  4. [Ankündigung] Wartungsarbeiten an der cloud.pro
161 Beiträge 44 Kommentatoren 35.6k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    @CyBork:
    Moin…..mein cloud Adapter schaltet sich leider komplett aus....
    cloud.0 2018-04-15 09:48:55.933 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
    cloud.0 2018-04-15 09:37:55.048 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
    cloud.0 2018-04-15 09:32:33.100 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
    cloud.0 2018-04-15 09:30:43.081 error Cloud says: timeout
    Hmmmm.... scheinbar hab ich keine Pro Lizenz... oder wie
    lief die letzen Monate ohne Wartungsarbeiten...
    Und nun kein Connect mehr zum Cloud Adapter.
    Hab nun nochwas entdeckt.....in den Logs
    cloud.0 2018-04-15 09:48:55.936 info Connection lost
    cloud.0 2018-04-15 09:48:55.935 info Connection changed: io client disconnect
    cloud.0 2018-04-15 09:48:55.929 warn Adapter stopped. Reason: command from server
    cloud.0 2018-04-15 09:48:55.899 info Connection changed: connect
    cloud.0 2018-04-15 09:48:55.796 info Trying to connect as system.user.admin from undefined
    cloud.0 2018-04-15 09:47:55.744 info Connection lost
    cloud.0 2018-04-15 09:47:55.743 info Connection changed: io client disconnect
    cloud.0 2018-04-15 09:47:55.737 info Adapter redirected temporally to "https://iobroker.pro:10560" in one minute. Reason: command from server
    cloud.0 2018-04-15 09:47:55.691 info Connection changed: connect
    cloud.0 2018-04-15 09:47:55.660 info Trying to connect as system.user.admin from undefined
    cloud.0 2018-04-15 09:47:55.000 info Connecting with https://iobroker.pro:10555 with "@pro_(Key ausgexxxxxxxxxxxxxxxxt"
    cloud.0 2018-04-15 09:47:54.876 info starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.3
    Bin nun leider immer noch nicht schlauer wie ich mein Licht wieder an bekomme :-( `
    Schreibe bitte dein ApiKey auf info@iobroker.net. Ich werde schnellst möglich prüfen
      MarkusP
      Cloud Adapter ist nun auch bei mir auf Grün. Danke dafür :P
      • ? Offline
        bei mir auch wieder grün, danke euch
        • SeiteBallon74S Offline
          SeiteBallon74
          @BBTown:
          @SeiteBallon74:
          Ich gehe in dem Adapter Reiter auf das entsprechende Modul das ich installieren möchte und drücke das plus Symbol. Und das hast Du mit dem ioBroker Information tab Adapter entsprechend auch gemacht und unter Instanzen läuft der auch? Und ioBroker wurde von dir neu gestartet?
          Jap, schon 2 mal gemacht. Immer noch kein Info Reiter vorhanden. Und die Cloud und Sonoff sind immer noch gelb.
          • R Offline
            Ramses123
            Läuft wieder!
            [emoji106][emoji106][emoji106]
            • BluefoxB Offline
              BluefoxB Offline
              @CyBork:
              Bist du sicher, dass du Lizenz gekauft hast?
              • DutchmanD Offline
                DutchmanD Offline
                Dutchman
                Pro bei mir jetzt seit 5 Minuten wieder funktionsfähig bitte alle Mal 10 Minuten warten das sich alle connects verarbeiten können sollte jetzt nach und nach wieder klappen
                Send from mobile device
                Das schöne ios hat Auto Korrektur zum k****
                Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
                • YellowballY Offline
                  YellowballY Offline
                  Yellowball
                  @tempestas:
                  Bei mir ist alles gut - nur als info `
                  Ist aber an dieser Stelle überhaupt nicht relevant :shock:
                  ioBroker | Raspberry Pi Zero,1,2,3,4 | Proxmox | Philips HUE | AVM | Broadlink Pro| Amazon Echo Dot, Echo, Echo Show | KODI | u.v.m
                  • C Offline
                    CyBork
                    Mail ist raus.
                    • BluefoxB Offline
                      BluefoxB Offline
                      @SeiteBallon74:
                      @BBTown:
                      @SeiteBallon74:
                      Jap, schon 2 mal gemacht. Immer noch kein Info Reiter vorhanden. Und die Cloud und Sonoff sind immer noch gelb. `
                      Gibt es irgendwelche logs?
                      • ? Offline
                        #66
                        @SeiteBallon74:
                        @BBTown:
                        @SeiteBallon74:
                        Hast du auch eine Instanz zu dem Info Adapter angelegt? Screenshot wäre hilfreich…
                        Geht mit dem + Zeichen in dem Adater-Tabreiter
                        • ostseereiterO Offline
                          ostseereiter
                          #67
                          Immer noch Gelb na mal abwarten
                          cloud.0 2018-04-15 10:27:48.157 info Trying to connect as system.user.admin from undefined
                          cloud.0 2018-04-15 10:27:46.797 info Connecting with https://iobroker.pro:10555 with "@pro_
                          cloud.0 2018-04-15 10:27:46.446 info starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v4.8.0
                          host.raspberrypi_iobrocker 2018-04-15 10:27:44.032 info instance system.adapter.cloud.0 started with pid 7254
                          host.raspberrypi_iobrocker 2018-04-15 10:27:43.998 info object change system.adapter.cloud.0
                          host.raspberrypi_iobrocker 2018-04-15 10:27:31.807 info instance system.adapter.cloud.0 terminated with code 0 (OK)
                          host.raspberrypi_iobrocker 2018-04-15 10:27:31.740 info stopInstance system.adapter.cloud.0 killing pid 7242
                          host.raspberrypi_iobrocker 2018-04-15 10:27:31.737 info "system.adapter.cloud.0" disabled
                          host.raspberrypi_iobrocker 2018-04-15 10:27:31.736 info object change system.adapter.cloud.0
                          cloud.0 2018-04-15 10:27:26.582 info Connection lost
                          cloud.0 2018-04-15 10:27:26.581 info Connection changed: io client disconnect
                          cloud.0 2018-04-15 10:27:26.558 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
                          cloud.0 2018-04-15 10:27:26.542 warn Adapter stopped. Reason: command from server
                          Gruß OSR
                          Plattform
                          • BluefoxB Offline
                            BluefoxB Offline
                            #68
                            @ostseereiter:
                            Immer noch Gelb na mal abwarten `
                            Sagt Log was?
                              YellowballY Offline
                              Yellowball
                              #69
                              Hier ein Screenshot vom Log
                              Sorry. Du hast dein Key offen gezeigt. Habe ich das Bild gelöscht.
                              Vielen Dank!
                              Hab zu spät bemerkt…
                              • BBTownB Offline
                                BBTownB Offline
                                BBTown
                                #70
                                @Yellowball:
                                Bildschirmfoto 2018-04-15 um 10.25.25.pngHier ein Screenshot vom Log `
                                Mach mal deinen key unleserlich!!
                                [Edit] bluefox war schneller ;)
                                  miwe
                                  #71
                                  Hier läuft es offenbar auch wieder - Besten Dank! Tolle Arbeit!
                                    YellowballY Offline
                                    Yellowball
                                    #72
                                    Kann ich bestätigen, tut endlich wieder!
                                    Was war denn die Ursache?
                                      SeiteBallon74
                                      #73
                                      @nisio:
                                      @SeiteBallon74:
                                      @BBTown:
                                      Und das hast Du mit dem ioBroker Information tab Adapter entsprechend auch gemacht und unter Instanzen läuft der auch? Und ioBroker wurde von dir neu gestartet? `
                                      Geht mit dem + Zeichen in dem Adater-Tabreiter `
                                      Wie meinst du das mit Instanz angelegt? Ich bin wie gesagt auf das + Zeichen und habe dann installiert. Admin ist auf grün und wenn ich das Dreieck drücke dann ist nichts da. Habe Admin 3.3.9 drauf glaub ich war das. Von was denn soll ich einen Screenshot machen?
                                      Schon mal danke für die Hilfe.
                                      • BBTownB Offline
                                        BBTownB Offline
                                        BBTown
                                        #74
                                        @SeiteBallon74:
                                        Von was denn soll ich einen Screenshot machen? ` Von der Instanzübersicht
                                          AndyUM61
                                          #75
                                          Alles wieder Super!!!
                                          DANKESCHÖN!!!!
                                          Internette Grüße
                                          Andy
                                          RaspberryMatic (Raspberry Pi3), CUxD, ioBroker (Synology/ Docker)
