  3. Einsteigerfragen
  4. Installation ioBroker bricht mit npm error code 22 ab
37 Beiträge 5 Kommentatoren 655 Aufrufe 5 Beobachtet
  • K krcm
    Hallo zusammen: Es sieht eigentlich jetzt nicht schlecht aus:
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
    ACL enabled: true
        ioBroker was installed successfully
        Open http://192.168.178.38:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
        Please run 'iob fix' first after the required re-login to finalize the setup.
    iobpi3@iobroker-pi3:/ $ exit
    logout
    Connection to iobroker-pi3 closed.
    PS C:\Users\Ralph> ssh iobpi3@iobroker-pi3
    iobpi3@iobroker-pi3's password:
    Linux iobroker-pi3 6.18.34+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.18.34-1+rpt1 (2026-06-09) aarch64
    permitted by applicable law.
    Last login: Sun Jul 26 14:44:41 2026 from 192.168.178.23
    iobpi3@iobroker-pi3:~ $ iob fix
    library: loaded
    Library version=2026-04-11
    ioBroker or some processes are still running:
    22922 iobroker.js-con
    22976 io.admin.0
    22991 io.backitup.0
    23054 io.discovery.0
    Please stop them first and try again!
    iobpi3@iobroker-pi3:~ $ iob stop
    library: loaded
        Welcome to the ioBroker installation fixer!
        Script version: 2025-09-18
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists... Done
        Checking ioBroker user and directory permissions (2/5)
    ACL enabled: true
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
    Authentication is required to stop 'iobroker.service'.
    Authenticating as: Raspberry Pi OS (iobpi3)
    Password:
    polkit-agent-helper-1: pam_authenticate failed: Authentication failure
    ==== AUTHENTICATION FAILED ====
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    @krcm sagte:
    Mag sein?
    Warte mal bis du ein paar wenige Instanzen laufen hast und lass dann mal top laufen
      krcm
      Ok ich komme auf die Web oberfläche und kann konfigurieren hier die Ausgabe von TOP:
      Last login: Sun Jul 26 15:37:09 2026 from 192.168.178.23
      iobpi3@iobroker-pi3:~ $ top
      top - 15:45:31 up  2:47,  1 user,  load average: 0.05, 0.26, 0.44
      Tasks: 135 total,   1 running, 134 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.2 us,  0.2 sy,  0.0 ni, 98.3 id,  0.1 wa,  0.0 hi,  0.2 si,  0.0 st
      MiB Mem :    905.1 total,    216.8 free,    525.8 used,    227.5 buff/cache
      MiB Swap:    905.0 total,    855.8 free,     49.2 used.    379.3 avail Mem
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
        25285 iobroker  20   0   10.9g 178740  49988 S   3.0  19.3   0:49.64 iobroker.js-con
        25304 iobroker  20   0   21.1g 185212  56828 S   2.3  20.0   0:33.10 io.admin.0
        25502 iobpi3    20   0   10196   5432   3320 R   1.0   0.6   0:00.19 top
          571 root      20   0  342152   6040   4876 S   0.3   0.7   0:03.57 NetworkManager
            1 root      20   0   25376   9724   6944 S   0.0   1.0   1:08.46 systemd
            2 root      20   0       0      0      0 S   0.0   0.0   0:00.02 kthreadd
            3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
            4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_gp
            5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-sync_wq
            6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-kvfree_rcu_reclaim
            7 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_flushwq
            8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-netns
           13 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-mm_percpu_wq
           14 root      20   0       0      0      0 S   0.0   0.0   0:00.18 ksoftirqd/0
           15 root      20   0       0      0      0 I   0.0   0.0   0:03.36 rcu_preempt
           16 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_exp_par_gp_kthread_worker/0
           17 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_exp_gp_kthread_worker
           18 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/0
           19 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
           20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
           21 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/1
           22 root      20   0       0      0      0 S   0.0   0.0   0:00.14 ksoftirqd/1
           25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
           26 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/2
           27 root      20   0       0      0      0 S   0.0   0.0   0:00.12 ksoftirqd/2
           30 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
           31 root      rt   0       0      0      0 S   0.0   0.0   0:00.00 migration/3
           32 root      20   0       0      0      0 S   0.0   0.0   0:00.13 ksoftirqd/3
           35 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kdevtmpfs
           36 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-inet_frag_wq
           37 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
           38 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
           39 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
           40 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kauditd
           42 root      20   0       0      0      0 S   0.0   0.0   0:00.01 khungtaskd
           43 root      20   0       0      0      0 S   0.0   0.0   0:00.00 oom_reaper
           44 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-writeback
           45 root      20   0       0      0      0 S   0.0   0.0   0:05.87 kcompactd0
           47 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-kblockd
           48 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-blkcg_punt_bio
        krcm
        Danke für Eure Hilfe!!
        • K krcm
          @krcm
          Dann hau jetzt mal ein
          iob diag
          raus. Müsste ja jetzt funktionieren.
            krcm
            Hallo Thomas, hier die Ausgabe von iob diag. Allerdings läuft parallel im Browser die Anwendung soll ich die vorher stoppen?```
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            https://forum.iobroker.net
            Just copy and paste the Summary Page, including the ``` characters at start and end.
            It helps us to help you!
            • Some output is masked. For full results please use 'iob diag --unmask' *
            Press any key to continue
            • K krcm
              @krcm
              Das ist nicht die Ausgabe, das ist der 'Vorspann'.
                krcm
                So jetzt :-):
                ```bash
                Script v.2026-06-06
                *** BASE SYSTEM ***
                Operating System: Debian GNU/Linux 13 (trixie)
                 Static hostname: iobroker-pi3
                       Icon name: computer
                          Kernel: Linux 6.18.34+rpt-rpi-v8
                    Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 3 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Unknown
                Kernel          : aarch64
                Userland        : 64bit
                System was installed 38 days ago (on 2026-06-18).
                Systemuptime and Load:
                 15:54:58 up  2:56,  1 user,  load average: 0.77, 0.63, 0.55
                CPU threads     : 4
                *** LIFE CYCLE STATUS ***
                Operating System is the current Debian stable version codenamed 'trixie'!
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** TIME AND TIMEZONES ***
                               Local time: Sun 2026-07-26 15:54:59 CEST
                           Universal time: Sun 2026-07-26 13:54:59 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                iobpi3
                HOME=/home/iobpi3
                GROUPS=iobpi3 adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input lpadmin iobroker
                iobroker
                HOME=/home/iobroker
                *** DISPLAY-SERVER SETUP ***
                Display-Server:         Unknown
                Display-Manager:        Not found
                Desktop:
                Session:                tty
                Boot Target:            multi-user.target
                *** MEMORY ***
                Mem:            949M        601M        157M        3.5M        260M        347M
                Swap:           948M        100M        848M
                Total:          1.9G        702M        1.0G
                Active iob-Instances:   4
                          905 M total memory
                          573 M used memory
                          457 M active memory
                          138 M inactive memory
                          149 M free memory
                            8 M buffer memory
                          240 M swap cache
                          904 M total swap
                           95 M used swap
                          809 M free swap
                top - 15:55:00 up  2:56,  1 user,  load average: 0.77, 0.63, 0.55
                Tasks: 149 total,   2 running, 147 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 12.7 us,  3.6 sy,  0.0 ni, 81.8 id,  1.8 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :    905.1 total,    149.7 free,    573.7 used,    249.2 buff/cache
                MiB Swap:    905.0 total,    809.2 free,     95.8 used.    331.4 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                No critical errors detected
                *** FILESYSTEM ***
                udev           devtmpfs  318M     0  318M   0% /dev
                tmpfs          tmpfs     182M   17M  165M  10% /run
                /dev/mmcblk0p2 ext4       15G  4.2G  9.3G  31% /
                tmpfs          tmpfs     453M     0  453M   0% /dev/shm
                tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                tmpfs          tmpfs     453M  2.6M  451M   1% /tmp
                /dev/mmcblk0p1 vfat      505M   66M  439M  14% /boot/firmware
                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                tmpfs          tmpfs      91M  8.0K   91M   1% /run/user/1000
                Messages concerning filesystems in dmesg:
                [Sun Jul 26 12:58:22 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                [Sun Jul 26 12:58:22 2026] EXT4-fs (mmcblk0p2): mounted filesystem 15f4c6be-1102-4331-9904-f78e78afd1fd ro with ordered data mode. Quota mode: none.
                [Sun Jul 26 12:58:26 2026] EXT4-fs (mmcblk0p2): re-mounted 15f4c6be-1102-4331-9904-f78e78afd1fd r/w.
                Show mounted filesystems:
                TARGET           SOURCE         FSTYPE OPTIONS
                /                /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                1.3G    /var/
                233M    /var/cache
                228M    /var/cache/apt
                180M    /var/lib
                148M    /var/lib/apt
                Archived and active journals take up 15.8M in the file system.
                /opt/iobroker/backups:
                4.0K    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                72M     /opt/iobroker/iobroker-data/
                65M     /opt/iobroker/iobroker-data/files
                47M     /opt/iobroker/iobroker-data/files/admin.admin
                46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
                7.0M    /opt/iobroker/iobroker-data/objects.jsonl
                3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-Byv11PyV.js
                3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
                USB-Devices by-id:
                USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                please always prefer the links 'by-id':
                No Devices found 'by-id'
                No nvbackup.json found.
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v22.23.1
                /usr/bin/node           v22.23.1
                /usr/bin/npm            10.9.8
                /usr/bin/npx            10.9.8
                ✓ Node.js installation is correct
                nodejs:
                  Installed: 22.23.1-1nodesource1
                  Candidate: 22.23.1-1nodesource1
                  Version table:
                 *** 22.23.1-1nodesource1 1001
                        500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                     22.23.0-1nodesource1 1001
                     22.22.3-1nodesource1 1001
                     22.22.2-1nodesource1 1001
                     22.22.1-1nodesource1 1001
                     22.22.0-1nodesource1 1001
                     22.21.0-1nodesource1 1001
                     22.20.0-1nodesource1 1001
                     22.19.0-1nodesource1 1001
                     22.18.0-1nodesource1 1001
                     22.17.1-1nodesource1 1001
                     22.17.0-1nodesource1 1001
                     22.16.0-1nodesource1 1001
                     22.15.1-1nodesource1 1001
                     22.15.0-1nodesource1 1001
                     22.14.0-1nodesource1 1001
                     22.13.1-1nodesource1 1001
                     22.13.0-1nodesource1 1001
                     22.12.0-1nodesource1 1001
                     22.11.0-1nodesource1 1001
                     22.10.0-1nodesource1 1001
                     22.9.0-1nodesource1 1001
                     22.8.0-1nodesource1 1001
                     22.7.0-1nodesource1 1001
                     22.6.0-1nodesource1 1001
                     22.5.1-1nodesource1 1001
                     22.5.0-1nodesource1 1001
                     22.4.1-1nodesource1 1001
                     22.4.0-1nodesource1 1001
                     22.3.0-1nodesource1 1001
                     22.2.0-1nodesource1 1001
                     22.1.0-1nodesource1 1001
                     22.0.0-1nodesource1 1001
                     20.19.2+dfsg-1+deb13u2 500
                        500 http://deb.debian.org/debian trixie/main arm64 Packages
                        500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                No problems detected
                Errors in npm tree: 0
                No known Vulnerabilities detected!
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                iobroker-pi3        iobroker-pi3 (version: 7.1.2, hostname: iobroker-pi3  , alive, uptime: 1028)
                Core adapters versions
                js-controller:  7.1.2
                admin:          7.8.23
                javascript:     "javascript" not found
                nodejs modules from github:     0
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker-pi3                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.backitup.0               : backitup              : iobroker-pi3                             -  enabled
                + system.adapter.discovery.0              : discovery             : iobroker-pi3                             -  enabled
                + system.adapter.history.0                : history               : iobroker-pi3                             -  enabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Upgrade policy: none
                Installed ioBroker-Adapters
                │ (index) │ id                         │ name        │ version  │ upgrade policy │
                │ 0       │ 'system.adapter.admin'     │ 'admin'     │ '7.8.23' │ 'none'         │
                │ 1       │ 'system.adapter.backitup'  │ 'backitup'  │ '3.3.17' │ 'none'         │
                │ 2       │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0'  │ 'none'         │
                │ 3       │ 'system.adapter.history'   │ 'history'   │ '4.0.0'  │ 'none'         │
                ioBroker-Adapter Versions and update status
                Used repository: stable
                Adapter    "admin"        : 7.8.23   , installed 7.8.23
                Adapter    "backitup"     : 3.3.17   , installed 3.3.17
                Adapter    "history"      : 4.0.0    , installed 4.0.0
                Controller "js-controller": 7.2.2    , installed 7.1.2  [Updatable]
                Objects and States
                Objects:        181
                States:         130
                Hit:1 http://archive.raspberrypi.com/debian trixie InRelease
                Hit:2 http://deb.debian.org/debian trixie InRelease
                Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
                Pending systemupdates: 0
                *** Listening Ports ***
                Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
                udp   UNCONN 0      0            0.0.0.0:mdns        0.0.0.0:*    users:(("avahi-daemon",pid=538,fd=12))
                udp   UNCONN 0      0            0.0.0.0:48611       0.0.0.0:*    users:(("avahi-daemon",pid=538,fd=14))
                udp   UNCONN 0      0            0.0.0.0:5678        0.0.0.0:*    users:(("io.discovery.0",pid=25328,fd=30))
                udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=22159,fd=5),("systemd",pid=1,fd=161))
                udp   UNCONN 0      0                  *:mdns              *:*    users:(("avahi-daemon",pid=538,fd=13))
                udp   UNCONN 0      0                  *:53263             *:*    users:(("avahi-daemon",pid=538,fd=15))
                udp   UNCONN 0      0                  *:sunrpc            *:*    users:(("rpcbind",pid=22159,fd=7),("systemd",pid=1,fd=169))
                tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=22159,fd=4),("systemd",pid=1,fd=160))
                tcp   LISTEN 0      128          0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=991,fd=6))
                tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=25285,fd=29))
                tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=25285,fd=23))
                tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbind",pid=22159,fd=6),("systemd",pid=1,fd=168))
                tcp   LISTEN 0      128             [::]:ssh            [::]:*    users:(("sshd",pid=991,fd=7))
                tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.0",pid=25505,fd=34))
                2026-07-26 15:54:24.076  - info: host.iobroker-pi3 iobroker Installing iobroker.history@4.0.0... (System call)
                2026-07-26 15:54:36.136  - info: host.iobroker-pi3 iobroker added 1 package in 12s
                2026-07-26 15:54:36.139  - info: host.iobroker-pi3 iobroker 112 packages are looking for funding  run `npm fund` for details
                2026-07-26 15:54:36.564  - info: host.iobroker-pi3 iobroker host.iobroker-pi3 install adapter history
                2026-07-26 15:54:36.661  - info: host.iobroker-pi3 iobroker upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                2026-07-26 15:54:36.688  - info: host.iobroker-pi3 iobroker upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.psd history.psd image/vnd.adobe.photoshop
                2026-07-26 15:54:36.768  - info: host.iobroker-pi3 iobroker upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de.json i18n/de.json application/json
                2026-07-26 15:54:37.162  - info: host.iobroker-pi3 iobroker upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en.json i18n/en.json application/json
                2026-07-26 15:54:37.178  - info: host.iobroker-pi3 iobroker upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es.json i18n/es.json application/json
                2026-07-26 15:54:37.192  - info: host.iobroker-pi3 iobroker upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr.json i18n/fr.json application/json
                2026-07-26 15:54:37.207  - info: host.iobroker-pi3 iobroker upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it.json i18n/it.json application/json
                2026-07-26 15:54:37.221  - info: host.iobroker-pi3 iobroker upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl.json i18n/nl.json application/json
                2026-07-26 15:54:37.247  - info: host.iobroker-pi3 iobroker upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl.json i18n/pl.json application/json
                2026-07-26 15:54:37.266  - info: host.iobroker-pi3 iobroker upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt.json i18n/pt.json application/json
                2026-07-26 15:54:37.316  - info: host.iobroker-pi3 iobroker upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru.json i18n/ru.json application/json
                2026-07-26 15:54:37.353  - info: host.iobroker-pi3 iobroker upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                2026-07-26 15:54:37.367  - info: host.iobroker-pi3 iobroker upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                2026-07-26 15:54:37.380  - info: host.iobroker-pi3 iobroker upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                2026-07-26 15:54:37.449  - info: host.iobroker-pi3 iobroker host.iobroker-pi3 object system.adapter.history created/updated
                2026-07-26 15:54:37.456  - info: host.iobroker-pi3 iobroker Updating objects from io-package.json for adapter "history" with version "4.0.0"
                2026-07-26 15:54:38.563  - info: host.iobroker-pi3 iobroker exit 0
                2026-07-26 15:54:38.698  - info: host.iobroker-pi3 Set hostname iobroker-pi3 for system.adapter.history.0
                2026-07-26 15:54:39.686  - info: host.iobroker-pi3 instance system.adapter.history.0 in version "4.0.0" started with pid 26225
                2026-07-26 15:54:45.219  - info: history.0 (26225) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.history, node: v22.23.1, js-controller: 7.1.2
                2026-07-26 15:54:45.329  - info: history.0 (26225) Set default history instance to "history.0"
                ============= Mark until here for C&P =============
                iob diag has finished.
                • K krcm
                  So jetzt :-):
                  ```bash
                  Script v.2026-06-06
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Unknown
                  Kernel          : aarch64
                  Userland        : 64bit
                  CPU threads     : 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  iobpi3
                  HOME=/home/iobpi3
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                            905 M total memory
                            573 M used memory
                            457 M active memory
                            149 M free memory
                              8 M buffer memory
                            240 M swap cache
                            904 M total swap
                             95 M used swap
                            809 M free swap
                  *** FILESYSTEM ***
                  /var:
                  1.3G    /var/
                  233M    /var/cache
                  228M    /var/cache/apt
                  180M    /var/lib
                  148M    /var/lib/apt
                  USB-Devices by-id:
                  /usr/bin/npm            10.9.8
                  /usr/bin/npx            10.9.8
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.8.23
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        181
                  States:         130
                  @krcm sagte:
                  Und das bei
                  @krcm sagte:
                    krcm
                    Ja das ist zu knapp. Trotzdem vielen Dank für Eure hilfe. Wieder was gelernt
                      krcm
                      Aber das JS Controller Update auf die 7.2.2 (das vorher nicht mehr ging und der Grund letzlich für das neuaufsetzen war) hat jetzt noch geklappt :-)
                      • K krcm
                        @krcm sagte:
                        Jetzt hast du ja auch 64 bit und wahrscheinlich die aktuelle nodejs-Version, die es fürc32 bit nicht mehr gibt
                          krcm
                          Genau so Danke nochmals und dann ist der Tread gelöst🙂👍
