  4. [HowTo] rtsp mit ffmpeg für vis konvertieren
vistemplate
59 Beiträge 24 Kommentatoren 31.2k Aufrufe 14 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    :D :D :D … und läuft!
    Ganz herzlichen Dank :!:
    • H Offline
      HoffmannOs
      ` > * javascript.0 2018-12-28 01:22:59.897 info script.js.Alarmanlage.ffmpeg: ffmpeg has exited unexpected! Restart in 30s!
      javascript.0 2018-12-28 01:22:59.897 info script.js.Alarmanlage.ffmpeg: getState(id=ffmpegCam.run, timerId=0) => [object Object]
      javascript.0 2018-12-28 01:22:59.897 info script.js.Alarmanlage.ffmpeg: ffmpeg error: ffmpeg version 3.2.12-1~deb9u1 Copyright © 2000-2018 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --pre
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: ffmpeg stop failed: ffmpeg: Kein Prozess gefunden
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: exec: ffmpeg -i "rtsp://xxx:xxxx12@192.168.181.53:554/onvif/profile1/media.smp" [http://localhost:8090/ipcam1.ffm](http://localhost:8090/ipcam1.ffm)
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: ffmpeg start...
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: exec: killall ffmpeg
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: ffmpeg stop...
      javascript.0 2018-12-28 01:22:54.447 warn script.js.Alarmanlage.ffmpeg: clearTimeout() => not found
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: setForeignState(id=javascript.0.ffmpegCam.statistics.cntRestart, state=45)
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: getState(id=ffmpegCam.statistics.cntRestart, timerId=0) => [object Object]
      javascript.0 2018-12-28 01:22:54.447 info script.js.Alarmanlage.ffmpeg: setForeignState(id=javascript.0.ffmpegCam.statistics.lastRestart, state="2018-12-28 01:22:54")
      javascript.0 2018-12-28 01:22:24.421 info script.js.Alarmanlage.ffmpeg: setTimeout(ms=30000)
      javascript.0 2018-12-28 01:22:24.421 info script.js.Alarmanlage.ffmpeg: ffmpeg has exited unexpected! Restart in 30s!
      javascript.0 2018-12-28 01:22:24.421 info script.js.Alarmanlage.ffmpeg: getState(id=ffmpegCam.run, timerId=0) => [object Object]
      javascript.0 2018-12-28 01:22:24.418 info script.js.Alarmanlage.ffmpeg: ffmpeg error: ffmpeg version 3.2.12-1~deb9u1 Copyright © 2000-2018 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --pre
      javascript.0 2018-12-28 01:22:18.922 info script.js.Alarmanlage.ffmpeg: exec: ffmpeg -i "rtsp://xxx:xx@192.168.181.53:554/onvif/profile1/media.smp" [http://localhost:8090/ipcam1.ffm](http://localhost:8090/ipcam1.ffm)
      javascript.0 2018-12-28 01:22:18.922 info script.js.Alarmanlage.ffmpeg: ffmpeg start...
      javascript.0 2018-12-28 01:22:18.921 info script.js.Alarmanlage.ffmpeg: Start ffmpeg...
      javascript.0 2018-12-28 01:22:18.921 info script.js.Alarmanlage.ffmpeg: Run state changed from false to true
      javascript.0 2018-12-28 01:22:05.055 info script.js.Alarmanlage.ffmpeg: exec: /usr/bin/ffserver &
      javascript.0 2018-12-28 01:22:05.055 info script.js.Alarmanlage.ffmpeg: ffserver start... `
      ich bekomme immer diesen fehler. kann mir jemand helfen?
      • ChaotC Offline
        ChaotC Offline
        Chaot
        Das ist eventuell der gleiche Fehler wie bei mir.
        aus
        muss
        rtsp://xxx:xx@192.168.181.53:554/onvif/profile1/media.smp\
        werden. dann sollte es funktionieren.
        Allerdings wundert mich die Adresse. Bist du sicher das da drüber der Stream kommt?
        Allerdings funktioniert bei mir jetzt zwar das Script, aber der Stream leider nicht. 😢
        • JohGreJ Offline
          JohGreJ Offline
          JohGre
          Ob der Stream funktioniert kannst du schnell mit VLC unter "Medien –> Netzwerkstream öffnen" testen.
          nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
            aleks-83
            Ich versuche auch gerade einen restream per ffmpeg aufzubauen.
            Habe aber ein Problem.
            Irgendwie scheitert die Verbindung zum localhost.
            Ich habe auch versucht localhost durch 127.0.0.1 oder die IP des servers zu ersetzen.
            Keine Änderung...
            ffmpeg version 3.2.12-1~deb9u1 Copyright (c) 2000-2018 the FFmpeg developers
              configuration: --prefix=/usr --extra-version='1~deb9u1'
            --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu
            --enable-gpl --disable-stripping --enable-avresample --enable-avisynth
            --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray
            --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libebur128
            --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi
             --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg
             --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband
            --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex
            --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis
            --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265
            --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx
            --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394
            --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv
            --enable-libx264 --enable-shared
              libavutil      55. 34.101 / 55. 34.101
              libavcodec     57. 64.101 / 57. 64.101
              libavformat    57. 56.101 / 57. 56.101
              libavdevice    57.  1.100 / 57.  1.100
              libavfilter     6. 65.100 /  6. 65.100
              libavresample   3.  1.  0 /  3.  1.  0
              libswscale      4.  2.100 /  4.  2.100
              libswresample   2.  3.100 /  2.  3.100
              libpostproc    54.  1.100 / 54.  1.100
            Input #0, rtsp, from 'rtsp://USER:PASS@10.0.0.21:554/Streaming/Channels/102':
              Metadata:
                title           : Media Presentation
              Duration: N/A, start: 0.310000, bitrate: N/A
                Stream #0:0: Video: h264 (Main), yuvj420p(pc, bt709, progressive), 640x360 [SAR 1:1 DAR 16:9], 20 fps, 25 tbr, 90k tbn, 40 tbc
            [tcp @ 0x55fc826e03a0] Connection to tcp://localhost:8090 failed (Connection refused), trying next address
            [tcp @ 0x55fc826e03a0] Connection to tcp://localhost:8090 failed: Connection refused
            http://localhost:8090/Eingang.ffm: Connection refused
            Der FFserver bzw. das WebIF ist aber auch nicht über die IP.des.Servers:8090 zu erreichen...
            Das scheint wohl das Problem zu sein.
            = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
            = Node.js v20.19.6 = NPM 22.22.2 = JS Controller 7.2.2 =
            Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
            Glasfaser 400
              aleks-83
              schrieb am zuletzt editiert von aleks-83
              Weiß niemand warum der ffserver nicht unter 8090 zu erreichen ist?
              Welche Befehle oder stati kann ich checken um ihn zum Laufen zu bekommen?
              Glasfaser 400
              • wendy2702W Online
                wendy2702W Online
                Gibt wenn ich mich nicht täusche für ffmpeg Optionen zum erweiterten Loggen. Mal googeln und schauen ob es mehr infos gibt.
                  aleks-83
                  @wendy2702 @eastcoast
                  Ich habe den ffmpeg Server nochmal mit einem Ubuntu 18.04 aufgesetzt.
                  Das läuft jetzt soweit besser durch.
                  Den Loglevel habe ich aber auch mal auf debug gesetzt.
                  Jetzt bekomme ich eine 404 Meldung:
                  root@ffmpeg:~# ffmpeg -loglevel debug -i "rtsp://ffmpeg:stream123@10.0.0.21:554/Streaming/Channels/102/" http://10.0.0.17:8090/eingang.ffm
                  ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers
                    built with gcc 7 (Ubuntu 7.3.0-16ubuntu3)
                    configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
                    libavutil      55. 78.100 / 55. 78.100
                    libavcodec     57.107.100 / 57.107.100
                    libavformat    57. 83.100 / 57. 83.100
                    libavdevice    57. 10.100 / 57. 10.100
                    libavfilter     6.107.100 /  6.107.100
                    libavresample   3.  7.  0 /  3.  7.  0
                    libswscale      4.  8.100 /  4.  8.100
                    libswresample   2.  9.100 /  2.  9.100
                    libpostproc    54.  7.100 / 54.  7.100
                  Splitting the commandline.
                  Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'.
                  Reading option '-i' ... matched as input url with argument 'rtsp://ffmpeg:stream123@10.0.0.21:554/Streaming/Channels/102/'.
                  Reading option 'http://10.0.0.17:8090/eingang.ffm' ... matched as output url.
                  Finished splitting the commandline.
                  Parsing a group of options: global .
                  Applying option loglevel (set logging level) with argument debug.
                  Successfully parsed a group of options.
                  Parsing a group of options: input url rtsp://ffmpeg:stream123@10.0.0.21:554/Streaming/Channels/102/.
                  Opening an input file: rtsp://ffmpeg:stream123@10.0.0.21:554/Streaming/Channels/102/.
                  [tcp @ 0x55d237b01aa0] No default whitelist set
                  [rtsp @ 0x55d237aff8c0] SDP:
                  v=0
                  o=- 1553524705086562 1553524705086562 IN IP6 ::
                  s=Media Presentation
                  e=NONE
                  b=AS:5050
                  t=0 0
                  a=control:rtsp://10.0.0.21:554/Streaming/Channels/102/
                  m=video 0 RTP/AVP 96
                  c=IN IP6 ::
                  b=AS:5000
                  a=recvonly
                  a=x-dimensions:640,360
                  a=control:rtsp://10.0.0.21:554/Streaming/Channels/102/trackID=1
                  a=rtpmap:96 H264/90000
                  a=fmtp:96 profile-level-id=420029; packetization-mode=1; sprop-parameter-sets=Z01AHppkBQF/y4C3AQEBQAAA+gAAJxA6GAEVwAEVsu8uNDACK4ACK2XeXCg=,aO48gA==
                  a=Media_header:MEDIAINFO=494D4B48010200000400000100000000000000000000000000000000000000000000000000000000;
                  a=appversion:1.0
                  [rtsp @ 0x55d237aff8c0] video codec set to: h264
                  [rtsp @ 0x55d237aff8c0] RTP Profile IDC: 42 Profile IOP: 0 Level: 29
                  [rtsp @ 0x55d237aff8c0] RTP Packetization Mode: 1
                  [rtsp @ 0x55d237aff8c0] Extradata set to 0x55d237b029a0 (size: 56)
                  [rtp @ 0x55d237b03b40] No default whitelist set
                  [udp @ 0x55d237b04360] No default whitelist set
                  [udp @ 0x55d237b04360] end receive buffer size reported is 131072
                  [udp @ 0x55d237b14800] No default whitelist set
                  [udp @ 0x55d237b14800] end receive buffer size reported is 131072
                  [rtsp @ 0x55d237aff8c0] setting jitter buffer size to 500
                  [rtsp @ 0x55d237aff8c0] hello state=0
                  [h264 @ 0x55d237b03380] nal_unit_type: 7, nal_ref_idc: 3
                  [h264 @ 0x55d237b03380] nal_unit_type: 8, nal_ref_idc: 3
                  [h264 @ 0x55d237b03380] nal_unit_type: 5, nal_ref_idc: 3
                  [h264 @ 0x55d237b03380] Reinit context to 640x368, pix_fmt: yuvj420p
                  [h264 @ 0x55d237b03380] nal_unit_type: 1, nal_ref_idc: 3
                      Last message repeated 3 times
                  [rtsp @ 0x55d237aff8c0] All info found
                  Input #0, rtsp, from 'rtsp://ffmpeg:stream123@10.0.0.21:554/Streaming/Channels/102/':
                    Metadata:
                      Stream #0:0, 28, 1/90000: Video: h264 (Main), 1 reference frame, yuvj420p(pc, bt709, progressive, left), 640x360 (640x368) [SAR 1:1 DAR 16:9], 0/1, 20 fps, 25 tbr, 90k tbn, 40 tbc
                  Successfully opened the file.
                  Parsing a group of options: output url http://10.0.0.17:8090/eingang.ffm.
                  Opening an output file: http://10.0.0.17:8090/eingang.ffm.
                  [NULL @ 0x55d237b3ce00] Opening 'http://10.0.0.17:8090/eingang.ffm' for reading
                  [http @ 0x55d237bf21a0] Setting default whitelist 'http,https,tls,rtp,tcp,udp,crypto,httpproxy'
                  [http @ 0x55d237bf21a0] request: GET /eingang.ffm HTTP/1.1
                  User-Agent: Lavf/57.83.100
                  Accept: */*
                  Range: bytes=0-
                  Connection: close
                  Host: 10.0.0.17:8090
                  Icy-MetaData: 1
                  [http @ 0x55d237bf21a0] HTTP error 404 Not Found
                  http://10.0.0.17:8090/eingang.ffm: Server returned 404 Not Found
                  Bei dieser Konfig:
                  HTTPPort 8090
                  HTTPBindAddress 0.0.0.0
                  MaxHTTPConnections 200
                  MaxClients 100
                  MaxBandwidth 4096
                  # CustomLog -
                  # IP camera feed...
                  <feed eingang.ffm>
                  File /tmp/eingang.ffm
                  FileMaxSize 1M
                  ACL allow 127.0.0.1
                  </feed>
                  # Streams...
                  <stream eingang.rtsp>
                  Feed eingang.ffm
                  Format rtsp
                  #VideoCodec libx264 (auch getestet)
                  VideoQMin 1
                  VideoQMax 4
                  VideoFrameRate 20
                  VideoSize 640x360
                  VideoBufferSize 1024
                  VideoBitRate 1024
                  NoAudio
                  Strict -1
                  </stream>
                  <stream status.html="">
                  # Server status URL Format status
                  # Only allow local people to get the status
                  ACL allow 0.0.0.0 255.255.255.255
                  </stream>
                  <redirect index.html>
                  # Just an URL redirect for index
                  # Redirect index.html to the appropriate site
                  URL http://www.ffmpeg.org/
                  </redirect>
                  Die Status-Seite gibt folgendes aus:
                  Klicke ich auf "eingang.rtsp" wird diese nicht gefunden...
                  File '/eingang.rtsp' not found
                  Glasfaser 400
                  • wendy2702W Online
                    wendy2702W Online
                    @aleks-83 sagte in [Tipp] IP-Kamera Stream mit ffmpeg für vis konvertieren:
                    Was soll das denn sein?
                      aleks-83
                      Der Feed der auf der Stream zeigt!?
                      Glasfaser 400
                      • A aleks-83
                        v=0
                        e=NONE
                        b=AS:5050
                        t=0 0
                        c=IN IP6 ::
                        b=AS:5000
                        a=recvonly
                        a=appversion:1.0
                          Metadata:
                        Accept: */*
                        Range: bytes=0-
                        Connection: close
                        Icy-MetaData: 1
                        Bei dieser Konfig:
                        HTTPPort 8090
                        MaxClients 100
                        MaxBandwidth 4096
                        # CustomLog -
                        # IP camera feed...
                        <feed eingang.ffm>
                        FileMaxSize 1M
                        ACL allow 127.0.0.1
                        </feed>
                        # Streams...
                        Feed eingang.ffm
                        Format rtsp
                        VideoQMin 1
                        VideoQMax 4
                        VideoFrameRate 20
                        VideoSize 640x360
                        VideoBitRate 1024
                        NoAudio
                        Strict -1
                        </stream>
                        </stream>
                        </redirect>
                        wendy2702W Online
                        wendy2702W Online
                        Denke da stimmt etwas mit den Optionen nicht. Es wird ja scheinbar von FFMPEG versucht das File zu öffnen.
                          aleks-83
                          Ja,
                          mit dem Befehl:
                          versucht er doch den rtsp Stream aus der 10.0.0.21 mit der http://10.0.0.17:8090/eingang.ffm zu verbinden, oder nicht?
                          Diese legt er dann in /tmp/ ab, und versucht sie als stream zu öffnen.
                          So verstehe ich das Ganze...
                          Glasfaser 400
                          • wendy2702W Online
                            wendy2702W Online
                            Da müsste ich mich wieder rein lesen wenn ich ehrlich bin.
                              aleks-83
                              Hmmm.
                              Ich scheine ja kurz vorm Ziel zu sein.
                              OffTopic:
                              MotionEye würde ja gehen, aber das will ich meinem NUC nicht antun.
                              Der läuft dann auf 75% CPU Last bei 4 Kameras.
                              Glasfaser 400
                              • wendy2702W Online
                                wendy2702W Online
                                Ob ffmpeg bei 4 Kameras nachher weniger benötigt?
                                Ich wollte/habe Motioneye ja auch gewählt da ich aufzeichnen möchte und das relativ einfach verwalten will.
                                Kameras ohne Aufzeichung im Aussenbereich macht für mich keinen bis wenig sinn.
                                  aleks-83
                                  Aufzeichnung macht meine Synology.
                                  Da sie aber zu schwach ist um auch noch MotionEye (für das restreaming) zu machen, wollte ich meinen NUC dafür nutzen.
                                  Glasfaser 400
                                  • wendy2702W Online
                                    wendy2702W Online
                                    Aber kann man nicht direkt von der Synology den Stream bekommen?
                                    Habe ich hier im Forum nicht so etwas mal gelesen ?
                                      aleks-83
                                      Die gibt nur rtsp raus.
                                      Aus der Surveillance Station
                                      Es gibt zwar ein PHP Skript was die Umwandlung in MJPEG übernimmt, das liefert aber nur alle paar Sekunden ein Bild.
                                      Das ist für mich kein Stream.
                                      Glasfaser 400
                                      • wendy2702W Online
                                        wendy2702W Online
                                        OK.
                                        Das altbekannte Problem mit rtsp und VIS :-(
                                        • wendy2702W wendy2702
                                          Samson71S Offline
                                          Samson71S Offline
                                          Samson71
                                          @wendy2702 sagte in [Tipp] IP-Kamera Stream mit ffmpeg für vis konvertieren:
                                          Meinst Du das hier von @apollon77?
                                          https://forum.iobroker.net/topic/3742/synology-surveillance-station-api/38
                                          Markus
                                          Bitte beachten:
