  4. [Aufruf] Adapter: Snips - Offline Speak2Text
snips
635 Beiträge 43 Kommentatoren 208.7k Aufrufe 22 Beobachtet
  • WalW Offline
    WalW Offline
    Wal
    sudo nano /etc/mosquitto/mosquitto.conf
    # Place your local configuration in /etc/mosquitto/conf.d/
    # A full description of the configuration file is at
    # /usr/share/doc/mosquitto/examples/mosquitto.conf.example
    pid_file /var/run/mosquitto.pid
    persistence false
    persistence_location /var/lib/mosquitto/
    log_dest file /var/log/mosquitto/mosquitto.log
    include_dir /etc/mosquitto/conf.d
    listener 1500
    "listener" ist dein gewünschter Port.
    sudo nano /etc/snips.toml
    [snips-common]
     bus = "mqtt"
     mqtt = "localhost:1500"
    Walter
    DoorIO-Adapter
    • smartboartS Offline
      smartboartS Offline
      smartboart
      Hallo Walter,
      vielen lieben Dank…habe es angeasst und den raspy neu gestartet..
      sam watch zeigt mir jetzt den gewünschten port an..
      Bekomme immer noch folgende Meldungen vom iobroker.snips adapter..
      Dazu noch jemand ne Idee?
      host.tinkerboard	2018-11-02 21:47:21.382	info	Restart adapter system.adapter.snips.0 because enabled
      host.tinkerboard	2018-11-02 21:47:21.382	error	instance system.adapter.snips.0 terminated with code 0 (OK)
      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Function.Module._load (module.js:498:3) code: 'MODULE_NOT_FOUND' }
      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at tryModuleLoad (module.js:506:12)
      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Module.load (module.js:566:32)
      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Module._compile (module.js:653:30)
      Caught	2018-11-02 21:47:21.382	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.snips/lib/client.js:3:25)
      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at require (internal/module.js:11:18)
      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at Module.require (module.js:597:17)
      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at Function.Module._load (module.js:475:25)
      Caught	2018-11-02 21:47:21.381	error	by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
      Caught	2018-11-02 21:47:21.381	error	by controller[0]: { Error: Cannot find module 'mqtt'</anonymous>
      • ? Offline
        Servus Smartboart,
        im Snips Adapter ist der neue Port gesetzt?
        Herzliche Grüße
        Equilora aka Harald
          smartboartS Offline
          smartboart
          Hi ..ja ist er…deshalb wundert mich die log Ausgabe ja...
          • WalW Offline
            WalW Offline
            Wal
            Sieht aus als ob er die mqtt.js nicht findet.
            Mach mal im ioBroker Verzeichniss ein "npm install mqtt"
            Walter
            DoorIO-Adapter
              Morgon
              @Wal:
              Eine Anleitung wäre nett, danke im vorraus. :mrgreen: `
              Ich hab mich einfach an die Anleitung hier gehalten:
              https://snips.gitbook.io/documentation/ … l-wakeword
              Hat prinzipiell gut geklappt und ich freu mich diebisch drüber, dass er auf "Igor" reagiert. Jetzt brauch ich nur noch ne Männliche TTS damit ich mir auf alles mit "Ja, Meister." antworten lassen kann.
              Allerdings war meine Freundin etwas pikiert, da durch das Anlernen scheinbar nur erkannt wird wenn ich das wakeword sage. Theoretisch sollte es aber auch möglich sein mehrere Wakewords oder von verschiedenen Personen gesprochen zu integrieren, allerdings bin ich derzeit eh noch am spielen und das ist in der Priorität erstmal auf später geschoben. Ich habe auch die Funktion von text2command noch nicht wirklich verstanden weswegen ich grad für alles Skripte erstelle...
                smartboartS Offline
                smartboart
                Hallo Walter,
                vielen Dank für den entscheidenten Hinweis…
                Ich hatte deinen adapter im Multihost System auf den Slave verschoben und nicht daran gedacht, dass dort mqtt ebenfalls installiert sein muss. Dort war mqtt nicht installiert....jetzt ist der adapter grün und einsatzbereit....Danke für deinen suport...
                • WalW Offline
                  WalW Offline
                  Wal
                  @smartboart:
                  Hallo Walter,
                  Ich hatte deinen adapter im Multihost System auf den Slave verschoben und nicht daran gedacht, dass dort mqtt ebenfalls installiert sein muss. Dort war mqtt nicht installiert....jetzt ist der adapter grün und einsatzbereit....Danke für deinen suport... `
                  Du nutzt die neue Snips-Version "0.60.1", da funktioniert das Anlernen der Wörter noch nicht. In der "main.js" vom Snips-Adapter muß das umgeändert werden werden.
                  adapter.on('stateChange', (id, state) => {
                      adapter.log.debug('stateChange ' + id + ': ' + JSON.stringify(state));
                      switch (id) {
                      case (adapter.namespace + '.send.say.text') :
                          adapter.log.info('from Text2Command : ' + state.val);
                  	if (state.val.indexOf(adapter.config.filter) == -1) {
                  	    if (client) client.onStateChange('hermes/tts/say',state.val,'say');
                  	break;
                      case (adapter.namespace + '.send.inject.room') :
                  	if (client) client.onStateChange('hermes/injection/perform',state.val,'inject_room');
                  	break;
                      case (adapter.namespace + '.send.inject.device') :
                  	if (client) client.onStateChange('hermes/injection/perform',state.val,'inject_device');
                  	break;
                  Auf der Snips-Hardware "snips-asr-injection" deinstallieren und "snips-injection" installieren.
                  Walter
                  DoorIO-Adapter
                    smartboartS Offline
                    smartboart
                    Danke fuer den Hinweis. Hatte ich bereits gemerkt und weiter oben gelesen… Danke fuer den workaround... Werde ich morgen gleich umstellen... Im Moment bastle ich eh noch an meinem Gehäuse.. Raspi mit Standart Gehäuse mittels steckkontakte zum einrasten (Dockinstation für den Pi) in einen meiner Satelliten Lautsprecher welche ich vom surround system noch übrig hatte... dank deinem Adapter wieder ein tolles Projek zum basteln...
                    Gesendet von meinem CLT-L09 mit Tapatalk
                    ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201811 ... 7377d1.jpg">https://uploads.tapatalk-cdn.com/20181103/e6d6c7a90daf878a4a791475777377d1.jpg</link_text>" />
                      smartboartS Offline
                      smartboart
                      hey, habe die Änderungen vorgenommen..
                      kann ich davon ausgehen, dass das Anlernen nun funktioniert? im ordner var/lib/snis/injections ist nichts zu finden.
                      Siehe Foto.. Ist das normal, dass snips-analytics nun nicht mehr läuft nachdem ich über mqtt kommuniziere?
                      • WalW Offline
                        WalW Offline
                        Wal
                        Müsste gehn.
                        snips-analytics und snips-skill-server habe gar nicht installiert.
                        Walter
                        DoorIO-Adapter
                          smartboartS Offline
                          smartboart
                          OK wundere mich nur warum die injects nicht angelegt wird.
                          Der workaround scheint nicht zu funktionieren… Wenn du noch ne Idee hast oder dein Patch fertig ist probiere ich gerne weiter...
                            smartboartS Offline
                            smartboart
                            @Wal:
                            Achtung !!!
                            Es gibt ein neues Snips-Update Ver. 0.60.1, dort wurde an der Snips-Injection herumgefrickelt, dadurch funktioniert das Anlernen der Wörter nicht mehr. Es gibt demnächst ein Patch dafür. `
                            Hi Wal, weist du schon wann du hierfür ein patch fertig hast?
                            • WalW Offline
                              WalW Offline
                              Wal
                              Der ist schon online auf Github
                              Walter
                              DoorIO-Adapter
                                smartboartS Offline
                                smartboart
                                ok, danke für den Hinweis…habe ich eben installiert. Verhält sich aber genauso wie vorher...hast du eine Idee, warum die Datei für die injections nicht angelegt wird? 6558_unbenannt.png
                                • WalW Offline
                                  WalW Offline
                                  Wal
                                  Nein, tut mir leid.
                                  Die Injections liegen unter /var/lib/snips/injections/… , schau mal ob der Ordner bei dir vorhanden ist.
                                  Gib auch mal "snips-watch -vvv" ein, ob du auch die zwei zusätzlichen Meldungen wie ich (siehe oben) bei einem Injection bekommst.
                                  edit: Ich sehe gerade, das der Ordner bei dir nicht vorhanden ist, ich mußte Snips deswegen neu installieren.
                                  Walter
                                  DoorIO-Adapter
                                    smartboartS Offline
                                    smartboart
                                    ok, ich hab das Problem gefunden!!! Waren die Schreibrechte des injections ordner.
                                    mit
                                    chmod -R 777 /var/lib/snips über die console
                                    war das Problem gelöst…
                                    Danke für deine Geduld!!
                                      smartboartS Offline
                                      smartboart
                                      Hab noch ein Hinweis, falls jemand auch die snips skills über sam installiert. Der Skill Server muss deaktiviert werden. Hat bei mir erst dann funktioniert. Es war auch hilfreich die Installation und sonstige Anpassung mit root user durchzuführen. Dann läuft man mit dem Vergeben von Schreibrechten für diverse Ordner auch nicht Gefahr das System abzuschiessen.
                                      Jetzt läufts klasse! Danke nochmal an den Entwickler…
                                      • W Offline
                                        W Offline
                                        walf
                                        Weiß hier zufällig jemand, warum auf snips.ai die FHEM App nicht mehr vorhanden ist?
                                        Michael
                                          smartboartS Offline
                                          smartboart
                                          hast du nach fhem ohne aktion gesucht…Vor ner Woche war noch alles da.
