  4. Test Adapter NSPanel-lovelace-ui v1.x.x
1.4k Beiträge 40 Kommentatoren 527.3k Aufrufe 39 Beobachtet
  • patricknitschP
    patricknitschP
    patricknitsch
    #1423
    Sieht ganz gut aus. Select funktioniert jetzt und langsam nimmt die cardThermo2 echt Formen an. Ein Bug war noch, dass er das Popup nicht auf dem Webpanel anzeigt. Das hast du in der Zwischenzeit schon behoben.
    Systeme:
    • Proxmox 1 mit ioBroker, HomeAssistant, piHole, PBS und Nextcloud
    • Proxmox 2 mit SOLECTRUS, Mosquitto, piHole und Frigate
    • RPi4 mit Octoprint
    Eigene Adapter: grohe-smarthome, solectrus-influxdb, schlueter-thermostat
    • T
      T
      ticaki
      #1424
      Das hier ist kein Breaking - da aber skript nicht mehr nötig ist - neue icons verwendet werden - die hmi version hoch ging habe ich eine 2.0.0 daraus gemacht:
      2.0.0 (2026-10-31)
      • (ticaki) maintain: new button "Take script over into admin" on every panel tile - converts the pages, the screensaver and the hardware buttons of a panel script into the admin configuration (preview with all problems, backup of the script, pages of the global script per panel, items the editor cannot express are taken over as raw data)
      • (ticaki) a configuration script is no longer required; new panel option "Panel uses no script" - the panel is configured in the admin only and a script sent for it is rejected
      • (ticaki) page configuration: new page types "Media player" (cardMedia), "Thermostat (classic)" (cardThermo) and "Page link"; paging of menu, thermostat and media pages can be set
      • (ticaki) page configuration: the old tabs "Page Power" and "Page Chart" are moved into the page configuration automatically at adapter start
      • (ticaki) item dialog: raw data (JSON) for page and screensaver items, many more fields (value conditions, slider ranges, secondRow, colormode, target page for buttons); long press is offered on grid pages only, like on the HMI
      • (tt-tom17) panel settings: the hardware buttons (relay decoupling and action) are configured in the panel tile
      • (ticaki) navigation flow: edit mode for prev/next/home/parent links (also for script pages, stored as override), auto layout, collapsible sub trees
      • (ticaki) icons: Material Design Icons 7.4.47 (546 new icons), own window and shutter icons, blinds show their position as icon - needs HMI/TFT 6.0.2 (beta TFT EU is 6.0.2)
      • (ticaki) global script: an admin page assigned to a panel replaces the global page of the same name
      • (ticaki, tt-tom17) web panel: tap and hold behave like on the HMI (grid tiles, cardMedia, cardThermo2, list rows), hardware buttons 20px higher
      • (ticaki) error in the log when Tasmota runs but the display never answers (hint to the NSPanel template / GPIO4)
      • (ticaki) fix: prefix and suffix of admin page item values were swapped - if you entered them the other way round, swap them back
      • (ticaki) fixes: colorScale.color_best ignored, font size lost while an item is off, long press also triggered the short press, media item of an admin page without media sub page, screensaver clock stopped, "show system pages" in the navigation flow
      • (tt-tom17) fixes: deactivated panels (cmd.activated) are left alone at adapter start and report deactivated, cmd.hideCards keeps its value at adapter start
      Spenden
      • T
        T
        ticaki
        #1425
        Noch ein Wort zu der "Page Link"
        Im Skript kann man ein globale Seite anlegen die dann
        a) als main dient
        b) als normale seite dient
        c) mehrfach auf einem panel verlinkt werden kann - z.B. Raum spezifische Seiten im Hausmenü und direkt in der main für den raum
        Das geht jetzt mit der Page Link (Verknüpfung) die gibt einfach einen weiteren uniquename und die möglichkeit eine andere navigation oder optionen (hidden, istStartseite usw) mitzugeben.
        Spenden
        • M
          M
          muuulle
          #1426
          Moin,
          die Version funktioniert sehr gut!
          Ich vermisse für den Screensaver noch eine Option, dass sich Icons aufgrund von Bedingungen ändern können (bspw. geänderter Ladestand einer Batterie oder Anzeige, ob eine Entnahme oder Beladung erfolgt).
          Vielen Dank für eure Arbeit! 👍
          • T
            T
            ticaki
            #1427
            ich weiß ja nicht ob nicht das hier meinst: (super mehrfach verneinungen) :D
            EDIT:
            Ah du meinst weil es gibt keine Icons für true und false?
            @tt-tom das lass ich mal für ich, das müsste ja ordentlich ins layout passen
            Spenden
            • M muuulle
              Moin,
              T
              T
              TT-Tom
              #1428
              @muuulle
              Ladestand kannst du mit der Version machen die @ticaki gezeigt hat. Laden / Entladen entweder True/False verschiedene Icon oder mit Bedingung Icon anzeigen/ausblenden.
              Oder habe ich das Thema falsch verstanden.
              Gruß Tom
              Public Transport
              NSPanel Adapter Dokumentation
              https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/
              • M
                M
                muuulle
                #1429
                Perfekt, nein, richtig verstanden 👍
                • C
                  C
                  claus1993
                  #1430
                  Hey,
                  möchte den Media Player einbinden, bekomme jedoch die Meldung dass die ID zu keinem unterstützten Adapter gehört.
                  In dem Alias sind die DP aus meinem MPD Player hinterlegt.
                  Bin noch neu was das NS Panel betrifft und kann nicht sehen wo mein Fehler liegt oder ob es sich hier um einen Bug handelt.
                  Danke und Grüße
                  • C claus1993
                    Hey,
                    Danke und Grüße
                    T
                    T
                    TT-Tom
                    #1431
                    @claus1993
                    Du brauchst für den Player keinen Alias.
                    Du musst den Adapter Instanz direkt auswählen.
                    Edit. Wenn du dir die Einstellungen genauer anschaust, da steht dein Beispiel auch.
                    Gruß Tom
                    Public Transport
                    C 1 Antwort Letzte Antwort
                    • T
                      T
                      ticaki
                      #1432
                      @claus1993
                      ab der version hier werden nur noch unterstützte Player channel angezeigt und wegen bug im admin in einer normalen auflistung und nicht so ein Objektbaum.
                      Danke fürs "Bescheid sagen". Auch ein Hä wie soll das gehen, ist eine gute Rückmeldung :)
                      2.0.1 (2026-11-01)
                      • (ticaki) screensaver editor: areas with more items than places page with arrows instead of hiding the extra items, they are no longer reported as "no place in this version"; items with a condition (enabled / visible condition, also in raw data) are marked
                      • (ticaki) admin: the "..." button of the media page player opens a list of all players found (alexa2 Echo devices, sonos speakers, squeezebox players, spotify-premium/mpd instances) grouped by adapter with search instead of the object tree; the id can still be typed by hand
                      • (ticaki) admin: screensaver items show readable names (headline, object name or template name) instead of regex fragments; the full name is in the tooltip
                      • (ticaki) admin: a script weather instance with a trailing dot (pirate-weather.0.) is recognized as installed and saved without the dot
                      Spenden
                      • patricknitschP
                        patricknitschP
                        patricknitsch
                        schrieb am zuletzt editiert von patricknitsch
                        #1433
                        Wegen der Textgröße habe ich noch mal geschaut. Bei den Card Types funktioniert das gut. Ist scheinbar nur ein Thema bei den Page Items in der thermoCard.
                        Noch eine Frage:
                        Für was ist eigenlich die Wertanzeige Konfiguration? Wenn ich das in einer Liste z.B teste, zeigt es immer nur den Namen an. Eigentlich sollte doch dann angezeigt werden, was unten in der Vorschau angezeigt wird. Oder übersehe ich da etwas?
                        Systeme:
                        • T
                          T
                          ticaki
                          #1434
                          hab mal Claude nach der wertkonfiguration gefragt, weiß selbst nicht mehr genau was die macht - da muß ich noch tiefer ein aber die antwort war:
                          ▎ Danke für die Bilder. Die Textgröße bei den Thermo-Items haben wir am echten Panel nachgestellt: Icons gibt es nur in den Fonts 1, 3 und 4. Mit
                          ▎ Größe 0, 2 oder 5 bleibt ein Icon leer, und Font 5 kann nur ASCII (kein °, keine Umlaute). Der Admin wird die Auswahl für Icons entsprechend
                          ▎ einschränken und erklären.
                          ▎ Die „Wertanzeige-Konfiguration“ hinter dem „…“ am Namen ist unglücklich benannt. Sie baut einen dynamischen Namen aus einem State (Präfix + Wert +
                          ▎ Suffix) und wird nur verwendet, wenn das Feld Name leer ist. Bei dir steht ein Name drin, deshalb siehst du nur den. Den angezeigten Wert selbst
                          ▎ stellst du über das Zahnrad neben der Channel-/State-ID ein. Dass Einheit und Datumsformat aus diesem Dialog derzeit nicht beim Panel ankommen,
                          ▎ obwohl die Vorschau sie zeigt, ist ein Fehler, den beheben wir.
                          und das webpanel kann aktuell keine fontsize bei cardThermo2 - das wird auch gefixt - und die wertekonfiguration wird bei cardThermo und cardMedia entfernt - da gibts afaik keine namen.
                          Spenden
                          • patricknitschP
                            patricknitschP
                            patricknitsch
                            #1435
                            Bestätige ich. Funktioniert auch in den PageItems in der thermoCard. Mein Problem war, dass ich die Größe auf "Default" gelassen habe. 0 ist aber nochmal kleiner und genau das, was ich eigentlich haben wollte. Webpanel, wie von dir gesagt, geht nicht.
                            Wertanzeige funktioniert auch, nachdem ich den Namen entfernt habe.
                            Ich hab die Hühner am Sonntag fast umsonst aufgescheucht 😆
                            Systeme:
                            • patricknitschP patricknitsch
                              T
                              T
                              ticaki
                              #1436
                              @patricknitsch
                              Ich hab meine Vermutung zu der Wertekonfiguration (die heißt demnächsst dynamischer Name) bestätigen lassen - auf cardThermo2 oder cardMedia sieht man den inhalt nur oben im Popup als Headline. Überall sonst ist es der text unterhalb der icons auf cardGrid und bei entities sollte es klar sein.
                              Spenden
                              • T ticaki
                                EDIT:
                                M
                                M
                                muuulle
                                #1437
                                EDIT:
                                Moin,
                                das trifft genau den Punkt. Ich habe gerade nachgeguckt, wo finde ich die Einstellung?
                                • T
                                  T
                                  ticaki
                                  #1438
                                  der button ist im expert modus versteckt das, um das beim normalen bedienen nicht zu sehr zu überladen. hmmm
                                  EDIT: ich mache das anders - es gibt nur 2 option hinter expert und die stören nicht auch wenn sie eingeblendet werden
                                  Spenden
                                  • T
                                    T
                                    ticaki
                                    #1439
                                    2.0.2 (2026-11-01)
                                    • (ticaki) admin: page item text size shows the pixel size of each font; icons only offer fonts 1, 3 and 4 (the others have no icons), font 5 is marked "ASCII only"
                                    • (ticaki) admin: the "..." button next to the item name is now "Dynamic name" (used only while the name is empty) and no longer offers unit and date format, which were ignored
                                    • (ticaki) admin: on cardThermo2 and cardMedia the name field notes that the name is only the popup title
                                    • (ticaki) admin: screensaver item dialog: "icon per value range" and the visibility settings are available without expert mode
                                    • (ticaki) web panel: the font ¬<n> of page items works on every card; cardThermo2 uses the slot sizes and positions of the HMI
                                    Spenden
                                    • T TT-Tom
                                      @claus1993
                                      C
                                      C
                                      claus1993
                                      #1440
                                      @TT-Tom said:
                                      @claus1993
                                      Danke @tt-tom
                                      Wollte den Ordner über die Objektstruktur auswählen, dort wird der Ordner "MOD.0" jedoch nicht angezeigt. Habe es dann manuell eingetragen und dann hat es gepasst.
                                      • C claus1993
                                        @TT-Tom said:
                                        @claus1993
                                        Danke @tt-tom
                                        T
                                        T
                                        TT-Tom
                                        #1441
                                        @claus1993
                                        mit dem Release 2.0.1 sollte der Bug behoben sein, siehe hier.
                                        https://forum.iobroker.net/post/1361316
                                        wenn irgendwas nicht verständlich ist, immer Bescheid geben damit wir es auch optimieren können.
                                        Die Doku wird nebenbei nach gezogen, ich hoffen nächstes WE dann das WIKI auf den neusten Stand zu heben.
                                        Dann wird das die neue Anlaufstelle zum Lesen.
                                        Gruß Tom
                                        Public Transport
                                        • T
                                          T
                                          TT-Tom
                                          #1442
                                          Wir ziehen in einen neuen Thread
                                          Test Adapter NSPanel-lovelace-ui v2.x.x
                                          Bitte stellt hier alle weiteren Fragen. Mit dem Sprung auf Version 2.x.x hat sich die ganze Konfiguration und Möglichkeiten des Adapters geändert.
                                          Danke für euer Feedback und das mit testen, zusammen haben wir das geschaffen was der Adapter heute mit dem Panel alles kann.
                                          vielen Dank von uns an Euch.
                                          Gruß Tom
                                          Public Transport
                                          84.2k
