  4. [Aufruf] BLE Adapter testen (v0.6.0)
370 Beiträge 59 Kommentatoren 121.0k Aufrufe 11 Beobachtet
    Siegfried
    Forum Testing
    #244
    da steht:
    $ ./iobroker url "https://github.com/AlCalzone/ioBroker.ble"
    install https://github.com/AlCalzone/ioBroker.ble/tarball/master
    npm install https://github.com/AlCalzone/ioBroker.ble/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    npm
    ERR!
    path
    /root/.npm/_logs
    npm
    ERR!
    code
    EACCES
    npm
    ERR! errno -13npm
    ERR! syscall scandirnpm
    ERR!
    Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm
    ERR! { Error: EACCES: permission denied, scandir '/root/.npm/_logs'npm
    ERR! stack: 'Error: EACCES: permission denied, scandir '/root/.npm/_logs'',npm ERR! errno: -13,
    ! npm ERR! code: 'EACCES',npm
    ERR! syscall: 'scandir',npm ERR!
    path: '/root/.npm/_logs' }npm ERR!
    npm ERR! The operation was rejected by your operating system.
    ! npm ERR! It is likely you do not have the permissions to access this file as the current usernpm
    ERR! npm ERR! If you believe this might be a permissions issue, please double-check the
    ! npm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
    ! glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs' stack: 'Error: EACCES: permission denied, scandir '/root/.npm/_logs'',
    errno: -13,
    code: 'EACCES',
    syscall: 'scandir',
    ! npm
    ERR!
    path
    /root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f
    npm
    ERR!
    code
    EACCESnpm
    ERR! errno
    -13npm ERR! syscall
    opennpm
    ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'npm ERR! { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'
    ! npm ERR! cause: npm
    ERR! { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'npm ERR! errno: -13,
    npm ERR! syscall: 'open',
    npm ERR! path: '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f' },
    npm ERR! isOperational: true,
    npm ERR! stack: 'Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'',
    npm ERR!
    ! npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR!
    npm ERR!
    ! npm
    WARN
    react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
    npm
    WARN
    react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
    npm
    WARN
    react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
    npm
    WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
    npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm
    WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):npm
    WARN optional
    SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: npm install node-pre-gyp
    npm
    WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 243
    ! process exited with code 0
    ****EDIT: Code in Code und Spoiler-Tags ; Homoran(Admin)****
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #245
      Dachte ich es mir doch. Du hast mal mit sudo installiert.
      => Lesen und befolgen: viewtopic.php?f=8&t=19209
      => Nochmal den Adapter über die Admin-UI installieren.
        Siegfried
        Forum Testing
        #246
        hm bekomme es irgendwie nicht hin.
        entweder ich bekomme den fehler oder es läuft wieder die alte version.
        Habe auch den Befehl.````
        sudo chown -R $(whoami) ~/.npm
        Reicht das? Oder sollte ich das in Klammern mit was ersetzten.
          Siegfried
          Forum Testing
          #247
          jetzt läuft es …hab nun mit einem anderen Adapter probleme :-(
            AlCalzoneA Offline
            AlCalzone
            #248
            Dann machst du am besten einen neuen Thread dazu auf ;)
              Shaky79
              #249
              bei mir findet er zwar das @abandonware/bluetooth-hci socket, aber er sagt mir schon wieder falsche node Version. (Siehe Anhang)
              Ich dachte es gäbe jetzt Node10 Support? Sorry bin immer noch Anfänger mit Linux. Was mache ich hier falsch?
              Ich hab nochmal neu installiert.
              Bei der Installation kommt tatsächlich auch eine Fehlermeldung bei Bluetooth. Werde da aber nicht draus schlau. Bzw. weiß nicht was ich tun soll.
              $ ./iobroker add ble  --host phoscon
              NPM version: 6.5.0
              npm install iobroker.ble --production --save --prefix "/opt/iobroker" (System call)
              ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::string>, int, v8::Local<v8::value>*)’ is deprecated [-Wdeprecated-declarations]
                   Nan::MakeCallback(Nan::New<object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
              In file included from ../src/BluetoothHciSocket.cpp:8:0:
              ../../../../nan/nan.h:979:46: note: declared here
                 NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback(
              ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
              ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local <v8::value>[1])’
                 Local <value>error = errorConstructor->NewInstance(1, constructorArgs);
              In file included from /root/.node-gyp/10.14.2/include/node/node.h:63:0,
                               from /root/.node-gyp/10.14.2/include/node/node_buffer.h:25,
                               from ../src/BluetoothHciSocket.cpp:7:
              /root/.node-gyp/10.14.2/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal <v8::object>v8::Function::NewInstance(v8::Local<v8::context>, int, v8::Local<v8::value>*) const
                 V8_WARN_UNUSED_RESULT MaybeLocal <object>NewInstance(
              /root/.node-gyp/10.14.2/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
              /root/.node-gyp/10.14.2/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal <v8::object>v8::Function::NewInstance(v8::Local<v8::context>) const
              /root/.node-gyp/10.14.2/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
              ../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::string>, int, v8::Local<v8::value>*)’ is deprecated [-Wdeprecated-declarations]
              ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/BluetoothHciSocket.cpp:395:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     devId = arg0->IntegerValue();
              In file included from /root/.node-gyp/10.14.2/include/node/v8.h:26:0,
                               from /root/.node-gyp/10.14.2/include/node/node.h:63,
              /root/.node-gyp/10.14.2/include/node/v8.h:2476:46: note: declared here
                 V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
              /root/.node-gyp/10.14.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                 declarator __attribute__((deprecated(message)))
              ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
              ../src/BluetoothHciSocket.cpp:417:34: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
              make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
              gyp
               ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
              gyp ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/noble/node_modules/bluetooth-hci-socket
              gyp ERR! node -v v10.14.2
              gyp ERR! node-gyp -v v3.8.0
              gyp ERR! not ok
              npm
               WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/bluetooth-hci-socket/package.json'
              npm
              WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
              npm
               WARN
               optional
               SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/noble/node_modules/bluetooth-hci-socket):
              npm WARN
               optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              host.phoscon install adapter ble
              got /opt/iobroker/node_modules/iobroker.ble/admin
              upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/words.js words.js application/javascript
              upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index.html index.html text/html
              upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
              host.phoscon object system.adapter.ble created
              host.phoscon create instance ble
              host.phoscon object ble.0.options.allowNewDevices created
              host.phoscon object ble.0.options created
              host.phoscon object ble.0.info.driverState created
              host.phoscon object ble.0.info.connection created
              host.phoscon object ble.0.info created
              host.phoscon object system.adapter.ble.0.outputCount created
              host.phoscon object system.adapter.ble.0.inputCount created
              host.phoscon object system.adapter.ble.0.uptime created
              host.phoscon object system.adapter.ble.0.memRss created
              host.phoscon object system.adapter.ble.0.memHeapTotal created
              host.phoscon object system.adapter.ble.0.memHeapUsed created
              host.phoscon object system.adapter.ble.0.connected created
              host.phoscon object system.adapter.ble.0.alive created
              host.phoscon object system.adapter.ble.0 created
              Fehlermeldung mit falscher Node Version bleibt aber die gleich.
              Lampe im Broker dann auf gelb
              Gruss
                [10504_bleadapter.jpg](/assets/uploads/files/10504_bleadapter.jpg)</v8::value></object></v8::value></v8::string></v8::object></v8::value></object></v8::context></v8::object></object></v8::value></v8::context></v8::object></value></v8::value></v8::value></object></v8::value></v8::string></v8::object></v8::value>
                AlCalzoneA Offline
                AlCalzone
                #250
                Nach einem NodeJS-Update kommst du um eine Neukompilierung der nativen Module nicht herum.
                Das kannst du erledigen mit
                cd /opt/iobroker
                npm rebuild
                Das wird eine Weile dauern.
                Außerdem ist scheinbar noch eine alte Version des Adapters installiert. Bitte mal komplett löschen und neu installieren:
                iobroker del ble
                iobroker add ble
                  Shaky79
                  #251
                  Danke schonmal . Rebuild wirft mir direkt ein paar EAccess Fehlermeldungen raus. Mach ich das auch mit diesem unsafe perm oder kann ich da sudo verwenden
                    AlCalzoneA Offline
                    AlCalzone
                    #252
                    @Shaky79:
                    Mach ich das auch mit diesem unsafe perm oder kann ich da sudo verwenden `
                    Nein und nein!
                    ==> Bitte viewtopic.php?f=8&t=19209 lesen
                    Wenn in den Meldungen auch
                    auftaucht, dann hilft Punkt 4 aus dem Link.
                    Sonst nochmal die Meldungen posten.
                      Shaky79
                      #253
                      ** Update: Hat sich glaub ich erledigt. Fehlercode gibt es zwar immer noch, aber der Rebuild läuft atm durch*
                      pi@phoscon:~ $ cd /opt/iobroker
                      pi@phoscon:/opt/iobroker $ npm rebuild
                      > iobroker@1.3.1 install /opt/iobroker/node_modules/iobroker
                      > node lib/checkVersions.js
                      NPM version: 6.5.0
                      > iobroker@1.3.1 postinstall /opt/iobroker/node_modules/iobroker
                      > node lib/install.js
                      fs.js:115
                          throw err;
                      Error: EACCES: permission denied, unlink '/opt/iobroker/LICENSE'
                          at Object.unlinkSync (fs.js:952:3)
                          at mayCopyFile (/opt/iobroker/node_modules/fs-extra/lib/copy-sync/copy-sync.js:57:8)
                          at onFile (/opt/iobroker/node_modules/fs-extra/lib/copy-sync/copy-sync.js:52:10)
                          at getStats (/opt/iobroker/node_modules/fs-extra/lib/copy-sync/copy-sync.js:46:44)
                          at startCopy (/opt/iobroker/node_modules/fs-extra/lib/copy-sync/copy-sync.js:36:10)
                          at Object.copySync (/opt/iobroker/node_modules/fs-extra/lib/copy-sync/copy-sync.js:31:10)
                          at Object.copyFilesRecursiveSync (/opt/iobroker/node_modules/iobroker/lib/tools.js:591:12)
                          at copyFilesToRootDir (/opt/iobroker/node_modules/iobroker/lib/installCopyFiles.js:29:11)
                          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker/lib/installCopyFiles.js:14:1)
                          at Module._compile (internal/modules/cjs/loader.js:689:30)
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! iobroker@1.3.1 postinstall: `node lib/install.js`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the iobroker@1.3.1 postinstall script.
                      npm ERR!     /home/pi/.npm/_logs/2018-12-29T09_02_20_981Z-debug.log
                      pi@phoscon:/opt/iobroker $</anonymous>
                      Das sind die Fehlermeldungen . Kein scandir dabei
                      Danke schonmal für deine Hilfe
                        AlCalzoneA Offline
                        AlCalzone
                        #254
                        Öhhhh das versucht das iobrokerpaket neu zu installieren und bricht dann ab… Geht folgendes?
                        cd /opt/iobroker
                        ./reinstall.sh
                        Gesendet von unterwegs
                          Shaky79
                          #255
                          Also irgendwie wird es immer kurioser:
                          npm rebuild ist jetzt durchgelaufen
                          bis es zu folgendem Fehler kommt:
                          bufferutil.target.mk:101: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
                          make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
                          make: Leaving directory '/opt/iobroker/node_modules/bufferutil/build'
                          gyp ERR! build error
                          gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR! bufferutil@1.1.0 install: `node-gyp rebuild`
                          npm ERR!
                          npm ERR! Failed at the bufferutil@1.1.0 install script.
                          npm ERR!     /home/pi/.npm/_logs/2018-12-29T11_02_07_683Z-debug.log
                          Hab danach trotzdem mal iobroker gestartet und siehe da: im Log gibt es keine Fehlermeldungen vom BLE Adapter mehr. Trotzdem bleibt er aber auf "gelb"
                          Muss noch was testen, dann melde ich mich nochmal
                            AlCalzoneA Offline
                            AlCalzone
                            #256
                            Was sagt der state Info.driverState?
                              Shaky79
                              #257
                              so langsam werde ich weich:
                              unhandled promise rejection: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node' was compiled against a different Node.js version using NODE_MODUL
                              Die Fehlermeldung kommt jetzt doch wieder beim Broker.
                              Das heißt wahrscheinlich, dass mein rebuild nicht bis zu dem node_module gekommen ist.
                              Irgendeine Idee wie ich das Problem mit der Fehlermeldung beim "bufferutil" wegbekomme?
                              Oder kann ich irgendwie nur das eine module rebuilden?
                              Gruss
                                AlCalzoneA Offline
                                AlCalzone
                                #258
                                cd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                                npm rebuild
                                  Shaky79
                                  #259
                                  Sorry für die Anfängerfragen [emoji3]
                                  Jetzt kann ich dir auch deine Frage zum state beantworten.
                                  Also Adapter ist gelb und bluetooth driver stater ist unauthorized
                                    Shaky79
                                    #260
                                    Ok, wahrscheinlich einfach von mir dumm, aber ich hab in den Adaptereinstellungen die Updatezeit auf 1000ms gestellt und jetzt ist er grün?
                                    So jetzt meine nächste dumme Frage:
                                    Kann ich da jetzt theoretisch mein Iphone, bzw. meine "Tile Pro" Bluetooth Tracker einbinden?
                                    Bzw. er legt keine Geräte an, die er findet.
                                    Müsste ja ne Menge in meinem Haus da sein.
                                    Update: Das war ein kurzes Vergnügen. Nach einem Neustart hat erstmal wieder alles nicht funktioniert.
                                    Mir ist jetzt aufgefallen, dass ich offensichtlich den IObroker immer unter sudo im Autostart habe und da ist der ganze Kram mit "Falsche Node Version" noch drin.
                                    Habe den Iobroker dann gestoppt und einfach einen ohne "Sudo" gestartet.
                                    Da bekomme ich wieder keine Fehlermeldung bezüglich "Node" Version, aber jetzt ist der Adapter wieder "gelb" .
                                    Ich werd wahnsinnig ;-)
                                      Shaky79
                                      #261
                                      Ok neue Erkenntnis,
                                      der BLE-Adapter springt auf grün sobald ich per Konsole````
                                      sudo hcitool lesecan
                                      anmache.
                                      In der Konsole stehen dann auch einige Mac-Adressen, aber im iobroker unter Objekte wird trotzdem nichts hinzugefügt.
                                      Sobald ich den hcitool lesecan beende und ich den Adapter neu starte geht die Lampe auch wieder nur auf gelb.
                                      Könnt ihr euch das erklären?
                                      Gruss
                                      • Deanna4711D Offline
                                        Deanna4711D Offline
                                        Deanna4711
                                        #262
                                        @Shaky79:
                                        anmache.
                                        Sobald ich den hcitool lesecan beende und ich den Adapter neu starte geht die Lampe auch wieder nur auf gelb. `
                                        Ich habe genau das selbe Verhalten. Ich suche schon seit 2 Wochen nach einer Lösung. Welches OS hast Du laufen?
                                        Bei mir läuft Armbian auf einem RockPi4. Ich nehme an, dass die BT Treiber das Problem sind.
                                          Shaky79
                                          #263
                                          Ich hab Raspbian drauf.
                                          Hab das zusammen mit dem Raspbee Stick +Deconz Software von Dresden-Elektronik runtergeladen.
                                          Fügt er bei dir auch keine Geräte hinzu?
