Adapter: iobroker.backitup (stable Release)
Nein, oben korrigiert.
Sorry paul
Hallo simatec,
habe dem User iobroker ein Passwort vergeben, dann mit
Putty User iobroker und Passwort Eingabe schliesst sich Putty sofort, wieso das denn???
Hier die Ausgabe in Putty für user tinker
! tinker@ioBroker-Sted1:~$ bash /opt/iobroker/node_modules/iobroker.backitup/lib/s top_r_IOB.sh
! touch: '/opt/iobroker/node_modules/iobroker.backitup/lib/.startctl.info' kann ni cht berührt werden: Keine Berechtigung
! [DEBUG] [minimal] iobroker controller daemon is not running
! [DEBUG] [minimal] host.ioBroker-Sted1 OK.
! [DEBUG] [minimal] host.ioBroker-Sted1 Clear all objects and states…
! [DEBUG] [minimal] clean 81 objects…
! [DEBUG] [minimal] clean 51 states…
! [DEBUG] [minimal] host.ioBroker-Sted1 done.
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 0/0 states
! [DEBUG] [minimal] 0 states restored.
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 0/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 200/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 400/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 600/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 800/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1000/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1200/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1400/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1600/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 1800/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2000/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2200/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2400/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2600/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 2800/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 3000/3280 objects
! [DEBUG] [minimal] host.ioBroker-Sted1 Processed 3200/3280 objects
! [DEBUG] [minimal] 3280 objects restored.
! [DEBUG] [minimal] host.ioBroker-Sted1 Upload user file "vis.0/Meines/vis-views.json
! [DEBUG] [minimal] host.ioBroker-Sted1 Upload user file "vis.0/main/vis-views.json
! [DEBUG] [minimal] host.ioBroker-Sted1 Upload user file "vis.0/main1/vis-views.json
! [DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.admin/admin
! [DEBUG] [minimal] upload [3] iobroker.admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
Der IOBroker ist auch im stopBeste Grüsse paul
OK das zeigt, dass der restore funktioniert aber irgendwas mit deinen Berechtigungen nicht stimmt.
Wenn du jetzt den iobroker mit sudo systemctl start iobroker startest, sollte der Restore aber durch sein.
Bitte noch geduld haben, da alle Adapter erst installiert werden … Das passiert im Hintergrund.
VERSION 1.0.5
Ich speichere meine Backups auf ein FTP (funktioniert, Backups kommen dort an).
Problem:
Backups liegen auch noch in /opt/iobroker/backups und werden nicht gelöscht… mir lief davon schon die SD Karte voll.
Lässt sich das abstellen/ändern/mache ich einen Fehler - übersehe ich eine Option?
Danke!
daNick
Nein bei der Auswahl von FTP wird nur eine Kopie auf dem FTP Server angelegt.
Du musst die Anzahl der maximalen Backups dementsprechend einstellen und auch unter FTP das löschen alter Backups aktivieren.
Hallo simatec,
Der IOBroker ist auch im stopBeste Grüsse paul `
Hat der Restore funktioniert?
Ich möchte aber hier noch einmal betonen, dass diese Dinge nicht mit backitup zu tun haben und auch backitup deswegen kein Problem hat.
Diese Dinge betreffen einzig und allein euer System. `
…und ich möchte nochmals betonen, dass es sich dabei nur um einen momentanen Workaround handeln darf, da damit die Sicherheitsbestrebungen, nicht mehr unter root zu arbeiten, ausgehebelt werden.
Rainer `
Genau aus diesen Sicherheitsbedenken und Bestrebungen habe ich auch die Threads dazu und auch die Doku von backitup geändert.
Man sollte maximal folgendes einfügen:
visudoDeinUsername ALL=(ALL) NOPASSWD: /bin/mount, /bin/umount, /bin/systemctlDanke nochmal für den Hinweis Rainer ;)
bei mir funktioniert eigentlich alles super mit dem Adapter - klasse Sache.
Verschiebe die BackUps per CIFS auf meinen NAS (QNAP)…
Beim Sichten der Daten ist mir dann aber aufgefallen, dass ich eine leeren/fehlerhaften mysql dump habe.
Der mySQL Server ist auf einem anderen System als der ioBroker.
Für Hilfe wäre ich sehr dankbar :shock:
Hier noch das Logfile des Standardbackups:
! Gestartet…
! [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":""}
! [DEBUG] [mount] - done
! [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"mysqlEnabled":true,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"","deleteBackupAfter":5,"host":"192.168.0.66","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.1","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
! [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_01_16-21_58_34_Standard_backupiobroker.tar.gz
! [DEBUG] [minimal] - done
! [DEBUG] [mysql] start with {"type":"creator","cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":""},"dbName":"iobroker","user":"iobroker","pass":"","deleteBackupAfter":5,"host":"192.168.0.66","port":"3306","exe":""}
! [DEBUG] [mysql] - done
! [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
! [DEBUG] [cifs] - done
! [DEBUG] [clean] start with {"deleteBackupAfter":0}
! [DEBUG] [clean] - done
! [DEBUG] [pushover] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"mysqlEnabled":true,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_16-21_58_34_Standard_backupiobroker.tar.gz","/opt/iobroker/backups/mysql_2019_01_16-21_58_37_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal"],"types":["minimal"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"","deleteBackupAfter":5,"host":"192.168.0.66","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.1","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de","time":"16. Januar 2019 um 21:58 Uhr"},"backupDir":"/opt/iobroker/backups"}
! [DEBUG] [pushover] - [minimal] used pushover-Instance: pushover.1
! [DEBUG] [pushover] - done
! [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"Standard","deleteBackupAfter":0,"mysqlEnabled":true,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_16-21_58_34_Standard_backupiobroker.tar.gz","/opt/iobroker/backups/mysql_2019_01_16-21_58_37_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal","mysql"],"types":["minimal","mysql"]},"adapter":null},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"dbName":"iobroker","user":"iobroker","pass":"","deleteBackupAfter":5,"host":"192.168.0.66","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"jb1980"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"16. Januar 2019 um 21:58 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.1","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
! [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.66","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=2.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/home/BackUp/iobroker/Standard","dirMinimal":"/home/BackUp/iobroker/Standard","dirTotal":"/home/BackUp/iobroker/Komplett","user":"admin","pass":"****","backupDir":"/opt/iobroker/backups"}
! [DEBUG] [umount] - wait 60 seconds for umount!
! [DEBUG] [mysql] - MySql File deleted!
! [DEBUG] [history] - backitup.0.history.html
! [EXIT] 0
! [DEBUG] [umount] - done
! [EXIT] 0 -
In der history.html stehen alle jemals erzeugten Backups drin.
Kann man die gelöschten da herausnehmen?
Ich verwende das Backup auf den an der Fritzbox eingesteckten USB-Stick und hier gibt es ja nur noch z.B. 5.
Sorry falls es die Antwort im Forum schon gab, hab sie nicht gefunden.
Gruß klausiob
filename="mysql_01.PNG" index="1">~~
filename="mysql_02.PNG" index="0">~~
! Gestartet…
! [EXIT] 0
! [EXIT] 0 `Es gibt mehrere Möglichkeiten.
1. Probiere statt der IP mal den Hostname deine db
2. installiere auf deinem Iobroker System mysqldump und gebe den Pfad an, falls er vom Standard abweicht.
3. überprüfe den Port
4. Logindaten prüfen
Danke,
Das heißt, das ich in der neuen Installationsroutine keine Vorteile sondern eher nur Nachteile sehe.
Da ich das System sowieso neu aufsetzen muß, lasse ich es, wie es gerade ist.
Ich fahre gerade eine Minimal-Installation mit 2 Raspberries, weil ich bis jetzt eine wichtigere Baustelle hatte.
Am Wochenende werde ich dann meine Beebox wieder aktivieren und IObroker mit der alten Methode installieren.
Gruß,
Mathias
Gesendet von meinem MI 8 mit Tapatalk
Du musst die Anzahl der maximalen Backups dementsprechend einstellen und auch unter FTP das löschen alter Backups aktivieren. `
Danke für die schnelle Antwort .
1. Mein FTP-User kann auf dem FTP offenbar keine Files löschen (OMV, ich kriege das im Moment nicht hin …).
Ich lösche das gelegentlich manuell; Speicher hat das NAS genug.
Kann es sein, dass Backitup lokal nicht löscht, wenn das Löschen auf dem FTP scheitert?
2. gibt es eine einfache Lösung, das lokale Backup sofort automatisch zu löschen?
Danke!
daNick
Gesendet von iPhone mit Tapatalk `
1. Keine Änderung
2. mysqldump ist installiert -> /usr/bin/mysqldump -> ist glaube ich Standard und dennoch eingetragen
3. 3306 ist richtig
4. Logindaten geprüft -> alles richtig
Ich habe eben auf der Konsole des NAS (nicht ioB) versucht mit dem iobroker DB User ein BackUp zu machen über mysqldump (auf NAS).
Das ist fehlgeschlagen - mit root funktionierte es.
Trage ich allerdings root in die Adaptereinstellungen (ioB) ein klappt es genauso wenig :?
Danke!
daNick `
Um das zu sehen, aktivere bitte den debug Modus für die Instanz von backitup und poste dann den Log eines automatischen Backups.
Bei manuellen Backups werden keine Files gelöscht
Du kannst die Anzahl in den Einstellungen auf Wert x begrenzen
Die Backups sind auf 5 begrenzt und es liegen auch nur die 5 aktuellsten auf dem FTP-Server. Ich meine die Aufzählung der Backups in der backitup.0.history.html.
Gruß klausiob
Ab sofort ist die Version 1.0.7 im Github und ab heute Nacht im latest verfügbar.
1.0.7 (17.01.2019)
(simatec) better start/stop Handling for backup and restore
Mit dieser Version sollten die Start/Stop Probleme bei neuen Installationen behoben sein.
Ich habe heute einen ausgiebigen Test der Start/Stop Vorgänge inkl. Auswertungen gemacht.
Viel Spaß mit der neuen Version … ;)
Auch die History kannst du begrenzen.
Dafür gibt es in den Haupteinstellungen einen Menüpunkt.
Danke habe es gefunden. Tomaten auf den Augen bzw. kleine Schrift und hellgrau auf weiss, so AGB-like, nichts für alte Augen.
Danke vielmals
Gruß klausiob
