  4. Installation auf NUC mit Proxmox
128 Beiträge 29 Kommentatoren 34.8k Aufrufe 9 Beobachtet
    mafe68
    #75
    Nein habe ich noch nicht, nur kann sie nicht voll sein da nur eine LXC Container drauf ist bei einer 2TB Platte
    Hier habe ich auch mal den Log
    root@proxmox:~# tail -f /var/log/daemon.log
    Sep 11 00:20:02 proxmox systemd[1]: pvesr.service: Failed with result 'exit-code'.
    Sep 11 00:21:00 proxmox systemd[1]: Starting Proxmox VE replication runner...
    Sep 11 00:21:02 proxmox pvesr[2897]: ipcc_send_rec[1] failed: Connection refused
    Sep 11 00:21:02 proxmox pvesr[2897]: ipcc_send_rec[2] failed: Connection refused
    Sep 11 00:21:02 proxmox pvesr[2897]: ipcc_send_rec[3] failed: Connection refused
    Sep 11 00:21:02 proxmox pvesr[2897]: Unable to load access control list: Connection refused
    Sep 11 00:21:02 proxmox systemd[1]: pvesr.service: Main process exited, code=exited, status=111/n/a
    Sep 11 00:21:02 proxmox systemd[1]: Failed to start Proxmox VE replication runner.
    Sep 11 00:21:02 proxmox systemd[1]: pvesr.service: Unit entered failed state.
    Sep 11 00:21:02 proxmox systemd[1]: pvesr.service: Failed with result 'exit-code'.
    Sep 11 00:22:00 proxmox systemd[1]: Starting Proxmox VE replication runner...
    Sep 11 00:22:02 proxmox pvesr[2911]: ipcc_send_rec[1] failed: Connection refused
    Sep 11 00:22:02 proxmox pvesr[2911]: ipcc_send_rec[2] failed: Connection refused
    Sep 11 00:22:02 proxmox pvesr[2911]: ipcc_send_rec[3] failed: Connection refused
    Sep 11 00:22:02 proxmox pvesr[2911]: Unable to load access control list: Connection refused
    Sep 11 00:22:02 proxmox systemd[1]: pvesr.service: Main process exited, code=exited, status=111/n/a
    Sep 11 00:22:02 proxmox systemd[1]: Failed to start Proxmox VE replication runner.
    Sep 11 00:22:02 proxmox systemd[1]: pvesr.service: Unit entered failed state.
    Sep 11 00:22:02 proxmox systemd[1]: pvesr.service: Failed with result 'exit-code'.
    LG. Mario
    ioBroker LXC Container Proxmox
    ioBroker BananaPi M1
      mafe68
      #76
      Hier die Auslastung der HDD`s
      root@proxmox:~# df -h
      Filesystem      Size  Used Avail Use% Mounted on
      udev            7.6G     0  7.6G   0% /dev
      tmpfs           1.6G  8.9M  1.6G   1% /run
      /dev/sda1        15G  2.0G   12G  15% /
      tmpfs           7.6G     0  7.6G   0% /dev/shm
      tmpfs           5.0M     0  5.0M   0% /run/lock
      tmpfs           7.6G     0  7.6G   0% /sys/fs/cgroup
      /dev/sda6        28G   45M   27G   1% /home
      /dev/sdb1       1.8T  5.0G  1.7T   1% /datastore
      tmpfs           1.6G     0  1.6G   0% /run/user/0
      LG. Mario
      • U Offline
        U Offline
        UncleB
        #77
        Sorry das ich so reingrätsche, aber wieso bügelt man Linux nicht direkt auf die ssd, sondern lässt das ganze unter Proxmox laufen?
        Gesendet von meinem SM-G950F mit Tapatalk
          mafe68
          #78
          Proxmox ist ein Linux System nur halt für Virtualisierung. Ich könnte ioBroker direkt in deinem Debian oder Ubuntu laufen lassen ,nur habe ich hier mehrere Anwendungen laufen die ich getrennt haben möchte und für jede Anwendung ein eigenes System laufen lassen ist Unsinn. Darum hier alles auf einer Hardware unter Proxmox als LXC Container.
          LG. Mario
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            #79
            @UncleB:
            Gesendet von meinem SM-G950F mit Tapatalk `
            Weil der Gebrauch von einen NUC mit seinen Ressourcen nur die eine Installation reine Ressourcen Verschwendung ist und Virtualisierung vierte Vorteile bringt.
            (Verschieden Systeme auf einen Host, snapshots usw)
            • chucky666C Offline
              chucky666C Offline
              chucky666
              #80
              Ich habe mehrere Vm am laufen ,
              Eine für Iobroker, Test Iobroker, Pi Hole , Windows
              Kann ich jedem nur empfehlen, wenn was schief geht . Super schnell ein Snapshot zurück spielen
              • P Offline
                piet
                #81
                Hallo an die Spezialisten,
                ich habe jetzt auch Proxmox auf einem Nuc installiert.
                Proxmox läuft , VM Debian mit Iobroker läuft auch.
                Autostart der VM funktioniert auch.
                Der Autostart von Iobroker selber klappt nicht.
                Ich habe es schon mit dem Vorschlag von Holger probiert.
                chmod +x /etc/init.d/iobroker.sh
                update-rc.d iobroker.sh defaults
                reboot
                Bei mir ist aber keine Datei iobroker.sh vorhanden.
                Node.js: v8.12.0
                NPM: 6.4.1
                JS Controller 1.4.2
                Hat jemand einen Tipp für mich?
                Klaus
                Aktiv: Pi 3
                Test: NUC mit Proxmox LXC und VM, Iobroker auf Debian.
                • VumerV Offline
                  VumerV Offline
                  Vumer
                  #82
                  nach dieser http://www.iobroker.net/docu/?page_id=5106&lang=de sollte alles funktionieren
                  • P Offline
                    piet
                    #83
                    Hallo Vumer,
                    vielen Dank
                    aber ich hatte nach der Anleitung installiert.
                    Klaus
                    Aktiv: Pi 3
                    • VumerV Offline
                      VumerV Offline
                      Vumer
                      #84
                      aber da steht
                      ` > das mitglieferte npm 5.6.0 npm unbedingt downgraden mit sudo npm install -g npm@4
                      <size size="85">npm 5.x enthält noch einen Bug, der bei ioBroker zu massiven Problemen führt</size>. `
                      und der Bug hat mit dem Autustart zutun
                      • P Offline
                        piet
                        #85
                        ist das auch gültig für
                        6.4.1 ?
                        Aktiv: Pi 3
                        • VumerV Offline
                          VumerV Offline
                          Vumer
                          #86
                          denke schon
                          mach doch eine neue VM und installier streng nach der Anleitung
                          • P Offline
                            piet
                            #87
                            so jetzt habe ich iobroker komplett neu installiert nach dieser Anleitung:
                            Wenn ich die VM starte wird Iobroker nicht automatisch gestartet.
                            Node = 6.14.4
                            Nodejs = 6.14.4
                            npm = 4.6.1
                            js-controller = 1.4.2
                            Vielleicht hat ja noch jemand einen Tipp.
                            Klaus
                            Aktiv: Pi 3
                            • P Offline
                              piet
                              #88
                              habe das Problem gelöst.
                              Es musste noch Sudo installiert werden.
                              Aktiv: Pi 3
                              • X Offline
                                X Offline
                                Xanon
                                #89
                                ich habe mich nun auch mit meinem NUC an die Proxmox installation gewagt um dort iobroker und später noch weitere Sachen drauf laufen zu lassen.
                                Ich habe zuvor viel gelesen und der Umzug hat gut funktioniert.
                                Neustart funktioniert und auch die externe Speicherung auf meinem NAS scheint zu funktionieren.
                                Allerdings…
                                ... ich verstehe noch nicht ganz, auf was ich bei einer Datensicherung/Einstellung (Backup, Snapshot) achten soll.
                                Ich habe das Backup so eingerichtet, dass täglich um 02:00 Uhr ein Backup auf meinem NAS erstellt wird.
                                Welche Einstellungen benutzt Ihr?
                                Modus: Snapshot, Suspend, Stopp?
                                Auswahlmodus: Alle ?
                                Kompression: LZO , GZIP?
                                Auch habe ich noch nicht verstanden, wie dass mit dem Backup funktioniert.
                                Also ich habe ein Backup erstellt , welches den Dateinamen "vzdump-qemu-100-2018_10_05-14_17_54.vma.lzo" trägt und 1,76GB groß ist
                                Was mache ich in einem Ernstfall mit dieser Datei?
                                Wohin muss das backup kopieren?
                                Ist in der Datei alles enthalten?
                                Debian, iobroker-komplett, VIS, …
                                Sorry, für die ganzen fragen aber ich blicke da noch nicht ganz durch.
                                Marcus
                                • U Offline
                                  U Offline
                                  uschi08
                                  #90
                                  Einfach über die Proxmox Oberfläche, unter Backup zurückspielen…
                                  • X Offline
                                    X Offline
                                    Xanon
                                    #91
                                    OK Danke für die Antwort.
                                    Dann warte ich mal ab und hoffe, dass alles funktioniert, wenn es drauf ankommt. ;)
                                    • apollon77A Offline
                                      #92
                                      Hoffen ist blöd bei sowas … TESTEN!
                                      • H Offline
                                        holgerwolf
                                        #93
                                        nachdem mein Proxmox eine Betriebszeit seit 2 Monaten hat und auch ohne Probleme durchläuft, mache ich mir gerade Gedanken über die anstehenden Updates des Host Betriebsystem. Sind mittleweile 20 Pakete zu updaten.
                                        Wie macht ihr das? Bei den VMs kann man für den Fall der Fälle ja vorher Snapshots anlegen. Aber beim Host?
                                        Holger
                                          #94
                                          Ohne einen "Cluster" bleibt das Host System das "Risiko".
