  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • simatecS Offline
    simatecS Offline
    simatec
    #1246
    @greyhound:
    Update bleibt hängen
    Doch, der ioBroker läuft zusammen mit Redis und Redis-Backup ist aktiviert.
    Anbei eine Liste der aktiven Adapter:
    Adapter    "admin"         : 3.5.10   , installed 3.5.10
    Adapter    "backitup"      : 0.4.2    , installed 0.4.2
    Adapter    "dwd"           : 2.4.3    , installed 2.4.3
    Adapter    "email"         : 1.0.4    , installed 1.0.4
    Adapter    "flot"          : 1.9.2    , installed 1.9.2
    Adapter    "fullcalendar"  : 0.2.4    , installed 0.2.4
    Adapter    "history"       : 1.8.5    , installed 1.8.5
    Adapter    "hm-rega"       : 2.0.0    , installed 2.0.0
    Adapter    "hm-rpc"        : 1.8.0    , installed 1.8.0
    Adapter    "hs100"         : 1.0.8    , installed 1.0.8
    Adapter    "influxdb"      : 1.6.2    , installed 1.6.2
    Adapter    "info"          : 1.0.2    , installed 1.0.2
    Adapter    "javascript"    : 4.0.5    , installed 4.0.5
    Controller "js-controller" : 1.4.2    , installed 1.5.3
    Adapter    "js2fs"         : 0.1.5    , installed 0.1.5
    Adapter    "mqtt"          : 2.0.4    , installed 2.0.4
    Adapter    "openweathermap": 0.1.0    , installed 0.1.0
    Adapter    "ping"          : 1.3.2    , installed 1.3.2
    Adapter    "simple-api"    : 2.0.0    , installed 2.0.0
    Adapter    "systeminfo"    : 0.2.2    , installed 0.2.2
    Adapter    "tankerkoenig"  : 1.0.4    , installed 1.0.4
    Adapter    "telegram"      : 1.3.6    , installed 1.3.6
    Adapter    "tr-064"        : 0.4.18   , installed 0.4.18
    Adapter    "tvspielfilm"   : 1.0.4    , installed 1.0.4
    Adapter    "vis"           : 1.1.8    , installed 1.1.7
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-colorpicker": 1.1.1   , installed 1.1.1
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
    Adapter    "vis-history"   : 0.2.7    , installed 0.2.7
    Adapter    "vis-hqwidgets" : 1.1.2    , installed 1.1.2
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.0    , installed 1.0.0
    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"       : 1.0.2    , installed 1.0.2
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"   : 0.1.5    , installed 0.1.5
    Adapter    "vis-plumb"     : 1.0.1    , installed 1.0.1
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "vis-weather"   : 2.2.0    , installed 2.2.0
    Adapter    "weatherunderground": 2.0.4   , installed 2.0.4
    Adapter    "web"           : 2.4.1    , installed 2.4.1
    Adapter    "yr"            : 2.0.3    , installed 2.0.3
    zu SMB-Einstellung
    Die "Anforderung" die SMB-Version einstellen zu können (und ob sudo oder nicht) ist von mir. SMBv1 ist ein Auslaufmodell, es sollte mind. SMBv2 genutzt werden. Im eigenen einbruchsicheren LAN kann natürlich gemacht werden, was man möchte. `
    Dann wird irgendeine Datei von iob blockiert und das backup bleibt hängen.
    Wie gesagt, genau für solche Anwendungsfälle gibt es die Funktion iob stop.
    Was spricht bei dir dagegen? Sichere doch einfach nachts, wenn iob eh kaum gebraucht wird.
    Andernfalls bleibt dir nur die Möglichkeit jeden Adapter einzeln zu deaktivieren, um rauszubekommen, was da das Backup blockiert.
    Ich habe hier 4 Testsysteme, mal mit und mal ohne Redis.
    Ich muss nix stoppen. Aber wie gesagt, Nadel im Heuhaufen suchen
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • H Offline
      Hightower1976
      #1247
      @simatec:
      Nein der mount hat nix mit redis zu tun.
      Poste bitte nochmal dein Log mit und ohne Redis.
      Gesendet von iPhone mit Tapatalk `
      Hi SImatec,
      Verrückt. irgend was hat sich geändert.
      Jetzt geht es in beiden Fällen. Egal ob mit oder ohne Redis status Sicherung.
      Ich hab keine Ahnung was sich geändert hat.
      Egal was es ist.
      Vielen Lieben Dank
      Hab den Fehler wieder. Ich hab nun gesehen warum es durch ging. Die Anbindung an die NAS war abgeschaltet.
      Wenn diese an ist. Geht es weder mit noch ohne REDIS.
      Fehler ist also noch vorhanden (Leider) ;-(
      • simatecS Offline
        simatecS Offline
        simatec
        #1248
        Unterstützt dein NAS auch nfs? Dann würde ich das mal probieren.
        Falls nicht, probiere mal den mount über Konsole, damit man mal sieht, wo dein System Probleme hat.
        sudo mount -t cifs -o user=hm-iob,password=password,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.7.200/TMBackup/IOB /opt/iobroker/backups
        Falls dein Passwort Sonderzeichen haben sollte, verwende entweder eins ohne Sonderzeichen oder schreibe es in der Config von backitup mal in Anführungszeichen.
        • greyhoundG Offline
          greyhoundG Offline
          greyhound
          #1249
          @simatec:
          Ich muss nix stoppen. Aber wie gesagt, Nadel im Heuhaufen suchen `
          Na ja, bei mir dauert das Speichern via NAS der 1,7 GB ungefähr 18 min., in der Zeit kann viel passieren - gut das ich da keine Alarmanlage drüber laufen habe. Über die 1,7 GB wundere ich mich ein wenig, muss ich mir auch noch anschauen, werde das System wohl mit node 8 sowieso neu aufsetzen.
          ioBroker auf ODROID-XU4 / Influx u. a. auf FUJITSU D3400-B, Celeron G3900, 16 GB RAM / CCU2 / Nuki
          • simatecS Offline
            simatecS Offline
            simatec
            #1250
            Also 1,7 GB scheint mir recht viel …
            Hab auf meinem Produktiv ca. 25 Adapter laufen und etliche Scripts ... aber das ist alles nicht wirklich so groß
            Hab ca. 300 MB.
            • PeoplesP Offline
              PeoplesP Offline
              Peoples
              #1251
              Also ich habe eben mal verglichen, ich hatte früher so ca 450 MB und seit dem ich alles neu gemacht habe 176MB.
              Schuld war bei mir der SonosCache, das waren die 274 MB mehr.
                greyhoundG Offline
                greyhound
                #1252
                Das Problem ist "schöner" als gedacht:
                Habe bis auf Admin und backitup alle Instanzen beendet.
                Redis läuft
                Dann das Komplett-Backup über "Jetzt Sichern" gestartet" - bleibt wieder bei ca. 5 MB stehen.
                Dann den Host via Tab Hosts neu gestartet, Backup neu gestartet –> Backup läuft
                Habe nun etliche Tests durchgeführt, der "Neustart-Trick" funktioniert leider auch nicht immer.
                Wenn ich das Backup auf Console ausführe: tar cvzf iobroker-oxu4-2018-12-14.tgz /opt/iobroker/ dann läuft es durch.
                Kann ich in backitup eine Option setzen, ggf. "einbauen", damit das Backup im verbose-Mode läuft und ich sehe, wo es hängen bleibt?
                • simatecS Offline
                  simatecS Offline
                  simatec
                  #1253
                  Hast du mal einen kompletten Restart deines Systems probiert?
                  Vielleicht hängt da irgendwo etwas anderes.
                  Lief das Backup bei dir bereits schonmal durch oder hast du das Problem seit der Installation?
                  Was hast du für eine node, nodejs, npm und js-controller Version?
                    greyhoundG Offline
                    greyhound
                    #1254
                    @simatec:
                    Was hast du für eine node, nodejs, npm und js-controller Version? `
                    Ja, restart habe ich mehrfach gemacht, das Backup läuft, wenn die Checkbox "ioBroker stoppen" aktiv ist.
                    Selber habe ich sonst auf der Shell mit tar gesichert, beim Umstieg auf den Adapter habe ich dann wegen der Datenkonsistenz ioBroker beenden lassen.
                    Wegen der langen Downtime des ioBroker bei mir (18 min.) kam dann von euch die Empfehlung, den ioBroker einfach laufen zu lassen und das klappt bei mir nicht.
                    node: 6.13.1
                    nodejs ???
                    npm: 3.10.10
                    js-controller: 1.5.3
                    Eine Besonderheit bei mir ist, dass ioBroker nicht mit root-Rechten läuft, aber ich habe wie gesagt auch kein Problem als ioBroker-User via Shell ein tar-Archiv zu machen.
                    Hast du einen Link zu dem node-Modul, welches ihr da verwendet, wir mir da ggf. selber die verbose-Option einbauen.
                    • simatecS Offline
                      simatecS Offline
                      simatec
                      #1255
                      Also da sehe ich schon das erste Problem mit dem js-Controller.
                      1.5.3 würde ich aktuell noch nicht unbedingt laufen lassen und erst recht nicht mit npm 3 in Kombi.
                      Mach mal ein Upgrade von node und npm und ggfs. ein downgrade des js-Controllers …
                      • H Offline
                        Hightower1976
                        #1256
                        @simatec:
                        Hi Simatec,
                        -bash: ****Password****,rw,file_mode=0777,dir_mode=0777,vers=1.0: Kommando nicht gefunden.
                        anscheinend ist mit dem Adapter irgend was nicht mit installiert worden ;(
                        • simatecS Offline
                          simatecS Offline
                          simatec
                          #1257
                          Befehle über Konsole haben nix mit dem Adapter zu tun.
                          Was hast du in der Konsole genau eingegeben
                          • H Offline
                            Hightower1976
                            #1258
                            @simatec:
                            ich hab es. ein Passwort mit 21 Zeichen ist dem Adapter wohl zu lang. Jetzt habe ich eins mit 12 Zeichen und alles ist gut.
                            • TomTT Offline
                              TomTT Offline
                              TomT
                              #1259
                              Gibt es eigentlich Pläne für den Adapter bei der Pushover Benachrichtigung nur 1 GeräteID eintragen zu können?
                              Momentan bekomme ich die Backup Nachricht auf alle Pushover GeräteIDs
                              Tom
                              PI3B > Raspimatic / Opi+2 > ioBroker / ESP8266
                              if (System == "running") {finger = "weg";} else {lastAction = "Rückgängig";}
                              • simatecS Offline
                                simatecS Offline
                                simatec
                                #1260
                                Können wir einbauen.
                                Da ich aber selber Pushover nicht nutze, wäre gut zu wissen, wie die Id ausschaut.
                                • TomTT Offline
                                  TomTT Offline
                                  TomT
                                  #1261
                                  Ja :D
                                  Das müsste das hier sein :
                                  https://pushover.net/api
                                  Some optional parameters may be included:
                                  device - your user's device name to send the message directly to that device, rather than all of the user's devices (multiple devices may be separated by a comma)
                                  Kommt bei dem Pushover Adapter unter Gerät ID als Text (Name den man selbst dem Gerät bei Pushover eingetragen hat)
                                  Tom
                                  • simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #1262
                                    OK ich schaue mir mal den Pushover Adapter an.
                                    Eventuell kann ich die User wie bei Telegram von backitup auslesen lassen und ein Auswahlmenü darstellen.
                                    • P Offline
                                      passuff
                                      #1263
                                      backitup hat bei mir früher immer wunderbar funktioniert. Leider kann ich neuerdings keine Backups wiederherstellen, bzw die abgelegten Backups werden nicht mehr gefunden. Ich nutze lediglich FTP Zugang, die Backups werden einwandfrei erstellt und abgelegt. Wenn ich jetzt auf Wiederherstellen klicke und FTP auswähle, werden dennoch nur lokale Backups angezeigt.
                                      • simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #1264
                                        Nach der Auswahl von FTP im Wiederherstellungsmenü bitte vorher speichern.
                                        Sonst wird die Auswahl FTP nicht übernommen und nur die lokalen Backups werden angezeigt.
                                        • simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #1265
                                          Ab sofort ist auf Github und ab heute Nacht im latest die Version 0.4.3 verfügbar.
                                          0.4.3 (17.12.2018)
                                          (simatec) Add device ID for pushover
