  4. IoBroker startet hin und wieder neu
32 Beiträge 5 Kommentatoren 552 Aufrufe 5 Beobachtet
  • F
    F
    fritzke316
    schrieb am zuletzt editiert von fritzke316
    Mein IoBroker startet in letzter Zeit hin und wieder einfach so neu, kann jemand was aus dem diag erkennen das nicht stimmt?
    ```bash
    Script v.2026-11-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Homeserver
           Icon name: computer
              Kernel: Linux 6.18.60+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 154 days ago (on 2026-06-18).
    Systemuptime and Load:
     06:55:52 up 7 min,  1 user,  load average: 2.27, 3.50, 1.95
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-11-19 06:55:52 CET
               Universal time: Thu 2026-11-19 05:55:52 UTC
                     RTC time: n/a
                    Time zone: Europe/Rome (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                web
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            8.2G        6.7G        1.1G        1.8M        447M        1.5G
    Swap:           2.1G        931M        1.2G
    Total:           10G        7.7G        2.3G
    Active iob-Instances:   30
             7818 M total memory
             6411 M used memory
             3010 M active memory
             3179 M inactive memory
             1070 M free memory
               34 M buffer memory
              392 M swap cache
             2047 M total swap
              888 M used swap
             1159 M free swap
    top - 06:55:53 up 8 min,  1 user,  load average: 2.56, 3.54, 1.97
    Tasks: 213 total,   2 running, 211 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 83.7 us,  6.1 sy,  0.0 ni,  6.1 id,  0.0 wa,  0.0 hi,  4.1 si,  0.0 st
    MiB Mem :   7818.6 total,   1070.7 free,   6411.2 used,    426.6 buff/cache
    MiB Swap:   2048.0 total,   1159.9 free,    888.1 used.   1407.4 avail Mem
    *** FAILED SERVICES ***
      UNIT                LOAD   ACTIVE SUB    DESCRIPTION
    * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     1.6G  9.1M  1.6G   1% /run
    /dev/sda2      ext4      110G  9.9G   96G  10% /
    tmpfs          tmpfs     3.9G  104K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/sda1      vfat      505M   67M  438M  14% /boot/firmware
    tmpfs          tmpfs     3.9G  432K  3.9G   1% /tmp
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
    Messages concerning filesystems in dmesg (Last 15 lines only):
    [Thu Nov 19 06:47:57 2026] EXT4-fs (sda2): mounted filesystem 15f4c6be-1102-4331-9904-f78e78afd1fd ro with ordered data mode. Quota mode: none.
    [Thu Nov 19 06:48:00 2026] EXT4-fs (sda2): re-mounted 15f4c6be-1102-4331-9904-f78e78afd1fd r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.0G    /var/
    809M    /var/cache
    786M    /var/cache/apt
    653M    /var/cache/apt/archives
    197M    /var/lib
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    786M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    783M    /opt/iobroker/iobroker-data/
    383M    /opt/iobroker/iobroker-data/files
    253M    /opt/iobroker/iobroker-data/backup-objects
    63M     /opt/iobroker/iobroker-data/files/aura
    61M     /opt/iobroker/iobroker-data/files/aura/assets
    90M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    11M     /opt/iobroker/iobroker-data/files/devices.admin/assets/index-h2WSMjGw.js
    11M     /opt/iobroker/iobroker-data/backup-objects/2026-11-19_04-35_objects.jsonl.gz
    11M     /opt/iobroker/iobroker-data/backup-objects/2026-11-19_02-35_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.22.3
    /usr/bin/node           v24.22.3
    /usr/bin/npm            11.19.1
    /usr/bin/npx            11.19.1
    ✓ Node.js installation is correct
    Recommended versions are nodejs 24.22.3 and npm 11.19.1
    nodejs:
      Installed: 24.22.3-1nodesource1
      Candidate: 24.22.3-1nodesource1
      Version table:
     *** 24.22.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
         24.22.2-1nodesource1 1001
         24.22.1-1nodesource1 1001
         24.22.0-1nodesource1 1001
         24.21.0-1nodesource1 1001
         24.20.0-1nodesource1 1001
         24.19.0-1nodesource1 1001
         24.18.1-1nodesource1 1001
         24.18.0-1nodesource1 1001
         24.17.0-1nodesource1 1001
         24.16.0-1nodesource1 1001
         24.15.0-1nodesource1 1001
         24.14.1-1nodesource1 1001
         24.14.0-1nodesource1 1001
         24.13.1-1nodesource1 1001
         24.13.0-1nodesource1 1001
         24.12.0-1nodesource1 1001
         24.11.1-1nodesource1 1001
         24.11.0-1nodesource1 1001
         24.10.0-1nodesource1 1001
         24.9.0-1nodesource1 1001
         24.8.0-1nodesource1 1001
         24.7.0-1nodesource1 1001
         24.6.0-1nodesource1 1001
         24.5.0-1nodesource1 1001
         24.4.1-1nodesource1 1001
         24.4.0-1nodesource1 1001
         24.3.0-1nodesource1 1001
         24.1.0-1nodesource1 1001
         24.0.2-1nodesource1 1001
         24.0.1-1nodesource1 1001
         24.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u3 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Homeserver          Homeserver (version: 7.2.5, hostname: Homeserver    , alive, uptime: 483)
    Core adapters versions
    js-controller:  7.2.5
    admin:          8.3.5
    javascript:     10.4.4
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Homeserver                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alarm.0                  : alarm                 : Homeserver                               -  enabled
      system.adapter.alias-manager.0          : alias-manager         : Homeserver                               - disabled
    + system.adapter.aura.0                   : aura                  : Homeserver                               -  enabled, port: 8095
    + system.adapter.backitup.0               : backitup              : Homeserver                               -  enabled
    + system.adapter.devices.0                : devices               : Homeserver                               -  enabled
    + system.adapter.discovery.0              : discovery             : Homeserver                               -  enabled
    + system.adapter.echarts.0                : echarts               : Homeserver                               -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Homeserver                               -  enabled
    + system.adapter.history.0                : history               : Homeserver                               -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : Homeserver                               - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : Homeserver                               - disabled
    + system.adapter.javascript.0             : javascript            : Homeserver                               -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Homeserver                               -  enabled, port: 1884, bind: 192.168.10.14
    + system.adapter.myuplink.0               : myuplink              : Homeserver                               -  enabled
    + system.adapter.nut.0                    : nut                   : Homeserver                               -  enabled
    + system.adapter.open-meteo-weather.0     : open-meteo-weather    : Homeserver                               -  enabled
    + system.adapter.openknx.0                : openknx               : Homeserver                               -  enabled, bind: 192.168.10.14
    + system.adapter.pushover.0               : pushover              : Homeserver                               -  enabled
    + system.adapter.pushover.1               : pushover              : Homeserver                               -  enabled
    + system.adapter.scenes.0                 : scenes                : Homeserver                               -  enabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : Homeserver                               -  enabled
    + system.adapter.socketio.0               : socketio              : Homeserver                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : Homeserver                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : Homeserver                               -  enabled
    + system.adapter.sprinklecontrol.0        : sprinklecontrol       : Homeserver                               -  enabled
    + system.adapter.telegram-menu.0          : telegram-menu         : Homeserver                               -  enabled
    + system.adapter.telegram.0               : telegram              : Homeserver                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Homeserver                               -  enabled
      system.adapter.vis-2.0                  : vis-2                 : Homeserver                               - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : Homeserver                               - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : Homeserver                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Homeserver                               - disabled
      system.adapter.vis.0                    : vis                   : Homeserver                               -  enabled
    + system.adapter.web.0                    : web                   : Homeserver                               -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : Homeserver                               -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.xsense.0                 : xsense                : Homeserver                               -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                  │ name                 │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '8.3.5'  │ 'none'         │
    │ 1       │ 'system.adapter.alarm'              │ 'alarm'              │ '5.1.2'  │ 'none'         │
    │ 2       │ 'system.adapter.alias-manager'      │ 'alias-manager'      │ '3.0.0'  │ 'none'         │
    │ 3       │ 'system.adapter.aura'               │ 'aura'               │ '1.0.2'  │ 'none'         │
    │ 4       │ 'system.adapter.backitup'           │ 'backitup'           │ '4.0.3'  │ 'none'         │
    │ 5       │ 'system.adapter.devices'            │ 'devices'            │ '4.2.2'  │ 'none'         │
    │ 6       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.2.0'  │ 'none'         │
    │ 7       │ 'system.adapter.echarts'            │ 'echarts'            │ '6.3.0'  │ 'none'         │
    │ 8       │ 'system.adapter.fb-checkpresence'   │ 'fb-checkpresence'   │ '1.5.0'  │ 'none'         │
    │ 9       │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0' │ 'none'         │
    │ 10      │ 'system.adapter.history'            │ 'history'            │ '5.1.1'  │ 'none'         │
    │ 11      │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0'  │ 'none'         │
    │ 12      │ 'system.adapter.icons-mfd-png'      │ 'icons-mfd-png'      │ '1.2.1'  │ 'none'         │
    │ 13      │ 'system.adapter.javascript'         │ 'javascript'         │ '10.4.4' │ 'none'         │
    │ 14      │ 'system.adapter.mqtt'               │ 'mqtt'               │ '8.1.2'  │ 'none'         │
    │ 15      │ 'system.adapter.myuplink'           │ 'myuplink'           │ '0.8.6'  │ 'none'         │
    │ 16      │ 'system.adapter.nut'                │ 'nut'                │ '1.7.0'  │ 'none'         │
    │ 17      │ 'system.adapter.open-meteo-weather' │ 'open-meteo-weather' │ '3.3.2'  │ 'none'         │
    │ 18      │ 'system.adapter.openknx'            │ 'openknx'            │ '1.2.0'  │ 'none'         │
    │ 19      │ 'system.adapter.pushover'           │ 'pushover'           │ '6.1.0'  │ 'none'         │
    │ 20      │ 'system.adapter.scenes'             │ 'scenes'             │ '5.1.0'  │ 'none'         │
    │ 21      │ 'system.adapter.shuttercontrol'     │ 'shuttercontrol'     │ '2.1.2'  │ 'none'         │
    │ 22      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '2.8.0'  │ 'none'         │
    │ 23      │ 'system.adapter.socketio'           │ 'socketio'           │ '9.0.2'  │ 'none'         │
    │ 24      │ 'system.adapter.sonoff'             │ 'sonoff'             │ '5.1.1'  │ 'none'         │
    │ 25      │ 'system.adapter.sourceanalytix'     │ 'sourceanalytix'     │ '0.7.1'  │ 'none'         │
    │ 26      │ 'system.adapter.sprinklecontrol'    │ 'sprinklecontrol'    │ '1.0.11' │ 'none'         │
    │ 27      │ 'system.adapter.telegram'           │ 'telegram'           │ '6.0.2'  │ 'none'         │
    │ 28      │ 'system.adapter.telegram-menu'      │ 'telegram-menu'      │ '4.2.3'  │ 'none'         │
    │ 29      │ 'system.adapter.tr-064'             │ 'tr-064'             │ '4.3.0'  │ 'none'         │
    │ 30      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'  │ 'none'         │
    │ 31      │ 'system.adapter.vis-2'              │ 'vis-2'              │ '2.20.8' │ 'none'         │
    │ 32      │ 'system.adapter.vis-colorpicker'    │ 'vis-colorpicker'    │ '2.1.0'  │ 'none'         │
    │ 33      │ 'system.adapter.vis-icontwo'        │ 'vis-icontwo'        │ '2.11.6' │ 'none'         │
    │ 34      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'  │ 'none'         │
    │ 35      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'  │ 'none'         │
    │ 36      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'  │ 'none'         │
    │ 37      │ 'system.adapter.xsense'             │ 'xsense'             │ '0.6.5'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Adapter    "admin"        : 8.3.5    , installed 8.3.5
    Adapter    "alarm"        : 5.1.2    , installed 5.1.2
    Adapter    "alias-manager": 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 4.0.3    , installed 4.0.3
    Adapter    "devices"      : 4.2.2    , installed 4.2.2
    Adapter    "discovery"    : 5.2.0    , installed 5.2.0
    Adapter    "echarts"      : 6.3.0    , installed 6.3.0
    Adapter    "fb-checkpresence": 1.5.0 , installed 1.5.0
    Adapter    "history"      : 5.1.1    , installed 5.1.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 10.4.4   , installed 10.4.4
    Controller "js-controller": 7.2.5    , installed 7.2.5
    Adapter    "mqtt"         : 8.1.2    , installed 8.1.2
    Adapter    "myuplink"     : 0.8.6    , installed 0.8.6
    Adapter    "nut"          : 1.7.0    , installed 1.7.0
    Adapter    "open-meteo-weather": 3.3.2, installed 3.3.2
    Adapter    "openknx"      : 1.2.0    , installed 1.2.0
    Adapter    "pushover"     : 6.1.0    , installed 6.1.0
    Adapter    "scenes"       : 5.1.0    , installed 5.1.0
    Adapter    "shuttercontrol": 2.1.2   , installed 2.1.2
    Adapter    "socketio"     : 9.0.2    , installed 9.0.2
    Adapter    "sonoff"       : 5.1.1    , installed 5.1.1
    Adapter    "sprinklecontrol": 1.0.11 , installed 1.0.11
    Adapter    "telegram"     : 6.0.2    , installed 6.0.2
    Adapter    "telegram-menu": 4.2.3    , installed 4.2.3
    Adapter    "vis-2"        : 2.20.8   , installed 2.20.8
    Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
    Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "xsense"       : 0.6.1    , installed 0.6.5
    Objects and States
    Objects:        13146
    States:         12435
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
    Get:6 https://pkgs.tailscale.com/stable/debian trixie InRelease
    Hit:7 https://repo.45drives.com/debian focal InRelease
    Fetched 6650 B in 1s (10.8 kB/s)
    Reading package lists...
    Pending systemupdates: 1
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q                          Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                                     0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=612,fd=5),("systemd",pid=1,fd=190))
    udp   UNCONN 0      0                                     0.0.0.0:41641              0.0.0.0:*    users:(("tailscaled",pid=968,fd=17))
    udp   UNCONN 0      0                                     0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=652,fd=12))
    udp   UNCONN 0      0                               192.168.10.14:47425              0.0.0.0:*    users:(("io.openknx.0",pid=1910,fd=35))
    udp   UNCONN 0      0                                     0.0.0.0:39520              0.0.0.0:*    users:(("avahi-daemon",pid=652,fd=14))
    udp   UNCONN 0      0                                           *:sunrpc                   *:*    users:(("rpcbind",pid=612,fd=7),("systemd",pid=1,fd=192))
    udp   UNCONN 0      0                 [fe80::aa0b:ec83:78bd:893b]:dhcpv6-client            *:*    users:(("NetworkManager",pid=735,fd=28))
    udp   UNCONN 0      0                                           *:41641                    *:*    users:(("tailscaled",pid=968,fd=19))
    udp   UNCONN 0      0                                           *:mdns                     *:*    users:(("avahi-daemon",pid=652,fd=13))
    udp   UNCONN 0      0                                           *:59879                    *:*    users:(("avahi-daemon",pid=652,fd=15))
    tcp   LISTEN 0      4096                                  0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=612,fd=4),("systemd",pid=1,fd=189))
    tcp   LISTEN 0      128                                   0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=987,fd=6))
    tcp   LISTEN 0      4096                 100.88.73.102%tailscale0:38459              0.0.0.0:*    users:(("tailscaled",pid=968,fd=25))
    tcp   LISTEN 0      511                             192.168.10.14:1884               0.0.0.0:*    users:(("io.mqtt.0",pid=1738,fd=35))
    tcp   LISTEN 0      16                                  127.0.0.1:nut                0.0.0.0:*    users:(("upsd",pid=1062,fd=4))
    tcp   LISTEN 0      511                                   0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=1964,fd=36))
    tcp   LISTEN 0      511                                 127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=964,fd=23))
    tcp   LISTEN 0      511                                 127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=964,fd=29))
    tcp   LISTEN 0      2048                                  0.0.0.0:8096               0.0.0.0:*    users:(("gunicorn",pid=1061,fd=3),("gunicorn",pid=1056,fd=3),("gunicorn",pid=1050,fd=3),("gunicorn",pid=965,fd=3))
    tcp   LISTEN 0      4096                                     [::]:sunrpc                [::]:*    users:(("rpcbind",pid=612,fd=6),("systemd",pid=1,fd=191))
    tcp   LISTEN 0      4096   [fd7a:115c:a1e0::6d3a:4967]%tailscale0:47587                 [::]:*    users:(("tailscaled",pid=968,fd=29))
    tcp   LISTEN 0      128                                      [::]:ssh                   [::]:*    users:(("sshd",pid=987,fd=7))
    tcp   LISTEN 0      4096                                        *:9090                     *:*    users:(("cockpit-tls",pid=1395,fd=3),("systemd",pid=1,fd=171))
    tcp   LISTEN 0      511                                         *:8082                     *:*    users:(("io.web.0",pid=2194,fd=35))
    tcp   LISTEN 0      511                                         *:tproxy                   *:*    users:(("io.admin.0",pid=1419,fd=36))
    tcp   LISTEN 0      511                                         *:8084                     *:*    users:(("io.socketio.0",pid=2139,fd=34))
    tcp   LISTEN 0      511                                         *:8089                     *:*    users:(("io.web.1",pid=2205,fd=35))
    tcp   LISTEN 0      511                                         *:8095                     *:*    users:(("io.aura.0",pid=1991,fd=30))
    2026-11-19 06:53:57.660  - info: sourceanalytix.0 (2057) Initialising "alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Heizung.PRODUCTION" | (23 of 24)
    2026-11-19 06:53:58.204  - info: sourceanalytix.0 (2057) Initialization of alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Heizung.PRODUCTION successfully
    2026-11-19 06:53:58.205  - info: sourceanalytix.0 (2057) Initialising "alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Wasser.PRODUCTION" | (24 of 24)
    2026-11-19 06:53:58.795  - info: sourceanalytix.0 (2057) Initialization of alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Wasser.PRODUCTION successfully
    2026-11-19 06:53:58.896  - info: sourceanalytix.0 (2057) Successfully activated SourceAnalytix for all 24 of 24 states, will do my Job until you stop me!
    2026-11-19 06:54:14.517  - info: web.1 (2205) ==> Connected system.user.admin from ::ffff:127.0.0.1
    2026-11-19 06:54:15.622  - info: javascript.0 (1554) script.js.Benachrichtigungen.MessageStateCreator: [MessageStateCreator] postMessage('TEMPERATURE_INFO', '🌐 2,4 °C 🏠 14,8 °C', 0)
    2026-11-19 06:55:00.050  - info: javascript.0 (1554) script.js.Wetter_Widget: Weather widget: HTML successfully generated.
    2026-11-19 06:55:12.605  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] connected with secret 1795067712603_4753
    2026-11-19 06:55:12.642  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] subscribes on "mqtt.0.Wasseruhr.Warmwasser_Wohnung_Keller.ctrl.flow_start"
    2026-11-19 06:55:12.659  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] subscribes on "mqtt.0.Wasseruhr.Warmwasser_Wohnung_Keller.ctrl.set_prevalue"
    2026-11-19 06:55:12.843  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] publishOnSubscribe
    2026-11-19 06:55:12.860  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] publishOnSubscribe
    2026-11-19 06:55:36.092  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] connected with secret 1795067736082_175
    2026-11-19 06:55:46.393  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.flow_start"
    2026-11-19 06:55:46.594  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
    2026-11-19 06:55:47.891  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.set_prevalue"
    2026-11-19 06:55:47.892  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.flow_start"
    2026-11-19 06:55:47.893  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.flow_start"
    2026-11-19 06:55:48.091  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
    2026-11-19 06:55:48.092  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
    2026-11-19 06:55:48.093  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
    2026-11-19 06:55:48.094  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
    2026-11-19 06:56:52.651  - info: javascript.0 (1554) script.js.Benachrichtigungen.MessageStateCreator: [MessageStateCreator] postMessage('TEMPERATURE_INFO', '🌐 2,4 °C 🏠 14,9 °C', 0)
    ============= Mark until here for C&P =============
    iob diag has finished.
    • F fritzke316
      ```bash
      Script v.2026-11-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                web
      *** MEMORY ***
               7818 M total memory
               6411 M used memory
               1070 M free memory
                 34 M buffer memory
                392 M swap cache
               2047 M total swap
                888 M used swap
               1159 M free swap
      *** FILESYSTEM ***
      /var:
      3.0G    /var/
      809M    /var/cache
      786M    /var/cache/apt
      197M    /var/lib
      USB-Devices by-id:
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          8.3.5
      javascript:     10.4.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        13146
      States:         12435
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @fritzke316 sagte:
      Was ist das für eine Quelle? Das ist nominell für das bereits abgekündigte Ubuntu 20.04 'Focal Fossa'.
      Und was ist mit dem nut-monitor los?
      • nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
      Meine KI analysiert:
      Die auffälligsten Punkte
      Pi war zum Diag-Zeitpunkt erst 7 Minuten oben (Boot 06:47, diag 06:55). Erste Rückfrage an den OP: Startet wirklich nur ioBroker neu, oder bootet die ganze Kiste? Das unterscheidet OOM-Kill von Neustart-Ursachen wie Watchdog/Netz/USB. Klären per
      journalctl --list-boots
      und
      last -x reboot shutdown
      RAM ist der Hauptverdächtige. 30 aktive Instanzen auf einem Pi 4 mit 8 GB, 7 Minuten nach dem Boot sind schon 6,7 GB belegt und ~900 MB Swap in Benutzung. Das ist massiver Druck, und der OOM-Killer, der den js-Controller-Host-Prozess abschießt, sieht exakt so aus wie „ioBroker startet neu". Das dmesg der Diagnose zeigt nichts, weil es nach dem Reboot leer ist, die Spuren liegen im vorherigen Boot:
      journalctl -k -b -1 | grep -iE 'oom|out of memory|killed process'
      nut-monitor.service ist failed. Die Beschreibung der Unit ist wörtlich „shutdown controller" ein fehlgeschlagener NUT ist Harmlos wenn keine USV hängt, aber falls doch eine USV dran ist, kann upsmon bei Kommunikationsproblemen ("on battery") eigenmächtig Shutdowns auslösen:
      journalctl -b -1 | grep -iE 'upsmon|nut'
      zeigt es.
      Kein Throttling zumindest in diesem Boot, also keine Undervoltage-Brownouts. Aber das gilt nur für die aktuelle Session.
      Root liegt auf einer 110-GB-SSD an USB (sda2, nicht SD). Wenn die Reboots mit IO-Hänger korrelieren, lohnt der Blick auf USB-Reset- und EXT4-Meldungen im vorherigen Boot.
      • F
        F
        fritzke316
        Danke für die schnelle Antwort, auch wenn ich nicht alles verstanden habe :))
        Ja ich habe eine USV (Legrand Nikky) mit USB an meinem Pi verbunden, die musste ich schon öffters mal aus und wieder anstecken damit sie wieder erkannt wurde, muss ich mal schaun.
        das 45drives ist glaube ich ein Addon zur Cockpit Oberfläche, und zwar ein File Browser. Habe Cockpit installiert um schnell und einfach ein Terminal zu haben und Updates zu machen, weis aber nicht ob das ideal ist.
        Zum Speicher, ich habe bemerkt dass der in letzter zeit ziemlich an der Grenze ist, vorallem wenn ich mal das Repo aktualisieren wollte, da waren die 8GB + 2GB Swap aufgebraucht und der browser ist eingefrohren. Das ist aber erst so seit den letzten Node JS, und Admin Updates seit dem ist die Kiste Speicher hungrig. Ja klar habe ich erst vor kurzem den Aura Adapter und eine 2te Web Instanz installiert.
        Was kann ich jetz am besten machen?
        • F fritzke316
          Thomas BraunT
          Thomas BraunT
          @fritzke316 sagte:
          Nö. Dafür ist es unnötger Killefit.
          Mehr RAM verfügbar machen. Unnötigen Killefit rauswerfen und schauen welche Dienste da rausgeworfen werden. LogLevel reduzieren, nicht jeden Mumpitz im 2 Sekundentakt historisieren usw.
          Edith: Ich hab die Befehle zur weiteren Diagnose oben gekennzeichnet. Gib die mal ein.
          • F
            F
            fritzke316
            Habe die Befehle mal eingegeben mit folgendem Ergebniss.
            Leider nur Screenshot konnte vom Handy nicht kopieren
            BluefoxB 1 Antwort Letzte Antwort
            • F
              F
              fritzke316
              Habe den Pi gerade wegen Update nochmal neugestartet und jetz liegt der aktuelle RAM verbrauch bei 4,4GB nach 15 Minuten Betriebszeit, vordem Neustart waren es 6,8GB wobei alleine der JSController ca. 4,3GB verbrauchte. Ist das normal??
              • F fritzke316
                Thomas BraunT
                Thomas BraunT
                @fritzke316
                Auf meinem System nicht. Aber da ist ja auch jedes Setup anders.
                Das du da kein persistentes Journal hast ist aber auch nicht normal. Außer dass Cockpit-Ding dreht dir an der Stelle dein System auf Links.
                • F
                  F
                  fritzke316
                  Ja keine Ahnung warum ich das Journal nicht habe, kann schon sein dass Cockpit da was macht. Wenn die Probleme weiter bestehen werde ich nochmal neu installieren und Cockpit weglassen. Habs eigentlich nur installiert damit auch mit dem Handy in ein Terminal kann, hab nichts Besseres gefunden :(
                  • F fritzke316
                    Thomas BraunT
                    Thomas BraunT
                    @fritzke316 sagte:
                    ??? Du fährst auch mit einem 40-Tonnner zum Bäcker um die Ecke, oder?
                    sshd bei der Installation aktivieren und auf dein Handy ein kleines Terminalprogramm. Auf meinen Android bin ich mittlerweile bei 'Termius' angekommen.
                    • F
                      F
                      fritzke316
                      Nicht dass ich nicht einige SSH Apps probiert habe, aber die haben mir alle nicht gefallen, entweder umständlich zu bedienen, oder kostenpflichtig usw.
                      Ich werde Termius mal probieren, danke für den Tipp.
                      • F fritzke316
                        @fritzke316 Das Journal wird bei dir nur im RAM gehalten und ist nach jedem Neustart weg. Deshalb sieht man nicht, was vorher passiert ist. Schalte das dauerhafte Speichern ein:
                        sudo mkdir -p /var/log/journal
                        sudo systemd-tmpfiles --create --prefix /var/log/journal
                        sudo systemctl restart systemd-journald
                        Wenn es danach wieder passiert, zeigt das hier das Ende vom vorherigen Boot:
                        sudo journalctl -b -1 -n 150 --no-pager
                        Zum diag: Um 06:55 lief der Pi erst seit 7 Minuten. Hast du da selbst neu gestartet? Wenn nicht, ist der ganze Pi neu gestartet und nicht nur ioBroker. Bei vollem Speicher beendet der Kernel (OOM-Killer) einzelne Prozesse, aber er startet nicht den ganzen Pi neu.
                        Darum habe ich die USV im Verdacht. Sie ist per USB angeschlossen, der nut-monitor ist failed und du musst sie öfter neu einstecken. Wenn upsmon meint, die USV sei auf Batterie oder leer, fährt es den Pi herunter. Schick mal:
                        systemctl status nut-monitor nut-driver --no-pager
                        cat /etc/nut/upsmon.conf | grep -v "^#" | grep -v "^$"
                        Bis dahin hilft das ioBroker-Log, das liegt auf der SSD:
                        grep -B 30 "js-controller starting" /opt/iobroker/log/iobroker.2026-11-19.log
                        Steht vor dem Start ein sauberes "terminating" der Instanzen, wurde ordentlich heruntergefahren. Bricht das Log einfach ab, war es ein harter Absturz oder der Strom war weg.
                        Unabhängig davon ist der RAM zu voll. Damit wir sehen, wer ihn frisst:
                        ps aux --sort=-rss | head -n 15
                        Cockpit mit dem 45drives-Repo brauchst du für ioBroker nicht. Ein SSH-Client wie PuTTY oder das Terminal im Windows/Mac reicht.
                        • F
                          F
                          fritzke316
                          Erstmal Danke euch für die Hilfe
                          @bluefox Habe das journal jetzt eingerichtet :)
                          Hier die Ausgaben der USV, da muss ich wohl noch was einrichten.
                          pi@Homeserver:~ $ systemctl status nut-monitor nut-driver --no-pager -l
                          × nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
                               Loaded: loaded (/usr/lib/systemd/system/nut-monitor.service; enabled; preset: enabled)
                               Active: failed (Result: exit-code) since Thu 2026-11-19 19:05:39 CET; 11h ago
                             Duration: 36ms
                           Invocation: eed184ccd15e4c29a3e56282fa4827aa
                              Process: 1137 ExecStartPre=/usr/bin/systemd-tmpfiles --create /usr/lib/tmpfiles.d/nut-common-tmpfiles.conf (code=exited, status=0/SUCCESS)
                              Process: 1139 ExecStart=/usr/sbin/upsmon -F (code=exited, status=1/FAILURE)
                             Main PID: 1139 (code=exited, status=1/FAILURE)
                          Nov 19 19:05:39 Homeserver systemd[1]: nut-monitor.service: Scheduled restart job, restart counter is at 5.
                          Nov 19 19:05:39 Homeserver systemd[1]: nut-monitor.service: Start request repeated too quickly.
                          Nov 19 19:05:39 Homeserver systemd[1]: nut-monitor.service: Failed with result 'exit-code'.
                          Nov 19 19:05:39 Homeserver systemd[1]: Failed to start nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller.
                          Unit nut-driver.service could not be found.
                          pi@Homeserver:~ $ cat /etc/nut/upsmon.conf | grep -v "^#" | grep -v "^$"
                          cat: /etc/nut/upsmon.conf: Permission denied
                          Und das Log vom 19.11.26
                          iobroker.2026-11-19.log.htm
                          Die Liste mit dem RAM verbrauch. Der sieht aktuell gut aus werde ich aber weiter verfolgen.
                          Habe jetz auch mal das script der Wetter Widgets deaktiviert da die häufig aktualisieren.
                          pi@Homeserver:~ $ ps aux --sort=-rss | head -n 15
                          USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
                          iobroker     960 11.4 17.5 3153232 1401904 ?     Ssl  Nov19  79:25 iobroker.js-controller
                          iobroker    1250  0.3  6.5 10595492 526892 ?     Sl   Nov19   2:06 io.admin.0
                          iobroker    1274  1.7  4.2 1954284 336292 ?      Sl   Nov19  12:12 io.javascript.0
                          iobroker    1718  0.1  2.4 1889252 195488 ?      Sl   Nov19   0:50 io.web.0
                          iobroker    1745  0.2  2.4 1821268 192484 ?      Sl   Nov19   1:27 io.web.1
                          iobroker    1499  0.3  2.3 10186836 189136 ?     Sl   Nov19   2:10 io.sonoff.0
                          iobroker    1753  0.3  2.2 1407524 181772 ?      Sl   Nov19   2:04 io.aura.0
                          iobroker    1520  0.0  2.2 1403892 179800 ?      Sl   Nov19   0:40 io.sprinklecontrol.0
                          iobroker    2708  0.2  2.1 10247368 174680 ?     Sl   04:00   0:27 io.telegram.0
                          iobroker    1532  0.4  2.1 1857572 168948 ?      Sl   Nov19   3:17 io.tr-064.0
                          iobroker    1628  0.1  1.9 1855964 158836 ?      Sl   Nov19   1:10 io.open-meteo-weather.0
                          iobroker    1386  0.1  1.9 1791600 158416 ?      Sl   Nov19   0:45 io.backitup.0
                          iobroker    1407  0.1  1.9 1727692 158288 ?      Sl   Nov19   0:54 io.mqtt.0
                          iobroker    1600  0.1  1.9 1377300 156300 ?      Sl   Nov19   0:41 io.echarts.0
                          • F
                            F
                            fritzke316
                            Jetzt gerade als ich den vorherigen Kommentar geschrieben habe ist der Pi wieder abgestürzt, kann es sein dass das Herunterladen des Repository der Auslöser ist, habe festgestellt dass das viel RAM verbraucht und genau danach ist er abgestürzt?
                            iobroker.2026-11-20.htm
                            • F fritzke316
                              Thomas BraunT
                              Thomas BraunT
                              @fritzke316
                              Deswegen sollst du ja auch den ganzen Klimmbimm ausschalten bzw. deinstallieren.
                              • F
                                F
                                fritzke316
                                Ja aber was hat das iOBroker Repository mit dem "Klimmbimm" zu tun? So viel Speicher wird durch das Deinstallieren von Cockpit auch nicht frei werden.
                                Habe beobachtet, dass beim Update des Repository (stabel oder beta) die 8GB RAM + 2GB Swap voll ausgelastet sind, ob das normal ist, oder ob das von Cockpit kommt kann ich nicht sagen.
                                • Michael SchmittM
                                  Michael SchmittM
                                  Michael Schmitt
                                  schrieb am zuletzt editiert von Michael Schmitt
                                  nimm die beta mal raus wenn du sie nicht brauchst
                                  F 1 Antwort Letzte Antwort
                                  • Michael SchmittM Michael Schmitt
                                    F
                                    F
                                    fritzke316
                                    @Michael-Schmitt sagte:
                                    ist da nicht eh immer nur eine aktiv?
                                    • Michael SchmittM
                                      Michael SchmittM
                                      Michael Schmitt
                                      aber es werden beide heruntergeladen
                                      • F
                                        F
                                        fritzke316
                                        @michael-schmitt
                                        kann man das einstellen, das die Beta nicht mit aktualisiert wird, oder müsste ich die komplett aus der Liste der Repositories nehmen?
                                        Würde es helfen SWAP auf 4GB oder mehr zu erhöhen?
                                        Marc BergM BluefoxB 2 Antworten Letzte Antwort
                                        • F fritzke316
                                          @michael-schmitt
                                          Marc BergM
                                          Marc BergM
                                          Marc Berg
                                          schrieb zuletzt editiert von
                                          @fritzke316 sagte:
                                          Unter "System-->Repositories" das Beta Repo über den Papierkorb löschen.
                                          Pi-hole, Traefik, Checkmk, Conbee II+Zigbee2MQTT, LoRaWAN
                                          33.2k
                                          84.3k
