  4. [Diskussion] js-controller 1.5.8 im Latest Repository
js-controller
76 Beiträge 20 Kommentatoren 13.7k Aufrufe 15 Beobachtet
  • sigi234S Online
    sigi234S Online
    Hallo Ingo,
    installiert, werde es beobachten. Alle Adapter Grün.
    Nachtrag:
    TR-064 bei mir Ok!
    Platform: Windows
    Architecture: x64
    CPUs: 4
    Speed: 3912 MHz
    Model: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
    RAM: 7.9 GB
    System uptime: 14:27:47
    Node.js: v8.16.0
    NPM: 6.4.1
    Admin: 3.6.2
    Disk size: 232.3 GiB
    Disk free: 135.4 GiB
    adapters count: 268
    Uptime: 00:03:39
    Active instances: 42
    • arteckA Offline
      arteckA Offline
      arteck
      grün läuft
      • J Offline
        Jan1
        Nach Update wurde der TR-064 Adapter nicht mehr grün und das stand im LOG:
        host.Beelink	2019-05-07 07:44:04.107	error	instance system.adapter.tr-064.0 terminated with code 1 ()
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:531:3)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:600:32)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:701:30)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: TypeError: fns.adapter is not a function
        Caught	2019-05-07 07:44:04.106	error	by controller[0]: ^
        Caught	2019-05-07 07:44:04.105	error	by controller[0]: fns.adapter = fns.adapter(options);
        Caught	2019-05-07 07:44:04.105	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
        Hab dann wieder auf 1.5.7 downgegradet und nun läuft das ganze System nicht mehr:
        Error:	2019-05-07 07:53:08.820	error	at Timer.processTimers (timers.js:223:10)
        Error:	2019-05-07 07:53:08.820	error	at listOnTimeout (timers.js:263:5)
        Error:	2019-05-07 07:53:08.820	error	at tryOnTimeout (timers.js:300:5)
        Error:	2019-05-07 07:53:08.820	error	at ontimeout (timers.js:436:11)
        Error:	2019-05-07 07:53:08.820	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2024:16)
        Error:	2019-05-07 07:53:08.820	error	at Object.writeFileSync (fs.js:1189:35)
        Error:	2019-05-07 07:53:08.820	error	at Object.openSync (fs.js:438:3)
        Error:	2019-05-07 07:53:08.820	error	EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
        uncaught	2019-05-07 07:53:08.818	error	exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
        apollon77A arteckA 2 Antworten Letzte Antwort
        • J Jan1
          @Jan1 Also diesbezüglich gab es keine Änderung in der 1.5.8. Welche version war vorher drauf? Bitte tr-064 aktualisieren
          Bezüglich der Rechte da ist was komisch. Bitte den Installation Fixer laufen lassen oder das PID file von den rechten her fixen oder löschen
          • apollon77A apollon77
            Jan1
            @apollon77
            Es lief vorher die 1.5.7 und bis auf den TR-064 lief alles sofort.
            Ich konnte das System nun wieder manuell starten (node node_modules/iobroker.js-controller/controller.js --logs). Der js-controller ist nun auch wieder auf 1.5.7, allerdings läuft der TR-064 Adapter hier nun auch nicht mehr.
            Ich deinstalliere den mal, lass den Fixer laufen (unter root oder normaler User?). Wenn es danach immer noch Probleme gibt, melde ich mich noch mal.
            • J Jan1
              arteckA Offline
              arteckA Offline
              arteck
              @Jan1 sagte in [Diskussion] js-controller 1.5.8 im Latest Repository:
              TR-064 Adapter
              hab ich auch am laufen.. ohne Probleme.. welche Version ??
              • ? Offline
                Via Terminal ins Verzeichnis "/opt/iobroker/node_modules/iobroker.tr-064" gehen und:
                sudo npm install soef
                apollon77A J 2 Antworten Letzte Antwort
                  @Yetiberg Da wäre ich vorsichtig!! Die soef Library wurde gern zwischen Releases gern mal inompatibel zu vorversionen. Also am besten von Girgub neu installieren den ganzen Adapter oder so
                    Jan1
                    @apollon77
                    ich bin dabei ein Backup zurück zu spielen, mal sehen obs läuft. Adapter dürfte der aktuellste gewesen sein, da ich auch latest bin und bis auf den Host alles aktuell war 😉
                    • apollon77A Offline
                      dann vllt besser latest npm anstelle GitHub versuchen
                        Jan1
                        @apollon77
                        wie stelle ich dass denn an?
                          im Zweifel an der Kommandozeile im ioBroker verzeichnis:
                          npm install iobroker.tr-064 --production
                          dann
                          iobroker upload tr-064
                          und instanz neu starten
                          • BBTownB Offline
                            BBTownB Offline
                            BBTown
                            schrieb am zuletzt editiert von BBTown
                            Bei mir verlief das Upgrade geräuschlos und alle Adapter sind auch gleich wieder auf grün gewechselt
                            [Nachtrag]
                            den tr-064 habe ich nicht im Einsatz
                            • J Offline
                              Jan1
                              Also der TR-064 hat definitiv ein Problem mit der neuen js-controiller Version!
                              Hab eben mal IOBroker nackt neu installiert und nur den TR-064 Adapter installiert, lief sofort grün. Dann den js-controller aktualisiert und der TR-064 Adapter läuft nicht mehr.
                              host.Beelink	2019-05-07 09:11:35.628	info	Restart adapter system.adapter.tr-064.0 because enabled
                              host.Beelink	2019-05-07 09:11:35.628	error	instance system.adapter.tr-064.0 terminated with code 1 ()
                              Caught	2019-05-07 09:11:35.628	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:754:12)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:531:3)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:600:32)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:701:30)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                              Caught	2019-05-07 09:11:35.627	error	by controller[0]: TypeError: fns.adapter is not a function
                              Caught	2019-05-07 09:11:35.626	error	by controller[0]: ^
                              Caught	2019-05-07 09:11:35.626	error	by controller[0]: fns.adapter = fns.adapter(options);
                              Caught	2019-05-07 09:11:35.626	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                              host.Beelink	2019-05-07 09:11:34.828	info	instance system.adapter.tr-064.0 started with pid 22165
                              host.Beelink	2019-05-07 09:11:04.813	info	Restart adapter system.adapter.tr-064.0 because enabled
                              wobei bei der IOBroker Installation auch das als Fehler in der Konsole aufgetaucht ist (lief aber durch):
                              make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Fehler 1
                              gyp ERR! build error
                              gyp ERR! stack Error: `make` failed with exit code: 2
                              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                              gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
                              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                              gyp ERR! System Linux 4.9.0-9-amd64
                              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                              gyp ERR! node -v v10.15.3
                              gyp ERR! node-gyp -v v3.8.0
                              gyp ERR! not ok
                              Hier mal die gesamte Ausgabe der Konsole von der IOBroker Installation:
                              root@Beelink:~# curl -sL https://iobroker.net/install.sh | bash -
                              Welcome to the ioBroker installer!
                              Installer version: 2019-04-04
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/4)
                              Creating ioBroker user and directory (2/4)
                              Directory /opt/iobroker created
                              Installing ioBroker (3/4)
                              In file included from ../node_modules/nan/nan.h:190:0,
                              from ../src/unix_dgram.cc:5:
                              ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Localv8::Object, v8::Localv8::Value, v8::Localv8::Value, v8::PropertyAttribute)’:
                              ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
                              return obj->ForceSet(GetCurrentContext(), key, value, attribs);
                              In file included from ../src/unix_dgram.cc:5:0:
                              ../node_modules/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’:
                              ../node_modules/nan/nan.h:817:60: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
                              , v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                              v8::Isolate::GetCurrent(), target, func, argc, argv);
                              In file included from ../node_modules/nan/nan.h:47:0,
                              /root/.node-gyp/10.15.3/include/node/node.h:177:50: note: declared here
                              NODE_EXTERN v8::Localv8::Value MakeCallback(
                              /root/.node-gyp/10.15.3/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                              attribute((deprecated(message))) declarator
                              ../node_modules/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value
                              ../node_modules/nan/nan.h:831:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                              v8::Isolate::GetCurrent(), target, symbol, argc, argv);
                              /root/.node-gyp/10.15.3/include/node/node.h:170:50: note: declared here
                              ../node_modules/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, const char
                              ../node_modules/nan/nan.h:845:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
                              , v8::Localv8::Object, const char*, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                              v8::Isolate::GetCurrent(), target, method, argc, argv);
                              /root/.node-gyp/10.15.3/include/node/node.h:163:50: note: declared here
                              ../node_modules/nan/nan.h: In member function ‘v8::Localv8::Value Nan::Callback::Call_(v8::Isolate
                              , v8::Localv8::Object, int, v8::Localv8::Value) const’:
                              ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
                              , v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              domain = info[0]->Int32Value();
                              In file included from /root/.node-gyp/10.15.3/include/node/v8.h:26:0,
                              from /root/.node-gyp/10.15.3/include/node/node.h:63,
                              from ../node_modules/nan/nan.h:47,
                              /root/.node-gyp/10.15.3/include/node/v8.h:2478:46: note: declared here
                              V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                              /root/.node-gyp/10.15.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                              declarator attribute((deprecated(message)))
                              ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              type = info[1]->Int32Value();
                              ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              protocol = info[2]->Int32Value();
                              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              fd = info[0]->Int32Value();
                              ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                              String::Utf8Value path(info[1]);
                              /root/.node-gyp/10.15.3/include/node/v8.h:2892:28: note: declared here
                              explicit Utf8Value(Localv8::Value obj));
                              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              ../src/unix_dgram.cc:259:27: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              buf = info[1]->ToObject();
                              In file included from /root/.node-gyp/10.15.3/include/node/node.h:63:0,
                              /root/.node-gyp/10.15.3/include/node/v8.h:10046:15: note: declared here
                              Local<Object> Value::ToObject() const {
                              ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              offset = info[2]->Uint32Value();
                              /root/.node-gyp/10.15.3/include/node/v8.h:2477:47: note: declared here
                              V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                              ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              length = info[3]->Uint32Value();
                              ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                              String::Utf8Value path(info[4]);
                              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              ../src/unix_dgram.cc:303:27: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                              ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              gyp ERR! stack Error: make failed with exit code: 2
                              gyp ERR! not ok
                              Finalizing installation (4/4)
                              Enabling autostart...
                              Autostart enabled!
                              ioBroker was installed successfully
                              Open http://192.168.100.10:8081 in a browser and start configuring!
                              You need to re-login before doing anything else on the console!
                                dann
                                Jan1
                                @apollon77 sagte in [Diskussion] js-controller 1.5.8 im Latest Repository:
                                dann
                                Habe ich getestet und funktioniert nicht.
                                Sobald ich auf 1.5.8 hoch gehe, geht der TR-064 Adapter mit dem oben geposteten Fehler nicht mehr. Auch wenn ich danach wieder zurück auf 1.5.7 gehe.
                                Was allerdings da Problem löst und zwar dauerhaft, ist der Vorschalg von @Yetiberg "sudo npm install soef"
                                im Verzeichnis "/opt/iobroker/node_modules/iobroker.tr-064".
                                Das funktioniert selbst wenn ich von 1.5.8 nach 1.5.7 zurück gehe, Adapter wird sofort grün und bleibt auch grün bei einem erneuten Update auf 1.5.8.
                                Das ganze hab ich wieder auf einer jungfräulichen IOBroker Installation mit Node 10.15.3 und NPM 6.9.0 unter Debian 9.8 mit 64 Struktur getestet.
                                Also irgendwas passt da nicht zusammen.
                                Braucht Ihr noch mehr Infos zum System? Ich bin heute noch bis 13Uhr am Basteln 😉
                                  Eine frische Installation bringt js-controller 1.4.2 denke ich ... ist also die Frage ob das an 1.4.2->1.5.x liegt ... an 1.5.8 an sich kann ich mir nicht vorstellen.
                                  Wenn ein install der soef lib ersthal hilft ist ja super. Der Adapter wird eh bald durch eine community Version ersetzt
                                  J SBorgS 2 Antworten Letzte Antwort
                                  • J Jan1
                                    dann
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @Jan1
                                    nochmal bei mir läuft es
                                      Jan1
                                      @apollon77
                                      Welcher Adapter wird ersetzt, der TR-064?
                                      Also ich teste gerne wo es hier klemmt, hab gerade alles wieder mit einem Backup und der aktuellen Version 1.5.8 am Laufen, wobei er mir jetzt das Problem beim wifilight Adapter an meckert.
                                      Ich schau mal ob man das auch mit "sudo npm install soef" auf die Reihe bekommt, an sonst lösche ich noch mal alles und bleibe bei der 1.5.7.
                                      • arteckA arteck
                                        @Jan1
                                        Jan1
                                        @arteck
                                        Ja das ist schön für Dich, hatte ja auch einige Fehler bei der IOBroker Installation gepostet, die eventuell an der Node 10 oder an meinem 64er Debian liegen könnten.
                                        Ich bin hier nicht wirklich fit und deshalb postet ich auch alles was auffällig ist. Bei mit läuft der TR-064 ja nun auch, nach dem ich "sudo npm install soef" im Adapter Verzeichnis durchgeführt hatte, nur dass jetzt eben der wifilight Adapter das an meckert.
                                        Ich bin hier auf Euch angewiesen, was noch zu tun ist, oder doch was am gesamt System nicht passt. Deshalb bitte fragen wenn ich mich unklar ausdrücke, oder mehr Infos benötigt werden.
                                        • J Jan1
                                          @arteck
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @Jan1 ich würde mich an deiner stelle ein wenig mit den zusamenhängen zwischen den js-controller und den einzelnen Adaptern beschäftigen.. um eine grundlegende Basis zu erreichen.. es bringt uns wenig wenn du uns mit Fehlermeldungen zuballerst.. nur weil an deinem System was nicht funktioniert.. und du weisst nicht warum...
                                          vor allem nicht in panik verfallen :-)
