  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. EVCC Version Update
EVCC Version Update
13 Beiträge 3 Kommentatoren 419 Aufrufe 3 Beobachtet
  • K
    K
    Karl-Heinz1
    das ist dort rausgekommen:
    sudo apt update
    [sudo] password for karl-heinz:
    Get:1 http://deb.debian.org/debian trixie InRelease [140 kB]
    Get:2 http://archive.raspberrypi.com/debian trixie InRelease [54.9 kB]
    Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
    Get:4 http://deb.debian.org/debian-security trixie-security InRelease [43.4 kB]
    Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian trixie InRelease [11.7 kB]
    Get:6 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Get:7 http://deb.debian.org/debian trixie/main armhf Packages [9,246 kB]
    Get:8 http://archive.raspberrypi.com/debian trixie/main armhf Packages [479 kB]
    Get:9 https://dl.evcc.io/public/evcc/stable/deb/debian trixie/main armhf Packages [34.4 kB]
    Get:10 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [12.5 kB]
    Get:11 https://dl.evcc.io/public/evcc/stable/deb/debian trixie/main arm64 Packages [34.4 kB]
    Get:12 http://archive.raspberrypi.com/debian trixie/main arm64 Packages [491 kB]
    Get:13 http://deb.debian.org/debian trixie/main arm64 Packages [9,614 kB]
    Get:14 http://deb.debian.org/debian trixie/main Translation-en [6,486 kB]
    Get:15 http://deb.debian.org/debian trixie/contrib armhf Packages [42.6 kB]
    Get:16 http://deb.debian.org/debian trixie/contrib arm64 Packages [48.4 kB]
    Get:17 http://deb.debian.org/debian-security trixie-security/main armhf Packages [245 kB]
    Get:18 http://deb.debian.org/debian-security trixie-security/main arm64 Packages [266 kB]
    Get:19 http://deb.debian.org/debian-security trixie-security/main Translation-en [163 kB]
    Get:20 http://deb.debian.org/debian-security trixie-security/contrib arm64 Packages [3,152 B]
    Get:21 http://deb.debian.org/debian-security trixie-security/contrib armhf Packages [3,148 B]
    Fetched 27.5 MB in 6s (4,535 kB/s)
    212 packages can be upgraded. Run 'apt list --upgradable' to see them.
    Notice: Repository 'http://deb.debian.org/debian trixie InRelease' changed its 'Version' value from '13.6' to '13.7'
    karl-heinz@meinbroker:~ $ apt policy evcc
    evcc:
      Installed: 0.315.0
      Candidate: 0.316.2
      Version table:
         0.316.2 500
            500 https://dl.evcc.io/public/evcc/stable/deb/debian trixie/main arm64 Packages
         0.316.1 500
         0.316.0 500
         0.315.2 500
     *** 0.315.0 500
         0.314.5 500
         0.314.4 500
         0.314.3 500
         0.314.2 500
         0.314.1 500
         0.313.3 500
         0.313.2 500
         0.313.1 500
         0.313.0 500
         0.312.1 500
         0.312.0 500
         0.311.1 500
         0.311.0 500
         0.310.1 500
         0.310.0 500
         0.309.2 500
    lines 1-47
    • K Karl-Heinz1
      sudo apt update
      evcc:
        Installed: 0.315.0
        Candidate: 0.316.2
        Version table:
           0.316.2 500
           0.316.1 500
           0.316.0 500
           0.315.2 500
       *** 0.315.0 500
           0.314.5 500
           0.314.4 500
           0.314.3 500
           0.314.2 500
           0.314.1 500
           0.313.3 500
           0.313.2 500
           0.313.1 500
           0.313.0 500
           0.312.1 500
           0.312.0 500
           0.311.1 500
           0.311.0 500
           0.310.1 500
           0.310.0 500
           0.309.2 500
      lines 1-47
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @Karl-Heinz1 sagte:
      Dann DRINGEND ran!!!!!!!
      Also
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      Das ganze dann regelmäßiger machen, so mindestens einmal im Monat, besser häufiger.
      • K
        K
        Karl-Heinz1
        Das mache ich jetzt einmal im Monat.
        was kann ich denn machen, das mir die USB/485 Adapter bei der device Zuordnung nicht immer durcheinander gewürfelt werden.
        ich habe diese 2 Anzeigen wenn ich die 2 verschiedenen Abfragen eingebe:
         $ ls -l /dev/serial/by-id/
        total 0
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0 -> ../../ttyUSB2
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0 -> ../../ttyUSB1
        $ ls -l /dev/serial/by-path/
        total 0
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1.1:1.0-port0 -> ../../ttyUSB1
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1.2:1.0-port0 -> ../../ttyUSB2
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1.3:1.0-port0 -> ../../ttyUSB4
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0-port0 -> ../../ttyUSB0
        lrwxrwxrwx 1 root root 13 Oct  8 12:20 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-port0 -> ../../ttyUSB3
        • K Karl-Heinz1
          total 0
          total 0
          Thomas BraunT
          Thomas BraunT
          @Karl-Heinz1 sagte:
          In dem man in den Adaptern NICHT direkt auf das Device geht (z. B. /dev/ttyUSB0) sondern den Link 'by-id' dort einträgt. Der zeigt nämlich immer auf das entsprechende Gerät, egal wo das tatsächlich von udev/dem Kernel hingehängt wird.
          • K Karl-Heinz1
            Es soll demnächst die Version 0.316.3 von EVCC geben, ist das unten richtig ?
            erst:
            sudo apt update
            und dann
            sudo apt --only-upgrade install -y evcc
            LG Karl-Heinz
            Samson71S
            Samson71S
            Samson71
            @Karl-Heinz1 sagte:
            Aktuell ist die 0.316.1 (stable) - wie bist Du an die gekommen?
            Selbst wenn Du noch eine 0.315.x laufen hast (0.316.0 enthält einige breaking changes) muss die ja auch mal installiert/upgedatet worden sein.
            IMHO gehört die Frage eigentlich auch eher ins EVCC-Forum oder dort ins GitHub als hier ins Forum. Das Update von EVCC hat mit "Einbindung von Geräten" wohl eher nichts zu tun.
            Ein Blick in die offizielle Doku von EVCC hilft auch.
            Markus
            Bitte beachten:
            • Samson71S Samson71
              @Karl-Heinz1 sagte:
              Thomas BraunT
              Thomas BraunT
              @Samson71
              Installiert ist zur Zeit:
               *** 0.315.0 500
              Aktuellere Versionen von evcc (hier 0.316.2) verstecken sich in den 212 in der Pipeline hängenden Updates:
              evcc:
                Installed: 0.315.0
                Candidate: 0.316.2
              Change logs sollte man natürlich lesen.
              • K
                K
                Karl-Heinz1
                Ja, OK ich will hier nicht nerven. Nur noch mal zu der Device Zeile.
                bei ls -l /dev/serial/by-id/ werden mir nur 3 USB Adapter gezeigt siehe oben #5
                Deshalb habe ich
                ls -l /dev/serial/by-path/ genommen, dann sehe ich alle 5 Adapter. siehe oben #5
                Sollte ich die zwei tauschen, welche sollte ich dann kaufen ?
                • K Karl-Heinz1
                  Deshalb habe ich
                  Thomas BraunT
                  Thomas BraunT
                  @Karl-Heinz1
                  Was ist denn das genau an Hardware da? 3 USB-Stöckchen? Die werden wie schon geschrieben am besten über /serial/by-id/ angesprochen. Dann kann es dir nämlich egal sein, wie die über den pcie-Bus laufen.
                  Und die anderen 2 Geräte sind genau was und wie?
                  • K
                    K
                    Karl-Heinz1
                    Es sind 3 Growatt Wechselrichter und 2 Heidelberg Wallboxen.
                    • K Karl-Heinz1
                      Thomas BraunT
                      Thomas BraunT
                      @Karl-Heinz1
                      Die 3 Growatt sind dann per USB-Stick angebunden und die Heidelberg Boxen?
                      • K
                        K
                        Karl-Heinz1
                        Ja auch genauso. Insgesamt 5 USB/485 Adapter, funktioniert ganz gut, bis eben jetzt wird der neue ID5 nicht ausgelesen, BMW und Fiat aber schon. Ich warte da mal das nächste Upgrade ab.
                        84.2k
