  4. EVCC wird nicht grün
83 Beiträge 4 Kommentatoren 785 Aufrufe 3 Beobachtet
  • K Karl-Heinz1
    Script v.2026-08-30
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 11 (bullseye)
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 400 Rev 1.1
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 1443 days ago (on 2022-09-22).
    Systemuptime and Load:
     13:44:49 up  3:16,  2 users,  load average: 0.08, 0.15, 0.15
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-09-04 13:44:49 CEST
               Universal time: Fri 2026-09-04 11:44:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:		Unknown
    Display-Manager: 	* lightdm.service - Light Display Manager
    Desktop:
    Session:		tty
    Boot Target: 		multi-user.target
    *** MEMORY ***
    Mem:            3.8G        156M        3.3G        1.0M        344M        3.6G
    Swap:            99M          0B         99M
    Total:          3.9G        156M        3.4G
    Active iob-Instances: 	0
             3794 M total memory
              156 M used memory
              348 M active memory
               62 M inactive memory
             3293 M free memory
               29 M buffer memory
              314 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 13:44:51 up  3:16,  2 users,  load average: 0.15, 0.17, 0.15
    Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3794.3 total,   3293.5 free,    156.3 used,    344.6 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3569.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       29G   17G   12G  60% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.3M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    Messages concerning filesystems in dmesg (Last 15 lines only):
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.1G	/var/
    3.1G	/var/log
    2.9G	/var/log/journal/79e438becaf044e4ab8664814f73dec8
    757M	/var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    170M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    4.6G	/opt/iobroker/iobroker-data/
    3.5G	/opt/iobroker/iobroker-data/history
    994M	/opt/iobroker/iobroker-data/files
    493M	/opt/iobroker/iobroker-data/files/javascript.admin
    461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    43M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map
    33M	/opt/iobroker/iobroker-data/objects.jsonl
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0
    /dev/serial/by-id/usb-FTDI_USB_Serial_Converter_FTB6SPL3-if00-port0
    No nvbackup.json found.
    *** NodeJS-Installation ***
    *** Node.js is NOT correctly installed ***
    Issues:  nodejs path x node path x npm path x npx path
    Execute 'iob nodejs-update' in your terminal.
    nodejs:
      Installed: (none)
      Candidate: 12.22.12~dfsg-1~deb11u8
      Version table:
         12.22.12~dfsg-1~deb11u8 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    sudo: node: command not found
    Hosts:
    Core adapters versionssudo: node: command not found
    js-controller: 	sudo: node: command not found
    admin: 		sudo: node: command not found
    javascript:
    nodejs modules from github: 	0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Adapters
    ioBroker-Adapter Versions and update status
    Objects and States
    Objects: 	0
    States: 	0
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian bullseye InRelease
    Fetched 11.7 kB in 1s (9463 B/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0            0.0.0.0:35997              0.0.0.0:*    users:(("avahi-daemon",pid=416,fd=14))
    udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=636,fd=21))
    udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=636,fd=3))
    udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=416,fd=12))
    udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=25))
    udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=24))
    udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=23))
    udp   UNCONN 0      0            0.0.0.0:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=531,fd=13))
    udp   UNCONN 0      0                  *:55910                    *:*    users:(("avahi-daemon",pid=416,fd=15))
    udp   UNCONN 0      0                  *:mdns                     *:*    users:(("evcc",pid=636,fd=22))
    udp   UNCONN 0      0                  *:mdns                     *:*    users:(("evcc",pid=636,fd=6))
    udp   UNCONN 0      0                  *:mdns                     *:*    users:(("avahi-daemon",pid=416,fd=13))
    udp   UNCONN 0      0                  *:dhcpv6-client            *:*    users:(("dhcpcd",pid=531,fd=16))
    tcp   LISTEN 0      5            0.0.0.0:5900               0.0.0.0:*    users:(("vncserver-x11-c",pid=671,fd=12))
    tcp   LISTEN 0      128        127.0.0.1:ipp                0.0.0.0:*    users:(("cupsd",pid=634,fd=7))
    tcp   LISTEN 0      128          0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=692,fd=3))
    tcp   LISTEN 0      5               [::]:5900                  [::]:*    users:(("vncserver-x11-c",pid=671,fd=11))
    tcp   LISTEN 0      128            [::1]:ipp                   [::]:*    users:(("cupsd",pid=634,fd=6))
    tcp   LISTEN 0      128             [::]:ssh                   [::]:*    users:(("sshd",pid=692,fd=4))
    tcp   LISTEN 0      4096               *:7070                     *:*    users:(("evcc",pid=636,fd=12))
    tcp   LISTEN 0      4096               *:8887                     *:*    users:(("evcc",pid=636,fd=8))
    tcp   LISTEN 0      4096               *:4712                     *:*    users:(("evcc",pid=636,fd=9))
    2026-09-04 09:51:22.503  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
    2026-09-04 09:51:22.753  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2026-09-04 09:51:22.753  - info: host.raspberrypi All instances are stopped.
    2026-09-04 09:51:22.753  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGKILL
    2026-09-04 09:51:22.754  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
    2026-09-04 09:51:22.754  - info: host.raspberrypi All instances are stopped.
    2026-09-04 09:51:22.754  - warn: host.raspberrypi instance system.adapter.discovery.0 terminated due to SIGKILL
    2026-09-04 09:51:22.754  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code null ()
    2026-09-04 09:51:22.755  - warn: host.raspberrypi instance system.adapter.ds18b20.0 terminated due to SIGKILL
    2026-09-04 09:51:22.755  - info: host.raspberrypi instance system.adapter.ds18b20.0 terminated with code null ()
    2026-09-04 09:51:22.755  - info: host.raspberrypi All instances are stopped.
    2026-09-04 09:51:22.756  - warn: host.raspberrypi instance system.adapter.iot.0 terminated due to SIGKILL
    2026-09-04 09:51:22.756  - info: host.raspberrypi instance system.adapter.iot.0 terminated with code null ()
    2026-09-04 09:51:22.756  - info: host.raspberrypi All instances are stopped.
    2026-09-04 09:51:22.756  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL
    2026-09-04 09:51:22.757  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
    2026-09-04 09:51:22.757  - info: host.raspberrypi All instances are stopped.
    2026-09-04 09:51:22.757  - warn: host.raspberrypi instance system.adapter.pushover.0 terminated due to SIGKILL
    2026-09-04 09:51:22.757  - info: host.raspberrypi instance system.adapter.pushover.0 terminated with code null ()
    2026-09-04 09:51:22.757  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGKILL
    2026-09-04 09:51:22.758  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
    2026-09-04 09:51:22.758  - info: host.raspberrypi All instances are stopped.
    2026-09-04 09:51:22.936  - info: host.raspberrypi terminated
    @Karl-Heinz1
    iob nodejs-update 22
      Karl-Heinz1
      Danke, jetzt läuft der iobroker wieder.
      Jetzt Backup mit Backitup.0 ?
      da ist bei mir in den Einstellung ein Haken bei iobroker und bei Javascript
      sonst nichts.
      Ist das OK
      Thomas BraunT fuzzy1955F 2 Antworten Letzte Antwort
      • K Karl-Heinz1
        sonst nichts.
        Ist das OK
        @Karl-Heinz1 sagte:
        Ist das OK
        Keine Ahnung, was du da alles laufen hast und sichern musst.
          Karl-Heinz1
          Ich habe nur den iobroker und evcc für Solarüberschussladen, sonst keine Software. Die Shelly`s steuere ich über den iobroker und die sonoff Adapter lese ich nur aus.
          • K Karl-Heinz1
            sonst nichts.
            Ist das OK
            fuzzy1955F Offline
            fuzzy1955F Offline
            fuzzy1955
            @Karl-Heinz1 sagte:
            History Daten?
            InfluxDB?
            Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
            Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
            Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
            Großes Danke an alle tatkräftigen Helfer im Forum!
              Karl-Heinz1
              Ich habe jetzt bei History und influxdb einen haken gemacht. Aber mich interessiert eigentlich nichts was vor 1 Jahr war. Und Monatsverbrauch, Tag und Jahr speichere ich in eigens erstellten Datenpunkten für 1 Jahr.
                Karl-Heinz1
                Ich habe jetzt alles soweit durchgeführt.
                Mir ist jetzt aber nicht klar, wie jetzt weiter. Eine neu Installation laut Doku macht doch den Speicherchip leer, dann ist meine Datensicherung weg und auch EVCC.
                Wie muss ich jetzt weiter machen.
                • K Karl-Heinz1
                  @Karl-Heinz1 sagte:
                  Backups immer auf externe Medien, damit man die dann von dort auch zurückspielen kann.
                    Karl-Heinz1
                    Leider habe ich zuwenig Zeit. Da fehlen mir Grundlagen, weil ich nicht so einfach weiss wie ich die Dateien finde und wie ich die auf meinen Mac bekomme. Ich blicke nicht durch die Linux Dateistruktur durch bzw. was da so auf dem Bildschirm steht das dauert jetzt erst mal.
                    • K Karl-Heinz1
                      @Karl-Heinz1 sagte:
                      Die solltest du dir aneignen. Wie sicherst du denn derzeitig deine Daten?
                      Wenn nichts anderes eingestellt ist liegen die Backups im Verzeichnis /opt/iobroker/backups/
                      Man kann und sollte die allerdings auf ein externes Medium schieben. Da gibt es verschiedene Ansätze.
                      Ich mounte z. B. eine Freigabe auf der FritzBox und schreibe dann direkt dorthin.
                      Was ist eigentlich dein Plan für einen Hardwaredefekt? Kann ja auch jederzeit eintreten.
                        Karl-Heinz1
                        ich habe jetzt laut Doku einen neuen Speicherchip erstellt. Leider komme ich nicht weiter Nachdem Eingabe ssh pi@192.XXXXX erfolgt die Passwort Abfrage mit dem Ergebnis Permission denied, please try again.
                        Ich habe die Erstellung nach der Doku gemacht.
                        ssh mit ja Passwörter auch eingeben und schon mehrfach neu versucht.
                        Passwörter nur mit Buchstaben und Zahlen ohne Sonderzeichen, leider alles ohne Erfolg.
                        • K Karl-Heinz1
                          HomoranH Offline
                          HomoranH Offline
                          @Karl-Heinz1
                          Hast du auch SSH bei der Installation aktiviert?
                            Karl-Heinz1
                            Ja ssh habe ich aktiviert
                            • HomoranH Offline
                              HomoranH Offline
                              Und auch einen eigene User angelegt?
                              Womöglich nicht als "pi"?
                                Karl-Heinz1
                                ich habe nicht alles dokumentiert. Ich bin einfach nur der Doku
                                "Einfacher gehts nicht"
                                Ich versuche es jetzt noch einmal und wenn ich unsicher bin frage ich dann hier.
                                • K Karl-Heinz1
                                  HomoranH Offline
                                  HomoranH Offline
                                  @Karl-Heinz1 sagte:
                                  Richtig!
                                    Karl-Heinz1
                                    Ich habe einen Raspberry pi 400.
                                    Welches Betriebssystem Raspberry PI OS (other) oder
                                    Raspberry PI OS lite (64 Bit)
                                    die beiden sind blau hinterlegt also empfohlen ?
                                    • K Karl-Heinz1
                                      HomoranH Offline
                                      HomoranH Offline
                                      @Karl-Heinz1 sagte:
                                        Karl-Heinz1
                                        Fertig SD in der Raspi eingelegt und eingeschaltet.
                                        im Mac Terminal ssh pi@192.168.178.XXX eingeben
                                        ist das OK
                                        • K Karl-Heinz1
                                          ist das OK
                                          HomoranH Offline
                                          HomoranH Offline
                                          @Karl-Heinz1 sagte:
                                          ist das OK
                                          Wenn die IP stimmt
                                          Wenn dein User entgegen der Anleitung tatsächlich pi heisst
                                          Wenn du in den Einstellungen nochmal geprüft hast op ssh aktiv ist
                                          Dann ja!
                                          Vorausgesetzt dass der Mäc da nicht irgendwelche Sicherheitseinstellungen benötigt.
                                          Mit Äpfeln kenne ich mich nicht aus.
