  4. EVCC wird nicht grün
83 Beiträge 4 Kommentatoren 785 Aufrufe 3 Beobachtet
    Karl-Heinz1
    Jetzt startet der iobroker nicht mehr.
    pi@raspberrypi:~ $ sudo reboot
    Connection to 192.168.178.92 closed by remote host.
    Connection to 192.168.178.92 closed.
    euronicsxxlwunstorf@MacBook-Air-188 ~ % ssh pi@192.168.178.92
    ** WARNING: connection is not using a post-quantum key exchange algorithm.
    ** This session may be vulnerable to "store now, decrypt later" attacks.
    ** The server may need to be upgraded. See https://openssh.com/pq.html
    pi@192.168.178.92's password:
    Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64
    permitted by applicable law.
    Last login: Fri Sep 4 10:26:56 2026
    • K Karl-Heinz1
      @Karl-Heinz1 sagte:
      Das sieht man aber da nicht.
      iob diag
      sagt?
        Karl-Heinz1
        Der iobroker startet nicht mehr.
        • K Karl-Heinz1
          @Karl-Heinz1
          Und
          iob diag
          sagt dazu?
            Karl-Heinz1
            Script v.2026-08-30
            *** BASE SYSTEM ***
            Operating System: Debian GNU/Linux 11 (bullseye)
               Static hostname: raspberrypi
                     Icon name: computer
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            OS is similar to:
            Model		: Raspberry Pi 400 Rev 1.1
            Docker          : false
            Virtualization  : none
            Unknown
            Kernel          : aarch64
            Userland        : 64bit
            System was installed 1443 days ago (on 2022-09-22).
            Systemuptime and Load:
             13:44:49 up  3:16,  2 users,  load average: 0.08, 0.15, 0.15
            CPU threads     : 4
            *** LIFE CYCLE STATUS ***
            Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Fri 2026-09-04 13:44:49 CEST
                       Universal time: Fri 2026-09-04 11:44:49 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Display-Server:		Unknown
            Display-Manager: 	* lightdm.service - Light Display Manager
            Desktop:
            Session:		tty
            Boot Target: 		multi-user.target
            *** MEMORY ***
            Mem:            3.8G        156M        3.3G        1.0M        344M        3.6G
            Swap:            99M          0B         99M
            Total:          3.9G        156M        3.4G
            Active iob-Instances: 	0
                     3794 M total memory
                      156 M used memory
                      348 M active memory
                       62 M inactive memory
                     3293 M free memory
                       29 M buffer memory
                      314 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 13:44:51 up  3:16,  2 users,  load average: 0.15, 0.17, 0.15
            Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3794.3 total,   3293.5 free,    156.3 used,    344.6 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3569.1 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4       29G   17G   12G  60% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     759M  1.3M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   32M  223M  13% /boot
            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
            Messages concerning filesystems in dmesg (Last 15 lines only):
            Show mounted filesystems:
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            4.1G	/var/
            3.1G	/var/log
            2.9G	/var/log/journal/79e438becaf044e4ab8664814f73dec8
            757M	/var/cache
            Archived and active journals take up 2.8G in the file system.
            /opt/iobroker/backups:
            170M	/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            4.6G	/opt/iobroker/iobroker-data/
            3.5G	/opt/iobroker/iobroker-data/history
            994M	/opt/iobroker/iobroker-data/files
            493M	/opt/iobroker/iobroker-data/files/javascript.admin
            461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
            43M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map
            33M	/opt/iobroker/iobroker-data/objects.jsonl
            26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
            26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
            24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
            USB-Devices by-id:
            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
            please always prefer the links 'by-id':
            /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0
            /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
            /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0
            /dev/serial/by-id/usb-FTDI_USB_Serial_Converter_FTB6SPL3-if00-port0
            No nvbackup.json found.
            *** NodeJS-Installation ***
            *** Node.js is NOT correctly installed ***
            Issues:  nodejs path x node path x npm path x npx path
            Execute 'iob nodejs-update' in your terminal.
            nodejs:
              Installed: (none)
              Candidate: 12.22.12~dfsg-1~deb11u8
              Version table:
                 12.22.12~dfsg-1~deb11u8 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            sudo: node: command not found
            Hosts:
            Core adapters versionssudo: node: command not found
            js-controller: 	sudo: node: command not found
            admin: 		sudo: node: command not found
            javascript:
            nodejs modules from github: 	0
            Adapter State
            ioBroker-Repositories
            Installed ioBroker-Adapters
            ioBroker-Adapter Versions and update status
            Objects and States
            Objects: 	0
            States: 	0
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian bullseye InRelease
            Fetched 11.7 kB in 1s (9463 B/s)
            Reading package lists...
            Pending systemupdates: 0
            *** Listening Ports ***
            Netid State  Recv-Q Send-Q Local Address:Port          Peer Address:PortProcess
            udp   UNCONN 0      0            0.0.0.0:35997              0.0.0.0:*    users:(("avahi-daemon",pid=416,fd=14))
            udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=636,fd=21))
            udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=636,fd=3))
            udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=416,fd=12))
            udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=25))
            udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=24))
            udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=23))
            udp   UNCONN 0      0            0.0.0.0:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=531,fd=13))
            udp   UNCONN 0      0                  *:55910                    *:*    users:(("avahi-daemon",pid=416,fd=15))
            udp   UNCONN 0      0                  *:mdns                     *:*    users:(("evcc",pid=636,fd=22))
            udp   UNCONN 0      0                  *:mdns                     *:*    users:(("evcc",pid=636,fd=6))
            udp   UNCONN 0      0                  *:mdns                     *:*    users:(("avahi-daemon",pid=416,fd=13))
            udp   UNCONN 0      0                  *:dhcpv6-client            *:*    users:(("dhcpcd",pid=531,fd=16))
            tcp   LISTEN 0      5            0.0.0.0:5900               0.0.0.0:*    users:(("vncserver-x11-c",pid=671,fd=12))
            tcp   LISTEN 0      128        127.0.0.1:ipp                0.0.0.0:*    users:(("cupsd",pid=634,fd=7))
            tcp   LISTEN 0      128          0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=692,fd=3))
            tcp   LISTEN 0      5               [::]:5900                  [::]:*    users:(("vncserver-x11-c",pid=671,fd=11))
            tcp   LISTEN 0      128            [::1]:ipp                   [::]:*    users:(("cupsd",pid=634,fd=6))
            tcp   LISTEN 0      128             [::]:ssh                   [::]:*    users:(("sshd",pid=692,fd=4))
            tcp   LISTEN 0      4096               *:7070                     *:*    users:(("evcc",pid=636,fd=12))
            tcp   LISTEN 0      4096               *:8887                     *:*    users:(("evcc",pid=636,fd=8))
            tcp   LISTEN 0      4096               *:4712                     *:*    users:(("evcc",pid=636,fd=9))
            2026-09-04 09:51:22.503  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
            2026-09-04 09:51:22.753  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
            2026-09-04 09:51:22.753  - info: host.raspberrypi All instances are stopped.
            2026-09-04 09:51:22.753  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGKILL
            2026-09-04 09:51:22.754  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
            2026-09-04 09:51:22.754  - info: host.raspberrypi All instances are stopped.
            2026-09-04 09:51:22.754  - warn: host.raspberrypi instance system.adapter.discovery.0 terminated due to SIGKILL
            2026-09-04 09:51:22.754  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code null ()
            2026-09-04 09:51:22.755  - warn: host.raspberrypi instance system.adapter.ds18b20.0 terminated due to SIGKILL
            2026-09-04 09:51:22.755  - info: host.raspberrypi instance system.adapter.ds18b20.0 terminated with code null ()
            2026-09-04 09:51:22.755  - info: host.raspberrypi All instances are stopped.
            2026-09-04 09:51:22.756  - warn: host.raspberrypi instance system.adapter.iot.0 terminated due to SIGKILL
            2026-09-04 09:51:22.756  - info: host.raspberrypi instance system.adapter.iot.0 terminated with code null ()
            2026-09-04 09:51:22.756  - info: host.raspberrypi All instances are stopped.
            2026-09-04 09:51:22.756  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL
            2026-09-04 09:51:22.757  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
            2026-09-04 09:51:22.757  - info: host.raspberrypi All instances are stopped.
            2026-09-04 09:51:22.757  - warn: host.raspberrypi instance system.adapter.pushover.0 terminated due to SIGKILL
            2026-09-04 09:51:22.757  - info: host.raspberrypi instance system.adapter.pushover.0 terminated with code null ()
            2026-09-04 09:51:22.757  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGKILL
            2026-09-04 09:51:22.758  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
            2026-09-04 09:51:22.758  - info: host.raspberrypi All instances are stopped.
            2026-09-04 09:51:22.936  - info: host.raspberrypi terminated
            • K Karl-Heinz1
              Script v.2026-08-30
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              OS is similar to:
              Docker          : false
              Unknown
              Kernel          : aarch64
              Userland        : 64bit
              CPU threads     : 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              Desktop:
              Session:		tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3794 M total memory
                        156 M used memory
                        348 M active memory
                       3293 M free memory
                         29 M buffer memory
                        314 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              *** FILESYSTEM ***
              /var:
              4.1G	/var/
              3.1G	/var/log
              757M	/var/cache
              USB-Devices by-id:
              nodejs:
                Installed: (none)
                Version table:
              ioBroker Status
              Hosts:
              javascript:
              Adapter State
              Objects and States
              Objects: 	0
              States: 	0
              @Karl-Heinz1
              iob nodejs-update 22
                Karl-Heinz1
                Danke, jetzt läuft der iobroker wieder.
                Jetzt Backup mit Backitup.0 ?
                da ist bei mir in den Einstellung ein Haken bei iobroker und bei Javascript
                sonst nichts.
                Ist das OK
                Thomas BraunT fuzzy1955F 2 Antworten Letzte Antwort
                • K Karl-Heinz1
                  sonst nichts.
                  Ist das OK
                  @Karl-Heinz1 sagte:
                  Ist das OK
                  Keine Ahnung, was du da alles laufen hast und sichern musst.
                    Karl-Heinz1
                    Ich habe nur den iobroker und evcc für Solarüberschussladen, sonst keine Software. Die Shelly`s steuere ich über den iobroker und die sonoff Adapter lese ich nur aus.
                    • K Karl-Heinz1
                      sonst nichts.
                      Ist das OK
                      fuzzy1955F Offline
                      fuzzy1955F Offline
                      fuzzy1955
                      @Karl-Heinz1 sagte:
                      History Daten?
                      InfluxDB?
                      Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
                      Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
                      Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
                      Großes Danke an alle tatkräftigen Helfer im Forum!
                        Karl-Heinz1
                        Ich habe jetzt bei History und influxdb einen haken gemacht. Aber mich interessiert eigentlich nichts was vor 1 Jahr war. Und Monatsverbrauch, Tag und Jahr speichere ich in eigens erstellten Datenpunkten für 1 Jahr.
                          Karl-Heinz1
                          Ich habe jetzt alles soweit durchgeführt.
                          Mir ist jetzt aber nicht klar, wie jetzt weiter. Eine neu Installation laut Doku macht doch den Speicherchip leer, dann ist meine Datensicherung weg und auch EVCC.
                          Wie muss ich jetzt weiter machen.
                          • K Karl-Heinz1
                            @Karl-Heinz1 sagte:
                            Backups immer auf externe Medien, damit man die dann von dort auch zurückspielen kann.
                              Karl-Heinz1
                              Leider habe ich zuwenig Zeit. Da fehlen mir Grundlagen, weil ich nicht so einfach weiss wie ich die Dateien finde und wie ich die auf meinen Mac bekomme. Ich blicke nicht durch die Linux Dateistruktur durch bzw. was da so auf dem Bildschirm steht das dauert jetzt erst mal.
                              • K Karl-Heinz1
                                @Karl-Heinz1 sagte:
                                Die solltest du dir aneignen. Wie sicherst du denn derzeitig deine Daten?
                                Wenn nichts anderes eingestellt ist liegen die Backups im Verzeichnis /opt/iobroker/backups/
                                Man kann und sollte die allerdings auf ein externes Medium schieben. Da gibt es verschiedene Ansätze.
                                Ich mounte z. B. eine Freigabe auf der FritzBox und schreibe dann direkt dorthin.
                                Was ist eigentlich dein Plan für einen Hardwaredefekt? Kann ja auch jederzeit eintreten.
                                  Karl-Heinz1
                                  ich habe jetzt laut Doku einen neuen Speicherchip erstellt. Leider komme ich nicht weiter Nachdem Eingabe ssh pi@192.XXXXX erfolgt die Passwort Abfrage mit dem Ergebnis Permission denied, please try again.
                                  Ich habe die Erstellung nach der Doku gemacht.
                                  ssh mit ja Passwörter auch eingeben und schon mehrfach neu versucht.
                                  Passwörter nur mit Buchstaben und Zahlen ohne Sonderzeichen, leider alles ohne Erfolg.
                                  • K Karl-Heinz1
                                    @Karl-Heinz1
                                    Hast du auch SSH bei der Installation aktiviert?
                                      Karl-Heinz1
                                      Ja ssh habe ich aktiviert
                                        Und auch einen eigene User angelegt?
                                        Womöglich nicht als "pi"?
                                          Karl-Heinz1
                                          ich habe nicht alles dokumentiert. Ich bin einfach nur der Doku
                                          "Einfacher gehts nicht"
                                          Ich versuche es jetzt noch einmal und wenn ich unsicher bin frage ich dann hier.
