  4. [Diskussion] js-controller 1.5.8 im Latest Repository
js-controller
76 Beiträge 20 Kommentatoren 13.7k Aufrufe 15 Beobachtet
  • J Offline
    Jan1
    Nach Update wurde der TR-064 Adapter nicht mehr grün und das stand im LOG:
    host.Beelink	2019-05-07 07:44:04.107	error	instance system.adapter.tr-064.0 terminated with code 1 ()
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:531:3)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:600:32)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:701:30)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: TypeError: fns.adapter is not a function
    Caught	2019-05-07 07:44:04.106	error	by controller[0]: ^
    Caught	2019-05-07 07:44:04.105	error	by controller[0]: fns.adapter = fns.adapter(options);
    Caught	2019-05-07 07:44:04.105	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    Hab dann wieder auf 1.5.7 downgegradet und nun läuft das ganze System nicht mehr:
    Error:	2019-05-07 07:53:08.820	error	at Timer.processTimers (timers.js:223:10)
    Error:	2019-05-07 07:53:08.820	error	at listOnTimeout (timers.js:263:5)
    Error:	2019-05-07 07:53:08.820	error	at tryOnTimeout (timers.js:300:5)
    Error:	2019-05-07 07:53:08.820	error	at ontimeout (timers.js:436:11)
    Error:	2019-05-07 07:53:08.820	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2024:16)
    Error:	2019-05-07 07:53:08.820	error	at Object.writeFileSync (fs.js:1189:35)
    Error:	2019-05-07 07:53:08.820	error	at Object.openSync (fs.js:438:3)
    Error:	2019-05-07 07:53:08.820	error	EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
    uncaught	2019-05-07 07:53:08.818	error	exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
    apollon77A arteckA 2 Antworten Letzte Antwort
    • J Jan1
      @Jan1 Also diesbezüglich gab es keine Änderung in der 1.5.8. Welche version war vorher drauf? Bitte tr-064 aktualisieren
      Bezüglich der Rechte da ist was komisch. Bitte den Installation Fixer laufen lassen oder das PID file von den rechten her fixen oder löschen
      • apollon77A apollon77
        Jan1
        @apollon77
        Es lief vorher die 1.5.7 und bis auf den TR-064 lief alles sofort.
        Ich konnte das System nun wieder manuell starten (node node_modules/iobroker.js-controller/controller.js --logs). Der js-controller ist nun auch wieder auf 1.5.7, allerdings läuft der TR-064 Adapter hier nun auch nicht mehr.
        Ich deinstalliere den mal, lass den Fixer laufen (unter root oder normaler User?). Wenn es danach immer noch Probleme gibt, melde ich mich noch mal.
        • J Jan1
          arteckA Offline
          arteckA Offline
          arteck
          @Jan1 sagte in [Diskussion] js-controller 1.5.8 im Latest Repository:
          TR-064 Adapter
          hab ich auch am laufen.. ohne Probleme.. welche Version ??
          • ? Offline
            Via Terminal ins Verzeichnis "/opt/iobroker/node_modules/iobroker.tr-064" gehen und:
            sudo npm install soef
            apollon77A J 2 Antworten Letzte Antwort
              @Yetiberg Da wäre ich vorsichtig!! Die soef Library wurde gern zwischen Releases gern mal inompatibel zu vorversionen. Also am besten von Girgub neu installieren den ganzen Adapter oder so
                Jan1
                @apollon77
                ich bin dabei ein Backup zurück zu spielen, mal sehen obs läuft. Adapter dürfte der aktuellste gewesen sein, da ich auch latest bin und bis auf den Host alles aktuell war 😉
                • apollon77A Offline
                  dann vllt besser latest npm anstelle GitHub versuchen
                    Jan1
                    @apollon77
                    wie stelle ich dass denn an?
                      im Zweifel an der Kommandozeile im ioBroker verzeichnis:
                      npm install iobroker.tr-064 --production
                      dann
                      iobroker upload tr-064
                      und instanz neu starten
                      • BBTownB Offline
                        BBTownB Offline
                        BBTown
                        schrieb am zuletzt editiert von BBTown
                        Bei mir verlief das Upgrade geräuschlos und alle Adapter sind auch gleich wieder auf grün gewechselt
                        [Nachtrag]
                        den tr-064 habe ich nicht im Einsatz
                        • J Offline
                          Jan1
                          Also der TR-064 hat definitiv ein Problem mit der neuen js-controiller Version!
                          Hab eben mal IOBroker nackt neu installiert und nur den TR-064 Adapter installiert, lief sofort grün. Dann den js-controller aktualisiert und der TR-064 Adapter läuft nicht mehr.
                          host.Beelink	2019-05-07 09:11:35.628	info	Restart adapter system.adapter.tr-064.0 because enabled
                          host.Beelink	2019-05-07 09:11:35.628	error	instance system.adapter.tr-064.0 terminated with code 1 ()
                          Caught	2019-05-07 09:11:35.628	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:531:3)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:600:32)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:701:30)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                          Caught	2019-05-07 09:11:35.627	error	by controller[0]: TypeError: fns.adapter is not a function
                          Caught	2019-05-07 09:11:35.626	error	by controller[0]: ^
                          Caught	2019-05-07 09:11:35.626	error	by controller[0]: fns.adapter = fns.adapter(options);
                          Caught	2019-05-07 09:11:35.626	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                          host.Beelink	2019-05-07 09:11:34.828	info	instance system.adapter.tr-064.0 started with pid 22165
                          host.Beelink	2019-05-07 09:11:04.813	info	Restart adapter system.adapter.tr-064.0 because enabled
                          wobei bei der IOBroker Installation auch das als Fehler in der Konsole aufgetaucht ist (lief aber durch):
                          make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
                          gyp ERR! build error
                          gyp ERR! stack Error: `make` failed with exit code: 2
                          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                          gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                          gyp ERR! System Linux 4.9.0-9-amd64
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                          gyp ERR! node -v v10.15.3
                          gyp ERR! node-gyp -v v3.8.0
                          gyp ERR! not ok
                          Hier mal die gesamte Ausgabe der Konsole von der IOBroker Installation:
                          root@Beelink:~# curl -sL https://iobroker.net/install.sh | bash -
                          Welcome to the ioBroker installer!
                          Installer version: 2019-04-04
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/4)
                          Creating ioBroker user and directory (2/4)
                          Directory /opt/iobroker created
                          Installing ioBroker (3/4)
                          In file included from ../node_modules/nan/nan.h:190:0,
                          from ../src/unix_dgram.cc:5:
                          ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Localv8::Object, v8::Localv8::Value, v8::Localv8::Value, v8::PropertyAttribute)’:
                          ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
                          return obj->ForceSet(GetCurrentContext(), key, value, attribs);
                          In file included from ../src/unix_dgram.cc:5:0:
                          ../node_modules/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’:
                          ../node_modules/nan/nan.h:817:60: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
                          , v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                          v8::Isolate::GetCurrent(), target, func, argc, argv);
                          In file included from ../node_modules/nan/nan.h:47:0,
                          /root/.node-gyp/10.15.3/include/node/node.h:177:50: note: declared here
                          NODE_EXTERN v8::Localv8::Value MakeCallback(
                          /root/.node-gyp/10.15.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                          attribute((deprecated(message))) declarator
                          ../node_modules/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value
                          ../node_modules/nan/nan.h:831:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                          v8::Isolate::GetCurrent(), target, symbol, argc, argv);
                          /root/.node-gyp/10.15.3/include/node/node.h:170:50: note: declared here
                          ../node_modules/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, const char
                          ../node_modules/nan/nan.h:845:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
                          , v8::Localv8::Object, const char*, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                          v8::Isolate::GetCurrent(), target, method, argc, argv);
                          /root/.node-gyp/10.15.3/include/node/node.h:163:50: note: declared here
                          ../node_modules/nan/nan.h: In member function ‘v8::Localv8::Value Nan::Callback::Call_(v8::Isolate
                          , v8::Localv8::Object, int, v8::Localv8::Value) const’:
                          ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
                          , v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                          ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          domain = info[0]->Int32Value();
                          In file included from /root/.node-gyp/10.15.3/include/node/v8.h:26:0,
                          from /root/.node-gyp/10.15.3/include/node/node.h:63,
                          from ../node_modules/nan/nan.h:47,
                          /root/.node-gyp/10.15.3/include/node/v8.h:2478:46: note: declared here
                          V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                          /root/.node-gyp/10.15.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                          declarator attribute((deprecated(message)))
                          ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          type = info[1]->Int32Value();
                          ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          protocol = info[2]->Int32Value();
                          ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          fd = info[0]->Int32Value();
                          ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                          String::Utf8Value path(info[1]);
                          /root/.node-gyp/10.15.3/include/node/v8.h:2892:28: note: declared here
                          explicit Utf8Value(Localv8::Value obj));
                          ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          ../src/unix_dgram.cc:259:27: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          buf = info[1]->ToObject();
                          In file included from /root/.node-gyp/10.15.3/include/node/node.h:63:0,
                          /root/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
                          Local<Object> Value::ToObject() const {
                          ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          offset = info[2]->Uint32Value();
                          /root/.node-gyp/10.15.3/include/node/v8.h:2477:47: note: declared here
                          V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                          ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          length = info[3]->Uint32Value();
                          ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                          String::Utf8Value path(info[4]);
                          ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          ../src/unix_dgram.cc:303:27: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                          ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                          gyp ERR! stack Error: make failed with exit code: 2
                          gyp ERR! not ok
                          Finalizing installation (4/4)
                          Enabling autostart...
                          Autostart enabled!
                          ioBroker was installed successfully
                          Open http://192.168.100.10:8081 in a browser and start configuring!
                          You need to re-login before doing anything else on the console!
                            dann
                            Jan1
                            @apollon77 sagte in [Diskussion] js-controller 1.5.8 im Latest Repository:
                            dann
                            Habe ich getestet und funktioniert nicht.
                            Sobald ich auf 1.5.8 hoch gehe, geht der TR-064 Adapter mit dem oben geposteten Fehler nicht mehr. Auch wenn ich danach wieder zurück auf 1.5.7 gehe.
                            Was allerdings da Problem löst und zwar dauerhaft, ist der Vorschalg von @Yetiberg "sudo npm install soef"
                            im Verzeichnis "/opt/iobroker/node_modules/iobroker.tr-064".
                            Das funktioniert selbst wenn ich von 1.5.8 nach 1.5.7 zurück gehe, Adapter wird sofort grün und bleibt auch grün bei einem erneuten Update auf 1.5.8.
                            Das ganze hab ich wieder auf einer jungfräulichen IOBroker Installation mit Node 10.15.3 und NPM 6.9.0 unter Debian 9.8 mit 64 Struktur getestet.
                            Also irgendwas passt da nicht zusammen.
                            Braucht Ihr noch mehr Infos zum System? Ich bin heute noch bis 13Uhr am Basteln 😉
                              Eine frische Installation bringt js-controller 1.4.2 denke ich ... ist also die Frage ob das an 1.4.2->1.5.x liegt ... an 1.5.8 an sich kann ich mir nicht vorstellen.
                              Wenn ein install der soef lib ersthal hilft ist ja super. Der Adapter wird eh bald durch eine community Version ersetzt
                              J SBorgS 2 Antworten Letzte Antwort
                              • J Jan1
                                dann
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @Jan1
                                nochmal bei mir läuft es
                                  Jan1
                                  @apollon77
                                  Welcher Adapter wird ersetzt, der TR-064?
                                  Also ich teste gerne wo es hier klemmt, hab gerade alles wieder mit einem Backup und der aktuellen Version 1.5.8 am Laufen, wobei er mir jetzt das Problem beim wifilight Adapter an meckert.
                                  Ich schau mal ob man das auch mit "sudo npm install soef" auf die Reihe bekommt, an sonst lösche ich noch mal alles und bleibe bei der 1.5.7.
                                  • arteckA arteck
                                    @Jan1
                                    Jan1
                                    @arteck
                                    Ja das ist schön für Dich, hatte ja auch einige Fehler bei der IOBroker Installation gepostet, die eventuell an der Node 10 oder an meinem 64er Debian liegen könnten.
                                    Ich bin hier nicht wirklich fit und deshalb postet ich auch alles was auffällig ist. Bei mit läuft der TR-064 ja nun auch, nach dem ich "sudo npm install soef" im Adapter Verzeichnis durchgeführt hatte, nur dass jetzt eben der wifilight Adapter das an meckert.
                                    Ich bin hier auf Euch angewiesen, was noch zu tun ist, oder doch was am gesamt System nicht passt. Deshalb bitte fragen wenn ich mich unklar ausdrücke, oder mehr Infos benötigt werden.
                                    • J Jan1
                                      @arteck
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @Jan1 ich würde mich an deiner stelle ein wenig mit den zusamenhängen zwischen den js-controller und den einzelnen Adaptern beschäftigen.. um eine grundlegende Basis zu erreichen.. es bringt uns wenig wenn du uns mit Fehlermeldungen zuballerst.. nur weil an deinem System was nicht funktioniert.. und du weisst nicht warum...
                                      vor allem nicht in panik verfallen :-)
                                      • arteckA arteck
                                        Jan1
                                        @arteck
                                        Nein, Panik habe ich keine mehr. Ich schaff es ja mit dem Backup das ganze immer wieder recht schnell ans Laufen zu bringen.
                                        Dein Rat in Ehren, genau das versuche ich ja auch, nur ist das eben nicht so einfach. Hast mal ein Link wo man das nach lesen kann, ohne dass man dazu gleich ein Studium braucht? ☺
                                        Ich lerne auf diese Art schon recht viel dazu, deshalb poste ich auch die Fehlermeldungen bei der IOBroker Installation. Da die durchläuft und danach ja auch für mich alles läuft, dürften das auch keine ernsten Geschichten sein. Hatte das vorher auf dem Raspberry laufen und da gabs eben keine Fehlermeldungen, wobei das auch noch unter Node 8 lief.
                                        Ich lese oft von Error Meldungen, die dann als "kann man ignorieren" bewertet werden.
                                        Zu ballern ist auch immer relativ, ich gebe lieber alle Infos weiter die mir in dem Fall relevant vorkommen und was ich beobachte. Ihr seid die Spezialisten und wenn man gebeten wird seine Erfahrungen zu posten, die man hat wenn eine neue Version getestet wird, dann mach ich das eben, oder wie sollen sonst alle Fehler auf den unterschiedlichen Systemen erkannt werden?
                                        Der Fixer hat da schon einiges vereinfacht und sorgt für eine recht einheitliche Installation (hat mir auch schon recht oft bei Problemen geholfen). Der große Unterschied dürfen aber immer noch die verschiedenen HW und SW Basis Installationen sein.
                                        • J Jan1
                                          @arteck
                                          sigi234S Online
                                          sigi234S Online
                                          Volle Zustimmung!
