<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IOBroker node js update hat nicht funktioniert]]></title><description><![CDATA[<p dir="auto">Hallo, nach dem Update des Systems  hat sich ode wohl komplett zerschossen. Hier das log von iob diag:</p>
<pre><code>```bash
Script v.2026-08-30
*** BASE SYSTEM ***
 Static hostname: raspberrypi
       Icon name: computer
          Kernel: Linux 6.12.109+rpt-rpi-v8
    Architecture: arm64
OS is similar to:
Model           : Raspberry Pi 4 Model B Rev 1.5
Docker          : false
Virtualization  : none
Unknown
Kernel          : aarch64
Userland        : 64bit
System was installed 1023 days ago (on 2023-12-11).
Systemuptime and Load:
 09:08:12 up 15:58,  3 users,  load average: 0.26, 0.09, 0.03
CPU threads     : 4
*** LIFE CYCLE STATUS ***
Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
               Local time: Tue 2026-09-29 09:08:12 CEST
           Universal time: Tue 2026-09-29 07:08:12 UTC
                 RTC time: n/a
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
ecki
HOME=/home/ecki
GROUPS=ecki adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
js-controller is not running
*** DISPLAY-SERVER SETUP ***
Display-Server:         Unknown
Display-Manager:        Not found
Desktop:
Session:                tty
Boot Target:            multi-user.target
*** MEMORY ***
Mem:            4.0G        321M        3.1G        1.2M        664M        3.7G
Swap:           209M          0B        209M
Total:          4.2G        321M        3.3G
Active iob-Instances:   0
         3796 M total memory
          306 M used memory
          328 M active memory
          398 M inactive memory
         2926 M free memory
          118 M buffer memory
          515 M swap cache
          199 M total swap
            0 M used swap
          199 M free swap
top - 09:08:12 up 15:58,  3 users,  load average: 0.26, 0.09, 0.03
Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   3796.7 total,   2926.0 free,    306.7 used,    633.6 buff/cache
MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3490.1 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  1.6G     0  1.6G   0% /dev
tmpfs          tmpfs     760M  1.2M  759M   1% /run
/dev/mmcblk0p2 ext4       29G   12G   16G  44% /
tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
/dev/mmcblk0p1 vfat      510M   67M  444M  13% /boot/firmware
tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
Messages concerning filesystems in dmesg (Last 15 lines only):
[Mon Sep 28 17:09:59 2026] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
[Mon Sep 28 17:10:01 2026] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w.
Show mounted filesystems:
TARGET           SOURCE         FSTYPE OPTIONS
/                /dev/mmcblk0p2 ext4   rw,noatime
`-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
5.4G    /var/
3.3G    /var/lib
3.2G    /var/lib/mysql
3.0G    /var/lib/mysql/iobroker
1.1G    /var/cache
Archived and active journals take up 827.3M in the file system.
/opt/iobroker/backups:
1.5G    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
470M    /opt/iobroker/iobroker-data/
180M    /opt/iobroker/iobroker-data/files
155M    /opt/iobroker/iobroker-data/history
82M     /opt/iobroker/iobroker-data/backup-objects
47M     /opt/iobroker/iobroker-data/files/admin.admin
50M     /opt/iobroker/iobroker-data/objects.jsonl
27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
No Devices found 'by-id'
No nvbackup.json found.
*** NodeJS-Installation ***
*** Node.js is NOT correctly installed ***
Issues:  nodejs path x node path x npm path x npx path
Execute 'iob nodejs-update' in your terminal.
nodejs:
  Installed: (none)
  Candidate: 18.20.4+dfsg-1~deb12u2
  Version table:
     18.20.4+dfsg-1~deb12u2 500
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
sudo: node: command not found
Hosts:
Core adapters versionssudo: node: command not found
js-controller:  sudo: node: command not found
admin:          sudo: node: command not found
javascript:
nodejs modules from github:     0
Adapter State
ioBroker-Repositories
Installed ioBroker-Adapters
ioBroker-Adapter Versions and update status
Objects and States
Objects:        0
States:         0
Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Reading package lists...
Pending systemupdates: 1
*** Listening Ports ***
Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=530,fd=12))
udp   UNCONN 0      0                          0.0.0.0:35823              0.0.0.0:*    users:(("avahi-daemon",pid=530,fd=14))
udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=530,fd=13))
udp   UNCONN 0      0      [fe80::819a:c2ee:b178:c084]:dhcpv6-client            *:*    users:(("NetworkManager",pid=634,fd=38))
udp   UNCONN 0      0      [fe80::a68a:30ea:c4de:a918]:dhcpv6-client            *:*    users:(("NetworkManager",pid=634,fd=31))
udp   UNCONN 0      0                                *:39682                    *:*    users:(("avahi-daemon",pid=530,fd=15))
tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=737,fd=3))
tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=737,fd=4))
tcp   LISTEN 0      4096                             *:mysql                    *:*    users:(("mariadbd",pid=746,fd=5),("systemd",pid=1,fd=59))
2026-09-28 15:30:30.477  - info: host.raspberrypi instance system.adapter.weishaupt-wem.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.477  - info: host.raspberrypi instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.478  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.sma-em.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.479  - info: host.raspberrypi instance system.adapter.easee.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.480  - info: host.raspberrypi instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.480  - info: host.raspberrypi instance system.adapter.device-reminder.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.487  - info: sql.0 (994) terminating
2026-09-28 15:30:30.489  - info: sql.0 (994) Terminated (NO_ERROR): Without reason
2026-09-28 15:30:30.657  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:30.658  - warn: host.raspberrypi instance system.adapter.javascript.0 terminated due to SIGKILL
2026-09-28 15:30:30.659  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code null ()
2026-09-28 15:30:30.659  - warn: host.raspberrypi instance system.adapter.telegram.0 terminated due to SIGKILL
2026-09-28 15:30:30.659  - info: host.raspberrypi instance system.adapter.telegram.0 terminated with code null ()
2026-09-28 15:30:30.659  - warn: host.raspberrypi instance system.adapter.shelly.0 terminated due to SIGKILL
2026-09-28 15:30:30.660  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code null ()
2026-09-28 15:30:30.660  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGKILL
2026-09-28 15:30:30.660  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
2026-09-28 15:30:30.660  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL
2026-09-28 15:30:30.660  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
2026-09-28 15:30:31.052  - info: host.raspberrypi instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
2026-09-28 15:30:31.052  - info: host.raspberrypi All instances are stopped.
2026-09-28 15:30:31.240  - info: host.raspberrypi terminated
</code></pre>
<pre><code>Was kann ich hier tun?
 node -v
-bash: node: Kommando nicht gefunden.
Das macht mich etwas ratlos...
Danke für Eure Hilfe!</code></pre>
]]></description><link>https://forum.iobroker.net/topic/85464/iobroker-node-js-update-hat-nicht-funktioniert</link><generator>RSS for Node</generator><lastBuildDate>Tue, 29 Sep 2026 13:52:17 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85464.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Sep 2026 07:52:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IOBroker node js update hat nicht funktioniert on Tue, 29 Sep 2026 11:38:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ecki" aria-label="Profile: Ecki">@<bdi>Ecki</bdi></a> <a href="/post/1356741">sagte</a>:</p>
<p dir="auto">Habe iob nodejs-update falsch geschrieben.</p>
</blockquote>
<p dir="auto">Dann passiert genau gar nichts:</p>
<pre><code>[thomas@roamer ~]$ iob nodesf-update
bash: iob: Kommando nicht gefunden
[thomas@roamer ~]$
</code></pre>
<p dir="auto">Edit: Uuuuuuuuups, falscher Host... Auf einem System mit installiertem ioBroker erscheint bei einem unbekannten Argument die Hilfe.</p>
]]></description><link>https://forum.iobroker.net/post/1356742</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356742</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 29 Sep 2026 11:38:36 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker node js update hat nicht funktioniert on Tue, 29 Sep 2026 11:18:33 GMT]]></title><description><![CDATA[<p dir="auto">Ich Vollp*****n... Habe iob nodejs-update falsch geschrieben.<br />
Läuft..<br />
Danke!</p>
]]></description><link>https://forum.iobroker.net/post/1356741</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356741</guid><dc:creator><![CDATA[Ecki]]></dc:creator><pubDate>Tue, 29 Sep 2026 11:18:33 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker node js update hat nicht funktioniert on Tue, 29 Sep 2026 10:01:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ecki" aria-label="Profile: Ecki">@<bdi>Ecki</bdi></a></p>
<p dir="auto">Wie wurde das Update vorgenommen? Welche Meldungen gab es?<br />
Wenn per</p>
<pre><code>iob nodejs-update
</code></pre>
<p dir="auto">dann lass es einfach jetzt nochmal laufen.<br />
Steht ja auch so im diag output drin:</p>
<blockquote>
<p dir="auto">Execute 'iob nodejs-update' in your terminal.</p>
</blockquote>
<p dir="auto">Am Rande:<br />
Bring das Betriebssystem in Bälde auf RaspberryOS 13 'Trixie'</p>
]]></description><link>https://forum.iobroker.net/post/1356730</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356730</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 29 Sep 2026 10:01:37 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker node js update hat nicht funktioniert on Tue, 29 Sep 2026 09:53:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ecki" aria-label="Profile: ecki">@<bdi>ecki</bdi></a></p>
<p dir="auto">Node ist bei Dir nicht korrekt installiert.</p>
<pre><code>nodejs:
  Installed: (none)
</code></pre>
<p dir="auto">die dfsg Version wäre auch die Falsche.</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/68035/iob-node-fix-skript">https://forum.iobroker.net/topic/68035/iob-node-fix-skript</a></p>
]]></description><link>https://forum.iobroker.net/post/1356728</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356728</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Tue, 29 Sep 2026 09:53:17 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker node js update hat nicht funktioniert on Tue, 29 Sep 2026 09:00:14 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ecki" aria-label="Profile: Ecki">@<bdi>Ecki</bdi></a> <a href="/post/1356714">sagte</a>:</p>
<p dir="auto">GNU/Linux 12 (bookworm)</p>
</blockquote>
<p dir="auto"><a href="https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie">https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie</a></p>
]]></description><link>https://forum.iobroker.net/post/1356721</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356721</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 29 Sep 2026 09:00:14 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker node js update hat nicht funktioniert on Tue, 29 Sep 2026 07:56:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ecki" aria-label="Profile: Ecki">@<bdi>Ecki</bdi></a> was und wie wolltest du denn updaten?</p>
]]></description><link>https://forum.iobroker.net/post/1356715</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356715</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 29 Sep 2026 07:56:33 GMT</pubDate></item></channel></rss>
