  4. ...nicht in offiziellem Repo
  5. [TEST] Mammotion – Adapter für Mammotion Luba / Yuka
    6.3k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
110 Beiträge 19 Kommentatoren 8.3k Aufrufe 21 Beobachtet
  • J Offline
    Jaschkopf
    Moin. Hab gerade nochmal versucht die Zonen abzufragen. Hatte den Adapter zwischenzeitlich deaktiviert und momentan stürzt er nach ca. 40sek ab. Hier das Log:
    host.iobroker
    2026-04-20 19:07:10.312	warn	Do not restart adapter system.adapter.mammotion.0 because restart loop detected
    host.iobroker
    2026-04-20 19:07:10.312	info	Restart adapter system.adapter.mammotion.0 because enabled
    host.iobroker
    2026-04-20 19:07:10.312	error	instance system.adapter.mammotion.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    influxdb.0
    2026-04-20 19:07:09.946	info	Store 1001 buffered influxDB history points
    mammotion.0
    2026-04-20 19:07:09.766	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    mammotion.0
    2026-04-20 19:07:09.766	info	terminating
    mammotion.0
    2026-04-20 19:07:09.765	error	connack timeout
    mammotion.0
    2026-04-20 19:07:09.765	error	Error: connack timeout at Timeout._onTimeout (/opt/iobroker/node_modules/mqtt/build/lib/client.js:363:32) at listOnTimeout (node:internal/timers:588:17) at process.processTimers (node:internal/timers:523:7)
    mammotion.0
    2026-04-20 19:07:09.764	error	uncaught exception: connack timeout
    mammotion.0
    2026-04-20 19:07:06.452	debug	Area-Name-Re-Request (missing) failed for Luba-VSY6PEGK: Request failed with status code 429
    mammotion.0
    2026-04-20 19:07:06.431	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:07:06.323	debug	JWT MQTT connection closed
    mammotion.0
    2026-04-20 19:07:06.323	debug	JWT MQTT offline
    mammotion.0
    2026-04-20 19:07:06.314	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for Luba-VSY6PEGK, receiver=1
    mammotion.0
    2026-04-20 19:07:06.313	debug	Area-Name-Re-Request (missing) failed for RTKBEU240470930: Request failed with status code 429
    mammotion.0
    2026-04-20 19:07:06.262	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:07:06.141	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for RTKBEU240470930, receiver=1
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/property/post
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/proto/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/property/post
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/proto/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:06.139	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:06.139	info	MQTT connected.
    mammotion.0
    2026-04-20 19:07:05.934	debug	Aliyun MQTT connection closed
    mammotion.0
    2026-04-20 19:07:05.933	debug	Aliyun MQTT offline
    mammotion.0
    2026-04-20 19:07:01.218	debug	Area-Name-Re-Request (missing) failed for Luba-VSY6PEGK: Request failed with status code 429
    mammotion.0
    2026-04-20 19:07:01.190	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:07:01.074	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for Luba-VSY6PEGK, receiver=1
    mammotion.0
    2026-04-20 19:07:01.073	debug	Area-Name-Re-Request (missing) failed for RTKBEU240470930: Request failed with status code 429
    mammotion.0
    2026-04-20 19:07:01.056	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:07:01.046	debug	JWT MQTT connection closed
    mammotion.0
    2026-04-20 19:07:01.046	debug	JWT MQTT offline
    mammotion.0
    2026-04-20 19:07:00.931	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for RTKBEU240470930, receiver=1
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/property/post
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/proto/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/property/post
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/proto/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:00.928	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:07:00.928	info	MQTT connected.
    mammotion.0
    2026-04-20 19:06:55.998	debug	Area-Name-Re-Request (missing) failed for Luba-VSY6PEGK: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:55.981	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:55.976	debug	[PROPS] Property keys for qTfCnXxDojviovYWZhqH000000: iotState, deviceVersionInfo, extMod, knifeHeight, leftMotorBootVersion, iotMsgHz, rtMrMod, iotMsgTotal, loraRawConfig, loraGeneralConfig, leftMotorVersion, betInfo, coordinate, intMod, bmsVersion, stm32H7Version, rightMotorVersion, rightMotorBootVersion, deviceVersion, rtkVersion, ltMrMod, networkInfo, bmsHardwareVersion, batteryPercentage, deviceState, deviceOtherInfo, mcBootVersion
    mammotion.0
    2026-04-20 19:06:55.873	debug	Aliyun MQTT ensure ok (jwt-offline).
    mammotion.0
    2026-04-20 19:06:55.872	debug	[ALIYUN-MQTT] Connecting to a5vlvzwIhhj.iot-as-mqtt.eu-central-1.aliyuncs.com:1883 as 81c8d51ab696a9bcc3c6306890b2f090&a5vlvzwIhhj
    mammotion.0
    2026-04-20 19:06:55.872	debug	JWT MQTT connection closed
    mammotion.0
    2026-04-20 19:06:55.872	debug	JWT MQTT offline
    mammotion.0
    2026-04-20 19:06:55.865	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for Luba-VSY6PEGK, receiver=1
    mammotion.0
    2026-04-20 19:06:55.822	debug	Area-Name-Re-Request (missing) failed for RTKBEU240470930: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:55.805	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:55.688	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for RTKBEU240470930, receiver=1
    mammotion.0
    2026-04-20 19:06:55.686	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/property/post
    mammotion.0
    2026-04-20 19:06:55.686	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:06:55.686	debug	[MQTT] Physical device topic reachable: /sys/proto/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:55.686	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:55.686	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/property/post
    mammotion.0
    2026-04-20 19:06:55.686	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:06:55.686	debug	[MQTT] Physical device topic reachable: /sys/proto/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:55.685	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:55.685	info	MQTT connected.
    mammotion.0
    2026-04-20 19:06:55.590	debug	[PROPS] Property keys for mNT5fCoPVHU90gjmPygZ000000: coordinate, networkInfo, otaProgress, mcuVersion, loraVersion, deviceVersionInfo, deviceVersion, loraGeneralConfig, deviceOtherInfo, rtkVersion
    mammotion.0
    2026-04-20 19:06:50.786	debug	Area-Name-Re-Request (missing) failed for Luba-VSY6PEGK: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:50.767	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:50.651	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for Luba-VSY6PEGK, receiver=1
    mammotion.0
    2026-04-20 19:06:50.650	debug	Area-Name-Re-Request (missing) failed for RTKBEU240470930: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:50.631	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:50.629	debug	JWT MQTT connection closed
    mammotion.0
    2026-04-20 19:06:50.629	debug	JWT MQTT offline
    mammotion.0
    2026-04-20 19:06:50.517	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for RTKBEU240470930, receiver=1
    mammotion.0
    2026-04-20 19:06:50.515	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/property/post
    mammotion.0
    2026-04-20 19:06:50.514	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:06:50.514	debug	[MQTT] Physical device topic reachable: /sys/proto/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:50.514	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:50.514	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/property/post
    mammotion.0
    2026-04-20 19:06:50.514	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:06:50.514	debug	[MQTT] Physical device topic reachable: /sys/proto/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:50.514	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:50.514	info	MQTT connected.
    mammotion.0
    2026-04-20 19:06:49.763	debug	Aliyun MQTT connection closed
    mammotion.0
    2026-04-20 19:06:49.763	debug	Aliyun MQTT offline
    mammotion.0
    2026-04-20 19:06:45.710	debug	Area-Name-Re-Request (missing) failed for Luba-VSY6PEGK: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:45.692	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:45.570	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for Luba-VSY6PEGK, receiver=1
    mammotion.0
    2026-04-20 19:06:45.567	debug	Area-Name-Re-Request (missing) failed for RTKBEU240470930: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:45.495	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:45.458	debug	JWT MQTT connection closed
    mammotion.0
    2026-04-20 19:06:45.458	debug	JWT MQTT offline
    mammotion.0
    2026-04-20 19:06:45.341	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for RTKBEU240470930, receiver=1
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/property/post
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/proto/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/property/post
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/event/property/post_reply
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/proto/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:45.338	debug	[MQTT] Physical device topic reachable: /sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post
    mammotion.0
    2026-04-20 19:06:45.337	info	MQTT connected.
    mammotion.0
    2026-04-20 19:06:40.282	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/property/post): Connection closed
    mammotion.0
    2026-04-20 19:06:40.282	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/event/property/post_reply): Connection closed
    mammotion.0
    2026-04-20 19:06:40.282	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/_thing/event/notify): Connection closed
    mammotion.0
    2026-04-20 19:06:40.282	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/model/down_raw): Connection closed
    mammotion.0
    2026-04-20 19:06:40.282	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/events): Connection closed
    mammotion.0
    2026-04-20 19:06:40.282	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/properties): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/proto/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/thing/event/+/post): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1LLmy1zc0j/Luba-VSY6PEGK/app/down/thing/status): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/property/post): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/event/property/post_reply): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/app/down/_thing/event/notify): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/model/down_raw): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/events): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/properties): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/proto/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/thing/event/+/post): Connection closed
    mammotion.0
    2026-04-20 19:06:40.281	warn	MQTT subscribe failed (/sys/a1Nc68bGZzX/RTKBEU240470930/app/down/thing/status): Connection closed
    mammotion.0
    2026-04-20 19:06:40.280	debug	JWT MQTT connection closed
    mammotion.0
    2026-04-20 19:06:40.280	debug	JWT MQTT offline
    mammotion.0
    2026-04-20 19:06:40.198	debug	[PROPS] Property keys for qTfCnXxDojviovYWZhqH000000: iotState, deviceVersionInfo, extMod, knifeHeight, leftMotorBootVersion, rtMrMod, iotMsgHz, iotMsgTotal, loraRawConfig, loraGeneralConfig, leftMotorVersion, betInfo, intMod, coordinate, bmsVersion, stm32H7Version, rightMotorVersion, rightMotorBootVersion, deviceVersion, rtkVersion, ltMrMod, networkInfo, bmsHardwareVersion, batteryPercentage, deviceState, deviceOtherInfo, mcBootVersion
    mammotion.0
    2026-04-20 19:06:39.842	info	Initialization successful: 2 device(s), telemetry via MQTT.
    mammotion.0
    2026-04-20 19:06:39.842	debug	Area-name request failed for Luba-VSY6PEGK: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:39.825	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:39.710	debug	Aliyun MQTT ensure ok (start-polling).
    mammotion.0
    2026-04-20 19:06:39.709	debug	[ALIYUN-MQTT] Connecting to a5vlvzwIhhj.iot-as-mqtt.eu-central-1.aliyuncs.com:1883 as 81c8d51ab696a9bcc3c6306890b2f090&a5vlvzwIhhj
    mammotion.0
    2026-04-20 19:06:39.709	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for Luba-VSY6PEGK, receiver=1
    mammotion.0
    2026-04-20 19:06:39.708	debug	Area-name request failed for RTKBEU240470930: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:39.691	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:39.598	debug	Area-Name-Re-Request (missing) failed for Luba-VSY6PEGK: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:39.580	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:39.575	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for RTKBEU240470930, receiver=1
    mammotion.0
    2026-04-20 19:06:39.575	debug	IoT sync for Luba-VSY6PEGK failed: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:39.557	warn	Modern command path returned Invalid device for Luba-VSY6PEGK, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:39.464	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for Luba-VSY6PEGK, receiver=1
    mammotion.0
    2026-04-20 19:06:39.462	debug	Area-Name-Re-Request (missing) failed for RTKBEU240470930: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:39.444	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:39.442	debug	IoT sync for RTKBEU240470930 failed: Request failed with status code 429
    mammotion.0
    2026-04-20 19:06:39.401	debug	[PROPS] Property keys for mNT5fCoPVHU90gjmPygZ000000: coordinate, networkInfo, otaProgress, mcuVersion, loraVersion, deviceVersionInfo, deviceVersion, loraGeneralConfig, deviceOtherInfo, rtkVersion
    mammotion.0
    2026-04-20 19:06:39.391	warn	Modern command path returned Invalid device for RTKBEU240470930, trying Aliyun fallback.
    mammotion.0
    2026-04-20 19:06:39.293	debug	[AREA-REQ] Sending sub_cmd=3 (AppGetAllAreaHashName) for RTKBEU240470930, receiver=1
    mammotion.0
    2026-04-20 19:06:39.289	info	MQTT connected.
    mammotion.0
    2026-04-20 19:06:34.582	info	starting. Version 0.0.7 (non-npm: DNAngelX/ioBroker.mammotion#9a5ddba9a906e60e81c8ea93406d8658c533e8bc) in /opt/iobroker/node_modules/iobroker.mammotion, node: v22.18.0, js-controller: 7.0.7
    host.iobroker
    2026-04-20 19:06:33.694	info	instance system.adapter.mammotion.0 in version "0.0.7" (non-npm: DNAngelX/ioBroker.mammotion#9a5ddba9a906e60e81c8ea93406d8658c533e8bc) started with pid 1304960
    host.iobroker
    2026-04-20 19:06:33.105	info	"system.adapter.mammotion.0" enabled
    Machen die Mammotion Server wieder doof?
    • stolly82S Offline
      stolly82S Offline
      stolly82
      @jaschkopf
      bin dran,... bekomme jetzt auch mit meinem Luba keine einzige Zone mehr.
      • J Offline
        Jaschkopf
        Gibt's schon Neuigkeiten?
        • stolly82S Offline
          stolly82S Offline
          stolly82
          @jaschkopf
          Leider nein!
          Die Zonen kommen per MQTT und die scheinen da irgendwas geändert zu haben mit dem letztem
          Update.
          Ich muss den Netzwerk Verkehr per MQTT loggen, was nicht über die Standard Logger funktioniert, da die in der Regel nur HTTP und HTTPS loggen können.
          Ist leider nicht „mal eben“ gemacht.
          • J Offline
            Jaschkopf
            Schade, wenn ich irgendwie unterstützen kann sag bescheid
            • m1k3f15hM Offline
              m1k3f15hM Offline
              m1k3f15h
              Hy,
              Bekomme ständig das im log:
              Was kann ich tun?
              Mike
              ioBroker Multihostsystem in Docker-Container auf Raspi's mit Redis-Sentinel als States und Objects DB
              Aktuell am Aufbau einer Lovelace Visu
              Deye SUN-12K + 10 kWp Module + 2 x 10 kWh MeritSun PowerWall
              Mammotion Yuka
              stolly82S 1 Antwort Letzte Antwort
              • m1k3f15hM m1k3f15h
                Hy,
                Was kann ich tun?
                Mike
                stolly82S Offline
                stolly82S Offline
                stolly82
                @m1k3f15h sagte:
                Hy,
                Was kann ich tun?
                Mike
                Was stört dich an dem log genau? Geht der Rest?
                Beachtet, der Adapter ist im development und Nix it stable und Zonen scheinen aktuell nickt zu funktionieren.
                • m1k3f15hM Offline
                  m1k3f15hM Offline
                  m1k3f15h
                  Hy
                  Kommt alle 5 Sekunden - Müllt das log zu...
                  Und ausserdem werden keine Datenpunkte aktualisiert :(
                  Ich weiss, dass er im dev ist.. möchte ja auch gerne Hilfestellung leisten :)
                  Mike
                  Mammotion Yuka
                    Hy
                    Mike
                    stolly82S Offline
                    stolly82S Offline
                    stolly82
                    @m1k3f15h sagte:
                    Hy
                    Mike
                    In der API wurde so einiges geändert, ich hatte es soeben zumindest wieder hinbekommen, dass er die Zonen wieder geladen hat. Danach kommen die Commands dass die auch wieder funktionieren.
                    Es geht voran, allerdings nicht so schnell wie ich es gerne würde.
                    m1k3f15hM N 2 Antworten Letzte Antwort
                    • stolly82S stolly82
                      @m1k3f15h sagte:
                      Hy
                      Mike
                      m1k3f15hM Offline
                      m1k3f15hM Offline
                      m1k3f15h
                      @stolly82 Danke für deine Mühen :)
                      Mike
                      Mammotion Yuka
                      • J Offline
                        Jens Lattwesen
                        Moin, bekomme nächste Woche einen Yuka.
                        Welche Szenarien habt ihr so in Planung? Integration Wetterdaten bspw?
                        Hat schon jemand Skripte am Laufen?
                          @m1k3f15h sagte:
                          Hy
                          Mike
                          N Offline
                          N Offline
                          Norb 0
                          @stolly82
                          besteht da noch Hoffnung auf einen funktionierenden Adapter?
                          Wenn ich irgendwie unterstützen kann, sag bescheid.
                          • stolly82S Offline
                            stolly82S Offline
                            stolly82
                            Hey zusammen,
                            aktuell scheitert es leider noch am Login über MQTT. Ich habe mir deshalb auch das Projekt PyMammotion genauer angesehen. Dort war zwischenzeitlich ebenfalls einiges kaputt, allerdings haben die Entwickler die Probleme inzwischen wieder behoben.
                            Das größte Problem ist aktuell allerdings Mammotion selbst. Die API greift extrem schnell auf ein Rate Limit. Nach wenigen Anfragen (gefühlt ca. 5) wird der Zugriff für rund 24 Stunden gesperrt. Das macht die Entwicklung unglaublich mühsam. Im Endeffekt kann ich am Wochenende vielleicht zwei Testläufe machen und danach ist der API-Zugriff wieder dicht. Dinge, die normalerweise in 20 Minuten erledigt wären, ziehen sich dadurch teilweise über viele Tage.
                            Ich überlege deshalb aktuell, den Adapter grundsätzlich auf PyMammotion aufzubauen – ähnlich wie es auch der Home Assistant Adapter macht. Der große Vorteil wäre, dass PyMammotion von mehreren Entwicklern aktiv gepflegt wird und Änderungen an der Mammotion-API dort meist zeitnah nachgezogen werden.
                            Der Nachteil ist allerdings, dass ioBroker komplett auf Node.js basiert, während PyMammotion eine Python-Bibliothek ist. Der Adapter müsste dann im Hintergrund einen Python-Prozess nutzen bzw. PyMammotion installieren. Das wäre für ioBroker eher ungewöhnlich und würde vermutlich auch eine vorhandene Python-Installation voraussetzen.
                            Ich bin deshalb gerade am Abwägen, welcher Weg langfristig sinnvoller ist.
                              Hey zusammen,
                              @stolly82
                              Es gibt aber einige Adapter, die python-libraries laden. Allerdings wird das mit kommenden npm-Versionen nicht einfacher vom Handling her. Das ganze muss dann da nochmal ausdrücklich freigegeben werden.
                                @stolly82
                                stolly82S Offline
                                stolly82S Offline
                                stolly82
                                #66
                                @Thomas-Braun
                                Das war auch der Grund, weshalb ich mir die Mühe machen wollte ohne den PyMammotion zu arbeiten.
                                • stolly82S Offline
                                  stolly82S Offline
                                  stolly82
                                  schrieb am zuletzt editiert von stolly82
                                  #67
                                  Neuer Adapter: mammotion-pymammotion (PyMammotion-Bridge)
                                  https://github.com/DNAngelX/ioBroker.mammotion-pymammotion
                                  Es gibt jetzt einen komplett neuen Ansatz für den Mammotion-Adapter. Statt direkt mit der Mammotion-Cloud/MQTT zu kommunizieren, nutzt dieser Adapter — genau wie der Home Assistant Adapter — PyMammotion als Python-Bridge (Sidecar). Das bedeutet wir profitieren direkt von der aktiven PyMammotion-Community und müssen das Protokoll nicht selbst nachbauen.
                                  Was der Adapter macht:
                                  • Startet automatisch einen Python-Sidecar-Prozess beim Adapterstart
                                  • Kommuniziert mit der Mammotion-Cloud über PyMammotion
                                  • Legt alle Geräte-States dynamisch an (Status, Telemetrie, Zonen, Befehle usw.)
                                  • Unterstützt Starten, Pausieren, Stoppen, Andocken, Zonen-Management
                                  • Sidecar-Neustart mit Backoff bei Absturz
                                  Voraussetzungen:
                                  • Python 3.13 muss auf dem ioBroker-Host installiert sein
                                  • Den Installationsbefehl findet ihr direkt im Adapter-Tab "Python":
                                    sudo apt install python3.13 python3.13-venv python3.13-distutils python3-setuptools
                                  • Den Rest (venv, pymammotion, Dependencies) erledigt der Adapter beim ersten Start selbst
                                  Installation über ioBroker Admin (Adapter → GitHub-URL):
                                  Getestet mit:
                                  • Luba 1
                                  • Luba 2
                                  Ach so:
                                  Um die Zonen abzurufen einmal mammotion-pymammotion.0.devices.Luba-XXXXX.zones.syncMap klicken!
                                  Zonen
                                  Die habe ich wieder so wie bei dem letztem Adapter so gemacht, dass diese einzeln aktiviert werden können in den mammotion-pymammotion.0.devices.Luba-XXXXX.zones.zone_8943002932612598000.config.selected, damit die dann über die mammotion-pymammotion.0.devices.Luba-XXXXX.zones.startSelected gestartet werden können (nach Reihenfolge aus mammotion-pymammotion.0.devices.Luba-XXXXX.zones.zone_8943002932612598000.status.order!
                                  Die können aber auch z.B. per JavaScript Adapter über mammotion-pymammotion.0.devices.Luba-XXXXX.zones.startPayload übergeben werden!
                                  • stolly82S Offline
                                    stolly82S Offline
                                    stolly82
                                    #68
                                    Ach so, und testen, testen, testen,...
                                    ich bin diese Woche dran und danach habe ich wieder viele andere Projekte.
                                    • stolly82S Offline
                                      stolly82S Offline
                                      stolly82
                                      #69
                                      @norb-0 @m1k3f15h @jaschkopf @randyandy @freak @maverick78
                                      Ist jemand in der Lage den Adapter zu testen?
                                      Hier (Luba 1 und Luba 2) läuft bisher alles rund!
                                      • Dia-droD Offline
                                        Dia-droD Offline
                                        Dia-dro
                                        #70
                                        Danke für deine Bemühungen!
                                        Leider scheitere ich bereits bei der Installation von Python:
                                        Kannst du mir einen Tipp geben?
                                        • Dia-droD Dia-dro
                                          #71
                                          @dia-dro
                                          Versuch es so:
                                          sudo apt update
                                          sudo apt install python3 python3-venv python3-distutils python3-setuptools
                                          Die Angabe der Versionsnummer im Paketnamen ist falsch.
                                          Edit: Und das Paket 'python3-distutils' wird es vermutlich nicht mehr geben. Also nicht über entsprechende Meldungen wundern.
                                          Dia-droD 1 Antwort Letzte Antwort
