  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.8m Aufrufe 50 Beobachtet
  • simatecS
    simatecS
    simatec
    #1533
    @paul.honka:
    Hallo simatec,
    habe dem User iobroker ein Passwort vergeben, dann mit
    Putty User iobroker und Passwort Eingabe schliesst sich Putty sofort, wieso das denn???
    Hier die Ausgabe in Putty für user tinker
    ! tinker@ioBroker-Sted1:~$ bash /opt/iobroker/node_modules/iobroker.backitup/lib/s top_r_IOB.sh
    ! touch: '/opt/iobroker/node_modules/iobroker.backitup/lib/.startctl.info' kann ni cht berührt werden: Keine Berechtigung
    ! [DEBUG] [minimal] iobroker controller daemon is not running
    ! [DEBUG] [minimal] host.ioBroker-Sted1 OK.
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Clear all objects and states…
    ! [DEBUG] [minimal] clean 81 objects…
    ! [DEBUG] [minimal] clean 51 states…
    ! [DEBUG] [minimal] host.ioBroker-Sted1 done.
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 0/0 states
    ! [DEBUG] [minimal] 0 states restored.
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 0/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 200/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 400/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 600/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 800/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1000/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1200/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1400/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1600/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1800/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2000/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2200/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2400/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2600/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2800/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 3000/3280 objects
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 3200/3280 objects
    ! [DEBUG] [minimal] 3280 objects restored.
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Upload user file "vis.0/Meines/vis-views.json
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Upload user file "vis.0/main/vis-views.json
    ! [DEBUG] [minimal] host.ioBroker-Sted1 Upload user file "vis.0/main1/vis-views.json
    ! [DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.admin/admin
    ! [DEBUG] [minimal] upload [3] iobroker.admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    Der IOBroker ist auch im stop
    Beste Grüsse paul `
    Hat der Restore funktioniert?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS
      simatecS
      simatec
      #1534
      @Homoran:
      @simatec:
      Ich möchte aber hier noch einmal betonen, dass diese Dinge nicht mit backitup zu tun haben und auch backitup deswegen kein Problem hat.
      Diese Dinge betreffen einzig und allein euer System. `
      …und ich möchte nochmals betonen, dass es sich dabei nur um einen momentanen Workaround handeln darf, da damit die Sicherheitsbestrebungen, nicht mehr unter root zu arbeiten, ausgehebelt werden.
      Rainer `
      Genau aus diesen Sicherheitsbedenken und Bestrebungen habe ich auch die Threads dazu und auch die Doku von backitup geändert.
      Man sollte maximal folgendes einfügen:
      visudo
      DeinUsername ALL=(ALL) NOPASSWD: /bin/mount, /bin/umount, /bin/systemctl
      Danke nochmal für den Hinweis Rainer ;)
      • nukleuzN
        nukleuzN
        nukleuz
        #1535
        bei mir funktioniert eigentlich alles super mit dem Adapter - klasse Sache.
        Verschiebe die BackUps per CIFS auf meinen NAS (QNAP)…
        Beim Sichten der Daten ist mir dann aber aufgefallen, dass ich eine leeren/fehlerhaften mysql dump habe.
        Der mySQL Server ist auf einem anderen System als der ioBroker.
        Für Hilfe wäre ich sehr dankbar :shock:
        Hier noch das Logfile des Standardbackups:
        ! Gestartet…
        ! [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":""}
        ! [DEBUG] [mount] - done
        ! [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"mysqlEnabled":true,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"
        ","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"","deleteBackupAfter":5,"host":"192.168.0.66","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.1","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        ! [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_01_16-21_58_34_Standard_backupiobroker.tar.gz
        ! [DEBUG] [minimal] - done
        ! [DEBUG] [mysql] start with {"type":"creator","cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"
        ! [DEBUG] [mysql] - done
        ! [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"
        ","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
        ! [DEBUG] [cifs] - done
        ! [DEBUG] [clean] start with {"deleteBackupAfter":0}
        ! [DEBUG] [clean] - done
        ! [DEBUG] [pushover] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"mysqlEnabled":true,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_16-21_58_34_Standard_backupiobroker.tar.gz","/opt/iobroker/backups/mysql_2019_01_16-21_58_37_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal"],"types":["minimal"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"","deleteBackupAfter":5,"host":"192.168.0.66","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.1","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de","time":"16. Januar 2019 um 21:58 Uhr"},"backupDir":"/opt/iobroker/backups"}
        ! [DEBUG] [pushover] - [minimal] used pushover-Instance: pushover.1
        ! [DEBUG] [pushover] - done
        ! [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"mysqlEnabled":true,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_16-21_58_34_Standard_backupiobroker.tar.gz","/opt/iobroker/backups/mysql_2019_01_16-21_58_37_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal","mysql"],"types":["minimal","mysql"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"","deleteBackupAfter":5,"host":"192.168.0.66","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"16. Januar 2019 um 21:58 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.1","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        ! [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"****","backupDir":"/opt/iobroker/backups"}
        ! [DEBUG] [umount] - wait 60 seconds for umount!
        ! [DEBUG] [mysql] - MySql File deleted!
        ! [DEBUG] [history] - backitup.0.history.html
        ! [EXIT] 0
        ! [DEBUG] [umount] - done
        ! [EXIT] 0
        Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
        • K
          K
          klausiob
          #1536
          In der history.html stehen alle jemals erzeugten Backups drin.
          Kann man die gelöschten da herausnehmen?
          Ich verwende das Backup auf den an der Fritzbox eingesteckten USB-Stick und hier gibt es ja nur noch z.B. 5.
          Sorry falls es die Antwort im Forum schon gab, hab sie nicht gefunden.
          Gruß klausiob
          Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
          node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
          • simatecS
            simatecS
            simatec
            #1537
            Du kannst die Anzahl in den Einstellungen auf Wert x begrenzen
            • simatecS
              simatecS
              simatec
              #1538
              @nukleuz:
              filename="mysql_01.PNG" index="1">~~
              filename="mysql_02.PNG" index="0">~~
              ! Gestartet…
              ! [EXIT] 0
              ! [EXIT] 0 `
              Es gibt mehrere Möglichkeiten.
              1. Probiere statt der IP mal den Hostname deine db
              2. installiere auf deinem Iobroker System mysqldump und gebe den Pfad an, falls er vom Standard abweicht.
              3. überprüfe den Port
              4. Logindaten prüfen
              • MathiasJM
                MathiasJM
                MathiasJ
                #1539
                Danke,
                Das heißt, das ich in der neuen Installationsroutine keine Vorteile sondern eher nur Nachteile sehe.
                Da ich das System sowieso neu aufsetzen muß, lasse ich es, wie es gerade ist.
                Ich fahre gerade eine Minimal-Installation mit 2 Raspberries, weil ich bis jetzt eine wichtigere Baustelle hatte.
                Am Wochenende werde ich dann meine Beebox wieder aktivieren und IObroker mit der alten Methode installieren.
                Gruß,
                Mathias
                Gesendet von meinem MI 8 mit Tapatalk
                IObroker auf dem NUC als VM.
                • D
                  D
                  daNick
                  #1540
                  @simatec:
                  Nein bei der Auswahl von FTP wird nur eine Kopie auf dem FTP Server angelegt.
                  Du musst die Anzahl der maximalen Backups dementsprechend einstellen und auch unter FTP das löschen alter Backups aktivieren. `
                  Danke für die schnelle Antwort .
                  1. Mein FTP-User kann auf dem FTP offenbar keine Files löschen (OMV, ich kriege das im Moment nicht hin …).
                  Ich lösche das gelegentlich manuell; Speicher hat das NAS genug.
                  Kann es sein, dass Backitup lokal nicht löscht, wenn das Löschen auf dem FTP scheitert?
                  2. gibt es eine einfache Lösung, das lokale Backup sofort automatisch zu löschen?
                  Danke!
                  daNick
                  • nukleuzN
                    nukleuzN
                    nukleuz
                    #1541
                    @simatec:
                    Gesendet von iPhone mit Tapatalk `
                    1. Keine Änderung
                    2. mysqldump ist installiert -> /usr/bin/mysqldump -> ist glaube ich Standard und dennoch eingetragen
                    3. 3306 ist richtig
                    4. Logindaten geprüft -> alles richtig
                    Ich habe eben auf der Konsole des NAS (nicht ioB) versucht mit dem iobroker DB User ein BackUp zu machen über mysqldump (auf NAS).
                    Das ist fehlgeschlagen - mit root funktionierte es.
                    Trage ich allerdings root in die Adaptereinstellungen (ioB) ein klappt es genauso wenig :?
                    • simatecS
                      simatecS
                      simatec
                      #1542
                      @daNick:
                      @simatec:
                      Danke!
                      daNick `
                      Um das zu sehen, aktivere bitte den debug Modus für die Instanz von backitup und poste dann den Log eines automatischen Backups.
                      Bei manuellen Backups werden keine Files gelöscht
                      • K
                        K
                        klausiob
                        #1543
                        @simatec:
                        Die Backups sind auf 5 begrenzt und es liegen auch nur die 5 aktuellsten auf dem FTP-Server. Ich meine die Aufzählung der Backups in der backitup.0.history.html.
                        Gruß klausiob
                        • simatecS
                          simatecS
                          simatec
                          #1544
                          Auch die History kannst du begrenzen.
                          Dafür gibt es in den Haupteinstellungen einen Menüpunkt.
                          • simatecS
                            simatecS
                            simatec
                            #1545
                            Ab sofort ist die Version 1.0.7 im Github und ab heute Nacht im latest verfügbar.
                            1.0.7 (17.01.2019)
                            (simatec) better start/stop Handling for backup and restore
                            Mit dieser Version sollten die Start/Stop Probleme bei neuen Installationen behoben sein.
                            Ich habe heute einen ausgiebigen Test der Start/Stop Vorgänge inkl. Auswertungen gemacht.
                            Viel Spaß mit der neuen Version … ;)
                            • K
                              K
                              klausiob
                              #1546
                              @simatec:
                              Danke habe es gefunden. Tomaten auf den Augen bzw. kleine Schrift und hellgrau auf weiss, so AGB-like, nichts für alte Augen.
                              Danke vielmals
                              Gruß klausiob
                              • simatecS
                                simatecS
                                simatec
                                #1547
                                Sehr gerne Klaus … [emoji51]
                                • B
                                  B
                                  Buddinski88
                                  #1548
                                  Guten Abend zusammen,
                                  ich habe ein kleines Problem.
                                  Das Backup auf meine Synology DS218+ läuft soweit echt gut durch (musste ein bisschen kämpfen), aber die Lösung war das keine Sonderzeichen im Passwort des Users sein dürfen (falls es mal jemand braucht).
                                  Jetzt möchte ich das die DS nachts durch backitup per WOL aufgeweckt wird. Das aufwecken klappt auch soweit, aber die 25 Sekunden Wartezeit bis das Backup startet, reicht leider nicht aus.
                                  Die DS braucht so ca. 34 Sekunden bis sie da ist.
                                  Daher die Frage: Gibt es eine Möglichkeit die Wartezeit selber zu setzen? Wäre in meinen Augen eine sinnvolle Funktion da wohl nicht alle Geräte in 25 Sekunden am start sind :-)
                                  Bin gespannt ob ich da völlig falsch liege.
                                  Viele Grüße und besten Dank,
                                  Bastian
                                  • simatecS
                                    simatecS
                                    simatec
                                    #1549
                                    Ist schon in Planung die Wartezeit konfigurierbar zu machen.
                                    • B
                                      B
                                      Buddinski88
                                      #1550
                                      Super, das klingt doch sehr gut. Ist absehbar, wann das implementiert ist?
                                      • simatecS
                                        simatecS
                                        simatec
                                        #1551
                                        Ich denke in der nächsten Version.
                                        • B
                                          B
                                          Buddinski88
                                          #1552
                                          Dann hoffe ich mal darauf das die bald kommt :-)
                                          Noch mals vielen Dank für den genialen Adapter!
                                          33.2k
                                          84.3k
