  5. Hilfe bei Blockly
    6.3k
Hilfe bei Blockly
257 Beiträge 7 Kommentatoren 25.0k Aufrufe 4 Beobachtet
  • tiobbT tiobb
    Bitte nicht meckern wegen fehlender Updates, das hat einen besonderen Grund 🙊
    Script v.2026-06-01
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 387 days ago (on 2025-05-13).
    Systemuptime and Load:
     18:11:03 up 17 min,  2 users,  load average: 0.69, 0.87, 1.04
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-06-04 18:11:03 CEST
               Universal time: Thu 2026-06-04 16:11:03 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio plugdev games users input netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:		X11
    Display-Manager: 	* lightdm.service - Light Display Manager
    Desktop:		LXDE-pi
    Session:		x11
    Boot Target: 		multi-user.target
    *** MEMORY ***
    Mem:            8.2G        2.5G        4.9G         35M        949M        5.7G
    Swap:           536M          0B        536M
    Total:          8.7G        2.5G        5.4G
    Active iob-Instances: 	29
             7809 M total memory
             2412 M used memory
             2517 M active memory
              493 M inactive memory
             4645 M free memory
               62 M buffer memory
              843 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 18:11:04 up 17 min,  2 users,  load average: 0.69, 0.87, 1.04
    Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.5 us, 12.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7809.4 total,   4644.5 free,   2413.1 used,    905.5 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5396.3 avail Mem
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * session-1.scope loaded failed failed Session 1 of User pi
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     781M  9.3M  772M   2% /run
    /dev/mmcblk0p2 ext4       58G  9.1G   46G  17% /
    tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   68M  443M  14% /boot/firmware
    tmpfs          tmpfs     781M   44K  781M   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Thu Jun  4 17:53:21 2026] EXT4-fs (mmcblk0p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Quota mode: none.
    [Thu Jun  4 17:53:22 2026] EXT4-fs (mmcblk0p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE            OPTIONS
    /                            /dev/mmcblk0p2 ext4              rw,noatime
    |-/boot/firmware             /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    /var:
    888M	/var/
    204M	/var/lib
    170M	/var/cache
    161M	/var/cache/apt
    144M	/var/lib/apt/lists
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    376M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    581M	/opt/iobroker/iobroker-data/
    420M	/opt/iobroker/iobroker-data/files
    156M	/opt/iobroker/iobroker-data/files/vis-2
    129M	/opt/iobroker/iobroker-data/backup-objects
    89M	/opt/iobroker/iobroker-data/files/vis-2/static
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    21M	/opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
    *** ZigBee Settings ***
    â Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        ...__0X00124B001CDD4A3A-if00        ...__0X00124B001CDD4A3A-if00        â Matching
    *** NodeJS-Installation ***
    /usr/bin/nodejs		v20.19.2
    /usr/bin/node		v20.19.2
    /usr/bin/npm		10.8.2
    /usr/bin/npx		10.8.2
    â Node.js installation is correct
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 20.20.2-1nodesource1
      Version table:
         20.20.2-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.20.1-1nodesource1 600
         20.20.0-1nodesource1 600
         20.19.6-1nodesource1 600
         20.19.5-1nodesource1 600
         20.19.4-1nodesource1 600
         20.19.3-1nodesource1 600
     *** 20.19.2-1nodesource1 600
         20.19.1-1nodesource1 600
         20.19.0-1nodesource1 600
         20.18.3-1nodesource1 600
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.20.4+dfsg-1~deb12u2 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    Vulnerabilities detected in the Node.js version!
    node:fs:2368
        return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        at Object.writeFileSync (node:fs:2368:20)
        at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
        at Object.onceWrapper (node:events:639:26)
        at ClientRequest.emit (node:events:524:28)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
        at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
        at TLSSocket.socketOnData (node:_http_client:544:22)
        at TLSSocket.emit (node:events:524:28)
        at addChunk (node:internal/streams/readable:561:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    Node.js v20.19.2
    npm notice
    npm notice New major version of npm available! 10.8.2 -> 11.16.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.16.0
    npm notice To update run: npm install -g npm@11.16.0
    npm notice
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1043)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
    + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : raspberrypi                              -  enabled, port: 1881, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
    + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
    + instance is alive
    ioBroker-Repositories
    âââââââââââ¬âââââââââââ¬ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¬âââââââââââââââ (index) â name     â url                                                     â auto upgrade â
    âââââââââââ¼âââââââââââ¼ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¼âââââââââââââââ¤
    â 0       â 'stable' â 'http://download.iobroker.net/sources-dist.json'        â false        â
    â 1       â 'beta'   â 'http://download.iobroker.net/sources-dist-latest.json' â false        â
    âââââââââââ´âââââââââââ´ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ´âââââââââââââââInstalled ioBroker-Adapters
    âââââââââââ¬ââââââââââââââââââââââââââââââââââââââ¬âââââââââââââââââââââââ¬âââââââââââ¬âââââââââââââââââ (index) â id                                  â name                 â version  â upgrade policy â
    âââââââââââ¼ââââââââââââââââââââââââââââââââââââââ¼âââââââââââââââââââââââ¼âââââââââââ¼âââââââââââââââââ¤
    â 0       â 'system.adapter.admin'              â 'admin'              â '7.6.17' â 'none'         â
    â 1       â 'system.adapter.alexa2'             â 'alexa2'             â '3.27.4' â 'none'         â
    â 2       â 'system.adapter.backitup'           â 'backitup'           â '3.2.2'  â 'none'         â
    â 3       â 'system.adapter.cloud'              â 'cloud'              â '5.0.1'  â 'none'         â
    â 4       â 'system.adapter.daswetter'          â 'daswetter'          â '3.2.3'  â 'none'         â
    â 5       â 'system.adapter.devices'            â 'devices'            â '1.2.9'  â 'none'         â
    â 6       â 'system.adapter.discovery'          â 'discovery'          â '5.0.0'  â 'none'         â
    â 7       â 'system.adapter.eusec'              â 'eusec'              â '1.3.3'  â 'none'         â
    â 8       â 'system.adapter.fullybrowser'       â 'fullybrowser'       â '3.1.5'  â 'none'         â
    â 9       â 'system.adapter.govee-local'        â 'govee-local'        â '0.2.8'  â 'none'         â
    â 10      â 'system.adapter.history'            â 'history'            â '3.0.1'  â 'none'         â
    â 11      â 'system.adapter.ical'               â 'ical'               â '1.16.1' â 'none'         â
    â 12      â 'system.adapter.icons-mfd-svg'      â 'icons-mfd-svg'      â '1.0.2'  â 'none'         â
    â 13      â 'system.adapter.javascript'         â 'javascript'         â '8.9.2'  â 'none'         â
    â 14      â 'system.adapter.lovelace'           â 'lovelace'           â '4.1.15' â 'none'         â
    â 15      â 'system.adapter.meross'             â 'meross'             â '1.17.0' â 'none'         â
    â 16      â 'system.adapter.mqtt'               â 'mqtt'               â '6.1.2'  â 'none'         â
    â 17      â 'system.adapter.mqtt-client'        â 'mqtt-client'        â '1.7.0'  â 'none'         â
    â 18      â 'system.adapter.scenes'             â 'scenes'             â '4.0.4'  â 'none'         â
    â 19      â 'system.adapter.shelly'             â 'shelly'             â '9.5.1'  â 'none'         â
    â 20      â 'system.adapter.socketio'           â 'socketio'           â '6.7.1'  â 'none'         â
    â 21      â 'system.adapter.sonoff'             â 'sonoff'             â '3.0.3'  â 'none'         â
    â 22      â 'system.adapter.sourceanalytix'     â 'sourceanalytix'     â '0.4.14' â 'none'         â
    â 23      â 'system.adapter.spotify-premium'    â 'spotify-premium'    â '1.5.3'  â 'none'         â
    â 24      â 'system.adapter.telegram'           â 'telegram'           â '4.1.0'  â 'none'         â
    â 25      â 'system.adapter.tr-064'             â 'tr-064'             â '4.3.0'  â 'none'         â
    â 26      â 'system.adapter.trashschedule'      â 'trashschedule'      â '3.3.0'  â 'none'         â
    â 27      â 'system.adapter.tuya'               â 'tuya'               â '3.17.0' â 'none'         â
    â 28      â 'system.adapter.weatherunderground' â 'weatherunderground' â '3.7.0'  â 'none'         â
    â 29      â 'system.adapter.web'                â 'web'                â '6.1.10' â 'none'         â
    â 30      â 'system.adapter.wifilight'          â 'wifilight'          â '2.0.3'  â 'none'         â
    â 31      â 'system.adapter.ws'                 â 'ws'                 â '2.6.2'  â 'none'         â
    â 32      â 'system.adapter.yeelight-2'         â 'yeelight-2'         â '1.4.0'  â 'none'         â
    â 33      â 'system.adapter.zigbee'             â 'zigbee'             â '3.4.1'  â 'none'         â
    âââââââââââ´ââââââââââââââââââââââââââââââââââââââ´âââââââââââââââââââââââ´âââââââââââ´âââââââââââââââââioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.6.17 [Updatable]
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.2.2  [Updatable]
    Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
    Adapter    "devices"      : 1.2.14   , installed 1.2.9  [Updatable]
    Adapter    "eusec"        : 2.0.3    , installed 1.3.3  [Updatable]
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.5
    Adapter    "govee-local"  : 0.4.5    , installed 0.2.8  [Updatable]
    Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
    Adapter    "ical"         : 1.20.0   , installed 1.16.1 [Updatable]
    Adapter    "icons-mfd-svg": 1.2.0    , installed 1.0.2  [Updatable]
    Adapter    "javascript"   : 9.0.18   , installed 8.9.2  [Updatable]
    Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
    Adapter    "lovelace"     : 5.0.5    , installed 4.1.15 [Updatable]
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "shelly"       : 10.6.1   , installed 9.5.1  [Updatable]
    Adapter    "simple-api"   : 3.0.7    , installed 2.8.0  [Updatable]
    Adapter    "socketio"     : 7.1.3    , installed 6.6.0  [Updatable]
    Adapter    "sonoff"       : 3.3.0    , installed 3.0.3  [Updatable]
    Adapter    "spotify-premium": 2.0.3  , installed 1.5.3  [Updatable]
    Adapter    "trashschedule": 5.3.0    , installed 3.3.0  [Updatable]
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 8.0.0    , installed 6.1.10 [Updatable]
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "ws"           : 4.0.0    , installed 2.5.8  [Updatable]
    Adapter    "yeelight-2"   : 1.5.2    , installed 1.4.0  [Updatable]
    Adapter    "zigbee"       : 3.3.5    , installed 3.4.1
    Objects and States
    Objects: 	9137
    States: 	7370
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Reading package lists...
    Pending systemupdates: 300
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                          0.0.0.0:56718              0.0.0.0:*    users:(("avahi-daemon",pid=481,fd=14))
    udp   UNCONN 0      0                          0.0.0.0:4002               0.0.0.0:*    users:(("io.govee-local.",pid=1508,fd=32))
    udp   UNCONN 0      0                          0.0.0.0:32938              0.0.0.0:*    users:(("io.eusec.0",pid=1485,fd=31))
    udp   UNCONN 0      0                   192.168.178.76:mdns               0.0.0.0:*    users:(("io.tr-064.1",pid=2072,fd=28))
    udp   UNCONN 0      0                   192.168.178.75:mdns               0.0.0.0:*    users:(("io.tr-064.1",pid=2072,fd=27))
    udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=481,fd=12))
    udp   UNCONN 0      0                          0.0.0.0:5683               0.0.0.0:*    users:(("io.shelly.0",pid=1978,fd=28))
    udp   UNCONN 0      0                          0.0.0.0:6666               0.0.0.0:*    users:(("io.tuya.0",pid=2087,fd=33))
    udp   UNCONN 0      0                          0.0.0.0:6667               0.0.0.0:*    users:(("io.tuya.0",pid=2087,fd=34))
    udp   UNCONN 0      0                                *:36824                    *:*    users:(("avahi-daemon",pid=481,fd=15))
    udp   UNCONN 0      0                                *:8555                     *:*    users:(("go2rtc",pid=1966,fd=9))
    udp   UNCONN 0      0      [fe80::416b:2ff3:8143:a968]:dhcpv6-client            *:*    users:(("NetworkManager",pid=589,fd=38))
    udp   UNCONN 0      0      [fe80::4f85:77ac:fa1b:1b20]:dhcpv6-client            *:*    users:(("NetworkManager",pid=589,fd=36))
    udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=481,fd=13))
    tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=649,fd=25))
    tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=649,fd=19))
    tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=671,fd=3))
    tcp   LISTEN 0      128                      127.0.0.1:ipp                0.0.0.0:*    users:(("cupsd",pid=648,fd=7))
    tcp   LISTEN 0      511                        0.0.0.0:1881               0.0.0.0:*    users:(("io.shelly.2",pid=2023,fd=31))
    tcp   LISTEN 0      511                        0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=2042,fd=32))
    tcp   LISTEN 0      511                        0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.1",pid=2000,fd=29))
    tcp   LISTEN 0      511                        0.0.0.0:38965              0.0.0.0:*    users:(("io.alexa2.0",pid=1394,fd=29))
    tcp   LISTEN 0      2                            [::1]:3350                  [::]:*    users:(("xrdp-sesman",pid=660,fd=11))
    tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=671,fd=4))
    tcp   LISTEN 0      4096                             *:8555                     *:*    users:(("go2rtc",pid=1966,fd=8))
    tcp   LISTEN 0      4096                             *:8554                     *:*    users:(("go2rtc",pid=1966,fd=7))
    tcp   LISTEN 0      4096                             *:1984                     *:*    users:(("go2rtc",pid=1966,fd=6))
    tcp   LISTEN 0      2                                *:ms-wbt-server            *:*    users:(("xrdp",pid=678,fd=11))
    tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=901,fd=30))
    tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=2219,fd=27))
    tcp   LISTEN 0      511                              *:8091                     *:*    users:(("io.lovelace.0",pid=2173,fd=26))
    tcp   LISTEN 0      128                          [::1]:ipp                   [::]:*    users:(("cupsd",pid=648,fd=6))
    2026-06-04 18:08:23.253  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2446 terminated with code 0 (NO_ERROR)
    2026-06-04 18:09:15.021  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 2464
    2026-06-04 18:09:17.681  - info: weatherunderground.0 (2464) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:09:47.196  - info: weatherunderground.0 (2464) Terminated (NO_ERROR): Without reason
    2026-06-04 18:09:47.740  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2464 terminated with code 0 (NO_ERROR)
    2026-06-04 18:10:15.025  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 2479
    2026-06-04 18:10:17.560  - info: weatherunderground.0 (2479) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:10:46.842  - info: weatherunderground.0 (2479) Terminated (NO_ERROR): Without reason
    2026-06-04 18:10:47.382  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2479 terminated with code 0 (NO_ERROR)
    2026-06-04 18:11:15.066  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 2828
    2026-06-04 18:11:18.304  - info: weatherunderground.0 (2828) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:11:50.491  - info: weatherunderground.0 (2828) Terminated (NO_ERROR): Without reason
    2026-06-04 18:11:51.321  - warn: weatherunderground.0 (2828) get state error: Connection is closed.
    2026-06-04 18:11:51.459  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2828 terminated with code 0 (NO_ERROR)
    2026-06-04 18:12:15.065  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 3848
    2026-06-04 18:12:17.447  - info: sonoff.0 (2042) Client [raspberrypi.mqtt.0] connection closed: timeout
    2026-06-04 18:12:17.456  - info: mqtt.0 (1947) Disconnected from 127.0.0.1: undefined
    2026-06-04 18:12:18.501  - info: weatherunderground.0 (3848) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:12:27.456  - info: mqtt.0 (1947) Reconnected to 127.0.0.1
    2026-06-04 18:12:27.462  - info: sonoff.0 (2042) Client [raspberrypi.mqtt.0] connected with secret 1780589547460_63
    2026-06-04 18:12:27.466  - info: mqtt.0 (1947) Connected to 127.0.0.1
    2026-06-04 18:12:27.471  - info: mqtt.0 (1947) Subscribe on "#"
    2026-06-04 18:12:27.471  - info: mqtt.0 (1947) Publishing state mqtt.0.info.connection
    2026-06-04 18:12:27.472  - info: mqtt.0 (1947) Publishing state mqtt.0.info.lastSession
    2026-06-04 18:12:27.481  - info: mqtt.0 (1947) All states published
    ============= Mark until here for C&P =============
    iob diag has finished.
    pi@raspberrypi:~ $
    #176
    Du hast einen
    @tiobb sagte:
    Besorg dir eine neue SD Karte, schreibe darauf das aktuelle RaspberryPi OS LITE,
    Fahre den Pi sauber herunter
    Tausche beide Karten
    Installiere iobroker über den Einzeiler auf der neuen Karte und schiebe das letzte Backup drauf!
    Dann sollte alles sauber laufen.
    Für den eigentlich nicht existierenden Fall dass nicht, hast du noch die alte Karte
    • tiobbT Offline
      tiobbT Offline
      tiobb
      schrieb am zuletzt editiert von tiobb
      #177
      System läuft jetzt wieder sauber.
      Ich habe aber diesen empfindlichen Sourceanalytix Adapter nicht mehr installiert, stattdessen versuche ich gerade das ganze über ein Blockly zu lösen. Könnt ihr mal drüber schauen ob das so funktionieren kann.
      Raspberry Pi 4 8gb
      paul53P Thomas BraunT 2 Antworten Letzte Antwort
      • tiobbT tiobb
        #178
        @tiobb [sagte]: ob das so funktionieren könnte.
        Man kann nicht unmittelbar nach dem Schreiben eines Wertes in einen DP ("Ölverbrauch gesamt") den Wert einlesen, da "aktualisiere" asynchron ausgeführt wird. Erst den Wert für die Variable berechnen und danach den Variablenwert gerundet in den DP schreiben.
        Wo werden die Zählerstände für Woche / Monat / Quartal / Jahr geschrieben?
        Prinzip für Periodenwerte:
        • tiobbT tiobb
          #179
          @tiobb sagte:
          Hast du alles aktualisiert?
          • tiobbT Offline
            tiobbT Offline
            tiobb
            #180
            Oh je, sieht ja mal komplett anders aus wie meins 🫣
            @paul53 sagte:
            @Thomas-Braun sagte:
            Jep
            Raspberry Pi 4 8gb
            • tiobbT tiobb
              @paul53 sagte:
              Jep
              #181
              @tiobb [sagte]: sieht ja mal komplett anders aus wie meins
              Du triggerst auf "Power". Ist das nicht die Leistung?
              • tiobbT Offline
                tiobbT Offline
                tiobb
                #182
                Genau, ich trigger auf power, wenn die Leistung im Heizungskeller über 250W liegt, läuft der Brenner, darunter ist er aus und es wird kein Öl verbraucht
                Raspberry Pi 4 8gb
                • tiobbT tiobb
                  #183
                  @tiobb [sagte: wenn die Leistung im Heizungskeller über 250W liegt, läuft der Brenner
                  Vorschlag:
                  • tiobbT Offline
                    tiobbT Offline
                    tiobb
                    #184
                    So, hat etwas gedauert, sieht jetzt so aus. Wird mir in Lovelace um 00.01 Uhr Wert für den Tag 0 angezeigt? Wenn ich das richtig verstehe wird der Wert vom Vortag mit in den nächsten Tag übernommen und erst geändert wenn die Heizung wieder läuft?
                    Die Verzögerung habe ich raus genommem
                    Raspberry Pi 4 8gb
                    • tiobbT tiobb
                      #185
                      @tiobb [sagte]: erst geändert wenn die Heizung wieder läuft?
                      Die aktuellen Werte werden geschrieben, wenn der Brenner ausschaltet.
                      Die vorherigen Werte sollte man kurz vor Mitternacht (23:59:55) schreiben damit das Datum im Zeitstempel stimmt.
                      • tiobbT Offline
                        tiobbT Offline
                        tiobb
                        #186
                        Das heißt ich muss noch den ganzen Zeit Block von weiter oben über das aktuelle Blockly setzen?
                        Raspberry Pi 4 8gb
                        • tiobbT tiobb
                          #187
                          @tiobb [sagte]: Zeit Block von weiter oben über das aktuelle Blockly setzen?
                          Es kann auch ein eigenes Skript sein, da der Stand ("Oelverbrauch_Gesamt") um 23:59:55 Uhr in eine Variable eingelesen wird.
                          tiobbT 1 Antwort Letzte Antwort
                            tiobbT Offline
                            tiobbT Offline
                            tiobb
                            #188
                            @paul53 sagte:
                            Übersichtlicher wäre es, für mich, alles in einem Script/Blockly zu haben.
                            Diese Lücke im zweiten falls Block bekomme ich nicht nachgebaut 🤷‍♂️
                            Raspberry Pi 4 8gb
                            • tiobbT tiobb
                              @paul53 sagte:
                              #189
                              @tiobb [sagte]: Diese Lücke im zweiten falls Block bekomme ich nicht nachgebaut
                              Du meinst das Prüfen auf Monatsende?
                              <block xmlns="https://developers.google.com/blockly/xml" type="logic_compare" id="X:NUCBE~wf;3IZ}`fy%z" x="1044.0014190673828" y="61">
                               <field name="OP">EQ</field>
                               <value name="A">
                                 <block type="convert_from_date" id="7kzjbZtb:yJ$[SLO8P-g">
                                   <field name="OPTION">d</field>
                                   <value name="VALUE">
                                     <block type="time_calculation" id="~0TGc{Jt;MYk[q@|?n2B">
                                       <field name="OPERATION">+</field>
                                       <value name="DATE_TIME">
                                         <shadow type="time_get" id="Pz^gn;_tc~Qu-3OZ:r7Z">
                                           <field name="OPTION">object</field>
                                         </shadow>
                                       </value>
                                         <shadow type="math_number" id="r3tt4M9TIHNAw~eR]p8C">
                                           <field name="NUM">10</field>
                                         </shadow>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id="2CtP9gDC:OKV)KF.lB40">
                                   <field name="NUM">1</field>
                                 </block>
                               </value>
                              </block>
                              Das Zeitformat zu Silvester ist falsch! Richtig:
                              ... oder du passt den Vergleichswert an:
                              • tiobbT Offline
                                tiobbT Offline
                                tiobb
                                #190
                                Guten Morgen,
                                vielen Dank, ich habe die XML Datei importiert und entsprechend eingebaut, und auch das Zeitformat angepasst. Ich hatte gestern mal für eine Minute die Heizung laufen, aber die Tageswerte, sowie alle dazugehörigen Daten wurden nicht aktualisiert, und heute nach Mitternacht ist dann das Passiert, ein Minusverbrauch von 1208 Litern. Oberer Screenshot noch von gestern, unterer von heute. Was ist denn da passiert, hast Du eine Idee?
                                Raspberry Pi 4 8gb
                                • tiobbT tiobb
                                  Guten Morgen,
                                  #191
                                  @tiobb [sagte]: heute nach Mitternacht ist dann das Passiert, ein Minusverbrauch von 1208 Litern.
                                  Wodurch wurde "Ölverbrauch Gesamt" auf 0,04 l gesetzt? Mit diesem Wert werden die Perodenwerte negativ.
                                  • tiobbT Offline
                                    tiobbT Offline
                                    tiobb
                                    #192
                                    Ich habe keine Ahnung warum fast alles durcheinander geraten ist
                                    So sieht das gesamte Blockly aus
                                    Raspberry Pi 4 8gb
                                    • tiobbT tiobb
                                      #193
                                      @tiobb [sagte: So sieht das gesamte Blockly aus
                                      Ich kann keinen Fehler erkennen. Setze "Ölverbrauch Gesamt" manuell auf einen schlüssigen Wert (1208.5) und korrigiere den Stand um 0:00 Uhr auf den gleichen Wert.
                                      Zum Testen logge mal die Variablen ED und liter_gesamt im unteren Trigger im sonst Zweig.
                                        tiobbT Offline
                                        tiobbT Offline
                                        tiobb
                                        #194
                                        @paul53 sagte:
                                        Um 00:00 Uhr horche ich schon an meiner Matratze 😴, und wie logge ich das?
                                        Ich werde jetzt alle Verbräuche händisch auf die Werte von gestern setzen.
                                        Sieht jetzt wieder so aus
                                        habe die Heizung mal kurz laufen lassen, Ergebnis sieht so aus
                                        Raspberry Pi 4 8gb
                                        • tiobbT tiobb
                                          @paul53 sagte:
                                          #195
                                          @tiobb [sagte]: Heizung mal kurz laufen lassen, Ergebnis sieht so aus
                                          Anscheinend werden die liter_gesamt falsch berechnet? Loggen!
                                          EDIT: Das sieht nach zwei unterschiedlichen Datenpunkten aus:
                                          Bei "Wert von ID" müsste auch der Name "Ölverbrauch Gesamt" angezeigt werden. Auch hier:
