  4. Xiaomi Magic Cube
    6.6k
Xiaomi Magic Cube
97 Beiträge 26 Kommentatoren 27.9k Aufrufe 1 Beobachtet
    technogodder
    Hallo Bluefox,
    ich füge hier mal ein Logfile ein, ich weiss nicht ob ich alles richtig gemacht habe, falls noch irgendwas fehlt bitte um Rückmeldung, was ich ändern muss. Ab 19:38:14 habe ich die Funktionen des Würfels getestet, manchmal 2x hintereinander das selbe, doch es kam jedesmal ein anderer Token:
    2018-06-03 19:37:54.804 - info: host.raspberrypi instance system.adapter.mihome.0 terminated with code 0 (OK)
    2018-06-03 19:37:57.256 - info: host.raspberrypi instance system.adapter.mihome.0 started with pid 19829
    2018-06-03 19:38:00.458 - debug: mihome.0 objectDB connected
    2018-06-03 19:38:00.593 - debug: mihome.0 statesDB connected
    2018-06-03 19:38:00.796 - info: mihome.0 starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.mihome, node: v6.13.0
    2018-06-03 19:38:01.264 - debug: mihome.0 device: 7811dce1e91c(gateway)
    2018-06-03 19:38:01.286 - debug: mihome.0 RAW: {"cmd":"iam","port":"9898","sid":"7811dce1e91c","model":"gateway","proto_version":"1.1.2","ip":"192.168.178.123"}
    2018-06-03 19:38:01.304 - debug: mihome.0 RAW: {"cmd":"get_id_list_ack","sid":"7811dce1e91c","token":"WbslaXBSTZU9JxS2","data":["158d0002275d06","158d0002277e04","158d00022b2a9d","158d000231e4a7"]}
    2018-06-03 19:38:01.315 - debug: mihome.0 data: 7811dce1e91c(gateway): {"illumination":407,"on":false,"dimmer":0,"rgb":"#000000"}
    2018-06-03 19:38:01.322 - debug: mihome.0 RAW: {"cmd":"read_ack","model":"gateway","sid":"7811dce1e91c","short_id":0,"data":{"rgb":0,"illumination":407,"proto_version":"1.1.2"}}
    2018-06-03 19:38:01.324 - debug: mihome.0 device: 158d0002275d06(magnet)
    2018-06-03 19:38:01.329 - debug: mihome.0 data: 158d0002275d06(magnet): {"voltage":3.025,"percent":82.5,"state":false}
    2018-06-03 19:38:01.333 - debug: mihome.0 RAW: {"cmd":"read_ack","model":"magnet","sid":"158d0002275d06","short_id":1070,"data":{"voltage":3025,"status":"close"}}
    2018-06-03 19:38:01.334 - debug: mihome.0 device: 158d0002277e04(magnet)
    2018-06-03 19:38:01.337 - debug: mihome.0 data: 158d0002277e04(magnet): {"voltage":3.045,"percent":84.5,"state":false}
    2018-06-03 19:38:01.338 - debug: mihome.0 RAW: {"cmd":"read_ack","model":"magnet","sid":"158d0002277e04","short_id":41999,"data":{"voltage":3045,"status":"close"}}
    2018-06-03 19:38:01.340 - debug: mihome.0 device: 158d00022b2a9d(switch)
    2018-06-03 19:38:01.344 - debug: mihome.0 data: 158d00022b2a9d(switch): {"voltage":3.072,"percent":87.2}
    2018-06-03 19:38:01.346 - debug: mihome.0 RAW: {"cmd":"read_ack","model":"switch","sid":"158d00022b2a9d","short_id":24747,"data":{"voltage":3072}}
    2018-06-03 19:38:01.348 - debug: mihome.0 device: 158d000231e4a7(cube)
    2018-06-03 19:38:01.353 - debug: mihome.0 data: 158d000231e4a7(cube): {"voltage":3.015,"percent":81.5}
    2018-06-03 19:38:01.354 - debug: mihome.0 RAW: {"cmd":"read_ack","model":"sensor_cube.aqgl01","sid":"158d000231e4a7","short_id":41931,"data":{"voltage":3015}}
    2018-06-03 19:38:01.373 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.illumination val=407, ack=true, ts=1528054681321, q=0, from=system.adapter.mihome.0, lc=1528054415284
    2018-06-03 19:38:01.386 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.on val=false, ack=true, ts=1528054681356, q=0, from=system.adapter.mihome.0, lc=1527794369080
    2018-06-03 19:38:01.396 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.dimmer val=0, ack=true, ts=1528054681365, q=0, from=system.adapter.mihome.0, lc=1527794369088
    2018-06-03 19:38:01.401 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.rgb val=#000000, ack=true, ts=1528054681370, q=0, from=system.adapter.mihome.0, lc=1527794369090
    2018-06-03 19:38:01.403 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002275d06.voltage val=3.025, ack=true, ts=1528054681372, q=0, from=system.adapter.mihome.0, lc=1527958076206
    2018-06-03 19:38:01.406 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002275d06.percent val=82.5, ack=true, ts=1528054681374, q=0, from=system.adapter.mihome.0, lc=1527958076215
    2018-06-03 19:38:01.410 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002275d06.state val=false, ack=true, ts=1528054681376, q=0, from=system.adapter.mihome.0, lc=1527780947809
    2018-06-03 19:38:01.414 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002277e04.voltage val=3.045, ack=true, ts=1528054681378, q=0, from=system.adapter.mihome.0, lc=1528015863746
    2018-06-03 19:38:01.416 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002277e04.percent val=84.5, ack=true, ts=1528054681379, q=0, from=system.adapter.mihome.0, lc=1528015863753
    2018-06-03 19:38:01.421 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002277e04.state val=false, ack=true, ts=1528054681381, q=0, from=system.adapter.mihome.0, lc=1527787991386
    2018-06-03 19:38:01.426 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.switch_158d00022b2a9d.voltage val=3.072, ack=true, ts=1528054681382, q=0, from=system.adapter.mihome.0, lc=1527848902028
    2018-06-03 19:38:01.434 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.switch_158d00022b2a9d.percent val=87.2, ack=true, ts=1528054681397, q=0, from=system.adapter.mihome.0, lc=1527848902032
    2018-06-03 19:38:01.436 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.cube_158d000231e4a7.voltage val=3.015, ack=true, ts=1528054681401, q=0, from=system.adapter.mihome.0, lc=1528054165469
    2018-06-03 19:38:01.438 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.cube_158d000231e4a7.percent val=81.5, ack=true, ts=1528054681403, q=0, from=system.adapter.mihome.0, lc=1528054165494
    2018-06-03 19:38:04.637 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"PWsvGPTeRdmKkoHG","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:38:14.775 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"YL7WLnoaiOfxPUdU","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:38:24.610 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"8p07YneCCxiOFyIi","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:38:34.749 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"9OggppaRLlR2visi","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:38:44.572 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"Umcfa0xM00FURSD1","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:38:54.709 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"AYUmchwiwPDLD3CQ","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:39:04.543 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"5RMx4bVLVmpq4jpz","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:39:14.679 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"tIH03CoF2hV9ePFd","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:39:24.510 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"JJqEZHvbitTaq7mh","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:39:34.648 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"GHToLB7SzFunSHqC","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:39:44.480 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"i5SG2osTtCrdhsoa","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:39:54.616 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"hqh6924WKx4D3x7D","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:40:04.449 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"eCeTAdBGpW5vZsJD","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:40:14.358 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"kzSLIuiJdwbt4cIK","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:40:24.416 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"KTjXMSzdOgd67nYo","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:40:34.554 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"OJkUk9L9UVs1Tkad","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:40:44.383 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"fZB5eoPvlhZcLbdW","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:40:54.286 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"osJeHuKZPEiWzBH5","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:41:04.348 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"OHFNKm2eeFGqzt5M","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:41:14.489 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"fxRCv3IExzUvWeXi","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:41:24.321 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"dawUxJdHfPdJopJj","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:41:34.458 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"cRQJzNuTRLOqQokD","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:41:44.290 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"mqppOYolHrpGtBt1","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:41:54.426 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"1kY5bQvFdrJLsM5Z","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:42:04.256 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"BY5zlTInlP0ZknLD","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:42:14.401 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"ZNKt8fyiltNXDsqx","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:42:24.225 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"gE91RFGC6fCPADVk","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:42:34.362 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"wtIUxIZVRbRWL2T0","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:42:44.193 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"fms6vgyWkAuJBulO","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:42:54.331 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"Ja0Ide4vJ7unpolC","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:43:04.163 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"aV0m79c76QfuOBzK","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:43:14.299 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"n7JTaqv4MoGkEDEj","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:43:17.375 - debug: mihome.0 data: 158d0002275d06(magnet): {"state":true}
    2018-06-03 19:43:17.378 - debug: mihome.0 RAW: {"cmd":"report","model":"magnet","sid":"158d0002275d06","short_id":1070,"data":{"status":"open"}}
    2018-06-03 19:43:17.387 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002275d06.state val=true, ack=true, ts=1528054997379, q=0, from=system.adapter.mihome.0, lc=1528054997379
    2018-06-03 19:43:17.678 - debug: mihome.0 data: 158d0002275d06(magnet): {"state":false}
    2018-06-03 19:43:17.680 - debug: mihome.0 RAW: {"cmd":"report","model":"magnet","sid":"158d0002275d06","short_id":1070,"data":{"status":"close"}}
    2018-06-03 19:43:17.688 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002275d06.state val=false, ack=true, ts=1528054997681, q=0, from=system.adapter.mihome.0, lc=1528054997681
    2018-06-03 19:43:18.292 - debug: mihome.0 data: 158d0002275d06(magnet): {"state":true}
    2018-06-03 19:43:18.295 - debug: mihome.0 RAW: {"cmd":"report","model":"magnet","sid":"158d0002275d06","short_id":1070,"data":{"status":"open"}}
    2018-06-03 19:43:18.302 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002275d06.state val=true, ack=true, ts=1528054998295, q=0, from=system.adapter.mihome.0, lc=1528054998295
    2018-06-03 19:43:18.600 - debug: mihome.0 data: 158d0002277e04(magnet): {"state":true}
    2018-06-03 19:43:18.602 - debug: mihome.0 RAW: {"cmd":"report","model":"magnet","sid":"158d0002277e04","short_id":41999,"data":{"status":"open"}}
    2018-06-03 19:43:18.610 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.magnet_158d0002277e04.state val=true, ack=true, ts=1528054998602, q=0, from=system.adapter.mihome.0, lc=1528054998602
    2018-06-03 19:43:20.445 - debug: mihome.0 data: 158d00022b2a9d(switch): {"click":true}
    2018-06-03 19:43:20.447 - debug: mihome.0 RAW: {"cmd":"report","model":"switch","sid":"158d00022b2a9d","short_id":24747,"data":{"status":"click"}}
    2018-06-03 19:43:20.454 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.switch_158d00022b2a9d.click val=true, ack=true, ts=1528055000447, q=0, from=system.adapter.mihome.0, lc=1528055000447
    2018-06-03 19:43:20.745 - debug: mihome.0 data: 158d00022b2a9d(switch): {"click":false}
    2018-06-03 19:43:20.753 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.switch_158d00022b2a9d.click val=false, ack=true, ts=1528055000748, q=0, from=system.adapter.mihome.0, lc=1528055000748
    2018-06-03 19:43:21.980 - debug: mihome.0 data: 7811dce1e91c(gateway): {"illumination":429,"on":false,"dimmer":0,"rgb":"#000000"}
    2018-06-03 19:43:21.983 - debug: mihome.0 RAW: {"cmd":"report","model":"gateway","sid":"7811dce1e91c","short_id":0,"data":{"rgb":0,"illumination":429}}
    2018-06-03 19:43:21.990 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.illumination val=429, ack=true, ts=1528055001982, q=0, from=system.adapter.mihome.0, lc=1528055001982
    2018-06-03 19:43:21.997 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.on val=false, ack=true, ts=1528055001990, q=0, from=system.adapter.mihome.0, lc=1527794369080
    2018-06-03 19:43:22.008 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.dimmer val=0, ack=true, ts=1528055001996, q=0, from=system.adapter.mihome.0, lc=1527794369088
    2018-06-03 19:43:22.018 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.rgb val=#000000, ack=true, ts=1528055001998, q=0, from=system.adapter.mihome.0, lc=1527794369090
    2018-06-03 19:43:23.822 - debug: mihome.0 data: 158d00022b2a9d(switch): {"click":true}
    2018-06-03 19:43:23.825 - debug: mihome.0 RAW: {"cmd":"report","model":"switch","sid":"158d00022b2a9d","short_id":24747,"data":{"status":"click"}}
    2018-06-03 19:43:23.832 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.switch_158d00022b2a9d.click val=true, ack=true, ts=1528055003825, q=0, from=system.adapter.mihome.0, lc=1528055003825
    2018-06-03 19:43:24.123 - debug: mihome.0 data: 158d00022b2a9d(switch): {"click":false}
    2018-06-03 19:43:24.130 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"5vCYh27TTLgaPLdJ","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:43:24.132 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.switch_158d00022b2a9d.click val=false, ack=true, ts=1528055004125, q=0, from=system.adapter.mihome.0, lc=1528055004125
    2018-06-03 19:43:24.745 - debug: mihome.0 data: 7811dce1e91c(gateway): {"illumination":459,"on":false,"dimmer":0,"rgb":"#000000"}
    2018-06-03 19:43:24.748 - debug: mihome.0 RAW: {"cmd":"report","model":"gateway","sid":"7811dce1e91c","short_id":0,"data":{"rgb":0,"illumination":459}}
    2018-06-03 19:43:24.772 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.illumination val=459, ack=true, ts=1528055004747, q=0, from=system.adapter.mihome.0, lc=1528055004747
    2018-06-03 19:43:24.788 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.on val=false, ack=true, ts=1528055004776, q=0, from=system.adapter.mihome.0, lc=1527794369080
    2018-06-03 19:43:24.796 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.dimmer val=0, ack=true, ts=1528055004788, q=0, from=system.adapter.mihome.0, lc=1527794369088
    2018-06-03 19:43:24.799 - silly: mihome.0 inMem message mihome.0.devices.* mihome.0.devices.gateway_7811dce1e91c.rgb val=#000000, ack=true, ts=1528055004790, q=0, from=system.adapter.mihome.0, lc=1527794369090
    2018-06-03 19:43:34.267 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"Mr2Ezh6XnPfGGZnj","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:43:44.098 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"mDKu5vOWVWtOK5Y1","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:43:54.236 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"QxJSnLEvXLHWyEpr","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:44:04.066 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"kgZczeLJI8AFSUQz","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:44:14.203 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"ssDRS8ihWfFohmlp","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:44:18.208 - debug: mihome.0 RAW: {"cmd":"report","model":"magnet","sid":"158d0002275d06","short_id":1070,"data":{"no_close":"60"}}
    2018-06-03 19:44:18.501 - debug: mihome.0 RAW: {"cmd":"report","model":"magnet","sid":"158d0002277e04","short_id":41999,"data":{"no_close":"60"}}
    2018-06-03 19:44:24.035 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"zEGxWXFrBe3SFNBH","data":{"ip":"192.168.178.123"}}
    2018-06-03 19:44:34.172 - debug: mihome.0 RAW: {"cmd":"heartbeat","model":"gateway","sid":"7811dce1e91c","short_id":"0","token":"DW1OfPBC7yg9VIkZ","data":{"ip":"192.168.178.123"}}
      Tomster
      @Bluefox, kannst du mit dem Log etwas anfangen?
      Sonst sag mir kurz Bescheid wie ich unterstützen kann…
      Tom
      • BluefoxB Offline
        BluefoxB Offline
        Aus dem Log sehe ich nur:
        Voltage und Percent sind richtig extrahiert…. Was anderes kommt nicht.
          Tomster
          Das meinte ich ja, es gibt leider kein anderes Log was ich posten könnte, da nichts ankommt. meine Türsensoren und Buttons erzeugen alle Logeinträge bei Aktion.
          Wie kann ich noch helfen? Habe 3 Cubes hier, würde dir auch einen zuschicken aber ohne den Hub oder einen geflashten Zigbee Stick wird der dir nicht viel helfen, oder doch?
          Angebot steht! Für ein paar Wochen würde ich auch auf den Hub verzichten können ;-)
          Tom
            monarchos
            Gleiches Verhalten bei mir. Cube Objekte werden unter mihome korrekt angelegt.
            Batterie und Voltage zeigen Werte. Der Rest reagiert nicht.
            Ich habe noch andere Xiaomi Sensoren, die sind alle ok.
            Ich habe bei flip90 in den Einstellungen mal "Write Allowed" aktiviert, sowie den Export nach Influx eingeschaltet und nach Tests ausgeschaltent. Danach bekam ich einmalig für flip90 ein true zurück. Das Verhalten kann ich aber leider nicht mehr reproduzieren.
              timboros
              ich hänge ebenfalls an der gleichen Stelle. Außer Batterie und Voltage wird nichts angezeigt. Mein Sonos / Echo reagiert somit auch nicht darauf.
              Hat schon einer was gefunden woran es liegt?
                Tomster
                hm, ok, schade. Hatte ich mir anders vorgestellt bzw. erhofft. Dann gehen die Dinger wohl erstmal wieder zu Ebay…
                Kurzes Feedback ob du noch was tun kannst oder nicht, nachdem Du uns schon drauf hingewiesen hast dass ohne Log hier nichts passieren wird wäre schon nett gewesen. Hast ja nun genug Leute die helfen wollen aber wenn da im Moment nichts mehr kommt ist´s ja auch gut zu wissen. Ohne Broker sind die Teile leider witzlos...
                Sollten sie denn irgendwann funktionieren,sind sie ja schnell wieder bestellt.
                Danke trotzdem, wird schon werden.
                Tom
                  Schlenz
                  Ich lege meinen mal in den Schrank und hoffe, dass es bald eine Lösung gibt.
                  Beste Grüße,
                  Schlenz
                  • R Offline
                    rnbprofi
                    Schade, meiner geht auch in den SChrank….Tee trinken.
                      timboros
                      @Tomster:
                      Tom `
                      wenn du mehr wissen willst, folge dem issue bei github. hier ist zumindest ein wenig der Grund beschrieben. Anscheinend senden die Cubes nicht mehr als Voltage und Percent, im Gegensatz zu dem alten Cube. Da kann IoB nichts machen.
                      https://github.com/ioBroker/ioBroker.mihome/issues/15#
                        Tomster
                        ich lese da auch mit.
                        bei Schimmer habe ich das hier gefunden…
                        ` > So,
                        nach langem Basteln funktioniert es jetzt (niemand weiß warum):
                        Die Magic Cubes werden quasi als 2 Sensoren im deCONZ angemeldet. Weil der iobroker-Adapter das nicht kann, habe ich von Hand (REST-Api) nachgeholfen, ich habe den 2 Sensoren versch. Namen gegeben.
                        Der iobroker-deconz-Adapter in der Version 0.2.1 funktioniert dann nicht, man nimmt wieder 0.2.0. `
                        Evtl. kann man da schauen wie es gemacht wurde, ich kenne mich da leider nicht aus, habe sie auf jeden Fall auch mal aufgehoben und hoffe dass es noch was wird.;-)
                        • N Offline
                          N Offline
                          Nobby
                          Morgen
                          soweit ich es dem Internet entnommen habe, liegt das Problem am Xiaomi Gateway.
                          Die neueren Würfel scheinen auch mit andern Smarthome System nicht zu funktionieren.
                          Habe es selber zur Zeit mit Deconz aktiv.
                          Norbert
                          Iobrocker / Sonoff /Ikea Tradfri / Xiaomi / Unifi / deconz Gateway
                            Tomster
                            Aber warum geht es dann mit Deconz? :shock:
                            • DiginixD Offline
                              DiginixD Offline
                              Diginix
                              Braucht es für den Workaround außer dem deConz Adapter noch weitere Hardware?
                              Oder kann der Adapter direkt mit dem Xiaomi Gateway auf den Aqara Cube zugreifen?
                              ..:: So long! Tom ::..
                              • N Offline
                                N Offline
                                Nobby
                                Ja, Deconz ist ein eigenes Zigbee Gateway der Fa. Dresden Elektronic.
                                Grüße Norbert
                                • BigWumpusB Offline
                                  BigWumpusB Offline
                                  BigWumpus
                                  ich habe da bei Schimmer mal alles reingeschrieben… Deconz!
                                  Pi3B ioBroker: SONOFFs Tasmota mit TasmoAdmin, Shelly2.5 Rollladen
                                  Pi2B RaspBee DeConz ZigBee: Philips&Innr&OSRAM Lampen/Stecker, Xiaomi Sensoren, Lichttaster und -Schalter
                                  Heizung: EQ-3 Max!
                                  Netz: AVM 7490, Devolo Magic 1
                                  • E Offline
                                    eve11
                                    Hallo zusammen, mit dem letzen Update 1.4.1_157 funktioniert nun der Aqara Cube.
                                    Heute getestet. Super.
                                    eve11
                                    • crunchipC Abwesend
                                      crunchipC Abwesend
                                      Update gerade gemacht, jedoch mit dem cube keinen erfolg :(
                                      muss mich korrigieren
                                      funktioniert nachdem ich ihn neu angemeldet habe.
                                      einzige was noch nicht läuft ist die Funktion "Swing"
                                      • E Offline
                                        eve11
                                        Bei funktioniert er seit dem Update. Davor nicht.
                                        mihome.0	2018-08-24 20:06:21.100	debug	data: 158d000279761f(cube): {"tap_twice":false}
                                        mihome.0	2018-08-24 20:06:20.800	debug	RAW: {"cmd":"report","model":"sensor_cube.aqgl01","sid":"158d000279761f","short_id":47885,"data":{"status":"tap_twice"}}
                                        eve11
                                          broker100
                                          @eve11:
                                          eve11 `
                                          Von welchem Update redest Du denn. Als mihome adapter habe ich dei Version 1.0.7?
