  4. Shelly Adapter - genereller Support
mcm1957shelly
608 Beiträge 82 Kommentatoren 124.0k Aufrufe 59 Beobachtet
  • AtomicIXA
    AtomicIXA
    AtomicIX
    #538
    Hi, ich habe ein Problem mit dem Wall Display:
    shelly.0
    2026-09-03 18:34:10.572	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" initialized.
    shelly.0
    2026-09-03 18:33:43.172	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" connected from 192.168.222.152!
    shelly.0
    2026-09-03 18:33:37.513	info	[MQTT] Client Close: 192.168.222.152 (ShellyWallDisplay / ShellyWallDisplay-00A90B9CDA7C / ShellyWallDisplay#00A90B9CDA7C#1) (false)
    shelly.0
    2026-09-03 18:31:34.457	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" initialized.
    shelly.0
    2026-09-03 18:31:17.532	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" connected from 192.168.222.152!
    zigbee.0
    2026-09-03 18:30:36.891	warn	DeviceAvailability:ELEVATED: Non-pingable device 'Laube Lichtschalter links (0x001788010e8d2e70)' was last seen '985.081' seconds ago.
    shelly.0
    2026-09-03 18:27:42.447	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" initialized.
    shelly.0
    2026-09-03 18:27:18.921	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" connected from 192.168.222.152!
    zigbee.0
    2026-09-03 18:25:36.889	warn	DeviceAvailability:ELEVATED: Non-pingable device 'Laube Lichtschalter links (0x001788010e8d2e70)' was last seen '685.079' seconds ago.
    zigbee.0
    2026-09-03 18:20:36.889	warn	DeviceAvailability:ELEVATED: Non-pingable device 'Laube Lichtschalter links (0x001788010e8d2e70)' was last seen '385.079' seconds ago.
    shelly.0
    2026-09-03 18:18:27.294	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" initialized.
    shelly.0
    2026-09-03 18:18:12.365	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" connected from 192.168.222.152!
    shelly.0
    2026-09-03 18:17:03.954	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" initialized.
    shelly.0
    2026-09-03 18:16:50.302	info	[MQTT] Device with client id "ShellyWallDisplay-00A90B9CDA7C" connected from 192.168.222.152!
    Es funktioniert aber eigentlich ohne Probleme. Was kann ich dagegen tun?
    Der Log ist voll damit.
    • mcm1957M
      mcm1957M
      mcm1957
      #539
      Aus irgendeinem Grund scheint die Verbindung zu dem Device ständig abzubrechen. Kann es sein, dass dein Netzwerk schwach ist?:
      Prüf ob du den Energiesparmodus bei Wall Display aktiv hast (falls es den dort gibt).
      Wenn du den Loglevel des Adapters auf Warning stellst werden die connects nicht mehr gelogged. Als Workraound auch anzudenken,
      • AtomicIXA
        AtomicIXA
        AtomicIX
        #540
        Okay, werde ich morgen mal testen. Also das Netzwerk ist gut. Das Display ist ca. 1 m vom AP entfernt. Alles anderen Geräte machen keine Probleme im Netzwerk.
        In den Einstellungen finde ich nichts zum Energiesparen, werde morgen mal direkt im Display schauen.
        Wollte nur mal fragen, ob es vielleicht ein bekanntest Problem damit gibt. Werde sonst mal einen Werksreset machen.
        • Holger EtzelH
          Holger EtzelH
          Holger Etzel
          #541
          hat schon jemand Erfahrungen mit der neuen Shelly-Kamera sammeln können?
          Welche Datenpunkte bekomme ich im IoBroker, bzw. habe ich Zugriff auf die EInstellungen auf der Kamera, Gibt es Datenpunkte für Snapshot oder Streams?
          Holger
          mcm1957M haus-automatisierungH 2 Antworten Letzte Antwort
          • Holger EtzelH Holger Etzel
            Holger
            mcm1957M
            mcm1957M
            mcm1957
            #542
            Keine Ahnung, aber die Kamery ist derzeit noch nicht in der API Dokumentaion enthalten.
            Korrektur - die Kamera wurde in die Dokumentation aufgenommen
            keine
            nein
            Die Kamera ist brand neu. Derzeit ist sie nicht im Adapter implementiert.
            Leg bitte ein Issue an (https://github.com/iobroker-community-adapters/ioBroker.shelly/issues) dann bekommst du es schneller mit wenn die Kamera implementiert wurde und Tester gesucht werden.
            • mcm1957M
              mcm1957M
              mcm1957
              #543
              Dieser Beitrag wurde gelöscht!
                Holger
                #544
                @Holger-Etzel sagte:
                Ich plane die nächste Woche zu integrieren.
                📚 Meine Dokumentation
                • AtomicIXA AtomicIX
                  Hallo, ich probiere eine "shelly multicolor bulb e27 gen3" im iobroker zu bekommen.
                  Ich nutze den aktuellen Shelly Adapter. Dort sind auch viele weitere Shelly Geräte, die über mqtt, problemlos funktionieren.
                  Die Lampe (es ist meine erste) will sich einfach nicht über mqtt verbinden.
                  In der Shelly App steht, keine Verbindung bei den Mqtt Einstellungen. Ich habe alle Einstellungen, mehrmals überprüft, die Lampe, zurückgesetzt. Alles ohne Erfolg. Die Lampe selber, funktioniert. Lokal oder über die Shelly Cloud.
                  Was könnte ich jetzt noch machen, damit die Lampe sich über mqtt, mit dem Iobroker (Shelly Adapter) unterhält?
                  mcm1957M
                  mcm1957M
                  mcm1957
                  #545
                  @Rene55 said:
                  Aktuell habe ich Probleme, meinen Shelly AZ H&T ins System zu bekommen.
                  Gibt ne neue ALPHA Version - siehe hier: https://forum.iobroker.net/post/1353826
                  • S
                    S
                    SP
                    #546
                    Guten Morgen zusammen,
                    ich binde gerade einen shelly in den iO Broker ein das funktioniert auch soweit. Es gibt nur ein Problem bei der Rückmeldung. Wenn ich z.B. das widget Metro verwende, um den shelly einzuschalten passiert es manchmal, dass das widget kurz seinen Zustand ändert und dann wieder zurück wechselt. Das Licht schaltet aber richtig. Manchmal schaltet das Licht ein, dass widget braucht dann etwas bis die Rückmeldung ankommt.
                    Ich hoffe ihr könnt mir helfen.
                    Lg SP
                    • mcm1957M
                      mcm1957M
                      mcm1957
                      #547
                      gremz mal ein ob widget od shellly problem
                      Welche statrs schaltest di über welchen Adapter in welchet Version?
                      schalte di states direlt im object browser. funktioniert das hats was mit dem widget
                      • S
                        S
                        SP
                        #548
                        Ich habe den Shelly über den shelly Adapter angebunden. Ich schalte den Relay.0 switch. Wenn ich den aus der Instanz schalte passiert genau das selbe. Der Schalter wechselt kurz seinen Zustand und geht dann wieder zurück. Manchmal klappt es aber auch und manchmal geht der Schalter erst nach einer Zeit auf den richtigen Status. Der Status klappt immer aber teilweise sehr verzögert >10 Sek.. Laut Ki liegt es an der falschen Zuordnung der Instanzen. Da bin ich mir aber nicht so sicher.
                        • mcm1957M
                          mcm1957M
                          mcm1957
                          #549
                          Ok, da es primär mal um den Shelly geht hab ich das Topic in den Shelly Supportthread gehängt.
                          Bitte leifer mal Versionsabgaben:
                          • version der shelly Adpaters
                          • version js-controller
                          • version der firmware des shelly plug 1 pm g3
                          Und dann häng ein log mit Level DEBUG an.
                          Die AI schick mal nach Hause, keine Idee was sie da von falscher Instanz fabuliert. Wenn der Shelly nicht mit der Instanz verbunden wäre wäre gar keine Reaktion zu sehen ...
                          • S
                            S
                            SP
                            #550
                            Guten Morgen,
                            es hat etwas gedauert.
                            • Version der shelly Adapter = Adapter im IoBroker ist 10.6.1
                            • version js-controller = IoBroker ist 7.2.2
                            • version der firmware des shelly plug 1 pm g3 = 20260710-101127/2.0.0-g87fbfa4
                            Ich habe die Log Einträge mit an die Nachricht gehängt ich hoffe das ist so OK
                            2026-09-09 11:14:36.642 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.uptime, value: 128058
                            2026-09-09 11:14:40.666 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.uptime, value: 436556
                            2026-09-09 11:14:40.666 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.rssi, value: -71
                            2026-09-09 11:14:41.981 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.uptime, value: 128063
                            2026-09-09 11:14:41.981 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.rssi, value: -67
                            2026-09-09 11:14:46.170 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.uptime, value: 436562
                            2026-09-09 11:14:47.340 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.uptime, value: 128068
                            2026-09-09 11:14:47.341 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.rssi, value: -68
                            2026-09-09 11:14:49.863 - debug: shelly.0 (18136) [onStateChange] "shelly.0.shelly1pmminig3#5432044edbc0#1.Relay0.Switch" state changed: {"val":true,"ack":false,"ts":1788945289865,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1788945289865} - forwarding to objectHelper
                            2026-09-09 11:14:49.863 - debug: shelly.0 (18136) [mqtt controlFunction] Executing state.mqtt.mqtt_cmd_funct of state shelly1pmminig3#5432044edbc0#1.Relay0.Switch for 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) with value: true -> {"id":8,"src":"iobroker","method":"Switch.Set","params":{"id":0,"on":true}}
                            2026-09-09 11:14:49.863 - debug: shelly.0 (18136) [MQTT] Send state to 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) with QoS 0: shelly1pmminig3-5432044edbc0/rpc = {"id":8,"src":"iobroker","method":"Switch.Set","params":{"id":0,"on":true}} (10)
                            2026-09-09 11:14:50.267 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: iobroker/rpc, qos: 1, payload: {"id":8,"src":"shelly1pmminig3-5432044edbc0","dst":"iobroker","result":{"was_on":false}}
                            2026-09-09 11:14:50.308 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/status/switch:0, qos: 1, payload: {"id":0,"source":"MQTT","tag":null, "output":false, "apower":0.0, "voltage":239.9, "freq":50.0, "current":0.000, "aenergy":{"total":152669.987,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945240}, "ret_aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945240},"counts":{"on_time":44340,"on_time_rst_ts":0,"switch_on":539,"switch_on_rst_ts":0,"on_above_thr":0,"on_above_thr_rst_ts":0},"temperature":{"tC":55.3, "tF":131.6}}
                            2026-09-09 11:14:50.309 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Switch, value: false
                            2026-09-09 11:14:50.309 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Voltage, value: 239.9
                            2026-09-09 11:14:50.315 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/events/rpc, qos: 1, payload: {"src":"shelly1pmminig3-5432044edbc0","dst":"shelly1pmminig3-5432044edbc0/events","method":"NotifyStatus","params":{"ts":1788945292.01,"switch:0":{"output":true,"source":"MQTT"}}}
                            2026-09-09 11:14:51.720 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.uptime, value: 436567
                            2026-09-09 11:14:52.675 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.uptime, value: 128074
                            2026-09-09 11:14:52.676 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.rssi, value: -69
                            2026-09-09 11:14:56.183 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/events/rpc, qos: 1, payload: {"src":"shelly1pmminig3-5432044edbc0","dst":"shelly1pmminig3-5432044edbc0/events","method":"NotifyStatus","params":{"ts":1788945292.88,"switch:0":{"apower":11.5,"current":0.071}}}
                            2026-09-09 11:14:56.190 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/status/switch:0, qos: 1, payload: {"id":0,"source":"MQTT","tag":null, "output":true, "apower":11.5, "voltage":240.3, "freq":50.0, "current":0.073, "aenergy":{"total":152669.987,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945240}, "ret_aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945240},"counts":{"on_time":44340,"on_time_rst_ts":0,"switch_on":539,"switch_on_rst_ts":0,"on_above_thr":0,"on_above_thr_rst_ts":0},"temperature":{"tC":55.0, "tF":131.0}}
                            2026-09-09 11:14:56.190 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Switch, value: true
                            2026-09-09 11:14:56.190 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.temperatureC, value: 55
                            2026-09-09 11:14:56.191 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.temperatureF, value: 131
                            2026-09-09 11:14:56.191 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Power, value: 11.5
                            2026-09-09 11:14:56.191 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Voltage, value: 240.3
                            2026-09-09 11:14:56.191 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Current, value: 0.073
                            2026-09-09 11:14:57.146 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.uptime, value: 436573
                            2026-09-09 11:14:57.146 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.rssi, value: -72
                            2026-09-09 11:14:57.928 - debug: shelly.0 (18136) [onStateChange] "shelly.0.shelly1pmminig3#5432044edbc0#1.Relay0.Switch" state changed: {"val":true,"ack":false,"ts":1788945297929,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1788945296194} - forwarding to objectHelper
                            2026-09-09 11:14:57.929 - debug: shelly.0 (18136) [mqtt controlFunction] Executing state.mqtt.mqtt_cmd_funct of state shelly1pmminig3#5432044edbc0#1.Relay0.Switch for 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) with value: true -> {"id":9,"src":"iobroker","method":"Switch.Set","params":{"id":0,"on":true}}
                            2026-09-09 11:14:57.929 - debug: shelly.0 (18136) [MQTT] Send state to 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) with QoS 0: shelly1pmminig3-5432044edbc0/rpc = {"id":9,"src":"iobroker","method":"Switch.Set","params":{"id":0,"on":true}} (11)
                            2026-09-09 11:14:57.929 - debug: shelly.0 (18136) [mqtt controlFunction] Ack state.mqtt.mqtt_cmd of state shelly1pmminig3#5432044edbc0#1.Relay0.Switch for 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) in adapter: Value not changed
                            2026-09-09 11:14:57.962 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: iobroker/rpc, qos: 1, payload: {"id":9,"src":"shelly1pmminig3-5432044edbc0","dst":"iobroker","result":{"was_on":true}}
                            2026-09-09 11:14:58.020 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.uptime, value: 128079
                            2026-09-09 11:14:58.021 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.rssi, value: -68
                            2026-09-09 11:14:58.278 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/events/rpc, qos: 1, payload: {"src":"shelly1pmminig3-5432044edbc0","dst":"shelly1pmminig3-5432044edbc0/events","method":"NotifyStatus","params":{"ts":1788945300.00,"switch:0":{"counts":{"on_above_thr":0,"on_time":44340,"switch_on":539}}}}
                            2026-09-09 11:14:58.289 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1) - topic: ShellyLichtGarten/events/rpc, qos: 1, payload: {"src":"shelly1pmminig3-e4b323133734","dst":"ShellyLichtGarten/events","method":"NotifyStatus","params":{"ts":1788945300.02,"switch:0":{"counts":{"on_above_thr":0,"on_time":241680,"switch_on":192}}}}
                            2026-09-09 11:14:58.317 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1) - topic: ShellyLichtGarten/status/switch:0, qos: 1, payload: {"id":0,"source":"SHC","tag":null, "output":false, "apower":0.0, "voltage":238.3, "freq":50.0, "current":0.000, "aenergy":{"total":2690.730,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300}, "ret_aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300},"counts":{"on_time":241680,"on_time_rst_ts":0,"switch_on":192,"switch_on_rst_ts":0,"on_above_thr":0,"on_above_thr_rst_ts":0},"temperature":{"tC":56.1, "tF":132.9}}
                            2026-09-09 11:14:58.318 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): ShellyLichtGarten/status/switch:0 -> state: shelly1pmminig3#e4b323133734#1.Relay0.temperatureC, value: 56.1
                            2026-09-09 11:14:58.318 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): ShellyLichtGarten/status/switch:0 -> state: shelly1pmminig3#e4b323133734#1.Relay0.temperatureF, value: 132.9
                            2026-09-09 11:14:58.318 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): ShellyLichtGarten/status/switch:0 -> state: shelly1pmminig3#e4b323133734#1.Relay0.Voltage, value: 238.3
                            2026-09-09 11:14:58.319 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1) - topic: ShellyLichtGarten/status/switch:0, qos: 1, payload: {"id":0,"source":"SHC","tag":null, "output":false, "apower":0.0, "voltage":238.3, "freq":50.0, "current":0.000, "aenergy":{"total":2690.730,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300}, "ret_aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300},"counts":{"on_time":241680,"on_time_rst_ts":0,"switch_on":192,"switch_on_rst_ts":0,"on_above_thr":0,"on_above_thr_rst_ts":0},"temperature":{"tC":56.1, "tF":132.9}}
                            2026-09-09 11:14:58.319 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1) - topic: ShellyLichtGarten/events/rpc, qos: 1, payload: {"src":"shelly1pmminig3-e4b323133734","dst":"ShellyLichtGarten/events","method":"NotifyStatus","params":{"ts":1788945300.02,"switch:0":{"aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300,"total":2690.730},"apower":0.0,"current":0.000,"freq":50.03,"ret_aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300,"total":0.000},"voltage":238.3}}}
                            2026-09-09 11:14:58.347 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/status/switch:0, qos: 1, payload: {"id":0,"source":"MQTT","tag":null, "output":true, "apower":11.5, "voltage":240.3, "freq":50.0, "current":0.073, "aenergy":{"total":152669.987,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945240}, "ret_aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300},"counts":{"on_time":44340,"on_time_rst_ts":0,"switch_on":539,"switch_on_rst_ts":0,"on_above_thr":0,"on_above_thr_rst_ts":0},"temperature":{"tC":55.3, "tF":131.6}}
                            2026-09-09 11:14:58.348 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.temperatureC, value: 55.3
                            2026-09-09 11:14:58.348 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.temperatureF, value: 131.6
                            2026-09-09 11:14:58.354 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/events/rpc, qos: 1, payload: {"src":"shelly1pmminig3-5432044edbc0","dst":"shelly1pmminig3-5432044edbc0/events","method":"NotifyStatus","params":{"ts":1788945300.03,"switch:0":{"aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300,"total":152669.987},"apower":11.5,"current":0.073,"freq":50.01,"ret_aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300,"total":0.000},"voltage":240.3}}}
                            2026-09-09 11:14:58.355 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/status/switch:0, qos: 1, payload: {"id":0,"source":"MQTT","tag":null, "output":true, "apower":11.5, "voltage":240.3, "freq":50.0, "current":0.073, "aenergy":{"total":152669.987,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300}, "ret_aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300},"counts":{"on_time":44340,"on_time_rst_ts":0,"switch_on":539,"switch_on_rst_ts":0,"on_above_thr":0,"on_above_thr_rst_ts":0},"temperature":{"tC":55.3, "tF":131.6}}
                            2026-09-09 11:15:02.216 - debug: shelly.0 (18136) [onStateChange] "shelly.0.shelly1pmminig3#5432044edbc0#1.Relay0.Switch" state changed: {"val":false,"ack":false,"ts":1788945302217,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1788945302217} - forwarding to objectHelper
                            2026-09-09 11:15:02.216 - debug: shelly.0 (18136) [mqtt controlFunction] Executing state.mqtt.mqtt_cmd_funct of state shelly1pmminig3#5432044edbc0#1.Relay0.Switch for 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) with value: false -> {"id":10,"src":"iobroker","method":"Switch.Set","params":{"id":0,"on":false}}
                            2026-09-09 11:15:02.217 - debug: shelly.0 (18136) [MQTT] Send state to 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) with QoS 0: shelly1pmminig3-5432044edbc0/rpc = {"id":10,"src":"iobroker","method":"Switch.Set","params":{"id":0,"on":false}} (12)
                            2026-09-09 11:15:02.250 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: iobroker/rpc, qos: 1, payload: {"id":10,"src":"shelly1pmminig3-5432044edbc0","dst":"iobroker","result":{"was_on":true}}
                            2026-09-09 11:15:02.295 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/status/switch:0, qos: 1, payload: {"id":0,"source":"MQTT","tag":null, "output":false, "apower":0.0, "voltage":240.2, "freq":50.0, "current":0.000, "aenergy":{"total":152669.987,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300}, "ret_aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1788945300},"counts":{"on_time":44340,"on_time_rst_ts":0,"switch_on":539,"switch_on_rst_ts":0,"on_above_thr":0,"on_above_thr_rst_ts":0},"temperature":{"tC":55.1, "tF":131.2}}
                            2026-09-09 11:15:02.296 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Switch, value: false
                            2026-09-09 11:15:02.296 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.temperatureC, value: 55.1
                            2026-09-09 11:15:02.296 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.temperatureF, value: 131.2
                            2026-09-09 11:15:02.297 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Power, value: 0
                            2026-09-09 11:15:02.297 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Voltage, value: 240.2
                            2026-09-09 11:15:02.297 - debug: shelly.0 (18136) [MQTT] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): shelly1pmminig3-5432044edbc0/status/switch:0 -> state: shelly1pmminig3#5432044edbc0#1.Relay0.Current, value: 0
                            2026-09-09 11:15:02.307 - debug: shelly.0 (18136) [MQTT] Publish: 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1) - topic: shelly1pmminig3-5432044edbc0/events/rpc, qos: 1, payload: {"src":"shelly1pmminig3-5432044edbc0","dst":"shelly1pmminig3-5432044edbc0/events","method":"NotifyStatus","params":{"ts":1788945303.99,"switch:0":{"apower":0,"current":0,"output":false,"source":"MQTT"}}}
                            2026-09-09 11:15:02.589 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.uptime, value: 436578
                            2026-09-09 11:15:02.590 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.rssi, value: -71
                            2026-09-09 11:15:03.424 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.uptime, value: 128084
                            2026-09-09 11:15:03.424 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.rssi, value: -69
                            2026-09-09 11:15:08.113 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.uptime, value: 436584
                            2026-09-09 11:15:08.113 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.82 (shelly1pmminig3 / shelly1pmminig3-5432044edbc0 / shelly1pmminig3#5432044edbc0#1): state: shelly1pmminig3#5432044edbc0#1.rssi, value: -70
                            2026-09-09 11:15:08.929 - debug: shelly.0 (18136) [httpIoBrokerState] State change 192.168.178.123 (shelly1pmminig3 / shelly1pmminig3-e4b323133734 / shelly1pmminig3#e4b323133734#1): state: shelly1pmminig3#e4b323133734#1.uptime, value: 128090
                            • mcm1957M
                              mcm1957M
                              mcm1957
                              #551
                              Bitte leg ein Issue an. Muss mir das noch genauer ansehen - aber auf den ersten Blick sieht es so aus aös würde shelly schon wieder bei einem Gerät falsche Daten senden ...
                              • S
                                S
                                SP
                                #552
                                Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
                                Hinweis: Das Eröffnen eines Issues hier ersetzt NICHT das Anlegen eine Issues im Repository des Adapters. Fehlerbehebungen werden ausschließlich über Issues getrackt.
                                DANKE
                                Bitte ausfüllen:
                                • Adaptername: Shelly
                                • Link zu Adapterrepository: Github(https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/1592)
                                • Adapterversion: 10.6.1
                                • js-controller Version: 7.2.2
                                • Admin Version: 7.8.23
                                • Hardwaresystem: Windows 11 Laptop (Test)
                                • Arbeitsspeicher: 8GB
                                • Festplattenart: SSD,
                                • Betriebssystem: Windows 11
                                • Nodejs-Version: v22.23.2
                                • NPM-Version: 10.9.8
                                • Installationsart: Skript oder Manuell ?
                                • Image, Docker genutzt: Nein
                                • Ort, Name der Imagedatei: ...
                                Linux User bitte hier den Output von iob diag einfügen.
                                Bei betätigen der Taste Licht Ein/Aus geht die Rückmeldung in der VIS 2 nicht auf den Zustand ein/aus oder nur kurz. Das Licht geht an, die Rückmeldung zieht irgendwann in der Visualisierung nach.
                                • S
                                  S
                                  SP
                                  #553
                                  habe ich erledigt
                                  • mcm1957M
                                    mcm1957M
                                    mcm1957
                                    #554
                                    @sp
                                    Danke für das Issue. Hab deine Postings hier im Supprottopic zusammengefasst.
                                    • N
                                      N
                                      Norb 0
                                      #555
                                      Ich habe ein ähnliches Problem mit Shelly Pro 2PM, Shelly PlugS Gen3:
                                      Beispiel:
                                      Der Relaisausgang des Shellys (PlugS Gen3, IP 192.168.178.114) wurde mit dem Objekt (shelly.0.shellyplugsg3#8cbfea9585e8#1.Relay0.Switch) von true auf false gesetzt. Das Relais des Shelly hat sofort reagiert, der Status des Objekts "Switch" im ioBroker ging ganz kurz auf false dann sofort wieder auf true, erst nach einer Verzögerung von mehreren Sekunden auf false (siehe log). Ich habe bereits diverse Einstellungen im Adapter und Shelly versucht, ohne Erfolg.
                                      Es kommen auch einige Fehlermeldungen im log (Request failed with status code 429).
                                      Ist dies das gleiche Problem oder ein Neues?
                                      log.txt
                                      • mcm1957M
                                        mcm1957M
                                        mcm1957
                                        #556
                                        Status 429 wird durch ein Änderung in der Shelly Firmware 2.x.x ausgelöst und sollte nur auftreten wenn du den Shelly mit einem (HTTP) Passwort geschützt hast. Ein Fix wird voraussichtlich mit 12.0.0 kommen.
                                        Das Verhalten des Relais States dürfte durch ein Fehlverhalten (aka Bug) im Shelly Code ausgelöst werden. Bitte leg ein (weiteres) Issue beim Adapter an wenn du kannst.Ich check das Log genauer sobald ich dazu komm. In den bisherogen Fällen hat der Shelly nach dem Statusschalten auf ON eine Statusnachrcht mit Status OFF (!) zurückgesendet und erst bei der nächsten Statusnachrichtig das richtieg ON gesendet ... (Ein diesbezügliches Issue hab ich bei Shelly für den 1L Gen3 offen. Das sollte mit V2.0.0 behoben sein - so wies aussieht ist es aber eher verbreuitere als vorher ...)
                                        Ev teste bitte auch die neueste BETA Shelly FW. Da ist eine Fehlerhebung beim verspäteten Tags drinnen. Tags sind zwar was anderes aber ev. hängt das zusammen)
                                        • N
                                          N
                                          Norb 0
                                          schrieb am zuletzt editiert von Norb 0
                                          #557
                                          Habe die FW auf 2.0.1-beta1 hochgezogen, gleiches Problem.
                                          Ticket erstellt: https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/1594
                                          84.2k
