  5. Hilfe bei Blockly
    6.3k
Hilfe bei Blockly
257 Beiträge 7 Kommentatoren 25.0k Aufrufe 4 Beobachtet
  • tiobbT Offline
    tiobbT Offline
    tiobb
    #168
    Bitte nicht meckern wegen fehlender Updates, das hat einen besonderen Grund 🙊
    Script v.2026-06-01
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 387 days ago (on 2025-05-13).
    Systemuptime and Load:
     18:11:03 up 17 min,  2 users,  load average: 0.69, 0.87, 1.04
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-06-04 18:11:03 CEST
               Universal time: Thu 2026-06-04 16:11:03 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio plugdev games users input netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:		X11
    Display-Manager: 	* lightdm.service - Light Display Manager
    Desktop:		LXDE-pi
    Session:		x11
    Boot Target: 		multi-user.target
    *** MEMORY ***
    Mem:            8.2G        2.5G        4.9G         35M        949M        5.7G
    Swap:           536M          0B        536M
    Total:          8.7G        2.5G        5.4G
    Active iob-Instances: 	29
             7809 M total memory
             2412 M used memory
             2517 M active memory
              493 M inactive memory
             4645 M free memory
               62 M buffer memory
              843 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 18:11:04 up 17 min,  2 users,  load average: 0.69, 0.87, 1.04
    Tasks: 243 total,   1 running, 242 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.5 us, 12.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7809.4 total,   4644.5 free,   2413.1 used,    905.5 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5396.3 avail Mem
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * session-1.scope loaded failed failed Session 1 of User pi
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     781M  9.3M  772M   2% /run
    /dev/mmcblk0p2 ext4       58G  9.1G   46G  17% /
    tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   68M  443M  14% /boot/firmware
    tmpfs          tmpfs     781M   44K  781M   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Thu Jun  4 17:53:21 2026] EXT4-fs (mmcblk0p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Quota mode: none.
    [Thu Jun  4 17:53:22 2026] EXT4-fs (mmcblk0p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE            OPTIONS
    /                            /dev/mmcblk0p2 ext4              rw,noatime
    |-/boot/firmware             /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    /var:
    888M	/var/
    204M	/var/lib
    170M	/var/cache
    161M	/var/cache/apt
    144M	/var/lib/apt/lists
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    376M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    581M	/opt/iobroker/iobroker-data/
    420M	/opt/iobroker/iobroker-data/files
    156M	/opt/iobroker/iobroker-data/files/vis-2
    129M	/opt/iobroker/iobroker-data/backup-objects
    89M	/opt/iobroker/iobroker-data/files/vis-2/static
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    21M	/opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
    *** ZigBee Settings ***
    â Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        ...__0X00124B001CDD4A3A-if00        ...__0X00124B001CDD4A3A-if00        â Matching
    *** NodeJS-Installation ***
    /usr/bin/nodejs		v20.19.2
    /usr/bin/node		v20.19.2
    /usr/bin/npm		10.8.2
    /usr/bin/npx		10.8.2
    â Node.js installation is correct
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 20.20.2-1nodesource1
      Version table:
         20.20.2-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.20.1-1nodesource1 600
         20.20.0-1nodesource1 600
         20.19.6-1nodesource1 600
         20.19.5-1nodesource1 600
         20.19.4-1nodesource1 600
         20.19.3-1nodesource1 600
     *** 20.19.2-1nodesource1 600
         20.19.1-1nodesource1 600
         20.19.0-1nodesource1 600
         20.18.3-1nodesource1 600
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.20.4+dfsg-1~deb12u2 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    Vulnerabilities detected in the Node.js version!
    node:fs:2368
        return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        at Object.writeFileSync (node:fs:2368:20)
        at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
        at Object.onceWrapper (node:events:639:26)
        at ClientRequest.emit (node:events:524:28)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:702:27)
        at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
        at TLSSocket.socketOnData (node:_http_client:544:22)
        at TLSSocket.emit (node:events:524:28)
        at addChunk (node:internal/streams/readable:561:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    Node.js v20.19.2
    npm notice
    npm notice New major version of npm available! 10.8.2 -> 11.16.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.16.0
    npm notice To update run: npm install -g npm@11.16.0
    npm notice
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1043)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
    + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : raspberrypi                              -  enabled, port: 1881, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
    + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
    + instance is alive
    ioBroker-Repositories
    âââââââââââ¬âââââââââââ¬ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¬âââââââââââââââ (index) â name     â url                                                     â auto upgrade â
    âââââââââââ¼âââââââââââ¼ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¼âââââââââââââââ¤
    â 0       â 'stable' â 'http://download.iobroker.net/sources-dist.json'        â false        â
    â 1       â 'beta'   â 'http://download.iobroker.net/sources-dist-latest.json' â false        â
    âââââââââââ´âââââââââââ´ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ´âââââââââââââââInstalled ioBroker-Adapters
    âââââââââââ¬ââââââââââââââââââââââââââââââââââââââ¬âââââââââââââââââââââââ¬âââââââââââ¬âââââââââââââââââ (index) â id                                  â name                 â version  â upgrade policy â
    âââââââââââ¼ââââââââââââââââââââââââââââââââââââââ¼âââââââââââââââââââââââ¼âââââââââââ¼âââââââââââââââââ¤
    â 0       â 'system.adapter.admin'              â 'admin'              â '7.6.17' â 'none'         â
    â 1       â 'system.adapter.alexa2'             â 'alexa2'             â '3.27.4' â 'none'         â
    â 2       â 'system.adapter.backitup'           â 'backitup'           â '3.2.2'  â 'none'         â
    â 3       â 'system.adapter.cloud'              â 'cloud'              â '5.0.1'  â 'none'         â
    â 4       â 'system.adapter.daswetter'          â 'daswetter'          â '3.2.3'  â 'none'         â
    â 5       â 'system.adapter.devices'            â 'devices'            â '1.2.9'  â 'none'         â
    â 6       â 'system.adapter.discovery'          â 'discovery'          â '5.0.0'  â 'none'         â
    â 7       â 'system.adapter.eusec'              â 'eusec'              â '1.3.3'  â 'none'         â
    â 8       â 'system.adapter.fullybrowser'       â 'fullybrowser'       â '3.1.5'  â 'none'         â
    â 9       â 'system.adapter.govee-local'        â 'govee-local'        â '0.2.8'  â 'none'         â
    â 10      â 'system.adapter.history'            â 'history'            â '3.0.1'  â 'none'         â
    â 11      â 'system.adapter.ical'               â 'ical'               â '1.16.1' â 'none'         â
    â 12      â 'system.adapter.icons-mfd-svg'      â 'icons-mfd-svg'      â '1.0.2'  â 'none'         â
    â 13      â 'system.adapter.javascript'         â 'javascript'         â '8.9.2'  â 'none'         â
    â 14      â 'system.adapter.lovelace'           â 'lovelace'           â '4.1.15' â 'none'         â
    â 15      â 'system.adapter.meross'             â 'meross'             â '1.17.0' â 'none'         â
    â 16      â 'system.adapter.mqtt'               â 'mqtt'               â '6.1.2'  â 'none'         â
    â 17      â 'system.adapter.mqtt-client'        â 'mqtt-client'        â '1.7.0'  â 'none'         â
    â 18      â 'system.adapter.scenes'             â 'scenes'             â '4.0.4'  â 'none'         â
    â 19      â 'system.adapter.shelly'             â 'shelly'             â '9.5.1'  â 'none'         â
    â 20      â 'system.adapter.socketio'           â 'socketio'           â '6.7.1'  â 'none'         â
    â 21      â 'system.adapter.sonoff'             â 'sonoff'             â '3.0.3'  â 'none'         â
    â 22      â 'system.adapter.sourceanalytix'     â 'sourceanalytix'     â '0.4.14' â 'none'         â
    â 23      â 'system.adapter.spotify-premium'    â 'spotify-premium'    â '1.5.3'  â 'none'         â
    â 24      â 'system.adapter.telegram'           â 'telegram'           â '4.1.0'  â 'none'         â
    â 25      â 'system.adapter.tr-064'             â 'tr-064'             â '4.3.0'  â 'none'         â
    â 26      â 'system.adapter.trashschedule'      â 'trashschedule'      â '3.3.0'  â 'none'         â
    â 27      â 'system.adapter.tuya'               â 'tuya'               â '3.17.0' â 'none'         â
    â 28      â 'system.adapter.weatherunderground' â 'weatherunderground' â '3.7.0'  â 'none'         â
    â 29      â 'system.adapter.web'                â 'web'                â '6.1.10' â 'none'         â
    â 30      â 'system.adapter.wifilight'          â 'wifilight'          â '2.0.3'  â 'none'         â
    â 31      â 'system.adapter.ws'                 â 'ws'                 â '2.6.2'  â 'none'         â
    â 32      â 'system.adapter.yeelight-2'         â 'yeelight-2'         â '1.4.0'  â 'none'         â
    â 33      â 'system.adapter.zigbee'             â 'zigbee'             â '3.4.1'  â 'none'         â
    âââââââââââ´ââââââââââââââââââââââââââââââââââââââ´âââââââââââââââââââââââ´âââââââââââ´âââââââââââââââââioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.6.17 [Updatable]
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.2.2  [Updatable]
    Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
    Adapter    "devices"      : 1.2.14   , installed 1.2.9  [Updatable]
    Adapter    "eusec"        : 2.0.3    , installed 1.3.3  [Updatable]
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.5
    Adapter    "govee-local"  : 0.4.5    , installed 0.2.8  [Updatable]
    Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
    Adapter    "ical"         : 1.20.0   , installed 1.16.1 [Updatable]
    Adapter    "icons-mfd-svg": 1.2.0    , installed 1.0.2  [Updatable]
    Adapter    "javascript"   : 9.0.18   , installed 8.9.2  [Updatable]
    Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
    Adapter    "lovelace"     : 5.0.5    , installed 4.1.15 [Updatable]
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "shelly"       : 10.6.1   , installed 9.5.1  [Updatable]
    Adapter    "simple-api"   : 3.0.7    , installed 2.8.0  [Updatable]
    Adapter    "socketio"     : 7.1.3    , installed 6.6.0  [Updatable]
    Adapter    "sonoff"       : 3.3.0    , installed 3.0.3  [Updatable]
    Adapter    "spotify-premium": 2.0.3  , installed 1.5.3  [Updatable]
    Adapter    "trashschedule": 5.3.0    , installed 3.3.0  [Updatable]
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 8.0.0    , installed 6.1.10 [Updatable]
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "ws"           : 4.0.0    , installed 2.5.8  [Updatable]
    Adapter    "yeelight-2"   : 1.5.2    , installed 1.4.0  [Updatable]
    Adapter    "zigbee"       : 3.3.5    , installed 3.4.1
    Objects and States
    Objects: 	9137
    States: 	7370
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Reading package lists...
    Pending systemupdates: 300
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                          0.0.0.0:56718              0.0.0.0:*    users:(("avahi-daemon",pid=481,fd=14))
    udp   UNCONN 0      0                          0.0.0.0:4002               0.0.0.0:*    users:(("io.govee-local.",pid=1508,fd=32))
    udp   UNCONN 0      0                          0.0.0.0:32938              0.0.0.0:*    users:(("io.eusec.0",pid=1485,fd=31))
    udp   UNCONN 0      0                   192.168.178.76:mdns               0.0.0.0:*    users:(("io.tr-064.1",pid=2072,fd=28))
    udp   UNCONN 0      0                   192.168.178.75:mdns               0.0.0.0:*    users:(("io.tr-064.1",pid=2072,fd=27))
    udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=481,fd=12))
    udp   UNCONN 0      0                          0.0.0.0:5683               0.0.0.0:*    users:(("io.shelly.0",pid=1978,fd=28))
    udp   UNCONN 0      0                          0.0.0.0:6666               0.0.0.0:*    users:(("io.tuya.0",pid=2087,fd=33))
    udp   UNCONN 0      0                          0.0.0.0:6667               0.0.0.0:*    users:(("io.tuya.0",pid=2087,fd=34))
    udp   UNCONN 0      0                                *:36824                    *:*    users:(("avahi-daemon",pid=481,fd=15))
    udp   UNCONN 0      0                                *:8555                     *:*    users:(("go2rtc",pid=1966,fd=9))
    udp   UNCONN 0      0      [fe80::416b:2ff3:8143:a968]:dhcpv6-client            *:*    users:(("NetworkManager",pid=589,fd=38))
    udp   UNCONN 0      0      [fe80::4f85:77ac:fa1b:1b20]:dhcpv6-client            *:*    users:(("NetworkManager",pid=589,fd=36))
    udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=481,fd=13))
    tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=649,fd=25))
    tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=649,fd=19))
    tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=671,fd=3))
    tcp   LISTEN 0      128                      127.0.0.1:ipp                0.0.0.0:*    users:(("cupsd",pid=648,fd=7))
    tcp   LISTEN 0      511                        0.0.0.0:1881               0.0.0.0:*    users:(("io.shelly.2",pid=2023,fd=31))
    tcp   LISTEN 0      511                        0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=2042,fd=32))
    tcp   LISTEN 0      511                        0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.1",pid=2000,fd=29))
    tcp   LISTEN 0      511                        0.0.0.0:38965              0.0.0.0:*    users:(("io.alexa2.0",pid=1394,fd=29))
    tcp   LISTEN 0      2                            [::1]:3350                  [::]:*    users:(("xrdp-sesman",pid=660,fd=11))
    tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=671,fd=4))
    tcp   LISTEN 0      4096                             *:8555                     *:*    users:(("go2rtc",pid=1966,fd=8))
    tcp   LISTEN 0      4096                             *:8554                     *:*    users:(("go2rtc",pid=1966,fd=7))
    tcp   LISTEN 0      4096                             *:1984                     *:*    users:(("go2rtc",pid=1966,fd=6))
    tcp   LISTEN 0      2                                *:ms-wbt-server            *:*    users:(("xrdp",pid=678,fd=11))
    tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=901,fd=30))
    tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=2219,fd=27))
    tcp   LISTEN 0      511                              *:8091                     *:*    users:(("io.lovelace.0",pid=2173,fd=26))
    tcp   LISTEN 0      128                          [::1]:ipp                   [::]:*    users:(("cupsd",pid=648,fd=6))
    2026-06-04 18:08:23.253  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2446 terminated with code 0 (NO_ERROR)
    2026-06-04 18:09:15.021  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 2464
    2026-06-04 18:09:17.681  - info: weatherunderground.0 (2464) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:09:47.196  - info: weatherunderground.0 (2464) Terminated (NO_ERROR): Without reason
    2026-06-04 18:09:47.740  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2464 terminated with code 0 (NO_ERROR)
    2026-06-04 18:10:15.025  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 2479
    2026-06-04 18:10:17.560  - info: weatherunderground.0 (2479) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:10:46.842  - info: weatherunderground.0 (2479) Terminated (NO_ERROR): Without reason
    2026-06-04 18:10:47.382  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2479 terminated with code 0 (NO_ERROR)
    2026-06-04 18:11:15.066  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 2828
    2026-06-04 18:11:18.304  - info: weatherunderground.0 (2828) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:11:50.491  - info: weatherunderground.0 (2828) Terminated (NO_ERROR): Without reason
    2026-06-04 18:11:51.321  - warn: weatherunderground.0 (2828) get state error: Connection is closed.
    2026-06-04 18:11:51.459  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2828 terminated with code 0 (NO_ERROR)
    2026-06-04 18:12:15.065  - info: host.raspberrypi instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 3848
    2026-06-04 18:12:17.447  - info: sonoff.0 (2042) Client [raspberrypi.mqtt.0] connection closed: timeout
    2026-06-04 18:12:17.456  - info: mqtt.0 (1947) Disconnected from 127.0.0.1: undefined
    2026-06-04 18:12:18.501  - info: weatherunderground.0 (3848) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.19.2, js-controller: 7.0.6
    2026-06-04 18:12:27.456  - info: mqtt.0 (1947) Reconnected to 127.0.0.1
    2026-06-04 18:12:27.462  - info: sonoff.0 (2042) Client [raspberrypi.mqtt.0] connected with secret 1780589547460_63
    2026-06-04 18:12:27.466  - info: mqtt.0 (1947) Connected to 127.0.0.1
    2026-06-04 18:12:27.471  - info: mqtt.0 (1947) Subscribe on "#"
    2026-06-04 18:12:27.471  - info: mqtt.0 (1947) Publishing state mqtt.0.info.connection
    2026-06-04 18:12:27.472  - info: mqtt.0 (1947) Publishing state mqtt.0.info.lastSession
    2026-06-04 18:12:27.481  - info: mqtt.0 (1947) All states published
    ============= Mark until here for C&P =============
    iob diag has finished.
    pi@raspberrypi:~ $
    Raspberry Pi 4 8gb
    • tiobbT tiobb
      Script v.2026-06-01
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Display-Server:		X11
      Desktop:		LXDE-pi
      Session:		x11
      *** MEMORY ***
      Swap:           536M          0B        536M
               7809 M total memory
               2412 M used memory
               4645 M free memory
                 62 M buffer memory
                843 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      888M	/var/
      204M	/var/lib
      170M	/var/cache
      161M	/var/cache/apt
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm		10.8.2
      /usr/bin/npx		10.8.2
      nodejs:
        Version table:
      node:fs:2368
        errno: -13,
        code: 'EACCES',
        syscall: 'open',
      Node.js v20.19.2
      npm notice
      npm notice
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.6.17
      javascript: 	8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	9137
      States: 	7370
      pi@raspberrypi:~ $
      #169
      @tiobb sagte:
      Da gibt es keinen. Updaten...
      Debian GNU/Linux 12 (bookworm)
      Auf Debian 13 'Trixie' bringen. Jetzt.
      Desktop-Geraffel ausschalten.
      nodejs@22 verwenden.
      Die ganzen ioBroker-Adapter auf Stand bringen.
      OS auch, bzw. bringst du das ja eh jetzt auf Debian 13.
        @tiobb sagte:
        Hab ich erledigt, alle Instanzen laufen, außer Sourceanalytix
        Klar doch!
        Steht alles im log!
        @tiobb sagte:
        host.raspberrypi 2026-06-04 16:22:21.824 error iobroker npm-install: adapter "sourceanalytix" cannot be installed: Unknown packet name sourceanalytix. Please install packages from outside the repository using "iobroker url <url-or-package>"!
        Du hast sourceanalytix noch gar nicht installiert.
        Im Backup sind lediglich die Instanzenkonfigurationen
        tiobbT Offline
        tiobbT Offline
        tiobb
        #170
        @Homoran sagte:
        Und warum laufen alle anderen Instanzen 🤔
        Raspberry Pi 4 8gb
        • tiobbT tiobb
          @Homoran sagte:
          #171
          @tiobb sagte:
          Weil die aus dem stable-Repo installierbar sind, im Gegensatz zum ewigen Beta-Adapter 'sourceanalytix'.
          • tiobbT Offline
            tiobbT Offline
            tiobb
            #172
            wie bekomme ich die jetzt installiert, wenn ich nach Sourceanalytix suche, wird nichts angezeigt?
            Raspberry Pi 4 8gb
            • tiobbT tiobb
              #173
              @tiobb
              Zuerst bringst du die Großbaustelle auf den aktuellen Stand.
              tiobbT 1 Antwort Letzte Antwort
                @tiobb
                tiobbT Offline
                tiobbT Offline
                tiobb
                schrieb am zuletzt editiert von tiobb
                #174
                @Thomas-Braun sagte:
                Wenn ich das mache, weiß ich zu 100 Prozent, dass dann gar nichts mehr läuft, und ich dann eine Woche brauche bis alles wieder läuft, sind Erfahrungen die ich leider machen musste. Aktualisiere ich eine Instanz, funktioniert danach nichts mehr, wie gerade bei einem User hier, der Lovelace aktualisiert hat, und danach liefen seine BubbleCards nicht mehr. Kannst Du mir bitte ohne Aktualisierung der der Adapter helfen?
                Für heute muss ich erstmal abbrechen, morgen kann ich wieder weitermachen, trotzdem erstmal vielen Dank!!!
                Raspberry Pi 4 8gb
                • tiobbT tiobb
                  #175
                  @tiobb sagte:
                  Nein.
                  Never-tatsch-a-running-System ist ganz großer Blödsinn und wird von mir nicht unterstützt.
                  Bring deinen Kram auf Stand. Angefangen beim Betriebssystem, über nodejs hinzu den ioBroker-Adaptern.
                  • tiobbT tiobb
                    Script v.2026-06-01
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64bit
                    CPU threads     : 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    iobroker
                    HOME=/home/iobroker
                    Display-Server:		X11
                    Desktop:		LXDE-pi
                    Session:		x11
                    *** MEMORY ***
                    Swap:           536M          0B        536M
                             7809 M total memory
                             2412 M used memory
                             4645 M free memory
                               62 M buffer memory
                              843 M swap cache
                              511 M total swap
                                0 M used swap
                              511 M free swap
                    *** FILESYSTEM ***
                    /var:
                    888M	/var/
                    204M	/var/lib
                    170M	/var/cache
                    161M	/var/cache/apt
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm		10.8.2
                    /usr/bin/npx		10.8.2
                    nodejs:
                      Version table:
                    node:fs:2368
                      errno: -13,
                      code: 'EACCES',
                      syscall: 'open',
                    Node.js v20.19.2
                    npm notice
                    npm notice
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin: 		7.6.17
                    javascript: 	8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects: 	9137
                    States: 	7370
                    pi@raspberrypi:~ $
                    #176
                    Du hast einen
                    @tiobb sagte:
                    Besorg dir eine neue SD Karte, schreibe darauf das aktuelle RaspberryPi OS LITE,
                    Fahre den Pi sauber herunter
                    Tausche beide Karten
                    Installiere iobroker über den Einzeiler auf der neuen Karte und schiebe das letzte Backup drauf!
                    Dann sollte alles sauber laufen.
                    Für den eigentlich nicht existierenden Fall dass nicht, hast du noch die alte Karte
                    • tiobbT Offline
                      tiobbT Offline
                      tiobb
                      #177
                      System läuft jetzt wieder sauber.
                      Ich habe aber diesen empfindlichen Sourceanalytix Adapter nicht mehr installiert, stattdessen versuche ich gerade das ganze über ein Blockly zu lösen. Könnt ihr mal drüber schauen ob das so funktionieren kann.
                      Raspberry Pi 4 8gb
                      paul53P Thomas BraunT 2 Antworten Letzte Antwort
                      • tiobbT tiobb
                        #178
                        @tiobb [sagte]: ob das so funktionieren könnte.
                        Man kann nicht unmittelbar nach dem Schreiben eines Wertes in einen DP ("Ölverbrauch gesamt") den Wert einlesen, da "aktualisiere" asynchron ausgeführt wird. Erst den Wert für die Variable berechnen und danach den Variablenwert gerundet in den DP schreiben.
                        Wo werden die Zählerstände für Woche / Monat / Quartal / Jahr geschrieben?
                        Prinzip für Periodenwerte:
                        • tiobbT tiobb
                          #179
                          @tiobb sagte:
                          Hast du alles aktualisiert?
                          • tiobbT Offline
                            tiobbT Offline
                            tiobb
                            #180
                            Oh je, sieht ja mal komplett anders aus wie meins 🫣
                            @paul53 sagte:
                            Jep
                            Raspberry Pi 4 8gb
                            • tiobbT tiobb
                              @paul53 sagte:
                              Jep
                              #181
                              @tiobb [sagte]: sieht ja mal komplett anders aus wie meins
                              Du triggerst auf "Power". Ist das nicht die Leistung?
                              • tiobbT Offline
                                tiobbT Offline
                                tiobb
                                #182
                                Genau, ich trigger auf power, wenn die Leistung im Heizungskeller über 250W liegt, läuft der Brenner, darunter ist er aus und es wird kein Öl verbraucht
                                Raspberry Pi 4 8gb
                                • tiobbT tiobb
                                  #183
                                  @tiobb [sagte: wenn die Leistung im Heizungskeller über 250W liegt, läuft der Brenner
                                  Vorschlag:
                                  • tiobbT Offline
                                    tiobbT Offline
                                    tiobb
                                    #184
                                    So, hat etwas gedauert, sieht jetzt so aus. Wird mir in Lovelace um 00.01 Uhr Wert für den Tag 0 angezeigt? Wenn ich das richtig verstehe wird der Wert vom Vortag mit in den nächsten Tag übernommen und erst geändert wenn die Heizung wieder läuft?
                                    Die Verzögerung habe ich raus genommem
                                    Raspberry Pi 4 8gb
                                    • tiobbT tiobb
                                      #185
                                      @tiobb [sagte]: erst geändert wenn die Heizung wieder läuft?
                                      Die aktuellen Werte werden geschrieben, wenn der Brenner ausschaltet.
                                      Die vorherigen Werte sollte man kurz vor Mitternacht (23:59:55) schreiben damit das Datum im Zeitstempel stimmt.
                                      • tiobbT Offline
                                        tiobbT Offline
                                        tiobb
                                        #186
                                        Das heißt ich muss noch den ganzen Zeit Block von weiter oben über das aktuelle Blockly setzen?
                                        Raspberry Pi 4 8gb
                                        • tiobbT tiobb
                                          #187
                                          @tiobb [sagte]: Zeit Block von weiter oben über das aktuelle Blockly setzen?
                                          Es kann auch ein eigenes Skript sein, da der Stand ("Oelverbrauch_Gesamt") um 23:59:55 Uhr in eine Variable eingelesen wird.
