  4. EVCC wird nicht grün
83 Beiträge 4 Kommentatoren 785 Aufrufe 3 Beobachtet
  • K Karl-Heinz1
    ich habe die Daten in ein PDF kopiert.
    iob diag.pdf
    @Karl-Heinz1
    Kopier das hier rein.
      Karl-Heinz1
      Script v.2026-08-30
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 11 (bullseye)
      Static hostname: raspberrypi
      Icon name: computer
      Kernel: Linux 6.1.21-v8+
      Architecture: arm64
      OS is similar to:
      Model : Raspberry Pi 400 Rev 1.1
      Docker : false
      Virtualization : none
      Unknown
      Kernel : aarch64
      Userland : 64bit
      System was installed 1442 days ago (on 2022-09-22).
      Systemuptime and Load:
      19:45:20 up 2:03, 2 users, load average: 4.74, 2.22, 1.54
      CPU threads : 4
      *** LIFE CYCLE STATUS ***
      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to
      be updated to the latest stable release 'trixie' NOW!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
      Local time: Thu 2026-09-03 19:45:21 CEST
      Universal time: Thu 2026-09-03 17:45:21 UTC
      RTC time: n/a
      NTP service: active
      RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input
      render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: Unknown
      Display-Manager: * lightdm.service - Light Display Manager
      Desktop:
      Session: tty
      Boot Target: multi-user.target
      *** MEMORY ***
      total used free shared buff/cache
      available
      Mem: 3.8G 1.9G 974M 1.0M 924M
      1.8G
      Swap: 99M 0B 99M
      Total: 3.9G 1.9G 1.1G
      Active iob-Instances: 24
      3794 M total memory
      1895 M used memory
      2151 M active memory
      518 M inactive memory
      974 M free memory
      76 M buffer memory
      848 M swap cache
      99 M total swap
      0 M used swap
      99 M free swap
      *** top - Table Of Processes ***
      top - 19:45:23 up 2:03, 2 users, load average: 4.74, 2.22, 1.54
      Tasks: 194 total, 1 running, 193 sleeping, 0 stopped, 0 zombie
      %Cpu(s): 4.2 us, 2.8 sy, 0.0 ni, 93.0 id, 0.0 wa, 0.0 hi, 0.0 si,
      0.0 st
      MiB Mem : 3794.3 total, 973.9 free, 1895.8 used, 924.7 buff/
      cache
      MiB Swap: 100.0 total, 100.0 free, 0.0 used. 1821.9 avail
      Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /dev/root ext4 29G 17G 11G 62% /
      devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
      tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
      tmpfs tmpfs 759M 1.3M 758M 1% /run
      tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
      /dev/mmcblk0p1 vfat 255M 32M 223M 13% /boot
      tmpfs tmpfs 380M 16K 380M 1% /run/user/1000
      Messages concerning filesystems in dmesg (Last 15 lines only):
      Show mounted filesystems:
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mmcblk0p2 ext4 rw,noatime,commit=600
      `-/boot /dev/mmcblk0p1 vfat
      rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname
      =mixed,errors=remount-ro
      /var:
      4.1G /var/
      3.1G /var/log
      3.0G /var/log/journal/79e438becaf044e4ab8664814f73dec8
      757M /var/cache
      Archived and active journals take up 2.9G in the file system.
      /opt/iobroker/backups:
      170M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      4.6G /opt/iobroker/iobroker-data/
      3.5G /opt/iobroker/iobroker-data/history
      994M /opt/iobroker/iobroker-data/files
      493M /opt/iobroker/iobroker-data/files/javascript.admin
      461M /opt/iobroker/iobroker-data/files/javascript.admin/static
      43M /opt/iobroker/iobroker-data/files/iot.admin/static/js/
      main.c9e0f545.js.map
      26M /opt/iobroker/iobroker-data/files/echarts/static/js/
      main.41cee985.js.map
      26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/
      24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/
      main.6a71b34c.js.map
      24M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/
      main.70a15e1f.js.map
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0
      /dev/serial/by-id/usb-FTDI_USB_Serial_Converter_FTB6SPL3-if00-port0
      No nvbackup.json found.
      *** NodeJS-Installation ***
      /usr/bin/nodejs v20.20.2
      /usr/bin/node v20.20.2
      /usr/bin/npm 10.8.2
      /usr/bin/npx 10.8.2
      ✓ Node.js installation is correct
      nodejs:
      Installed: 20.20.2-1nodesource1
      Candidate: 20.20.2-1nodesource1
      Version table:
      *** 20.20.2-1nodesource1 1001
      500 https://deb.nodesource.com/node_20.x nodistro/main arm64
      Packages
      20.20.1-1nodesource1 1001
      Packages
      20.20.0-1nodesource1 1001
      Packages
      20.19.6-1nodesource1 1001
      Packages
      20.19.5-1nodesource1 1001
      Packages
      20.19.4-1nodesource1 1001
      Packages
      20.19.3-1nodesource1 1001
      Packages
      20.19.2-1nodesource1 1001
      Packages
      20.19.1-1nodesource1 1001
      Packages
      20.19.0-1nodesource1 1001
      Packages
      20.18.3-1nodesource1 1001
      Packages
      20.18.2-1nodesource1 1001
      Packages
      20.18.1-1nodesource1 1001
      Packages
      20.18.0-1nodesource1 1001
      Packages
      20.17.0-1nodesource1 1001
      Packages
      20.16.0-1nodesource1 1001
      Packages
      20.15.1-1nodesource1 1001
      Packages
      20.15.0-1nodesource1 1001
      Packages
      20.14.0-1nodesource1 1001
      Packages
      20.13.1-1nodesource1 1001
      Packages
      20.13.0-1nodesource1 1001
      Packages
      20.12.2-1nodesource1 1001
      Packages
      20.12.1-1nodesource1 1001
      Packages
      20.12.0-1nodesource1 1001
      Packages
      20.11.1-1nodesource1 1001
      Packages
      20.11.0-1nodesource1 1001
      Packages
      20.10.0-1nodesource1 1001
      Packages
      20.9.0-1nodesource1 1001
      Packages
      20.8.1-1nodesource1 1001
      Packages
      20.8.0-1nodesource1 1001
      Packages
      20.7.0-1nodesource1 1001
      Packages
      20.6.1-1nodesource1 1001
      Packages
      20.6.0-1nodesource1 1001
      Packages
      20.5.1-1nodesource1 1001
      Packages
      20.5.0-1nodesource1 1001
      Packages
      20.4.0-1nodesource1 1001
      Packages
      20.3.1-1nodesource1 1001
      Packages
      20.3.0-1nodesource1 1001
      Packages
      20.2.0-1nodesource1 1001
      Packages
      20.1.0-1nodesource1 1001
      Packages
      20.0.0-1nodesource1 1001
      Packages
      12.22.12~dfsg-1~deb11u8 500
      500 http://security.debian.org/debian-security bullseye-
      security/main arm64 Packages
      12.22.12~dfsg-1~deb11u4 500
      500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      Vulnerabilities detected in the Node.js version!
      node:fs:2380
      return binding.writeFileUtf8(
      Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-
      my-node-vulnerable/schedule.etag'
      at Object.writeFileSync (node:fs:2380:20)
      at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-
      node-vulnerable/is-vulnerable.js:82:12)
      at Object.onceWrapper (node:events:639:26)
      at ClientRequest.emit (node:events:524:28)
      at HTTPParser.parserOnIncomingClient [as onIncoming]
      (node:_http_client:702:27)
      at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
      at TLSSocket.socketOnData (node:_http_client:544:22)
      at TLSSocket.emit (node:events:524:28)
      at addChunk (node:internal/streams/readable:561:12)
      at readableAddChunkPushByteMode (node:internal/streams/
      readable:512:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/
      schedule.etag'
      Node.js v20.20.2
      npm notice
      npm notice New major version of npm available! 10.8.2 -> 12.0.2
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v12.0.2
      npm notice To update run: npm install -g npm@12.0.2
      npm notice
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Hosts:
      raspberrypi raspberrypi (version: 6.0.11, hostname: raspberrypi
      , alive, uptime: 7413)
      Core adapters versions
      js-controller: 6.0.11
      admin: 7.8.23
      javascript: 8.8.2
      nodejs modules from github: 1
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://
      git@github.com/ioBroker/ioBroker.icons-open-icon-library-
      png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      Adapter State
      + system.adapter.admin.0 : admin :
      raspberrypi - enabled, port: 8081, bind:
      0.0.0.0, run as: admin
      + system.adapter.backitup.0 : backitup :
      + system.adapter.chromecast.0 : chromecast :
      system.adapter.cloud.0 : cloud :
      raspberrypi - disabled
      + system.adapter.discovery.0 : discovery :
      + system.adapter.ds18b20.0 : ds18b20 :
      + system.adapter.echarts.0 : echarts :
      + system.adapter.evcc.0 : evcc :
      raspberrypi - enabled, port: 7070
      system.adapter.flot.0 : flot :
      + system.adapter.growatt.0 : growatt :
      + system.adapter.history.0 : history :
      system.adapter.icons-material-png.0 : icons-material-png :
      system.adapter.icons-mfd-svg.0 : icons-mfd-svg :
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-
      png: raspberrypi - disabled
      system.adapter.icons-ultimate-png.0 : icons-ultimate-png :
      + system.adapter.iot.0 : iot :
      + system.adapter.jarvis.0 : jarvis :
      + system.adapter.javascript.0 : javascript :
      + system.adapter.modbus.0 : modbus :
      + system.adapter.mqtt.0 : mqtt :
      raspberrypi - enabled, port: 1883, bind:
      0.0.0.0
      + system.adapter.net-tools.0 : net-tools :
      + system.adapter.node-red.0 : node-red :
      raspberrypi - enabled, port: 1880, bind:
      0.0.0.0
      + system.adapter.pushover.0 : pushover :
      + system.adapter.shelly.0 : shelly :
      raspberrypi - enabled, port: 1882, bind:
      0.0.0.0
      + system.adapter.shelly.1 : shelly :
      0.0.0.0
      + system.adapter.simple-api.0 : simple-api :
      raspberrypi - enabled, port: 8087, bind:
      + system.adapter.smartcontrol.0 : smartcontrol :
      + system.adapter.sonoff.0 : sonoff :
      0.0.0.0
      system.adapter.telegram.0 : telegram :
      raspberrypi - disabled, port: 8443, bind:
      0.0.0.0
      system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges :
      system.adapter.vis-colorpicker.0 : vis-colorpicker :
      system.adapter.vis-justgage.0 : vis-justgage :
      system.adapter.vis-material-advanced.0 : vis-material-advanced :
      system.adapter.vis-materialdesign.0 : vis-materialdesign :
      system.adapter.vis-rgraph.0 : vis-rgraph :
      system.adapter.vis.0 : vis :
      + system.adapter.web.0 : web :
      raspberrypi - enabled, port: 8082, bind:
      + instance is alive
      0.0.0.0
      0.0.0.0
      0.0.0.0
      0.0.0.0
      0.0.0.0
      ioBroker-Repositories
      ───────┬──────────────┐ │ (index) │ name │ url
      │ auto upgrade │ ├─────────┼──────────┼────────────────────────────────────────────────── ───────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'
      │ false │
      │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-
      latest.json' │ false │ └─────────┴──────────┴──────────────────────────────────────────────────
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      ─────────────────┬──────────┬────────────────┐ │ (index) │ id │ name
      │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼────────────── ─────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin'
      │ '7.8.23' │ 'none' │
      │ 1 │ 'system.adapter.backitup' │ 'backitup'
      │ '3.0.20' │ 'none' │
      │ 2 │ 'system.adapter.chromecast' │ 'chromecast'
      │ '3.4.1' │ 'none' │
      │ 3 │ 'system.adapter.cloud' │ 'cloud'
      │ '5.0.1' │ 'none' │
      │ 4 │ 'system.adapter.discovery' │ 'discovery'
      │ '5.0.0' │ 'none' │
      │ 5 │ 'system.adapter.ds18b20' │ 'ds18b20'
      │ '2.0.5' │ 'none' │
      │ 6 │ 'system.adapter.echarts' │ 'echarts'
      │ '1.9.2' │ 'none' │
      │ 7 │ 'system.adapter.evcc' │ 'evcc'
      │ '0.2.4' │ 'none' │
      │ 8 │ 'system.adapter.flot' │ 'flot'
      │ '1.12.0' │ 'none' │
      │ 9 │ 'system.adapter.growatt' │ 'growatt'
      │ '3.3.1' │ 'none' │
      │ 10 │ 'system.adapter.history' │ 'history'
      │ '3.0.1' │ 'none' │
      │ 11 │ 'system.adapter.icons-material-png' │ 'icons-
      material-png' │ '0.1.0' │ 'none' │
      │ 12 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-
      svg' │ '1.2.0' │ 'none' │
      │ 13 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-
      icon-library-png' │ '0.1.3' │ 'none' │
      │ 14 │ 'system.adapter.icons-ultimate-png' │ 'icons-
      ultimate-png' │ '1.0.1' │ 'none' │
      │ 15 │ 'system.adapter.iot' │ 'iot'
      │ '3.4.2' │ 'none' │
      │ 16 │ 'system.adapter.jarvis' │ 'jarvis'
      │ '3.1.8' │ 'none' │
      │ 17 │ 'system.adapter.javascript' │ 'javascript'
      │ '8.8.2' │ 'none' │
      │ 18 │ 'system.adapter.modbus' │ 'modbus'
      │ '6.3.2' │ 'none' │
      │ 19 │ 'system.adapter.mqtt' │ 'mqtt'
      │ '6.1.1' │ 'none' │
      │ 20 │ 'system.adapter.net-tools' │ 'net-tools'
      │ '1.0.11' │ 'none' │
      │ 21 │ 'system.adapter.node-red' │ 'node-red'
      │ '5.2.1' │ 'none' │
      │ 22 │ 'system.adapter.pushover' │ 'pushover'
      │ '4.1.0' │ 'none' │
      │ 23 │ 'system.adapter.shelly' │ 'shelly'
      │ '8.2.1' │ 'none' │
      │ 24 │ 'system.adapter.simple-api' │ 'simple-api'
      │ '2.8.0' │ 'none' │
      │ 25 │ 'system.adapter.smartcontrol' │
      'smartcontrol' │ '2.0.1' │ 'none' │
      │ 26 │ 'system.adapter.socketio' │ 'socketio'
      │ '6.7.1' │ 'none' │
      │ 27 │ 'system.adapter.sonoff' │ 'sonoff'
      │ '3.1.2' │ 'none' │
      │ 28 │ 'system.adapter.telegram' │ 'telegram'
      │ '3.9.0' │ 'none' │
      │ 29 │ 'system.adapter.vis' │ 'vis'
      │ '1.5.6' │ 'none' │
      │ 30 │ 'system.adapter.vis-2-widgets-gauges' │ 'vis-2-
      widgets-gauges' │ '1.1.0' │ 'none' │
      │ 31 │ 'system.adapter.vis-colorpicker' │ 'vis-
      colorpicker' │ '2.0.3' │ 'none' │
      │ 32 │ 'system.adapter.vis-justgage' │ 'vis-
      justgage' │ '2.1.7' │ 'none' │
      │ 33 │ 'system.adapter.vis-material-advanced' │ 'vis-
      material-advanced' │ '1.7.4' │ 'none' │
      │ 34 │ 'system.adapter.vis-materialdesign' │ 'vis-
      materialdesign' │ '0.5.9' │ 'none' │
      │ 35 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph'
      │ '0.0.2' │ 'none' │
      │ 36 │ 'system.adapter.web' │ 'web'
      │ '6.3.1' │ 'none' │
      │ 37 │ 'system.adapter.ws' │ 'ws'
      │ '2.6.2' │ 'none' │ └─────────┴──────────────────────────────────────────────┴──────────────
      ioBroker-Adapter Versions and update status
      Used repository: stable
      Adapter "admin" : 8.0.11 , installed 7.8.23 [Updatable]
      Adapter "backitup" : 4.0.3 , installed 3.0.20 [Updatable]
      Adapter "chromecast" : 4.2.0 , installed 3.4.1 [Updatable]
      Adapter "cloud" : 6.0.1 , installed 5.0.1 [Updatable]
      Adapter "discovery" : 5.0.0 , installed 5.0.0
      Adapter "ds18b20" : 3.1.1 , installed 2.0.5 [Updatable]
      Adapter "echarts" : 3.1.0 , installed 1.9.2 [Updatable]
      Adapter "evcc" : 0.2.4 , installed 0.2.4
      Adapter "growatt" : 3.3.1 , installed 3.3.1
      Adapter "history" : 4.0.0 , installed 3.0.1 [Updatable]
      Adapter "icons-material-png": 0.1.0, installed 0.1.0
      Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0
      Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter "iot" : 6.0.3 , installed 3.4.2 [Updatable]
      Adapter "jarvis" : 3.1.8 , installed 3.1.8
      Adapter "javascript" : 10.1.3 , installed 8.8.2 [Updatable]
      Controller "js-controller": 7.2.2 , installed 6.0.11 [Updatable]
      Adapter "modbus" : 8.0.3 , installed 6.3.2 [Updatable]
      Adapter "mqtt" : 6.1.4 , installed 6.1.1 [Updatable]
      Adapter "net-tools" : 1.2.3 , installed 1.0.11 [Updatable]
      Adapter "node-red" : 6.0.7 , installed 5.2.1 [Updatable]
      Adapter "pushover" : 5.0.0 , installed 4.1.0 [Updatable]
      Adapter "shelly" : 10.6.1 , installed 8.2.1 [Updatable]
      Adapter "simple-api" : 3.0.7 , installed 2.8.0 [Updatable]
      Adapter "smartcontrol" : 2.0.1 , installed 2.0.1
      Adapter "socketio" : 7.1.3 , installed 6.7.1 [Updatable]
      Adapter "sonoff" : 3.3.0 , installed 3.1.2 [Updatable]
      Adapter "telegram" : 5.0.5 , installed 3.9.0 [Updatable]
      Adapter "vis" : 1.5.6 , installed 1.5.6
      Adapter "vis-2-widgets-gauges": 2.0.2, installed 1.1.0 [Updatable]
      Adapter "vis-colorpicker": 2.1.0 , installed 2.0.3 [Updatable]
      Adapter "vis-justgage" : 2.1.7 , installed 2.1.7
      Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
      Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
      Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
      Adapter "web" : 8.0.0 , installed 6.3.1 [Updatable]
      Adapter "ws" : 4.1.0 , installed 2.6.2 [Updatable]
      Objects and States
      Objects: 4866
      States: 4366
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security
      InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Get:6 https://dl.evcc.io/public/evcc/stable/deb/debian bullseye
      InRelease
      Fetched 11.7 kB in 2s (7071 B/s)
      Reading package lists...
      Pending systemupdates: 0
      *** Listening Ports ***
      Netid State Recv-Q Send-Q Local Address:Port Peer
      Address:PortProcess
      udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:*
      users:(("evcc",pid=2475,fd=22))
      users:(("evcc",pid=2475,fd=3))
      users:(("io.chromecast.0",pid=1379,fd=28))
      users:(("avahi-daemon",pid=406,fd=12))
      udp UNCONN 0 0 0.0.0.0:60818 0.0.0.0:*
      users:(("avahi-daemon",pid=406,fd=14))
      udp UNCONN 0 0 0.0.0.0:5683 0.0.0.0:*
      users:(("io.shelly.1",pid=1485,fd=29))
      udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:*
      users:(("evcc",pid=2475,fd=26))
      users:(("evcc",pid=2475,fd=25))
      users:(("evcc",pid=2475,fd=24))
      udp UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:*
      users:(("dhcpcd",pid=513,fd=13))
      udp UNCONN 0 0 *:mdns *:*
      users:(("evcc",pid=2475,fd=23))
      users:(("evcc",pid=2475,fd=6))
      users:(("avahi-daemon",pid=406,fd=13))
      udp UNCONN 0 0 *:dhcpv6-client *:*
      users:(("dhcpcd",pid=513,fd=16))
      udp UNCONN 0 0 *:60545 *:*
      users:(("avahi-daemon",pid=406,fd=15))
      tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:*
      users:(("sshd",pid=669,fd=3))
      tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:*
      users:(("io.jarvis.0",pid=1623,fd=27))
      tcp LISTEN 0 5 0.0.0.0:5900 0.0.0.0:*
      users:(("vncserver-x11-c",pid=662,fd=12))
      tcp LISTEN 0 128 127.0.0.1:ipp 0.0.0.0:*
      users:(("cupsd",pid=600,fd=7))
      tcp LISTEN 0 511 0.0.0.0:1882 0.0.0.0:*
      users:(("io.shelly.0",pid=1465,fd=29))
      tcp LISTEN 0 511 0.0.0.0:1883 0.0.0.0:*
      users:(("io.sonoff.0",pid=1500,fd=32))
      tcp LISTEN 0 511 0.0.0.0:1880 0.0.0.0:*
      users:(("node-red",pid=1402,fd=36))
      tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:*
      users:(("iobroker.js-con",pid=607,fd=25))
      tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:*
      users:(("iobroker.js-con",pid=607,fd=19))
      tcp LISTEN 0 128 [::]:ssh [::]:*
      users:(("sshd",pid=669,fd=4))
      tcp LISTEN 0 4096 *:7070 *:*
      users:(("evcc",pid=2475,fd=12))
      tcp LISTEN 0 4096 *:4712 *:*
      users:(("evcc",pid=2475,fd=10))
      tcp LISTEN 0 4096 *:8887 *:*
      users:(("evcc",pid=2475,fd=9))
      tcp LISTEN 0 5 [::]:5900 [::]:*
      users:(("vncserver-x11-c",pid=662,fd=11))
      tcp LISTEN 0 128 [::1]:ipp [::]:*
      users:(("cupsd",pid=600,fd=6))
      tcp LISTEN 0 511 *:8087 *:*
      users:(("io.simple-api.0",pid=1731,fd=26))
      tcp LISTEN 0 511 *:8082 *:*
      users:(("io.web.0",pid=1668,fd=27))
      tcp LISTEN 0 511 *:tproxy *:*
      users:(("io.admin.0",pid=1235,fd=27))
      2026-09-03 19:46:52.099 - debug: sonoff.0 (1500) stateChange
      sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe:
      {"val":18369,"ack":true,"ts":1788457612096,"q":0,"from":"system.adapter.
      sonoff.0","user":"system.user.admin","lc":1788456340684}
      2026-09-03 19:46:52.102 - debug: sonoff.0 (1500) process task:
      {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","data
      ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","common":
      {"role":"value","read":true,"write":false,"type":"number","name":"DVES_3
      E7859 SENSOR.SML Curr_p1"},"native":{},"type":"state"},"cbArg":0}
      2026-09-03 19:46:52.103 - debug: sonoff.0 (1500) Set state after task:
      2026-09-03 19:46:52.153 - debug: sonoff.0 (1500) stateChange
      sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1:
      {"val":0,"ack":true,"ts":1788457612148,"q":0,"from":"system.adapter.sono
      ff.0","user":"system.user.admin","lc":1721243462981}
      2026-09-03 19:46:52.159 - debug: sonoff.0 (1500) process task:
      {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","data
      ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","common":
      E7859 SENSOR.SML Curr_p2"},"native":{},"type":"state"},"cbArg":0}
      2026-09-03 19:46:52.159 - debug: sonoff.0 (1500) Set state after task:
      2026-09-03 19:46:52.207 - debug: sonoff.0 (1500) stateChange
      sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2:
      {"val":0,"ack":true,"ts":1788457612204,"q":0,"from":"system.adapter.sono
      ff.0","user":"system.user.admin","lc":1721243463081}
      2026-09-03 19:46:52.210 - debug: sonoff.0 (1500) process task:
      {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","data
      ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","common":
      E7859 SENSOR.SML Curr_p3"},"native":{},"type":"state"},"cbArg":0}
      2026-09-03 19:46:52.211 - debug: sonoff.0 (1500) Set state after task:
      2026-09-03 19:46:52.259 - debug: sonoff.0 (1500) stateChange
      sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3:
      {"val":0,"ack":true,"ts":1788457612256,"q":0,"from":"system.adapter.sono
      ff.0","user":"system.user.admin","lc":1721243463181}
      2026-09-03 19:46:52.262 - debug: sonoff.0 (1500) process task:
      {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","data
      ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","common":
      E7859 SENSOR.SML Volt_p1"},"native":{},"type":"state"},"cbArg":0}
      2026-09-03 19:46:52.262 - debug: sonoff.0 (1500) Set state after task:
      2026-09-03 19:46:52.311 - debug: sonoff.0 (1500) stateChange
      sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1:
      {"val":0,"ack":true,"ts":1788457612308,"q":0,"from":"system.adapter.sono
      ff.0","user":"system.user.admin","lc":1721243463273}
      2026-09-03 19:46:52.314 - debug: sonoff.0 (1500) process task:
      {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","data
      ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","common":
      E7859 SENSOR.SML Volt_p2"},"native":{},"type":"state"},"cbArg":0}
      2026-09-03 19:46:52.315 - debug: sonoff.0 (1500) Set state after task:
      2026-09-03 19:46:52.364 - debug: sonoff.0 (1500) stateChange
      sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2:
      {"val":0,"ack":true,"ts":1788457612360,"q":0,"from":"system.adapter.sono
      ff.0","user":"system.user.admin","lc":1721243463333}
      2026-09-03 19:46:52.367 - debug: sonoff.0 (1500) process task:
      {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","data
      ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","common":
      E7859 SENSOR.SML Volt_p3"},"native":{},"type":"state"},"cbArg":0}
      2026-09-03 19:46:52.368 - debug: sonoff.0 (1500) Set state after task:
      2026-09-03 19:46:52.419 - debug: sonoff.0 (1500) stateChange
      sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3:
      {"val":0,"ack":true,"ts":1788457612416,"q":0,"from":"system.adapter.sono
      ff.0","user":"system.user.admin","lc":1721243463393}
      2026-09-03 19:46:53.254 - debug: sonoff.0 (1500) Client [DVES_571961]
      pingreq
      2026-09-03 19:46:53.362 - debug: sonoff.0 (1500) Client [DVES_3E7859]
      pingreq
      2026-09-03 19:46:54.105 - info: shelly.0 (1465) [authEnabled]
      192.168.178.43 (shellyplus1 / shellyplus1-80646fd8df60 /
      shellyplus1#80646fd8df60#1): This device is not protected via restricted
      login (see adapter documentation for details)
      2026-09-03 19:46:54.155 - info: shelly.0 (1465) [authEnabled]
      192.168.178.53 (shellyplus1 / shellyplus1-7c87ce725954 /
      shellyplus1#7c87ce725954#1): This device is not protected via restricted
      2026-09-03 19:46:54.533 - info: shelly.1 (1485) [authEnabled]
      192.168.178.64 (shellyplug-s / shellyplug-s-3CE90ED7361F / SHPLG-
      S#3CE90ED7361F#1): This device is not protected via restricted login
      2026-09-03 19:46:54.557 - info: shelly.0 (1465) [authEnabled]
      192.168.178.81 (shellyplus1 / shellyplus1-7c87ce63d85c /
      shellyplus1#7c87ce63d85c#1): This device is not protected via restricted
      ============= Mark until here for C&P =============
      iob diag has finished.
      pi@raspbe
      • K Karl-Heinz1
        Script v.2026-08-30
        *** BASE SYSTEM ***
        Icon name: computer
        Architecture: arm64
        OS is similar to:
        Docker : false
        Unknown
        Kernel : aarch64
        Userland : 64bit
        CPU threads : 4
        Current issues:
        RTC time: n/a
        NTP service: active
        RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session: tty
        *** MEMORY ***
        available
        1.8G
        Swap: 99M 0B 99M
        3794 M total memory
        1895 M used memory
        974 M free memory
        76 M buffer memory
        848 M swap cache
        99 M total swap
        0 M used swap
        99 M free swap
        0.0 st
        cache
        Mem
        *** FILESYSTEM ***
        /var:
        4.1G /var/
        3.1G /var/log
        757M /var/cache
        USB-Devices by-id:
        /usr/bin/npm 10.8.2
        /usr/bin/npx 10.8.2
        nodejs:
        Version table:
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        Packages
        node:fs:2380
        readable:512:3) {
        errno: -13,
        code: 'EACCES',
        syscall: 'open',
        schedule.etag'
        Node.js v20.20.2
        npm notice
        npm notice
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        Hosts:
        admin: 7.8.23
        javascript: 8.8.2
        Adapter State
        0.0.0.0
        0.0.0.0
        0.0.0.0
        0.0.0.0
        0.0.0.0
        0.0.0.0
        + instance is alive
        0.0.0.0
        0.0.0.0
        0.0.0.0
        0.0.0.0
        0.0.0.0
        │ false │
        Objects and States
        Objects: 4866
        States: 4366
        InRelease
        InRelease
        Address:PortProcess
        pingreq
        pingreq
        pi@raspbe
        @Karl-Heinz1 sagte:
        Also nodejs@22 installieren, ioBroker vollständig updaten, davon ein Backup ziehen, Betriebssystem komplett neuinstallieren, Backup wieder einspielen, fertig.
          Karl-Heinz1
          als erstes nodejs instalieren
          sudo apt install -y nodejs npm
          ist das so OK
          • K Karl-Heinz1
            ist das so OK
            @Karl-Heinz1
            Nein.
            Mach es per
            iob nodejs-update
              Karl-Heinz1
              [INFO] No specific version given. Installing recommended version from Node.js v.22 tree.
              [INFO] Current Node.js version: v20.20.2
              [INFO] Stopping ioBroker with 'iob stop'...
              [INFO] ioBroker stopped successfully.
              [INFO] Node.js paths are correct.
              [INFO] Removing old Node.js versions...
              (Reading database ... 107768 files and directories currently installed.)
              Removing nodejs (20.20.2-1nodesource1) ...
              Processing triggers for man-db (2.9.4-2) ...
              [INFO] Setting up NodeSource repository for Node.js 22...
              [INFO] Downloading NodeSource GPG key...
              [INFO] Verifying GPG key fingerprint...
              [ERROR] NodeSource GPG key fingerprint mismatch! Expected: 6F71F525282841EEDAF85fdsffdd2F59B5F99B1BE0B4, Got: pubrsa20482016-05-23[SC]
              [INFO] Cleaning up temporary files...
              Ist der Fingerprint Error ein Problem ?
                Karl-Heinz1
                Use 'sudo apt autoremove' to remove them.
                soll ich das machen
                • K Karl-Heinz1
                  @Karl-Heinz1 sagte:
                  Ja, ist es.
                  Der wird aber aktualisiert, wenn du das noch mal laufen lässt.
                  Und wenn dein System läuft und keine Updates mehr in der Pipeline hängen kannst du nach einem Neustart auch ein
                  sudo apt autoremove
                  absetzen.
                    Karl-Heinz1
                    Jetzt startet der iobroker nicht mehr.
                    pi@raspberrypi:~ $ sudo reboot
                    Connection to 192.168.178.92 closed by remote host.
                    Connection to 192.168.178.92 closed.
                    euronicsxxlwunstorf@MacBook-Air-188 ~ % ssh pi@192.168.178.92
                    ** WARNING: connection is not using a post-quantum key exchange algorithm.
                    ** This session may be vulnerable to "store now, decrypt later" attacks.
                    ** The server may need to be upgraded. See https://openssh.com/pq.html
                    pi@192.168.178.92's password:
                    Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64
                    permitted by applicable law.
                    Last login: Fri Sep 4 10:26:56 2026
                    • K Karl-Heinz1
                      @Karl-Heinz1 sagte:
                      Das sieht man aber da nicht.
                      iob diag
                      sagt?
                        Karl-Heinz1
                        Der iobroker startet nicht mehr.
                        • K Karl-Heinz1
                          @Karl-Heinz1
                          Und
                          iob diag
                          sagt dazu?
                            Karl-Heinz1
                            Script v.2026-08-30
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Unknown
                            Kernel          : aarch64
                            Userland        : 64bit
                            System was installed 1443 days ago (on 2022-09-22).
                             13:44:49 up  3:16,  2 users,  load average: 0.08, 0.15, 0.15
                            CPU threads     : 4
                            Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
                            Current issues:
                                           Local time: Fri 2026-09-04 13:44:49 CEST
                                       Universal time: Fri 2026-09-04 11:44:49 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                            js-controller is not running
                            Desktop:
                            Session:		tty
                            *** MEMORY ***
                            Mem:            3.8G        156M        3.3G        1.0M        344M        3.6G
                            Swap:            99M          0B         99M
                            Total:          3.9G        156M        3.4G
                            Active iob-Instances: 	0
                                     3794 M total memory
                                      156 M used memory
                                      348 M active memory
                                       62 M inactive memory
                                     3293 M free memory
                                       29 M buffer memory
                                      314 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 13:44:51 up  3:16,  2 users,  load average: 0.15, 0.17, 0.15
                            Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3794.3 total,   3293.5 free,    156.3 used,    344.6 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3569.1 avail Mem
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G   17G   12G  60% /
                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            4.1G	/var/
                            3.1G	/var/log
                            2.9G	/var/log/journal/79e438becaf044e4ab8664814f73dec8
                            757M	/var/cache
                            Archived and active journals take up 2.8G in the file system.
                            43M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map
                            33M	/opt/iobroker/iobroker-data/objects.jsonl
                            26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                            26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                            24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                            USB-Devices by-id:
                            *** Node.js is NOT correctly installed ***
                            Issues:  nodejs path x node path x npm path x npx path
                            Execute 'iob nodejs-update' in your terminal.
                            nodejs:
                              Installed: (none)
                              Candidate: 12.22.12~dfsg-1~deb11u8
                              Version table:
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                            ioBroker Status
                            sudo: node: command not found
                            Hosts:
                            Core adapters versionssudo: node: command not found
                            js-controller: 	sudo: node: command not found
                            admin: 		sudo: node: command not found
                            javascript:
                            nodejs modules from github: 	0
                            Adapter State
                            Objects and States
                            Objects: 	0
                            States: 	0
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian bullseye InRelease
                            Fetched 11.7 kB in 1s (9463 B/s)
                            Netid State  Recv-Q Send-Q Local Address:Port          Peer Address:PortProcess
                            udp   UNCONN 0      0            0.0.0.0:35997              0.0.0.0:*    users:(("avahi-daemon",pid=416,fd=14))
                            udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=636,fd=21))
                            udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=636,fd=3))
                            udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=416,fd=12))
                            udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=25))
                            udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=24))
                            udp   UNCONN 0      0            0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=636,fd=23))
                            udp   UNCONN 0      0            0.0.0.0:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=531,fd=13))
                            udp   UNCONN 0      0                  *:55910                    *:*    users:(("avahi-daemon",pid=416,fd=15))
                            udp   UNCONN 0      0                  *:mdns                     *:*    users:(("evcc",pid=636,fd=22))
                            udp   UNCONN 0      0                  *:mdns                     *:*    users:(("evcc",pid=636,fd=6))
                            udp   UNCONN 0      0                  *:mdns                     *:*    users:(("avahi-daemon",pid=416,fd=13))
                            udp   UNCONN 0      0                  *:dhcpv6-client            *:*    users:(("dhcpcd",pid=531,fd=16))
                            tcp   LISTEN 0      5            0.0.0.0:5900               0.0.0.0:*    users:(("vncserver-x11-c",pid=671,fd=12))
                            tcp   LISTEN 0      128        127.0.0.1:ipp                0.0.0.0:*    users:(("cupsd",pid=634,fd=7))
                            tcp   LISTEN 0      128          0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=692,fd=3))
                            tcp   LISTEN 0      5               [::]:5900                  [::]:*    users:(("vncserver-x11-c",pid=671,fd=11))
                            tcp   LISTEN 0      128            [::1]:ipp                   [::]:*    users:(("cupsd",pid=634,fd=6))
                            tcp   LISTEN 0      128             [::]:ssh                   [::]:*    users:(("sshd",pid=692,fd=4))
                            tcp   LISTEN 0      4096               *:7070                     *:*    users:(("evcc",pid=636,fd=12))
                            tcp   LISTEN 0      4096               *:8887                     *:*    users:(("evcc",pid=636,fd=8))
                            tcp   LISTEN 0      4096               *:4712                     *:*    users:(("evcc",pid=636,fd=9))
                            2026-09-04 09:51:22.503  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
                            2026-09-04 09:51:22.753  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                            2026-09-04 09:51:22.753  - info: host.raspberrypi All instances are stopped.
                            2026-09-04 09:51:22.753  - warn: host.raspberrypi instance system.adapter.sonoff.0 terminated due to SIGKILL
                            2026-09-04 09:51:22.754  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code null ()
                            2026-09-04 09:51:22.754  - info: host.raspberrypi All instances are stopped.
                            2026-09-04 09:51:22.754  - warn: host.raspberrypi instance system.adapter.discovery.0 terminated due to SIGKILL
                            2026-09-04 09:51:22.754  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code null ()
                            2026-09-04 09:51:22.755  - warn: host.raspberrypi instance system.adapter.ds18b20.0 terminated due to SIGKILL
                            2026-09-04 09:51:22.755  - info: host.raspberrypi instance system.adapter.ds18b20.0 terminated with code null ()
                            2026-09-04 09:51:22.755  - info: host.raspberrypi All instances are stopped.
                            2026-09-04 09:51:22.756  - warn: host.raspberrypi instance system.adapter.iot.0 terminated due to SIGKILL
                            2026-09-04 09:51:22.756  - info: host.raspberrypi instance system.adapter.iot.0 terminated with code null ()
                            2026-09-04 09:51:22.756  - info: host.raspberrypi All instances are stopped.
                            2026-09-04 09:51:22.756  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL
                            2026-09-04 09:51:22.757  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
                            2026-09-04 09:51:22.757  - info: host.raspberrypi All instances are stopped.
                            2026-09-04 09:51:22.757  - warn: host.raspberrypi instance system.adapter.pushover.0 terminated due to SIGKILL
                            2026-09-04 09:51:22.757  - info: host.raspberrypi instance system.adapter.pushover.0 terminated with code null ()
                            2026-09-04 09:51:22.757  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGKILL
                            2026-09-04 09:51:22.758  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
                            2026-09-04 09:51:22.758  - info: host.raspberrypi All instances are stopped.
                            2026-09-04 09:51:22.936  - info: host.raspberrypi terminated
                            • K Karl-Heinz1
                              Script v.2026-08-30
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Unknown
                              Kernel          : aarch64
                              Userland        : 64bit
                              CPU threads     : 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              Desktop:
                              Session:		tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                        156 M used memory
                                        348 M active memory
                                       3293 M free memory
                                         29 M buffer memory
                                        314 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              4.1G	/var/
                              3.1G	/var/log
                              757M	/var/cache
                              USB-Devices by-id:
                              nodejs:
                                Installed: (none)
                                Version table:
                              ioBroker Status
                              Hosts:
                              javascript:
                              Adapter State
                              Objects and States
                              Objects: 	0
                              States: 	0
                              @Karl-Heinz1
                              iob nodejs-update 22
                                Karl-Heinz1
                                Danke, jetzt läuft der iobroker wieder.
                                Jetzt Backup mit Backitup.0 ?
                                da ist bei mir in den Einstellung ein Haken bei iobroker und bei Javascript
                                sonst nichts.
                                Ist das OK
                                Thomas BraunT fuzzy1955F 2 Antworten Letzte Antwort
                                • K Karl-Heinz1
                                  sonst nichts.
                                  Ist das OK
                                  @Karl-Heinz1 sagte:
                                  Ist das OK
                                  Keine Ahnung, was du da alles laufen hast und sichern musst.
                                    Karl-Heinz1
                                    Ich habe nur den iobroker und evcc für Solarüberschussladen, sonst keine Software. Die Shelly`s steuere ich über den iobroker und die sonoff Adapter lese ich nur aus.
                                    • K Karl-Heinz1
                                      sonst nichts.
                                      Ist das OK
                                      fuzzy1955F Offline
                                      fuzzy1955F Offline
                                      fuzzy1955
                                      @Karl-Heinz1 sagte:
                                      History Daten?
                                      InfluxDB?
                                      Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
                                      Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
                                      Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
                                      Großes Danke an alle tatkräftigen Helfer im Forum!
                                        Karl-Heinz1
                                        Ich habe jetzt bei History und influxdb einen haken gemacht. Aber mich interessiert eigentlich nichts was vor 1 Jahr war. Und Monatsverbrauch, Tag und Jahr speichere ich in eigens erstellten Datenpunkten für 1 Jahr.
                                          Karl-Heinz1
                                          Ich habe jetzt alles soweit durchgeführt.
                                          Mir ist jetzt aber nicht klar, wie jetzt weiter. Eine neu Installation laut Doku macht doch den Speicherchip leer, dann ist meine Datensicherung weg und auch EVCC.
                                          Wie muss ich jetzt weiter machen.
