  4. [Vorlage] Spotify Skript
    apollon77A
javascript
745 Beiträge 95 Kommentatoren 386.3k Aufrufe 41 Beobachtet
  • crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    #434
    kannn mir hier jemand bei der folgenden Fehlermeldung weiterhelfen?
    ! 21:08:16.942 [error] Caught by controller[0]: at CreatePlaybackInfo (script.js.common.Spotify:258:13)
    ! 21:08:16.942 [error] Caught by controller[0]: at script.js.common.Spotify:781:31
    ! 21:08:16.942 [error] Caught by controller[0]: at Request._callback (script.js.common.Spotify:185:24)
    ! 21:08:56.099 [info] javascript.0 Start javascript script.js.common.Spotify
    ! 21:08:56.099 [info] javascript.0 script.js.common.Spotify: registered 21 subscriptions and 1 schedule
    ! 21:08:56.199 [info] javascript.0 script.js.common.Spotify: Spotify Token aus Datei gelesen !
    ! 21:09:01.739 [error] javascript.0 TypeError: Cannot read property 'hasOwnProperty' of null at CreatePlaybackInfo (script.js.common.Spotify:258:13) at script.js.common.Spotify:781:31 at Request._callback (script.js.common.Spotify:185:24) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at emitTwo (events.js:126:13) at Request.emit (events.js:214:7) at Request. (/opt/iobroker/node_modules/request/request.js:1161:10) at emitOne (events.js:116:13) at Request.emit (events.js:211:7) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1083:12)
    ! 21:09:02.552 [error] Caught by controller[0]: at CreatePlaybackInfo (script.js.common.Spotify:258:13)
    ! 21:09:02.552 [error] Caught by controller[0]: at script.js.common.Spotify:781:31
    ! 21:09:02.552 [error] Caught by controller[0]: at Request._callback (script.js.common.Spotify:185:24)
    • C
      C
      Coffeelover
      #435
      Hallo in die Runde,
      ich finde leider nichts - aber ihr habt doch bestimmt coole Spotify Widgets, oder? Gibt es hierzu im Forum etwas, das ich nicht finde?
      • D
        D
        Daag
        #436
        Ich habe das Problem, dass wenn ich die Funktion shuffleOn im Szenen-Adapter integrieren will, diese Funktion ohne Reaktion bleibt. Wie muss ich diese genau integrieren?
        MfG
        • X
          X
          Xyolyp
          #437
          Guten Tag,
          gibt es inzwischen eigentlich eine Möglichkeit wenn keine Geräte in der Liste der verfügbaren Geräte sind trotzdem ein bestimmtes Gerät anzusprechen? Ich habe einen Google Home Mini und einen Chromecast (Video), welche ich beide aus der Spotify App heraus anwählen kann, aber sie tauchen nur in der Liste der verfügbaren Geräte auf, solange ich Spotify auf dem Gerät offen habe. Besteht eine Möglichkeit lokal den "Starte Spotify" Befehl an den Google Home Mini bzw den Chromecast zu senden? Die App scheint ja irgendeine Möglichkeit zu haben lokal zu prüfen, welche Geräte verfügbar sind ohne, dass Spotify auf den Geräten aktiv sein muss.
          • P
            P
            Pascal09
            #438
            Hallo irgendwie klappt das bei mir nicht bekomme immer folgenden Fehler nachdem ich die Return URI eingetragen habe:
            javascript.0 2018-09-18 20:15:39.227 info script.js.Skripte.Spotify: Fehler beim Token Speichern
            • lobomauL
              lobomauL
              lobomau
              #439
              @mikiline:
              @Alex1808:
              @mikiline:
              Das ist richtig, jedoch "müllt" es den Log zu und macht ihn unübersichtlich. Schön wäre es wenn man diesen Log nur sieht wenn man auf Debug stellt `
              Mache eventuell auch ausschalten?
              Script für Adapter zum Ein/Ausschalten aus VIS
              /* Spritpreis Spotify adapter neu starten
              ! erzeugt Objekt, das in VIS geschaltet werden kann
              Schaltung triggert Neustart eines Adapters
              ! 28.03.2018 erstellt von pix
              const logging = true; // (true;false) Logausgabe zentral schalten, da 5minütlich ein Mehrzeiler geloggt wird.
              const instanz = "javascript." + instance;
              const fC = false; // force Create
              const idSchalter = instanz + ".Spotify.Adapter.Schalter";
              const adapter = "spotify-premium.0"; // Name und Instanz des Adapters
              ! // Ab hier nix mehr ändern
              if (logging) log("Skript " + name + " in der Instanz " + instance + " gestartet");
              ! var idAdapter = "system.adapter." + adapter;
              ! createState(idSchalter, false, fC, {
              name: adapter + " Adapter neu starten",
              type: "boolean",
              desc: "Schaltet den <" + adapter + "> Adapter per Skript zB aus VIS",
              role: "switch"
              ! // Neustart triggern
              on({
              change: "ne",
              from: "system.adapter.web.0" // Schaltung nur aus VIS möglich
              }, function (dpobj) {
              var obj = getObject(idAdapter);
              if (dpobj.state.val) {
              obj.common.enabled = true; // Adapter einschalten
              } else if (!dpobj.state.val) {
              obj.common.enabled = false; // Adapter ausschalten
              setObject(idAdapter, obj);
              if (logging) log("Adapter <" + adapter + "> wurde " + ((obj.common.enabled) ? "ein" : "aus") + "geschaltet");
              Und ich hänge noch ein Indikator mit dazu, dann ist auch wirklich klar ob Adapter An oder Aus ist
              system.adapter.spotify-premium.0.alive `
              Danke :-) Hab das Skript mal implementiert `
              Ich habe nicht verstanden was das Script mit den log-Einträgen
              spotify-premium.0	2018-09-20 08:38:01.724	warn	no playback content
              spotify-premium.0	2018-09-20 08:37:56.543	warn	no playback content
              spotify-premium.0	2018-09-20 08:37:51.431	warn	no playback content
              spotify-premium.0	2018-09-20 08:37:46.310	warn	no playback content
              zu tun hat?
              Ich habe nun in vis einen Schalter mit dem ich den Spotify-Adapter neustarten kann. Und dann geht der log genauso weiter wie vorher :roll:
              Ich kann beim Adapter nur die Log-Stufe auf Error stellen. Dann ist Ruhe.
              Host: NUC8i3 mit Proxmox:
              • Slave: Pi4
              • N
                N
                Nopax
                #440
                @Xyolyp:
                Guten Tag,
                gibt es inzwischen eigentlich eine Möglichkeit wenn keine Geräte in der Liste der verfügbaren Geräte sind trotzdem ein bestimmtes Gerät anzusprechen? Ich habe einen Google Home Mini und einen Chromecast (Video), welche ich beide aus der Spotify App heraus anwählen kann, aber sie tauchen nur in der Liste der verfügbaren Geräte auf, solange ich Spotify auf dem Gerät offen habe. Besteht eine Möglichkeit lokal den "Starte Spotify" Befehl an den Google Home Mini bzw den Chromecast zu senden? Die App scheint ja irgendeine Möglichkeit zu haben lokal zu prüfen, welche Geräte verfügbar sind ohne, dass Spotify auf den Geräten aktiv sein muss. `
                Ich habe auch das Problem das sämtliche Geräte nicht in der Liste verfügbar sind, falls jemand eine Möglichkeit hat die Geräte trotzdem anzusprechen wäre ich sehr dankbar.
                • AxelF1977A
                  AxelF1977A
                  AxelF1977
                  #441
                  @twonky:
                  @schubi82: Hier habe ich dir ein Skript zusammen gebastelt womit du das lösen kannst. Das Design musst du natürlich an deine Bedürfnisse anpassen. `
                  Genial, sowas habe ich gesucht, Danke
                  Ich möchte das view nach und nach optisch an Spotify ranrücken. Dafür möchte ich die Playliste genau wie die Trackliste einer Playliste als Tabelle darstellen (siehe Screenshot). Ich möchte das nicht über DropDown Auswahl regeln.
                  Leider habe ich es nicht geschafft das Javascript anzupassen. Da fehlen mir leider Kenntnisse.
                  Könnte mir da jemand helfen?
                  Vielen Dank
                  ASROCK Deskmini Intel I3 8100 16GB mit Proxmox VM ioBroker VM DIYHue| CCU piVCCU + FHEM auf Raspberry | Maria DB mit Grafana und Prometheus auf Tinker Board
                  • E
                    E
                    el-lutschi
                    #442
                    bei mir in der Log läuft auch dauernd der "Fehler", wenn keine Musik läuft:
                    Außerdem habe ich das Problem, dass sich meine Connect Geräte dauernd mehrfach im Adapter anlegen und dann nicht mehr über Skripte steuerbar sind.
                    (Siehe Screenshot).
                    Vll kann man dagegen auch was tun?
                    Danke und Gruß
                    Chris
                    • AxelF1977A
                      AxelF1977A
                      AxelF1977
                      #443
                      Keiner eine Idee wie das Script umgebaut werden kann, damit die Playlisten als Links in einer Tabelle dargestellt werden können, sie wie es das Script von twonky für die Tracks einer Playliste tut?
                      `createState('javascript.0.spotify-premium.trackListHtml', '', false);
                      function refreshTrackList() {
                      	var current = getState('spotify-premium.0.playbackInfo.playlist.trackList').val;
                      	var source = getState('spotify-premium.0.playbackInfo.playlist.trackListArray').val;
                      	var html = '';
                      	for (var i = 0; i < source.length; i++) {
                      		html += '';
                      		html += '';
                      		html += '';
                      		html += '';
                      	html += '
                      		if(current == i) html += '**';
                      		html += source[i].artist;
                      		html += ' | ';
                      		html += source[i].title;
                      		html += ' |
                      	setState('javascript.0.spotify-premium.trackListHtml', html, true);
                      on('spotify-premium.0.playbackInfo.playlist.trackList', refreshTrackList);
                      on('spotify-premium.0.playbackInfo.playlist.trackListArray', refreshTrackList);
                      refreshTrackList();`
                      Ich bekomme es trotz vielen Versuchen einfach nicht hin  :oops:[/i][/i]
                      • twonkyT
                        twonkyT
                        twonky
                        #444
                        Skript erstellt: https://github.com/twonky4/ioBroker.spo … l-Playlist
                        • AxelF1977A
                          AxelF1977A
                          AxelF1977
                          #445
                          @twonky:
                          Skript erstellt: https://github.com/twonky4/ioBroker.spo … l-Playlist `
                          Wie ich Dir schon geschrieben habe, ich bin schwer beeindruckt! Und ich bin Dir sehr dankbar für die schnelle Hilfe.
                          Ist auch schon eingebaut, siehe Screenshot. Habe noch kurz die Scrollbars an mein Design angepasst. Kommt echt gut jetzt zusammen. Daher einfach mal Danke sagen!
                          Klasse Arbeit twonky!
                          • AxelF1977A
                            AxelF1977A
                            AxelF1977
                            #446
                            @twonky
                            Gibt es eigentlich mittlerweile ein Lösung um die Lautstärke zu regeln, je nach dem Device, auf der die Wiedergabe gerade läuft?
                            https://forum.iobroker.net/viewtopic.php?f=21&t=8173&start=280#p131088 funktioniert bei mir nicht (angepasst an den neuen Adapter).
                            Das View nimmt auch langsam Formen an.
                            Klasse wäre es, auch noch die Anzahl der Titel pro Playliste anzeigen zulassen, wie es auch bei Spotify der Fall ist. Hier = 13 Songs. Der Adapter gibt das ja her, aber wie regel ich das pro Playliste dynamisch?
                            • M
                              M
                              mikiline
                              #447
                              Es gibt bereits einen Datenpunkt hierzu
                              "spotify-premium.0.playbackInfo.playlist.tracksTotal"
                              Auch welcher bereits abgespielt wird
                              "spotify-premium.0.playbackInfo.playlist.trackNo"
                              • AxelF1977A
                                AxelF1977A
                                AxelF1977
                                #448
                                @mikiline:
                                "spotify-premium.0.playbackInfo.playlist.trackNo" `
                                Danke mikiline, da habe ich gestern den Wald vor lauter Bäumen nicht mehr gesehen.
                                • X
                                  X
                                  Xyolyp
                                  #449
                                  @AxelF1977 stellst du deine View zur Verfügung wenn sie fertig ist? Sieht wirklich gut aus und sollte durch leichte Änderung der Widgetgrößen (oder hast du die schon prozentual?) ja auf nahezu jedem Tablet laufen können ;)
                                  • AxelF1977A
                                    AxelF1977A
                                    AxelF1977
                                    #450
                                    @Xyolyp:
                                    @AxelF1977 stellst du deine View zur Verfügung wenn sie fertig ist? Sieht wirklich gut aus und sollte durch leichte Änderung der Widgetgrößen (oder hast du die schon prozentual?) ja auf nahezu jedem Tablet laufen können ;) `
                                    ja, das kann ich gerne machen. Aktuell ist es noch im groben Entstehen, und nur auf mein Tablet angepasst. Sobald es funktioniert wie ich möchte, kann ich es so anpassen, das es universell nutzbar ist
                                      #451
                                      @ AxelF1977
                                      Wie hast Du denn die Scrollbalken da rein bekommen?
                                      • AxelF1977A
                                        AxelF1977A
                                        AxelF1977
                                        #452
                                        @Pocky:
                                        @ AxelF1977
                                        Wie hast Du denn die Scrollbalken da rein bekommen? `
                                        Hi Pocky,
                                        das sind jeweils basic string (unescaped) widgeds. Diesen habe ich bei overflow-y: den Wert "scroll" zugeordnet. Damit werden die Widgets dann mit Scrollbalken versehen, falls der Inhalt länger ist, als die Widgethöhe.
                                        Zum Schluss noch mit CSS an mein Layout angepasst.
                                        /* width */
                                        ::-webkit-scrollbar {
                                            width: 15px;
                                        /* Track */
                                        ::-webkit-scrollbar-track {
                                            background: #424242;
                                        /* Handle */
                                        ::-webkit-scrollbar-thumb {
                                            background: #888;
                                        /* Handle on hover */
                                        ::-webkit-scrollbar-thumb:hover {
                                            background: #a7a6a6;
                                          #453
                                          @ AxelF1977
                                          Danke Dir
                                          83.9k
