EVCC wird nicht grün
Das ist das Ergebnis von iob diag
Ob iob diag funktioniert muss du jetzt sagen. Ich mache jetzt nichts, warte ab, was ich tun soll.
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: meinbroker Icon name: computer Kernel: Linux 6.18.39+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 400 Rev 1.1 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 81 days ago (on 2026-06-18). Systemuptime and Load: 19:57:19 up 2:22, 3 users, load average: 0.81, 0.38, 0.36 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Mon 2026-09-07 19:57:20 CEST Universal time: Mon 2026-09-07 17:57:20 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': karl-heinz HOME=/home/karl-heinz GROUPS=karl-heinz adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: * lightdm.service - Light Display Manager Desktop: Session: tty Boot Target: graphical.target System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix' *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 2.8G 367M 34M 908M 1.2G Swap: 2.1G 0B 2.1G Total: 6.1G 2.8G 2.5G Active iob-Instances: 22 3795 M total memory 2698 M used memory 1917 M active memory 1188 M inactive memory 349 M free memory 115 M buffer memory 750 M swap cache 2047 M total swap 0 M used swap 2047 M free swap *** top - Table Of Processes *** top - 19:57:20 up 2:22, 3 users, load average: 0.81, 0.38, 0.36 Tasks: 221 total, 1 running, 220 sleeping, 0 stopped, 0 zombie %Cpu(s): 2.2 us, 2.2 sy, 0.0 ni, 95.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3795.8 total, 349.7 free, 2698.4 used, 867.2 buff/cache MiB Swap: 2048.0 total, 2048.0 free, 0.0 used. 1097.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 760M 9.3M 750M 2% /run /dev/mmcblk0p2 ext4 29G 12G 16G 44% / tmpfs tmpfs 1.9G 360K 1.9G 1% /dev/shm tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service /dev/mmcblk0p1 vfat 505M 79M 426M 16% /boot/firmware tmpfs tmpfs 1.9G 2.6M 1.9G 1% /tmp tmpfs tmpfs 380M 64K 380M 1% /run/user/1000 tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service Messages concerning filesystems in dmesg (Last 15 lines only): [Mon Sep 7 17:35:12 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [Mon Sep 7 17:35:12 2026] EXT4-fs (mmcblk0p2): mounted filesystem 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 ro with ordered data mode. Quota mode: none. [Mon Sep 7 17:35:15 2026] EXT4-fs (mmcblk0p2): re-mounted 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.5G /var/ 220M /var/lib 216M /var/cache 203M /var/cache/apt 149M /var/lib/apt Archived and active journals take up 8M in the file system. /opt/iobroker/backups: 37M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 885M /opt/iobroker/iobroker-data/ 814M /opt/iobroker/iobroker-data/files 493M /opt/iobroker/iobroker-data/files/javascript.admin 461M /opt/iobroker/iobroker-data/files/javascript.admin/static 460M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 43M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map 24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map 19M /opt/iobroker/iobroker-data/objects.jsonl 19M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map 11M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0 /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0 No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.23.2 /usr/bin/node v22.23.2 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.2-1nodesource1 Candidate: 22.23.2-1nodesource1 Version table: *** 22.23.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.23.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.23.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.3-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main arm64 Packages 500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: meinbroker meinbroker (version: 7.2.2, hostname: meinbroker , alive, uptime: 2569) Core adapters versions js-controller: 7.2.2 admin: 7.8.23 javascript: 8.8.2 nodejs modules from github: 1 +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) Adapter State + system.adapter.admin.0 : admin : meinbroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.backitup.0 : backitup : meinbroker - enabled + system.adapter.chromecast.0 : chromecast : meinbroker - enabled system.adapter.cloud.0 : cloud : meinbroker - disabled + system.adapter.discovery.0 : discovery : meinbroker - enabled + system.adapter.ds18b20.0 : ds18b20 : meinbroker - enabled + system.adapter.echarts.0 : echarts : meinbroker - enabled + system.adapter.evcc.0 : evcc : meinbroker - enabled, port: 7070 system.adapter.flot.0 : flot : meinbroker - disabled + system.adapter.growatt.0 : growatt : meinbroker - enabled + system.adapter.history.0 : history : meinbroker - enabled system.adapter.icons-material-png.0 : icons-material-png : meinbroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : meinbroker - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: meinbroker - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : meinbroker - disabled + system.adapter.iot.0 : iot : meinbroker - enabled + system.adapter.jarvis.0 : jarvis : meinbroker - enabled system.adapter.javascript.0 : javascript : meinbroker - enabled + system.adapter.modbus.0 : modbus : meinbroker - enabled + system.adapter.mqtt.0 : mqtt : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.net-tools.0 : net-tools : meinbroker - enabled + system.adapter.node-red.0 : node-red : meinbroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.pushover.0 : pushover : meinbroker - enabled + system.adapter.shelly.0 : shelly : meinbroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : meinbroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.smartcontrol.0 : smartcontrol : meinbroker - enabled + system.adapter.sonoff.0 : sonoff : meinbroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.telegram.0 : telegram : meinbroker - disabled, port: 8443, bind: 0.0.0.0 system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : meinbroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : meinbroker - disabled system.adapter.vis-justgage.0 : vis-justgage : meinbroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : meinbroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : meinbroker - disabled system.adapter.vis-rgraph.0 : vis-rgraph : meinbroker - disabled system.adapter.vis.0 : vis : meinbroker - enabled + system.adapter.web.0 : web : meinbroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : meinbroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.evcc.0 : evcc : meinbroker - enabled, port: 7070 + system.adapter.mqtt.0 : mqtt : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : meinbroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : meinbroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : meinbroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.0 : web : meinbroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '7.8.23' │ 'none' │ │ 1 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 2 │ 'system.adapter.chromecast' │ 'chromecast' │ '3.4.1' │ 'none' │ │ 3 │ 'system.adapter.cloud' │ 'cloud' │ '5.0.1' │ 'none' │ │ 4 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 5 │ 'system.adapter.ds18b20' │ 'ds18b20' │ '2.0.5' │ 'none' │ │ 6 │ 'system.adapter.echarts' │ 'echarts' │ '1.9.2' │ 'none' │ │ 7 │ 'system.adapter.evcc' │ 'evcc' │ '0.2.4' │ 'none' │ │ 8 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 9 │ 'system.adapter.growatt' │ 'growatt' │ '3.3.1' │ 'none' │ │ 10 │ 'system.adapter.history' │ 'history' │ '3.0.1' │ 'none' │ │ 11 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 12 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 13 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3' │ 'none' │ │ 14 │ 'system.adapter.icons-ultimate-png' │ 'icons-ultimate-png' │ '1.0.1' │ 'none' │ │ 15 │ 'system.adapter.iot' │ 'iot' │ '3.4.2' │ 'none' │ │ 16 │ 'system.adapter.jarvis' │ 'jarvis' │ '3.1.8' │ 'none' │ │ 17 │ 'system.adapter.javascript' │ 'javascript' │ '8.8.2' │ 'none' │ │ 18 │ 'system.adapter.modbus' │ 'modbus' │ '6.3.2' │ 'none' │ │ 19 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.1' │ 'none' │ │ 20 │ 'system.adapter.net-tools' │ 'net-tools' │ '1.0.11' │ 'none' │ │ 21 │ 'system.adapter.node-red' │ 'node-red' │ '5.2.1' │ 'none' │ │ 22 │ 'system.adapter.pushover' │ 'pushover' │ '4.1.0' │ 'none' │ │ 23 │ 'system.adapter.shelly' │ 'shelly' │ '8.2.1' │ 'none' │ │ 24 │ 'system.adapter.simple-api' │ 'simple-api' │ '2.8.0' │ 'none' │ │ 25 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 26 │ 'system.adapter.socketio' │ 'socketio' │ '6.7.1' │ 'none' │ │ 27 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.1.2' │ 'none' │ │ 28 │ 'system.adapter.telegram' │ 'telegram' │ '3.9.0' │ 'none' │ │ 29 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 30 │ 'system.adapter.vis-2-widgets-gauges' │ 'vis-2-widgets-gauges' │ '1.1.0' │ 'none' │ │ 31 │ 'system.adapter.vis-colorpicker' │ 'vis-colorpicker' │ '2.0.3' │ 'none' │ │ 32 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 33 │ 'system.adapter.vis-material-advanced' │ 'vis-material-advanced' │ '1.7.4' │ 'none' │ │ 34 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.9' │ 'none' │ │ 35 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 36 │ 'system.adapter.web' │ 'web' │ '6.3.1' │ 'none' │ │ 37 │ 'system.adapter.ws' │ 'ws' │ '2.6.2' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.0.11 , installed 7.8.23 [Updatable] Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "chromecast" : 4.2.0 , installed 3.4.1 [Updatable] Adapter "cloud" : 6.0.1 , installed 5.0.1 [Updatable] Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "ds18b20" : 3.1.1 , installed 2.0.5 [Updatable] Adapter "echarts" : 3.1.0 , installed 1.9.2 [Updatable] Adapter "evcc" : 0.2.4 , installed 0.2.4 Adapter "growatt" : 3.3.1 , installed 3.3.1 Adapter "history" : 4.0.0 , installed 3.0.1 [Updatable] Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "iot" : 6.0.3 , installed 3.4.2 [Updatable] Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 10.1.3 , installed 8.8.2 [Updatable] Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "modbus" : 8.0.3 , installed 6.3.2 [Updatable] Adapter "mqtt" : 6.1.4 , installed 6.1.1 [Updatable] Adapter "net-tools" : 1.2.3 , installed 1.0.11 [Updatable] Adapter "node-red" : 6.0.7 , installed 5.2.1 [Updatable] Adapter "pushover" : 5.0.0 , installed 4.1.0 [Updatable] Adapter "shelly" : 10.6.1 , installed 8.2.1 [Updatable] Adapter "simple-api" : 3.0.7 , installed 2.8.0 [Updatable] Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 7.1.3 , installed 6.7.1 [Updatable] Adapter "sonoff" : 3.3.0 , installed 3.1.2 [Updatable] Adapter "telegram" : 5.0.5 , installed 3.9.0 [Updatable] Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2-widgets-gauges": 2.0.2, installed 1.1.0 [Updatable] Adapter "vis-colorpicker": 2.1.0 , installed 2.0.3 [Updatable] Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "web" : 8.0.0 , installed 6.3.1 [Updatable] Adapter "ws" : 4.1.0 , installed 2.6.2 [Updatable] Objects and States Please stand by - This may take a while Objects: 4938 States: 4382 *** OS-Repositories and Updates *** W: https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/evcc-stable.asc are ignored as the file has an unsupported filetype. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Failed to fetch https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Some index files failed to download. They have been ignored, or old ones used instead. Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://archive.raspberrypi.com/debian trixie InRelease Hit:4 http://deb.debian.org/debian-security trixie-security InRelease Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian trixie InRelease Get:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease Err:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. Fetched 23.4 kB in 0s (71.0 kB/s) Reading package lists... W: https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/evcc-stable.asc are ignored as the file has an unsupported filetype. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Failed to fetch https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Some index files failed to download. They have been ignored, or old ones used instead. Pending systemupdates: 10 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.chromecast.0",pid=4395,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("evcc",pid=1461,fd=22)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("evcc",pid=1461,fd=3)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("avahi-daemon",pid=708,fd=12)) udp UNCONN 0 0 0.0.0.0:56744 0.0.0.0:* users:(("avahi-daemon",pid=708,fd=14)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.1",pid=4516,fd=36)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("evcc",pid=1461,fd=26)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("evcc",pid=1461,fd=25)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("evcc",pid=1461,fd=24)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=678,fd=5),("systemd",pid=1,fd=201)) udp UNCONN 0 0 [fe80::e65f:1ff:fea3:9269]:dhcpv6-client *:* users:(("NetworkManager",pid=804,fd=35)) udp UNCONN 0 0 *:mdns *:* users:(("evcc",pid=1461,fd=23)) udp UNCONN 0 0 *:mdns *:* users:(("evcc",pid=1461,fd=6)) udp UNCONN 0 0 *:mdns *:* users:(("avahi-daemon",pid=708,fd=13)) udp UNCONN 0 0 *:56692 *:* users:(("avahi-daemon",pid=708,fd=15)) udp UNCONN 0 0 *:sunrpc *:* users:(("rpcbind",pid=678,fd=7),("systemd",pid=1,fd=203)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=4247,fd=29)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=4247,fd=23)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=678,fd=4),("systemd",pid=1,fd=200)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=1290,fd=6)) tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:* users:(("io.jarvis.0",pid=4646,fd=29)) tcp LISTEN 0 511 0.0.0.0:1880 0.0.0.0:* users:(("node-red",pid=4415,fd=23)) tcp LISTEN 0 511 0.0.0.0:1882 0.0.0.0:* users:(("io.shelly.0",pid=4504,fd=38)) tcp LISTEN 0 511 0.0.0.0:1883 0.0.0.0:* users:(("io.sonoff.0",pid=4533,fd=40)) tcp LISTEN 0 4096 *:7070 *:* users:(("evcc",pid=1461,fd=12)) tcp LISTEN 0 4096 *:4712 *:* users:(("evcc",pid=1461,fd=10)) tcp LISTEN 0 4096 *:8887 *:* users:(("evcc",pid=1461,fd=9)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=678,fd=6),("systemd",pid=1,fd=202)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=1290,fd=7)) tcp LISTEN 0 511 *:8087 *:* users:(("io.simple-api.0",pid=4684,fd=34)) tcp LISTEN 0 511 *:tproxy *:* users:(("io.admin.0",pid=4276,fd=36)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=4730,fd=35)) *** Log File - Last 25 Lines *** 2026-09-07 19:58:49.419 - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Curr_p1"},"native":{},"type":"state"},"cbArg":0} 2026-09-07 19:58:49.419 - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1 2026-09-07 19:58:49.420 - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe: {"val":18388,"ack":true,"ts":1788803929418,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1788801639298} 2026-09-07 19:58:49.463 - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Curr_p2"},"native":{},"type":"state"},"cbArg":0} 2026-09-07 19:58:49.463 - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2 2026-09-07 19:58:49.464 - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1: {"val":0,"ack":true,"ts":1788803929462,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462981} 2026-09-07 19:58:49.507 - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Curr_p3"},"native":{},"type":"state"},"cbArg":0} 2026-09-07 19:58:49.507 - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3 2026-09-07 19:58:49.508 - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2: {"val":0,"ack":true,"ts":1788803929506,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463081} 2026-09-07 19:58:49.551 - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Volt_p1"},"native":{},"type":"state"},"cbArg":0} 2026-09-07 19:58:49.551 - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1 2026-09-07 19:58:49.552 - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3: {"val":0,"ack":true,"ts":1788803929550,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463181} 2026-09-07 19:58:49.599 - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Volt_p2"},"native":{},"type":"state"},"cbArg":0} 2026-09-07 19:58:49.599 - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2 2026-09-07 19:58:49.600 - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1: {"val":0,"ack":true,"ts":1788803929598,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463273} 2026-09-07 19:58:49.643 - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Volt_p3"},"native":{},"type":"state"},"cbArg":0} 2026-09-07 19:58:49.643 - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3 2026-09-07 19:58:49.644 - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2: {"val":0,"ack":true,"ts":1788803929642,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463333} 2026-09-07 19:58:49.688 - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3: {"val":0,"ack":true,"ts":1788803929686,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463393} 2026-09-07 19:58:50.061 - info: shelly.0 (4504) [authEnabled] 192.168.178.40 (shellyplusplugs / shellyplusplugs-b48a0a1cc8cc / shellyplusplugs#b48a0a1cc8cc#1): This device is not protected via restricted login (see adapter documentation for details) 2026-09-07 19:58:51.122 - info: shelly.0 (4504) [authEnabled] 192.168.178.57 (shellyplus1 / shellyplus1-80646fd94da8 / shellyplus1#80646fd94da8#1): This device is not protected via restricted login (see adapter documentation for details) 2026-09-07 19:58:51.459 - info: shelly.1 (4516) [authEnabled] 192.168.178.50 (shelly1 / shelly1-244CAB43CA38 / SHSW-1#244CAB43CA38#1): This device is not protected via restricted login (see adapter documentation for details) 2026-09-07 19:58:51.883 - info: shelly.0 (4504) [authEnabled] 192.168.178.43 (shellyplus1 / shellyplus1-80646fd8df60 / shellyplus1#80646fd8df60#1): This device is not protected via restricted login (see adapter documentation for details) 2026-09-07 19:58:52.072 - info: shelly.1 (4516) [authEnabled] 192.168.178.64 (shellyplug-s / shellyplug-s-3CE90ED7361F / SHPLG-S#3CE90ED7361F#1): This device is not protected via restricted login (see adapter documentation for details) 2026-09-07 19:58:55.334 - info: shelly.0 (4504) [authEnabled] 192.168.178.81 (shellyplus1 / shellyplus1-7c87ce63d85c / shellyplus1#7c87ce63d85c#1): This device is not protected via restricted login (see adapter documentation for details)============= Mark until here for C&P =============
iob diag has finished.
karl-heinz@meinbroker:~ $
Per direktem Aufruf oder über den Weg mit 'curl'?
Schalt den Desktop-Krempel aus, wenn da nicht direkt ein Display dran hängt.
Update die ganzen ioBroker-Adapter...
Die Quelle zu evcc musst du richtig anlegen. Geht z. B. damit sauber:
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https curl curl -1sLf 'https://dl.evcc.io/public/evcc/stable/setup.deb.sh' | sudo -E bash sudo apt update sudo apt install -y evccQuelle: https://docs.evcc.io/de/installation/linux/
Und wenn die evcc-Quelle sauber ist installierst du die 10 Updates des Betriebssystems...
Immer regelmäßig und zeitnah updates einspielen!
ich habe im Terminal "iob diag" eingegeben.
Was bedeutet das ?
Ich habe keinen Display am Raspi ich habe da nix geladen, sondern den iobroker lauf Doku installiert und die Datensicherung mit Backitup wieder eingespielt.soll ich jetzt als erstes alle Adapter updaten ?
EVCC habe ich genauso installiert. https://docs.evcc.io/de/installation/linux/
nach der Doku
was ist damit unten, soll ich das so machen ?
sudo apt update
sudo apt install -y evccUnd wo bekomme ich die 10 Updates des Betriebssystems her.
Ich muss das auch morgen verschieben, habe vom langen sitzen Rückenschmerzen.
Was bedeutet das ?
nach der Doku
sudo apt update
Dann brauchst du auch kein graphical.target. Setzt das also auf multiuser.target, das ist die für den Serverbetrieb vorgesehen Stufe. Geht u.a. so:
sudo systemctl set-default multi-user.targetEVCC habe ich genauso installiert.
Nein, hast du nicht, sonst käme nämlich nicht diese Meldung um's Eck:
W: Some index files failed to download. They have been ignored, or old ones used instead.was ist damit unten, soll ich das so machen ?
Das ist die Anleitung, wie man die Quelle für evcc richtig anlegt.
Wie immer über deinen Paketmanager. Aber dafür muss der erstmal sauber eingerichtet sein. Siehe Quelle für evcc...
Dann halt
sudo apt update sudo apt full-upgrade -
Also als erstes die 4 Befehlszeilen nacheinander.
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https curl curl -1sLf 'https://dl.evcc.io/public/evcc/stable/setup.deb.sh' | sudo -E bash sudo apt update sudo apt install -y evcc -
das ist jetzt das Ergebnis von "iob diag"
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: meinbroker Icon name: computer Kernel: Linux 6.18.39+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 400 Rev 1.1 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 82 days ago (on 2026-06-18). Systemuptime and Load: 12:55:26 up 19:20, 3 users, load average: 0.31, 0.44, 0.72 CPU threads : 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Tue 2026-09-08 12:55:27 CEST Universal time: Tue 2026-09-08 10:55:27 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': karl-heinz HOME=/home/karl-heinz GROUPS=karl-heinz adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: * lightdm.service - Light Display Manager Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 3.3G 139M 44M 698M 713M Swap: 2.1G 211M 1.9G Total: 6.1G 3.5G 2.1G Active iob-Instances: 23 3795 M total memory 3115 M used memory 2275 M active memory 1077 M inactive memory 133 M free memory 100 M buffer memory 566 M swap cache 2047 M total swap 201 M used swap 1846 M free swap *** top - Table Of Processes *** top - 12:55:27 up 19:20, 3 users, load average: 0.31, 0.44, 0.72 Tasks: 221 total, 1 running, 220 sleeping, 0 stopped, 0 zombie %Cpu(s): 20.8 us, 4.2 sy, 0.0 ni, 75.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3795.8 total, 132.2 free, 3116.0 used, 666.7 buff/cache MiB Swap: 2048.0 total, 1846.1 free, 201.9 used. 679.8 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 760M 33M 727M 5% /run /dev/mmcblk0p2 ext4 29G 12G 16G 42% / tmpfs tmpfs 1.9G 360K 1.9G 1% /dev/shm tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service /dev/mmcblk0p1 vfat 505M 79M 426M 16% /boot/firmware tmpfs tmpfs 1.9G 2.6M 1.9G 1% /tmp tmpfs tmpfs 380M 64K 380M 1% /run/user/1000 tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service Messages concerning filesystems in dmesg (Last 15 lines only): [Mon Sep 7 17:35:12 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [Mon Sep 7 17:35:12 2026] EXT4-fs (mmcblk0p2): mounted filesystem 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 ro with ordered data mode. Quota mode: none. [Mon Sep 7 17:35:15 2026] EXT4-fs (mmcblk0p2): re-mounted 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.5G /var/ 219M /var/lib 216M /var/cache 203M /var/cache/apt 148M /var/lib/apt/lists Archived and active journals take up 31.3M in the file system. /opt/iobroker/backups: 37M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 452M /opt/iobroker/iobroker-data/ 322M /opt/iobroker/iobroker-data/files 79M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png 57M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 43M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map 33M /opt/iobroker/iobroker-data/objects.jsonl 11M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js 8.2M /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-6vd4TbNS.js 8.1M /opt/iobroker/iobroker-data/history/20260907/history.growatt.0.1030054.devices.TPJ4CHW072.historyLast.bmsSOC.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0 No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.23.2 /usr/bin/node v22.23.2 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.2-1nodesource1 Candidate: 22.23.2-1nodesource1 Version table: *** 22.23.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.23.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.23.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.3-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main arm64 Packages 500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: meinbroker meinbroker (version: 7.2.2, hostname: meinbroker , alive, uptime: 63651) Core adapters versions js-controller: 7.2.2 admin: 8.0.11 javascript: 10.1.3 nodejs modules from github: 1 +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946) Adapter State + system.adapter.admin.0 : admin : meinbroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.backitup.0 : backitup : meinbroker - enabled + system.adapter.chromecast.0 : chromecast : meinbroker - enabled system.adapter.cloud.0 : cloud : meinbroker - disabled + system.adapter.discovery.0 : discovery : meinbroker - enabled + system.adapter.ds18b20.0 : ds18b20 : meinbroker - enabled + system.adapter.echarts.0 : echarts : meinbroker - enabled + system.adapter.evcc.0 : evcc : meinbroker - enabled, port: 7070 system.adapter.flot.0 : flot : meinbroker - disabled + system.adapter.growatt.0 : growatt : meinbroker - enabled + system.adapter.history.0 : history : meinbroker - enabled system.adapter.icons-material-png.0 : icons-material-png : meinbroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : meinbroker - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: meinbroker - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : meinbroker - disabled + system.adapter.iot.0 : iot : meinbroker - enabled + system.adapter.jarvis.0 : jarvis : meinbroker - enabled + system.adapter.javascript.0 : javascript : meinbroker - enabled + system.adapter.modbus.0 : modbus : meinbroker - enabled + system.adapter.mqtt.0 : mqtt : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.net-tools.0 : net-tools : meinbroker - enabled + system.adapter.node-red.0 : node-red : meinbroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.pushover.0 : pushover : meinbroker - enabled + system.adapter.shelly.0 : shelly : meinbroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : meinbroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.smartcontrol.0 : smartcontrol : meinbroker - enabled + system.adapter.sonoff.0 : sonoff : meinbroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : meinbroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : meinbroker - disabled system.adapter.vis-justgage.0 : vis-justgage : meinbroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : meinbroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : meinbroker - disabled system.adapter.vis-rgraph.0 : vis-rgraph : meinbroker - disabled system.adapter.vis.0 : vis : meinbroker - enabled + system.adapter.web.0 : web : meinbroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : meinbroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.evcc.0 : evcc : meinbroker - enabled, port: 7070 + system.adapter.mqtt.0 : mqtt : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.node-red.0 : node-red : meinbroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : meinbroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : meinbroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : meinbroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.0 : web : meinbroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.11' │ 'none' │ │ 1 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 2 │ 'system.adapter.chromecast' │ 'chromecast' │ '4.2.0' │ 'none' │ │ 3 │ 'system.adapter.cloud' │ 'cloud' │ '6.0.1' │ 'none' │ │ 4 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 5 │ 'system.adapter.ds18b20' │ 'ds18b20' │ '3.1.1' │ 'none' │ │ 6 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 7 │ 'system.adapter.evcc' │ 'evcc' │ '0.2.4' │ 'none' │ │ 8 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 9 │ 'system.adapter.growatt' │ 'growatt' │ '3.3.1' │ 'none' │ │ 10 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 11 │ 'system.adapter.icons-material-png' │ 'icons-material-png' │ '0.1.0' │ 'none' │ │ 12 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 13 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3' │ 'none' │ │ 14 │ 'system.adapter.icons-ultimate-png' │ 'icons-ultimate-png' │ '1.0.1' │ 'none' │ │ 15 │ 'system.adapter.iot' │ 'iot' │ '3.4.2' │ 'none' │ │ 16 │ 'system.adapter.jarvis' │ 'jarvis' │ '3.1.8' │ 'none' │ │ 17 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 18 │ 'system.adapter.modbus' │ 'modbus' │ '8.0.3' │ 'none' │ │ 19 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 20 │ 'system.adapter.net-tools' │ 'net-tools' │ '1.2.3' │ 'none' │ │ 21 │ 'system.adapter.node-red' │ 'node-red' │ '6.0.7' │ 'none' │ │ 22 │ 'system.adapter.pushover' │ 'pushover' │ '5.0.0' │ 'none' │ │ 23 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 24 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 25 │ 'system.adapter.smartcontrol' │ 'smartcontrol' │ '2.0.1' │ 'none' │ │ 26 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 27 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 28 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 29 │ 'system.adapter.vis-2-widgets-gauges' │ 'vis-2-widgets-gauges' │ '2.0.2' │ 'none' │ │ 30 │ 'system.adapter.vis-colorpicker' │ 'vis-colorpicker' │ '2.1.0' │ 'none' │ │ 31 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 32 │ 'system.adapter.vis-material-advanced' │ 'vis-material-advanced' │ '1.7.4' │ 'none' │ │ 33 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.9' │ 'none' │ │ 34 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph' │ '0.0.2' │ 'none' │ │ 35 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 36 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.0.11 , installed 8.0.11 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "chromecast" : 4.2.0 , installed 4.2.0 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "ds18b20" : 3.1.1 , installed 3.1.1 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "evcc" : 0.2.4 , installed 0.2.4 Adapter "growatt" : 3.3.1 , installed 3.3.1 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "iot" : 6.0.3 , installed 3.4.2 [Updatable] Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "modbus" : 8.0.3 , installed 8.0.3 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "net-tools" : 1.2.3 , installed 1.2.3 Adapter "node-red" : 6.0.7 , installed 6.0.7 Adapter "pushover" : 5.0.0 , installed 5.0.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonoff" : 3.3.0 , installed 3.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2-widgets-gauges": 2.0.2, installed 2.0.2 Adapter "vis-colorpicker": 2.1.0 , installed 2.1.0 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Objects and States Please stand by - This may take a while Objects: 5022 States: 4473 *** OS-Repositories and Updates *** W: https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/evcc-stable.asc are ignored as the file has an unsupported filetype. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Failed to fetch https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Some index files failed to download. They have been ignored, or old ones used instead. Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://archive.raspberrypi.com/debian trixie InRelease Hit:4 http://deb.debian.org/debian-security trixie-security InRelease Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian trixie InRelease Get:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease Err:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. Fetched 23.4 kB in 0s (80.7 kB/s) Reading package lists... W: https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/evcc-stable.asc are ignored as the file has an unsupported filetype. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Failed to fetch https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature. W: Some index files failed to download. They have been ignored, or old ones used instead. Pending systemupdates: 0 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("evcc",pid=18363,fd=23)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("evcc",pid=18363,fd=3)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.chromecast.0",pid=7395,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("avahi-daemon",pid=708,fd=12)) udp UNCONN 0 0 0.0.0.0:56744 0.0.0.0:* users:(("avahi-daemon",pid=708,fd=14)) udp UNCONN 0 0 0.0.0.0:coap 0.0.0.0:* users:(("io.shelly.1",pid=8154,fd=38)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("evcc",pid=18363,fd=27)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("evcc",pid=18363,fd=26)) udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:* users:(("evcc",pid=18363,fd=25)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=678,fd=5),("systemd",pid=1,fd=115)) udp UNCONN 0 0 [fe80::e65f:1ff:fea3:9269]:dhcpv6-client *:* users:(("NetworkManager",pid=804,fd=35)) udp UNCONN 0 0 *:mdns *:* users:(("evcc",pid=18363,fd=24)) udp UNCONN 0 0 *:mdns *:* users:(("evcc",pid=18363,fd=7)) udp UNCONN 0 0 *:mdns *:* users:(("avahi-daemon",pid=708,fd=13)) udp UNCONN 0 0 *:56692 *:* users:(("avahi-daemon",pid=708,fd=15)) udp UNCONN 0 0 *:sunrpc *:* users:(("rpcbind",pid=678,fd=7),("systemd",pid=1,fd=118)) tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:* users:(("iobroker.js-con",pid=4247,fd=29)) tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:* users:(("iobroker.js-con",pid=4247,fd=23)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=678,fd=4),("systemd",pid=1,fd=114)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=1290,fd=6)) tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:* users:(("io.jarvis.0",pid=4646,fd=29)) tcp LISTEN 0 511 0.0.0.0:1880 0.0.0.0:* users:(("node-red",pid=7852,fd=25)) tcp LISTEN 0 511 0.0.0.0:1882 0.0.0.0:* users:(("io.shelly.0",pid=8147,fd=38)) tcp LISTEN 0 511 0.0.0.0:1883 0.0.0.0:* users:(("io.sonoff.0",pid=7964,fd=40)) tcp LISTEN 0 4096 *:7070 *:* users:(("evcc",pid=18363,fd=12)) tcp LISTEN 0 4096 *:4712 *:* users:(("evcc",pid=18363,fd=10)) tcp LISTEN 0 4096 *:8887 *:* users:(("evcc",pid=18363,fd=9)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=678,fd=6),("systemd",pid=1,fd=116)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=1290,fd=7)) tcp LISTEN 0 511 *:8087 *:* users:(("io.simple-api.0",pid=7324,fd=35)) tcp LISTEN 0 511 *:tproxy *:* users:(("io.admin.0",pid=6973,fd=40)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=8031,fd=35)) *** Log File - Last 25 Lines *** 2026-09-08 12:57:09.891 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Total_Tarif2"},"native":{},"type":"state"},"cbArg":0} 2026-09-08 12:57:09.892 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2 2026-09-08 12:57:09.893 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif1: {"val":0,"ack":true,"ts":1788865029890,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462801} 2026-09-08 12:57:09.943 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Total_Summe"},"native":{},"type":"state"},"cbArg":18392} 2026-09-08 12:57:09.944 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe 2026-09-08 12:57:09.945 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2: {"val":0,"ack":true,"ts":1788865029942,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462861} 2026-09-08 12:57:09.996 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Curr_p1"},"native":{},"type":"state"},"cbArg":0} 2026-09-08 12:57:09.996 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1 2026-09-08 12:57:09.997 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe: {"val":18392,"ack":true,"ts":1788865029992,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1788863360418} 2026-09-08 12:57:10.043 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Curr_p2"},"native":{},"type":"state"},"cbArg":0} 2026-09-08 12:57:10.044 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2 2026-09-08 12:57:10.045 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1: {"val":0,"ack":true,"ts":1788865030042,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462981} 2026-09-08 12:57:10.091 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Curr_p3"},"native":{},"type":"state"},"cbArg":0} 2026-09-08 12:57:10.092 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3 2026-09-08 12:57:10.093 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2: {"val":0,"ack":true,"ts":1788865030090,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463081} 2026-09-08 12:57:10.139 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Volt_p1"},"native":{},"type":"state"},"cbArg":0} 2026-09-08 12:57:10.140 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1 2026-09-08 12:57:10.144 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3: {"val":0,"ack":true,"ts":1788865030138,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463181} 2026-09-08 12:57:10.192 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Volt_p2"},"native":{},"type":"state"},"cbArg":0} 2026-09-08 12:57:10.192 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2 2026-09-08 12:57:10.193 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1: {"val":0,"ack":true,"ts":1788865030190,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463273} 2026-09-08 12:57:10.244 - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML Volt_p3"},"native":{},"type":"state"},"cbArg":0} 2026-09-08 12:57:10.244 - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3 2026-09-08 12:57:10.245 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2: {"val":0,"ack":true,"ts":1788865030242,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463333} 2026-09-08 12:57:10.294 - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3: {"val":0,"ack":true,"ts":1788865030290,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463393}============= Mark until here for C&P =============
Und das folgende ist die Ausgabe von "sudo systemctl status evcc
den timout vom vom 3 Wechselrichter bekomme ich nicht weg, ich habe schon einen anderen rs485/usb Adapter genommen und die Schnittstelle am Wechselrichter überprüft. Vielleicht liegt es am Widerstand ? der Adapter wird aber erkannt.
sudo systemctl status evcc ● evcc.service - evcc Loaded: loaded (/usr/lib/systemd/system/evcc.service; enabled; preset: enabled) Active: active (running) since Tue 2026-09-08 12:45:13 CEST; 20min ago Invocation: 392ff29538cf4598882d60989e9b0856 Main PID: 18363 (evcc) Tasks: 11 (limit: 3967) CPU: 5.615s CGroup: /system.slice/evcc.service └─18363 /usr/bin/evcc Sep 08 13:05:33 meinbroker evcc[18363]: [lp-2 ] DEBUG 2026/09/08 13:05:33 charge power: 0W Sep 08 13:05:33 meinbroker evcc[18363]: [lp-1 ] DEBUG 2026/09/08 13:05:33 charge power: 0W Sep 08 13:05:33 meinbroker evcc[18363]: [lp-2 ] DEBUG 2026/09/08 13:05:33 charge currents: [0 0 0]A Sep 08 13:05:33 meinbroker evcc[18363]: [lp-1 ] DEBUG 2026/09/08 13:05:33 charge currents: [0 0 0]A Sep 08 13:05:33 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:33 pv 2 power: 1935W Sep 08 13:05:33 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:33 grid power: 130W Sep 08 13:05:34 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:34 pv 1 power: 4426W Sep 08 13:05:34 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:34 battery 1 power: -1550W Sep 08 13:05:34 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:34 battery 1 soc: 64% Sep 08 13:05:43 meinbroker evcc[18363]: [site ] ERROR 2026/09/08 13:05:43 pv 3 power: read failed: serial: timeout karl-heinz@meinbroker -
sudo systemctl status evcc ● evcc.service - evcc Loaded: loaded (/usr/lib/systemd/system/evcc.service; enabled; preset: enabled) Active: active (running) since Tue 2026-09-08 12:45:13 CEST; 20min ago Invocation: 392ff29538cf4598882d60989e9b0856 Main PID: 18363 (evcc) Tasks: 11 (limit: 3967) CPU: 5.615s CGroup: /system.slice/evcc.service └─18363 /usr/bin/evcc Sep 08 13:05:33 meinbroker evcc[18363]: [lp-2 ] DEBUG 2026/09/08 13:05:33 charge power: 0W Sep 08 13:05:33 meinbroker evcc[18363]: [lp-1 ] DEBUG 2026/09/08 13:05:33 charge power: 0W Sep 08 13:05:33 meinbroker evcc[18363]: [lp-2 ] DEBUG 2026/09/08 13:05:33 charge currents: [0 0 0]A Sep 08 13:05:33 meinbroker evcc[18363]: [lp-1 ] DEBUG 2026/09/08 13:05:33 charge currents: [0 0 0]A Sep 08 13:05:33 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:33 pv 2 power: 1935W Sep 08 13:05:33 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:33 grid power: 130W Sep 08 13:05:34 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:34 pv 1 power: 4426W Sep 08 13:05:34 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:34 battery 1 power: -1550W Sep 08 13:05:34 meinbroker evcc[18363]: [site ] DEBUG 2026/09/08 13:05:34 battery 1 soc: 64% Sep 08 13:05:43 meinbroker evcc[18363]: [site ] ERROR 2026/09/08 13:05:43 pv 3 power: read failed: serial: timeout karl-heinz@meinbrokerJetzt suchst du dir die Datei, die noch eine Referenz auf bookworm enthält:
cd /etc/apt/sources.list.d/ grep -r "bookworm"und löschst die komplett, wenn da nur eine Zeile drin ist, ansonsten die Zeile mit dem bookworm-Eintrag.
Danach dann schauen, ob die Repos dann sauber sind:sudo apt update apt policy evcc -
Da ist das drin
-rw-r--r-- 1 root root 378 Jun 18 02:19 debian.sources -rw-r--r-- 1 root root 81 Sep 7 02:34 evcc.list -rw-r--r-- 1 root root 410 Sep 8 12:08 evcc-stable.list -rw-r--r-- 1 root root 155 Sep 6 22:13 nodesource.sources -rw-r--r-- 1 root root 151 Jun 18 02:19 raspi.sources karl-heinz@meinbroker:~ $ ls -l /etc/apt/sources.list. -
Da ist das drin
-rw-r--r-- 1 root root 378 Jun 18 02:19 debian.sources -rw-r--r-- 1 root root 81 Sep 7 02:34 evcc.list -rw-r--r-- 1 root root 410 Sep 8 12:08 evcc-stable.list -rw-r--r-- 1 root root 155 Sep 6 22:13 nodesource.sources -rw-r--r-- 1 root root 151 Jun 18 02:19 raspi.sources karl-heinz@meinbroker:~ $ ls -l /etc/apt/sources.list.Da ist das drin
Und das ist die Ausgabe von welchem Befehl?
Immer die VOLLSTÄNDIGEN Ein- wie Ausgaben in der Konsole posten. LoginPrompt inklusive.
Damit man sieht WAS du da WO eingegeben hast.Du solltest aber auch
cd /etc/apt/sources.list.d/ grep -r "bookworm"ausführen.
Müsste dann aber hier zu suchen sein:
evcc.list
Also
sudo rm /etc/apt/sources.list.d/evcc.listdürfte dann die vorherigen Meldungen zum fehlenden Zertifikat beseitigen.
ja, den habe ich ausgeführt.
karl-heinz@meinbroker:~ $ cd /etc/apt/sources.list.d/ grep -r "bookworm" evcc.list:deb [trusted=yes] https://dl.evcc.io/public/evcc/stable/deb/debian bookworm main karl-heinz@meinbroker:/etc/apt/sources.list.d $Das war die Ausgabe.
Damit konnte ich nichts anfangen und dann habe ich das eingegeben.
karl-heinz@meinbroker:~ $ ls -l /etc/apt/sources.list.d total 20 -rw-r--r-- 1 root root 378 Jun 18 02:19 debian.sources -rw-r--r-- 1 root root 81 Sep 7 02:34 evcc.list -rw-r--r-- 1 root root 410 Sep 8 12:08 evcc-stable.list -rw-r--r-- 1 root root 155 Sep 6 22:13 nodesource.sources -rw-r--r-- 1 root root 151 Jun 18 02:19 raspi.sources karl-heinz@meinbroker:~ $Das war die Ausgabe
Das spuckt alle Dateien aus, die den Text 'bookworm' enthalten. Hier also die evcc.list.
Mit
sudo rm /etc/apt/sources.list.d/evcc.listwird also die richtige Datei gelöscht.
der EVCC Adapter ist immer noch nicht grün
jetzt ist allerdings auch der Growatt Adapter nicht grünEVCC zeigt aber den Ladezustand der Hausbatterie richtig an und der ändert sich auch, aber die Datenpunkte von Growatt der Hausbatterie sind eingefroren, wie auch die Datenpunkte von EVCC.
Diese beiden brauche ich für die Skripte zum Steuern von den Shelly`s für WarmwasserEs wäre schön wenn wir das noch hinbekommen. Ich verspreche, das ich dann regelmässige Updates mache.
Ohne LogFiles wird das schwierig werden.
Das ist die Fehlermeldung von Growatt und EVCC
growatt.0 2026-09-08 20:16:56.838 error Growatt exception: AxiosError: Request failed with status code 500 evcc.0 2026-09-08 20:16:52.284 error Invalid URLbei Growatt habe ich festgestellt, das ich auch nicht auf den Server von Growatt zugreifen kann. Wenn ich mich privat anmelde, werde ich nach Benutzer und Passwort gefragt, danach kommt die erste Seite aber dunkel. Das funktioniert auch nicht. Mit der Handy APP funktioniert es. das wäre ja ein komischer Zufall.
Bei EVCC kommt nur diese eine Meldung. Ich habe die URL geprüft, mit http://192.168.168.XX:7070.
Growatt hat sich erledigt. Die Chinesen haben den wegen Wartungsarbeiten abgeschaltet.
evcc.0
2026-09-08 20:16:52.284 error Invalid URLBei EVCC kommt nur diese eine Meldung. Ich habe die URL geprüft, mit http://192.168.178.XXX:7070 ist die richtig. Ich habe es ohne http:// versucht geht auch nicht.
Bei Growatt hat es sich geklärt. Die Chinesen haben Wartungsarbeiten.
Bei EVCC ist es nur diese eine Meldung. Die URL ist OK, wenn ich die mit dem Explorer aufrufe ist die EVCC Seite sofort da.
evcc.0
2026-09-08 21:12:12.435 error Invalid URL -
Habe gefunden. Die URL von EVCC ist nicht die, die man im Browser eingibt, wenn man EVCC startet.
EVCC ist jetzt grün -
Danke Thomas und die anderen.
evcc.0
Die URL ist OK
Sondern welche?
