<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IoBroker startet hin und wieder neu]]></title><description><![CDATA[<p dir="auto">Mein IoBroker startet in letzter Zeit hin und wieder einfach so neu, kann jemand was aus dem diag erkennen das nicht stimmt?</p>
<pre><code>
```bash
Script v.2026-11-09
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
 Static hostname: Homeserver
       Icon name: computer
          Kernel: Linux 6.18.60+rpt-rpi-v8
    Architecture: arm64
OS is similar to:
Model           : Raspberry Pi 4 Model B Rev 1.4
Docker          : false
Virtualization  : none
Unknown
Kernel          : aarch64
Userland        : 64bit
System was installed 154 days ago (on 2026-06-18).
Systemuptime and Load:
 06:55:52 up 7 min,  1 user,  load average: 2.27, 3.50, 1.95
CPU threads     : 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
               Local time: Thu 2026-11-19 06:55:52 CET
           Universal time: Thu 2026-11-19 05:55:52 UTC
                 RTC time: n/a
                Time zone: Europe/Rome (CET, +0100)
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
pi
HOME=/home/pi
GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
iobroker
HOME=/home/iobroker
*** DISPLAY-SERVER SETUP ***
Display-Server:         Unknown
Display-Manager:        Not found
Desktop:
Session:                web
Boot Target:            multi-user.target
*** MEMORY ***
Mem:            8.2G        6.7G        1.1G        1.8M        447M        1.5G
Swap:           2.1G        931M        1.2G
Total:           10G        7.7G        2.3G
Active iob-Instances:   30
         7818 M total memory
         6411 M used memory
         3010 M active memory
         3179 M inactive memory
         1070 M free memory
           34 M buffer memory
          392 M swap cache
         2047 M total swap
          888 M used swap
         1159 M free swap
top - 06:55:53 up 8 min,  1 user,  load average: 2.56, 3.54, 1.97
Tasks: 213 total,   2 running, 211 sleeping,   0 stopped,   0 zombie
%Cpu(s): 83.7 us,  6.1 sy,  0.0 ni,  6.1 id,  0.0 wa,  0.0 hi,  4.1 si,  0.0 st
MiB Mem :   7818.6 total,   1070.7 free,   6411.2 used,    426.6 buff/cache
MiB Swap:   2048.0 total,   1159.9 free,    888.1 used.   1407.4 avail Mem
*** FAILED SERVICES ***
  UNIT                LOAD   ACTIVE SUB    DESCRIPTION
* nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
Legend: LOAD   -&gt; Reflects whether the unit definition was properly loaded.
        ACTIVE -&gt; The high-level unit activation state, i.e. generalization of SUB.
        SUB    -&gt; The low-level unit activation state, values depend on unit type.
1 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  3.6G     0  3.6G   0% /dev
tmpfs          tmpfs     1.6G  9.1M  1.6G   1% /run
/dev/sda2      ext4      110G  9.9G   96G  10% /
tmpfs          tmpfs     3.9G  104K  3.9G   1% /dev/shm
tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
/dev/sda1      vfat      505M   67M  438M  14% /boot/firmware
tmpfs          tmpfs     3.9G  432K  3.9G   1% /tmp
tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
Messages concerning filesystems in dmesg (Last 15 lines only):
[Thu Nov 19 06:47:57 2026] EXT4-fs (sda2): mounted filesystem 15f4c6be-1102-4331-9904-f78e78afd1fd ro with ordered data mode. Quota mode: none.
[Thu Nov 19 06:48:00 2026] EXT4-fs (sda2): re-mounted 15f4c6be-1102-4331-9904-f78e78afd1fd r/w.
Show mounted filesystems:
TARGET           SOURCE    FSTYPE OPTIONS
/                /dev/sda2 ext4   rw,noatime
`-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
3.0G    /var/
809M    /var/cache
786M    /var/cache/apt
653M    /var/cache/apt/archives
197M    /var/lib
Archived and active journals take up 8M in the file system.
/opt/iobroker/backups:
786M    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
783M    /opt/iobroker/iobroker-data/
383M    /opt/iobroker/iobroker-data/files
253M    /opt/iobroker/iobroker-data/backup-objects
63M     /opt/iobroker/iobroker-data/files/aura
61M     /opt/iobroker/iobroker-data/files/aura/assets
90M     /opt/iobroker/iobroker-data/objects.jsonl
23M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
11M     /opt/iobroker/iobroker-data/files/devices.admin/assets/index-h2WSMjGw.js
11M     /opt/iobroker/iobroker-data/backup-objects/2026-11-19_04-35_objects.jsonl.gz
11M     /opt/iobroker/iobroker-data/backup-objects/2026-11-19_02-35_objects.jsonl.gz
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
No Devices found 'by-id'
No nvbackup.json found.
*** NodeJS-Installation ***
/usr/bin/nodejs         v24.22.3
/usr/bin/node           v24.22.3
/usr/bin/npm            11.19.1
/usr/bin/npx            11.19.1
✓ Node.js installation is correct
Recommended versions are nodejs 24.22.3 and npm 11.19.1
nodejs:
  Installed: 24.22.3-1nodesource1
  Candidate: 24.22.3-1nodesource1
  Version table:
 *** 24.22.3-1nodesource1 1001
        500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
        100 /var/lib/dpkg/status
     24.22.2-1nodesource1 1001
     24.22.1-1nodesource1 1001
     24.22.0-1nodesource1 1001
     24.21.0-1nodesource1 1001
     24.20.0-1nodesource1 1001
     24.19.0-1nodesource1 1001
     24.18.1-1nodesource1 1001
     24.18.0-1nodesource1 1001
     24.17.0-1nodesource1 1001
     24.16.0-1nodesource1 1001
     24.15.0-1nodesource1 1001
     24.14.1-1nodesource1 1001
     24.14.0-1nodesource1 1001
     24.13.1-1nodesource1 1001
     24.13.0-1nodesource1 1001
     24.12.0-1nodesource1 1001
     24.11.1-1nodesource1 1001
     24.11.0-1nodesource1 1001
     24.10.0-1nodesource1 1001
     24.9.0-1nodesource1 1001
     24.8.0-1nodesource1 1001
     24.7.0-1nodesource1 1001
     24.6.0-1nodesource1 1001
     24.5.0-1nodesource1 1001
     24.4.1-1nodesource1 1001
     24.4.0-1nodesource1 1001
     24.3.0-1nodesource1 1001
     24.1.0-1nodesource1 1001
     24.0.2-1nodesource1 1001
     24.0.1-1nodesource1 1001
     24.0.0-1nodesource1 1001
     20.19.2+dfsg-1+deb13u3 500
        500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
     20.19.2+dfsg-1+deb13u2 500
        500 http://deb.debian.org/debian trixie/main arm64 Packages
No problems detected
Errors in npm tree: 0
No known Vulnerabilities detected!
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
Homeserver          Homeserver (version: 7.2.5, hostname: Homeserver    , alive, uptime: 483)
Core adapters versions
js-controller:  7.2.5
admin:          8.3.5
javascript:     10.4.4
nodejs modules from github:     0
Adapter State
+ system.adapter.admin.0                  : admin                 : Homeserver                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
+ system.adapter.alarm.0                  : alarm                 : Homeserver                               -  enabled
  system.adapter.alias-manager.0          : alias-manager         : Homeserver                               - disabled
+ system.adapter.aura.0                   : aura                  : Homeserver                               -  enabled, port: 8095
+ system.adapter.backitup.0               : backitup              : Homeserver                               -  enabled
+ system.adapter.devices.0                : devices               : Homeserver                               -  enabled
+ system.adapter.discovery.0              : discovery             : Homeserver                               -  enabled
+ system.adapter.echarts.0                : echarts               : Homeserver                               -  enabled
+ system.adapter.fb-checkpresence.0       : fb-checkpresence      : Homeserver                               -  enabled
+ system.adapter.history.0                : history               : Homeserver                               -  enabled
  system.adapter.icons-material-png.0     : icons-material-png    : Homeserver                               - disabled
  system.adapter.icons-mfd-png.0          : icons-mfd-png         : Homeserver                               - disabled
+ system.adapter.javascript.0             : javascript            : Homeserver                               -  enabled
+ system.adapter.mqtt.0                   : mqtt                  : Homeserver                               -  enabled, port: 1884, bind: 192.168.10.14
+ system.adapter.myuplink.0               : myuplink              : Homeserver                               -  enabled
+ system.adapter.nut.0                    : nut                   : Homeserver                               -  enabled
+ system.adapter.open-meteo-weather.0     : open-meteo-weather    : Homeserver                               -  enabled
+ system.adapter.openknx.0                : openknx               : Homeserver                               -  enabled, bind: 192.168.10.14
+ system.adapter.pushover.0               : pushover              : Homeserver                               -  enabled
+ system.adapter.pushover.1               : pushover              : Homeserver                               -  enabled
+ system.adapter.scenes.0                 : scenes                : Homeserver                               -  enabled
+ system.adapter.shuttercontrol.0         : shuttercontrol        : Homeserver                               -  enabled
+ system.adapter.socketio.0               : socketio              : Homeserver                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
+ system.adapter.sonoff.0                 : sonoff                : Homeserver                               -  enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.sourceanalytix.0         : sourceanalytix        : Homeserver                               -  enabled
+ system.adapter.sprinklecontrol.0        : sprinklecontrol       : Homeserver                               -  enabled
+ system.adapter.telegram-menu.0          : telegram-menu         : Homeserver                               -  enabled
+ system.adapter.telegram.0               : telegram              : Homeserver                               -  enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.tr-064.0                 : tr-064                : Homeserver                               -  enabled
  system.adapter.vis-2.0                  : vis-2                 : Homeserver                               - disabled
  system.adapter.vis-colorpicker.0        : vis-colorpicker       : Homeserver                               - disabled
  system.adapter.vis-icontwo.0            : vis-icontwo           : Homeserver                               - disabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : Homeserver                               - disabled
  system.adapter.vis.0                    : vis                   : Homeserver                               -  enabled
+ system.adapter.web.0                    : web                   : Homeserver                               -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
+ system.adapter.web.1                    : web                   : Homeserver                               -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
+ system.adapter.xsense.0                 : xsense                : Homeserver                               -  enabled
+ instance is alive
ioBroker-Repositories
│ (index) │ name               │ url                                                     │ auto upgrade │
│ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
│ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
Upgrade policy: none
Installed ioBroker-Adapters
│ (index) │ id                                  │ name                 │ version  │ upgrade policy │
│ 0       │ 'system.adapter.admin'              │ 'admin'              │ '8.3.5'  │ 'none'         │
│ 1       │ 'system.adapter.alarm'              │ 'alarm'              │ '5.1.2'  │ 'none'         │
│ 2       │ 'system.adapter.alias-manager'      │ 'alias-manager'      │ '3.0.0'  │ 'none'         │
│ 3       │ 'system.adapter.aura'               │ 'aura'               │ '1.0.2'  │ 'none'         │
│ 4       │ 'system.adapter.backitup'           │ 'backitup'           │ '4.0.3'  │ 'none'         │
│ 5       │ 'system.adapter.devices'            │ 'devices'            │ '4.2.2'  │ 'none'         │
│ 6       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.2.0'  │ 'none'         │
│ 7       │ 'system.adapter.echarts'            │ 'echarts'            │ '6.3.0'  │ 'none'         │
│ 8       │ 'system.adapter.fb-checkpresence'   │ 'fb-checkpresence'   │ '1.5.0'  │ 'none'         │
│ 9       │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0' │ 'none'         │
│ 10      │ 'system.adapter.history'            │ 'history'            │ '5.1.1'  │ 'none'         │
│ 11      │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0'  │ 'none'         │
│ 12      │ 'system.adapter.icons-mfd-png'      │ 'icons-mfd-png'      │ '1.2.1'  │ 'none'         │
│ 13      │ 'system.adapter.javascript'         │ 'javascript'         │ '10.4.4' │ 'none'         │
│ 14      │ 'system.adapter.mqtt'               │ 'mqtt'               │ '8.1.2'  │ 'none'         │
│ 15      │ 'system.adapter.myuplink'           │ 'myuplink'           │ '0.8.6'  │ 'none'         │
│ 16      │ 'system.adapter.nut'                │ 'nut'                │ '1.7.0'  │ 'none'         │
│ 17      │ 'system.adapter.open-meteo-weather' │ 'open-meteo-weather' │ '3.3.2'  │ 'none'         │
│ 18      │ 'system.adapter.openknx'            │ 'openknx'            │ '1.2.0'  │ 'none'         │
│ 19      │ 'system.adapter.pushover'           │ 'pushover'           │ '6.1.0'  │ 'none'         │
│ 20      │ 'system.adapter.scenes'             │ 'scenes'             │ '5.1.0'  │ 'none'         │
│ 21      │ 'system.adapter.shuttercontrol'     │ 'shuttercontrol'     │ '2.1.2'  │ 'none'         │
│ 22      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '2.8.0'  │ 'none'         │
│ 23      │ 'system.adapter.socketio'           │ 'socketio'           │ '9.0.2'  │ 'none'         │
│ 24      │ 'system.adapter.sonoff'             │ 'sonoff'             │ '5.1.1'  │ 'none'         │
│ 25      │ 'system.adapter.sourceanalytix'     │ 'sourceanalytix'     │ '0.7.1'  │ 'none'         │
│ 26      │ 'system.adapter.sprinklecontrol'    │ 'sprinklecontrol'    │ '1.0.11' │ 'none'         │
│ 27      │ 'system.adapter.telegram'           │ 'telegram'           │ '6.0.2'  │ 'none'         │
│ 28      │ 'system.adapter.telegram-menu'      │ 'telegram-menu'      │ '4.2.3'  │ 'none'         │
│ 29      │ 'system.adapter.tr-064'             │ 'tr-064'             │ '4.3.0'  │ 'none'         │
│ 30      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'  │ 'none'         │
│ 31      │ 'system.adapter.vis-2'              │ 'vis-2'              │ '2.20.8' │ 'none'         │
│ 32      │ 'system.adapter.vis-colorpicker'    │ 'vis-colorpicker'    │ '2.1.0'  │ 'none'         │
│ 33      │ 'system.adapter.vis-icontwo'        │ 'vis-icontwo'        │ '2.11.6' │ 'none'         │
│ 34      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'  │ 'none'         │
│ 35      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'  │ 'none'         │
│ 36      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'  │ 'none'         │
│ 37      │ 'system.adapter.xsense'             │ 'xsense'             │ '0.6.5'  │ 'none'         │
ioBroker-Adapter Versions and update status
Adapter    "admin"        : 8.3.5    , installed 8.3.5
Adapter    "alarm"        : 5.1.2    , installed 5.1.2
Adapter    "alias-manager": 3.0.0    , installed 3.0.0
Adapter    "backitup"     : 4.0.3    , installed 4.0.3
Adapter    "devices"      : 4.2.2    , installed 4.2.2
Adapter    "discovery"    : 5.2.0    , installed 5.2.0
Adapter    "echarts"      : 6.3.0    , installed 6.3.0
Adapter    "fb-checkpresence": 1.5.0 , installed 1.5.0
Adapter    "history"      : 5.1.1    , installed 5.1.1
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
Adapter    "javascript"   : 10.4.4   , installed 10.4.4
Controller "js-controller": 7.2.5    , installed 7.2.5
Adapter    "mqtt"         : 8.1.2    , installed 8.1.2
Adapter    "myuplink"     : 0.8.6    , installed 0.8.6
Adapter    "nut"          : 1.7.0    , installed 1.7.0
Adapter    "open-meteo-weather": 3.3.2, installed 3.3.2
Adapter    "openknx"      : 1.2.0    , installed 1.2.0
Adapter    "pushover"     : 6.1.0    , installed 6.1.0
Adapter    "scenes"       : 5.1.0    , installed 5.1.0
Adapter    "shuttercontrol": 2.1.2   , installed 2.1.2
Adapter    "socketio"     : 9.0.2    , installed 9.0.2
Adapter    "sonoff"       : 5.1.1    , installed 5.1.1
Adapter    "sprinklecontrol": 1.0.11 , installed 1.0.11
Adapter    "telegram"     : 6.0.2    , installed 6.0.2
Adapter    "telegram-menu": 4.2.3    , installed 4.2.3
Adapter    "vis-2"        : 2.20.8   , installed 2.20.8
Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
Adapter    "vis-icontwo"  : 2.11.6   , installed 2.11.6
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "ws"           : 4.1.0    , installed 4.1.0
Adapter    "xsense"       : 0.6.1    , installed 0.6.5
Objects and States
Objects:        13146
States:         12435
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
Get:6 https://pkgs.tailscale.com/stable/debian trixie InRelease
Hit:7 https://repo.45drives.com/debian focal InRelease
Fetched 6650 B in 1s (10.8 kB/s)
Reading package lists...
Pending systemupdates: 1
*** Listening Ports ***
Netid State  Recv-Q Send-Q                          Local Address:Port          Peer Address:PortProcess
udp   UNCONN 0      0                                     0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=612,fd=5),("systemd",pid=1,fd=190))
udp   UNCONN 0      0                                     0.0.0.0:41641              0.0.0.0:*    users:(("tailscaled",pid=968,fd=17))
udp   UNCONN 0      0                                     0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=652,fd=12))
udp   UNCONN 0      0                               192.168.10.14:47425              0.0.0.0:*    users:(("io.openknx.0",pid=1910,fd=35))
udp   UNCONN 0      0                                     0.0.0.0:39520              0.0.0.0:*    users:(("avahi-daemon",pid=652,fd=14))
udp   UNCONN 0      0                                           *:sunrpc                   *:*    users:(("rpcbind",pid=612,fd=7),("systemd",pid=1,fd=192))
udp   UNCONN 0      0                 [fe80::aa0b:ec83:78bd:893b]:dhcpv6-client            *:*    users:(("NetworkManager",pid=735,fd=28))
udp   UNCONN 0      0                                           *:41641                    *:*    users:(("tailscaled",pid=968,fd=19))
udp   UNCONN 0      0                                           *:mdns                     *:*    users:(("avahi-daemon",pid=652,fd=13))
udp   UNCONN 0      0                                           *:59879                    *:*    users:(("avahi-daemon",pid=652,fd=15))
tcp   LISTEN 0      4096                                  0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=612,fd=4),("systemd",pid=1,fd=189))
tcp   LISTEN 0      128                                   0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=987,fd=6))
tcp   LISTEN 0      4096                 100.88.73.102%tailscale0:38459              0.0.0.0:*    users:(("tailscaled",pid=968,fd=25))
tcp   LISTEN 0      511                             192.168.10.14:1884               0.0.0.0:*    users:(("io.mqtt.0",pid=1738,fd=35))
tcp   LISTEN 0      16                                  127.0.0.1:nut                0.0.0.0:*    users:(("upsd",pid=1062,fd=4))
tcp   LISTEN 0      511                                   0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=1964,fd=36))
tcp   LISTEN 0      511                                 127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=964,fd=23))
tcp   LISTEN 0      511                                 127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=964,fd=29))
tcp   LISTEN 0      2048                                  0.0.0.0:8096               0.0.0.0:*    users:(("gunicorn",pid=1061,fd=3),("gunicorn",pid=1056,fd=3),("gunicorn",pid=1050,fd=3),("gunicorn",pid=965,fd=3))
tcp   LISTEN 0      4096                                     [::]:sunrpc                [::]:*    users:(("rpcbind",pid=612,fd=6),("systemd",pid=1,fd=191))
tcp   LISTEN 0      4096   [fd7a:115c:a1e0::6d3a:4967]%tailscale0:47587                 [::]:*    users:(("tailscaled",pid=968,fd=29))
tcp   LISTEN 0      128                                      [::]:ssh                   [::]:*    users:(("sshd",pid=987,fd=7))
tcp   LISTEN 0      4096                                        *:9090                     *:*    users:(("cockpit-tls",pid=1395,fd=3),("systemd",pid=1,fd=171))
tcp   LISTEN 0      511                                         *:8082                     *:*    users:(("io.web.0",pid=2194,fd=35))
tcp   LISTEN 0      511                                         *:tproxy                   *:*    users:(("io.admin.0",pid=1419,fd=36))
tcp   LISTEN 0      511                                         *:8084                     *:*    users:(("io.socketio.0",pid=2139,fd=34))
tcp   LISTEN 0      511                                         *:8089                     *:*    users:(("io.web.1",pid=2205,fd=35))
tcp   LISTEN 0      511                                         *:8095                     *:*    users:(("io.aura.0",pid=1991,fd=30))
2026-11-19 06:53:57.660  - info: sourceanalytix.0 (2057) Initialising "alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Heizung.PRODUCTION" | (23 of 24)
2026-11-19 06:53:58.204  - info: sourceanalytix.0 (2057) Initialization of alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Heizung.PRODUCTION successfully
2026-11-19 06:53:58.205  - info: sourceanalytix.0 (2057) Initialising "alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Wasser.PRODUCTION" | (24 of 24)
2026-11-19 06:53:58.795  - info: sourceanalytix.0 (2057) Initialization of alias.0.Erzeugung.Gebaeude.Waermepumpe.Waerme_Wasser.PRODUCTION successfully
2026-11-19 06:53:58.896  - info: sourceanalytix.0 (2057) Successfully activated SourceAnalytix for all 24 of 24 states, will do my Job until you stop me!
2026-11-19 06:54:14.517  - info: web.1 (2205) ==&gt; Connected system.user.admin from ::ffff:127.0.0.1
2026-11-19 06:54:15.622  - info: javascript.0 (1554) script.js.Benachrichtigungen.MessageStateCreator: [MessageStateCreator] postMessage('TEMPERATURE_INFO', '🌐 2,4 °C 🏠 14,8 °C', 0)
2026-11-19 06:55:00.050  - info: javascript.0 (1554) script.js.Wetter_Widget: Weather widget: HTML successfully generated.
2026-11-19 06:55:12.605  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] connected with secret 1795067712603_4753
2026-11-19 06:55:12.642  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] subscribes on "mqtt.0.Wasseruhr.Warmwasser_Wohnung_Keller.ctrl.flow_start"
2026-11-19 06:55:12.659  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] subscribes on "mqtt.0.Wasseruhr.Warmwasser_Wohnung_Keller.ctrl.set_prevalue"
2026-11-19 06:55:12.843  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] publishOnSubscribe
2026-11-19 06:55:12.860  - info: mqtt.0 (1738) Client [Wasseruhr_Warmwasser_Wohnung_Keller] publishOnSubscribe
2026-11-19 06:55:36.092  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] connected with secret 1795067736082_175
2026-11-19 06:55:46.393  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.flow_start"
2026-11-19 06:55:46.594  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
2026-11-19 06:55:47.891  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.set_prevalue"
2026-11-19 06:55:47.892  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.flow_start"
2026-11-19 06:55:47.893  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] subscribes on "mqtt.0.Wasseruhr.Wasser_Wohnung_Keller_Garten.ctrl.flow_start"
2026-11-19 06:55:48.091  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
2026-11-19 06:55:48.092  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
2026-11-19 06:55:48.093  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
2026-11-19 06:55:48.094  - info: mqtt.0 (1738) Client [Wasseruhr_Wohnung_Keller_Garten] publishOnSubscribe
2026-11-19 06:56:52.651  - info: javascript.0 (1554) script.js.Benachrichtigungen.MessageStateCreator: [MessageStateCreator] postMessage('TEMPERATURE_INFO', '🌐 2,4 °C 🏠 14,9 °C', 0)
============= Mark until here for C&amp;P =============
iob diag has finished.
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/85871/iobroker-startet-hin-und-wieder-neu</link><generator>RSS for Node</generator><lastBuildDate>Sat, 21 Nov 2026 11:17:12 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85871.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Nov 2026 06:03:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Sat, 21 Nov 2026 05:51:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> Das sieht schon deutlich besser aus. Nach 12 Stunden 2,6 GB verfügbar und Swap auf 0 ist in Ordnung.</p>
<p dir="auto">Ja, das passt zum Beta-Repo. Beim Aktualisieren wird das komplette Objekt <code>system.repositories</code> eingelesen, verarbeitet und neu geschrieben. Darin lag der Katalog von Stable und zusätzlich der von Beta. Beta ist ungefähr gleich groß und enthält noch mehr Versionen. Das bekommst du doppelt zu spüren, und unter Node 24 ist die Spitze sowieso höher. Wenn dann noch 30 Instanzen laufen, ist der Pi schnell am Limit.</p>
<p dir="auto">Zur Timeout-Meldung: Poste bitte den genauen Text der Meldung und probier es zum Vergleich einmal auf der Konsole:</p>
<pre><code>time iob update
</code></pre>
<p dir="auto">Wenn das sauber und in normaler Zeit durchläuft, kommt die Meldung nur aus dem Admin und das Repo ist trotzdem aktuell. Schreib bitte auch dazu, welche Admin- und js-controller-Version du hast.</p>
<p dir="auto">Zur USV: Das bekannte Problem beim Pi 4 ist, dass er nach <code>shutdown -h</code> erst wieder startet, wenn der Strom einmal kurz weg war. Kommt der Netzstrom zurück, bevor die USV leer ist, bleibt er aus. Bei NUT löst man das meist so: upsmon fährt den Pi herunter und schaltet am Ende die USV über das <code>POWERDOWNFLAG</code> (killpower) ab. Kommt der Strom zurück, schaltet die USV wieder ein und der Pi bootet. Ob deine Legrand mit <code>nutdrv_qx</code> den Shutdown-Befehl unterstützt, musst du in der NUT-Doku zum Treiber nachsehen. Das hat aber mit den Neustarts nichts zu tun, das kannst du in Ruhe angehen.</p>
<p dir="auto">Wenn er jetzt noch mal von allein neu startet, schick bitte die Ausgabe von:</p>
<pre><code>journalctl --list-boots
sudo journalctl -b -1 -n 150 --no-pager
sudo journalctl -b -1 | grep -iE "oom|out of memory|killed process|watchdog"
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1364231</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364231</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Sat, 21 Nov 2026 05:51:34 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Sat, 21 Nov 2026 05:23:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a><br />
Habe das Journal jetzt nach deiner Angabe eingerichtet, und das Verzeichnis unter /var/log/journal ist auch vorhanden.</p>
<p dir="auto">Zum Nut, da habe ich den monitor vorerst deaktiviert, den habe ich noch nicht richtig eingerichtet da ich noch nicht genau weiß wie ich es mach wenn der Pi runterfährt, damit er mir dann auch wieder hoch fährt sollte Strom doch wieder da sein bevor die USV abschaltet.</p>
<p dir="auto">Ja Beta-Repo habe ich gelöscht, wenn ich jetzt das Repo aktualisiere, also bei den Adaptern auf "Adapter auf Updates überprüfen" klicke läuft der RAM nicht mehr so voll.<br />
Ich bekomme aber immer eine Timeout Meldung, da meine Verbindung zu langsam sein soll.<br />
Kann es sein, dass das Beta so viel mehr RAM benötigt, denn jetz steigt der RAM Verbrauch nur etwas an, vorher waren es sicher 4GB die er nach obe gschnellt ist.</p>
<p dir="auto">Speicherauslastung nach 12 Stunden Laufzeit:</p>
<pre><code>               total        used        free      shared  buff/cache   available
Mem:           7.6Gi       5.0Gi       1.5Gi       9.7Mi       1.3Gi       2.6Gi
Swap:          2.0Gi          0B       2.0Gi
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1364228</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364228</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Sat, 21 Nov 2026 05:23:04 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Sat, 21 Nov 2026 04:54:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> Raspberry Pi OS schreibt das Journal standardmäßig nur in den RAM (Storage=volatile). Ein Neustart allein ändert daran nichts. So stellst du es auf persistent um:</p>
<pre><code class="language-bash">sudo mkdir -p /etc/systemd/journald.conf.d
printf '[Journal]\nStorage=persistent\n' | sudo tee /etc/systemd/journald.conf.d/99-persistent.conf
sudo systemctl restart systemd-journald
ls /var/log/journal
</code></pre>
<p dir="auto">Unter <code>/var/log/journal</code> sollte jetzt ein Verzeichnis liegen. Ab dem nächsten Absturz zeigt dir <code>journalctl --list-boots</code> dann auch Boot <code>-1</code>, und die Befehle von oben funktionieren.</p>
<p dir="auto">Zum nut-monitor: In deiner <code>upsmon.conf</code> fehlt die Zeile <code>MONITOR</code>, deshalb "Sum of power values: 0". Das sieht ungefähr so aus:</p>
<pre><code>MONITOR legrand@localhost 1 &lt;user&gt; &lt;passwort&gt; primary
</code></pre>
<p dir="auto">Benutzer und Passwort müssen zu einem Eintrag in <code>/etc/nut/upsd.users</code> passen. So wie es jetzt ist, hat upsmon nie gelaufen und konnte auch keinen Shutdown auslösen. Als Ursache für die Neustarts ist er also eher unwahrscheinlich. Ich tippe weiter auf den Speicher.</p>
<p dir="auto">Hast du das Beta-Repo inzwischen mit <code>iob repo del</code> gelöscht? Und wie sieht <code>free -h</code> aus, wenn das System ein paar Stunden läuft?</p>
]]></description><link>https://forum.iobroker.net/post/1364224</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364224</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Sat, 21 Nov 2026 04:54:32 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 18:27:45 GMT]]></title><description><![CDATA[<p dir="auto">ja habe den Nut-Monitor erstmal deaktiviert bis ich ihn richtig konfiguriert habe.</p>
<pre><code>systemctl status nut-monitor
○ nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
     Loaded: loaded (/usr/lib/systemd/system/nut-monitor.service; disabled; preset: enabled)
     Active: inactive (dead) since Fri 2026-11-20 18:13:40 CET; 1h 12min ago
   Duration: 48ms
 Invocation: 7f2e73b519c94683ba11e4299e5bfdb3
   Main PID: 1144 (code=exited, status=1/FAILURE)
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1364197</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364197</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 18:27:45 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 18:01:35 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> <a href="/post/1364189">sagte</a>:</p>
<p dir="auto">Nov 20 18:13:40 Homeserver nut-monitor[1144]: Fatal error: insufficient power configured!<br />
Nov 20 18:13:40 Homeserver nut-monitor[1144]: Sum of power values........: 0<br />
Nov 20 18:13:40 Homeserver nut-monitor[1144]: Minimum value (MINSUPPLIES): 1<br />
Nov 20 18:13:40 Homeserver nut-monitor[1144]: Edit your upsmon.conf and change the values.</p>
</blockquote>
<p dir="auto">Dein nut ist offenbar nicht richtig konfiguriert. Auf deren Homepage gibt es sehr ausführliche Anleitungen prro Treiber.</p>
]]></description><link>https://forum.iobroker.net/post/1364193</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364193</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 20 Nov 2026 18:01:35 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 17:28:32 GMT]]></title><description><![CDATA[<p dir="auto">Habe einen reboot gemacht aber immer noch das Selbe:</p>
<pre><code>pi@Homeserver:~ $ journalctl --list-boots
IDX BOOT ID                          FIRST ENTRY                 LAST ENTRY
  0 f931730ede3a4c6e991db8fd19c146d8 Fri 2026-11-20 18:13:30 CET Fri 2026-11-20 18:24:29 CET
pi@Homeserver:~ $ sudo journalctl -b -1 -n 150 --no-pager
[sudo] password for pi:
Specifying boot ID or boot offset has no effect, no persistent journal was found.
pi@Homeserver:~ $ sudo journalctl -b -1 | grep -iE "oom|out of memory|killed process|upsmon|nut|watchdog"
pi@Homeserver:~ $
</code></pre>
<p dir="auto">Hier noch die Ausgabe vom Nut Server:</p>
<pre><code>pi@Homeserver:~ $ systemctl list-units 'nut*' --all --no-pager
  nut-driver-enumerator.path    loaded active   waiting nut-driver-enumerator.path
  nut-driver-enumerator.service loaded inactive dead    Network UPS Tools - enumeration of configur…
  nut-driver@legrand.service    loaded active   running Network UPS Tools - device driver for NUT d…
● nut-monitor.service           loaded failed   failed  Network UPS Tools - power device monitor an…
  nut-server.service            loaded active   running Network UPS Tools - power devices informati…
  nut-driver.target             loaded active   active  Network UPS Tools - target for power device…
  nut.target                    loaded active   active  Network UPS Tools - target for power device…
Legend: LOAD   → Reflects whether the unit definition was properly loaded.
        ACTIVE → The high-level unit activation state, i.e. generalization of SUB.
        SUB    → The low-level unit activation state, values depend on unit type.
7 loaded units listed.
To show all installed unit files use 'systemctl list-unit-files'.
pi@Homeserver:~ $ sudo grep -vE "^#|^$" /etc/nut/upsmon.conf
MINSUPPLIES 1
SHUTDOWNCMD "/sbin/shutdown -h +0"
POLLFREQ 5
POLLFREQALERT 5
HOSTSYNC 15
DEADTIME 15
POWERDOWNFLAG /etc/killpower
RBWARNTIME 43200
NOCOMMWARNTIME 300
FINALDELAY 5
pi@Homeserver:~ $ sudo grep -vE "^#|^$" /etc/nut/ups.conf
maxretry = 3
[legrand]
    driver = nutdrv_qx
    port = auto
    vendorid = ffff
    productid = 0000
    subdriver = krauler
    desc = "Legrand Niky 800"
pi@Homeserver:~ $ sudo journalctl -u nut-monitor -n 30 --no-pager
Nov 20 18:13:39 Homeserver systemd[1]: nut-monitor.service: Scheduled restart job, restart counter is at 3.
Nov 20 18:13:39 Homeserver systemd[1]: Starting nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller...
Nov 20 18:13:39 Homeserver systemd[1]: Started nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller.
Nov 20 18:13:39 Homeserver nut-monitor[1141]: fopen /run/nut/upsmon.pid: No such file or directory
Nov 20 18:13:39 Homeserver nut-monitor[1141]: Could not find PID file to see if previous upsmon instance is already running!
Nov 20 18:13:39 Homeserver nut-monitor[1141]: Using power down flag file /etc/killpower
Nov 20 18:13:39 Homeserver nut-monitor[1141]: Network UPS Tools upsmon 2.8.1
Nov 20 18:13:39 Homeserver nut-monitor[1141]: Fatal error: insufficient power configured!
Nov 20 18:13:39 Homeserver nut-monitor[1141]: Sum of power values........: 0
Nov 20 18:13:39 Homeserver nut-monitor[1141]: Minimum value (MINSUPPLIES): 1
Nov 20 18:13:39 Homeserver nut-monitor[1141]: Edit your upsmon.conf and change the values.
Nov 20 18:13:39 Homeserver systemd[1]: nut-monitor.service: Main process exited, code=exited, status=1/FAILURE
Nov 20 18:13:39 Homeserver systemd[1]: nut-monitor.service: Failed with result 'exit-code'.
Nov 20 18:13:40 Homeserver systemd[1]: nut-monitor.service: Scheduled restart job, restart counter is at 4.
Nov 20 18:13:40 Homeserver systemd[1]: Starting nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller...
Nov 20 18:13:40 Homeserver systemd[1]: Started nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller.
Nov 20 18:13:40 Homeserver nut-monitor[1144]: fopen /run/nut/upsmon.pid: No such file or directory
Nov 20 18:13:40 Homeserver nut-monitor[1144]: Could not find PID file to see if previous upsmon instance is already running!
Nov 20 18:13:40 Homeserver nut-monitor[1144]: Using power down flag file /etc/killpower
Nov 20 18:13:40 Homeserver nut-monitor[1144]: Network UPS Tools upsmon 2.8.1
Nov 20 18:13:40 Homeserver systemd[1]: nut-monitor.service: Main process exited, code=exited, status=1/FAILURE
Nov 20 18:13:40 Homeserver systemd[1]: nut-monitor.service: Failed with result 'exit-code'.
Nov 20 18:13:40 Homeserver systemd[1]: nut-monitor.service: Scheduled restart job, restart counter is at 5.
Nov 20 18:13:40 Homeserver systemd[1]: nut-monitor.service: Start request repeated too quickly.
Nov 20 18:13:40 Homeserver systemd[1]: Failed to start nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1364189</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364189</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 17:28:32 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 17:14:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
ok dann mache ich mal einen reboot, und deaktiviere nut über die Konsole</p>
]]></description><link>https://forum.iobroker.net/post/1364187</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364187</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 17:14:40 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 17:13:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> <a href="/post/1364184">sagte</a>:</p>
<p dir="auto">Reicht es wenn ich Nut in den Instanzen Pausiere?</p>
</blockquote>
<p dir="auto">Nein, der Dienst läuft nicht in ioBroker sondern als systemd-Service.</p>
]]></description><link>https://forum.iobroker.net/post/1364186</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364186</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 20 Nov 2026 17:13:28 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 17:12:45 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Irgendwie hat das mit dem Journal nicht geklappt :(</p>
</blockquote>
<p dir="auto">Doch, aber du hast nur eines. Der Befehl<br />
journalctl -b -1<br />
schaut aber auf das davor liegendene (nicht vorhandendene journal). Du musst einmal sauber neustarten.</p>
]]></description><link>https://forum.iobroker.net/post/1364185</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364185</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 20 Nov 2026 17:12:45 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 17:12:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a><br />
  0 01cf775e9c114bc6bcbfe377f968f8e7 Fri 2026-11-20 06:49:15 CET Fri 2026-11-20 18:07:19 CET
</code></pre>
<p dir="auto">Reicht es wenn ich Nut in den Instanzen Pausiere?<br />
<img src="/assets/uploads/files/1795194758543-f619d607-91b4-4c5a-9e6d-cf72476c50d7-image.jpeg" alt="grafik.jpeg" class="img-markdown  img-fluid" width="410" height="45" /></p>
]]></description><link>https://forum.iobroker.net/post/1364184</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364184</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 17:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 13:51:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> Du hast das Journal eingerichtet, bevor er abgestürzt ist. Jetzt müsste man also sehen, was passiert ist:</p>
</code></pre>
<p dir="auto">Dein Verdacht mit dem Repository passt. Beim Aktualisieren des Repos braucht der js-controller kurzzeitig viel zusätzlichen RAM. Außerdem bleibt der Katalog eines inaktiven Repos (also Beta) im Objekt <code>system.repositories</code> gespeichert, auch wenn nur Stable aktiv ist. Siehe <a href="https://github.com/ioBroker/ioBroker.js-controller/issues/3427" rel="nofollow ugc">js-controller #3427</a>. Deshalb löschen, wie Marc geschrieben hat, und nicht nur deaktivieren. Auf der Konsole geht das so:</p>
<pre><code>iob repo
iob repo del &lt;Name vom Beta-Repo&gt;
</code></pre>
<p dir="auto">Den genauen Namen zeigt dir <code>iob repo</code>.</p>
<p dir="auto">Den Swap auf 4 GB zu erhöhen, verschiebt das Problem nur. Wenn alles in den Swap läuft, wird der Pi so langsam, dass er praktisch hängt. Wichtiger ist, dass der RAM gar nicht erst so voll wird. 1,4 GB RSS nur für den js-controller ist viel.</p>
<p dir="auto">Zur USV: <code>nut-driver</code> gibt es unter trixie so nicht. Bitte schick:</p>
<pre><code>systemctl list-units 'nut*' --all --no-pager
</code></pre>
<p dir="auto">Wenn die USV nicht sauber eingerichtet ist und du sie gerade nicht brauchst, deaktiviere den nut-monitor, bis er läuft. Dann können wir sie als Ursache ausschließen.</p>
]]></description><link>https://forum.iobroker.net/post/1364161</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364161</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Fri, 20 Nov 2026 13:51:04 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 13:18:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> <a href="/post/1364119">sagte</a>:</p>
<p dir="auto">So viel Speicher wird durch das Deinstallieren von Cockpit auch nicht frei werden.</p>
</blockquote>
<p dir="auto">So viel Speicher hast du aber auf dem Pi gar nicht zur Verfügung, dass du dir da noch Klimbimm leisten könntest.</p>
]]></description><link>https://forum.iobroker.net/post/1364152</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364152</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 20 Nov 2026 13:18:58 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 11:58:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> <a href="/post/1364136">sagte</a>:</p>
<p dir="auto">kann man das einstellen, das die Beta nicht mit aktualisiert wird</p>
</blockquote>
<p dir="auto">Unter "System--&gt;Repositories" das Beta Repo über den Papierkorb löschen.</p>
]]></description><link>https://forum.iobroker.net/post/1364145</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364145</guid><dc:creator><![CDATA[Marc Berg]]></dc:creator><pubDate>Fri, 20 Nov 2026 11:58:23 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 10:00:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: michael-schmitt">@<bdi>michael-schmitt</bdi></a><br />
kann man das einstellen, das die Beta nicht mit aktualisiert wird, oder müsste ich die komplett aus der Liste der Repositories nehmen?<br />
Würde es helfen SWAP auf 4GB oder mehr zu erhöhen?</p>
]]></description><link>https://forum.iobroker.net/post/1364136</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364136</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 10:00:49 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 09:37:34 GMT]]></title><description><![CDATA[<p dir="auto">aber es werden beide heruntergeladen</p>
]]></description><link>https://forum.iobroker.net/post/1364134</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364134</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Fri, 20 Nov 2026 09:37:34 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 09:17:49 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a> <a href="/post/1364130">sagte</a>:</p>
<p dir="auto">nimm die beta mal raus wenn du sie nicht brauchst</p>
</blockquote>
<p dir="auto">ist da nicht eh immer nur eine aktiv?</p>
]]></description><link>https://forum.iobroker.net/post/1364131</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364131</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 09:17:49 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 08:57:35 GMT]]></title><description><![CDATA[<p dir="auto">nimm die beta mal raus wenn du sie nicht brauchst</p>
]]></description><link>https://forum.iobroker.net/post/1364130</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364130</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Fri, 20 Nov 2026 08:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 08:26:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ja aber was hat das iOBroker Repository mit dem "Klimmbimm" zu tun? So viel Speicher wird durch das Deinstallieren von Cockpit auch nicht frei werden.<br />
Habe beobachtet, dass beim Update des Repository (stabel oder beta) die 8GB RAM + 2GB Swap voll ausgelastet sind, ob das normal ist, oder ob das von Cockpit kommt kann ich nicht sagen.</p>
]]></description><link>https://forum.iobroker.net/post/1364119</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364119</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 08:26:27 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 07:54:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a></p>
<p dir="auto">Deswegen sollst du ja auch den ganzen Klimmbimm ausschalten bzw. deinstallieren.</p>
]]></description><link>https://forum.iobroker.net/post/1364115</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364115</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 20 Nov 2026 07:54:42 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 07:00:01 GMT]]></title><description><![CDATA[<p dir="auto">Jetzt gerade als ich den vorherigen Kommentar geschrieben habe ist der Pi wieder abgestürzt, kann es sein dass das Herunterladen des Repository der Auslöser ist, habe festgestellt dass das viel RAM verbraucht und genau danach ist er abgestürzt?</p>
<p dir="auto"><a href="/assets/uploads/files/1795154609504-iobroker.2026-11-20.htm">iobroker.2026-11-20.htm</a></p>
]]></description><link>https://forum.iobroker.net/post/1364104</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364104</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 07:00:01 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 05:51:16 GMT]]></title><description><![CDATA[<p dir="auto">Erstmal Danke euch für die Hilfe<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a> Habe das journal jetzt eingerichtet :)<br />
Hier die Ausgaben der USV, da muss ich wohl noch was einrichten.</p>
<pre><code>pi@Homeserver:~ $ systemctl status nut-monitor nut-driver --no-pager -l
× nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
     Loaded: loaded (/usr/lib/systemd/system/nut-monitor.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Thu 2026-11-19 19:05:39 CET; 11h ago
   Duration: 36ms
 Invocation: eed184ccd15e4c29a3e56282fa4827aa
    Process: 1137 ExecStartPre=/usr/bin/systemd-tmpfiles --create /usr/lib/tmpfiles.d/nut-common-tmpfiles.conf (code=exited, status=0/SUCCESS)
    Process: 1139 ExecStart=/usr/sbin/upsmon -F (code=exited, status=1/FAILURE)
   Main PID: 1139 (code=exited, status=1/FAILURE)
Nov 19 19:05:39 Homeserver systemd[1]: nut-monitor.service: Scheduled restart job, restart counter is at 5.
Nov 19 19:05:39 Homeserver systemd[1]: nut-monitor.service: Start request repeated too quickly.
Nov 19 19:05:39 Homeserver systemd[1]: nut-monitor.service: Failed with result 'exit-code'.
Nov 19 19:05:39 Homeserver systemd[1]: Failed to start nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller.
Unit nut-driver.service could not be found.
pi@Homeserver:~ $ cat /etc/nut/upsmon.conf | grep -v "^#" | grep -v "^$"
cat: /etc/nut/upsmon.conf: Permission denied
</code></pre>
<p dir="auto">Und das Log vom 19.11.26</p>
<p dir="auto"><a href="/assets/uploads/files/1795153740062-iobroker.2026-11-19.log.htm">iobroker.2026-11-19.log.htm</a></p>
<p dir="auto">Die Liste mit dem RAM verbrauch. Der sieht aktuell gut aus werde ich aber weiter verfolgen.<br />
Habe jetz auch mal das script der Wetter Widgets deaktiviert da die häufig aktualisieren.</p>
<pre><code>pi@Homeserver:~ $ ps aux --sort=-rss | head -n 15
USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
iobroker     960 11.4 17.5 3153232 1401904 ?     Ssl  Nov19  79:25 iobroker.js-controller
iobroker    1250  0.3  6.5 10595492 526892 ?     Sl   Nov19   2:06 io.admin.0
iobroker    1274  1.7  4.2 1954284 336292 ?      Sl   Nov19  12:12 io.javascript.0
iobroker    1718  0.1  2.4 1889252 195488 ?      Sl   Nov19   0:50 io.web.0
iobroker    1745  0.2  2.4 1821268 192484 ?      Sl   Nov19   1:27 io.web.1
iobroker    1499  0.3  2.3 10186836 189136 ?     Sl   Nov19   2:10 io.sonoff.0
iobroker    1753  0.3  2.2 1407524 181772 ?      Sl   Nov19   2:04 io.aura.0
iobroker    1520  0.0  2.2 1403892 179800 ?      Sl   Nov19   0:40 io.sprinklecontrol.0
iobroker    2708  0.2  2.1 10247368 174680 ?     Sl   04:00   0:27 io.telegram.0
iobroker    1532  0.4  2.1 1857572 168948 ?      Sl   Nov19   3:17 io.tr-064.0
iobroker    1628  0.1  1.9 1855964 158836 ?      Sl   Nov19   1:10 io.open-meteo-weather.0
iobroker    1386  0.1  1.9 1791600 158416 ?      Sl   Nov19   0:45 io.backitup.0
iobroker    1407  0.1  1.9 1727692 158288 ?      Sl   Nov19   0:54 io.mqtt.0
iobroker    1600  0.1  1.9 1377300 156300 ?      Sl   Nov19   0:41 io.echarts.0
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1364103</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364103</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Fri, 20 Nov 2026 05:51:16 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Fri, 20 Nov 2026 04:38:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> Das Journal wird bei dir nur im RAM gehalten und ist nach jedem Neustart weg. Deshalb sieht man nicht, was vorher passiert ist. Schalte das dauerhafte Speichern ein:</p>
<pre><code>sudo mkdir -p /var/log/journal
sudo systemd-tmpfiles --create --prefix /var/log/journal
</code></pre>
<p dir="auto">Wenn es danach wieder passiert, zeigt das hier das Ende vom vorherigen Boot:</p>
<pre><code>sudo journalctl -b -1 -n 150 --no-pager
</code></pre>
<p dir="auto">Zum diag: Um 06:55 lief der Pi erst seit 7 Minuten. Hast du da selbst neu gestartet? Wenn nicht, ist der ganze Pi neu gestartet und nicht nur ioBroker. Bei vollem Speicher beendet der Kernel (OOM-Killer) einzelne Prozesse, aber er startet nicht den ganzen Pi neu.</p>
<p dir="auto">Darum habe ich die USV im Verdacht. Sie ist per USB angeschlossen, der nut-monitor ist failed und du musst sie öfter neu einstecken. Wenn upsmon meint, die USV sei auf Batterie oder leer, fährt es den Pi herunter. Schick mal:</p>
<pre><code>systemctl status nut-monitor nut-driver --no-pager
</code></pre>
<p dir="auto">Bis dahin hilft das ioBroker-Log, das liegt auf der SSD:</p>
<pre><code>grep -B 30 "js-controller starting" /opt/iobroker/log/iobroker.2026-11-19.log
</code></pre>
<p dir="auto">Steht vor dem Start ein sauberes "terminating" der Instanzen, wurde ordentlich heruntergefahren. Bricht das Log einfach ab, war es ein harter Absturz oder der Strom war weg.</p>
<p dir="auto">Unabhängig davon ist der RAM zu voll. Damit wir sehen, wer ihn frisst:</p>
<pre><code>ps aux --sort=-rss | head -n 15
</code></pre>
<p dir="auto">Cockpit mit dem 45drives-Repo brauchst du für ioBroker nicht. Ein SSH-Client wie PuTTY oder das Terminal im Windows/Mac reicht.</p>
]]></description><link>https://forum.iobroker.net/post/1364097</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364097</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Fri, 20 Nov 2026 04:38:53 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Thu, 19 Nov 2026 19:55:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Nicht dass ich nicht einige SSH Apps probiert habe, aber die haben mir alle nicht gefallen, entweder umständlich zu bedienen, oder kostenpflichtig usw.<br />
Ich werde Termius mal probieren, danke für den Tipp.</p>
]]></description><link>https://forum.iobroker.net/post/1364084</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364084</guid><dc:creator><![CDATA[fritzke316]]></dc:creator><pubDate>Thu, 19 Nov 2026 19:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to IoBroker startet hin und wieder neu on Thu, 19 Nov 2026 19:12:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fritzke316" aria-label="Profile: fritzke316">@<bdi>fritzke316</bdi></a> <a href="/post/1364077">sagte</a>:</p>
<p dir="auto">hab nichts Besseres gefunden :(</p>
</blockquote>
<p dir="auto">??? Du fährst auch mit einem 40-Tonnner zum Bäcker um die Ecke, oder?<br />
sshd bei der Installation aktivieren und auf dein Handy ein kleines Terminalprogramm. Auf meinen Android bin ich mittlerweile bei 'Termius' angekommen.</p>
]]></description><link>https://forum.iobroker.net/post/1364080</link><guid isPermaLink="true">https://forum.iobroker.net/post/1364080</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 19 Nov 2026 19:12:40 GMT</pubDate></item></channel></rss>
