  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.3k Aufrufe 40 Beobachtet
  • teletapiT teletapi
    Error bleibt der gleiche
    Vulnerabilities detected in the Node.js version!
    node:fs:2414
        return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        at Object.writeFileSync (node:fs:2414:20)
        at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
        at Object.onceWrapper (node:events:631:26)
        at ClientRequest.emit (node:events:509:28)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:798:27)
        at HTTPParser.parserOnHeadersComplete (node:_http_common:125:17)
        at TLSSocket.socketOnData (node:_http_client:633:22)
        at TLSSocket.emit (node:events:509:28)
        at addChunk (node:internal/streams/readable:563:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:514:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    Node.js v24.15.0
    #847
    @teletapi
    Zieh das Skript jetzt nochmal neu.
    • teletapiT Online
      teletapiT Online
      teletapi
      #848
      Das sieht gut aus
      ```bash
      Script v.2026-05-19
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: Raspberrypi5
             Icon name: computer
                Kernel: Linux 6.18.29+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      System was installed 952 days ago (on 2023-10-10).
      Systemuptime and Load:
       01:16:36 up 16 min,  1 user,  load average: 1.22, 0.82, 0.58
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2026-05-20 01:16:36 CEST
                 Universal time: Tue 2026-05-19 23:16:36 UTC
                       RTC time: Tue 2026-05-19 23:16:36
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobrokerHOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        Not found
      Desktop:
      Session:                tty
      Boot Target:            multi-user.target
      *** MEMORY ***
      Mem:             17G        5.2G         10G         26M        1.7G         11G
      Swap:           209M          0B        209M
      Total:           17G        5.2G         10G
      Active iob-Instances:   38
              16218 M total memory
               4994 M used memory
               4861 M active memory
                986 M inactive memory
               9730 M free memory
                199 M buffer memory
               1439 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 01:16:36 up 16 min,  1 user,  load average: 1.22, 0.82, 0.58
      Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  16218.4 total,   9727.4 free,   4996.9 used,   1638.5 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.  11221.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.9G     0  7.9G   0% /dev
      tmpfs          tmpfs     3.2G   17M  3.2G   1% /run
      /dev/nvme0n1p2 ext4      117G   17G   95G  16% /
      tmpfs          tmpfs     8.0G     0  8.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      tmpfs          tmpfs     8.0G  8.7M  8.0G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
      /dev/nvme0n1p1 vfat      510M   75M  436M  15% /boot/firmware
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
      tmpfs          tmpfs     1.6G   32K  1.6G   1% /run/user/1000
      Messages concerning filesystems in dmesg:
      [Wed May 20 00:59:57 2026] EXT4-fs (nvme0n1p2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
      [Wed May 20 00:59:58 2026] EXT4-fs (nvme0n1p2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/nvme0n1p2 ext4   rw,noatime
      `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.9G    /var/
      1.9G    /var/lib
      1.7G    /var/lib/influxdb/engine/data/5ba497ab85a9233a/autogen
      Archived and active journals take up 196.9M in the file system.
      /opt/iobroker/backups:
      5.0G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      643M    /opt/iobroker/iobroker-data/
      262M    /opt/iobroker/iobroker-data/files
      127M    /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/node-red
      71M     /opt/iobroker/iobroker-data/node-red/node_modules
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
      19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
      18M     /opt/iobroker/iobroker-data/states.jsonl
      9.0M    /opt/iobroker/iobroker-data/files/devices/assets/index-DEPE9oow.js
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a3b83b6a53aef11aaf2321455516304-if00-port0
      *** ZigBee Settings ***
      ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      Zigbee Network Settings on your coordinator / in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      === ZigBee Port Overview ===
      Instance        Configured Port                     Available by-id Port                Status
      zigbee.0        ...f2321455516304-if00-port0        ...f2321455516304-if00-port0        ✓ Matching
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v24.15.0
      /usr/bin/node           v24.15.0
      /usr/bin/npm            11.12.1
      /usr/bin/npx            11.12.1
      ✓ Node.js installation is correct
      nodejs:
        Installed: 24.15.0-1nodesource1
        Candidate: 24.15.0-1nodesource1
        Version table:
       *** 24.15.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
           24.14.1-1nodesource1 1001
           24.14.0-1nodesource1 1001
           24.13.1-1nodesource1 1001
           24.13.0-1nodesource1 1001
           24.12.0-1nodesource1 1001
           24.11.1-1nodesource1 1001
           24.11.0-1nodesource1 1001
           24.10.0-1nodesource1 1001
           24.9.0-1nodesource1 1001
           24.8.0-1nodesource1 1001
           24.7.0-1nodesource1 1001
           24.6.0-1nodesource1 1001
           24.5.0-1nodesource1 1001
           24.4.1-1nodesource1 1001
           24.4.0-1nodesource1 1001
           24.3.0-1nodesource1 1001
           24.1.0-1nodesource1 1001
           24.0.2-1nodesource1 1001
           24.0.1-1nodesource1 1001
           24.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      No known Vulnerabilities detected!
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      Raspberrypi5        Raspberrypi5 (version: 7.1.2, hostname: Raspberrypi5  , alive, uptime: 993)
      Core adapters versions
      js-controller:  7.1.2
      admin:          7.8.25
      javascript:     9.2.2
      nodejs modules from github:     2
      +-- iobroker.influxdb@4.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.influxdb.git#ae7b21709836538e11e7059472f4d72ce49b223e)
      +-- iobroker.jarvis@4.0.0-alpha.13 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#56f23ff400d6411cd23a4cf9e61790dc38fb288c)
      Adapter State
      + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
        system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             -  enabled
      + system.adapter.alpha-ess.0              : alpha-ess             : Raspberrypi5                             -  enabled
      + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
      + system.adapter.devices.0                : devices               : Raspberrypi5                             -  enabled
      + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
      + system.adapter.e3oncan.0                : e3oncan               : Raspberrypi5                             -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             -  enabled
        system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Raspberrypi5                             - disabled
      + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: Raspberrypi5                             -  enabled
        system.adapter.energiefluss-erweitert.3 : energiefluss-erweitert: Raspberrypi5                             - disabled
      + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
        system.adapter.fullcalendar.0           : fullcalendar          : Raspberrypi5                             - disabled
      + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
      + system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : Raspberrypi5                             -  enabled
      + system.adapter.hue.0                    : hue                   : Raspberrypi5                             -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
        system.adapter.ical.1                   : ical                  : Raspberrypi5                             - disabled
      + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
        system.adapter.iot.0                    : iot                   : Raspberrypi5                             - disabled
      + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
      + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
      + system.adapter.matter.0                 : matter                : Raspberrypi5                             -  enabled
      + system.adapter.modbus.0                 : modbus                : Raspberrypi5                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
      + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : Raspberrypi5                             -  enabled
      + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
        system.adapter.openweathermap.0         : openweathermap        : Raspberrypi5                             -  enabled
      + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
      + system.adapter.pirate-weather.0         : pirate-weather        : Raspberrypi5                             -  enabled
      + system.adapter.reolink.0                : reolink               : Raspberrypi5                             -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
      + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
      + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
      + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Raspberrypi5                             - disabled
        system.adapter.wled.0                   : wled                  : Raspberrypi5                             - disabled
      + system.adapter.zigbee.0                 : zigbee                : Raspberrypi5                             -  enabled, port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a3b83b6a53aef11aaf2321455516304-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      │ (index) │ id                                      │ name                     │ version          │ upgrade policy │
      │ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '7.8.25'         │ 'none'         │
      │ 1       │ 'system.adapter.alexa2'                 │ 'alexa2'                 │ '3.27.4'         │ 'none'         │
      │ 2       │ 'system.adapter.alias-manager'          │ 'alias-manager'          │ '2.1.0'          │ 'none'         │
      │ 3       │ 'system.adapter.alpha-ess'              │ 'alpha-ess'              │ '4.1.0'          │ 'none'         │
      │ 4       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'         │ 'none'         │
      │ 5       │ 'system.adapter.cloud'                  │ 'cloud'                  │ '6.0.4'          │ 'none'         │
      │ 6       │ 'system.adapter.devices'                │ 'devices'                │ '2.0.18'         │ 'none'         │
      │ 7       │ 'system.adapter.discovery'              │ 'discovery'              │ '5.0.0'          │ 'none'         │
      │ 8       │ 'system.adapter.e3oncan'                │ 'e3oncan'                │ '1.0.2'          │ 'none'         │
      │ 9       │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'          │ 'none'         │
      │ 10      │ 'system.adapter.fritzdect'              │ 'fritzdect'              │ '2.6.2'          │ 'none'         │
      │ 11      │ 'system.adapter.fullcalendar'           │ 'fullcalendar'           │ '2.4.5'          │ 'none'         │
      │ 12      │ 'system.adapter.hm-rega'                │ 'hm-rega'                │ '5.1.0'          │ 'none'         │
      │ 13      │ 'system.adapter.hm-rpc'                 │ 'hm-rpc'                 │ '3.0.2'          │ 'none'         │
      │ 14      │ 'system.adapter.homeconnect'            │ 'homeconnect'            │ '1.6.1'          │ 'none'         │
      │ 15      │ 'system.adapter.hue'                    │ 'hue'                    │ '3.16.2'         │ 'none'         │
      │ 16      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'         │ 'none'         │
      │ 17      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.3'          │ 'none'         │
      │ 18      │ 'system.adapter.iot'                    │ 'iot'                    │ '6.0.3'          │ 'none'         │
      │ 19      │ 'system.adapter.jarvis'                 │ 'jarvis'                 │ '4.0.0-alpha.13' │ 'none'         │
      │ 20      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'          │ 'none'         │
      │ 21      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'          │ 'none'         │
      │ 22      │ 'system.adapter.modbus'                 │ 'modbus'                 │ '8.1.3'          │ 'none'         │
      │ 23      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'          │ 'none'         │
      │ 24      │ 'system.adapter.net-tools'              │ 'net-tools'              │ '1.2.3'          │ 'none'         │
      │ 25      │ 'system.adapter.nspanel-lovelace-ui'    │ 'nspanel-lovelace-ui'    │ '0.17.8'         │ 'none'         │
      │ 26      │ 'system.adapter.nuki'                   │ 'nuki'                   │ '2.0.0'          │ 'none'         │
      │ 27      │ 'system.adapter.openweathermap'         │ 'openweathermap'         │ '1.4.0'          │ 'none'         │
      │ 28      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'          │ 'none'         │
      │ 29      │ 'system.adapter.pirate-weather'         │ 'pirate-weather'         │ '0.8.0'          │ 'none'         │
      │ 30      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'          │ 'none'         │
      │ 31      │ 'system.adapter.rpi2'                   │ 'rpi2'                   │ '3.0.2'          │ 'none'         │
      │ 32      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'          │ 'none'         │
      │ 33      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'          │ 'none'         │
      │ 34      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'          │ 'none'         │
      │ 35      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'          │ 'none'         │
      │ 36      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'          │ 'none'         │
      │ 37      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'          │ 'none'         │
      │ 38      │ 'system.adapter.whatsapp-cmb'           │ 'whatsapp-cmb'           │ '0.3.0'          │ 'none'         │
      │ 39      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'          │ 'none'         │
      │ 40      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'          │ 'none'         │
      │ 41      │ 'system.adapter.zigbee'                 │ 'zigbee'                 │ '3.4.5'          │ 'none'         │
      ioBroker-Adapter Versions and update status
      Used repository: beta
      Adapter    "admin"        : 7.8.25   , installed 7.8.25
      Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "alpha-ess"    : 4.1.0    , installed 4.1.0
      Adapter    "backitup"     : 3.3.17   , installed 3.3.17
      Adapter    "cloud"        : 6.0.4    , installed 6.0.4
      Adapter    "devices"      : 2.0.18   , installed 2.0.18
      Adapter    "e3oncan"      : 1.0.2    , installed 1.0.2
      Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "hm-rpc"       : 3.0.2    , installed 3.0.2
      Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.20.1   , installed 1.20.1
      Adapter    "influxdb"     : 4.0.2    , installed 4.0.3
      Adapter    "iot"          : 6.0.3    , installed 6.0.3
      Adapter    "jarvis"       : 3.1.8    , installed 4.0.0-alpha.13
      Adapter    "javascript"   : 9.2.2    , installed 9.2.2
      Controller "js-controller": 7.1.2    , installed 7.1.2
      Adapter    "matter"       : 1.0.0    , installed 1.0.0
      Adapter    "modbus"       : 8.1.3    , installed 8.1.3
      Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
      Adapter    "nspanel-lovelace-ui": 0.17.8, installed 0.17.8
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "openweathermap": 1.4.0   , installed 1.4.0
      Adapter    "ping"         : 2.2.4    , installed 2.2.4
      Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
      Adapter    "reolink"      : 1.4.2    , installed 1.4.2
      Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Adapter    "web"          : 8.1.0    , installed 8.1.0
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wled"         : 0.9.2    , installed 0.9.2
      Adapter    "ws"           : 4.1.0    , installed 4.1.0
      Adapter    "zigbee"       : 3.4.5    , installed 3.4.5
      Objects and States
      Objects:        18712
      States:         18858
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
      Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
      Fetched 6922 B in 0s (35.0 kB/s)
      Reading package lists... Done
      Pending systemupdates: 0
      *** Listening Ports ***
      Netid                   State                     Recv-Q                    Send-Q                                                     Local Address:Port                                                Peer Address:Port                   Process
      udp                     UNCONN                    0                         0        0.0.0.0:33196                                                    0.0.0.0:*                       users:(("avahi-daemon",pid=716,fd=14))
      udp                     UNCONN                    0                         0        0.0.0.0:43688                                                    0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=42))
      udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=39))
      udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=37))
      udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("avahi-daemon",pid=716,fd=12))
      udp                     UNCONN                    0                         0        0.0.0.0:5541                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=36))
      udp                     UNCONN                    0                         0        *:40920                                                          *:*                       users:(("io.matter.0",pid=2209,fd=41))
      udp                     UNCONN                    0                         0                                            [fe80::b78f:a4e0:4880:4be4]:dhcpv6-client                                                  *:*                       users:(("NetworkManager",pid=834,fd=38))
      udp                     UNCONN                    0                         0                                            [fe80::f05b:9255:16fc:d8b2]:dhcpv6-client                                                  *:*                       users:(("NetworkManager",pid=834,fd=35))
      udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("io.matter.0",pid=2209,fd=40))
      udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("io.matter.0",pid=2209,fd=38))
      udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("avahi-daemon",pid=716,fd=13))
      udp                     UNCONN                    0                         0        *:5541                                                           *:*                       users:(("io.matter.0",pid=2209,fd=35))
      udp                     UNCONN                    0                         0        *:56246                                                          *:*                       users:(("avahi-daemon",pid=716,fd=15))
      tcp                     LISTEN                    0                         511                                                       192.168.178.82:8087                                                     0.0.0.0:*                       users:(("io.simple-api.0",pid=2273,fd=35))
      tcp                     LISTEN                    0                         128                                                              0.0.0.0:ssh                                                      0.0.0.0:*                       users:(("sshd",pid=965,fd=6))
      tcp                     LISTEN                    0                         100                                                              0.0.0.0:1883                                                     0.0.0.0:*                       users:(("mosquitto",pid=991,fd=5))
      tcp                     LISTEN                    0                         511                                                              0.0.0.0:1886                                                     0.0.0.0:*                       users:(("io.sonoff.0",pid=1892,fd=40))
      tcp                     LISTEN                    0                         20                                                             127.0.0.1:smtp                                                     0.0.0.0:*                       users:(("exim4",pid=1250,fd=5))
      tcp                     LISTEN                    0                         511                                                            127.0.0.1:9000                                                     0.0.0.0:*                       users:(("iobroker.js-con",pid=1300,fd=29))
      tcp                     LISTEN                    0                         511                                                            127.0.0.1:9001                                                     0.0.0.0:*                       users:(("iobroker.js-con",pid=1300,fd=23))
      tcp                     LISTEN                    0                         511                                                       192.168.178.82:9292                                                     0.0.0.0:*                       users:(("io.hm-rpc.2",pid=2054,fd=35))
      tcp                     LISTEN                    0                         511                                                       192.168.178.82:18701                                                    0.0.0.0:*                       users:(("io.hm-rpc.0",pid=1660,fd=35))
      tcp                     LISTEN                    0                         511                                                       192.168.178.82:18702                                                    0.0.0.0:*                       users:(("io.hm-rpc.1",pid=1677,fd=35))
      tcp                     LISTEN                    0                         4096        *:3000                                                           *:*                       users:(("grafana",pid=1299,fd=18))
      tcp                     LISTEN                    0                         128        [::]:ssh                                                         [::]:*                       users:(("sshd",pid=965,fd=7))
      tcp                     LISTEN                    0                         511        *:8400                                                           *:*                       users:(("io.jarvis.0",pid=2184,fd=36))
      tcp                     LISTEN                    0                         100        [::]:1883                                                        [::]:*                       users:(("mosquitto",pid=991,fd=6))
      tcp                     LISTEN                    0                         20        [::1]:smtp                                                        [::]:*                       users:(("exim4",pid=1250,fd=6))
      tcp                     LISTEN                    0                         511        *:tproxy                                                         *:*                       users:(("io.admin.0",pid=1357,fd=39))
      tcp                     LISTEN                    0                         511        *:8082                                                           *:*                       users:(("io.web.0",pid=2327,fd=35))
      tcp                     LISTEN                    0                         511        *:8084                                                           *:*                       users:(("io.socketio.0",pid=2305,fd=34))
      tcp                     LISTEN                    0                         4096        *:8086                                                           *:*                       users:(("influxd",pid=979,fd=1547))
      2026-05-20 01:15:48.873  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-4W | Battery=366W | Bedarf=366W | Überschuss=4W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:15:50.000  - info: javascript.0 (1435) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-4W | PV_total:-1W | Batt:366W | Haus:369W | Tag:0.418kWh
      2026-05-20 01:15:54.612  - info: hm-rpc.2 (2054) xmlrpc <- listDevices ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c"]
      2026-05-20 01:15:54.650  - info: hm-rpc.2 (2054) xmlrpc -> 48 devices
      2026-05-20 01:15:54.713  - info: hm-rpc.2 (2054) xmlrpc <- newDevices 48
      2026-05-20 01:15:54.753  - info: hm-rpc.2 (2054) new virtual-devices devices/channels after filter: 0
      2026-05-20 01:15:54.756  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000004"]
      2026-05-20 01:15:54.759  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000005"]
      2026-05-20 01:15:54.763  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000006"]
      2026-05-20 01:15:54.766  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000007"]
      2026-05-20 01:15:54.769  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000010"]
      2026-05-20 01:15:54.772  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000014"]
      2026-05-20 01:15:58.873  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-11W | Battery=366W | Bedarf=366W | Überschuss=11W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:16:06.755  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2026-05-20 01:16:08.874  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-7W | Battery=366W | Bedarf=366W | Überschuss=7W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:16:18.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=0W | Battery=366W | Bedarf=366W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:16:27.110  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2026-05-20 01:16:28.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=6W | Battery=366W | Bedarf=372W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:16:38.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=11W | Battery=340W | Bedarf=351W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:16:48.263  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2026-05-20 01:16:48.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-4W | Battery=366W | Bedarf=366W | Überschuss=4W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:16:50.000  - info: javascript.0 (1435) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-7W | PV_total:-1W | Batt:366W | Haus:366W | Tag:0.424kWh
      2026-05-20 01:16:58.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-6W | Battery=366W | Bedarf=366W | Überschuss=6W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:17:08.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=12W | Battery=339W | Bedarf=351W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
      2026-05-20 01:17:09.154  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      ============= Mark until here for C&P =============
      iob diag has finished.
        Das sieht gut aus
        ```bash
        Script v.2026-05-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Unknown
        Kernel          : aarch64
        Userland        : 64bit
        CPU threads     : 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           209M          0B        209M
        Total:           17G        5.2G         10G
                 4994 M used memory
                 9730 M free memory
                  199 M buffer memory
                 1439 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        2.9G    /var/
        1.9G    /var/lib
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.8.25
        javascript:     9.2.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        18712
        States:         18858
        #849
        @teletapi
        Ich hab mit den Rechten noch was herumgespielt. Aber so ganz erklären kann ich mir das Verhalten auf deiner Kiste nicht.
        teletapiT 1 Antwort Letzte Antwort
          @teletapi
          teletapiT Online
          teletapiT Online
          teletapi
          #850
          System läuft aber auch top und ich kann keinerlei Fehler sehen oder bemerken. Vielleicht fällt ja irgendwann noch was auf. herzlichen dank für die Hilfe dazu
            @skvarel sagte:
            Ubuntu 24.04.4 ist aber doch LTS, oder?
            Ja, es ist zwar noch supportet, aber perspektivisch sollte das auf 26.04 'Resolute Raccoon' gehievt werden. Und genau das steht da. Wenn es EOL wäre würde das auch da stehen.
            Hab jetzt noch mal was geändert. Magst du noch mal testen?
            skvarelS Offline
            skvarelS Offline
            skvarel
            #851
            @Thomas-Braun sagte:
            Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
            *** LEBENSZYKLUS STATUS ***
            Die Unterstützung für das Betriebssystem mit dem Codenamen 'noble' läuft aus. Es sollte in nächster Zeit auf die aktuelle Version 'resolute' mit Langzeitunterstützung gebracht werden.
            #TeamInventwo
            Unsere Adapter:
            • BananaJoeB BananaJoe
              @skvarel und damit warten wir mindestens bis zur Version 26.04.1 - wenn diese erschienen ist, wird dich dein 24.04.x auch darauf Hinweisen das nun ein Inplace-Upgrade möglich wäre.
              Ob dann Inplace oder Neuinstallation dann der richtige Weg ist wäre eine andere Diskussion
              skvarelS Offline
              skvarelS Offline
              skvarel
              #852
              @BananaJoe sagte:
              Ich bin nicht gut im Erkennen von Ironie/Sarkasmus und schon gar nicht was Linux angeht ... ist das Warten ernst gemeint oder jetzt updaten?
              #TeamInventwo
              Unsere Adapter:
              • skvarelS skvarel
                @BananaJoe sagte:
                #853
                @skvarel sagte:
                Upgrades aus einer Bestandsversion sind offiziell erst nach der Veröffentlichung des ersten Point releases vorgesehen. Wer das vorzeitig machen will muss das ausdrücklich dem Upgrade mitgeben.
                sudo do-release-upgrade -d
                ist das. Später geht es dann ohne -d.
                Das Abwarten des ersten Point releases ist auch für Debian eine übliche Praxis. Dafür gibt es ja die einjährige Übergangsphase z.B.
                • skvarelS skvarel
                  #854
                  @skvarel sagte:
                  Genau so soll es aussehen. Danke für's testen!
                  skvarelS 1 Antwort Letzte Antwort
                    @skvarel sagte:
                    skvarelS Offline
                    skvarelS Offline
                    skvarel
                    #855
                    @Thomas-Braun .. sehr gerne und vielen Dank für den Fix 👍
                    Ich kann leider nicht mehr Voten
                    #TeamInventwo
                    Unsere Adapter:
                    • M MCU
                      @Thomas-Braun Gibt es die diag auch für Windows?
                      S Abwesend
                      S Abwesend
                      Shadowhunter23
                      #856
                      @Thomas-Braun
                      Ist es nicht möglich mit KI ein Windows iob_diag bauen zu lassen?
                      Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                      ioBroker Backup Analyzer
                      • S Shadowhunter23
                        @Thomas-Braun
                        #857
                        @Shadowhunter23 sagte:
                        Da fragst du den richtigen...
                        Ich hab von Windows keine Ahnung, will ich auch nicht.
                        Und mit KIs und deren wiedersprüchlichen Ansinnen schlage ich mich schon genug herum.
                        Und dann wird doch auch immer erzählt, Windows ist viel 'einfacher' als dieses dämliche 'Linuggs-Geraffel', kann auch meine Oma beklicken. Wozu dann ein solches Diag-Skript? ;-)
                        • Thomas BraunT Online
                          #858
                          @skvarel @teletapi
                          Könnten die fleißigen Tester nochmal checken?
                          Ich hab gestern noch ein paar Dinge im Kampf mit zwei KIs umgestellt.
                          Optisch ändert sich nix gravierendes, nur bitte mal schauen ob die Ausgaben noch bzw. wieder plausibel sind.
                          Danke schön!
                          Super wäre auch mal ein komplexeres ZigBee-Konstrukt mit mehreren Koordinatoren und/oder mehreren Anschlüssen (per TCP oder USB) zu sehen. Aber die Konstellation ist wohl nicht gar so häufig in freier Wildbahn anzutreffen.
                          • skvarelS Offline
                            skvarelS Offline
                            skvarel
                            schrieb am zuletzt editiert von skvarel
                            #859
                            ./iob_diag.sh
                            ```bash
                            Script v.2026-05-20
                            *** BASE SYSTEM ***
                            Operating System: Ubuntu 24.04.4 LTS
                             Static hostname: ioBroker
                                   Icon name: computer-desktop
                                     Chassis: desktop 🖥️
                                      Kernel: Linux 6.8.0-117-generic
                                Architecture: x86-64
                             Hardware Vendor: Dell Inc.
                              Hardware Model: OptiPlex 3050
                            Firmware Version: 1.6.5
                               Firmware Date: Sat 2017-09-09
                                Firmware Age: 8y 8month 1w 3d
                            OS is similar to: debian
                            model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
                            Docker          : false
                            Unknown
                            Kernel          : x86_64
                            Userland        : 64bit
                            System was installed 243 days ago (on 2025-09-19).
                             11:17:00 up 3 days,  4:15,  1 user,  load average: 0.54, 0.66, 0.76
                            CPU threads     : 4
                                           Local time: Thu 2026-05-21 11:17:00 CEST
                                       Universal time: Thu 2026-05-21 09:17:00 UTC
                                             RTC time: Thu 2026-05-21 09:17:00
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm cdrom sudo dip plugdev lxd iobroker
                            iobroker[sudo] password for pi:
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev redis
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:             16G        9.7G        2.9G        5.0M        4.5G        7.0G
                            Swap:           4.3G          0B        4.3G
                            Total:           20G        9.7G        7.2G
                            Active iob-Instances:   53
                                    15877 M total memory
                                     9220 M used memory
                                     9344 M active memory
                                     2736 M inactive memory
                                     2735 M free memory
                                      800 M buffer memory
                                     3461 M swap cache
                                     4095 M total swap
                                        0 M used swap
                                     4095 M free swap
                            top - 11:17:11 up 3 days,  4:15,  1 user,  load average: 0.68, 0.68, 0.76
                            Tasks: 233 total,   1 running, 232 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  9.8 us,  5.9 sy,  0.0 ni, 82.4 id,  0.0 wa,  0.0 hi,  2.0 si,  0.0 st
                            MiB Mem :  15877.7 total,   2734.3 free,   9222.2 used,   4262.3 buff/cache
                            MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6655.5 avail Mem
                            *** FILESYSTEM ***
                            Filesystem                        Type   Size  Used Avail Use% Mounted on
                            tmpfs                             tmpfs  1.6G  4.6M  1.6G   1% /run
                            /dev/mapper/ubuntu--vg-ubuntu--lv ext4   467G   20G  428G   5% /
                            tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
                            tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                            /dev/nvme0n1p2                    ext4   2.0G  200M  1.6G  11% /boot
                            tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
                            [Mon May 18 07:01:29 2026] Btrfs loaded, zoned=yes, fsverity=yes
                            [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): mounted filesystem a547182b-43b5-440e-b6fe-09323774b05c ro with ordered data mode. Quota mode: none.
                            [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): re-mounted a547182b-43b5-440e-b6fe-09323774b05c r/w.
                            [Mon May 18 07:01:30 2026] EXT4-fs (nvme0n1p2): mounted filesystem 7a71a3d0-fb5e-4ed0-8d6d-dc24002c0eef r/w with ordered data mode. Quota mode: none.
                            /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
                            `-/boot /dev/nvme0n1p2                    ext4   rw,relatime
                            /var:
                            5.3G    /var/
                            4.4G    /var/log
                            4.2G    /var/log/journal/b521ee0ca8cb46db87113e33c1d11d82
                            760M    /var/lib
                            Archived and active journals take up 4.1G in the file system.
                            190M    /opt/iobroker/backups/
                            502M    /opt/iobroker/iobroker-data/
                            329M    /opt/iobroker/iobroker-data/files
                            132M    /opt/iobroker/iobroker-data/backup-objects
                            56M     /opt/iobroker/iobroker-data/files/vis-2
                            47M     /opt/iobroker/iobroker-data/files/admin.admin
                            38M     /opt/iobroker/iobroker-data/objects.jsonl
                            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                            9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                            9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            No nvbackup.json found.
                            /usr/bin/nodejs         v22.22.2
                            /usr/bin/node           v22.22.2
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                              Installed: 22.22.2-1nodesource1
                              Candidate: 22.22.2-1nodesource1
                              Version table:
                             *** 22.22.2-1nodesource1 1001
                                 22.22.1-1nodesource1 1001
                                 22.22.0-1nodesource1 1001
                                 22.21.0-1nodesource1 1001
                                 22.20.0-1nodesource1 1001
                                 22.19.0-1nodesource1 1001
                                 22.18.0-1nodesource1 1001
                                 22.17.1-1nodesource1 1001
                                 22.17.0-1nodesource1 1001
                                 22.16.0-1nodesource1 1001
                                 22.15.1-1nodesource1 1001
                                 22.15.0-1nodesource1 1001
                                 22.14.0-1nodesource1 1001
                                 22.13.1-1nodesource1 1001
                                 22.13.0-1nodesource1 1001
                                 22.12.0-1nodesource1 1001
                                 22.11.0-1nodesource1 1001
                                 22.10.0-1nodesource1 1001
                                 22.9.0-1nodesource1 1001
                                 22.8.0-1nodesource1 1001
                                 22.7.0-1nodesource1 1001
                                 22.6.0-1nodesource1 1001
                                 22.5.1-1nodesource1 1001
                                 22.5.0-1nodesource1 1001
                                 22.4.1-1nodesource1 1001
                                 22.4.0-1nodesource1 1001
                                 22.3.0-1nodesource1 1001
                                 22.2.0-1nodesource1 1001
                                 22.1.0-1nodesource1 1001
                                 22.0.0-1nodesource1 1001
                                 18.19.1+dfsg-6ubuntu5 500
                                    500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            Hosts:
                            ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152296)
                            admin:          7.8.25
                            javascript:     9.2.2
                            nodejs modules from github:     3
                            +-- iobroker.energiefluss-erweitert@0.8.2 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#89dbb71bf0fc70044249fd6453c25194130d9971)
                            +-- iobroker.foxesscloud@0.4.0 (git+ssh://git@github.com/inventwo/ioBroker.foxesscloud.git#9c22623f35cd02277a4a3dcc145ada655b4e9080)
                            +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                            + system.adapter.autodarts.0              : autodarts             : ioBroker                                 -  enabled, port: 3180
                            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                            + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
                              system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                            + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
                            + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                            + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                            + system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
                            + system.adapter.discovergy.0             : discovergy            : ioBroker                                 -  enabled
                            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                            + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
                            + system.adapter.enpal.0                  : enpal                 : ioBroker                                 -  enabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                              system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                              system.adapter.foxesscloud.0            : foxesscloud           : ioBroker                                 - disabled
                            + system.adapter.foxesscloud.1            : foxesscloud           : ioBroker                                 -  enabled
                            + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
                            + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                              system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                              system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                              system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
                              system.adapter.ical.4                   : ical                  : ioBroker                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                            + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                            + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
                            + system.adapter.javascript.2             : javascript            : ioBroker                                 -  enabled
                            + system.adapter.javascript.3             : javascript            : ioBroker                                 -  enabled
                            + system.adapter.javascript.5             : javascript            : ioBroker                                 -  enabled
                            + system.adapter.life360ng.0              : life360ng             : ioBroker                                 -  enabled
                            + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                            + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                            + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ioBroker                                 - disabled, port: 16021
                            + system.adapter.operating-hours.0        : operating-hours       : ioBroker                                 -  enabled
                            + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                            + system.adapter.reolink.5                : reolink               : ioBroker                                 -  enabled
                            + system.adapter.reolink.6                : reolink               : ioBroker                                 -  enabled
                            + system.adapter.reolink.7                : reolink               : ioBroker                                 -  enabled
                            + system.adapter.reolink.8                : reolink               : ioBroker                                 -  enabled
                              system.adapter.reolink.9                : reolink               : ioBroker                                 - disabled
                              system.adapter.seq.0                    : seq                   : ioBroker                                 - disabled, port: 443
                            + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
                            + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                              system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
                            + system.adapter.sureflap.0               : sureflap              : ioBroker                                 -  enabled
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                            + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.tidy.0                   : tidy                  : ioBroker                                 -  enabled
                            + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                              system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
                            + system.adapter.trashschedule.1          : trashschedule         : ioBroker                                 -  enabled
                            + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                              system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
                              system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
                            + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                            + system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 -  enabled, port: 5000
                            + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                            + system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
                            + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
                            + instance is alive
                            │ 0       │ 'Beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                            │ 1       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                            Active repo(s): Beta
                            │ 2       │ 'system.adapter.autodarts'              │ 'autodarts'              │ '1.0.8'   │ 'none'         │
                            │ 3       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'  │ 'none'         │
                            │ 4       │ 'system.adapter.bambulab'               │ 'bambulab'               │ '0.4.3'   │ 'none'         │
                            │ 5       │ 'system.adapter.birthdays'              │ 'birthdays'              │ '6.0.1'   │ 'none'         │
                            │ 6       │ 'system.adapter.brightsky'              │ 'brightsky'              │ '1.1.0'   │ 'none'         │
                            │ 7       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'   │ 'none'         │
                            │ 8       │ 'system.adapter.device-watcher'         │ 'device-watcher'         │ '2.15.15' │ 'none'         │
                            │ 9       │ 'system.adapter.devices'                │ 'devices'                │ '2.1.1'   │ 'none'         │
                            │ 10      │ 'system.adapter.discovergy'             │ 'discovergy'             │ '0.7.0'   │ 'none'         │
                            │ 11      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
                            │ 12      │ 'system.adapter.enpal'                  │ 'enpal'                  │ '0.2.0'   │ 'none'         │
                            │ 13      │ 'system.adapter.fb-checkpresence'       │ 'fb-checkpresence'       │ '1.4.2'   │ 'none'         │
                            │ 14      │ 'system.adapter.feiertage'              │ 'feiertage'              │ '1.4.0'   │ 'none'         │
                            │ 15      │ 'system.adapter.foxesscloud'            │ 'foxesscloud'            │ '0.4.0'   │ 'none'         │
                            │ 16      │ 'system.adapter.harmony'                │ 'harmony'                │ '2.1.0'   │ 'none'         │
                            │ 17      │ 'system.adapter.hmip'                   │ 'hmip'                   │ '1.27.0'  │ 'none'         │
                            │ 18      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
                            │ 19      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
                            │ 21      │ 'system.adapter.life360ng'              │ 'life360ng'              │ '1.9.1'   │ 'none'         │
                            │ 22      │ 'system.adapter.linux-control'          │ 'linux-control'          │ '1.1.6'   │ 'none'         │
                            │ 23      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'   │ 'none'         │
                            │ 24      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'   │ 'none'         │
                            │ 25      │ 'system.adapter.nanoleaf-lightpanels'   │ 'nanoleaf-lightpanels'   │ '1.6.0'   │ 'none'         │
                            │ 26      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'   │ 'none'         │
                            │ 27      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
                            │ 28      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'   │ 'none'         │
                            │ 29      │ 'system.adapter.seq'                    │ 'seq'                    │ '1.0.2'   │ 'none'         │
                            │ 30      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
                            │ 31      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
                            │ 32      │ 'system.adapter.snmp'                   │ 'snmp'                   │ '3.4.0'   │ 'none'         │
                            │ 33      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'   │ 'none'         │
                            │ 34      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14'  │ 'none'         │
                            │ 35      │ 'system.adapter.spotify-premium'        │ 'spotify-premium'        │ '2.0.3'   │ 'none'         │
                            │ 36      │ 'system.adapter.sureflap'               │ 'sureflap'               │ '3.4.2'   │ 'none'         │
                            │ 37      │ 'system.adapter.tankerkoenig'           │ 'tankerkoenig'           │ '3.4.0'   │ 'none'         │
                            │ 38      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'   │ 'none'         │
                            │ 39      │ 'system.adapter.tidy'                   │ 'tidy'                   │ '0.1.1'   │ 'none'         │
                            │ 40      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'   │ 'none'         │
                            │ 41      │ 'system.adapter.trashschedule'          │ 'trashschedule'          │ '5.3.0'   │ 'none'         │
                            │ 42      │ 'system.adapter.tuya'                   │ 'tuya'                   │ '3.17.0'  │ 'none'         │
                            │ 43      │ 'system.adapter.vis-2'                  │ 'vis-2'                  │ '2.13.19' │ 'none'         │
                            │ 44      │ 'system.adapter.vis-2-widgets-icontwo'  │ 'vis-2-widgets-icontwo'  │ '1.40.0'  │ 'none'         │
                            │ 45      │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.0.0'   │ 'none'         │
                            │ 46      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.3'  │ 'none'         │
                            │ 47      │ 'system.adapter.wallpanel'              │ 'wallpanel'              │ '0.3.11'  │ 'none'         │
                            │ 48      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'   │ 'none'         │
                            │ 49      │ 'system.adapter.wiobrowser'             │ 'wiobrowser'             │ '2.0.2'   │ 'none'         │
                            │ 50      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'   │ 'none'         │
                            │ 51      │ 'system.adapter.worx'                   │ 'worx'                   │ '3.3.0'   │ 'none'         │
                            │ 52      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
                            │ 53      │ 'system.adapter.zigbee2mqtt'            │ 'zigbee2mqtt'            │ '3.2.1'   │ 'none'         │
                            Used repository: Beta
                            Adapter    "autodarts"    : 1.0.8    , installed 1.0.8
                            Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
                            Adapter    "birthdays"    : 6.0.1    , installed 6.0.1
                            Adapter    "brightsky"    : 1.1.0    , installed 1.1.0
                            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                            Adapter    "device-watcher": 2.15.15 , installed 2.15.15
                            Adapter    "devices"      : 2.1.1    , installed 2.1.1
                            Adapter    "discovergy"   : 0.7.0    , installed 0.7.0
                            Adapter    "enpal"        : 0.2.0    , installed 0.2.0
                            Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                            Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
                            Adapter    "foxesscloud"  : 0.4.0    , installed 0.4.0
                            Adapter    "harmony"      : 2.1.0    , installed 2.1.0
                            Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                            Adapter    "life360ng"    : 1.9.1    , installed 1.9.1
                            Adapter    "linux-control": 1.1.5    , installed 1.1.6
                            Adapter    "nanoleaf-lightpanels": 1.6.0, installed 1.6.0
                            Adapter    "operating-hours": 1.5.1  , installed 1.5.1
                            Adapter    "seq"          : 1.0.2    , installed 1.0.2
                            Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                            Adapter    "snmp"         : 3.4.0    , installed 3.4.0
                            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                            Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
                            Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
                            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                            Adapter    "trashschedule": 5.3.0    , installed 5.3.0
                            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                            Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
                            Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
                            Adapter    "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
                            Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                            Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                            Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                            Adapter    "worx"         : 3.3.0    , installed 3.3.0
                            Adapter    "zigbee2mqtt"  : 3.2.1    , installed 3.2.1
                            Objects and States
                            Objects:        22292
                            States:         22954
                            Hit:1 https://apt.grafana.com stable InRelease
                            Get:2 https://repos.influxdata.com/debian stable InRelease [6922 B]
                            Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
                            Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
                            Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                            Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                            Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                            Hit:8 https://packages.redis.io/deb noble InRelease
                            Fetched 6922 B in 1s (7313 B/s)
                            Pending systemupdates: 2
                            udp       UNCONN     0          0                                         0.0.0.0:61991                      0.0.0.0:*        users:(("io.harmony.0",pid=612834,fd=30))
                            udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=42))
                            udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=40))
                            udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.wled.0",pid=614951,fd=22))
                            udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=38))
                            udp       UNCONN     0          0                                         0.0.0.0:5540                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=46))
                            udp       UNCONN     0          0                                         0.0.0.0:5541                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=37))
                            udp       UNCONN     0          0                                         0.0.0.0:5542                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=47))
                            udp       UNCONN     0          0                                         0.0.0.0:6666                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=53))
                            udp       UNCONN     0          0                                         0.0.0.0:6667                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=54))
                            udp       UNCONN     0          0                                      127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=16))
                            udp       UNCONN     0          0                                   127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=14))
                            udp       UNCONN     0          0                          192.168.130.130%enp2s0:bootpc                     0.0.0.0:*        users:(("systemd-network",pid=512,fd=24))
                            udp       UNCONN     0          0                                         0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=5),("systemd",pid=1,fd=270))
                            udp       UNCONN     0          0                                  172.18.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=25))
                            udp       UNCONN     0          0                                      172.18.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=24))
                            udp       UNCONN     0          0                                  172.17.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=21))
                            udp       UNCONN     0          0                                      172.17.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=20))
                            udp       UNCONN     0          0                                 192.168.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=16))
                            udp       UNCONN     0          0                                 192.168.130.130:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=15))
                            udp       UNCONN     0          0                                         0.0.0.0:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=13))
                            udp       UNCONN     0          0                                  172.18.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=27))
                            udp       UNCONN     0          0                                      172.18.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=26))
                            udp       UNCONN     0          0                                  172.17.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=23))
                            udp       UNCONN     0          0                                      172.17.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=22))
                            udp       UNCONN     0          0                                 192.168.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=18))
                            udp       UNCONN     0          0                                 192.168.130.130:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=17))
                            udp       UNCONN     0          0                                         0.0.0.0:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=14))
                            udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=44))
                            udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=43))
                            udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=41))
                            udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=39))
                            udp       UNCONN     0          0                                            [::]:5540                          [::]:*        users:(("io.matter.0",pid=614373,fd=45))
                            udp       UNCONN     0          0                                            [::]:5541                          [::]:*        users:(("io.matter.0",pid=614373,fd=36))
                            udp       UNCONN     0          0                                            [::]:5542                          [::]:*        users:(("io.matter.0",pid=614373,fd=35))
                            udp       UNCONN     0          0                                            [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=7),("systemd",pid=1,fd=272))
                            udp       UNCONN     0          0              [fe80::da9e:f3ff:fe78:3132]%enp2s0:dhcpv6-client                 [::]:*        users:(("systemd-network",pid=512,fd=22))
                            tcp       LISTEN     0          50                                        0.0.0.0:netbios-ssn                0.0.0.0:*        users:(("smbd",pid=1007,fd=31))
                            tcp       LISTEN     0          4096                                      0.0.0.0:ssh                        0.0.0.0:*        users:(("sshd",pid=2422,fd=3),("systemd",pid=1,fd=101))
                            tcp       LISTEN     0          4096                                      0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=4),("systemd",pid=1,fd=269))
                            tcp       LISTEN     0          4096                                   127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=17))
                            tcp       LISTEN     0          4096                                      0.0.0.0:http                       0.0.0.0:*        users:(("docker-proxy",pid=1323,fd=7))
                            tcp       LISTEN     0          50                                        0.0.0.0:microsoft-ds               0.0.0.0:*        users:(("smbd",pid=1007,fd=30))
                            tcp       LISTEN     0          511                                       0.0.0.0:1885                       0.0.0.0:*        users:(("io.mqtt.0",pid=613007,fd=34))
                            tcp       LISTEN     0          511                                       0.0.0.0:1883                       0.0.0.0:*        users:(("io.sonoff.0",pid=613163,fd=40))
                            tcp       LISTEN     0          511                                       0.0.0.0:1882                       0.0.0.0:*        users:(("io.shelly.0",pid=614225,fd=36))
                            tcp       LISTEN     0          511                                     127.0.0.1:9001                       0.0.0.0:*        users:(("iobroker.js-con",pid=612180,fd=23))
                            tcp       LISTEN     0          4096                                    127.0.0.1:34169                      0.0.0.0:*        users:(("containerd",pid=764,fd=15))
                            tcp       LISTEN     0          511                                     127.0.0.1:redis                      0.0.0.0:*        users:(("redis-server",pid=720,fd=20))
                            tcp       LISTEN     0          4096                                127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=15))
                            tcp       LISTEN     0          50                                           [::]:netbios-ssn                   [::]:*        users:(("smbd",pid=1007,fd=29))
                            tcp       LISTEN     0          4096                                         [::]:ssh                           [::]:*        users:(("sshd",pid=2422,fd=4),("systemd",pid=1,fd=102))
                            tcp       LISTEN     0          4096                                         [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=6),("systemd",pid=1,fd=271))
                            tcp       LISTEN     0          4096                                         [::]:http                          [::]:*        users:(("docker-proxy",pid=1330,fd=7))
                            tcp       LISTEN     0          50                                           [::]:microsoft-ds                  [::]:*        users:(("smbd",pid=1007,fd=28))
                            tcp       LISTEN     0          4096                                            *:3000                             *:*        users:(("grafana",pid=1463,fd=26))
                            tcp       LISTEN     0          511                                             *:61991                            *:*        users:(("io.harmony.0",pid=612834,fd=29))
                            tcp       LISTEN     0          511                                         [::1]:redis                         [::]:*        users:(("redis-server",pid=720,fd=21))
                            tcp       LISTEN     0          511                                             *:8087                             *:*        users:(("io.simple-api.0",pid=614626,fd=35))
                            tcp       LISTEN     0          4096                                            *:8086                             *:*        users:(("influxd",pid=946,fd=358))
                            tcp       LISTEN     0          511                                             *:8084                             *:*        users:(("io.ws.0",pid=614776,fd=34))
                            tcp       LISTEN     0          511                                             *:8082                             *:*        users:(("io.web.0",pid=612361,fd=35))
                            tcp       LISTEN     0          511                                             *:tproxy                           *:*        users:(("io.admin.0",pid=612200,fd=39))
                            2026-05-21 11:00:07.069  - info: ical.1 (1343691) processing URL: xxx
                            2026-05-21 11:00:08.171  - info: host.ioBroker instance system.adapter.ical.3 in version "1.20.1" started with pid 1343725
                            2026-05-21 11:00:08.497  - info: ical.0 (1343653) Terminated (NO_ERROR): Without reason
                            2026-05-21 11:00:09.021  - info: host.ioBroker instance system.adapter.ical.0 having pid 1343653 terminated with code 0 (NO_ERROR)
                            2026-05-21 11:00:10.036  - info: ical.3 (1343725) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                            2026-05-21 11:00:10.837  - info: ical.3 (1343725) processing URL: Jannis https://calendar.google.com/calendar/ical/0815%40group.calendar.google.com/private-0815/basic.ics
                            2026-05-21 11:00:12.326  - info: ical.1 (1343691) Terminated (NO_ERROR): Without reason
                            2026-05-21 11:00:12.852  - info: host.ioBroker instance system.adapter.ical.1 having pid 1343691 terminated with code 0 (NO_ERROR)
                            2026-05-21 11:00:16.030  - info: ical.3 (1343725) Terminated (NO_ERROR): Without reason
                            2026-05-21 11:00:16.592  - info: host.ioBroker instance system.adapter.ical.3 having pid 1343725 terminated with code 0 (NO_ERROR)
                            2026-05-21 11:00:31.696  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
                            2026-05-21 11:00:57.303  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Home → in der Ladestation
                            2026-05-21 11:04:57.953  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
                            2026-05-21 11:10:13.946  - info: alexa2.0 (869734) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
                            2026-05-21 11:10:15.455  - info: alexa2.0 (869734) Alexa-Push-Connection (macDms = true) established. Disable Polling
                            2026-05-21 11:15:00.094  - info: host.ioBroker instance system.adapter.ical.1 in version "1.20.1" started with pid 1347962
                            2026-05-21 11:15:01.965  - info: ical.1 (1347962) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                            2026-05-21 11:15:02.781  - info: ical.1 (1347962) processing URL: xxx
                            2026-05-21 11:15:04.113  - info: host.ioBroker instance system.adapter.ical.0 in version "1.20.1" started with pid 1348018
                            2026-05-21 11:15:05.832  - info: ical.0 (1348018) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                            2026-05-21 11:15:06.610  - info: ical.0 (1348018) processing URL: xxx
                            2026-05-21 11:15:08.103  - info: ical.1 (1347962) Terminated (NO_ERROR): Without reason
                            2026-05-21 11:15:08.658  - info: host.ioBroker instance system.adapter.ical.1 having pid 1347962 terminated with code 0 (NO_ERROR)
                            2026-05-21 11:15:11.941  - info: ical.0 (1348018) Terminated (NO_ERROR): Without reason
                            2026-05-21 11:15:12.502  - info: host.ioBroker instance system.adapter.ical.0 having pid 1348018 terminated with code 0 (NO_ERROR)
                            ./iob_diag.sh --de
                            ```bash
                            Script v.2026-05-20
                            *** GRUNDSYSTEM ***
                                     Chassis: desktop 🖥️
                            Docker          : false
                            Unknown
                            Kernel          : x86_64
                            Userland        : 64bit
                            Das System wurde vor 243 Tagen installiert (am 19.09.2025).
                             11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
                            CPU threads     : 4
                            *** ZEIT UND ZEITZONEN ***
                                           Local time: Thu 2026-05-21 11:21:33 CEST
                                       Universal time: Thu 2026-05-21 09:21:33 UTC
                                             RTC time: Thu 2026-05-21 09:21:33
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User und Gruppen ***
                            User der 'iob diag' aufgerufen hat:
                            pi
                            HOME=/home/pi
                            User der den 'js-controller' ausführt:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           4.3G          0B        4.3G
                                     9221 M used memory
                                     9345 M active memory
                                     2737 M inactive memory
                                     2733 M free memory
                                      801 M buffer memory
                                     3462 M swap cache
                                     4095 M total swap
                                        0 M used swap
                                     4095 M free swap
                            top - 11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
                            Tasks: 235 total,   2 running, 233 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 18.6 us,  9.3 sy,  0.0 ni, 72.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  15877.7 total,   2737.4 free,   9218.2 used,   4263.2 buff/cache
                            MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6659.5 avail Mem
                            Es wurden keine kritischen Fehler gefunden
                            *** FILESYSTEM ***
                            /var:
                            5.3G    /var/
                            4.4G    /var/log
                            760M    /var/lib
                            USB-Devices by-id:
                            USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
                            bevorzuge immer die Links 'by-id':
                            Keine Geräte gefunden 'by-id'
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            ✓ Node.js ist korrekt installiert
                            nodejs:
                              Version table:
                            Keine bekannten Sicherheitslücken in der Node.js-Version erkannt!
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            Hosts:
                            ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152566)
                            admin:          7.8.25
                            javascript:     9.2.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        22292
                            States:         22954
                            Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
                            Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
                            Get:4 https://repos.influxdata.com/debian stable InRelease [6922 B]
                            Fetched 6922 B in 1s (7184 B/s)
                            Offene Systemupdates: 2
                            EDIT:
                            Mit internem Zigbee kann ich nicht dienen. Ich nutze Zigbee2mqqt auf einer separaten Hardware
                            #TeamInventwo
                            Unsere Adapter:
                            • skvarelS skvarel
                              ./iob_diag.sh
                              ```bash
                              Script v.2026-05-20
                              *** BASE SYSTEM ***
                                       Chassis: desktop 🖥️
                              Docker          : false
                              Unknown
                              Kernel          : x86_64
                              Userland        : 64bit
                              CPU threads     : 4
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              HOME=/home/iobroker
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           4.3G          0B        4.3G
                                       9220 M used memory
                                       2735 M free memory
                                        800 M buffer memory
                                       3461 M swap cache
                                       4095 M total swap
                                          0 M used swap
                                       4095 M free swap
                              *** FILESYSTEM ***
                              /var:
                              5.3G    /var/
                              4.4G    /var/log
                              760M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: redis
                              Hosts:
                              admin:          7.8.25
                              javascript:     9.2.2
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        22292
                              States:         22954
                              ./iob_diag.sh --de
                              ```bash
                              Script v.2026-05-20
                              *** GRUNDSYSTEM ***
                                       Chassis: desktop 🖥️
                              Docker          : false
                              Unknown
                              Kernel          : x86_64
                              Userland        : 64bit
                              CPU threads     : 4
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           4.3G          0B        4.3G
                                       9221 M used memory
                                       2733 M free memory
                                        801 M buffer memory
                                       3462 M swap cache
                                       4095 M total swap
                                          0 M used swap
                                       4095 M free swap
                              *** FILESYSTEM ***
                              /var:
                              5.3G    /var/
                              4.4G    /var/log
                              760M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: redis
                              Hosts:
                              admin:          7.8.25
                              javascript:     9.2.2
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        22292
                              States:         22954
                              EDIT:
                              #860
                              @skvarel sagte:
                              Das hilft mir aber auch. Das Skript erkennt die Situation und gibt dann in deinem Fall auch erst gar nichts konkret zu Zigbee aus. Nur:
                              USB-Devices by-id:
                              • skvarelS skvarel
                                ./iob_diag.sh
                                ```bash
                                Script v.2026-05-20
                                *** BASE SYSTEM ***
                                         Chassis: desktop 🖥️
                                Docker          : false
                                Unknown
                                Kernel          : x86_64
                                Userland        : 64bit
                                CPU threads     : 4
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                HOME=/home/iobroker
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           4.3G          0B        4.3G
                                         9220 M used memory
                                         2735 M free memory
                                          800 M buffer memory
                                         3461 M swap cache
                                         4095 M total swap
                                            0 M used swap
                                         4095 M free swap
                                *** FILESYSTEM ***
                                /var:
                                5.3G    /var/
                                4.4G    /var/log
                                760M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.9.7
                                /usr/bin/npx            10.9.7
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: redis
                                Hosts:
                                admin:          7.8.25
                                javascript:     9.2.2
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        22292
                                States:         22954
                                ./iob_diag.sh --de
                                ```bash
                                Script v.2026-05-20
                                *** GRUNDSYSTEM ***
                                         Chassis: desktop 🖥️
                                Docker          : false
                                Unknown
                                Kernel          : x86_64
                                Userland        : 64bit
                                CPU threads     : 4
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           4.3G          0B        4.3G
                                         9221 M used memory
                                         2733 M free memory
                                          801 M buffer memory
                                         3462 M swap cache
                                         4095 M total swap
                                            0 M used swap
                                         4095 M free swap
                                *** FILESYSTEM ***
                                /var:
                                5.3G    /var/
                                4.4G    /var/log
                                760M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.9.7
                                /usr/bin/npx            10.9.7
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: redis
                                Hosts:
                                admin:          7.8.25
                                javascript:     9.2.2
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        22292
                                States:         22954
                                EDIT:
                                #861
                                @skvarel
                                Ich hätte dich angechattet, aber das funktioniert nicht.
                                Du hast im Ausschnitt des Logs private Daten drin.
                                  @skvarel
                                  skvarelS Offline
                                  skvarelS Offline
                                  skvarel
                                  #862
                                  @Thomas-Braun .. jetzt solltest du mit mir chatten können
                                  #TeamInventwo
                                  Unsere Adapter:
                                  • NashraN Offline
                                    NashraN Offline
                                    Nashra
                                    Most Active Forum Testing
                                    schrieb am zuletzt editiert von Nashra
                                    #863
                                    Hier von dem aktuellen Script...
                                    ```bash
                                    Script v.2026-05-20
                                    *** BASE SYSTEM ***
                                           Icon name: computer-container
                                             Chassis: container ☐
                                      Virtualization: lxc
                                              Kernel: Linux 7.0.2-4-pve
                                    OS is similar to:
                                    model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
                                    Docker          : false
                                    Virtualization  : lxc
                                    Kernel          : x86_64
                                    Userland        : 64bit
                                    System was installed 163 days ago (on 2025-12-08).
                                     11:54:32 up 18:17,  0 users,  load average: 2.96, 2.91, 2.78
                                    CPU threads     : 4
                                                   Local time: Thu 2026-05-21 11:54:32 CEST
                                               Universal time: Thu 2026-05-21 09:54:32 UTC
                                                     RTC time: n/a
                                                  NTP service: inactive
                                              RTC in local TZ: no
                                    jack
                                    HOME=/home/jack
                                    GROUPS=jack sudo users iobroker
                                    iobroker[sudo] password for jack:
                                    HOME=/home/iobroker
                                    Desktop:
                                    Session:
                                    *** MEMORY ***
                                    Mem:             12G        6.5G        5.2G        3.2M        1.2G        6.4G
                                    Swap:             0B          0B          0B
                                    Total:           12G        6.5G        5.2G
                                    Active iob-Instances:   51
                                            12288 M total memory
                                             6165 M used memory
                                             1229 M active memory
                                             5857 M inactive memory
                                             4936 M free memory
                                                0 M buffer memory
                                             1189 M swap cache
                                                0 M total swap
                                                0 M used swap
                                                0 M free swap
                                    top - 11:54:37 up 18:17,  0 users,  load average: 2.80, 2.88, 2.77
                                    Tasks:  77 total,   2 running,  75 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s): 48.8 us,  7.3 sy,  0.0 ni, 41.5 id,  0.0 wa,  0.0 hi,  2.4 si,  0.0 st
                                    MiB Mem :  12288.0 total,   4933.0 free,   6167.9 used,   1189.9 buff/cache
                                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6120.1 avail Mem
                                    dmesg: read kernel buffer failed: Operation not permitted
                                    *** FILESYSTEM ***
                                    /dev/mapper/pve-vm--100--disk--0 ext4       25G   12G   12G  52% /
                                    none                             tmpfs     492K  4.0K  488K   1% /dev
                                    none                             tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                                    udev                             devtmpfs  6.9G     0  6.9G   0% /dev/tty
                                    tmpfs                            tmpfs     3.2G  104K  3.2G   1% /run
                                    tmpfs                            tmpfs     7.8G  3.0M  7.8G   1% /tmp
                                    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                                    /var:
                                    2.4G    /var/
                                    2.1G    /var/log/journal/d283c01113b6426689c9fe48dd9c672b
                                    2.1G    /var/log
                                    169M    /var/lib
                                    Archived and active journals take up 551M in the file system.
                                    1.7G    /opt/iobroker/backups/
                                    2.7G    /opt/iobroker/iobroker-data/
                                    1.1G    /opt/iobroker/iobroker-data/backup-objects
                                    816M    /opt/iobroker/iobroker-data/files
                                    655M    /opt/iobroker/iobroker-data/history
                                    269M    /opt/iobroker/iobroker-data/files/vis.0
                                    97M     /opt/iobroker/iobroker-data/states.jsonl
                                    58M     /opt/iobroker/iobroker-data/objects.jsonl
                                    35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_11-37_states.jsonl.gz
                                    35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_09-37_states.jsonl.gz
                                    35M     /opt/iobroker/iobroker-data/backup-objects/2026-05-21_07-37_states.jsonl.gz
                                    USB-Devices by-id:
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    zigbee.0        ...936c4ce259fb3e-if00-port0        ...936c4ce259fb3e-if00-port0        ✓ Matching
                                    /usr/bin/npm            10.9.7
                                    /usr/bin/npx            10.9.7
                                    nodejs:
                                      Version table:
                                            500 http://security.debian.org trixie-security/main amd64 Packages
                                            500 http://deb.debian.org/debian trixie/main amd64 Packages
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 65841)
                                    js-controller:  7.0.7
                                    admin:          7.8.23
                                    javascript:     9.0.18
                                    nodejs modules from github:     10
                                    +-- iobroker.dwd@2.8.5 (git+ssh://git@github.com/arteck/ioBroker.dwd.git#d01fd75bacd6f2bd2c7b0612181e6118693bab71)
                                    +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
                                    +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
                                    +-- iobroker.logparser@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.logparser.git#266cccca93fd6f272ebce95e8f9e936363c30263)
                                    +-- iobroker.openmeteo-notify@0.1.3 (git+ssh://git@github.com/ipod86/ioBroker.openmeteo-notify.git#60b75eafea469372d5b30239f90b78adc67a5ef4)
                                    +-- iobroker.parcel@0.3.1 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#c579b7c8e878e72c56ae1c30c2fed9292b469895)
                                    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                    +-- iobroker.tidy@0.1.1 (git+ssh://git@github.com/inventwo/ioBroker.tidy.git#3920e88695d8032773a7066efd0b4b4afdacbcfc)
                                    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                    +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                                    Adapter State
                                      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
                                    + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
                                      system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
                                    + system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                                    + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                                      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                                    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                                    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                                      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                                    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                                      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                                      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                                      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                                      system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
                                    + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                      system.adapter.labcom.0                 : labcom                : ioBroker                                 - disabled
                                    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                                    + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
                                    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                                    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                                    + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
                                      system.adapter.nut.2                    : nut                   : ioBroker                                 - disabled
                                    + system.adapter.nut.3                    : nut                   : ioBroker                                 -  enabled
                                    + system.adapter.open-meteo-weather.0     : open-meteo-weather    : ioBroker                                 -  enabled
                                      system.adapter.open-meteo-weather.1     : open-meteo-weather    : ioBroker                                 - disabled
                                    + system.adapter.openmeteo-notify.0       : openmeteo-notify      : ioBroker                                 -  enabled
                                      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                                    + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                                    + system.adapter.pirate-weather.0         : pirate-weather        : ioBroker                                 -  enabled
                                    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                                    + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
                                    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                                    + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
                                      system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
                                    + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                                      system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
                                    + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
                                      system.adapter.synology.2               : synology              : ioBroker                                 - disabled, port: 5000
                                    + system.adapter.tagesschau.0             : tagesschau            : ioBroker                                 -  enabled
                                      system.adapter.tidy.0                   : tidy                  : ioBroker                                 - disabled
                                    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                                    + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 443
                                      system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
                                    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
                                      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                                      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                                      system.adapter.vis-owl.0                : vis-owl               : ioBroker                                 - disabled
                                      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                    + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
                                      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                                      system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
                                    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                                      system.adapter.wettercom.0              : wettercom             : ioBroker                                 - disabled
                                    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                                    + instance is alive
                                    │ (index) │ name               │ url                                                     │ auto upgrade │
                                    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                    │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                                    │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                                    │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
                                    │ 3       │ 'system.adapter.ankersolix2'                 │ 'ankersolix2'                 │ '2.4.1'  │ 'none'         │
                                    │ 4       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.14' │ 'none'         │
                                    │ 5       │ 'system.adapter.birthdays'                   │ 'birthdays'                   │ '5.0.0'  │ 'none'         │
                                    │ 6       │ 'system.adapter.brightsky'                   │ 'brightsky'                   │ '1.0.1'  │ 'none'         │
                                    │ 7       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'  │ 'none'         │
                                    │ 8       │ 'system.adapter.deyeidc'                     │ 'deyeidc'                     │ '0.3.1'  │ 'none'         │
                                    │ 9       │ 'system.adapter.dwd'                         │ 'dwd'                         │ '2.8.5'  │ 'none'         │
                                    │ 10      │ 'system.adapter.echarts'                     │ 'echarts'                     │ '3.1.0'  │ 'none'         │
                                    │ 11      │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'  │ 'none'         │
                                    │ 12      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.2'  │ 'none'         │
                                    │ 13      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'  │ 'none'         │
                                    │ 14      │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
                                    │ 15      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'  │ 'none'         │
                                    │ 16      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.20.0' │ 'none'         │
                                    │ 17      │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0'  │ 'none'         │
                                    │ 18      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'  │ 'none'         │
                                    │ 19      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
                                    │ 20      │ 'system.adapter.icons-material-svg'          │ 'icons-material-svg'          │ '0.1.0'  │ 'none'         │
                                    │ 21      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
                                    │ 22      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
                                    │ 23      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'  │ 'none'         │
                                    │ 24      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
                                    │ 25      │ 'system.adapter.iot'                         │ 'iot'                         │ '5.0.12' │ 'none'         │
                                    │ 26      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18' │ 'none'         │
                                    │ 27      │ 'system.adapter.labcom'                      │ 'labcom'                      │ '0.1.4'  │ 'none'         │
                                    │ 28      │ 'system.adapter.lgtv'                        │ 'lgtv'                        │ '2.5.0'  │ 'none'         │
                                    │ 29      │ 'system.adapter.linux-control'               │ 'linux-control'               │ '1.1.5'  │ 'none'         │
                                    │ 30      │ 'system.adapter.logparser'                   │ 'logparser'                   │ '2.4.0'  │ 'none'         │
                                    │ 31      │ 'system.adapter.nut'                         │ 'nut'                         │ '1.7.0'  │ 'none'         │
                                    │ 32      │ 'system.adapter.open-meteo-weather'          │ 'open-meteo-weather'          │ '3.1.0'  │ 'none'         │
                                    │ 33      │ 'system.adapter.openmeteo-notify'            │ 'openmeteo-notify'            │ '0.1.3'  │ 'none'         │
                                    │ 34      │ 'system.adapter.openweathermap'              │ 'openweathermap'              │ '1.4.0'  │ 'none'         │
                                    │ 35      │ 'system.adapter.parcel'                      │ 'parcel'                      │ '0.3.1'  │ 'none'         │
                                    │ 36      │ 'system.adapter.ping'                        │ 'ping'                        │ '2.0.0'  │ 'none'         │
                                    │ 37      │ 'system.adapter.pirate-weather'              │ 'pirate-weather'              │ '0.8.0'  │ 'none'         │
                                    │ 38      │ 'system.adapter.pollenflug'                  │ 'pollenflug'                  │ '2.0.0'  │ 'none'         │
                                    │ 39      │ 'system.adapter.proxmox'                     │ 'proxmox'                     │ '2.4.10' │ 'none'         │
                                    │ 40      │ 'system.adapter.rest-api'                    │ 'rest-api'                    │ '4.0.1'  │ 'none'         │
                                    │ 41      │ 'system.adapter.rssfeed'                     │ 'rssfeed'                     │ '4.0.3'  │ 'none'         │
                                    │ 42      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
                                    │ 43      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
                                    │ 44      │ 'system.adapter.snmp'                        │ 'snmp'                        │ '3.4.0'  │ 'none'         │
                                    │ 45      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
                                    │ 46      │ 'system.adapter.synology'                    │ 'synology'                    │ '3.1.0'  │ 'none'         │
                                    │ 47      │ 'system.adapter.tagesschau'                  │ 'tagesschau'                  │ '0.6.0'  │ 'none'         │
                                    │ 48      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'  │ 'none'         │
                                    │ 49      │ 'system.adapter.tidy'                        │ 'tidy'                        │ '0.1.1'  │ 'none'         │
                                    │ 50      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'  │ 'none'         │
                                    │ 51      │ 'system.adapter.trashschedule'               │ 'trashschedule'               │ '5.3.0'  │ 'none'         │
                                    │ 52      │ 'system.adapter.tuya'                        │ 'tuya'                        │ '3.17.0' │ 'none'         │
                                    │ 53      │ 'system.adapter.unifi'                       │ 'unifi'                       │ '0.7.0'  │ 'none'         │
                                    │ 54      │ 'system.adapter.unifi-network'               │ 'unifi-network'               │ '1.4.0'  │ 'none'         │
                                    │ 55      │ 'system.adapter.upnp'                        │ 'upnp'                        │ '1.1.0'  │ 'none'         │
                                    │ 56      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
                                    │ 57      │ 'system.adapter.vis-bars'                    │ 'vis-bars'                    │ '0.1.4'  │ 'none'         │
                                    │ 58      │ 'system.adapter.vis-canvas-gauges'           │ 'vis-canvas-gauges'           │ '1.0.1'  │ 'none'         │
                                    │ 59      │ 'system.adapter.vis-fancyswitch'             │ 'vis-fancyswitch'             │ '1.1.0'  │ 'none'         │
                                    │ 60      │ 'system.adapter.vis-google-fonts'            │ 'vis-google-fonts'            │ '1.0.4'  │ 'none'         │
                                    │ 61      │ 'system.adapter.vis-history'                 │ 'vis-history'                 │ '1.0.0'  │ 'none'         │
                                    │ 62      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'  │ 'none'         │
                                    │ 63      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.3' │ 'none'         │
                                    │ 64      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '3.3.5'  │ 'none'         │
                                    │ 65      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'  │ 'none'         │
                                    │ 66      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
                                    │ 67      │ 'system.adapter.vis-map'                     │ 'vis-map'                     │ '1.1.2'  │ 'none'         │
                                    │ 68      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.94' │ 'none'         │
                                    │ 69      │ 'system.adapter.vis-owl'                     │ 'vis-owl'                     │ '0.2.13' │ 'none'         │
                                    │ 70      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'  │ 'none'         │
                                    │ 71      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'  │ 'none'         │
                                    │ 72      │ 'system.adapter.weather-warnings'            │ 'weather-warnings'            │ '0.10.1' │ 'none'         │
                                    │ 73      │ 'system.adapter.weatherunderground'          │ 'weatherunderground'          │ '3.7.0'  │ 'none'         │
                                    │ 74      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
                                    │ 75      │ 'system.adapter.wettercom'                   │ 'wettercom'                   │ '0.1.5'  │ 'none'         │
                                    │ 76      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.0.0'  │ 'none'         │
                                    │ 77      │ 'system.adapter.zigbee'                      │ 'zigbee'                      │ '3.3.5'  │ 'none'         │
                                    Adapter    "admin"        : 7.8.23   , installed 7.8.23
                                    Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
                                    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                                    Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
                                    Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
                                    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
                                    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
                                    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                                    Adapter    "email"        : 2.0.4    , installed 2.0.4
                                    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.2
                                    Adapter    "history"      : 4.0.0    , installed 4.0.0
                                    Adapter    "ical"         : 1.20.0   , installed 1.20.0
                                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                    Adapter    "iot"          : 5.0.12   , installed 5.0.12
                                    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                                    Controller "js-controller": 7.0.7    , installed 7.0.7
                                    Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                                    Adapter    "nut"          : 1.7.0    , installed 1.7.0
                                    Adapter    "open-meteo-weather": 3.1.0, installed 3.1.0
                                    Adapter    "ping"         : 1.7.9    , installed 2.0.0
                                    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                                    Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
                                    Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
                                    Adapter    "rssfeed"      : 4.0.3    , installed 4.0.3
                                    Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                    Adapter    "tagesschau"   : 0.6.0    , installed 0.6.0
                                    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                    Adapter    "unifi-network": 1.4.0    , installed 1.4.0
                                    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                                    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                                    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                                    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                                    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                    Adapter    "weather-warnings": 0.10.1, installed 0.10.1
                                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                    Adapter    "web"          : 8.0.0    , installed 8.0.0
                                    Adapter    "ws"           : 4.0.0    , installed 4.0.0
                                    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
                                    Objects and States
                                    Objects:        58986
                                    States:         51570
                                    Hit:1 http://security.debian.org trixie-security InRelease
                                    Hit:2 http://deb.debian.org/debian trixie InRelease
                                    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                                    udp        UNCONN      0            0                        0.0.0.0:sunrpc                  0.0.0.0:*          users:(("rpcbind",pid=133,fd=5),("systemd",pid=1,fd=35))
                                    udp        UNCONN      0            0                        0.0.0.0:49687                   0.0.0.0:*          users:(("io.snmp.0",pid=1075,fd=31))
                                    udp        UNCONN      0            0                        0.0.0.0:33873                   0.0.0.0:*          users:(("io.upnp.0",pid=1628,fd=30))
                                    udp        UNCONN      0            0                        0.0.0.0:1900                    0.0.0.0:*          users:(("io.upnp.0",pid=1628,fd=31))
                                    udp        UNCONN      0            0                   192.168.1.14:mdns                    0.0.0.0:*          users:(("io.tr-064.0",pid=1153,fd=62))
                                    udp        UNCONN      0            0                        0.0.0.0:coap                    0.0.0.0:*          users:(("io.shelly.0",pid=1032,fd=39))
                                    udp        UNCONN      0            0                        0.0.0.0:55521                   0.0.0.0:*          users:(("io.snmp.0",pid=1075,fd=30))
                                    udp        UNCONN      0            0                        0.0.0.0:6666                    0.0.0.0:*          users:(("io.tuya.0",pid=1169,fd=44))
                                    udp        UNCONN      0            0                        0.0.0.0:6667                    0.0.0.0:*          users:(("io.tuya.0",pid=1169,fd=45))
                                    udp        UNCONN      0            0                           [::]:sunrpc                     [::]:*          users:(("rpcbind",pid=133,fd=7),("systemd",pid=1,fd=37))
                                    tcp        LISTEN      0            511                 192.168.1.14:8082                    0.0.0.0:*          users:(("io.web.0",pid=1768,fd=30))
                                    tcp        LISTEN      0            1                        0.0.0.0:9999                    0.0.0.0:*          users:(("nc",pid=492379,fd=3))
                                    tcp        LISTEN      0            511                      0.0.0.0:1882                    0.0.0.0:*          users:(("io.shelly.1",pid=1048,fd=31))
                                    tcp        LISTEN      0            511                      0.0.0.0:9000                    0.0.0.0:*          users:(("iobroker.js-con",pid=153,fd=29))
                                    tcp        LISTEN      0            511                      0.0.0.0:9001                    0.0.0.0:*          users:(("iobroker.js-con",pid=153,fd=23))
                                    tcp        LISTEN      0            100                    127.0.0.1:smtp                    0.0.0.0:*          users:(("master",pid=308,fd=13))
                                    tcp        LISTEN      0            4096                     0.0.0.0:sunrpc                  0.0.0.0:*          users:(("rpcbind",pid=133,fd=4),("systemd",pid=1,fd=34))
                                    tcp        LISTEN      0            511                            *:8093                          *:*          users:(("io.rest-api.0",pid=1510,fd=29))
                                    tcp        LISTEN      0            511                            *:8087                          *:*          users:(("io.simple-api.0",pid=1527,fd=30))
                                    tcp        LISTEN      0            511                            *:8084                          *:*          users:(("io.ws.0",pid=1799,fd=29))
                                    tcp        LISTEN      0            511                            *:tproxy                        *:*          users:(("io.admin.0",pid=330,fd=30))
                                    tcp        LISTEN      0            100                        [::1]:smtp                       [::]:*          users:(("master",pid=308,fd=14))
                                    tcp        LISTEN      0            4096                           *:ssh                           *:*          users:(("sshd",pid=184,fd=3),("systemd",pid=1,fd=59))
                                    tcp        LISTEN      0            4096                        [::]:sunrpc                     [::]:*          users:(("rpcbind",pid=133,fd=6),("systemd",pid=1,fd=36))
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Arbeitszimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Arbeitszimmer: 18.31 g/m³
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Arbeitszimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Arbeitszimmer: 24.09 °C
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Arbeitszimmer] Fixed Calculation: RH_in=86%, Threshold=60 -> Empfehlung Lüften: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Arbeitszimmer] Absolute Humidity Calculation: AH_in=18.31 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Waeschezimmer: 13.09 g/m³
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Waeschezimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Waeschezimmer: 18.57 °C
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Waeschezimmer] Fixed Calculation: RH_in=67%, Threshold=60 -> Empfehlung Lüften: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Waeschezimmer] Absolute Humidity Calculation: AH_in=13.09 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Flur gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Flur: 15.34 g/m³
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Flur gespeichert in 0_userdata.0.Raumklima.Taupunkt.Flur: 21.17 °C
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Flur] Fixed Calculation: RH_in=71.5%, Threshold=60 -> Empfehlung Lüften: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Flur] Absolute Humidity Calculation: AH_in=15.34 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Schlafzimmer: 13.14 g/m³
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Schlafzimmer: 18.66 °C
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Schlafzimmer] Fixed Calculation: RH_in=63%, Threshold=60 -> Empfehlung Lüften: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Schlafzimmer] Absolute Humidity Calculation: AH_in=13.14 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Werkstatt gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Werkstatt: 10.95 g/m³
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: Taupunkt in Werkstatt gespeichert in 0_userdata.0.Raumklima.Taupunkt.Werkstatt: 15.81 °C
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Werkstatt] Fixed Calculation: RH_in=50%, Threshold=60 -> Empfehlung Lüften: false
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: [Werkstatt] Absolute Humidity Calculation: AH_in=10.95 g/m³, AH_out=11.69 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: false
                                    2026-05-21 11:50:00.006  - info: javascript.0 (452) script.js.Heizungen.Raumklima: runCalculation ausgelöst (10-Minuten-Intervall)
                                    2026-05-21 11:50:44.476  - info: javascript.0 (452) script.js.Heizungen.Wohnzimmer: Stopping script
                                    2026-05-21 11:50:45.925  - info: javascript.0 (452) script.js.Heizungen.Büro: Stopping script
                                    2026-05-21 11:52:07.611  - info: parcel.0 (1855) Relogin to Amazon successful
                                    Gruß Ralf
