  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.4k Aufrufe 40 Beobachtet
  • teletapiT Online
    teletapiT Online
    teletapi
    #848
    Das sieht gut aus
    ```bash
    Script v.2026-05-19
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Raspberrypi5
           Icon name: computer
              Kernel: Linux 6.18.29+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 952 days ago (on 2023-10-10).
    Systemuptime and Load:
     01:16:36 up 16 min,  1 user,  load average: 1.22, 0.82, 0.58
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2026-05-20 01:16:36 CEST
               Universal time: Tue 2026-05-19 23:16:36 UTC
                     RTC time: Tue 2026-05-19 23:16:36
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobrokerHOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:             17G        5.2G         10G         26M        1.7G         11G
    Swap:           209M          0B        209M
    Total:           17G        5.2G         10G
    Active iob-Instances:   38
            16218 M total memory
             4994 M used memory
             4861 M active memory
              986 M inactive memory
             9730 M free memory
              199 M buffer memory
             1439 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 01:16:36 up 16 min,  1 user,  load average: 1.22, 0.82, 0.58
    Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16218.4 total,   9727.4 free,   4996.9 used,   1638.5 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.  11221.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.9G     0  7.9G   0% /dev
    tmpfs          tmpfs     3.2G   17M  3.2G   1% /run
    /dev/nvme0n1p2 ext4      117G   17G   95G  16% /
    tmpfs          tmpfs     8.0G     0  8.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     8.0G  8.7M  8.0G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
    /dev/nvme0n1p1 vfat      510M   75M  436M  15% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    tmpfs          tmpfs     1.6G   32K  1.6G   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Wed May 20 00:59:57 2026] EXT4-fs (nvme0n1p2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
    [Wed May 20 00:59:58 2026] EXT4-fs (nvme0n1p2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.9G    /var/
    1.9G    /var/lib
    1.7G    /var/lib/influxdb/engine/data/5ba497ab85a9233a/autogen
    Archived and active journals take up 196.9M in the file system.
    /opt/iobroker/backups:
    5.0G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    643M    /opt/iobroker/iobroker-data/
    262M    /opt/iobroker/iobroker-data/files
    127M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/node-red
    71M     /opt/iobroker/iobroker-data/node-red/node_modules
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    18M     /opt/iobroker/iobroker-data/states.jsonl
    9.0M    /opt/iobroker/iobroker-data/files/devices/assets/index-DEPE9oow.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a3b83b6a53aef11aaf2321455516304-if00-port0
    *** ZigBee Settings ***
    ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        ...f2321455516304-if00-port0        ...f2321455516304-if00-port0        ✓ Matching
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.15.0
    /usr/bin/node           v24.15.0
    /usr/bin/npm            11.12.1
    /usr/bin/npx            11.12.1
    ✓ Node.js installation is correct
    nodejs:
      Installed: 24.15.0-1nodesource1
      Candidate: 24.15.0-1nodesource1
      Version table:
     *** 24.15.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
         24.14.1-1nodesource1 1001
         24.14.0-1nodesource1 1001
         24.13.1-1nodesource1 1001
         24.13.0-1nodesource1 1001
         24.12.0-1nodesource1 1001
         24.11.1-1nodesource1 1001
         24.11.0-1nodesource1 1001
         24.10.0-1nodesource1 1001
         24.9.0-1nodesource1 1001
         24.8.0-1nodesource1 1001
         24.7.0-1nodesource1 1001
         24.6.0-1nodesource1 1001
         24.5.0-1nodesource1 1001
         24.4.1-1nodesource1 1001
         24.4.0-1nodesource1 1001
         24.3.0-1nodesource1 1001
         24.1.0-1nodesource1 1001
         24.0.2-1nodesource1 1001
         24.0.1-1nodesource1 1001
         24.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberrypi5        Raspberrypi5 (version: 7.1.2, hostname: Raspberrypi5  , alive, uptime: 993)
    Core adapters versions
    js-controller:  7.1.2
    admin:          7.8.25
    javascript:     9.2.2
    nodejs modules from github:     2
    +-- iobroker.influxdb@4.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.influxdb.git#ae7b21709836538e11e7059472f4d72ce49b223e)
    +-- iobroker.jarvis@4.0.0-alpha.13 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#56f23ff400d6411cd23a4cf9e61790dc38fb288c)
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
      system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             -  enabled
    + system.adapter.alpha-ess.0              : alpha-ess             : Raspberrypi5                             -  enabled
    + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
    + system.adapter.devices.0                : devices               : Raspberrypi5                             -  enabled
    + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
    + system.adapter.e3oncan.0                : e3oncan               : Raspberrypi5                             -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             -  enabled
      system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Raspberrypi5                             - disabled
    + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: Raspberrypi5                             -  enabled
      system.adapter.energiefluss-erweitert.3 : energiefluss-erweitert: Raspberrypi5                             - disabled
    + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
      system.adapter.fullcalendar.0           : fullcalendar          : Raspberrypi5                             - disabled
    + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
    + system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : Raspberrypi5                             -  enabled
    + system.adapter.hue.0                    : hue                   : Raspberrypi5                             -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
      system.adapter.ical.1                   : ical                  : Raspberrypi5                             - disabled
    + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : Raspberrypi5                             - disabled
    + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
    + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
    + system.adapter.matter.0                 : matter                : Raspberrypi5                             -  enabled
    + system.adapter.modbus.0                 : modbus                : Raspberrypi5                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : Raspberrypi5                             -  enabled
    + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
      system.adapter.openweathermap.0         : openweathermap        : Raspberrypi5                             -  enabled
    + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
    + system.adapter.pirate-weather.0         : pirate-weather        : Raspberrypi5                             -  enabled
    + system.adapter.reolink.0                : reolink               : Raspberrypi5                             -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
    + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
    + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
    + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Raspberrypi5                             - disabled
      system.adapter.wled.0                   : wled                  : Raspberrypi5                             - disabled
    + system.adapter.zigbee.0                 : zigbee                : Raspberrypi5                             -  enabled, port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a3b83b6a53aef11aaf2321455516304-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                      │ name                     │ version          │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '7.8.25'         │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'                 │ 'alexa2'                 │ '3.27.4'         │ 'none'         │
    │ 2       │ 'system.adapter.alias-manager'          │ 'alias-manager'          │ '2.1.0'          │ 'none'         │
    │ 3       │ 'system.adapter.alpha-ess'              │ 'alpha-ess'              │ '4.1.0'          │ 'none'         │
    │ 4       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'         │ 'none'         │
    │ 5       │ 'system.adapter.cloud'                  │ 'cloud'                  │ '6.0.4'          │ 'none'         │
    │ 6       │ 'system.adapter.devices'                │ 'devices'                │ '2.0.18'         │ 'none'         │
    │ 7       │ 'system.adapter.discovery'              │ 'discovery'              │ '5.0.0'          │ 'none'         │
    │ 8       │ 'system.adapter.e3oncan'                │ 'e3oncan'                │ '1.0.2'          │ 'none'         │
    │ 9       │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'          │ 'none'         │
    │ 10      │ 'system.adapter.fritzdect'              │ 'fritzdect'              │ '2.6.2'          │ 'none'         │
    │ 11      │ 'system.adapter.fullcalendar'           │ 'fullcalendar'           │ '2.4.5'          │ 'none'         │
    │ 12      │ 'system.adapter.hm-rega'                │ 'hm-rega'                │ '5.1.0'          │ 'none'         │
    │ 13      │ 'system.adapter.hm-rpc'                 │ 'hm-rpc'                 │ '3.0.2'          │ 'none'         │
    │ 14      │ 'system.adapter.homeconnect'            │ 'homeconnect'            │ '1.6.1'          │ 'none'         │
    │ 15      │ 'system.adapter.hue'                    │ 'hue'                    │ '3.16.2'         │ 'none'         │
    │ 16      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'         │ 'none'         │
    │ 17      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.3'          │ 'none'         │
    │ 18      │ 'system.adapter.iot'                    │ 'iot'                    │ '6.0.3'          │ 'none'         │
    │ 19      │ 'system.adapter.jarvis'                 │ 'jarvis'                 │ '4.0.0-alpha.13' │ 'none'         │
    │ 20      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'          │ 'none'         │
    │ 21      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'          │ 'none'         │
    │ 22      │ 'system.adapter.modbus'                 │ 'modbus'                 │ '8.1.3'          │ 'none'         │
    │ 23      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'          │ 'none'         │
    │ 24      │ 'system.adapter.net-tools'              │ 'net-tools'              │ '1.2.3'          │ 'none'         │
    │ 25      │ 'system.adapter.nspanel-lovelace-ui'    │ 'nspanel-lovelace-ui'    │ '0.17.8'         │ 'none'         │
    │ 26      │ 'system.adapter.nuki'                   │ 'nuki'                   │ '2.0.0'          │ 'none'         │
    │ 27      │ 'system.adapter.openweathermap'         │ 'openweathermap'         │ '1.4.0'          │ 'none'         │
    │ 28      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'          │ 'none'         │
    │ 29      │ 'system.adapter.pirate-weather'         │ 'pirate-weather'         │ '0.8.0'          │ 'none'         │
    │ 30      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'          │ 'none'         │
    │ 31      │ 'system.adapter.rpi2'                   │ 'rpi2'                   │ '3.0.2'          │ 'none'         │
    │ 32      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'          │ 'none'         │
    │ 33      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'          │ 'none'         │
    │ 34      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'          │ 'none'         │
    │ 35      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'          │ 'none'         │
    │ 36      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'          │ 'none'         │
    │ 37      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'          │ 'none'         │
    │ 38      │ 'system.adapter.whatsapp-cmb'           │ 'whatsapp-cmb'           │ '0.3.0'          │ 'none'         │
    │ 39      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'          │ 'none'         │
    │ 40      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'          │ 'none'         │
    │ 41      │ 'system.adapter.zigbee'                 │ 'zigbee'                 │ '3.4.5'          │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: beta
    Adapter    "admin"        : 7.8.25   , installed 7.8.25
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "alpha-ess"    : 4.1.0    , installed 4.1.0
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "cloud"        : 6.0.4    , installed 6.0.4
    Adapter    "devices"      : 2.0.18   , installed 2.0.18
    Adapter    "e3oncan"      : 1.0.2    , installed 1.0.2
    Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "hm-rpc"       : 3.0.2    , installed 3.0.2
    Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.20.1   , installed 1.20.1
    Adapter    "influxdb"     : 4.0.2    , installed 4.0.3
    Adapter    "iot"          : 6.0.3    , installed 6.0.3
    Adapter    "jarvis"       : 3.1.8    , installed 4.0.0-alpha.13
    Adapter    "javascript"   : 9.2.2    , installed 9.2.2
    Controller "js-controller": 7.1.2    , installed 7.1.2
    Adapter    "matter"       : 1.0.0    , installed 1.0.0
    Adapter    "modbus"       : 8.1.3    , installed 8.1.3
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "nspanel-lovelace-ui": 0.17.8, installed 0.17.8
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "ping"         : 2.2.4    , installed 2.2.4
    Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
    Adapter    "reolink"      : 1.4.2    , installed 1.4.2
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.1.0    , installed 8.1.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.9.2    , installed 0.9.2
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 3.4.5    , installed 3.4.5
    Objects and States
    Objects:        18712
    States:         18858
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Fetched 6922 B in 0s (35.0 kB/s)
    Reading package lists... Done
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid                   State                     Recv-Q                    Send-Q                                                     Local Address:Port                                                Peer Address:Port                   Process
    udp                     UNCONN                    0                         0        0.0.0.0:33196                                                    0.0.0.0:*                       users:(("avahi-daemon",pid=716,fd=14))
    udp                     UNCONN                    0                         0        0.0.0.0:43688                                                    0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=42))
    udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=39))
    udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=37))
    udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("avahi-daemon",pid=716,fd=12))
    udp                     UNCONN                    0                         0        0.0.0.0:5541                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=36))
    udp                     UNCONN                    0                         0        *:40920                                                          *:*                       users:(("io.matter.0",pid=2209,fd=41))
    udp                     UNCONN                    0                         0                                            [fe80::b78f:a4e0:4880:4be4]:dhcpv6-client                                                  *:*                       users:(("NetworkManager",pid=834,fd=38))
    udp                     UNCONN                    0                         0                                            [fe80::f05b:9255:16fc:d8b2]:dhcpv6-client                                                  *:*                       users:(("NetworkManager",pid=834,fd=35))
    udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("io.matter.0",pid=2209,fd=40))
    udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("io.matter.0",pid=2209,fd=38))
    udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("avahi-daemon",pid=716,fd=13))
    udp                     UNCONN                    0                         0        *:5541                                                           *:*                       users:(("io.matter.0",pid=2209,fd=35))
    udp                     UNCONN                    0                         0        *:56246                                                          *:*                       users:(("avahi-daemon",pid=716,fd=15))
    tcp                     LISTEN                    0                         511                                                       192.168.178.82:8087                                                     0.0.0.0:*                       users:(("io.simple-api.0",pid=2273,fd=35))
    tcp                     LISTEN                    0                         128                                                              0.0.0.0:ssh                                                      0.0.0.0:*                       users:(("sshd",pid=965,fd=6))
    tcp                     LISTEN                    0                         100                                                              0.0.0.0:1883                                                     0.0.0.0:*                       users:(("mosquitto",pid=991,fd=5))
    tcp                     LISTEN                    0                         511                                                              0.0.0.0:1886                                                     0.0.0.0:*                       users:(("io.sonoff.0",pid=1892,fd=40))
    tcp                     LISTEN                    0                         20                                                             127.0.0.1:smtp                                                     0.0.0.0:*                       users:(("exim4",pid=1250,fd=5))
    tcp                     LISTEN                    0                         511                                                            127.0.0.1:9000                                                     0.0.0.0:*                       users:(("iobroker.js-con",pid=1300,fd=29))
    tcp                     LISTEN                    0                         511                                                            127.0.0.1:9001                                                     0.0.0.0:*                       users:(("iobroker.js-con",pid=1300,fd=23))
    tcp                     LISTEN                    0                         511                                                       192.168.178.82:9292                                                     0.0.0.0:*                       users:(("io.hm-rpc.2",pid=2054,fd=35))
    tcp                     LISTEN                    0                         511                                                       192.168.178.82:18701                                                    0.0.0.0:*                       users:(("io.hm-rpc.0",pid=1660,fd=35))
    tcp                     LISTEN                    0                         511                                                       192.168.178.82:18702                                                    0.0.0.0:*                       users:(("io.hm-rpc.1",pid=1677,fd=35))
    tcp                     LISTEN                    0                         4096        *:3000                                                           *:*                       users:(("grafana",pid=1299,fd=18))
    tcp                     LISTEN                    0                         128        [::]:ssh                                                         [::]:*                       users:(("sshd",pid=965,fd=7))
    tcp                     LISTEN                    0                         511        *:8400                                                           *:*                       users:(("io.jarvis.0",pid=2184,fd=36))
    tcp                     LISTEN                    0                         100        [::]:1883                                                        [::]:*                       users:(("mosquitto",pid=991,fd=6))
    tcp                     LISTEN                    0                         20        [::1]:smtp                                                        [::]:*                       users:(("exim4",pid=1250,fd=6))
    tcp                     LISTEN                    0                         511        *:tproxy                                                         *:*                       users:(("io.admin.0",pid=1357,fd=39))
    tcp                     LISTEN                    0                         511        *:8082                                                           *:*                       users:(("io.web.0",pid=2327,fd=35))
    tcp                     LISTEN                    0                         511        *:8084                                                           *:*                       users:(("io.socketio.0",pid=2305,fd=34))
    tcp                     LISTEN                    0                         4096        *:8086                                                           *:*                       users:(("influxd",pid=979,fd=1547))
    2026-05-20 01:15:48.873  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-4W | Battery=366W | Bedarf=366W | Überschuss=4W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:15:50.000  - info: javascript.0 (1435) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-4W | PV_total:-1W | Batt:366W | Haus:369W | Tag:0.418kWh
    2026-05-20 01:15:54.612  - info: hm-rpc.2 (2054) xmlrpc <- listDevices ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c"]
    2026-05-20 01:15:54.650  - info: hm-rpc.2 (2054) xmlrpc -> 48 devices
    2026-05-20 01:15:54.713  - info: hm-rpc.2 (2054) xmlrpc <- newDevices 48
    2026-05-20 01:15:54.753  - info: hm-rpc.2 (2054) new virtual-devices devices/channels after filter: 0
    2026-05-20 01:15:54.756  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000004"]
    2026-05-20 01:15:54.759  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000005"]
    2026-05-20 01:15:54.763  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000006"]
    2026-05-20 01:15:54.766  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000007"]
    2026-05-20 01:15:54.769  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000010"]
    2026-05-20 01:15:54.772  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000014"]
    2026-05-20 01:15:58.873  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-11W | Battery=366W | Bedarf=366W | Überschuss=11W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:16:06.755  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-20 01:16:08.874  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-7W | Battery=366W | Bedarf=366W | Überschuss=7W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:16:18.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=0W | Battery=366W | Bedarf=366W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:16:27.110  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-20 01:16:28.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=6W | Battery=366W | Bedarf=372W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:16:38.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=11W | Battery=340W | Bedarf=351W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:16:48.263  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-20 01:16:48.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-4W | Battery=366W | Bedarf=366W | Überschuss=4W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:16:50.000  - info: javascript.0 (1435) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-7W | PV_total:-1W | Batt:366W | Haus:366W | Tag:0.424kWh
    2026-05-20 01:16:58.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-6W | Battery=366W | Bedarf=366W | Überschuss=6W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:17:08.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=12W | Battery=339W | Bedarf=351W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 01:17:09.154  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    ============= Mark until here for C&P =============
    iob diag has finished.
    • teletapiT teletapi
      Das sieht gut aus
      ```bash
      Script v.2026-05-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M          0B        209M
      Total:           17G        5.2G         10G
               4994 M used memory
               9730 M free memory
                199 M buffer memory
               1439 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      2.9G    /var/
      1.9G    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.8.25
      javascript:     9.2.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        18712
      States:         18858
      #849
      @teletapi
      Ich hab mit den Rechten noch was herumgespielt. Aber so ganz erklären kann ich mir das Verhalten auf deiner Kiste nicht.
      teletapiT 1 Antwort Letzte Antwort
        @teletapi
        teletapiT Online
        teletapiT Online
        teletapi
        #850
        System läuft aber auch top und ich kann keinerlei Fehler sehen oder bemerken. Vielleicht fällt ja irgendwann noch was auf. herzlichen dank für die Hilfe dazu
          @skvarel sagte:
          Ubuntu 24.04.4 ist aber doch LTS, oder?
          Ja, es ist zwar noch supportet, aber perspektivisch sollte das auf 26.04 'Resolute Raccoon' gehievt werden. Und genau das steht da. Wenn es EOL wäre würde das auch da stehen.
          Hab jetzt noch mal was geändert. Magst du noch mal testen?
          skvarelS Offline
          skvarelS Offline
          skvarel
          #851
          @Thomas-Braun sagte:
          Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
          *** LEBENSZYKLUS STATUS ***
          Die Unterstützung für das Betriebssystem mit dem Codenamen 'noble' läuft aus. Es sollte in nächster Zeit auf die aktuelle Version 'resolute' mit Langzeitunterstützung gebracht werden.
          #TeamInventwo
          Unsere Adapter:
          • BananaJoeB BananaJoe
            @skvarel und damit warten wir mindestens bis zur Version 26.04.1 - wenn diese erschienen ist, wird dich dein 24.04.x auch darauf Hinweisen das nun ein Inplace-Upgrade möglich wäre.
            Ob dann Inplace oder Neuinstallation dann der richtige Weg ist wäre eine andere Diskussion
            skvarelS Offline
            skvarelS Offline
            skvarel
            #852
            @BananaJoe sagte:
            Ich bin nicht gut im Erkennen von Ironie/Sarkasmus und schon gar nicht was Linux angeht ... ist das Warten ernst gemeint oder jetzt updaten?
            #TeamInventwo
            Unsere Adapter:
            • skvarelS skvarel
              @BananaJoe sagte:
              #853
              @skvarel sagte:
              Upgrades aus einer Bestandsversion sind offiziell erst nach der Veröffentlichung des ersten Point releases vorgesehen. Wer das vorzeitig machen will muss das ausdrücklich dem Upgrade mitgeben.
              sudo do-release-upgrade -d
              ist das. Später geht es dann ohne -d.
              Das Abwarten des ersten Point releases ist auch für Debian eine übliche Praxis. Dafür gibt es ja die einjährige Übergangsphase z.B.
              • skvarelS skvarel
                #854
                @skvarel sagte:
                Genau so soll es aussehen. Danke für's testen!
                skvarelS 1 Antwort Letzte Antwort
                  @skvarel sagte:
                  skvarelS Offline
                  skvarelS Offline
                  skvarel
                  #855
                  @Thomas-Braun .. sehr gerne und vielen Dank für den Fix 👍
                  Ich kann leider nicht mehr Voten
                  #TeamInventwo
                  Unsere Adapter:
                  • M MCU
                    @Thomas-Braun Gibt es die diag auch für Windows?
                    S Abwesend
                    S Abwesend
                    Shadowhunter23
                    #856
                    @Thomas-Braun
                    Ist es nicht möglich mit KI ein Windows iob_diag bauen zu lassen?
                    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                    ioBroker Backup Analyzer
                    • S Shadowhunter23
                      @Thomas-Braun
                      #857
                      @Shadowhunter23 sagte:
                      Da fragst du den richtigen...
                      Ich hab von Windows keine Ahnung, will ich auch nicht.
                      Und mit KIs und deren wiedersprüchlichen Ansinnen schlage ich mich schon genug herum.
                      Und dann wird doch auch immer erzählt, Windows ist viel 'einfacher' als dieses dämliche 'Linuggs-Geraffel', kann auch meine Oma beklicken. Wozu dann ein solches Diag-Skript? ;-)
                      • Thomas BraunT Online
                        #858
                        @skvarel @teletapi
                        Könnten die fleißigen Tester nochmal checken?
                        Ich hab gestern noch ein paar Dinge im Kampf mit zwei KIs umgestellt.
                        Optisch ändert sich nix gravierendes, nur bitte mal schauen ob die Ausgaben noch bzw. wieder plausibel sind.
                        Danke schön!
                        Super wäre auch mal ein komplexeres ZigBee-Konstrukt mit mehreren Koordinatoren und/oder mehreren Anschlüssen (per TCP oder USB) zu sehen. Aber die Konstellation ist wohl nicht gar so häufig in freier Wildbahn anzutreffen.
                        • skvarelS Offline
                          skvarelS Offline
                          skvarel
                          schrieb am zuletzt editiert von skvarel
                          #859
                          ./iob_diag.sh
                          ```bash
                          Script v.2026-05-20
                          *** BASE SYSTEM ***
                          Operating System: Ubuntu 24.04.4 LTS
                           Static hostname: ioBroker
                                 Icon name: computer-desktop
                                   Chassis: desktop 🖥️
                                    Kernel: Linux 6.8.0-117-generic
                              Architecture: x86-64
                           Hardware Vendor: Dell Inc.
                            Hardware Model: OptiPlex 3050
                          Firmware Version: 1.6.5
                             Firmware Date: Sat 2017-09-09
                              Firmware Age: 8y 8month 1w 3d
                          OS is similar to: debian
                          model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
                          Docker          : false
                          Unknown
                          Kernel          : x86_64
                          Userland        : 64bit
                          System was installed 243 days ago (on 2025-09-19).
                           11:17:00 up 3 days,  4:15,  1 user,  load average: 0.54, 0.66, 0.76
                          CPU threads     : 4
                                         Local time: Thu 2026-05-21 11:17:00 CEST
                                     Universal time: Thu 2026-05-21 09:17:00 UTC
                                           RTC time: Thu 2026-05-21 09:17:00
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          GROUPS=pi adm cdrom sudo dip plugdev lxd iobroker
                          iobroker[sudo] password for pi:
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video plugdev redis
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Mem:             16G        9.7G        2.9G        5.0M        4.5G        7.0G
                          Swap:           4.3G          0B        4.3G
                          Total:           20G        9.7G        7.2G
                          Active iob-Instances:   53
                                  15877 M total memory
                                   9220 M used memory
                                   9344 M active memory
                                   2736 M inactive memory
                                   2735 M free memory
                                    800 M buffer memory
                                   3461 M swap cache
                                   4095 M total swap
                                      0 M used swap
                                   4095 M free swap
                          top - 11:17:11 up 3 days,  4:15,  1 user,  load average: 0.68, 0.68, 0.76
                          Tasks: 233 total,   1 running, 232 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  9.8 us,  5.9 sy,  0.0 ni, 82.4 id,  0.0 wa,  0.0 hi,  2.0 si,  0.0 st
                          MiB Mem :  15877.7 total,   2734.3 free,   9222.2 used,   4262.3 buff/cache
                          MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6655.5 avail Mem
                          *** FILESYSTEM ***
                          Filesystem                        Type   Size  Used Avail Use% Mounted on
                          tmpfs                             tmpfs  1.6G  4.6M  1.6G   1% /run
                          /dev/mapper/ubuntu--vg-ubuntu--lv ext4   467G   20G  428G   5% /
                          tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
                          tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                          /dev/nvme0n1p2                    ext4   2.0G  200M  1.6G  11% /boot
                          tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
                          [Mon May 18 07:01:29 2026] Btrfs loaded, zoned=yes, fsverity=yes
                          [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): mounted filesystem a547182b-43b5-440e-b6fe-09323774b05c ro with ordered data mode. Quota mode: none.
                          [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): re-mounted a547182b-43b5-440e-b6fe-09323774b05c r/w.
                          [Mon May 18 07:01:30 2026] EXT4-fs (nvme0n1p2): mounted filesystem 7a71a3d0-fb5e-4ed0-8d6d-dc24002c0eef r/w with ordered data mode. Quota mode: none.
                          /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
                          `-/boot /dev/nvme0n1p2                    ext4   rw,relatime
                          /var:
                          5.3G    /var/
                          4.4G    /var/log
                          4.2G    /var/log/journal/b521ee0ca8cb46db87113e33c1d11d82
                          760M    /var/lib
                          Archived and active journals take up 4.1G in the file system.
                          190M    /opt/iobroker/backups/
                          502M    /opt/iobroker/iobroker-data/
                          329M    /opt/iobroker/iobroker-data/files
                          132M    /opt/iobroker/iobroker-data/backup-objects
                          56M     /opt/iobroker/iobroker-data/files/vis-2
                          47M     /opt/iobroker/iobroker-data/files/admin.admin
                          38M     /opt/iobroker/iobroker-data/objects.jsonl
                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                          9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                          USB-Devices by-id:
                          No Devices found 'by-id'
                          No nvbackup.json found.
                          /usr/bin/nodejs         v22.22.2
                          /usr/bin/node           v22.22.2
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          nodejs:
                            Installed: 22.22.2-1nodesource1
                            Candidate: 22.22.2-1nodesource1
                            Version table:
                           *** 22.22.2-1nodesource1 1001
                               22.22.1-1nodesource1 1001
                               22.22.0-1nodesource1 1001
                               22.21.0-1nodesource1 1001
                               22.20.0-1nodesource1 1001
                               22.19.0-1nodesource1 1001
                               22.18.0-1nodesource1 1001
                               22.17.1-1nodesource1 1001
                               22.17.0-1nodesource1 1001
                               22.16.0-1nodesource1 1001
                               22.15.1-1nodesource1 1001
                               22.15.0-1nodesource1 1001
                               22.14.0-1nodesource1 1001
                               22.13.1-1nodesource1 1001
                               22.13.0-1nodesource1 1001
                               22.12.0-1nodesource1 1001
                               22.11.0-1nodesource1 1001
                               22.10.0-1nodesource1 1001
                               22.9.0-1nodesource1 1001
                               22.8.0-1nodesource1 1001
                               22.7.0-1nodesource1 1001
                               22.6.0-1nodesource1 1001
                               22.5.1-1nodesource1 1001
                               22.5.0-1nodesource1 1001
                               22.4.1-1nodesource1 1001
                               22.4.0-1nodesource1 1001
                               22.3.0-1nodesource1 1001
                               22.2.0-1nodesource1 1001
                               22.1.0-1nodesource1 1001
                               22.0.0-1nodesource1 1001
                               18.19.1+dfsg-6ubuntu5 500
                                  500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          Hosts:
                          ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152296)
                          admin:          7.8.25
                          javascript:     9.2.2
                          nodejs modules from github:     3
                          +-- iobroker.energiefluss-erweitert@0.8.2 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#89dbb71bf0fc70044249fd6453c25194130d9971)
                          +-- iobroker.foxesscloud@0.4.0 (git+ssh://git@github.com/inventwo/ioBroker.foxesscloud.git#9c22623f35cd02277a4a3dcc145ada655b4e9080)
                          +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                          + system.adapter.autodarts.0              : autodarts             : ioBroker                                 -  enabled, port: 3180
                          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                          + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
                            system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                          + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
                          + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                          + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                          + system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
                          + system.adapter.discovergy.0             : discovergy            : ioBroker                                 -  enabled
                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
                          + system.adapter.enpal.0                  : enpal                 : ioBroker                                 -  enabled
                            system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                            system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                            system.adapter.foxesscloud.0            : foxesscloud           : ioBroker                                 - disabled
                          + system.adapter.foxesscloud.1            : foxesscloud           : ioBroker                                 -  enabled
                          + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
                          + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                            system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                            system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
                            system.adapter.ical.4                   : ical                  : ioBroker                                 -  enabled
                          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                          + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                          + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
                          + system.adapter.javascript.2             : javascript            : ioBroker                                 -  enabled
                          + system.adapter.javascript.3             : javascript            : ioBroker                                 -  enabled
                          + system.adapter.javascript.5             : javascript            : ioBroker                                 -  enabled
                          + system.adapter.life360ng.0              : life360ng             : ioBroker                                 -  enabled
                          + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                          + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                          + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ioBroker                                 - disabled, port: 16021
                          + system.adapter.operating-hours.0        : operating-hours       : ioBroker                                 -  enabled
                          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                          + system.adapter.reolink.5                : reolink               : ioBroker                                 -  enabled
                          + system.adapter.reolink.6                : reolink               : ioBroker                                 -  enabled
                          + system.adapter.reolink.7                : reolink               : ioBroker                                 -  enabled
                          + system.adapter.reolink.8                : reolink               : ioBroker                                 -  enabled
                            system.adapter.reolink.9                : reolink               : ioBroker                                 - disabled
                            system.adapter.seq.0                    : seq                   : ioBroker                                 - disabled, port: 443
                          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
                          + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                            system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
                          + system.adapter.sureflap.0               : sureflap              : ioBroker                                 -  enabled
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.tidy.0                   : tidy                  : ioBroker                                 -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                            system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
                          + system.adapter.trashschedule.1          : trashschedule         : ioBroker                                 -  enabled
                          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                            system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
                            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
                          + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                          + system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 -  enabled
                          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 -  enabled, port: 5000
                          + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                          + system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
                          + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                          + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
                          + instance is alive
                          │ 0       │ 'Beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                          │ 1       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                          Active repo(s): Beta
                          │ 2       │ 'system.adapter.autodarts'              │ 'autodarts'              │ '1.0.8'   │ 'none'         │
                          │ 3       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'  │ 'none'         │
                          │ 4       │ 'system.adapter.bambulab'               │ 'bambulab'               │ '0.4.3'   │ 'none'         │
                          │ 5       │ 'system.adapter.birthdays'              │ 'birthdays'              │ '6.0.1'   │ 'none'         │
                          │ 6       │ 'system.adapter.brightsky'              │ 'brightsky'              │ '1.1.0'   │ 'none'         │
                          │ 7       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'   │ 'none'         │
                          │ 8       │ 'system.adapter.device-watcher'         │ 'device-watcher'         │ '2.15.15' │ 'none'         │
                          │ 9       │ 'system.adapter.devices'                │ 'devices'                │ '2.1.1'   │ 'none'         │
                          │ 10      │ 'system.adapter.discovergy'             │ 'discovergy'             │ '0.7.0'   │ 'none'         │
                          │ 11      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
                          │ 12      │ 'system.adapter.enpal'                  │ 'enpal'                  │ '0.2.0'   │ 'none'         │
                          │ 13      │ 'system.adapter.fb-checkpresence'       │ 'fb-checkpresence'       │ '1.4.2'   │ 'none'         │
                          │ 14      │ 'system.adapter.feiertage'              │ 'feiertage'              │ '1.4.0'   │ 'none'         │
                          │ 15      │ 'system.adapter.foxesscloud'            │ 'foxesscloud'            │ '0.4.0'   │ 'none'         │
                          │ 16      │ 'system.adapter.harmony'                │ 'harmony'                │ '2.1.0'   │ 'none'         │
                          │ 17      │ 'system.adapter.hmip'                   │ 'hmip'                   │ '1.27.0'  │ 'none'         │
                          │ 18      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
                          │ 19      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
                          │ 21      │ 'system.adapter.life360ng'              │ 'life360ng'              │ '1.9.1'   │ 'none'         │
                          │ 22      │ 'system.adapter.linux-control'          │ 'linux-control'          │ '1.1.6'   │ 'none'         │
                          │ 23      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'   │ 'none'         │
                          │ 24      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'   │ 'none'         │
                          │ 25      │ 'system.adapter.nanoleaf-lightpanels'   │ 'nanoleaf-lightpanels'   │ '1.6.0'   │ 'none'         │
                          │ 26      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'   │ 'none'         │
                          │ 27      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
                          │ 28      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'   │ 'none'         │
                          │ 29      │ 'system.adapter.seq'                    │ 'seq'                    │ '1.0.2'   │ 'none'         │
                          │ 30      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
                          │ 31      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
                          │ 32      │ 'system.adapter.snmp'                   │ 'snmp'                   │ '3.4.0'   │ 'none'         │
                          │ 33      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'   │ 'none'         │
                          │ 34      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14'  │ 'none'         │
                          │ 35      │ 'system.adapter.spotify-premium'        │ 'spotify-premium'        │ '2.0.3'   │ 'none'         │
                          │ 36      │ 'system.adapter.sureflap'               │ 'sureflap'               │ '3.4.2'   │ 'none'         │
                          │ 37      │ 'system.adapter.tankerkoenig'           │ 'tankerkoenig'           │ '3.4.0'   │ 'none'         │
                          │ 38      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'   │ 'none'         │
                          │ 39      │ 'system.adapter.tidy'                   │ 'tidy'                   │ '0.1.1'   │ 'none'         │
                          │ 40      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'   │ 'none'         │
                          │ 41      │ 'system.adapter.trashschedule'          │ 'trashschedule'          │ '5.3.0'   │ 'none'         │
                          │ 42      │ 'system.adapter.tuya'                   │ 'tuya'                   │ '3.17.0'  │ 'none'         │
                          │ 43      │ 'system.adapter.vis-2'                  │ 'vis-2'                  │ '2.13.19' │ 'none'         │
                          │ 44      │ 'system.adapter.vis-2-widgets-icontwo'  │ 'vis-2-widgets-icontwo'  │ '1.40.0'  │ 'none'         │
                          │ 45      │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.0.0'   │ 'none'         │
                          │ 46      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.3'  │ 'none'         │
                          │ 47      │ 'system.adapter.wallpanel'              │ 'wallpanel'              │ '0.3.11'  │ 'none'         │
                          │ 48      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'   │ 'none'         │
                          │ 49      │ 'system.adapter.wiobrowser'             │ 'wiobrowser'             │ '2.0.2'   │ 'none'         │
                          │ 50      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'   │ 'none'         │
                          │ 51      │ 'system.adapter.worx'                   │ 'worx'                   │ '3.3.0'   │ 'none'         │
                          │ 52      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
                          │ 53      │ 'system.adapter.zigbee2mqtt'            │ 'zigbee2mqtt'            │ '3.2.1'   │ 'none'         │
                          Used repository: Beta
                          Adapter    "autodarts"    : 1.0.8    , installed 1.0.8
                          Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
                          Adapter    "birthdays"    : 6.0.1    , installed 6.0.1
                          Adapter    "brightsky"    : 1.1.0    , installed 1.1.0
                          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                          Adapter    "device-watcher": 2.15.15 , installed 2.15.15
                          Adapter    "devices"      : 2.1.1    , installed 2.1.1
                          Adapter    "discovergy"   : 0.7.0    , installed 0.7.0
                          Adapter    "enpal"        : 0.2.0    , installed 0.2.0
                          Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                          Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
                          Adapter    "foxesscloud"  : 0.4.0    , installed 0.4.0
                          Adapter    "harmony"      : 2.1.0    , installed 2.1.0
                          Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                          Adapter    "life360ng"    : 1.9.1    , installed 1.9.1
                          Adapter    "linux-control": 1.1.5    , installed 1.1.6
                          Adapter    "nanoleaf-lightpanels": 1.6.0, installed 1.6.0
                          Adapter    "operating-hours": 1.5.1  , installed 1.5.1
                          Adapter    "seq"          : 1.0.2    , installed 1.0.2
                          Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                          Adapter    "snmp"         : 3.4.0    , installed 3.4.0
                          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                          Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
                          Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                          Adapter    "trashschedule": 5.3.0    , installed 5.3.0
                          Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                          Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
                          Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
                          Adapter    "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
                          Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                          Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                          Adapter    "worx"         : 3.3.0    , installed 3.3.0
                          Adapter    "zigbee2mqtt"  : 3.2.1    , installed 3.2.1
                          Objects and States
                          Objects:        22292
                          States:         22954
                          Hit:1 https://apt.grafana.com stable InRelease
                          Get:2 https://repos.influxdata.com/debian stable InRelease [6922 B]
                          Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
                          Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
                          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                          Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                          Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                          Hit:8 https://packages.redis.io/deb noble InRelease
                          Fetched 6922 B in 1s (7313 B/s)
                          Pending systemupdates: 2
                          udp       UNCONN     0          0                                         0.0.0.0:61991                      0.0.0.0:*        users:(("io.harmony.0",pid=612834,fd=30))
                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=42))
                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=40))
                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.wled.0",pid=614951,fd=22))
                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=38))
                          udp       UNCONN     0          0                                         0.0.0.0:5540                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=46))
                          udp       UNCONN     0          0                                         0.0.0.0:5541                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=37))
                          udp       UNCONN     0          0                                         0.0.0.0:5542                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=47))
                          udp       UNCONN     0          0                                         0.0.0.0:6666                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=53))
                          udp       UNCONN     0          0                                         0.0.0.0:6667                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=54))
                          udp       UNCONN     0          0                                      127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=16))
                          udp       UNCONN     0          0                                   127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=14))
                          udp       UNCONN     0          0                          192.168.130.130%enp2s0:bootpc                     0.0.0.0:*        users:(("systemd-network",pid=512,fd=24))
                          udp       UNCONN     0          0                                         0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=5),("systemd",pid=1,fd=270))
                          udp       UNCONN     0          0                                  172.18.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=25))
                          udp       UNCONN     0          0                                      172.18.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=24))
                          udp       UNCONN     0          0                                  172.17.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=21))
                          udp       UNCONN     0          0                                      172.17.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=20))
                          udp       UNCONN     0          0                                 192.168.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=16))
                          udp       UNCONN     0          0                                 192.168.130.130:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=15))
                          udp       UNCONN     0          0                                         0.0.0.0:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=13))
                          udp       UNCONN     0          0                                  172.18.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=27))
                          udp       UNCONN     0          0                                      172.18.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=26))
                          udp       UNCONN     0          0                                  172.17.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=23))
                          udp       UNCONN     0          0                                      172.17.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=22))
                          udp       UNCONN     0          0                                 192.168.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=18))
                          udp       UNCONN     0          0                                 192.168.130.130:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=17))
                          udp       UNCONN     0          0                                         0.0.0.0:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=14))
                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=44))
                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=43))
                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=41))
                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=39))
                          udp       UNCONN     0          0                                            [::]:5540                          [::]:*        users:(("io.matter.0",pid=614373,fd=45))
                          udp       UNCONN     0          0                                            [::]:5541                          [::]:*        users:(("io.matter.0",pid=614373,fd=36))
                          udp       UNCONN     0          0                                            [::]:5542                          [::]:*        users:(("io.matter.0",pid=614373,fd=35))
                          udp       UNCONN     0          0                                            [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=7),("systemd",pid=1,fd=272))
                          udp       UNCONN     0          0              [fe80::da9e:f3ff:fe78:3132]%enp2s0:dhcpv6-client                 [::]:*        users:(("systemd-network",pid=512,fd=22))
                          tcp       LISTEN     0          50                                        0.0.0.0:netbios-ssn                0.0.0.0:*        users:(("smbd",pid=1007,fd=31))
                          tcp       LISTEN     0          4096                                      0.0.0.0:ssh                        0.0.0.0:*        users:(("sshd",pid=2422,fd=3),("systemd",pid=1,fd=101))
                          tcp       LISTEN     0          4096                                      0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=4),("systemd",pid=1,fd=269))
                          tcp       LISTEN     0          4096                                   127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=17))
                          tcp       LISTEN     0          4096                                      0.0.0.0:http                       0.0.0.0:*        users:(("docker-proxy",pid=1323,fd=7))
                          tcp       LISTEN     0          50                                        0.0.0.0:microsoft-ds               0.0.0.0:*        users:(("smbd",pid=1007,fd=30))
                          tcp       LISTEN     0          511                                       0.0.0.0:1885                       0.0.0.0:*        users:(("io.mqtt.0",pid=613007,fd=34))
                          tcp       LISTEN     0          511                                       0.0.0.0:1883                       0.0.0.0:*        users:(("io.sonoff.0",pid=613163,fd=40))
                          tcp       LISTEN     0          511                                       0.0.0.0:1882                       0.0.0.0:*        users:(("io.shelly.0",pid=614225,fd=36))
                          tcp       LISTEN     0          511                                     127.0.0.1:9001                       0.0.0.0:*        users:(("iobroker.js-con",pid=612180,fd=23))
                          tcp       LISTEN     0          4096                                    127.0.0.1:34169                      0.0.0.0:*        users:(("containerd",pid=764,fd=15))
                          tcp       LISTEN     0          511                                     127.0.0.1:redis                      0.0.0.0:*        users:(("redis-server",pid=720,fd=20))
                          tcp       LISTEN     0          4096                                127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=15))
                          tcp       LISTEN     0          50                                           [::]:netbios-ssn                   [::]:*        users:(("smbd",pid=1007,fd=29))
                          tcp       LISTEN     0          4096                                         [::]:ssh                           [::]:*        users:(("sshd",pid=2422,fd=4),("systemd",pid=1,fd=102))
                          tcp       LISTEN     0          4096                                         [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=6),("systemd",pid=1,fd=271))
                          tcp       LISTEN     0          4096                                         [::]:http                          [::]:*        users:(("docker-proxy",pid=1330,fd=7))
                          tcp       LISTEN     0          50                                           [::]:microsoft-ds                  [::]:*        users:(("smbd",pid=1007,fd=28))
                          tcp       LISTEN     0          4096                                            *:3000                             *:*        users:(("grafana",pid=1463,fd=26))
                          tcp       LISTEN     0          511                                             *:61991                            *:*        users:(("io.harmony.0",pid=612834,fd=29))
                          tcp       LISTEN     0          511                                         [::1]:redis                         [::]:*        users:(("redis-server",pid=720,fd=21))
                          tcp       LISTEN     0          511                                             *:8087                             *:*        users:(("io.simple-api.0",pid=614626,fd=35))
                          tcp       LISTEN     0          4096                                            *:8086                             *:*        users:(("influxd",pid=946,fd=358))
                          tcp       LISTEN     0          511                                             *:8084                             *:*        users:(("io.ws.0",pid=614776,fd=34))
                          tcp       LISTEN     0          511                                             *:8082                             *:*        users:(("io.web.0",pid=612361,fd=35))
                          tcp       LISTEN     0          511                                             *:tproxy                           *:*        users:(("io.admin.0",pid=612200,fd=39))
                          2026-05-21 11:00:07.069  - info: ical.1 (1343691) processing URL: xxx
                          2026-05-21 11:00:08.171  - info: host.ioBroker instance system.adapter.ical.3 in version "1.20.1" started with pid 1343725
                          2026-05-21 11:00:08.497  - info: ical.0 (1343653) Terminated (NO_ERROR): Without reason
                          2026-05-21 11:00:09.021  - info: host.ioBroker instance system.adapter.ical.0 having pid 1343653 terminated with code 0 (NO_ERROR)
                          2026-05-21 11:00:10.036  - info: ical.3 (1343725) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                          2026-05-21 11:00:10.837  - info: ical.3 (1343725) processing URL: Jannis https://calendar.google.com/calendar/ical/0815%40group.calendar.google.com/private-0815/basic.ics
                          2026-05-21 11:00:12.326  - info: ical.1 (1343691) Terminated (NO_ERROR): Without reason
                          2026-05-21 11:00:12.852  - info: host.ioBroker instance system.adapter.ical.1 having pid 1343691 terminated with code 0 (NO_ERROR)
                          2026-05-21 11:00:16.030  - info: ical.3 (1343725) Terminated (NO_ERROR): Without reason
                          2026-05-21 11:00:16.592  - info: host.ioBroker instance system.adapter.ical.3 having pid 1343725 terminated with code 0 (NO_ERROR)
                          2026-05-21 11:00:31.696  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
                          2026-05-21 11:00:57.303  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Home → in der Ladestation
                          2026-05-21 11:04:57.953  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
                          2026-05-21 11:10:13.946  - info: alexa2.0 (869734) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
                          2026-05-21 11:10:15.455  - info: alexa2.0 (869734) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2026-05-21 11:15:00.094  - info: host.ioBroker instance system.adapter.ical.1 in version "1.20.1" started with pid 1347962
                          2026-05-21 11:15:01.965  - info: ical.1 (1347962) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                          2026-05-21 11:15:02.781  - info: ical.1 (1347962) processing URL: xxx
                          2026-05-21 11:15:04.113  - info: host.ioBroker instance system.adapter.ical.0 in version "1.20.1" started with pid 1348018
                          2026-05-21 11:15:05.832  - info: ical.0 (1348018) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                          2026-05-21 11:15:06.610  - info: ical.0 (1348018) processing URL: xxx
                          2026-05-21 11:15:08.103  - info: ical.1 (1347962) Terminated (NO_ERROR): Without reason
                          2026-05-21 11:15:08.658  - info: host.ioBroker instance system.adapter.ical.1 having pid 1347962 terminated with code 0 (NO_ERROR)
                          2026-05-21 11:15:11.941  - info: ical.0 (1348018) Terminated (NO_ERROR): Without reason
                          2026-05-21 11:15:12.502  - info: host.ioBroker instance system.adapter.ical.0 having pid 1348018 terminated with code 0 (NO_ERROR)
                          ./iob_diag.sh --de
                          ```bash
                          Script v.2026-05-20
                          *** GRUNDSYSTEM ***
                                   Chassis: desktop 🖥️
                          Docker          : false
                          Unknown
                          Kernel          : x86_64
                          Userland        : 64bit
                          Das System wurde vor 243 Tagen installiert (am 19.09.2025).
                           11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
                          CPU threads     : 4
                          *** ZEIT UND ZEITZONEN ***
                                         Local time: Thu 2026-05-21 11:21:33 CEST
                                     Universal time: Thu 2026-05-21 09:21:33 UTC
                                           RTC time: Thu 2026-05-21 09:21:33
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User und Gruppen ***
                          User der 'iob diag' aufgerufen hat:
                          pi
                          HOME=/home/pi
                          User der den 'js-controller' ausführt:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           4.3G          0B        4.3G
                                   9221 M used memory
                                   9345 M active memory
                                   2737 M inactive memory
                                   2733 M free memory
                                    801 M buffer memory
                                   3462 M swap cache
                                   4095 M total swap
                                      0 M used swap
                                   4095 M free swap
                          top - 11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
                          Tasks: 235 total,   2 running, 233 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 18.6 us,  9.3 sy,  0.0 ni, 72.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  15877.7 total,   2737.4 free,   9218.2 used,   4263.2 buff/cache
                          MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6659.5 avail Mem
                          Es wurden keine kritischen Fehler gefunden
                          *** FILESYSTEM ***
                          /var:
                          5.3G    /var/
                          4.4G    /var/log
                          760M    /var/lib
                          USB-Devices by-id:
                          USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
                          bevorzuge immer die Links 'by-id':
                          Keine Geräte gefunden 'by-id'
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          ✓ Node.js ist korrekt installiert
                          nodejs:
                            Version table:
                          Keine bekannten Sicherheitslücken in der Node.js-Version erkannt!
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          Hosts:
                          ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152566)
                          admin:          7.8.25
                          javascript:     9.2.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        22292
                          States:         22954
                          Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
                          Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
                          Get:4 https://repos.influxdata.com/debian stable InRelease [6922 B]
                          Fetched 6922 B in 1s (7184 B/s)
                          Offene Systemupdates: 2
                          EDIT:
                          Mit internem Zigbee kann ich nicht dienen. Ich nutze Zigbee2mqqt auf einer separaten Hardware
                          #TeamInventwo
                          Unsere Adapter:
                          • skvarelS skvarel
                            ./iob_diag.sh
                            ```bash
                            Script v.2026-05-20
                            *** BASE SYSTEM ***
                                     Chassis: desktop 🖥️
                            Docker          : false
                            Unknown
                            Kernel          : x86_64
                            Userland        : 64bit
                            CPU threads     : 4
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            HOME=/home/iobroker
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           4.3G          0B        4.3G
                                     9220 M used memory
                                     2735 M free memory
                                      800 M buffer memory
                                     3461 M swap cache
                                     4095 M total swap
                                        0 M used swap
                                     4095 M free swap
                            *** FILESYSTEM ***
                            /var:
                            5.3G    /var/
                            4.4G    /var/log
                            760M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            Hosts:
                            admin:          7.8.25
                            javascript:     9.2.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        22292
                            States:         22954
                            ./iob_diag.sh --de
                            ```bash
                            Script v.2026-05-20
                            *** GRUNDSYSTEM ***
                                     Chassis: desktop 🖥️
                            Docker          : false
                            Unknown
                            Kernel          : x86_64
                            Userland        : 64bit
                            CPU threads     : 4
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           4.3G          0B        4.3G
                                     9221 M used memory
                                     2733 M free memory
                                      801 M buffer memory
                                     3462 M swap cache
                                     4095 M total swap
                                        0 M used swap
                                     4095 M free swap
                            *** FILESYSTEM ***
                            /var:
                            5.3G    /var/
                            4.4G    /var/log
                            760M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            Hosts:
                            admin:          7.8.25
                            javascript:     9.2.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        22292
                            States:         22954
                            EDIT:
                            #860
                            @skvarel sagte:
                            Das hilft mir aber auch. Das Skript erkennt die Situation und gibt dann in deinem Fall auch erst gar nichts konkret zu Zigbee aus. Nur:
                            USB-Devices by-id:
                            • skvarelS skvarel
                              ./iob_diag.sh
                              ```bash
                              Script v.2026-05-20
                              *** BASE SYSTEM ***
                                       Chassis: desktop 🖥️
                              Docker          : false
                              Unknown
                              Kernel          : x86_64
                              Userland        : 64bit
                              CPU threads     : 4
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              HOME=/home/iobroker
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           4.3G          0B        4.3G
                                       9220 M used memory
                                       2735 M free memory
                                        800 M buffer memory
                                       3461 M swap cache
                                       4095 M total swap
                                          0 M used swap
                                       4095 M free swap
                              *** FILESYSTEM ***
                              /var:
                              5.3G    /var/
                              4.4G    /var/log
                              760M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: redis
                              Hosts:
                              admin:          7.8.25
                              javascript:     9.2.2
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        22292
                              States:         22954
                              ./iob_diag.sh --de
                              ```bash
                              Script v.2026-05-20
                              *** GRUNDSYSTEM ***
                                       Chassis: desktop 🖥️
                              Docker          : false
                              Unknown
                              Kernel          : x86_64
                              Userland        : 64bit
                              CPU threads     : 4
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           4.3G          0B        4.3G
                                       9221 M used memory
                                       2733 M free memory
                                        801 M buffer memory
                                       3462 M swap cache
                                       4095 M total swap
                                          0 M used swap
                                       4095 M free swap
                              *** FILESYSTEM ***
                              /var:
                              5.3G    /var/
                              4.4G    /var/log
                              760M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: redis
                              Hosts:
                              admin:          7.8.25
                              javascript:     9.2.2
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        22292
                              States:         22954
                              EDIT:
                              #861
                              @skvarel
                              Ich hätte dich angechattet, aber das funktioniert nicht.
                              Du hast im Ausschnitt des Logs private Daten drin.
                                @skvarel
                                skvarelS Offline
                                skvarelS Offline
                                skvarel
                                #862
                                @Thomas-Braun .. jetzt solltest du mit mir chatten können
                                #TeamInventwo
                                Unsere Adapter:
                                • NashraN Offline
                                  NashraN Offline
                                  Nashra
                                  Most Active Forum Testing
                                  schrieb am zuletzt editiert von Nashra
                                  #863
                                  Hier von dem aktuellen Script...
                                  ```bash
                                  Script v.2026-05-20
                                  *** BASE SYSTEM ***
                                         Icon name: computer-container
                                           Chassis: container ☐
                                    Virtualization: lxc
                                            Kernel: Linux 7.0.2-4-pve
                                  OS is similar to:
                                  model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
                                  Docker          : false
                                  Virtualization  : lxc
                                  Kernel          : x86_64
                                  Userland        : 64bit
                                  System was installed 163 days ago (on 2025-12-08).
                                   11:54:32 up 18:17,  0 users,  load average: 2.96, 2.91, 2.78
                                  CPU threads     : 4
                                                 Local time: Thu 2026-05-21 11:54:32 CEST
                                             Universal time: Thu 2026-05-21 09:54:32 UTC
                                                   RTC time: n/a
                                                NTP service: inactive
                                            RTC in local TZ: no
                                  jack
                                  HOME=/home/jack
                                  GROUPS=jack sudo users iobroker
                                  iobroker[sudo] password for jack:
                                  HOME=/home/iobroker
                                  Desktop:
                                  Session:
                                  *** MEMORY ***
                                  Mem:             12G        6.5G        5.2G        3.2M        1.2G        6.4G
                                  Swap:             0B          0B          0B
                                  Total:           12G        6.5G        5.2G
                                  Active iob-Instances:   51
                                          12288 M total memory
                                           6165 M used memory
                                           1229 M active memory
                                           5857 M inactive memory
                                           4936 M free memory
                                              0 M buffer memory
                                           1189 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  top - 11:54:37 up 18:17,  0 users,  load average: 2.80, 2.88, 2.77
                                  Tasks:  77 total,   2 running,  75 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s): 48.8 us,  7.3 sy,  0.0 ni, 41.5 id,  0.0 wa,  0.0 hi,  2.4 si,  0.0 st
                                  MiB Mem :  12288.0 total,   4933.0 free,   6167.9 used,   1189.9 buff/cache
                                  MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6120.1 avail Mem
                                  dmesg: read kernel buffer failed: Operation not permitted
                                  *** FILESYSTEM ***
                                  /dev/mapper/pve-vm--100--disk--0 ext4       25G   12G   12G  52% /
                                  none                             tmpfs     492K  4.0K  488K   1% /dev
                                  none                             tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                                  udev                             devtmpfs  6.9G     0  6.9G   0% /dev/tty
                                  tmpfs                            tmpfs     3.2G  104K  3.2G   1% /run
                                  tmpfs                            tmpfs     7.8G  3.0M  7.8G   1% /tmp
                                  /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                                  /var:
                                  2.4G    /var/
                                  2.1G    /var/log/journal/d283c01113b6426689c9fe48dd9c672b
                                  2.1G    /var/log
                                  169M    /var/lib
                                  Archived and active journals take up 551M in the file system.
                                  1.7G    /opt/iobroker/backups/
                                  2.7G    /opt/iobroker/iobroker-data/
                                  1.1G    /opt/iobroker/iobroker-data/backup-objects
                                  816M    /opt/iobroker/iobroker-data/files
                                  655M    /opt/iobroker/iobroker-data/history
                                  269M    /opt/iobroker/iobroker-data/files/vis.0
                                  97M     /opt/iobroker/iobroker-data/states.jsonl
                                  58M     /opt/iobroker/iobroker-data/objects.jsonl
                                  35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_11-37_states.jsonl.gz
                                  35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_09-37_states.jsonl.gz
                                  35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_07-37_states.jsonl.gz
                                  USB-Devices by-id:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  zigbee.0        ...936c4ce259fb3e-if00-port0        ...936c4ce259fb3e-if00-port0        ✓ Matching
                                  /usr/bin/npm            10.9.7
                                  /usr/bin/npx            10.9.7
                                  nodejs:
                                    Version table:
                                          500 http://security.debian.org trixie-security/main amd64 Packages
                                          500 http://deb.debian.org/debian trixie/main amd64 Packages
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 65841)
                                  js-controller:  7.0.7
                                  admin:          7.8.23
                                  javascript:     9.0.18
                                  nodejs modules from github:     10
                                  +-- iobroker.dwd@2.8.5 (git+ssh://git@github.com/arteck/ioBroker.dwd.git#d01fd75bacd6f2bd2c7b0612181e6118693bab71)
                                  +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
                                  +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
                                  +-- iobroker.logparser@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.logparser.git#266cccca93fd6f272ebce95e8f9e936363c30263)
                                  +-- iobroker.openmeteo-notify@0.1.3 (git+ssh://git@github.com/ipod86/ioBroker.openmeteo-notify.git#60b75eafea469372d5b30239f90b78adc67a5ef4)
                                  +-- iobroker.parcel@0.3.1 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#c579b7c8e878e72c56ae1c30c2fed9292b469895)
                                  | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                  +-- iobroker.tidy@0.1.1 (git+ssh://git@github.com/inventwo/ioBroker.tidy.git#3920e88695d8032773a7066efd0b4b4afdacbcfc)
                                  +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                  +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                                  Adapter State
                                    system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
                                  + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
                                    system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
                                  + system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                                  + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                                    system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                                  + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                                  + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                                    system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                                  + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                                    system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                                    system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                                    system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                                    system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
                                  + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                  + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                    system.adapter.labcom.0                 : labcom                : ioBroker                                 - disabled
                                  + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                                  + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
                                  + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                                  + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                                  + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
                                    system.adapter.nut.2                    : nut                   : ioBroker                                 - disabled
                                  + system.adapter.nut.3                    : nut                   : ioBroker                                 -  enabled
                                  + system.adapter.open-meteo-weather.0     : open-meteo-weather    : ioBroker                                 -  enabled
                                    system.adapter.open-meteo-weather.1     : open-meteo-weather    : ioBroker                                 - disabled
                                  + system.adapter.openmeteo-notify.0       : openmeteo-notify      : ioBroker                                 -  enabled
                                    system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                                  + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                                  + system.adapter.pirate-weather.0         : pirate-weather        : ioBroker                                 -  enabled
                                  + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                                  + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
                                  + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                                  + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
                                    system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
                                  + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                                    system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                  + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
                                  + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
                                    system.adapter.synology.2               : synology              : ioBroker                                 - disabled, port: 5000
                                  + system.adapter.tagesschau.0             : tagesschau            : ioBroker                                 -  enabled
                                    system.adapter.tidy.0                   : tidy                  : ioBroker                                 - disabled
                                  + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                                  + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 443
                                    system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
                                  + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                                    system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
                                    system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                    system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                                    system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                                    system.adapter.vis-owl.0                : vis-owl               : ioBroker                                 - disabled
                                    system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                    system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                  + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                                    system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
                                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                                    system.adapter.wettercom.0              : wettercom             : ioBroker                                 - disabled
                                  + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                                  + instance is alive
                                  │ (index) │ name               │ url                                                     │ auto upgrade │
                                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                  │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                                  │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                                  │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
                                  │ 3       │ 'system.adapter.ankersolix2'                 │ 'ankersolix2'                 │ '2.4.1'  │ 'none'         │
                                  │ 4       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.14' │ 'none'         │
                                  │ 5       │ 'system.adapter.birthdays'                   │ 'birthdays'                   │ '5.0.0'  │ 'none'         │
                                  │ 6       │ 'system.adapter.brightsky'                   │ 'brightsky'                   │ '1.0.1'  │ 'none'         │
                                  │ 7       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'  │ 'none'         │
                                  │ 8       │ 'system.adapter.deyeidc'                     │ 'deyeidc'                     │ '0.3.1'  │ 'none'         │
                                  │ 9       │ 'system.adapter.dwd'                         │ 'dwd'                         │ '2.8.5'  │ 'none'         │
                                  │ 10      │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'  │ 'none'         │
                                  │ 11      │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'  │ 'none'         │
                                  │ 12      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.2'  │ 'none'         │
                                  │ 13      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'  │ 'none'         │
                                  │ 14      │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
                                  │ 15      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'  │ 'none'         │
                                  │ 16      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.20.0' │ 'none'         │
                                  │ 17      │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0'  │ 'none'         │
                                  │ 18      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'  │ 'none'         │
                                  │ 19      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
                                  │ 20      │ 'system.adapter.icons-material-svg'          │ 'icons-material-svg'          │ '0.1.0'  │ 'none'         │
                                  │ 21      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
                                  │ 22      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
                                  │ 23      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'  │ 'none'         │
                                  │ 24      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
                                  │ 25      │ 'system.adapter.iot'                         │ 'iot'                         │ '5.0.12' │ 'none'         │
                                  │ 26      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18' │ 'none'         │
                                  │ 27      │ 'system.adapter.labcom'                      │ 'labcom'                      │ '0.1.4'  │ 'none'         │
                                  │ 28      │ 'system.adapter.lgtv'                        │ 'lgtv'                        │ '2.5.0'  │ 'none'         │
                                  │ 29      │ 'system.adapter.linux-control'               │ 'linux-control'               │ '1.1.5'  │ 'none'         │
                                  │ 30      │ 'system.adapter.logparser'                   │ 'logparser'                   │ '2.4.0'  │ 'none'         │
                                  │ 31      │ 'system.adapter.nut'                         │ 'nut'                         │ '1.7.0'  │ 'none'         │
                                  │ 32      │ 'system.adapter.open-meteo-weather'          │ 'open-meteo-weather'          │ '3.1.0'  │ 'none'         │
                                  │ 33      │ 'system.adapter.openmeteo-notify'            │ 'openmeteo-notify'            │ '0.1.3'  │ 'none'         │
                                  │ 34      │ 'system.adapter.openweathermap'              │ 'openweathermap'              │ '1.4.0'  │ 'none'         │
                                  │ 35      │ 'system.adapter.parcel'                      │ 'parcel'                      │ '0.3.1'  │ 'none'         │
                                  │ 36      │ 'system.adapter.ping'                        │ 'ping'                        │ '2.0.0'  │ 'none'         │
                                  │ 37      │ 'system.adapter.pirate-weather'              │ 'pirate-weather'              │ '0.8.0'  │ 'none'         │
                                  │ 38      │ 'system.adapter.pollenflug'                  │ 'pollenflug'                  │ '2.0.0'  │ 'none'         │
                                  │ 39      │ 'system.adapter.proxmox'                     │ 'proxmox'                     │ '2.4.10' │ 'none'         │
                                  │ 40      │ 'system.adapter.rest-api'                    │ 'rest-api'                    │ '4.0.1'  │ 'none'         │
                                  │ 41      │ 'system.adapter.rssfeed'                     │ 'rssfeed'                     │ '4.0.3'  │ 'none'         │
                                  │ 42      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
                                  │ 43      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
                                  │ 44      │ 'system.adapter.snmp'                        │ 'snmp'                        │ '3.4.0'  │ 'none'         │
                                  │ 45      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
                                  │ 46      │ 'system.adapter.synology'                    │ 'synology'                    │ '3.1.0'  │ 'none'         │
                                  │ 47      │ 'system.adapter.tagesschau'                  │ 'tagesschau'                  │ '0.6.0'  │ 'none'         │
                                  │ 48      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'  │ 'none'         │
                                  │ 49      │ 'system.adapter.tidy'                        │ 'tidy'                        │ '0.1.1'  │ 'none'         │
                                  │ 50      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'  │ 'none'         │
                                  │ 51      │ 'system.adapter.trashschedule'               │ 'trashschedule'               │ '5.3.0'  │ 'none'         │
                                  │ 52      │ 'system.adapter.tuya'                        │ 'tuya'                        │ '3.17.0' │ 'none'         │
                                  │ 53      │ 'system.adapter.unifi'                       │ 'unifi'                       │ '0.7.0'  │ 'none'         │
                                  │ 54      │ 'system.adapter.unifi-network'               │ 'unifi-network'               │ '1.4.0'  │ 'none'         │
                                  │ 55      │ 'system.adapter.upnp'                        │ 'upnp'                        │ '1.1.0'  │ 'none'         │
                                  │ 56      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
                                  │ 57      │ 'system.adapter.vis-bars'                    │ 'vis-bars'                    │ '0.1.4'  │ 'none'         │
                                  │ 58      │ 'system.adapter.vis-canvas-gauges'           │ 'vis-canvas-gauges'           │ '1.0.1'  │ 'none'         │
                                  │ 59      │ 'system.adapter.vis-fancyswitch'             │ 'vis-fancyswitch'             │ '1.1.0'  │ 'none'         │
                                  │ 60      │ 'system.adapter.vis-google-fonts'            │ 'vis-google-fonts'            │ '1.0.4'  │ 'none'         │
                                  │ 61      │ 'system.adapter.vis-history'                 │ 'vis-history'                 │ '1.0.0'  │ 'none'         │
                                  │ 62      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'  │ 'none'         │
                                  │ 63      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.3' │ 'none'         │
                                  │ 64      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '3.3.5'  │ 'none'         │
                                  │ 65      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'  │ 'none'         │
                                  │ 66      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
                                  │ 67      │ 'system.adapter.vis-map'                     │ 'vis-map'                     │ '1.1.2'  │ 'none'         │
                                  │ 68      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.94' │ 'none'         │
                                  │ 69      │ 'system.adapter.vis-owl'                     │ 'vis-owl'                     │ '0.2.13' │ 'none'         │
                                  │ 70      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'  │ 'none'         │
                                  │ 71      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'  │ 'none'         │
                                  │ 72      │ 'system.adapter.weather-warnings'            │ 'weather-warnings'            │ '0.10.1' │ 'none'         │
                                  │ 73      │ 'system.adapter.weatherunderground'          │ 'weatherunderground'          │ '3.7.0'  │ 'none'         │
                                  │ 74      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
                                  │ 75      │ 'system.adapter.wettercom'                   │ 'wettercom'                   │ '0.1.5'  │ 'none'         │
                                  │ 76      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.0.0'  │ 'none'         │
                                  │ 77      │ 'system.adapter.zigbee'                      │ 'zigbee'                      │ '3.3.5'  │ 'none'         │
                                  Adapter    "admin"        : 7.8.23   , installed 7.8.23
                                  Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
                                  Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                                  Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
                                  Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
                                  Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
                                  Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
                                  Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                                  Adapter    "email"        : 2.0.4    , installed 2.0.4
                                  Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.2
                                  Adapter    "history"      : 4.0.0    , installed 4.0.0
                                  Adapter    "ical"         : 1.20.0   , installed 1.20.0
                                  Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                  Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                  Adapter    "iot"          : 5.0.12   , installed 5.0.12
                                  Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                                  Controller "js-controller": 7.0.7    , installed 7.0.7
                                  Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                  Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                                  Adapter    "nut"          : 1.7.0    , installed 1.7.0
                                  Adapter    "open-meteo-weather": 3.1.0, installed 3.1.0
                                  Adapter    "ping"         : 1.7.9    , installed 2.0.0
                                  Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                                  Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
                                  Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
                                  Adapter    "rssfeed"      : 4.0.3    , installed 4.0.3
                                  Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                  Adapter    "tagesschau"   : 0.6.0    , installed 0.6.0
                                  Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                  Adapter    "unifi-network": 1.4.0    , installed 1.4.0
                                  Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                                  Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                                  Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                                  Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                                  Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                  Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                  Adapter    "weather-warnings": 0.10.1, installed 0.10.1
                                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                  Adapter    "web"          : 8.0.0    , installed 8.0.0
                                  Adapter    "ws"           : 4.0.0    , installed 4.0.0
                                  Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
                                  Objects and States
                                  Objects:        58986
                                  States:         51570
                                  Hit:1 http://security.debian.org trixie-security InRelease
                                  Hit:2 http://deb.debian.org/debian trixie InRelease
                                  Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                  Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                                  udp        UNCONN      0            0                        0.0.0.0:sunrpc                  0.0.0.0:*          users:(("rpcbind",pid=133,fd=5),("systemd",pid=1,fd=35))
                                  udp        UNCONN      0            0                        0.0.0.0:49687                   0.0.0.0:*          users:(("io.snmp.0",pid=1075,fd=31))
                                  udp        UNCONN      0            0                        0.0.0.0:33873                   0.0.0.0:*          users:(("io.upnp.0",pid=1628,fd=30))
                                  udp        UNCONN      0            0                        0.0.0.0:1900                    0.0.0.0:*          users:(("io.upnp.0",pid=1628,fd=31))
                                  udp        UNCONN      0            0                   192.168.1.14:mdns                    0.0.0.0:*          users:(("io.tr-064.0",pid=1153,fd=62))
                                  udp        UNCONN      0            0                        0.0.0.0:coap                    0.0.0.0:*          users:(("io.shelly.0",pid=1032,fd=39))
                                  udp        UNCONN      0            0                        0.0.0.0:55521                   0.0.0.0:*          users:(("io.snmp.0",pid=1075,fd=30))
                                  udp        UNCONN      0            0                        0.0.0.0:6666                    0.0.0.0:*          users:(("io.tuya.0",pid=1169,fd=44))
                                  udp        UNCONN      0            0                        0.0.0.0:6667                    0.0.0.0:*          users:(("io.tuya.0",pid=1169,fd=45))
                                  udp        UNCONN      0            0                           [::]:sunrpc                     [::]:*          users:(("rpcbind",pid=133,fd=7),("systemd",pid=1,fd=37))
                                  tcp        LISTEN      0            511                 192.168.1.14:8082                    0.0.0.0:*          users:(("io.web.0",pid=1768,fd=30))
                                  tcp        LISTEN      0            1                        0.0.0.0:9999                    0.0.0.0:*          users:(("nc",pid=492379,fd=3))
                                  tcp        LISTEN      0            511                      0.0.0.0:1882                    0.0.0.0:*          users:(("io.shelly.1",pid=1048,fd=31))
                                  tcp        LISTEN      0            511                      0.0.0.0:9000                    0.0.0.0:*          users:(("iobroker.js-con",pid=153,fd=29))
                                  tcp        LISTEN      0            511                      0.0.0.0:9001                    0.0.0.0:*          users:(("iobroker.js-con",pid=153,fd=23))
                                  tcp        LISTEN      0            100                    127.0.0.1:smtp                    0.0.0.0:*          users:(("master",pid=308,fd=13))
                                  tcp        LISTEN      0            4096                     0.0.0.0:sunrpc                  0.0.0.0:*          users:(("rpcbind",pid=133,fd=4),("systemd",pid=1,fd=34))
                                  tcp        LISTEN      0            511                            *:8093                          *:*          users:(("io.rest-api.0",pid=1510,fd=29))
                                  tcp        LISTEN      0            511                            *:8087                          *:*          users:(("io.simple-api.0",pid=1527,fd=30))
                                  tcp        LISTEN      0            511                            *:8084                          *:*          users:(("io.ws.0",pid=1799,fd=29))
                                  tcp        LISTEN      0            511                            *:tproxy                        *:*          users:(("io.admin.0",pid=330,fd=30))
                                  tcp        LISTEN      0            100                        [::1]:smtp                       [::]:*          users:(("master",pid=308,fd=14))
                                  tcp        LISTEN      0            4096                           *:ssh                           *:*          users:(("sshd",pid=184,fd=3),("systemd",pid=1,fd=59))
                                  tcp        LISTEN      0            4096                        [::]:sunrpc                     [::]:*          users:(("rpcbind",pid=133,fd=6),("systemd",pid=1,fd=36))
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Arbeitszimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Arbeitszimmer: 18.31 g/m³
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Arbeitszimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Arbeitszimmer: 24.09 °C
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Arbeitszimmer] Fixed Calculation: RH_in=86%, Threshold=60 -> Empfehlung Lüften: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Arbeitszimmer] Absolute Humidity Calculation: AH_in=18.31 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Waeschezimmer: 13.09 g/m³
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Waeschezimmer: 18.57 °C
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Waeschezimmer] Fixed Calculation: RH_in=67%, Threshold=60 -> Empfehlung Lüften: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Waeschezimmer] Absolute Humidity Calculation: AH_in=13.09 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Flur gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Flur: 15.34 g/m³
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Flur gespeichert in 0_userdata.0.Raumklima.Taupunkt.Flur: 21.17 °C
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Flur] Fixed Calculation: RH_in=71.5%, Threshold=60 -> Empfehlung Lüften: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Flur] Absolute Humidity Calculation: AH_in=15.34 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Schlafzimmer: 13.14 g/m³
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Schlafzimmer: 18.66 °C
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Schlafzimmer] Fixed Calculation: RH_in=63%, Threshold=60 -> Empfehlung Lüften: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Schlafzimmer] Absolute Humidity Calculation: AH_in=13.14 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Werkstatt gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Werkstatt: 10.95 g/m³
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Werkstatt gespeichert in 0_userdata.0.Raumklima.Taupunkt.Werkstatt: 15.81 °C
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Werkstatt] Fixed Calculation: RH_in=50%, Threshold=60 -> Empfehlung Lüften: false
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Werkstatt] Absolute Humidity Calculation: AH_in=10.95 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: false
                                  2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: runCalculation ausgelöst (10-Minuten-Intervall)
                                  2026-05-21 11:50:44.476  - info: javascript.0 (452) script.js.Heizungen.Wohnzimmer: Stopping script
                                  2026-05-21 11:50:45.925  - info: javascript.0 (452) script.js.Heizungen.Büro: Stopping script
                                  2026-05-21 11:52:07.611  - info: parcel.0 (1855) Relogin to Amazon successful
                                  Gruß Ralf
