  4. IOBroker node js update hat nicht funktioniert
    apollon77A
7 Beiträge 4 Kommentatoren 114 Aufrufe 4 Beobachtet
  • E
    E
    Ecki
    Hallo, nach dem Update des Systems hat sich ode wohl komplett zerschossen. Hier das log von iob diag:
    ```bash
    Script v.2026-08-30
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.109+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 1023 days ago (on 2023-12-11).
    Systemuptime and Load:
     09:08:12 up 15:58,  3 users,  load average: 0.26, 0.09, 0.03
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-09-29 09:08:12 CEST
               Universal time: Tue 2026-09-29 07:08:12 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    ecki
    HOME=/home/ecki
    GROUPS=ecki adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            4.0G        321M        3.1G        1.2M        664M        3.7G
    Swap:           209M          0B        209M
    Total:          4.2G        321M        3.3G
    Active iob-Instances:   0
             3796 M total memory
              306 M used memory
              328 M active memory
              398 M inactive memory
             2926 M free memory
              118 M buffer memory
              515 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 09:08:12 up 15:58,  3 users,  load average: 0.26, 0.09, 0.03
    Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.7 total,   2926.0 free,    306.7 used,    633.6 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3490.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.2M  759M   1% /run
    /dev/mmcblk0p2 ext4       29G   12G   16G  44% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   67M  444M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    Messages concerning filesystems in dmesg (Last 15 lines only):
    [Mon Sep 28 17:09:59 2026] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
    [Mon Sep 28 17:10:01 2026] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.4G    /var/
    3.3G    /var/lib
    3.2G    /var/lib/mysql
    3.0G    /var/lib/mysql/iobroker
    1.1G    /var/cache
    Archived and active journals take up 827.3M in the file system.
    /opt/iobroker/backups:
    1.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    470M    /opt/iobroker/iobroker-data/
    180M    /opt/iobroker/iobroker-data/files
    155M    /opt/iobroker/iobroker-data/history
    82M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    50M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    *** Node.js is NOT correctly installed ***
    Issues:  nodejs path x node path x npm path x npx path
    Execute 'iob nodejs-update' in your terminal.
    nodejs:
      Installed: (none)
      Candidate: 18.20.4+dfsg-1~deb12u2
      Version table:
         18.20.4+dfsg-1~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    sudo: node: command not found
    Hosts:
    Core adapters versionssudo: node: command not found
    js-controller:  sudo: node: command not found
    admin:          sudo: node: command not found
    javascript:
    nodejs modules from github:     0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Adapters
    ioBroker-Adapter Versions and update status
    Objects and States
    Objects:        0
    States:         0
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Reading package lists...
    Pending systemupdates: 1
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=530,fd=12))
    udp   UNCONN 0      0                          0.0.0.0:35823              0.0.0.0:*    users:(("avahi-daemon",pid=530,fd=14))
    udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=530,fd=13))
    udp   UNCONN 0      0      [fe80::819a:c2ee:b178:c084]:dhcpv6-client            *:*    users:(("NetworkManager",pid=634,fd=38))
    udp   UNCONN 0      0      [fe80::a68a:30ea:c4de:a918]:dhcpv6-client            *:*    users:(("NetworkManager",pid=634,fd=31))
    udp   UNCONN 0      0                                *:39682                    *:*    users:(("avahi-daemon",pid=530,fd=15))
    tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=737,fd=3))
    tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=737,fd=4))
    tcp   LISTEN 0      4096                             *:mysql                    *:*    users:(("mariadbd",pid=746,fd=5),("systemd",pid=1,fd=59))
    2026-09-28 15:30:30.477  - info: host.raspberrypi instance system.adapter.weishaupt-wem.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.477  - info: host.raspberrypi instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.478  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.sma-em.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.easee.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.480  - info: host.raspberrypi instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.480  - info: host.raspberrypi instance system.adapter.device-reminder.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.487  - info: sql.0 (994) terminating
    2026-09-28 15:30:30.489  - info: sql.0 (994) Terminated (NO_ERROR): Without reason
    2026-09-28 15:30:30.657  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:30.658  - warn: host.raspberrypi instance system.adapter.javascript.0 terminated due to SIGKILL
    2026-09-28 15:30:30.659  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code null ()
    2026-09-28 15:30:30.659  - warn: host.raspberrypi instance system.adapter.telegram.0 terminated due to SIGKILL
    2026-09-28 15:30:30.659  - info: host.raspberrypi instance system.adapter.telegram.0 terminated with code null ()
    2026-09-28 15:30:30.659  - warn: host.raspberrypi instance system.adapter.shelly.0 terminated due to SIGKILL
    2026-09-28 15:30:30.660  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code null ()
    2026-09-28 15:30:30.660  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGKILL
    2026-09-28 15:30:30.660  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
    2026-09-28 15:30:30.660  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL
    2026-09-28 15:30:30.660  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
    2026-09-28 15:30:31.052  - info: host.raspberrypi instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
    2026-09-28 15:30:31.052  - info: host.raspberrypi All instances are stopped.
    2026-09-28 15:30:31.240  - info: host.raspberrypi terminated
    Was kann ich hier tun?
     node -v
    -bash: node: Kommando nicht gefunden.
    Das macht mich etwas ratlos...
    Danke für Eure Hilfe!
    crunchipC Thomas BraunT 3 Antworten Letzte Antwort
    • E Ecki
      ```bash
      Script v.2026-08-30
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      ecki
      HOME=/home/ecki
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               3796 M total memory
                306 M used memory
                328 M active memory
               2926 M free memory
                118 M buffer memory
                515 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      5.4G    /var/
      3.3G    /var/lib
      3.2G    /var/lib/mysql
      1.1G    /var/cache
      USB-Devices by-id:
      nodejs:
        Installed: (none)
        Version table:
      ioBroker Status
      Hosts:
      javascript:
      Adapter State
      Objects and States
      Objects:        0
      States:         0
       node -v
      crunchipC
      crunchipC
      Developer Global Moderator Most Active Forum Testing
      @Ecki was und wie wolltest du denn updaten?
      • E Ecki
        ```bash
        Script v.2026-08-30
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Unknown
        Kernel          : aarch64
        Userland        : 64bit
        CPU threads     : 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        ecki
        HOME=/home/ecki
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 3796 M total memory
                  306 M used memory
                  328 M active memory
                 2926 M free memory
                  118 M buffer memory
                  515 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        5.4G    /var/
        3.3G    /var/lib
        3.2G    /var/lib/mysql
        1.1G    /var/cache
        USB-Devices by-id:
        nodejs:
          Installed: (none)
          Version table:
        ioBroker Status
        Hosts:
        javascript:
        Adapter State
        Objects and States
        Objects:        0
        States:         0
         node -v
        crunchipC
        crunchipC
        @Ecki sagte:
        GNU/Linux 12 (bookworm)
        https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
          @Ecki sagte:
          haselchenH
          haselchenH
          haselchen
          @ecki
          Node ist bei Dir nicht korrekt installiert.
          nodejs:
            Installed: (none)
          die dfsg Version wäre auch die Falsche.
          • E Ecki
            ```bash
            Script v.2026-08-30
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Unknown
            Kernel          : aarch64
            Userland        : 64bit
            CPU threads     : 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            ecki
            HOME=/home/ecki
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           209M          0B        209M
                     3796 M total memory
                      306 M used memory
                      328 M active memory
                     2926 M free memory
                      118 M buffer memory
                      515 M swap cache
                      199 M total swap
                        0 M used swap
                      199 M free swap
            *** FILESYSTEM ***
            /var:
            5.4G    /var/
            3.3G    /var/lib
            3.2G    /var/lib/mysql
            1.1G    /var/cache
            USB-Devices by-id:
            nodejs:
              Installed: (none)
              Version table:
            ioBroker Status
            Hosts:
            javascript:
            Adapter State
            Objects and States
            Objects:        0
            States:         0
             node -v
            Thomas BraunT
            Thomas BraunT
            @Ecki
            Wie wurde das Update vorgenommen? Welche Meldungen gab es?
            Wenn per
            iob nodejs-update
            dann lass es einfach jetzt nochmal laufen.
            Steht ja auch so im diag output drin:
            Am Rande:
            Bring das Betriebssystem in Bälde auf RaspberryOS 13 'Trixie'
            • E
              E
              Ecki
              Ich Vollp*****n... Habe iob nodejs-update falsch geschrieben.
              Läuft..
              Danke!
              • E Ecki
                Läuft..
                Danke!
                Thomas BraunT
                Thomas BraunT
                @Ecki sagte:
                Dann passiert genau gar nichts:
                [thomas@roamer ~]$ iob nodesf-update
                bash: iob: Kommando nicht gefunden
                [thomas@roamer ~]$
                Edit: Uuuuuuuuups, falscher Host... Auf einem System mit installiertem ioBroker erscheint bei einem unbekannten Argument die Hilfe.
                83.9k
