Adapter Hyundai (Bluelink) oder KIA (UVO)
Test mit Hyundai Ioniq5 auf adapter version 3.1.32
Anmeldung erfolgreich
Token Generierung erfolgreich
Die Objektdaten von der Cloud werden gelesen und eingestellt.
Adapter läuft dann noch kurz und terminiert sich dann selbst.2026-08-20 22:40:30.892 - info: host.RPi4 instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-08-20 22:40:34.825 - info: host.RPi4 instance system.adapter.bluelink.0 in version "3.1.32" started with pid 68013 2026-08-20 22:40:37.467 - info: bluelink.0 (68013) starting. Version 3.1.32 in /opt/iobroker/node_modules/iobroker.bluelink, node: v22.23.2, js-controller: 7.2.2 2026-08-20 22:40:37.540 - info: bluelink.0 (68013) Login to api – token source: refreshToken, tokenLen=87 (CCI/CCS mode) 2026-08-20 22:40:38.481 - info: bluelink.0 (68013) 1 Vehicles found 2026-08-20 22:40:38.625 - info: bluelink.0 (68013) Read new update for2026-08-20 22:40:30.148 - info: host.RPi4 stopInstance system.adapter.bluelink.0 (force=false, process=true) 2026-08-20 22:40:30.150 - info: bluelink.0 (67992) [saveTokenToConfig] Token encrypted and saved, valid until 2027-02-16T20:40:30.084Z 2026-08-20 22:40:30.155 - info: bluelink.0 (67992) Got terminate signal TERMINATE_YOURSELF 2026-08-20 22:40:30.157 - info: bluelink.0 (67992) Adapter bluelink cleaned up everything... 2026-08-20 22:40:30.159 - info: bluelink.0 (67992) terminating 2026-08-20 22:40:30.162 - info: bluelink.0 (67992) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-08-20 22:40:30.265 - info: host.RPi4 stopInstance system.adapter.bluelink.0 send kill signal 2026-08-20 22:40:30.662 - info: bluelink.0 (67992) terminating 2026-08-20 22:40:30.663 - info: bluelink.0 (67992) terminating 2026-08-20 22:40:30.892 - info: host.RPi4 instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-08-20 22:40:34.825 - info: host.RPi4 instance system.adapter.bluelink.0 in version "3.1.32" started with pid 68013 -
Hier der Debug Log.
Hier der Debug Log.
Ich bin auf der Suche nach dem Datenpunkt fürs Schiebedach. In der App wird mir der Status angezeigt, im Adapter finde ich leider keinen Datenpunkt. Kann das sein?
Hast du in den RAW Datenpunkten nachgesehen?
Das ist ein Abbild der json-Daten vom Fzg bzw. Server. -
Ich habe den Status vom Schiebedach.
Denke dein Fahrzeug liefert es dann nicht.
Die Daten in RAW kommen so 1 zu 1 von Hyundai / Kia.
In vehicleStatusRaw hab ich gesucht und nichts gefunden. Die KI hat auch nichts gefunden. Anscheinend gibts den Status in einer Home-Assistant-Integration. Deshalb frag ich hier.
was ist das für eine Aussage - anscheinend
JA oder NEIN .UND WICHTIG für dein Modell.. da gibts noch unterschiede
ist wie Schwanger.JA oder NEIN. anscheinend.. phöö
wenn JA dann gibts den auch in den unter bluelink.0xxxxxxx.vehicleStatusRaw. hier steht alles was die API liefert
Könntest den Adapter mal im Debug starten. Da wird das json komplett angezeigt was aus der Cloud kommt. Falls der Adapter was falsch verarbeitet, müsste es da drinnen stehen.
daws kannst du dir sparen. siehe oben
