  4. EVCC wird nicht grün
    apollon77A
102 Beiträge 6 Kommentatoren 3.0k Aufrufe 5 Beobachtet
  • K
    K
    Karl-Heinz1
    #78
    Nein, da habe ich nicht richtig hingeguckt und war nicht angemeldet.
    karl-heinz@meinbroker:~ $ iob fix
    Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
    library: loaded
    Library version=2026-04-11
        Welcome to the ioBroker installation fixer!
        Script version: 2025-09-18
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Get:3 http://archive.raspberrypi.com/debian trixie InRelease [54.9 kB]
    Get:4 http://deb.debian.org/debian-security trixie-security InRelease [43.4 kB]
    Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian trixie InRelease
    Get:6 http://deb.debian.org/debian-security trixie-security/main armhf Packages [232 kB]
    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
    Get:8 http://archive.raspberrypi.com/debian trixie/main arm64 Packages [470 kB]
    Get:9 http://deb.debian.org/debian-security trixie-security/main arm64 Packages [252 kB]
    Get:10 http://archive.raspberrypi.com/debian trixie/main armhf Packages [461 kB]
    Get:11 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
    Err:11 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
      Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature.
    Fetched 1,537 kB in 0s (3,082 kB/s)
    Reading package lists... Done
    W: https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/evcc-stable.asc are ignored as the file has an unsupported filetype.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature.
    W: Failed to fetch https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature.
    W: Some index files failed to download. They have been ignored, or old ones used instead.
        Checking ioBroker user and directory permissions (2/5)
    ACL enabled: true
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
    Authentication is required to stop 'iobroker.service'.
    Authenticating as: Raspberry Pi OS (karl-heinz)
    Password:
    ==== AUTHENTICATION COMPLETE ====
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    • K Karl-Heinz1
      library: loaded
      ACL enabled: true
      Done.
      Password:
      Autostart enabled!
      Thomas BraunT
      Thomas BraunT
      #79
      @Karl-Heinz1 sagte:
      Das ist übrigens der Grund, warum evcc nicht läuft. Das kann so gar nicht erst installiert werden. Musst du mal in einer gescheiten Anleitung zu evcc schauen, wie das richtig gemacht wird.
      Funktioniert denn
      iob diag
      nun?
      Wenn nicht:
      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      • K
        K
        Karl-Heinz1
        #80
        Das ist das Ergebnis von iob diag
        Ob iob diag funktioniert muss du jetzt sagen. Ich mache jetzt nichts, warte ab, was ich tun soll.
        ```bash
        Script v.2026-08-30
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 13 (trixie)
         Static hostname: meinbroker
               Icon name: computer
                  Kernel: Linux 6.18.39+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model		: Raspberry Pi 400 Rev 1.1
        Docker          : false
        Virtualization  : none
        Unknown
        Kernel          : aarch64
        Userland        : 64bit
        System was installed 81 days ago (on 2026-06-18).
        Systemuptime and Load:
         19:57:19 up  2:22,  3 users,  load average: 0.81, 0.38, 0.36
        CPU threads     : 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'trixie'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2026-09-07 19:57:20 CEST
                   Universal time: Mon 2026-09-07 17:57:20 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        karl-heinz
        HOME=/home/karl-heinz
        GROUPS=karl-heinz adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server:		Unknown
        Display-Manager: 	* lightdm.service - Light Display Manager
        Desktop:
        Session:		tty
        Boot Target: 		graphical.target
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
        Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            4.0G        2.8G        367M         34M        908M        1.2G
        Swap:           2.1G          0B        2.1G
        Total:          6.1G        2.8G        2.5G
        Active iob-Instances: 	22
                 3795 M total memory
                 2698 M used memory
                 1917 M active memory
                 1188 M inactive memory
                  349 M free memory
                  115 M buffer memory
                  750 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        top - 19:57:20 up  2:22,  3 users,  load average: 0.81, 0.38, 0.36
        Tasks: 221 total,   1 running, 220 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.2 us,  2.2 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.8 total,    349.7 free,   2698.4 used,    867.2 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1097.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     760M  9.3M  750M   2% /run
        /dev/mmcblk0p2 ext4       29G   12G   16G  44% /
        tmpfs          tmpfs     1.9G  360K  1.9G   1% /dev/shm
        tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
        /dev/mmcblk0p1 vfat      505M   79M  426M  16% /boot/firmware
        tmpfs          tmpfs     1.9G  2.6M  1.9G   1% /tmp
        tmpfs          tmpfs     380M   64K  380M   1% /run/user/1000
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
        Messages concerning filesystems in dmesg (Last 15 lines only):
        [Mon Sep  7 17:35:12 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Mon Sep  7 17:35:12 2026] EXT4-fs (mmcblk0p2): mounted filesystem 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 ro with ordered data mode. Quota mode: none.
        [Mon Sep  7 17:35:15 2026] EXT4-fs (mmcblk0p2): re-mounted 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 r/w.
        Show mounted filesystems:
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.5G	/var/
        220M	/var/lib
        216M	/var/cache
        203M	/var/cache/apt
        149M	/var/lib/apt
        Archived and active journals take up 8M in the file system.
        /opt/iobroker/backups:
        37M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        885M	/opt/iobroker/iobroker-data/
        814M	/opt/iobroker/iobroker-data/files
        493M	/opt/iobroker/iobroker-data/files/javascript.admin
        461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        460M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        43M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map
        24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
        19M	/opt/iobroker/iobroker-data/objects.jsonl
        19M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
        11M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0
        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0
        No nvbackup.json found.
        *** NodeJS-Installation ***
        /usr/bin/nodejs		v22.23.2
        /usr/bin/node		v22.23.2
        /usr/bin/npm		10.9.8
        /usr/bin/npx		10.9.8
        ✓ Node.js installation is correct
        nodejs:
          Installed: 22.23.2-1nodesource1
          Candidate: 22.23.2-1nodesource1
          Version table:
         *** 22.23.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
             22.23.1-1nodesource1 1001
             22.23.0-1nodesource1 1001
             22.22.3-1nodesource1 1001
             22.22.2-1nodesource1 1001
             22.22.1-1nodesource1 1001
             22.22.0-1nodesource1 1001
             22.21.0-1nodesource1 1001
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             20.19.2+dfsg-1+deb13u2 500
                500 http://deb.debian.org/debian trixie/main arm64 Packages
                500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        No known Vulnerabilities detected!
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        meinbroker          meinbroker (version: 7.2.2, hostname: meinbroker    , alive, uptime: 2569)
        Core adapters versions
        js-controller: 	7.2.2
        admin: 		7.8.23
        javascript: 	8.8.2
        nodejs modules from github: 	1
        +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
        Adapter State
        + system.adapter.admin.0                  : admin                 : meinbroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : meinbroker                               -  enabled
        + system.adapter.chromecast.0             : chromecast            : meinbroker                               -  enabled
          system.adapter.cloud.0                  : cloud                 : meinbroker                               - disabled
        + system.adapter.discovery.0              : discovery             : meinbroker                               -  enabled
        + system.adapter.ds18b20.0                : ds18b20               : meinbroker                               -  enabled
        + system.adapter.echarts.0                : echarts               : meinbroker                               -  enabled
        + system.adapter.evcc.0                   : evcc                  : meinbroker                               -  enabled, port: 7070
          system.adapter.flot.0                   : flot                  : meinbroker                               - disabled
        + system.adapter.growatt.0                : growatt               : meinbroker                               -  enabled
        + system.adapter.history.0                : history               : meinbroker                               -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : meinbroker                               - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : meinbroker                               - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: meinbroker                               - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : meinbroker                               - disabled
        + system.adapter.iot.0                    : iot                   : meinbroker                               -  enabled
        + system.adapter.jarvis.0                 : jarvis                : meinbroker                               -  enabled
          system.adapter.javascript.0             : javascript            : meinbroker                               -  enabled
        + system.adapter.modbus.0                 : modbus                : meinbroker                               -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : meinbroker                               -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.net-tools.0              : net-tools             : meinbroker                               -  enabled
        + system.adapter.node-red.0               : node-red              : meinbroker                               -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.pushover.0               : pushover              : meinbroker                               -  enabled
        + system.adapter.shelly.0                 : shelly                : meinbroker                               -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : meinbroker                               -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : meinbroker                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartcontrol.0           : smartcontrol          : meinbroker                               -  enabled
        + system.adapter.sonoff.0                 : sonoff                : meinbroker                               -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.telegram.0               : telegram              : meinbroker                               - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : meinbroker                               - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : meinbroker                               - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : meinbroker                               - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : meinbroker                               - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : meinbroker                               - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : meinbroker                               - disabled
          system.adapter.vis.0                    : vis                   : meinbroker                               -  enabled
        + system.adapter.web.0                    : web                   : meinbroker                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        │ (index) │ id                                           │ name                          │ version  │ upgrade policy │
        │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
        │ 1       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '4.0.3'  │ 'none'         │
        │ 2       │ 'system.adapter.chromecast'                  │ 'chromecast'                  │ '3.4.1'  │ 'none'         │
        │ 3       │ 'system.adapter.cloud'                       │ 'cloud'                       │ '5.0.1'  │ 'none'         │
        │ 4       │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'  │ 'none'         │
        │ 5       │ 'system.adapter.ds18b20'                     │ 'ds18b20'                     │ '2.0.5'  │ 'none'         │
        │ 6       │ 'system.adapter.echarts'                     │ 'echarts'                     │ '1.9.2'  │ 'none'         │
        │ 7       │ 'system.adapter.evcc'                        │ 'evcc'                        │ '0.2.4'  │ 'none'         │
        │ 8       │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
        │ 9       │ 'system.adapter.growatt'                     │ 'growatt'                     │ '3.3.1'  │ 'none'         │
        │ 10      │ 'system.adapter.history'                     │ 'history'                     │ '3.0.1'  │ 'none'         │
        │ 11      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
        │ 12      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
        │ 13      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3'  │ 'none'         │
        │ 14      │ 'system.adapter.icons-ultimate-png'          │ 'icons-ultimate-png'          │ '1.0.1'  │ 'none'         │
        │ 15      │ 'system.adapter.iot'                         │ 'iot'                         │ '3.4.2'  │ 'none'         │
        │ 16      │ 'system.adapter.jarvis'                      │ 'jarvis'                      │ '3.1.8'  │ 'none'         │
        │ 17      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '8.8.2'  │ 'none'         │
        │ 18      │ 'system.adapter.modbus'                      │ 'modbus'                      │ '6.3.2'  │ 'none'         │
        │ 19      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.1'  │ 'none'         │
        │ 20      │ 'system.adapter.net-tools'                   │ 'net-tools'                   │ '1.0.11' │ 'none'         │
        │ 21      │ 'system.adapter.node-red'                    │ 'node-red'                    │ '5.2.1'  │ 'none'         │
        │ 22      │ 'system.adapter.pushover'                    │ 'pushover'                    │ '4.1.0'  │ 'none'         │
        │ 23      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '8.2.1'  │ 'none'         │
        │ 24      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '2.8.0'  │ 'none'         │
        │ 25      │ 'system.adapter.smartcontrol'                │ 'smartcontrol'                │ '2.0.1'  │ 'none'         │
        │ 26      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '6.7.1'  │ 'none'         │
        │ 27      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.1.2'  │ 'none'         │
        │ 28      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '3.9.0'  │ 'none'         │
        │ 29      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
        │ 30      │ 'system.adapter.vis-2-widgets-gauges'        │ 'vis-2-widgets-gauges'        │ '1.1.0'  │ 'none'         │
        │ 31      │ 'system.adapter.vis-colorpicker'             │ 'vis-colorpicker'             │ '2.0.3'  │ 'none'         │
        │ 32      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
        │ 33      │ 'system.adapter.vis-material-advanced'       │ 'vis-material-advanced'       │ '1.7.4'  │ 'none'         │
        │ 34      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'  │ 'none'         │
        │ 35      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'  │ 'none'         │
        │ 36      │ 'system.adapter.web'                         │ 'web'                         │ '6.3.1'  │ 'none'         │
        │ 37      │ 'system.adapter.ws'                          │ 'ws'                          │ '2.6.2'  │ 'none'         │
        ioBroker-Adapter Versions and update status
        Used repository: stable
        Adapter    "admin"        : 8.0.11   , installed 7.8.23 [Updatable]
        Adapter    "backitup"     : 4.0.3    , installed 4.0.3
        Adapter    "chromecast"   : 4.2.0    , installed 3.4.1  [Updatable]
        Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
        Adapter    "ds18b20"      : 3.1.1    , installed 2.0.5  [Updatable]
        Adapter    "echarts"      : 3.1.0    , installed 1.9.2  [Updatable]
        Adapter    "evcc"         : 0.2.4    , installed 0.2.4
        Adapter    "growatt"      : 3.3.1    , installed 3.3.1
        Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
        Adapter    "iot"          : 6.0.3    , installed 3.4.2  [Updatable]
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 10.1.3   , installed 8.8.2  [Updatable]
        Controller "js-controller": 7.2.2    , installed 7.2.2
        Adapter    "modbus"       : 8.0.3    , installed 6.3.2  [Updatable]
        Adapter    "mqtt"         : 6.1.4    , installed 6.1.1  [Updatable]
        Adapter    "net-tools"    : 1.2.3    , installed 1.0.11 [Updatable]
        Adapter    "node-red"     : 6.0.7    , installed 5.2.1  [Updatable]
        Adapter    "pushover"     : 5.0.0    , installed 4.1.0  [Updatable]
        Adapter    "shelly"       : 10.6.1   , installed 8.2.1  [Updatable]
        Adapter    "simple-api"   : 3.0.7    , installed 2.8.0  [Updatable]
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 7.1.3    , installed 6.7.1  [Updatable]
        Adapter    "sonoff"       : 3.3.0    , installed 3.1.2  [Updatable]
        Adapter    "telegram"     : 5.0.5    , installed 3.9.0  [Updatable]
        Adapter    "vis-2-widgets-gauges": 2.0.2, installed 1.1.0 [Updatable]
        Adapter    "vis-colorpicker": 2.1.0  , installed 2.0.3  [Updatable]
        Adapter    "web"          : 8.0.0    , installed 6.3.1  [Updatable]
        Adapter    "ws"           : 4.1.0    , installed 2.6.2  [Updatable]
        Objects and States
        Objects: 	4938
        States: 	4382
        Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
        Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
        Get:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
        Err:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
        Fetched 23.4 kB in 0s (71.0 kB/s)
        Pending systemupdates: 10
        *** Listening Ports ***
        Netid State  Recv-Q Send-Q              Local Address:Port          Peer Address:PortProcess
        udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("io.chromecast.0",pid=4395,fd=35))
        udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=1461,fd=22))
        udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=1461,fd=3))
        udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=708,fd=12))
        udp   UNCONN 0      0                         0.0.0.0:56744              0.0.0.0:*    users:(("avahi-daemon",pid=708,fd=14))
        udp   UNCONN 0      0                         0.0.0.0:coap               0.0.0.0:*    users:(("io.shelly.1",pid=4516,fd=36))
        udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=1461,fd=26))
        udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=1461,fd=25))
        udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=1461,fd=24))
        udp   UNCONN 0      0                         0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=678,fd=5),("systemd",pid=1,fd=201))
        udp   UNCONN 0      0      [fe80::e65f:1ff:fea3:9269]:dhcpv6-client            *:*    users:(("NetworkManager",pid=804,fd=35))
        udp   UNCONN 0      0                               *:mdns                     *:*    users:(("evcc",pid=1461,fd=23))
        udp   UNCONN 0      0                               *:mdns                     *:*    users:(("evcc",pid=1461,fd=6))
        udp   UNCONN 0      0                               *:mdns                     *:*    users:(("avahi-daemon",pid=708,fd=13))
        udp   UNCONN 0      0                               *:56692                    *:*    users:(("avahi-daemon",pid=708,fd=15))
        udp   UNCONN 0      0                               *:sunrpc                   *:*    users:(("rpcbind",pid=678,fd=7),("systemd",pid=1,fd=203))
        tcp   LISTEN 0      511                     127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=4247,fd=29))
        tcp   LISTEN 0      511                     127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=4247,fd=23))
        tcp   LISTEN 0      4096                      0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=678,fd=4),("systemd",pid=1,fd=200))
        tcp   LISTEN 0      128                       0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=1290,fd=6))
        tcp   LISTEN 0      511                       0.0.0.0:8400               0.0.0.0:*    users:(("io.jarvis.0",pid=4646,fd=29))
        tcp   LISTEN 0      511                       0.0.0.0:1880               0.0.0.0:*    users:(("node-red",pid=4415,fd=23))
        tcp   LISTEN 0      511                       0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.0",pid=4504,fd=38))
        tcp   LISTEN 0      511                       0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=4533,fd=40))
        tcp   LISTEN 0      4096                            *:7070                     *:*    users:(("evcc",pid=1461,fd=12))
        tcp   LISTEN 0      4096                            *:4712                     *:*    users:(("evcc",pid=1461,fd=10))
        tcp   LISTEN 0      4096                            *:8887                     *:*    users:(("evcc",pid=1461,fd=9))
        tcp   LISTEN 0      4096                         [::]:sunrpc                [::]:*    users:(("rpcbind",pid=678,fd=6),("systemd",pid=1,fd=202))
        tcp   LISTEN 0      128                          [::]:ssh                   [::]:*    users:(("sshd",pid=1290,fd=7))
        tcp   LISTEN 0      511                             *:8087                     *:*    users:(("io.simple-api.0",pid=4684,fd=34))
        tcp   LISTEN 0      511                             *:tproxy                   *:*    users:(("io.admin.0",pid=4276,fd=36))
        tcp   LISTEN 0      511                             *:8082                     *:*    users:(("io.web.0",pid=4730,fd=35))
        2026-09-07 19:58:49.419  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p1"},"native":{},"type":"state"},"cbArg":0}
        2026-09-07 19:58:49.419  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1
        2026-09-07 19:58:49.420  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe: {"val":18388,"ack":true,"ts":1788803929418,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1788801639298}
        2026-09-07 19:58:49.463  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p2"},"native":{},"type":"state"},"cbArg":0}
        2026-09-07 19:58:49.463  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2
        2026-09-07 19:58:49.464  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1: {"val":0,"ack":true,"ts":1788803929462,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462981}
        2026-09-07 19:58:49.507  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p3"},"native":{},"type":"state"},"cbArg":0}
        2026-09-07 19:58:49.507  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3
        2026-09-07 19:58:49.508  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2: {"val":0,"ack":true,"ts":1788803929506,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463081}
        2026-09-07 19:58:49.551  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p1"},"native":{},"type":"state"},"cbArg":0}
        2026-09-07 19:58:49.551  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1
        2026-09-07 19:58:49.552  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3: {"val":0,"ack":true,"ts":1788803929550,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463181}
        2026-09-07 19:58:49.599  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p2"},"native":{},"type":"state"},"cbArg":0}
        2026-09-07 19:58:49.599  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2
        2026-09-07 19:58:49.600  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1: {"val":0,"ack":true,"ts":1788803929598,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463273}
        2026-09-07 19:58:49.643  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p3"},"native":{},"type":"state"},"cbArg":0}
        2026-09-07 19:58:49.643  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3
        2026-09-07 19:58:49.644  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2: {"val":0,"ack":true,"ts":1788803929642,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463333}
        2026-09-07 19:58:49.688  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3: {"val":0,"ack":true,"ts":1788803929686,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463393}
        2026-09-07 19:58:50.061  - info: shelly.0 (4504) [authEnabled] 192.168.178.40 (shellyplusplugs / shellyplusplugs-b48a0a1cc8cc / shellyplusplugs#b48a0a1cc8cc#1): This device is not protected via restricted login (see adapter documentation for details)
        2026-09-07 19:58:51.122  - info: shelly.0 (4504) [authEnabled] 192.168.178.57 (shellyplus1 / shellyplus1-80646fd94da8 / shellyplus1#80646fd94da8#1): This device is not protected via restricted login (see adapter documentation for details)
        2026-09-07 19:58:51.459  - info: shelly.1 (4516) [authEnabled] 192.168.178.50 (shelly1 / shelly1-244CAB43CA38 / SHSW-1#244CAB43CA38#1): This device is not protected via restricted login (see adapter documentation for details)
        2026-09-07 19:58:51.883  - info: shelly.0 (4504) [authEnabled] 192.168.178.43 (shellyplus1 / shellyplus1-80646fd8df60 / shellyplus1#80646fd8df60#1): This device is not protected via restricted login (see adapter documentation for details)
        2026-09-07 19:58:52.072  - info: shelly.1 (4516) [authEnabled] 192.168.178.64 (shellyplug-s / shellyplug-s-3CE90ED7361F / SHPLG-S#3CE90ED7361F#1): This device is not protected via restricted login (see adapter documentation for details)
        2026-09-07 19:58:55.334  - info: shelly.0 (4504) [authEnabled] 192.168.178.81 (shellyplus1 / shellyplus1-7c87ce63d85c / shellyplus1#7c87ce63d85c#1): This device is not protected via restricted login (see adapter documentation for details)
        ============= Mark until here for C&P =============
        iob diag has finished.
        • K Karl-Heinz1
          ```bash
          Script v.2026-08-30
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Unknown
          Kernel          : aarch64
          Userland        : 64bit
          CPU threads     : 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          karl-heinz
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:		tty
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   3795 M total memory
                   2698 M used memory
                    349 M free memory
                    115 M buffer memory
                    750 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G	/var/
          220M	/var/lib
          216M	/var/cache
          203M	/var/cache/apt
          149M	/var/lib/apt
          USB-Devices by-id:
          /usr/bin/npm		10.9.8
          /usr/bin/npx		10.9.8
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin: 		7.8.23
          javascript: 	8.8.2
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	4938
          States: 	4382
          Thomas BraunT
          Thomas BraunT
          #81
          @Karl-Heinz1 sagte:
          Per direktem Aufruf oder über den Weg mit 'curl'?
          Schalt den Desktop-Krempel aus, wenn da nicht direkt ein Display dran hängt.
          Update die ganzen ioBroker-Adapter...
          Die Quelle zu evcc musst du richtig anlegen. Geht z. B. damit sauber:
          sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https curl
          curl -1sLf 'https://dl.evcc.io/public/evcc/stable/setup.deb.sh' | sudo -E bash
          sudo apt update
          sudo apt install -y evcc
          Quelle: https://docs.evcc.io/de/installation/linux/
          Und wenn die evcc-Quelle sauber ist installierst du die 10 Updates des Betriebssystems...
          Immer regelmäßig und zeitnah updates einspielen!
          • K
            K
            Karl-Heinz1
            #82
            ich habe im Terminal "iob diag" eingegeben.
            Was bedeutet das ?
            Ich habe keinen Display am Raspi ich habe da nix geladen, sondern den iobroker lauf Doku installiert und die Datensicherung mit Backitup wieder eingespielt.
            soll ich jetzt als erstes alle Adapter updaten ?
            EVCC habe ich genauso installiert. https://docs.evcc.io/de/installation/linux/
            nach der Doku
            was ist damit unten, soll ich das so machen ?
            sudo apt update
            Und wo bekomme ich die 10 Updates des Betriebssystems her.
            Ich muss das auch morgen verschieben, habe vom langen sitzen Rückenschmerzen.
            • K Karl-Heinz1
              Was bedeutet das ?
              nach der Doku
              sudo apt update
              Thomas BraunT
              Thomas BraunT
              #83
              @Karl-Heinz1 sagte:
              Dann brauchst du auch kein graphical.target. Setzt das also auf multiuser.target, das ist die für den Serverbetrieb vorgesehen Stufe. Geht u.a. so:
              sudo systemctl set-default multi-user.target
              Nein, hast du nicht, sonst käme nämlich nicht diese Meldung um's Eck:
              Das ist die Anleitung, wie man die Quelle für evcc richtig anlegt.
              Wie immer über deinen Paketmanager. Aber dafür muss der erstmal sauber eingerichtet sein. Siehe Quelle für evcc...
              Dann halt
              sudo apt update
              sudo apt full-upgrade
              • K
                K
                Karl-Heinz1
                #84
                Also als erstes die 4 Befehlszeilen nacheinander.
                sudo apt update
                • K
                  K
                  Karl-Heinz1
                  #85
                  das ist jetzt das Ergebnis von "iob diag"
                  ```bash
                  Script v.2026-08-30
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Unknown
                  Kernel          : aarch64
                  Userland        : 64bit
                  System was installed 82 days ago (on 2026-06-18).
                   12:55:26 up 19:20,  3 users,  load average: 0.31, 0.44, 0.72
                  CPU threads     : 4
                  Current issues:
                                 Local time: Tue 2026-09-08 12:55:27 CEST
                             Universal time: Tue 2026-09-08 10:55:27 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  karl-heinz
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Session:		tty
                  Boot Target: 		multi-user.target
                  *** MEMORY ***
                  Mem:            4.0G        3.3G        139M         44M        698M        713M
                  Swap:           2.1G        211M        1.9G
                  Total:          6.1G        3.5G        2.1G
                  Active iob-Instances: 	23
                           3795 M total memory
                           3115 M used memory
                           2275 M active memory
                           1077 M inactive memory
                            133 M free memory
                            100 M buffer memory
                            566 M swap cache
                           2047 M total swap
                            201 M used swap
                           1846 M free swap
                  top - 12:55:27 up 19:20,  3 users,  load average: 0.31, 0.44, 0.72
                  %Cpu(s): 20.8 us,  4.2 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   3795.8 total,    132.2 free,   3116.0 used,    666.7 buff/cache
                  MiB Swap:   2048.0 total,   1846.1 free,    201.9 used.    679.8 avail Mem
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     760M   33M  727M   5% /run
                  /dev/mmcblk0p2 ext4       29G   12G   16G  42% /
                  /var:
                  2.5G	/var/
                  219M	/var/lib
                  216M	/var/cache
                  203M	/var/cache/apt
                  148M	/var/lib/apt/lists
                  Archived and active journals take up 31.3M in the file system.
                  452M	/opt/iobroker/iobroker-data/
                  322M	/opt/iobroker/iobroker-data/files
                  79M	/opt/iobroker/iobroker-data/backup-objects
                  78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                  57M	/opt/iobroker/iobroker-data/files/vis
                  33M	/opt/iobroker/iobroker-data/objects.jsonl
                  8.2M	/opt/iobroker/iobroker-data/files/modbus.admin/assets/index-6vd4TbNS.js
                  8.1M	/opt/iobroker/iobroker-data/history/20260907/history.growatt.0.1030054.devices.TPJ4CHW072.historyLast.bmsSOC.json
                  USB-Devices by-id:
                  /usr/bin/npm		10.9.8
                  /usr/bin/npx		10.9.8
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  meinbroker          meinbroker (version: 7.2.2, hostname: meinbroker    , alive, uptime: 63651)
                  admin: 		8.0.11
                  javascript: 	10.1.3
                  Adapter State
                  + system.adapter.javascript.0             : javascript            : meinbroker                               -  enabled
                  + instance is alive
                  │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '8.0.11' │ 'none'         │
                  │ 2       │ 'system.adapter.chromecast'                  │ 'chromecast'                  │ '4.2.0'  │ 'none'         │
                  │ 3       │ 'system.adapter.cloud'                       │ 'cloud'                       │ '6.0.1'  │ 'none'         │
                  │ 5       │ 'system.adapter.ds18b20'                     │ 'ds18b20'                     │ '3.1.1'  │ 'none'         │
                  │ 6       │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'  │ 'none'         │
                  │ 10      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'  │ 'none'         │
                  │ 17      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '10.1.3' │ 'none'         │
                  │ 18      │ 'system.adapter.modbus'                      │ 'modbus'                      │ '8.0.3'  │ 'none'         │
                  │ 19      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'  │ 'none'         │
                  │ 20      │ 'system.adapter.net-tools'                   │ 'net-tools'                   │ '1.2.3'  │ 'none'         │
                  │ 21      │ 'system.adapter.node-red'                    │ 'node-red'                    │ '6.0.7'  │ 'none'         │
                  │ 22      │ 'system.adapter.pushover'                    │ 'pushover'                    │ '5.0.0'  │ 'none'         │
                  │ 23      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
                  │ 24      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
                  │ 26      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
                  │ 27      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'  │ 'none'         │
                  │ 28      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
                  │ 29      │ 'system.adapter.vis-2-widgets-gauges'        │ 'vis-2-widgets-gauges'        │ '2.0.2'  │ 'none'         │
                  │ 30      │ 'system.adapter.vis-colorpicker'             │ 'vis-colorpicker'             │ '2.1.0'  │ 'none'         │
                  │ 31      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
                  │ 32      │ 'system.adapter.vis-material-advanced'       │ 'vis-material-advanced'       │ '1.7.4'  │ 'none'         │
                  │ 33      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'  │ 'none'         │
                  │ 34      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'  │ 'none'         │
                  │ 35      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
                  │ 36      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'  │ 'none'         │
                  Adapter    "admin"        : 8.0.11   , installed 8.0.11
                  Adapter    "chromecast"   : 4.2.0    , installed 4.2.0
                  Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                  Adapter    "ds18b20"      : 3.1.1    , installed 3.1.1
                  Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                  Adapter    "history"      : 4.0.0    , installed 4.0.0
                  Adapter    "javascript"   : 10.1.3   , installed 10.1.3
                  Adapter    "modbus"       : 8.0.3    , installed 8.0.3
                  Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
                  Adapter    "node-red"     : 6.0.7    , installed 6.0.7
                  Adapter    "pushover"     : 5.0.0    , installed 5.0.0
                  Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                  Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                  Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                  Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                  Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
                  Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                  Adapter    "web"          : 8.0.0    , installed 8.0.0
                  Adapter    "ws"           : 4.1.0    , installed 4.1.0
                  Objects and States
                  Objects: 	5022
                  States: 	4473
                  Fetched 23.4 kB in 0s (80.7 kB/s)
                  Pending systemupdates: 0
                  udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=18363,fd=23))
                  udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=18363,fd=3))
                  udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("io.chromecast.0",pid=7395,fd=35))
                  udp   UNCONN 0      0                         0.0.0.0:coap               0.0.0.0:*    users:(("io.shelly.1",pid=8154,fd=38))
                  udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=18363,fd=27))
                  udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=18363,fd=26))
                  udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=18363,fd=25))
                  udp   UNCONN 0      0                         0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=678,fd=5),("systemd",pid=1,fd=115))
                  udp   UNCONN 0      0                               *:mdns                     *:*    users:(("evcc",pid=18363,fd=24))
                  udp   UNCONN 0      0                               *:mdns                     *:*    users:(("evcc",pid=18363,fd=7))
                  udp   UNCONN 0      0                               *:sunrpc                   *:*    users:(("rpcbind",pid=678,fd=7),("systemd",pid=1,fd=118))
                  tcp   LISTEN 0      4096                      0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=678,fd=4),("systemd",pid=1,fd=114))
                  tcp   LISTEN 0      511                       0.0.0.0:1880               0.0.0.0:*    users:(("node-red",pid=7852,fd=25))
                  tcp   LISTEN 0      511                       0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.0",pid=8147,fd=38))
                  tcp   LISTEN 0      511                       0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=7964,fd=40))
                  tcp   LISTEN 0      4096                            *:7070                     *:*    users:(("evcc",pid=18363,fd=12))
                  tcp   LISTEN 0      4096                            *:4712                     *:*    users:(("evcc",pid=18363,fd=10))
                  tcp   LISTEN 0      4096                            *:8887                     *:*    users:(("evcc",pid=18363,fd=9))
                  tcp   LISTEN 0      4096                         [::]:sunrpc                [::]:*    users:(("rpcbind",pid=678,fd=6),("systemd",pid=1,fd=116))
                  tcp   LISTEN 0      511                             *:8087                     *:*    users:(("io.simple-api.0",pid=7324,fd=35))
                  tcp   LISTEN 0      511                             *:tproxy                   *:*    users:(("io.admin.0",pid=6973,fd=40))
                  tcp   LISTEN 0      511                             *:8082                     *:*    users:(("io.web.0",pid=8031,fd=35))
                  2026-09-08 12:57:09.891  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Total_Tarif2"},"native":{},"type":"state"},"cbArg":0}
                  2026-09-08 12:57:09.892  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2
                  2026-09-08 12:57:09.893  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif1: {"val":0,"ack":true,"ts":1788865029890,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462801}
                  2026-09-08 12:57:09.943  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Total_Summe"},"native":{},"type":"state"},"cbArg":18392}
                  2026-09-08 12:57:09.944  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe
                  2026-09-08 12:57:09.945  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Tarif2: {"val":0,"ack":true,"ts":1788865029942,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462861}
                  2026-09-08 12:57:09.996  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p1"},"native":{},"type":"state"},"cbArg":0}
                  2026-09-08 12:57:09.996  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1
                  2026-09-08 12:57:09.997  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe: {"val":18392,"ack":true,"ts":1788865029992,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1788863360418}
                  2026-09-08 12:57:10.043  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p2"},"native":{},"type":"state"},"cbArg":0}
                  2026-09-08 12:57:10.044  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2
                  2026-09-08 12:57:10.045  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1: {"val":0,"ack":true,"ts":1788865030042,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462981}
                  2026-09-08 12:57:10.091  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p3"},"native":{},"type":"state"},"cbArg":0}
                  2026-09-08 12:57:10.092  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3
                  2026-09-08 12:57:10.093  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2: {"val":0,"ack":true,"ts":1788865030090,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463081}
                  2026-09-08 12:57:10.139  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p1"},"native":{},"type":"state"},"cbArg":0}
                  2026-09-08 12:57:10.140  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1
                  2026-09-08 12:57:10.144  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3: {"val":0,"ack":true,"ts":1788865030138,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463181}
                  2026-09-08 12:57:10.192  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p2"},"native":{},"type":"state"},"cbArg":0}
                  2026-09-08 12:57:10.192  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2
                  2026-09-08 12:57:10.193  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1: {"val":0,"ack":true,"ts":1788865030190,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463273}
                  2026-09-08 12:57:10.244  - debug: sonoff.0 (7964) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p3"},"native":{},"type":"state"},"cbArg":0}
                  2026-09-08 12:57:10.244  - debug: sonoff.0 (7964) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3
                  2026-09-08 12:57:10.245  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2: {"val":0,"ack":true,"ts":1788865030242,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463333}
                  2026-09-08 12:57:10.294  - debug: sonoff.0 (7964) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3: {"val":0,"ack":true,"ts":1788865030290,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463393}
                  • K
                    K
                    Karl-Heinz1
                    #86
                    Und das folgende ist die Ausgabe von "sudo systemctl status evcc
                    den timout vom vom 3 Wechselrichter bekomme ich nicht weg, ich habe schon einen anderen rs485/usb Adapter genommen und die Schnittstelle am Wechselrichter überprüft. Vielleicht liegt es am Widerstand ? der Adapter wird aber erkannt.
                    ● evcc.service - evcc
                         Loaded: loaded (/usr/lib/systemd/system/evcc.service; enabled; preset: enabled)
                         Active: active (running) since Tue 2026-09-08 12:45:13 CEST; 20min ago
                     Invocation: 392ff29538cf4598882d60989e9b0856
                       Main PID: 18363 (evcc)
                          Tasks: 11 (limit: 3967)
                            CPU: 5.615s
                         CGroup: /system.slice/evcc.service
                                 └─18363 /usr/bin/evcc
                    Sep 08 13:05:33 meinbroker evcc[18363]: [lp-2  ] DEBUG 2026/09/08 13:05:33 charge power: 0W
                    Sep 08 13:05:33 meinbroker evcc[18363]: [lp-1  ] DEBUG 2026/09/08 13:05:33 charge power: 0W
                    Sep 08 13:05:33 meinbroker evcc[18363]: [lp-2  ] DEBUG 2026/09/08 13:05:33 charge currents: [0 0 0]A
                    Sep 08 13:05:33 meinbroker evcc[18363]: [lp-1  ] DEBUG 2026/09/08 13:05:33 charge currents: [0 0 0]A
                    Sep 08 13:05:33 meinbroker evcc[18363]: [site  ] DEBUG 2026/09/08 13:05:33 pv 2 power: 1935W
                    Sep 08 13:05:33 meinbroker evcc[18363]: [site  ] DEBUG 2026/09/08 13:05:33 grid power: 130W
                    Sep 08 13:05:34 meinbroker evcc[18363]: [site  ] DEBUG 2026/09/08 13:05:34 pv 1 power: 4426W
                    Sep 08 13:05:34 meinbroker evcc[18363]: [site  ] DEBUG 2026/09/08 13:05:34 battery 1 power: -1550W
                    Sep 08 13:05:34 meinbroker evcc[18363]: [site  ] DEBUG 2026/09/08 13:05:34 battery 1 soc: 64%
                    Sep 08 13:05:43 meinbroker evcc[18363]: [site  ] ERROR 2026/09/08 13:05:43 pv 3 power: read failed: serial: timeout
                    • K Karl-Heinz1
                              CPU: 5.615s
                      Thomas BraunT
                      Thomas BraunT
                      #87
                      @Karl-Heinz1
                      Jetzt suchst du dir die Datei, die noch eine Referenz auf bookworm enthält:
                      cd /etc/apt/sources.list.d/
                      grep -r "bookworm"
                      und löschst die komplett, wenn da nur eine Zeile drin ist, ansonsten die Zeile mit dem bookworm-Eintrag.
                      Danach dann schauen, ob die Repos dann sauber sind:
                      sudo apt update
                      apt policy evcc
                      • K
                        K
                        Karl-Heinz1
                        #88
                        Da ist das drin
                        -rw-r--r-- 1 root root 378 Jun 18 02:19 debian.sources
                        -rw-r--r-- 1 root root  81 Sep  7 02:34 evcc.list
                        -rw-r--r-- 1 root root 410 Sep  8 12:08 evcc-stable.list
                        -rw-r--r-- 1 root root 155 Sep  6 22:13 nodesource.sources
                        -rw-r--r-- 1 root root 151 Jun 18 02:19 raspi.sources
                        karl-heinz@meinbroker:~ $ ls -l /etc/apt/sources.list.
                        • K Karl-Heinz1
                          Da ist das drin
                          Thomas BraunT
                          Thomas BraunT
                          #89
                          @Karl-Heinz1 sagte:
                          Da ist das drin
                          Und das ist die Ausgabe von welchem Befehl?
                          Immer die VOLLSTÄNDIGEN Ein- wie Ausgaben in der Konsole posten. LoginPrompt inklusive.
                          Damit man sieht WAS du da WO eingegeben hast.
                          Du solltest aber auch
                          grep -r "bookworm"
                          ausführen.
                          Müsste dann aber hier zu suchen sein:
                          evcc.list
                          Also
                          sudo rm /etc/apt/sources.list.d/evcc.list
                          dürfte dann die vorherigen Meldungen zum fehlenden Zertifikat beseitigen.
                          • K
                            K
                            Karl-Heinz1
                            #90
                            ja, den habe ich ausgeführt.
                            karl-heinz@meinbroker:~ $ cd /etc/apt/sources.list.d/
                            grep -r "bookworm"
                            evcc.list:deb [trusted=yes] https://dl.evcc.io/public/evcc/stable/deb/debian bookworm main
                            karl-heinz@meinbroker:/etc/apt/sources.list.d $
                            Das war die Ausgabe.
                            Damit konnte ich nichts anfangen und dann habe ich das eingegeben.
                            karl-heinz@meinbroker:~ $ ls -l /etc/apt/sources.list.d
                            total 20
                            Das war die Ausgabe
                            • K Karl-Heinz1
                              grep -r "bookworm"
                              total 20
                              Das war die Ausgabe
                              Thomas BraunT
                              Thomas BraunT
                              #91
                              @Karl-Heinz1 sagte:
                              Das spuckt alle Dateien aus, die den Text 'bookworm' enthalten. Hier also die evcc.list.
                              Mit
                              wird also die richtige Datei gelöscht.
                              • K
                                K
                                Karl-Heinz1
                                #92
                                der EVCC Adapter ist immer noch nicht grün
                                jetzt ist allerdings auch der Growatt Adapter nicht grün
                                EVCC zeigt aber den Ladezustand der Hausbatterie richtig an und der ändert sich auch, aber die Datenpunkte von Growatt der Hausbatterie sind eingefroren, wie auch die Datenpunkte von EVCC.
                                Diese beiden brauche ich für die Skripte zum Steuern von den Shelly`s für Warmwasser
                                Es wäre schön wenn wir das noch hinbekommen. Ich verspreche, das ich dann regelmässige Updates mache.
                                • K Karl-Heinz1
                                  Thomas BraunT
                                  Thomas BraunT
                                  #93
                                  @Karl-Heinz1 sagte:
                                  Ohne LogFiles wird das schwierig werden.
                                  • K
                                    K
                                    Karl-Heinz1
                                    #94
                                    Das ist die Fehlermeldung von Growatt und EVCC
                                    growatt.0
                                    2026-09-08 20:16:56.838	error	Growatt exception: AxiosError: Request failed with status code 500
                                    evcc.0
                                    2026-09-08 20:16:52.284	error	Invalid URL
                                    bei Growatt habe ich festgestellt, das ich auch nicht auf den Server von Growatt zugreifen kann. Wenn ich mich privat anmelde, werde ich nach Benutzer und Passwort gefragt, danach kommt die erste Seite aber dunkel. Das funktioniert auch nicht. Mit der Handy APP funktioniert es. das wäre ja ein komischer Zufall.
                                    Bei EVCC kommt nur diese eine Meldung. Ich habe die URL geprüft, mit http://192.168.168.XX:7070.
                                    • K
                                      K
                                      Karl-Heinz1
                                      #95
                                      Growatt hat sich erledigt. Die Chinesen haben den wegen Wartungsarbeiten abgeschaltet.
                                      evcc.0
                                      Bei EVCC kommt nur diese eine Meldung. Ich habe die URL geprüft, mit http://192.168.178.XXX:7070 ist die richtig. Ich habe es ohne http:// versucht geht auch nicht.
                                      HomoranH Samson71S 2 Antworten Letzte Antwort
                                      • K
                                        K
                                        Karl-Heinz1
                                        #96
                                        Bei Growatt hat es sich geklärt. Die Chinesen haben Wartungsarbeiten.
                                        Bei EVCC ist es nur diese eine Meldung. Die URL ist OK, wenn ich die mit dem Explorer aufrufe ist die EVCC Seite sofort da.
                                        evcc.0
                                        2026-09-08 21:12:12.435 error Invalid URL
                                        • K
                                          K
                                          Karl-Heinz1
                                          #97
                                          Habe gefunden. Die URL von EVCC ist nicht die, die man im Browser eingibt, wenn man EVCC startet.
                                          EVCC ist jetzt grün
                                          83.9k
