  4. ...nicht in offiziellem Repo
  5. MotionEye Integration - Alpha
    6.3k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
motionmotioneyecamerainventwocursor ai
67 Beiträge 9 Kommentatoren 4.1k Aufrufe 11 Beobachtet
  • skvarelS Offline
    skvarelS Offline
    skvarel
    schrieb am zuletzt editiert von skvarel
    To-Do-Liste:
    • Einstellungen der Kameras auch über den Adapter zu realisieren
    Changelog:
    0.5.0 (2026-07-01)
    • (skvarel) MotionEye 0.44+ support: session login via POST /login (auto-fallback when URL signature auth fails); keeps 0.43.x signature auth
    0.4.3 (2026-06-30)
    • (skvarel) Fixed italian translation for streamReadyTimeoutMs_help (repository review E5606)
    0.4.2 (2026-06-30)
    • (skvarel) FAQ: connection test button, SSH node path on ioBroker host, GitHub install, web-login vs API troubleshooting
    • (skvarel) Trim MotionEye host/user/password before API calls; admin button 'Test connection'
    • (skvarel) Verbose unauthorized hints: web login URL and simple-password troubleshooting
    0.4.1 (2026-06-28)
    • (skvarel) Added Logs / Logging tab with optional verbose diagnostic logging for troubleshooting (e.g. unauthorized)
    0.4.0 (2026-06-28)
    • (ioBroker-Bot) Adapter requires admin >= 7.8.23 now.
    • (skvarel) Repository review fixes: timer value capping, self-scheduling status poll, removed unused help i18n keys, stream timing settings in expert mode
    Older changes:
    0.3.3 (2026-06-23)
    (skvarel) Redesigned help tab: short intro, quickstart, and links to GitHub documentation
    (skvarel) Added GitHub documentation in docs/en/ and docs/de/ (settings, cameras, modes, datapoints, VIS stream, FAQ)
    (skvarel) Help tab shows one documentation link per admin language (DE or EN) plus direct FAQ link; external links open in a new tab
    0.3.2 (2026-06-22)
    (skvarel) Modified config/help
    0.3.1 (2026-06-22)
    (skvarel) Changed repo icon
    0.3.0 (2026-06-22)
    (skvarel) Camera channel folders are now lowercase (e.g. innenhof_ii instead of Innenhof_II) — aligned with other ioBroker adapters
    (skvarel) Info states moved from 0_info to _info
    (skvarel) Existing datapoint values are migrated automatically on adapter start — please check VIS, scripts, and automations that use fixed state paths
    #TeamInventwo
    Unsere Adapter:
    • skvarelS Offline
      skvarelS Offline
      skvarel
      Anbei ein paar Screenshots von meiner VIS2 mit den Datenpunkten aus dem neuen Adapter
      • Livestream über Binding;
      • Steuerung der Bewegungserkennung per Dropdown;
      • Snapshot per Button;
      Die Datenpunkte pro Kamera:
      Die Info Datenpunkte vom System:
      Die Config:
      #TeamInventwo
      Unsere Adapter:
      • Merlin123M Offline
        Merlin123M Offline
        Merlin123
        bin von motioneye auf go2rtc umgestiegen, weil das weniger Ressourcen benötigt und bei mir besser läuft.
        Deine Motioneye Integration sieht aber klasse aus!
        Beta-Tester
        skvarelS 1 Antwort Letzte Antwort
        • Merlin123M Merlin123
          skvarelS Offline
          skvarelS Offline
          skvarel
          @Merlin123 .. go2rtc kann halt keine Bewegungen erkennen/melden und nicht aufnehmen. Deswegen bin ich von go2rtc wieder zurück auf MotionEye.
          Es läuft genau flüssig, wenn man die MotionEye Oberfläche nicht nutzt. Deswegen der Adapter. Er macht die MotionEye Oberfläche überflüssig ;)
          #TeamInventwo
          Unsere Adapter:
          • skvarelS skvarel
            Aktuelle Alpha Version 0.5.x
            Veröffentlichungsdatum 21.06.2026
            Github Link https://github.com/inventwo/ioBroker.motioneye
            npm Link https://www.npmjs.com/package/iobroker.motioneye
            FAQ https://github.com/inventwo/ioBroker.motioneye/blob/main/docs/de/faq.md
            Gibt es hier noch MotionEye Nutzer? Ich nutze MotionEye, um mich nicht auf eine Marke festlegen zu müssen.
            Ich habe ein paar Reolink, ein paar ESP32-Cam, eine USB-Cam und eine Galayou Y4 in meinem Smarthome.
            Mir fehlte nur eine sauber Anbindung an den ioBroker. Das habe ich jetzt nachgeholt.
            Der Adapter bringt Bewegungsmelder, Snapshots und Livestream in ioBroker. Pro Kamera gibt es eigene Kanäle mit frei wählbarem Namen. Die Modi off, still und sharp lassen sich aus ioBroker steuern. MotionEye wird dabei über die Config-API (Port 8765) synchronisiert.
            Für Bewegung nutzt der Adapter einen eingebauten Webhook-Server – simple-api ist nicht nötig. Webhook-URLs schreibt der Adapter beim Start nach MotionEye.
            Zusätzlich gibt es Snapshot, Stream ein/aus, streamPulse (kurze Vorschau) und streamUrl mit fertigem HTML für jedes HTML-Widget in VIS, VIS2 oder Dashboards.
            Im Admin gibt es einen Hilfe-Tab und einen Button „Kameras aus MotionEye laden“, der fehlende Kameras aus /config/list in die Tabelle übernimmt.
            Der Adapter ist noch jung und soll in der Praxis getestet werden. Feedback, Fehler und Ideen sind sehr willkommen – am besten hier im Thread oder als Issue auf GitHub.
            Wer mitmachen möchte: Instanz anlegen, MotionEye-Host und Webhook-Host (ioBroker-IP, von MotionEye aus erreichbar) setzen, Kameras eintragen oder laden, speichern und Instanz neu starten.
            Gruß, skvarel von inventwo
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            @skvarel sagte:
            Ja, hier! :)
            Werde ihn gleich testen.
            ° Fixer ---> iob fix
            • madingM Offline
              madingM Offline
              mading
              schrieb am zuletzt editiert von mading
              Ja hier 😊
              Habe meine MotionEye Instanz erfolgreich eingebunden, sehe aber im Log ein paar Fehler. Beide Streams (Garage und Haustuere) sind über Motioneye sichtbar.
              Log-Größe: 676.1 KB
              Zeit
              motioneye.0
              2026-06-23 07:52:48.446	info	MotionEye adapter ready
              motioneye.0
              2026-06-23 07:52:48.402	warn	Initial setup failed for Garage: unauthorized
              motioneye.0
              2026-06-23 07:52:48.357	warn	Initial setup failed for Haustuere: unauthorized
              motioneye.0
              2026-06-23 07:52:48.312	warn	MotionEye not reachable at startup: unauthorized
              motioneye.0
              2026-06-23 07:52:48.248	info	Webhook server listening on 0.0.0.0:8090
              motioneye.0
              2026-06-23 07:52:48.229	info	MotionEye adapter starting...
              • skvarelS skvarel
                FredFF Online
                FredFF Online
                FredF
                Most Active Forum Testing
                @skvarel
                Hier ebenso.
                Werde testen und berichten
                • madingM mading
                  Ja hier 😊
                  Log-Größe: 676.1 KB
                  Zeit
                  motioneye.0
                  motioneye.0
                  motioneye.0
                  motioneye.0
                  motioneye.0
                  motioneye.0
                  skvarelS Offline
                  skvarelS Offline
                  skvarel
                  @mading .. bitte einmal die Login Daten Kontrollieren. Der Adapter benötigt den Admin Zugriff
                  #TeamInventwo
                  Unsere Adapter:
                  • FredFF Online
                    FredFF Online
                    FredF
                    @skvarel
                    Schon bin ich überfordert:
                    2026-06-23 12:30:39.237 - info: motioneye.0 (3124) starting. Version 0.3.2 (non-npm: inventwo/ioBroker.motioneye#8cadbff4edc91070b78d6facae2498ad5a1e2134) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.23.0, js-controller: 7.2.2
                    2026-06-23 12:30:39.245 - info: motioneye.0 (3124) MotionEye adapter starting...
                    2026-06-23 12:30:39.264 - info: motioneye.0 (3124) Webhook server listening on 0.0.0.0:8090
                    2026-06-23 12:30:42.403 - warn: motioneye.0 (3124) MotionEye not reachable at startup: connect EHOSTUNREACH 192.168.10.30:8765
                    2026-06-23 12:30:45.475 - warn: motioneye.0 (3124) Initial setup failed for Garten: connect EHOSTUNREACH 192.168.10.30:8765
                    2026-06-23 12:30:45.479 - info: motioneye.0 (3124) MotionEye adapter ready
                    ioBroker und MotionEye laufen auf unraid Docker Containern.
                    Eine Idee? IP stimmt natürlich, motionEye läuft und ist über Browser erreichbar.
                    skvarelS 2 Antworten Letzte Antwort
                    • FredFF FredF
                      @skvarel
                      skvarelS Offline
                      skvarelS Offline
                      skvarel
                      @FredF .. schaue ich mir gleich genauer an. Ich bin gerade noch unterwegs.
                      #TeamInventwo
                      Unsere Adapter:
                      • FredFF FredF
                        @skvarel
                        skvarelS Offline
                        skvarelS Offline
                        skvarel
                        @FredF sagte:
                        Was mich gerade wundert, ist der Versuch sich mit der Camera zu verbinden ?! Eigentlich soll sich der Adapter nur an die IP von MotionEye halten. Die IPs der Kameras werden nicht benötigt.
                        Ich habe allerdings keine Ahnung von Docker. Ich nutze getrennte Hardware für meine Systeme.
                        #TeamInventwo
                        Unsere Adapter:
                        • skvarelS Offline
                          skvarelS Offline
                          skvarel
                          @mading ... @fredf ...
                          Ich habe gerade eine Doku erstellen lassen und darin auch eure Probleme beschreiben lassen. Bitte einmal reingucken und testen ob es daran liegt.
                          @fredf .. bei Docker kann es wirklich zu deinem Problem kommen.
                          • DE: https://github.com/inventwo/ioBroker.motioneye/blob/main/docs/de/README.md
                          • EN: https://github.com/inventwo/ioBroker.motioneye/blob/main/docs/en/README.md
                          #TeamInventwo
                          Unsere Adapter:
                          • E Offline
                            emil70
                            Top Adapter,
                            @skvarel
                            wie hast du die einstellungen stehen?
                            damit auch zügig erkannt wird
                            gruss emil70
                            iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
                            • E emil70
                              Top Adapter,
                              @skvarel
                              skvarelS Offline
                              skvarelS Offline
                              skvarel
                              @emil70 ... zum Testen habe ich alle Kameras so eingestellt:
                              Feintuning muss ich noch machen. Die Kamera auf der Auffahrt löst mir noch etwas zu oft aus
                              #TeamInventwo
                              Unsere Adapter:
                              • skvarelS skvarel
                                FredFF Online
                                FredFF Online
                                FredF
                                @skvarel
                                Danke für den Hinweis. ich hätte auch selbst darauf kommen können...
                                Mein ioBroker Testsystem läuft auf einem Custom Network und der motionEye container läuft als Host, kann ja nicht funktionieren.
                                Aus Zeitgründen stelle ich das jetzt nicht um, teste deinen Adapter dann später weiter.
                                • LongbowL Offline
                                  LongbowL Offline
                                  Longbow
                                  Guten Morgen, also ich habe mich mal dran gemacht. Die eine Reolink RLC-823S2 ist nicht möglich ein zu binden?! Weiß da einer einen Tipp? Hab nur es Passwort und kein Benutzer!
                                  Aber was ich nicht hin bekomme, die Daten vom Motioneye Server stimmen, kann mich mit den ja anmelden dort, nur der Adapter sagt immer immer den Fehler.
                                  Bildschirmfoto_25-6-2026_71838_192.168.7.201.jpeg Bildschirmfoto_25-6-2026_71827_192.168.7.201.jpeg
                                  • LongbowL Longbow
                                    skvarelS Offline
                                    skvarelS Offline
                                    skvarel
                                    @Longbow .. Der Adapter benötigt zwingend den Admin-Zugriff auf MotionEye.
                                    Wenn du den Benutzer nihct geändert hast, ist es 'admin'. In den Adapter musst genau den Benutzer und das Passwort eintragen, mit dem du dich als Admin in MotionEye anmeldest.
                                    Ist die Kamera in MotionEye eingerichtung und funktioniert der Stream dort?
                                    Kannst du mir den Log, nach dem Start des Adpapters, zeigen?
                                    EDIT:
                                    Vorsichtshalber bitte mal den Haken bei "MotionEye über Config-API steuern" setzen.
                                    #TeamInventwo
                                    Unsere Adapter:
                                    LongbowL 1 Antwort Letzte Antwort
                                    • skvarelS skvarel
                                      EDIT:
                                      LongbowL Offline
                                      LongbowL Offline
                                      Longbow
                                      @skvarel
                                      hallo
                                      ich habe Benutzer nicht verändert, muss nur nach dem ersten Loggin das PW ändern.
                                      Daher ist das wie normal.
                                      Im MotionEye ist eine Cam drin und man sieht alles.
                                      Hier das Potrokoll.
                                      motioneye.0
                                      2026-06-25 16:52:46.741	info	MotionEye adapter ready
                                      motioneye.0
                                      2026-06-25 16:52:46.697	warn	MotionEye not reachable at startup: unauthorized
                                      motioneye.0
                                      2026-06-25 16:52:46.688	warn	No enabled cameras configured — add cameras on the Cameras tab
                                      motioneye.0
                                      2026-06-25 16:52:46.688	info	Webhook server listening on 0.0.0.0:8090
                                      motioneye.0
                                      2026-06-25 16:52:46.660	info	MotionEye adapter starting...
                                      motioneye.0
                                      2026-06-25 16:52:46.651	info	starting. Version 0.3.3 (non-npm: inventwo/ioBroker.motioneye#e72e9f1d6627241be0440356251d5b3b5c03b2ed) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.21.0, js-controller: 7.2.2
                                      motioneye.0
                                      2026-06-25 16:52:41.896	info	terminating
                                      motioneye.0
                                      motioneye.0
                                      2026-06-25 16:52:41.396	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      motioneye.0
                                      2026-06-25 16:52:41.396	info	terminating
                                      motioneye.0
                                      2026-06-25 16:52:41.395	info	Got terminate signal TERMINATE_YOURSELF
                                      motioneye.0
                                      2026-06-25 16:49:08.387	warn	Status poll failed: unauthorized```
                                      • LongbowL Longbow
                                        @skvarel
                                        hallo
                                        Hier das Potrokoll.
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        motioneye.0
                                        skvarelS Offline
                                        skvarelS Offline
                                        skvarel
                                        @Longbow
                                        Danke für Log — damit lässt sich das ziemlich klar eingrenzen.
                                        unauthorized bedeutet: MotionEye unter 192.168.7.206:8765 ist erreichbar, aber Benutzer/Passwort für die Config-API werden abgelehnt. Das ist kein Netzwerk- oder Docker-Problem.
                                        Wahrscheinlich stimmt das gespeicherte Passwort im Adapter nicht — auch wenn im Feld noch Punkte stehen. Seit Adapter 0.2.1 wird das Passwort verschlüsselt gespeichert; nach Installation/Update kann ein alter Wert noch angezeigt werden, ohne dass die API-Signatur passt.
                                        Bitte so vorgehen:
                                        • Instanz-Einstellungen öffnen
                                        • Feld MotionEye-Passwort komplett leeren
                                        • Dein MotionEye-Admin-Passwort neu eintippen (exakt wie beim Login in der MotionEye-Weboberfläche)
                                        • Haken bei „MotionEye über Config-API steuern“ setzen (bei dir im Screenshot noch aus — für den normalen Betrieb nötig)
                                        • Speichern und Instanz neu starten
                                        • Im Objektbaum prüfen: motioneye.0._info.connection sollte true sein, im Log keine unauthorized-Meldungen mehr
                                        Zusätzlich: Im Log steht No enabled cameras configured. Bitte auf dem Tab Kameras mindestens eine Kamera eintragen (oder „Kameras aus MotionEye laden“), speichern und erneut starten. Die Kamera in MotionEye allein reicht nicht — sie muss auch im Adapter konfiguriert sein.
                                        FAQ mit weiteren Details:
                                        Wenn es danach noch hakt, bitte nochmal den Log nach Neustart schicken und kurz bestätigen, ob _info.connection true/false ist.
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • skvarelS skvarel
                                          @Longbow
                                          Bitte so vorgehen:
                                          LongbowL Offline
                                          LongbowL Offline
                                          Longbow
                                          schrieb am zuletzt editiert von Longbow
                                          @skvarel
                                          Danke, habe gerade ausprobiert, bleibt leider dabei,
                                          http://192.168.7.206:8765/ das ist die Adresse und admin und PW habe ich nochmals eingeben. Ich kann wegen dem Fehler ja keine Cam hinzufügen.
                                          Info_Connection false
                                          Log:
                                          motioneye.0
                                          2026-06-25 20:26:40.078	warn	Status poll failed: unauthorized
                                          motioneye.0
                                          2026-06-25 20:21:40.077	warn	Status poll failed: unauthorized
                                          motioneye.0
                                          2026-06-25 20:16:40.078	warn	Status poll failed: unauthorized
                                          motioneye.0
                                          2026-06-25 20:11:40.078	warn	Status poll failed: unauthorized
                                          motioneye.0
                                          2026-06-25 20:06:40.032	info	MotionEye adapter ready
                                          motioneye.0
                                          2026-06-25 20:06:39.987	warn	MotionEye not reachable at startup: unauthorized
                                          motioneye.0
                                          2026-06-25 20:06:39.980	warn	No enabled cameras configured — add cameras on the Cameras tab
                                          motioneye.0
                                          2026-06-25 20:06:39.980	info	Webhook server listening on 0.0.0.0:8090
                                          motioneye.0
                                          2026-06-25 20:06:39.959	info	MotionEye adapter starting...
                                          motioneye.0
                                          2026-06-25 20:06:39.951	info	starting. Version 0.3.3 (non-npm: inventwo/ioBroker.motioneye#e72e9f1d6627241be0440356251d5b3b5c03b2ed) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.21.0, js-controller: 7.2.2
                                          motioneye.0
                                          2026-06-25 20:06:35.365	info	terminating
                                          motioneye.0
                                          2026-06-25 20:06:35.364	info	terminating
                                          motioneye.0
                                          2026-06-25 20:06:34.865	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          motioneye.0
                                          2026-06-25 20:06:34.865	info	terminating
                                          motioneye.0
                                          2026-06-25 20:06:34.863	info	Got terminate signal TERMINATE_YOURSELF
                                          motioneye.0
                                          2026-06-25 20:06:20.878	info	MotionEye adapter ready
                                          motioneye.0
                                          2026-06-25 20:06:20.833	warn	MotionEye not reachable at startup: unauthorized
                                          motioneye.0
                                          2026-06-25 20:06:20.826	warn	No enabled cameras configured — add cameras on the Cameras tab
                                          motioneye.0
                                          2026-06-25 20:06:20.826	info	Webhook server listening on 0.0.0.0:8090
                                          motioneye.0
                                          2026-06-25 20:06:20.803	info	MotionEye adapter starting...
                                          motioneye.0
                                          2026-06-25 20:06:20.795	info	starting. Version 0.3.3 (non-npm: inventwo/ioBroker.motioneye#e72e9f1d6627241be0440356251d5b3b5c03b2ed) in /opt/iobroker/node_modules/iobroker.motioneye, node: v22.21.0, js-controller: 7.2.2
                                          motioneye.0
                                          2026-06-25 20:06:16.250	info	terminating
                                          motioneye.0
                                          2026-06-25 20:06:16.249	info	terminating
                                          motioneye.0
                                          2026-06-25 20:06:15.750	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          motioneye.0
                                          2026-06-25 20:06:15.749	info	terminating
                                          motioneye.0
                                          2026-06-25 20:06:15.748	info	Got terminate signal TERMINATE_YOURSELF```
                                          skvarelS 3 Antworten Letzte Antwort
