  3. Off Topic
  4. Docker
  5. Admin lässt sich unter DOCKER nicht updaten
Geplant Angeheftet Gesperrt Verschoben Docker
80 Beiträge 11 Kommentatoren 5.5k Aufrufe 4 Beobachtet
Dieses Thema wurde aufgespalten von Admin-Adapter - aktuelle Version? Homoran
  • J juggi1962
    @Thomas-Braun sagte:
    @juggi1962
    Und lass keine Instanzen dauerhaft im Debug-Loglevel laufen.
    wenn du Depug vom Admin adapter meinst den habe ich nur gerade zuvor mal eingeschalten
    hier das was Putty ausgespuckt hat
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Hardware Vendor : Synology Inc.
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v11.1.0
    Virtualization  : docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     12:32:18 up 37 days, 54 min,  0 user,  load average: 1.10, 0.96, 0.89
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
    Sun May 31 10:32:18 UTC 2026
    Sun May 31 12:32:18 CEST 2026
    CEST +0200
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    sudo: unable to resolve host Buanet-iobroker-final-1: No address associated with hostname
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    System has not been booted with systemd as init system (PID 1). Can't operate.
    Failed to connect to bus: Host is down
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            8.3G        6.2G        634M        194M        2.5G        2.1G
    Swap:           7.1G        2.5G        4.6G
    Total:           15G        8.7G        5.3G
    Active iob-Instances:   34
             7916 M total memory
             5933 M used memory
             3215 M active memory
             2536 M inactive memory
              604 M free memory
               26 M buffer memory
             2338 M swap cache
             6797 M total swap
             2390 M used swap
             4407 M free swap
    top - 12:32:18 up 37 days, 54 min,  0 user,  load average: 1.10, 0.96, 0.89
    Tasks:  42 total,   1 running,  41 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7916.3 total,    602.9 free,   5935.1 used,   2365.7 buff/cache
    MiB Swap:   6797.9 total,   4407.6 free,   2390.3 used.   1981.2 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_0 btrfs   11T  2.0T  8.6T  19% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  3.9G     0  3.9G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 btrfs   11T  2.0T  8.6T  19% /opt/iobroker
    /dev/mapper/cachedev_0 btrfs   11T  2.0T  8.6T  19% /etc/hosts
    Show mounted filesystems:
    TARGET                                     SOURCE        FSTYPE OPTIONS
    /                                          /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/7f3ca3ebe289692f6875b4d22785696de6148f5e8df6478e6519b7a7428bacb8]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=4375,subvol=/@syno/@docker/btrfs/subvolumes/7f3ca3ebe289692f6875b4d22785696de6148f5e8df6478e6519b7a7428bacb8
    |-/opt/iobroker                            /dev/mapper/cachedev_0[/@syno/docker/iobroker_neu]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=271,subvol=/@syno/docker
    | |-/opt/iobroker/ipcam/motioneye_terrasse /dev/mapper/cachedev_0[/@syno/docker/motioneye_terrasse]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=271,subvol=/@syno/docker
    | `-/opt/iobroker/ipcam/motioneye_eingang  /dev/mapper/cachedev_0[/@syno/docker/motioneye_eingang]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=271,subvol=/@syno/docker
    |-/etc/resolv.conf                         /dev/mapper/cachedev_0[/@syno/@docker/containers/8f304bdba0c9762c6ed16ce60077181720ee92108c1340f4acdb2cfadc59291b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
    |-/etc/hostname                            /dev/mapper/cachedev_0[/@syno/@docker/containers/8f304bdba0c9762c6ed16ce60077181720ee92108c1340f4acdb2cfadc59291b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
    `-/etc/hosts                               /dev/mapper/cachedev_0[/@syno/@docker/containers/8f304bdba0c9762c6ed16ce60077181720ee92108c1340f4acdb2cfadc59291b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
    /var:
    35M     /var/
    33M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    14M     /var/lib/dpkg
    /opt/iobroker/backups:
    613M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    556M    /opt/iobroker/iobroker-data/files
    274M    /opt/iobroker/iobroker-data/history
    163M    /opt/iobroker/iobroker-data/backup-objects
    150M    /opt/iobroker/iobroker-data/files/vis-2
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/states.jsonl
    18M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-Rz8ETF2t.js
    11M     /opt/iobroker/iobroker-data/files/vis.0/Wohnung/vis-views.json
    11M     /opt/iobroker/iobroker-data/files/vis-2.0/Wohnung/vis-views.json
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u2 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    Temp directories causing deletion problem: 34
    Some problems detected, please run iob fix
    Errors in npm tree: 0
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Buanet-iobroker-final-1 Buanet-iobroker-final-1 (version: 7.0.7, hostname: Buanet-iobroker-final-1, alive, uptime: 170109)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     7
    +-- iobroker.flot@1.12.0 (git+ssh://git@github.com/ioBroker/ioBroker.flot.git#3fbdbcf0b10608766542321563277139057babba)
    +-- iobroker.libre@0.1.4 (git+ssh://git@github.com/TA2k/ioBroker.libre.git#49ae3f2f305f5684d72233d1120abf35831220d3)
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.viessmannapi@2.4.4 (git+ssh://git@github.com/TA2k/ioBroker.viessmannapi.git#6181ab8a2a820b718d64e6c784a2d5f78e4d8e9d)
    +-- iobroker.vis-justgage@2.1.7 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.vis-justgage.git#86e183acccd62100965331f9cb5d8e63c97297c5)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.admin.0                  : admin                 : Buanet-iobroker-final-1                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alarm.0                  : alarm                 : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.alexa2.0                 : alexa2                : Buanet-iobroker-final-1                  -  enabled
      system.adapter.alias-manager.0          : alias-manager         : Buanet-iobroker-final-1                  - disabled
    + system.adapter.backitup.0               : backitup              : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.cloud.0                  : cloud                 : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.discovery.0              : discovery             : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Buanet-iobroker-final-1                  -  enabled
    + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Buanet-iobroker-final-1                  -  enabled
      system.adapter.flexcharts.0             : flexcharts            : Buanet-iobroker-final-1                  -  enabled
      system.adapter.flot.0                   : flot                  : Buanet-iobroker-final-1                  - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.history.0                : history               : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.hue.0                    : hue                   : Buanet-iobroker-final-1                  -  enabled, port: 443
    + system.adapter.iot.0                    : iot                   : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.javascript.0             : javascript            : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.libre.0                  : libre                 : Buanet-iobroker-final-1                  -  enabled
      system.adapter.matter.0                 : matter                : Buanet-iobroker-final-1                  - disabled
      system.adapter.modbus.0                 : modbus                : Buanet-iobroker-final-1                  - disabled
    + system.adapter.mqtt.0                   : mqtt                  : Buanet-iobroker-final-1                  -  enabled, port: 1883, bind: 192.168.1.33
    + system.adapter.myenergi.0               : myenergi              : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.netatmo.0                : netatmo               : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.node-red.0               : node-red              : Buanet-iobroker-final-1                  -  enabled, port: 1880, bind: 192.168.1.33
    + system.adapter.ping.0                   : ping                  : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.places.0                 : places                : Buanet-iobroker-final-1                  -  enabled
      system.adapter.pushover.0               : pushover              : Buanet-iobroker-final-1                  - disabled
    + system.adapter.radar2.0                 : radar2                : Buanet-iobroker-final-1                  -  enabled
      system.adapter.rpi2.0                   : rpi2                  : Buanet-iobroker-final-1                  - disabled
    + system.adapter.shelly.0                 : shelly                : Buanet-iobroker-final-1                  -  enabled, port: 1882, bind: 192.168.1.33
    + system.adapter.simple-api.0             : simple-api            : Buanet-iobroker-final-1                  -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.sonos.0                  : sonos                 : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.sun2000.0                : sun2000               : Buanet-iobroker-final-1                  -  enabled, port: 502
      system.adapter.synology.0               : synology              : Buanet-iobroker-final-1                  - disabled, port: 50000
      system.adapter.synology.1               : synology              : Buanet-iobroker-final-1                  - disabled, port: 50000
    + system.adapter.telegram.0               : telegram              : Buanet-iobroker-final-1                  -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : Buanet-iobroker-final-1                  - disabled
      system.adapter.tuya.0                   : tuya                  : Buanet-iobroker-final-1                  - disabled
    + system.adapter.viessmannapi.0           : viessmannapi          : Buanet-iobroker-final-1                  -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-2-widgets-ovarious.0 : vis-2-widgets-ovarious: Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-2-widgets-rssfeed.0  : vis-2-widgets-rssfeed : Buanet-iobroker-final-1                  - disabled
    + system.adapter.vis-2.0                  : vis-2                 : Buanet-iobroker-final-1                  -  enabled
      system.adapter.vis-bars.0               : vis-bars              : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-history.0            : vis-history           : Buanet-iobroker-final-1                  - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : Buanet-iobroker-final-1                  -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-map.0                : vis-map               : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Buanet-iobroker-final-1                  - disabled
      system.adapter.vis.0                    : vis                   : Buanet-iobroker-final-1                  -  enabled
    + system.adapter.web.0                    : web                   : Buanet-iobroker-final-1                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zwavews.0                : zwavews               : Buanet-iobroker-final-1                  -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.7.22 [Updatable]
    Adapter    "alarm"        : 3.7.6    , installed 3.7.6
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "flexcharts"   : 0.7.2    , installed 0.7.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "matter"       : 0.5.6    , installed 0.5.6
    Adapter    "modbus"       : 8.0.3    , installed 8.0.3
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "node-red"     : 6.0.7    , installed 6.0.7
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "places"       : 1.4.0    , installed 1.4.0
    Adapter    "pushover"     : 5.0.0    , installed 5.0.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "sun2000"      : 2.4.5    , installed 2.4.5
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "vis-2"        : 2.13.8   , installed 2.13.19
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
    Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
    Adapter    "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
    Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.6
    Adapter    "vis-2-widgets-ovarious": 2.0.0, installed 2.0.0
    Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
    Adapter    "vis-2-widgets-rssfeed": 1.2.2, installed 1.2.2
    Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
    Adapter    "vis-inventwo" : 4.1.0    , installed 3.3.5  [Updatable]
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zwavews"      : 0.2.1    , installed 0.2.1
    Objects and States
    Objects:        58513
    States:         49446
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 7
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          44347      -
    tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          32134      -
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27421      -
    tcp        0      0 192.168.1.33:1880       0.0.0.0:*               LISTEN      1000       188489548  28994/node-red
    tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         86931      -
    tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          27236      -
    tcp        0      0 192.168.1.33:1882       0.0.0.0:*               LISTEN      1000       180379022  755/io.shelly.0
    tcp        0      0 192.168.1.33:1883       0.0.0.0:*               LISTEN      1000       180377745  588/io.mqtt.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          42487      -
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          42486      -
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          42485      -
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          42465      -
    tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          31132      -
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          45960      -
    tcp        0      0 192.168.1.33:1502       0.0.0.0:*               LISTEN      1000       180379204  817/io.sun2000.0
    tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          203197     -
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          46552      -
    tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          37530      -
    tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          184121331  -
    tcp        0      0 0.0.0.0:5510            0.0.0.0:*               LISTEN      192868     97469      -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       180371823  137/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       180371811  137/iobroker.js-con
    tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN      0          84598      -
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          45961      -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          174136398  -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          174136397  -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          174136396  -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          174136394  -
    tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          46572      -
    tcp        0      0 0.0.0.0:49999           0.0.0.0:*               LISTEN      0          42469      -
    tcp        0      0 0.0.0.0:49999           0.0.0.0:*               LISTEN      0          42468      -
    tcp        0      0 0.0.0.0:49999           0.0.0.0:*               LISTEN      0          42467      -
    tcp        0      0 0.0.0.0:49999           0.0.0.0:*               LISTEN      0          42459      -
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23916      -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          42481      -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          42480      -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          42479      -
    tcp        0      0 0.0.0.0:50000           0.0.0.0:*               LISTEN      0          42475      -
    tcp        0      0 0.0.0.0:50000           0.0.0.0:*               LISTEN      0          42474      -
    tcp        0      0 0.0.0.0:50000           0.0.0.0:*               LISTEN      0          42473      -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          42463      -
    tcp        0      0 0.0.0.0:50000           0.0.0.0:*               LISTEN      0          42461      -
    tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN      0          149984     -
    tcp6       0      0 :::21                   :::*                    LISTEN      0          44348      -
    tcp6       0      0 :::662                  :::*                    LISTEN      0          32138      -
    tcp6       0      0 :::22                   :::*                    LISTEN      0          27428      -
    tcp6       0      0 :::3000                 :::*                    LISTEN      0          174761439  -
    tcp6       0      0 :::8089                 :::*                    LISTEN      1000       180380576  1006/io.simple-api.
    tcp6       0      0 :::8091                 :::*                    LISTEN      0          174761364  -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          42490      -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          42489      -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          42488      -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          42466      -
    tcp6       0      0 :::892                  :::*                    LISTEN      0          31136      -
    tcp6       0      0 :::3261                 :::*                    LISTEN      0          50504      -
    tcp6       0      0 :::445                  :::*                    LISTEN      0          45958      -
    tcp6       0      0 :::3263                 :::*                    LISTEN      0          50503      -
    tcp6       0      0 :::1984                 :::*                    LISTEN      0          115689458  -
    tcp6       0      0 :::3264                 :::*                    LISTEN      0          50506      -
    tcp6       0      0 :::3265                 :::*                    LISTEN      0          54004      -
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          46563      -
    tcp6       0      0 :::6690                 :::*                    LISTEN      0          184121332  -
    tcp6       0      0 :::5510                 :::*                    LISTEN      192868     97470      -
    tcp6       0      0 :::6281                 :::*                    LISTEN      0          73660      -
    tcp6       0      0 :::8554                 :::*                    LISTEN      0          115690446  -
    tcp6       0      0 :::8555                 :::*                    LISTEN      0          115690452  -
    tcp6       0      0 :::139                  :::*                    LISTEN      0          45959      -
    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       180380021  783/io.sonos.0
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          174136401  -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          174136400  -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          174136399  -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          174136395  -
    tcp6       0      0 :::4045                 :::*                    LISTEN      0          46574      -
    tcp6       0      0 :::1935                 :::*                    LISTEN      233155     82542      -
    tcp6       0      0 :::49999                :::*                    LISTEN      0          42472      -
    tcp6       0      0 :::49999                :::*                    LISTEN      0          42471      -
    tcp6       0      0 :::49999                :::*                    LISTEN      0          42470      -
    tcp6       0      0 :::49999                :::*                    LISTEN      0          42460      -
    tcp6       0      0 :::111                  :::*                    LISTEN      0          23919      -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          42484      -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          42483      -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          42482      -
    tcp6       0      0 :::50000                :::*                    LISTEN      0          42478      -
    tcp6       0      0 :::50000                :::*                    LISTEN      0          42477      -
    tcp6       0      0 :::50000                :::*                    LISTEN      0          42476      -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          42464      -
    tcp6       0      0 :::50000                :::*                    LISTEN      0          42462      -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       188613792  30989/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       180382450  1120/io.web.0
    udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          31130      -
    udp        0      0 0.0.0.0:54219           0.0.0.0:*                           0          188865485  -
    udp        0      0 0.0.0.0:37913           0.0.0.0:*                           0          188605907  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          188864361  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          188612270  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          188613074  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          188606551  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          188605086  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          174758471  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          174758470  -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          147558302  -
    udp        0      0 0.0.0.0:50490           0.0.0.0:*                           0          188605088  -
    udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          25292      -
    udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          25291      -
    udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          25290      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          174134099  -
    udp        0      0 0.0.0.0:55206           0.0.0.0:*                           0          188613076  -
    udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          46562      -
    udp        0      0 0.0.0.0:59944           0.0.0.0:*                           0          188864363  -
    udp        0      0 0.0.0.0:51759           0.0.0.0:*                           0          188865484  -
    udp        0      0 0.0.0.0:43580           0.0.0.0:*                           0          188609419  -
    udp        0      0 0.0.0.0:52624           0.0.0.0:*                           0          188612272  -
    udp        0      0 0.0.0.0:36266           0.0.0.0:*                           0          188611528  -
    udp        0      0 0.0.0.0:19996           0.0.0.0:*                           233155     81881      -
    udp        0      0 0.0.0.0:19997           0.0.0.0:*                           233155     81880      -
    udp        0      0 0.0.0.0:19998           0.0.0.0:*                           233155     81879      -
    udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         174134778  -
    udp        0      0 0.0.0.0:57258           0.0.0.0:*                           0          23915      -
    udp        0      0 0.0.0.0:36790           0.0.0.0:*                           0          188606540  -
    udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          46571      -
    udp        0      0 0.0.0.0:53229           0.0.0.0:*                           0          188613083  -
    udp        0      0 0.0.0.0:40976           0.0.0.0:*                           0          147558304  -
    udp        0      0 0.0.0.0:53280           0.0.0.0:*                           0          188606553  -
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       180377879  711/io.radar2.0
    udp    87040      0 0.0.0.0:68              0.0.0.0:*                           0          24997      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          27029      -
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23914      -
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          30442      -
    udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          174132678  -
    udp        0      0 192.168.1.33:137        0.0.0.0:*                           0          174132677  -
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          174132655  -
    udp        0      0 0.0.0.0:32906           0.0.0.0:*                           0          184122194  -
    udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          174132680  -
    udp        0      0 192.168.1.33:138        0.0.0.0:*                           0          174132679  -
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          174132656  -
    udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          37529      -
    udp        0      0 0.0.0.0:37080           0.0.0.0:*                           0          188609421  -
    udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          30440      -
    udp        0      0 169.254.191.38:8555     0.0.0.0:*                           0          115690461  -
    udp        0      0 172.17.0.1:8555         0.0.0.0:*                           0          115690460  -
    udp        0      0 169.254.31.192:8555     0.0.0.0:*                           0          115690459  -
    udp        0      0 192.168.1.33:8555       0.0.0.0:*                           0          115690458  -
    udp        0      0 0.0.0.0:33142           0.0.0.0:*                           0          188606559  -
    udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          32132      -
    udp        0      0 0.0.0.0:45747           0.0.0.0:*                           0          188605876  -
    udp        0      0 127.0.0.1:704           0.0.0.0:*                           0          32121      -
    udp6       0      0 :::892                  :::*                                0          31134      -
    udp6       0      0 :::37803                :::*                                0          188609420  -
    udp6       0      0 :::42048                :::*                                0          188606558  -
    udp6       0      0 :::50293                :::*                                0          188863468  -
    udp6       0      0 :::58502                :::*                                0          23918      -
    udp6       0      0 :::5353                 :::*                                0          188864362  -
    udp6       0      0 :::5353                 :::*                                0          188612271  -
    udp6       0      0 :::5353                 :::*                                0          188613075  -
    udp6       0      0 :::5353                 :::*                                0          188606552  -
    udp6       0      0 :::5353                 :::*                                0          188605087  -
    udp6       0      0 :::5353                 :::*                                0          147558303  -
    udp6       0      0 :::58876                :::*                                0          188606554  -
    udp6       0      0 :::46826                :::*                                0          188609422  -
    udp6       0      0 :::2049                 :::*                                0          46564      -
    udp6       0      0 :::43300                :::*                                0          188606560  -
    udp6       0      0 :::35471                :::*                                0          188613077  -
    udp6       0      0 :::47875                :::*                                0          188605093  -
    udp6       0      0 :::56414                :::*                                0          188865483  -
    udp6       0      0 :::56689                :::*                                0          188864364  -
    udp6       0      0 :::36280                :::*                                0          147558305  -
    udp6       0      0 :::52788                :::*                                0          188605089  -
    udp6       0      0 :::3702                 :::*                                99         174134780  -
    udp6       0      0 :::49061                :::*                                0          188612273  -
    udp6       0      0 :::57278                :::*                                0          188612279  -
    udp6       0      0 :::4045                 :::*                                0          46573      -
    udp6       0      0 :::111                  :::*                                0          23917      -
    udp6       0      0 :::123                  :::*                                0          30443      -
    udp6       0      0 :::32955                :::*                                0          188606539  -
    udp6       0      0 ::1:323                 :::*                                0          30441      -
    udp6       0      0 :::53664                :::*                                0          188612278  -
    udp6       0      0 :::662                  :::*                                0          32136      -
    2026-05-31 11:58:28.367  - debug: admin.0 (30989) Subscribes: dummy
    2026-05-31 11:58:29.816  - debug: admin.0 (30989) Subscribes: system.host.*.notifications.*
    2026-05-31 11:58:29.818  - debug: admin.0 (30989) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive
    2026-05-31 11:58:29.819  - debug: admin.0 (30989) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2026-05-31 11:58:30.442  - debug: admin.0 (30989) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive
    2026-05-31 11:58:30.451  - debug: admin.0 (30989) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2026-05-31 11:58:48.279  - debug: admin.0 (30989) Disable logging, because no one socket connected
    2026-05-31 11:58:48.280  - info: admin.0 (30989) <== Disconnect system.user.admin from ::ffff:192.168.1.73 admin
    2026-05-31 11:58:48.361  - info: admin.0 (30989) <== Disconnect system.user.admin from ::ffff:192.168.1.73 admin
    2026-05-31 12:00:05.137  - info: admin.0 (30989) ==> Connected system.user.admin from ::ffff:192.168.1.73
    2026-05-31 12:00:05.145  - debug: admin.0 (30989) Subscribes: dummy
    2026-05-31 12:00:05.147  - debug: admin.0 (30989) Subscribes: system.host.*.notifications.*
    2026-05-31 12:00:05.148  - debug: admin.0 (30989) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive
    2026-05-31 12:00:05.149  - debug: admin.0 (30989) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive
    2026-05-31 12:00:05.151  - debug: admin.0 (30989) Subscribes: system.host.*.notifications.*, system.adapter.discovery.0.alive, system.host.*.alive, admin.0.info.newsFeed
    2026-05-31 12:00:05.164  - debug: admin.0 (30989) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2026-05-31 12:03:05.144  - info: admin.0 (30989) <== Disconnect system.user.admin from ::ffff:192.168.1.73 admin
    2026-05-31 12:05:28.815  - info: javascript.0 (252) script.js.Neu.Teich_&_Terrasse.Solarpumpe_Teichheizung_bei_60__oder_80__ein_aus: Solarpumpe Teichheizung ab 58° ist ein
    2026-05-31 12:17:55.220  - info: javascript.0 (252) script.js.Neu.BYD_Dolphin.ECO_&_FAST_Automatisch_ein_aus: Zappi wurde auf STOP gestellt
    2026-05-31 12:17:55.432  - info: myenergi.0 (988) {}
    2026-05-31 12:26:35.200  - info: javascript.0 (252) script.js.Neu.BYD_Dolphin.ECO_&_FAST_Automatisch_ein_aus: Zappi wurde auf STOP gestellt
    2026-05-31 12:26:35.409  - info: myenergi.0 (988) {}
    2026-05-31 12:26:45.705  - info: hue.0 (558) Started scene: Scene WC Taglicht grün
    2026-05-31 12:26:46.655  - info: hue.0 (558) Started scene: Scene WC Taglicht grün
    2026-05-31 12:29:36.210  - error: sonos.0 (783) RequestFailedError: Got status 500 when invoking /MediaRenderer/AVTransport/Control
    iob diag has finished.
    root@Buanet-iobroker-final-1:/opt/iobroker# KernelKernel
    bash: KernelKernel: command not found
    root@Buanet-iobroker-final-1:/opt/iobroker# iob update && iob upgrade all -y
    Adapter "discovery" : 5.0.0 , installed 5.0.0
    Adapter "telegram" : 4.1.0 , installed 4.1.0
    Adapter "vis" : 1.5.6 , installed 1.5.6
    Adapter "vis-bars" : 0.1.4 , installed 0.1.4
    Adapter "vis-history" : 1.0.0 , installed 1.0.0
    Adapter "vis-justgage" : 2.1.7 , installed 2.1.7
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Update vis-inventwo from @3.3.5 to @4.1.0
    NPM version: 10.9.7
    Installing iobroker.vis-inventwo@4.1.0... (System call)
    removed 244 packages, and changed 1 package in 9s
    287 packages are looking for funding
    run npm fund for details
    Adapter "system.adapter.vis.0" restarted.
    Adapter "system.adapter.web.0" restarted.
    Updating objects from io-package.json for adapter "vis-inventwo" with version "4.1.0"
    Update "system.adapter.vis-inventwo.0"
    upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
    Update admin from @7.7.22 to @7.8.23
    host.Buanet-iobroker-final-1 Adapter "system.adapter.admin.0" is stopped.
    NPM version: 10.9.7
    Installing iobroker.admin@7.8.23... (System call)
    Try to solve ENOTEMPTY error automatically
    Could not handle ENOTEMPTY, because no deletable files were found
    npm error code ENOTEMPTY
    npm error syscall rename
    npm error path /opt/iobroker/node_modules/@grpc/grpc-js
    npm error dest /opt/iobroker/node_modules/@grpc/.grpc-js-f8Nv8b3T
    npm error errno -39
    npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@grpc/grpc-js' -> '/opt/iobroker/node_modules/@grpc/.grpc-js-f8Nv8b3T'
    npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2026-05-31T10_44_14_097Z-debug-0.log
    host.Buanet-iobroker-final-1 Cannot install iobroker.admin@7.8.23: 217
    @juggi1962
    iob stop
    iob fix
    iob start
    wäre das auf einem 'richtigen' System. Im Docker vermutlich anders. Muss dir aber einer der Dockeristen sagen.
      @juggi1962
      iob stop
      iob fix
      iob start
      juggi1962
      @juggi1962
      iob stop
      iob fix
      iob start
      okay danke für deine Bemühungen, vielleicht meldest sich ja jemand der sich mit dem Container auf der Synology auskennt
      • J juggi1962
        @juggi1962
        iob stop
        iob fix
        iob start
        juggi1962
        juggi1962 sagte:
        @juggi1962
        iob stop
        iob fix
        iob start
        das Thema hat sich erledigt laut Copilot hab ich jetzt einen komplettern Neuaufbau der Node‑Module gemacht und jetzt hat das Update funktioniert.
        Danke an Alle für eure Hilfe
        HomoranH OliverIOO 2 Antworten Letzte Antwort
        • J juggi1962
          juggi1962 sagte:
          @juggi1962
          iob stop
          iob fix
          iob start
          @juggi1962 sagte:
          Und bitte wie?
          • icebearI Offline
            icebearI Offline
            icebear
            @juggi1962
            Es wäre schön wenn du uns mitteilen würdest, was du gemacht hast, damit wenn anderen vor dem selben Problem stehen nicht wieder dieselben Fragen stellen, oder schneller zur Lösung kommen.
            • J Offline
              juggi1962
              schrieb am zuletzt editiert von juggi1962
              Diese Anleitung wurde nicht von mir sondern von Copilot erstellt und genau so habe ich es wieder zum laufen gebracht, dass ich das Admin Adapter Update machen konnte.
              ✅ Kurzfassung: Welche Befehle das Admin‑Adapter‑Update wieder repariert haben
              Das Update des Admin‑Adapters funktionierte nicht, weil das node_modules‑Verzeichnis im ioBroker‑Volume beschädigt war.
              Die Lösung war, die Node‑Module im Docker‑Container komplett neu aufzubauen.
              Diese Befehle wurden ausgeführt:
              1. In den Container wechseln
              Code:    docker exec -it <containername> bash
              2. Zum Benutzer iobroker wechseln
              Code:    su - iobroker
              3. Maintenance‑Modus aktivieren
              Code:    maintenance on
              4. In das ioBroker‑Verzeichnis wechseln
              Code:    cd /opt/iobroker
              5. Beschädigte Node‑Module löschen
              Code:    rm -rf node_modules
              6. npm‑Cache leeren
              Code :    npm cache clean --force
              7. Alle Pakete neu installieren
              Code:    npm install
              8. Maintenance‑Modus deaktivieren
              Code:   maintenance off
              → Der Container stoppt/restartet danach automatisch.
              🎉 Ergebnis
              Nach dem Neuaufbau von node_modules ließ sich der Admin‑Adapter wieder problemlos aktualisieren.
              Ich hoffe ich konnte auch mal helfen, leider weiß ich nicht wie man das macht, dass die Befehle so angezeigt werden, dass man sie so schön kopieren kann.
              Gruß Jürgen
              • Meister MopperM Online
                Meister Mopper
                @juggi1962 sagte:
                Das ist einfach, kopiere die Befehle aus der Konsole raus und füge sie hier nach Anklicken von </> ein.
                Proxmox und HA ...
                • mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  Noch ein Zusatz:
                  Sollte das Löschen des node_modules Trees und direkte npm Befehle nicht zu einem laufenden System führen, bitte an Copilot wenden, mit diesem diskutieren und sich hier nicht beschweren.
                  Generell gilt die Empfehlung niemals direkt mit npm herumhantieren...
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • mcm1957M mcm1957
                    Noch ein Zusatz:
                    juggi1962
                    @mcm1957 sagte:
                    Noch ein Zusatz:
                    ja vorher eine Sicherung machen falls was schief geht und ja, ich weiß dass die KI nicht immer alles richtig macht aber sonst hat mir ja keiner wirklich helfen können und es hat funktioniert.
                    haselchenH Meister MopperM 2 Antworten Letzte Antwort
                    • J juggi1962
                      @mcm1957 sagte:
                      Noch ein Zusatz:
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @juggi1962
                      Dass Du in dieser "Situation" gesteckt hast, liegt an keinem Entwickler oder der Software.
                      Eine solche Verbiegung des Systems , des Containers, wird einem Zutun Deinerseits zugrunde liegen.
                      Leider hast Du nicht offenbart, was Du alles im Vorfeld getan hast.
                      Ich nutze seit knapp 7 Jahren den Iobroker Container und kann ohne Umschweife sagen, wenn was hakt , sitzt das Problem VOR dem Rechner.
                      Da CoPilot das Problem gelöst hast, können wir das hier abhaken.
                      Was den Lerneffekt betrifft, der ist leider für keinen vorhanden, da die Ursache nicht bekannt ist.
                      • J juggi1962
                        @mcm1957 sagte:
                        Noch ein Zusatz:
                        Meister Mopper
                        @juggi1962 sagte:
                        Ich bin überzeugt, dass du (fast) alles richtig gemacht hast, insbesondere, dass du erwähnt hast, welche KI du genutzt hast.
                        Wir befinden uns aber aktuell in einem Umbruch und KI und Entwickler stehen in (teilweise falsch) verstandener Konkurrenz.
                        Ich nutze auch KI, aber die Kenntnisse der hiesigen Devs schätze ich weit mehr, als die sicher auftretenden Halluzinationen der KI.
                        Wenn es systemisch kritisch wird, ist mir menschliches Expertenwissen wichtiger.
                        Proxmox und HA ...
                        • haselchenH haselchen
                          @juggi1962
                          juggi1962
                          @haselchen sagte:
                          @juggi1962
                          Was willst du mir mit dem (was hakt , sitzt das Problem VOR dem Rechner) unterstellen?
                          Ich habe im Vorfeld gar nichts gemacht ich habe den Container installiert und er lief auch ohne Probleme schon ein paar Wochen und außerdem habe ich nie geschrieben, dass irgend wehr Schuld ist egal ob buanet oder sonst was, der Admin Adapter war auch der einzige Adapter der sich auf das neue Update nicht aktualisieren ließ. Aber wenn man hier so runter gemacht wird dann danke dafür.
                          Ich habe geschrieben ich bin kein Profi.
                            @juggi1962 sagte:
                            juggi1962
                            @Meister-Mopper sagte:
                            @juggi1962 sagte:
                            Mir wäre auch lieber wenn mir wer von hier geholfen hätte aber für einen Leien sind halt gewisse aussagen was zu tun ist nicht zu verstehen und wenn man nachfragt kommt wieder eine Antwort die nur ein Profi versteht. Da hab ich halt mal in der Zwischenzeit die KI gefragt und es konnte ja nichts schief gehen, kann ja jeder Zeit wieder zurück (Backup) und es hat funktioniert.
                            Es tut mir leid, dass ich nicht gewartet habe bis jemand Zeit hatte das anständig einem Dummi zu erklären. So aber jetzt reicht es mit dem ganzen hin und her.
                            Schönen Abend noch an Alle
                            • J juggi1962
                              @juggi1962 sagte:
                              @juggi1962 sagte:
                              Das wäre auch gekommen!
                              Nur etwas Geduld!
                              Dass ein entsprechender User, mit Docker Kenntnissen, hier innerhalb von 3 Stunden auf deine Nachfrage stößt ist schon sehr optimistisch.
                              Zumal du dich an einen alten bestehenden Thread gehängt hast, bei dem nichts von Docker im Threadtitel steht
                              Siehe auch: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                                @juggi1962 sagte:
                                Nur etwas Geduld!
                                juggi1962
                                @Homoran sagte:
                                @juggi1962 sagte:
                                Nur etwas Geduld!
                                ja ich weiß es doch. Hatte halt gerade Zeit vor dem PC und dachte ich versuch es mal, kann ja nichts passieren und ja es hat zufällig gleich funktioniert. Wenn ich gewusst hätte was ich da für einen Wirbel mit dem KI zeug auslöse, dann wäre ich einfach still gewesen anstatt es zu schreiben.
                                So und jetzt lassen wir es und wenn man die Beschreibung der Ki nicht hier haben will bitte löschen.
                                Danke trotzdem für eure Hilfe
                                • J juggi1962
                                  @Homoran sagte:
                                  @juggi1962 sagte:
                                  Nur etwas Geduld!
                                  Meister Mopper
                                  @juggi1962 sagte:
                                  Wie ich schon schrieb, du hast nichts falsch gemacht. Aber einige im Forum sollten ihre Routinen überarbeiten.
                                  World has changed!
                                  Proxmox und HA ...
                                  • J juggi1962
                                    @haselchen sagte:
                                    @juggi1962
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @juggi1962
                                    Junge Junge, kann da nur @samson71 nochmal zitieren:
                                    Halt mal die Füsse still.
                                    Du benutzt ein System , was Deine Fähigkeiten übersteigt und drängelst dann das ein Dockerist hier helfen soll.
                                    Lässt Dich dann feiern, weil eine KI Dein Problem gelöst hat.
                                    Wenn Du mal Dein Log in die KI eingegeben hättest, dann wäre hervorgekommen:
                                    Die eigentliche Ursache in deinem Log
                                    Der entscheidende Hinweis ist:
                                    Das bedeutet:
                                    npm hat bereits versucht, das Problem automatisch zu reparieren, hat aber in dem Verzeichnis keine Dateien gefunden, die gefahrlos gelöscht werden konnten.
                                    Das spricht am ehesten für:
                                    einen hängen gebliebenen Restordner eines früheren Updates
                                    oder einen noch laufenden Prozess, der Dateien im @grpc-Verzeichnis verwendet.
                                    Deshalb würde ich die Wahrscheinlichkeit ungefähr so einschätzen:
                                    60 % → abgebrochenes/früheres Update
                                    30 % → laufender Prozess hält Dateien offen
                                    10 % → Rechte- oder Dateisystemproblem
                                    Eine Lösung wird dann auch angeboten.
                                    Es IST also voher schon was passiert.
                                    Sorry, aber "Ich habe im Vorfeld gar nichts gemacht ich habe den Container installiert und er lief auch ohne Probleme schon ein paar Wochen..." stimmt halt nicht.
                                    Aber auch Dir einen schönen Abend.
                                      @juggi1962 sagte:
                                      World has changed!
                                      World has changed!
                                      Das mag ja sein, aber das hiesige Haupt"problem" ist doch, dass ein Dockerkundiger nicht sofort zur Hand war.
                                      In meinem Fall (und ich weiss es auch von anderen) liegt es daran, dass Docker als zusätzliche Ebene bei Problemen eben doch anders behandelt werden muss als eine native Installation.
                                      Mir ist das zu komplex, deswegen lasse ich die Finger davon.
                                      Für einen "Laien, der nicht fit mit der Materie" ist ist es bei Dockerproblemen nochmal schwieriger.
                                      Wenn man dan eine KI fragt und d die Antwort nicht bewerten kann, sehe ich eine weitere Gefahr.
                                      Es gibt ja einige Maßnahmen, die bei einer nativen Installation durchaus üblich sind, bei Docker aber nicht angewandt werden dürfen.
                                      Soweit mein Halb-/Viertelwissen.
                                      Ich würde mir nicht zutrauen eine Anweisung, die eine Ki aus Nativer und Dockerinstallation mixt zu bewerten.
                                      EDIT:
                                      Die KI Korrektur von meinem neuen Tablet hat mal wieder einige Worte fehkorrigiert und so sinnentstellt.
                                      Ich hoffe ich habe das bereinigen können
                                      • J Offline
                                        juggi1962
                                        Guten Morgen, ich hoffe die Gemüter haben sich wieder beruhigt.
                                        Wenn ich hier darf möchte ich noch mal meine Situation schildern ohne gleich wieder angegriffen zu werden.
                                        Ich habe ca. 9 Jahre den ioBroker zuerst auf einem Raspberry 3 dann auf einem 4er mit einer SSD Festplatte und einem Argon ONE Gehäuse am laufen gehabt.
                                        Mein ganzes Haus laüft darauf 86 zWave Module, Viessmann Heizung wird ausgelesen, PV von Huawei, Zappi Wallbox, 3 Netatmo Cams usw. ich wollte eigentlich da ich ja das Synology DS 923+ NAS am Laufen habe eigentlich nur den ioBroker Container als Backup einrichten falls mal der Raspberry den Geist auf gibt, damit ich gleich wieder online mit meinem ganzen Haus bin. ich habe den Container eingerichtet und das Backup vom Raspberry drauf gespielt und alles hat funktioniert und sogar viel besser und schneller als mit dem Raspberry 4 darum bin ich bei dem Container geblieben und hab den Raspberry als Backup gelassen. Vielleicht entstand der Fehler dass ich jetzt den Admin Adapter nicht auf das neueste Update aktualisieren konnte durch das übernehmen des Backups vom Raspberry. Ich weiß es nicht, mir war auch nicht klar, dass das mit einem Container komplizierter ist als mit einem Raspberry. Ich möchte aber auf dem Nas bleiben weil einfach alles viel zügiger und schneller läuft. es gibt keine Verzögerungen mehr usw.
                                        Das war mal meine Situation und da ich ja belehrbar bin und es richtig machen möchte, bitte ich die mit dem Container was zu tun haben und mir vielleicht sagen können ob das was mir die KI da vorgeschlagen hat völliger Blödsinn war und wie ich es dann besser und sicherere machen kann. Momentan läuft alles wie es soll, aber das habe ich auch gedacht bis das Admin Update gekommen ist.
                                        Falls man das in einen anderen Bereich verschieben soll bitte machen.
                                        Danke noch mal für eure Hilfe und ich habe mich gestern nicht feiern lassen, ich habe nur weil es gewünscht war was ich getan habe, dass das Update dann funktioniert hat, es hier reingeschrieben.
                                        Gruß aus Tirol von einem 64 Jährigen der sich halt mit den ganzen Code nicht so auskennt.
                                        HomoranH crunchipC 2 Antworten Letzte Antwort
                                        • J juggi1962
                                          @juggi1962 sagte:
                                          Wenn ich hier darf
                                          Natürlich darfst du!
                                          @juggi1962 sagte:
                                          Ich glaube nicht, dass du bisher angegriffen wurdest.
                                          Das muss ein Missverständnis sein.
                                          Was ich bisher gesehen habe waren Hinweise und Ratschläge.
                                          Und nochmals zur Klarstellung.
                                          Docker ist ein super Tool. Und solange es -wie bei dir- rund läuft, hast du damit auch nichts am Hut.
                                          Erst wenn es es nicht mehr tut ist halt eine weitere Ebene involviert, mit der man sich auskennen muss.
                                          Und genau da hakt es.
                                          Ich habe keine Ahnung warum sich der admin bei dir nicht updaten ließ. Das sollte im Container nicht anders laufen als nativ.
                                          Da muss vorher irgendetwas schief gelaufen sein, was wir durch den "Eingriff der KI" jetzt leider nicht mehr klären können.
                                          Deshalb steht auch in den verlinkten "Hinweisen für gute Forenbeiträge" dass man während der "Behandlung" keine unabgesprochenen Aktionen ausführen soll.
                                          Auch wenn so ein Fall nur alle paar Jahre vorkommt, wäre es für andere User interessant die Ursache zu kennen.
