  4. KNX Adapter überholt
1.0k Beiträge 123 Kommentatoren 513.1k Aufrufe 26 Beobachtet
  • C Offline
    Centurytt
    #769
    Hallo Leute,
    nach jedem Start des KNX Adapter sieht mein Log so aus. Dabei habe ich NPM 4 und Nodejs 8 installiert. Erst nach einem kompletten reboot meldet sich der KNX wieder mit Lebenszeichen. KNX 0.8.6 ! Was ist denn da los ? DANKE
    host.ubuntu-hd 2018-08-25 09:51:43.217 info Restart adapter system.adapter.knx.0 because enabled
    host.ubuntu-hd 2018-08-25 09:51:43.217 error instance system.adapter.knx.0 terminated with code 0 (OK)
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at fsm.transition (/opt/iobroker/node_modules/iobroker.knx/node_modules/machina/lib/machina.js:653:28)
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at fsm._onEnter (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:286:12)
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at fsm.emitEvent (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:312:10)
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at fsm.emit (/opt/iobroker/node_modules/iobroker.knx/node_modules/machina/lib/machina.js:111:8)
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at Function. <anonymous>(/opt/iobroker/node_modules/iobroker.knx/node_modules/lodash/index.js:3346:13)
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/node_modules/lodash/index.js:3049:15
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/node_modules/lodash/index.js:2874:23
    Caught 2018-08-25 09:51:43.217 error by controller[0]: at fsm. <anonymous>(/opt/iobroker/node_modules/iobroker.knx/node_modules/machina/lib/machina.js:113:17)
    Caught 2018-08-25 09:51:43.216 error by controller[0]: at fsm. <anonymous>(/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/Datapoint.js:51:28)
    Caught 2018-08-25 09:51:43.216 error by controller[0]: at Object.dpts.fromBuffer (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/dptlib/index.js:175:54)
    Caught 2018-08-25 09:51:43.216 error by controller[0]: TypeError: Cannot read property 'hasOwnProperty' of undefined
    knx.0 2018-08-25 09:51:43.191 error at fsm.transition (/opt/iobroker/node_modules/iobroker.knx/node_modules/machina/lib/machina.js:653:28)
    knx.0 2018-08-25 09:51:43.191 error at fsm._onEnter (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:286:12)
    knx.0 2018-08-25 09:51:43.191 error at fsm.emitEvent (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/FSM.js:312:10)
    knx.0 2018-08-25 09:51:43.191 error at fsm.emit (/opt/iobroker/node_modules/iobroker.knx/node_modules/machina/lib/machina.js:111:8)
    knx.0 2018-08-25 09:51:43.191 error at Function. <anonymous>(/opt/iobroker/node_modules/iobroker.knx/node_modules/lodash/index.js:3346:13)
    knx.0 2018-08-25 09:51:43.191 error at /opt/iobroker/node_modules/iobroker.knx/node_modules/lodash/index.js:3049:15
    knx.0 2018-08-25 09:51:43.191 error at /opt/iobroker/node_modules/iobroker.knx/node_modules/lodash/index.js:2874:23
    knx.0 2018-08-25 09:51:43.191 error at fsm. <anonymous>(/opt/iobroker/node_modules/iobroker.knx/node_modules/machina/lib/machina.js:113:17)
    knx.0 2018-08-25 09:51:43.191 error at fsm. <anonymous>(/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/Datapoint.js:51:28)
    knx.0 2018-08-25 09:51:43.191 error at Object.dpts.fromBuffer (/opt/iobroker/node_modules/iobroker.knx/lib/knx-mod/src/dptlib/index.js:175:54)
    knx.0 2018-08-25 09:51:43.191 error TypeError: Cannot read property 'hasOwnProperty' of undefined
    knx.0 2018-08-25 09:51:43.191 error uncaught exception: Cannot read property 'hasOwnProperty' of undefined</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      Micheagle
      #770
      Hallo Centurrytt,
      warum benutzt du noch die alte Version des Adapters?
      chefkoch009 hat viel Zeit und Mühe in die neuen Versionen investiert.
      Dies ist der Testbereich und soweit ich das nachvollziehen kann, sind nun die Probleme soweit gelöst, dass der Adapter in Version 1.0.17 stabil läuft.
      Hast du es schon mit Version 1.0.17 probiert?
      Bus: KNX, 1-wire
      Host-Machine: Raspberry Pi 3B
      Interface: KNXD über GIRA X1 oder auch Busware TPUART
      • C Offline
        Centurytt
        #771
        @Micheagle:
        Hallo Centurrytt,
        Hast du es schon mit Version 1.0.17 probiert? `
        weil bei mir der neue Adapter nicht funktioniert. Der 0.8.6 ist der einzige der soweit läuft dass ich meinen KNX IP GW damit ansprechen kann. Beim Adapter 1.0.17 passiert einfach gar nichts. Ich weiss auch nicht warum aber es werden im neuen keine DPT erstellt ?? Ich verwende kein KNXD und oder EIBD sondern ich fahre direkt auf den BUS. Auch hab ich KNX Komponenten von GIRA, Berker, Theben usw. im Einsatz und kein Homematic oder dgl. ! Ich bin jetzt schon soviel zeit und Mühen investiert, dass ich wirklich beim überlegen bin, mir eine andere Plattform als ioBroker zu suchen. Ich mag nicht mehr. Egal was ich mache der KNX Adapter läuft nicht. Die Installation lasse ich auf einer QNAP in der Linux Station als Ubuntu 14.04 laufen. Werde jetzt nochmals einen RPI3 nehmen und das dort probieren.
        lg
        Tom
          Micheagle
          #772
          Hallo Tom,
          ich hoffe, dass du meine Nachfrage nicht als Vorwurf verstanden hast.
          Auch ich habe viel Zeit investiert, um das System ans Laufen zu bringen.
          Bei klappt es sowohl über den KNXD mit einem Busware TUL als auch direkt über die Schnittstelle des Gira X1.
          Welche Schnittstelle nutzt du?
          Meiner Meinung nach ist der erfolgversprechende Weg der, dass wir lernen die Log Files zu lesen und zu verstehen.
          Das hilft uns und auch chefkoch009, weil der dann die Punkte angehen kann.
          Und das macht er ja auch regelmäßig.
          Guck mal, ob du es auf dem Raspi ans Laufen bringst.
          Und wenn das klappt, ist es ja noch eine Option es ggf noch mal auf dem QNAP zu probieren.
          Bus: KNX, 1-wire
          • C Offline
            Centurytt
            #773
            Hi Micheagle,
            nein nein, das war überhaupt kein Vorwurf…. ich ärgere mich nur, dass der Adapter von einem Tag auf den nächsten nicht mehr funktioniert und ich nicht weiß warum. Nachdem Aufsetzen von Ubuntu und Einrichtung klappte alles wunderbar. Nach einem Tag fangen dann die Logeinträge wieder an.. ?
            Ich hab mir die ein Interface von EIBMARKT gekauft (N000401) und das läuft soweit auch spitze da kann ich nix sagen. Ich werde jetzt den RPI3 mal von grund auf neu konfigurieren und nur die VIS importieren. Dann sehe ich weiter. Eventuell liegts ja auch an QNAp und ich muss auf einen Blink umsteigen um mehr Power zu haben. Die Virtuellen Instanzen sind eh schwer zu analysieren wenns um Fehlersuche geht.
            LG
            Tom
              tombox
              #774
              @Centurytt:
              Hallo Leute,
              nach jedem Start des KNX Adapter sieht mein Log so aus. Dabei habe ich NPM 4 und Nodejs 8 installiert. Erst nach einem kompletten reboot meldet sich der KNX wieder mit Lebenszeichen. KNX 0.8.6 ! Was ist denn da los ? DANKE `
              0.8.6 scheint probleme mit deinem dpts aus deinem projekt zu haben.
              • chefkoch009C Offline
                chefkoch009
                #775
                Diesen "fsm" Fehler konnte ich nicht beheben, weil dieser Fehler aus einem Paket von einem anderen Entwickler kommt. Das hat mich geärgert, deshalb habe ich es neu geschrieben. Seit V1.0.0 kann dieser Fehler nicht mehr kommen. Seit Beginn der Adapterentwicklung hat sich auch einiges an npm und node geändert. Aus diesem Grund ist npm v6.x und node v8.x zwingend. Änderungen an der Objektstruktur hatte ich weiter oben schon beschrieben.
                Da man node auf verschiedene Weisen installieren kann bitte prüfen, ob auch wirklich die geforderte Version benutzt wird.
                @Micheagle: danke für dein Feedback.
                chefkoch009
                • C Offline
                  Centurytt
                  #776
                  Hallo Chefkoch,
                  ich hab das letzte SD Image jetzt für RPI3 verwendet. Bin gerade noch am einrichten, hier wird Nodejs 8 verwendet npm werde ich auf 6 updaten. Dann versuche ich mein Glück erneut und gebe Bescheid.
                  lg
                  Tom
                    kilolima
                    #777
                    @Micheagle:
                    So,
                    ich möchte kurz zurück melden, dass bei mir die aktuelle Version seit Tagen ohne Probleme läuft.
                    <emoji seq="1f44d-1f3fb">👍🏻</emoji>
                    Gute Arbeit @chefkoch009
                    Danke und Gruß
                    Michael `
                    Verständnisfrage vom nicht versierten Laien.
                    1.0.17? Ist das der aktuelle, der bei dir läuft?
                    Kai
                      Micheagle
                      #778
                      Hallo Kai,
                      schau an, da hatte ich den Eintrag zwei mal, weil ich wohl einmal noch die Versionsnummer nachgetragen hatte,
                      dann aber hatte ich den Eindruck eines Doppel-Posts und hatte den Eintrag mit der Versionsnummer gelöscht.
                      Clever … :lol:
                      Ja, die aktuelle Version, die bei mir problemlos läuft, ist die Version 1.0.17.
                      Michael
                      Bus: KNX, 1-wire
                        kilolima
                        #779
                        Danke Michael.
                        Hmm… ich scheine da keine Verbindung zu meiner KNX-Schnittstelle hinzubekommen. Habe zwei IP-Schnittstellen probiert. Ist das ein bekanter Fehler? Der Adapter läuft soweit.
                        Was mache ich ggf. falsch?
                        Danke und Gruß
                          Micheagle
                          #780
                          Die physical eib address steht auf 0.0.0
                          Trage da mal eine freie KNX Bus Adresse ein.
                          bei mir ist das ne 1.1.9, ich hatte aber auch schon eine 1.1.60.
                          Die darf natürlich nicht von einem anderen Gerät belegt sein.
                          Das Problem hatte ich schon. Dank an chefkoch009 an dieser Stelle …
                          Bus: KNX, 1-wire
                          • C Offline
                            Centurytt
                            #781
                            Hallo an Alle,
                            mein Erfahrungen im Bezug auf viele fehlgeschlagene Installationen von KNX Adapter, endet heute mit einem Erfolg. Nachdem ich immer wieder versucht habe den ioBroker auf Ubuntu 14.04 stabil zum laufen zu bringen, dass scheinbar (mir zumindest) nicht gelungen ist, habe ich dann Gestern zuerst mit RPI3 und dann noch im Anschluss mit DOCKER Container etwas herumgespielt.
                            Dazu folgende Anmerkung: es ist mir unter Ubuntu nie gelungen den KNX Adapter von Chefkoch in der V1.0.17 zum laufen zu bringen, jedoch unter Debian sehr wohl. Daher habe ich dann den Docker Container mit einer ioBroker Installation konfiguriert und mit node 8.11.x und npm 6 am ans laufen gebracht. Nach der Wiederherstellung des Backups, dass in einem Docker Container etwas aufwändiger ist läuft auch der KNX Adapter in der aktuellen Version von Chefkoch ohne Probleme.
                            Zuvor hatte ich ständig Error Einträge im Log…. unter Debian nicht einen. Somit hoffe ich endet das Drama :-) und ich erfreue mich meiner Visualisierung :-)
                            Danke @All
                            lg
                            Tom
                              tombox
                              #782
                              Also mit ubuntu 18 und raspianpi ohne desktop 4.14 funktioniert ohne Probleme
                                kilolima
                                #783
                                @Micheagle:
                                Das Problem hatte ich schon. Dank an chefkoch009 an dieser Stelle … `
                                Entwarnung! kopfmeetstischkante
                                Das Log lesen hat echt Sinn. Ich hatte seit letztem Oktober nichts mehr im iOBroker gemacht und mir war nicht geläufig, dass ich eine Lizenz für den KNX-Adapter brauchte.
                                Jetzt leuchtet habe ich einen grünen Punkt in der Instanz. Das finde ich gut ;o)
                                Nächste Station - Projekt wieder einlesen und die Verbindung zu Alexa checken. Da gibt es zwischenzeitlich eine Lösung ohne ioBroker-Cloud habe ich irgendwo gelesen !?!
                                Und was ist Alexa 2 ?
                                Fragen über Fragen! :shock:
                                  kilolima
                                  #784
                                  Ich habe jetzt mehrfach versucht mein KNX-Projektfile zu importieren. Zuletzt habe ich es über eine Stunde laden lassen. Der Statusbalken wandert ziemlich zügig nach links und dann geht es an das Erstellen der Objekte. Danach tut sich nichts mehr. Wie gesagt, hatte es nun los vier eine Stunde rödeln lassen. Was stimmt da nicht?
                                  Danke und viele Grüße
                                  Kai
                                    axel.rathey
                                    #785
                                    das gleiche Problem habe ich auch. Der Import der knxproj Datei wird gestartet, kommt aber nicht zum Ende, es kommt auch keine Fehlermeldung. Im log taucht zwar einiges auf, ist aber nicht aussagekräftig ob das der Fehler ist oder woran das liegt. Breche ich ab, wurden meist keine Objekte angelegt, manchmal ein paar wenige, aber nie alle.
                                    Hardware: iobroker unter raspbian jessie auf einem BananaPi M3
                                    Ethernet2KNX-Adapater: IPS/S 3.1.1 über PoE vom Switch gespeist.
                                    npm -v = 6.4.0 (auf Anraten von Chefkoch gestern Abend in Github von zunächst npm 4.6 auf npm 6.* aktualisiert)
                                    node -v = 8.11.4
                                    iobroker.admin = 3.4.7
                                    iobroker.knx = 1.0.17
                                    Browser = Firefox und Chrome beide probiert
                                    Die Konfig hatte so vor meinem Update unter npm 3.10.10 und Node 6.* mit dem alten KNX 0.8.6 funktioniert.
                                    Reicht es aus, wenn das npm apt-get install
                                    Wäre Klasse, wenn ich das mit Eurer Hilfe bald wieder zum Laufen bringen könnte, da wir einige zigbee Q-Lampen (Paul Neuhaus) sonst nur über deren Fernbedienung oder die tradfri-App (Q-Lampen über tradfri Gateway angebunden) schalten kann. Wäre für mich kein Problem, aber es gibt halt auch NichtNerds in der Familie.
                                    Danke, Gruß
                                    Axel
                                    iobroker, KNX, tradfi, fritzdect, tr-064
                                      tombox
                                      #786
                                      Das beste wäre wohl wenn ihr euer knxproj Chefkoch zukommen lässt damit man das mal testen kann
                                        Micheagle
                                        #787
                                        Bitte Chefkoch009 direkt zukommen lassen.
                                        Die Projektdateien sollen ja nicht öffentlich zugänglich sein.
                                        Bus: KNX, 1-wire
                                          axel.rathey
                                          #788
                                          Habe ihm gerade einen gdrive Link zugesandt
