  4. [Ankündigung] Wartungsarbeiten an der cloud.pro
161 Beiträge 44 Kommentatoren 35.6k Aufrufe
  • R Offline
    Ramses123
    Läuft wieder!
    [emoji106][emoji106][emoji106]
    • BluefoxB Offline
      BluefoxB Offline
      @CyBork:
      Moin…..mein cloud Adapter schaltet sich leider komplett aus....
      cloud.0 2018-04-15 09:48:55.933 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
      cloud.0 2018-04-15 09:37:55.048 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
      cloud.0 2018-04-15 09:32:33.100 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
      cloud.0 2018-04-15 09:30:43.081 error Cloud says: timeout
      Hmmmm.... scheinbar hab ich keine Pro Lizenz... oder wie
      lief die letzen Monate ohne Wartungsarbeiten...
      Und nun kein Connect mehr zum Cloud Adapter.
      Hab nun nochwas entdeckt.....in den Logs
      cloud.0 2018-04-15 09:48:55.936 info Connection lost
      cloud.0 2018-04-15 09:48:55.935 info Connection changed: io client disconnect
      cloud.0 2018-04-15 09:48:55.929 warn Adapter stopped. Reason: command from server
      cloud.0 2018-04-15 09:48:55.899 info Connection changed: connect
      cloud.0 2018-04-15 09:48:55.796 info Trying to connect as system.user.admin from undefined
      cloud.0 2018-04-15 09:47:55.744 info Connection lost
      cloud.0 2018-04-15 09:47:55.743 info Connection changed: io client disconnect
      cloud.0 2018-04-15 09:47:55.737 info Adapter redirected temporally to "https://iobroker.pro:10560" in one minute. Reason: command from server
      cloud.0 2018-04-15 09:47:55.691 info Connection changed: connect
      cloud.0 2018-04-15 09:47:55.660 info Trying to connect as system.user.admin from undefined
      cloud.0 2018-04-15 09:47:55.000 info Connecting with https://iobroker.pro:10555 with "@pro_(Key ausgexxxxxxxxxxxxxxxxt"
      cloud.0 2018-04-15 09:47:54.876 info starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.3
      Bin nun leider immer noch nicht schlauer wie ich mein Licht wieder an bekomme :-( `
      Bist du sicher, dass du Lizenz gekauft hast?
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        Pro bei mir jetzt seit 5 Minuten wieder funktionsfähig bitte alle Mal 10 Minuten warten das sich alle connects verarbeiten können sollte jetzt nach und nach wieder klappen
        Send from mobile device
        Das schöne ios hat Auto Korrektur zum k****
        Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
        • YellowballY Offline
          YellowballY Offline
          Yellowball
          @tempestas:
          Bei mir ist alles gut - nur als info `
          Ist aber an dieser Stelle überhaupt nicht relevant :shock:
          ioBroker | Raspberry Pi Zero,1,2,3,4 | Proxmox | Philips HUE | AVM | Broadlink Pro| Amazon Echo Dot, Echo, Echo Show | KODI | u.v.m
          • C Offline
            CyBork
            Schreibe bitte dein ApiKey auf info@iobroker.net. Ich werde schnellst möglich prüfen
            Mail ist raus.
            • BluefoxB Offline
              BluefoxB Offline
              @SeiteBallon74:
              @BBTown:
              @SeiteBallon74:
              Ich gehe in dem Adapter Reiter auf das entsprechende Modul das ich installieren möchte und drücke das plus Symbol. Und das hast Du mit dem ioBroker Information tab Adapter entsprechend auch gemacht und unter Instanzen läuft der auch? Und ioBroker wurde von dir neu gestartet?
              Jap, schon 2 mal gemacht. Immer noch kein Info Reiter vorhanden. Und die Cloud und Sonoff sind immer noch gelb. `
              Gibt es irgendwelche logs?
              • ? Offline
                #66
                @SeiteBallon74:
                @BBTown:
                @SeiteBallon74:
                Hast du auch eine Instanz zu dem Info Adapter angelegt? Screenshot wäre hilfreich…
                Geht mit dem + Zeichen in dem Adater-Tabreiter
                • ostseereiterO Offline
                  ostseereiter
                  #67
                  Immer noch Gelb na mal abwarten
                  cloud.0 2018-04-15 10:27:48.157 info Trying to connect as system.user.admin from undefined
                  cloud.0 2018-04-15 10:27:46.797 info Connecting with https://iobroker.pro:10555 with "@pro_
                  cloud.0 2018-04-15 10:27:46.446 info starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v4.8.0
                  host.raspberrypi_iobrocker 2018-04-15 10:27:44.032 info instance system.adapter.cloud.0 started with pid 7254
                  host.raspberrypi_iobrocker 2018-04-15 10:27:43.998 info object change system.adapter.cloud.0
                  host.raspberrypi_iobrocker 2018-04-15 10:27:31.807 info instance system.adapter.cloud.0 terminated with code 0 (OK)
                  host.raspberrypi_iobrocker 2018-04-15 10:27:31.740 info stopInstance system.adapter.cloud.0 killing pid 7242
                  host.raspberrypi_iobrocker 2018-04-15 10:27:31.737 info "system.adapter.cloud.0" disabled
                  host.raspberrypi_iobrocker 2018-04-15 10:27:31.736 info object change system.adapter.cloud.0
                  cloud.0 2018-04-15 10:27:26.582 info Connection lost
                  cloud.0 2018-04-15 10:27:26.581 info Connection changed: io client disconnect
                  cloud.0 2018-04-15 10:27:26.558 error Please buy remote access to use pro. If you did it, please wait 5 minutes.
                  cloud.0 2018-04-15 10:27:26.542 warn Adapter stopped. Reason: command from server
                  Gruß OSR
                  Plattform
                  • BluefoxB Offline
                    BluefoxB Offline
                    #68
                    @ostseereiter:
                    Immer noch Gelb na mal abwarten `
                    Sagt Log was?
                      YellowballY Offline
                      Yellowball
                      #69
                      Hier ein Screenshot vom Log
                      Sorry. Du hast dein Key offen gezeigt. Habe ich das Bild gelöscht.
                      Vielen Dank!
                      Hab zu spät bemerkt…
                      • BBTownB Offline
                        BBTownB Offline
                        BBTown
                        #70
                        @Yellowball:
                        Bildschirmfoto 2018-04-15 um 10.25.25.pngHier ein Screenshot vom Log `
                        Mach mal deinen key unleserlich!!
                        [Edit] bluefox war schneller ;)
                          miwe
                          #71
                          Hier läuft es offenbar auch wieder - Besten Dank! Tolle Arbeit!
                            YellowballY Offline
                            Yellowball
                            #72
                            Kann ich bestätigen, tut endlich wieder!
                            Was war denn die Ursache?
                            • SeiteBallon74S Offline
                              SeiteBallon74
                              #73
                              @nisio:
                              @SeiteBallon74:
                              @BBTown:
                              Und das hast Du mit dem ioBroker Information tab Adapter entsprechend auch gemacht und unter Instanzen läuft der auch? Und ioBroker wurde von dir neu gestartet? `
                              Geht mit dem + Zeichen in dem Adater-Tabreiter `
                              Wie meinst du das mit Instanz angelegt? Ich bin wie gesagt auf das + Zeichen und habe dann installiert. Admin ist auf grün und wenn ich das Dreieck drücke dann ist nichts da. Habe Admin 3.3.9 drauf glaub ich war das. Von was denn soll ich einen Screenshot machen?
                              Schon mal danke für die Hilfe.
                              • BBTownB Offline
                                BBTownB Offline
                                BBTown
                                #74
                                @SeiteBallon74:
                                Von was denn soll ich einen Screenshot machen? ` Von der Instanzübersicht
                                  AndyUM61
                                  #75
                                  Alles wieder Super!!!
                                  DANKESCHÖN!!!!
                                  Internette Grüße
                                  Andy
                                  RaspberryMatic (Raspberry Pi3), CUxD, ioBroker (Synology/ Docker)
                                    ostseereiter
                                    #76
                                    Immer noch nicht
                                    Gruß OSR
                                    Plattform
                                    • DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      #77
                                      @ostseereiter:
                                      Immer noch nicht `
                                      dein cloud adapter ist ausgeschaltet der Pfeil ist rot ! bitte mal starten und dan im log shaun
                                        ostseereiter
                                        #78
                                        ich starte den ja andauernd
                                        cloud.0 2018-04-15 10:47:36.833 info Connecting with https://iobroker.pro:10555 with "@kkkkkkkkkkkkkkkkkkkkkkkk
                                        cloud.0 2018-04-15 10:47:36.414 info starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v4.8.0
                                        host.raspberrypi_iobrocker 2018-04-15 10:47:33.718 info instance system.adapter.cloud.0 started with pid 1290
                                        host.raspberrypi_iobrocker 2018-04-15 10:47:33.688 info object change system.adapter.cloud.0
                                        host.raspberrypi_iobrocker 2018-04-15 10:47:03.813 info instance system.adapter.cloud.0 terminated with code 0 (OK)
                                        host.raspberrypi_iobrocker 2018-04-15 10:47:03.759 info stopInstance system.adapter.cloud.0 killing pid 1266
                                        host.raspberrypi_iobrocker 2018-04-15 10:47:03.756 info "system.adapter.cloud.0" disabled
                                        host.raspberrypi_iobrocker 2018-04-15 10:47:03.755 info object change system.adapter.cloud.0
                                        cloud.0 2018-04-15 10:46:58.677 info Connection lost
                                        cloud.0 2018-04-15 10:46:58.677 info Connection changed: io client disconnect
                                        Gruß OSR
                                        Plattform
                                        • DutchmanD Offline
                                          DutchmanD Offline
                                          Dutchman
                                          #79
                                          @ostseereiter:
                                          ich starte den ja andauernd `
                                          lass da mal bitte sein, nur starten und dan Biobroker die Arbeit machen lassen, er wird probieren zu verbinden und wen das nicht klappt nochmal.
                                          Bitte 5 Minuten laufen lassen und dan schon was passiert das ist besser als immerzu an/aus machen….
                                          Dutch
