  4. iob diag - Skript
    1.0k
iob diag - Skript
863 Beiträge 52 Kommentatoren 309.4k Aufrufe 40 Beobachtet
  • teletapiT Online
    teletapiT Online
    teletapi
    schrieb am zuletzt editiert von teletapi
    #840
    curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Work_in_progress/diag.sh > iob_diag.sh
    chmod 744 iob_diag.sh
    ./iob_diag.sh
    Das war der Befehl:
    ```bash
    Script v.2026-05-19
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Raspberrypi5
           Icon name: computer
              Kernel: Linux 6.18.29+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 952 days ago (on 2023-10-10).
    Systemuptime and Load:
     00:28:24 up 57 min,  1 user,  load average: 0.54, 0.29, 0.35
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2026-05-20 00:28:24 CEST
               Universal time: Tue 2026-05-19 22:28:24 UTC
                     RTC time: Tue 2026-05-19 22:28:24
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobrokerHOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:             17G        5.9G        9.4G         26M        1.8G         11G
    Swap:           209M          0B        209M
    Total:           17G        5.9G        9.6G
    Active iob-Instances:   38
            16218 M total memory
             5646 M used memory
             5512 M active memory
             1064 M inactive memory
             8984 M free memory
              224 M buffer memory
             1507 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 00:28:24 up 57 min,  1 user,  load average: 0.50, 0.29, 0.35
    Tasks: 213 total,   1 running, 212 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  9.8 us,  2.4 sy,  0.0 ni, 87.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16218.4 total,   9000.2 free,   5630.6 used,   1732.2 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.  10587.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.9G     0  7.9G   0% /dev
    tmpfs          tmpfs     3.2G   17M  3.2G   1% /run
    /dev/nvme0n1p2 ext4      117G   18G   95G  16% /
    tmpfs          tmpfs     8.0G     0  8.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     8.0G  8.9M  8.0G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
    /dev/nvme0n1p1 vfat      510M   75M  436M  15% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    tmpfs          tmpfs     1.6G   32K  1.6G   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Tue May 19 23:30:38 2026] EXT4-fs (nvme0n1p2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
    [Tue May 19 23:30:39 2026] EXT4-fs (nvme0n1p2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.9G    /var/
    2.0G    /var/lib
    1.7G    /var/lib/influxdb/engine/data/5ba497ab85a9233a/autogen
    Archived and active journals take up 196.9M in the file system.
    /opt/iobroker/backups:
    4.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    651M    /opt/iobroker/iobroker-data/
    262M    /opt/iobroker/iobroker-data/files
    127M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/node-red
    71M     /opt/iobroker/iobroker-data/node-red/node_modules
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    17M     /opt/iobroker/iobroker-data/states.jsonl
    9.0M    /opt/iobroker/iobroker-data/files/devices/assets/index-DEPE9oow.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a3b83b6a53aef11aaf2321455516304-if00-port0
    *** ZigBee Settings ***
    ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        ...f2321455516304-if00-port0        ...f2321455516304-if00-port0        ✓ Matching
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.15.0
    /usr/bin/node           v24.15.0
    /usr/bin/npm            11.12.1
    /usr/bin/npx            11.12.1
    ✓ Node.js installation is correct
    nodejs:
      Installed: 24.15.0-1nodesource1
      Candidate: 24.15.0-1nodesource1
      Version table:
     *** 24.15.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
         24.14.1-1nodesource1 1001
         24.14.0-1nodesource1 1001
         24.13.1-1nodesource1 1001
         24.13.0-1nodesource1 1001
         24.12.0-1nodesource1 1001
         24.11.1-1nodesource1 1001
         24.11.0-1nodesource1 1001
         24.10.0-1nodesource1 1001
         24.9.0-1nodesource1 1001
         24.8.0-1nodesource1 1001
         24.7.0-1nodesource1 1001
         24.6.0-1nodesource1 1001
         24.5.0-1nodesource1 1001
         24.4.1-1nodesource1 1001
         24.4.0-1nodesource1 1001
         24.3.0-1nodesource1 1001
         24.1.0-1nodesource1 1001
         24.0.2-1nodesource1 1001
         24.0.1-1nodesource1 1001
         24.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    Vulnerabilities detected in the Node.js version!
    node:fs:2414
        return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
        at Object.writeFileSync (node:fs:2414:20)
        at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
        at Object.onceWrapper (node:events:631:26)
        at ClientRequest.emit (node:events:509:28)
        at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:798:27)
        at HTTPParser.parserOnHeadersComplete (node:_http_common:125:17)
        at TLSSocket.socketOnData (node:_http_client:633:22)
        at TLSSocket.emit (node:events:509:28)
        at addChunk (node:internal/streams/readable:563:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:514:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    Node.js v24.15.0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberrypi5        Raspberrypi5 (version: 7.1.2, hostname: Raspberrypi5  , alive, uptime: 3453)
    Core adapters versions
    js-controller:  7.1.2
    admin:          7.8.25
    javascript:     9.2.2
    nodejs modules from github:     2
    +-- iobroker.influxdb@4.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.influxdb.git#ae7b21709836538e11e7059472f4d72ce49b223e)
    +-- iobroker.jarvis@4.0.0-alpha.13 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#56f23ff400d6411cd23a4cf9e61790dc38fb288c)
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
      system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             -  enabled
    + system.adapter.alpha-ess.0              : alpha-ess             : Raspberrypi5                             -  enabled
    + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
    + system.adapter.devices.0                : devices               : Raspberrypi5                             -  enabled
    + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
    + system.adapter.e3oncan.0                : e3oncan               : Raspberrypi5                             -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             -  enabled
      system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Raspberrypi5                             - disabled
    + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: Raspberrypi5                             -  enabled
      system.adapter.energiefluss-erweitert.3 : energiefluss-erweitert: Raspberrypi5                             - disabled
    + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
      system.adapter.fullcalendar.0           : fullcalendar          : Raspberrypi5                             - disabled
    + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
    + system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : Raspberrypi5                             -  enabled
    + system.adapter.hue.0                    : hue                   : Raspberrypi5                             -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
      system.adapter.ical.1                   : ical                  : Raspberrypi5                             - disabled
    + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : Raspberrypi5                             - disabled
    + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
    + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
    + system.adapter.matter.0                 : matter                : Raspberrypi5                             -  enabled
    + system.adapter.modbus.0                 : modbus                : Raspberrypi5                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : Raspberrypi5                             -  enabled
    + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
      system.adapter.openweathermap.0         : openweathermap        : Raspberrypi5                             -  enabled
    + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
    + system.adapter.pirate-weather.0         : pirate-weather        : Raspberrypi5                             -  enabled
    + system.adapter.reolink.0                : reolink               : Raspberrypi5                             -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
    + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
    + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
    + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Raspberrypi5                             - disabled
      system.adapter.wled.0                   : wled                  : Raspberrypi5                             - disabled
    + system.adapter.zigbee.0                 : zigbee                : Raspberrypi5                             -  enabled, port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a3b83b6a53aef11aaf2321455516304-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                      │ name                     │ version          │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '7.8.25'         │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'                 │ 'alexa2'                 │ '3.27.4'         │ 'none'         │
    │ 2       │ 'system.adapter.alias-manager'          │ 'alias-manager'          │ '2.1.0'          │ 'none'         │
    │ 3       │ 'system.adapter.alpha-ess'              │ 'alpha-ess'              │ '4.1.0'          │ 'none'         │
    │ 4       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'         │ 'none'         │
    │ 5       │ 'system.adapter.cloud'                  │ 'cloud'                  │ '6.0.4'          │ 'none'         │
    │ 6       │ 'system.adapter.devices'                │ 'devices'                │ '2.0.18'         │ 'none'         │
    │ 7       │ 'system.adapter.discovery'              │ 'discovery'              │ '5.0.0'          │ 'none'         │
    │ 8       │ 'system.adapter.e3oncan'                │ 'e3oncan'                │ '1.0.2'          │ 'none'         │
    │ 9       │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'          │ 'none'         │
    │ 10      │ 'system.adapter.fritzdect'              │ 'fritzdect'              │ '2.6.2'          │ 'none'         │
    │ 11      │ 'system.adapter.fullcalendar'           │ 'fullcalendar'           │ '2.4.5'          │ 'none'         │
    │ 12      │ 'system.adapter.hm-rega'                │ 'hm-rega'                │ '5.1.0'          │ 'none'         │
    │ 13      │ 'system.adapter.hm-rpc'                 │ 'hm-rpc'                 │ '3.0.2'          │ 'none'         │
    │ 14      │ 'system.adapter.homeconnect'            │ 'homeconnect'            │ '1.6.1'          │ 'none'         │
    │ 15      │ 'system.adapter.hue'                    │ 'hue'                    │ '3.16.2'         │ 'none'         │
    │ 16      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'         │ 'none'         │
    │ 17      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.3'          │ 'none'         │
    │ 18      │ 'system.adapter.iot'                    │ 'iot'                    │ '6.0.3'          │ 'none'         │
    │ 19      │ 'system.adapter.jarvis'                 │ 'jarvis'                 │ '4.0.0-alpha.13' │ 'none'         │
    │ 20      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'          │ 'none'         │
    │ 21      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'          │ 'none'         │
    │ 22      │ 'system.adapter.modbus'                 │ 'modbus'                 │ '8.1.3'          │ 'none'         │
    │ 23      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'          │ 'none'         │
    │ 24      │ 'system.adapter.net-tools'              │ 'net-tools'              │ '1.2.3'          │ 'none'         │
    │ 25      │ 'system.adapter.nspanel-lovelace-ui'    │ 'nspanel-lovelace-ui'    │ '0.17.8'         │ 'none'         │
    │ 26      │ 'system.adapter.nuki'                   │ 'nuki'                   │ '2.0.0'          │ 'none'         │
    │ 27      │ 'system.adapter.openweathermap'         │ 'openweathermap'         │ '1.4.0'          │ 'none'         │
    │ 28      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'          │ 'none'         │
    │ 29      │ 'system.adapter.pirate-weather'         │ 'pirate-weather'         │ '0.8.0'          │ 'none'         │
    │ 30      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'          │ 'none'         │
    │ 31      │ 'system.adapter.rpi2'                   │ 'rpi2'                   │ '3.0.2'          │ 'none'         │
    │ 32      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'          │ 'none'         │
    │ 33      │ 'system.adapter.socketio'               │ 'socketio'               │ '7.1.3'          │ 'none'         │
    │ 34      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'          │ 'none'         │
    │ 35      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'          │ 'none'         │
    │ 36      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'          │ 'none'         │
    │ 37      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'          │ 'none'         │
    │ 38      │ 'system.adapter.whatsapp-cmb'           │ 'whatsapp-cmb'           │ '0.3.0'          │ 'none'         │
    │ 39      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'          │ 'none'         │
    │ 40      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'          │ 'none'         │
    │ 41      │ 'system.adapter.zigbee'                 │ 'zigbee'                 │ '3.4.5'          │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: beta
    Adapter    "admin"        : 7.8.25   , installed 7.8.25
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "alpha-ess"    : 4.1.0    , installed 4.1.0
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "cloud"        : 6.0.4    , installed 6.0.4
    Adapter    "devices"      : 2.0.18   , installed 2.0.18
    Adapter    "e3oncan"      : 1.0.2    , installed 1.0.2
    Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "hm-rpc"       : 3.0.2    , installed 3.0.2
    Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.20.1   , installed 1.20.1
    Adapter    "influxdb"     : 4.0.2    , installed 4.0.3
    Adapter    "iot"          : 6.0.3    , installed 6.0.3
    Adapter    "jarvis"       : 3.1.8    , installed 4.0.0-alpha.13
    Adapter    "javascript"   : 9.2.2    , installed 9.2.2
    Controller "js-controller": 7.1.2    , installed 7.1.2
    Adapter    "matter"       : 1.0.0    , installed 1.0.0
    Adapter    "modbus"       : 8.1.3    , installed 8.1.3
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "nspanel-lovelace-ui": 0.17.8, installed 0.17.8
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "ping"         : 2.2.4    , installed 2.2.4
    Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
    Adapter    "reolink"      : 1.4.2    , installed 1.4.2
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.1.0    , installed 8.1.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.9.2    , installed 0.9.2
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 3.4.5    , installed 3.4.5
    Objects and States
    Objects:        18706
    States:         18825
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Fetched 6922 B in 0s (35.3 kB/s)
    Reading package lists... Done
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid           State            Recv-Q           Send-Q                                   Local Address:Port                                Peer Address:Port           Process
    udp             UNCONN           0                0                                              0.0.0.0:45342                                    0.0.0.0:*               users:(("io.matter.0",pid=2165,fd=42))
    udp             UNCONN           0                0                                              0.0.0.0:mdns                                     0.0.0.0:*               users:(("io.matter.0",pid=2165,fd=39))
    udp             UNCONN           0                0                                              0.0.0.0:mdns                                     0.0.0.0:*               users:(("io.matter.0",pid=2165,fd=37))
    udp             UNCONN           0                0                                              0.0.0.0:mdns                                     0.0.0.0:*               users:(("avahi-daemon",pid=716,fd=12))
    udp             UNCONN           0                0                                              0.0.0.0:5541                                     0.0.0.0:*               users:(("io.matter.0",pid=2165,fd=36))
    udp             UNCONN           0                0                                              0.0.0.0:57417                                    0.0.0.0:*               users:(("avahi-daemon",pid=716,fd=14))
    udp             UNCONN           0                0                                                    *:mdns                                           *:*               users:(("io.matter.0",pid=2165,fd=40))
    udp             UNCONN           0                0                                                    *:mdns                                           *:*               users:(("io.matter.0",pid=2165,fd=38))
    udp             UNCONN           0                0                                                    *:mdns                                           *:*               users:(("avahi-daemon",pid=716,fd=13))
    udp             UNCONN           0                0                                                    *:5541                                           *:*               users:(("io.matter.0",pid=2165,fd=35))
    udp             UNCONN           0                0                                                    *:57272                                          *:*               users:(("avahi-daemon",pid=716,fd=15))
    udp             UNCONN           0                0                          [fe80::f05b:9255:16fc:d8b2]:dhcpv6-client                                  *:*               users:(("NetworkManager",pid=869,fd=22))
    udp             UNCONN           0                0                          [fe80::b78f:a4e0:4880:4be4]:dhcpv6-client                                  *:*               users:(("NetworkManager",pid=869,fd=35))
    udp             UNCONN           0                0                                                    *:51306                                          *:*               users:(("io.matter.0",pid=2165,fd=41))
    tcp             LISTEN           0                511                                     192.168.178.82:8087                                     0.0.0.0:*               users:(("io.simple-api.0",pid=2232,fd=35))
    tcp             LISTEN           0                511                                            0.0.0.0:1886                                     0.0.0.0:*               users:(("io.sonoff.0",pid=1836,fd=40))
    tcp             LISTEN           0                100                                            0.0.0.0:1883                                     0.0.0.0:*               users:(("mosquitto",pid=989,fd=5))
    tcp             LISTEN           0                20                                           127.0.0.1:smtp                                     0.0.0.0:*               users:(("exim4",pid=1249,fd=5))
    tcp             LISTEN           0                511                                          127.0.0.1:9001                                     0.0.0.0:*               users:(("iobroker.js-con",pid=1301,fd=23))
    tcp             LISTEN           0                511                                          127.0.0.1:9000                                     0.0.0.0:*               users:(("iobroker.js-con",pid=1301,fd=29))
    tcp             LISTEN           0                128                                            0.0.0.0:ssh                                      0.0.0.0:*               users:(("sshd",pid=963,fd=6))
    tcp             LISTEN           0                511                                     192.168.178.82:18701                                    0.0.0.0:*               users:(("io.hm-rpc.0",pid=1617,fd=35))
    tcp             LISTEN           0                511                                     192.168.178.82:18702                                    0.0.0.0:*               users:(("io.hm-rpc.1",pid=1635,fd=35))
    tcp             LISTEN           0                511                                     192.168.178.82:9292                                     0.0.0.0:*               users:(("io.hm-rpc.2",pid=1994,fd=35))
    tcp             LISTEN           0                100                                               [::]:1883                                        [::]:*               users:(("mosquitto",pid=989,fd=6))
    tcp             LISTEN           0                511                                                  *:8400                                           *:*               users:(("io.jarvis.0",pid=2141,fd=29))
    tcp             LISTEN           0                128                                               [::]:ssh                                         [::]:*               users:(("sshd",pid=963,fd=7))
    tcp             LISTEN           0                4096                                                 *:3000                                           *:*               users:(("grafana",pid=1300,fd=30))
    tcp             LISTEN           0                20                                               [::1]:smtp                                        [::]:*               users:(("exim4",pid=1249,fd=6))
    tcp             LISTEN           0                511                                                  *:8084                                           *:*               users:(("io.socketio.0",pid=2262,fd=34))
    tcp             LISTEN           0                4096                                                 *:8086                                           *:*               users:(("influxd",pid=980,fd=1546))
    tcp             LISTEN           0                511                                                  *:tproxy                                         *:*               users:(("io.admin.0",pid=1361,fd=39))
    tcp             LISTEN           0                511                                                  *:8082                                           *:*               users:(("io.web.0",pid=2283,fd=35))
    2026-05-20 00:27:30.676  - info: hm-rpc.2 (1994) xmlrpc <- listDevices ["Raspberrypi5:hm-rpc.2:48f6516f425fd0a7d69b10ad00768acd"]
    2026-05-20 00:27:30.703  - info: hm-rpc.2 (1994) xmlrpc -> 48 devices
    2026-05-20 00:27:30.750  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-2W | Battery=393W | Bedarf=393W | Überschuss=2W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:27:30.765  - info: hm-rpc.2 (1994) xmlrpc <- newDevices 48
    2026-05-20 00:27:30.789  - info: hm-rpc.2 (1994) new virtual-devices devices/channels after filter: 0
    2026-05-20 00:27:30.792  - info: hm-rpc.2 (1994) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:48f6516f425fd0a7d69b10ad00768acd","INT0000004"]
    2026-05-20 00:27:30.795  - info: hm-rpc.2 (1994) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:48f6516f425fd0a7d69b10ad00768acd","INT0000005"]
    2026-05-20 00:27:30.798  - info: hm-rpc.2 (1994) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:48f6516f425fd0a7d69b10ad00768acd","INT0000006"]
    2026-05-20 00:27:30.801  - info: hm-rpc.2 (1994) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:48f6516f425fd0a7d69b10ad00768acd","INT0000007"]
    2026-05-20 00:27:30.804  - info: hm-rpc.2 (1994) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:48f6516f425fd0a7d69b10ad00768acd","INT0000010"]
    2026-05-20 00:27:30.806  - info: hm-rpc.2 (1994) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:48f6516f425fd0a7d69b10ad00768acd","INT0000014"]
    2026-05-20 00:27:40.750  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-22W | Battery=393W | Bedarf=393W | Überschuss=22W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:27:44.001  - info: javascript.0 (1431) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:0W | PV_total:-1W | Batt:393W | Haus:381W | Tag:0.168kWh
    2026-05-20 00:27:48.026  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-20 00:27:50.750  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=0W | Battery=393W | Bedarf=393W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:28:00.751  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=0W | Battery=393W | Bedarf=393W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:28:08.210  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-20 00:28:10.751  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-17W | Battery=393W | Bedarf=393W | Überschuss=17W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:28:20.750  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=2W | Battery=393W | Bedarf=395W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:28:29.318  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-20 00:28:30.751  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=0W | Battery=366W | Bedarf=366W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:28:40.751  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=2W | Battery=366W | Bedarf=368W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
    2026-05-20 00:28:46.001  - info: javascript.0 (1431) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:4W | PV_total:-1W | Batt:393W | Haus:385W | Tag:0.175kWh
    2026-05-20 00:28:50.057  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-20 00:28:50.750  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-5W | Battery=366W | Bedarf=366W | Überschuss=5W | Ziel=0W | Status=Kein Bedarf
    ============= Mark until here for C&P =============
    iob diag has finished.
    • teletapiT teletapi
      ./iob_diag.sh
      Das war der Befehl:
      ```bash
      Script v.2026-05-19
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               5646 M used memory
               8984 M free memory
                224 M buffer memory
               1507 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      2.9G    /var/
      2.0G    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      nodejs:
        Version table:
      node:fs:2414
        errno: -13,
        code: 'EACCES',
        syscall: 'open',
      Node.js v24.15.0
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.8.25
      javascript:     9.2.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        18706
      States:         18825
      #841
      @teletapi
      Kann ich mir keinen Reim drauf machen.
      Der Code an der Stelle ist eigentlich trivial. Gib das mal Zeilenweise ein:
      cd /home/iobroker
      sudo -H -u "$(whoami)" npm i --silent is-my-node-vulnerable
      sudo -H -u "$(whoami)" npx is-my-node-vulnerable
      npm ls
      • teletapiT Online
        teletapiT Online
        teletapi
        #842
        pi@Raspberrypi5:~ $ cd /home/iobroker
        pi@Raspberrypi5:/home/iobroker $ sudo -H -u "$(whoami)" npm i --silent is-my-node-vulnerable
        pi@Raspberrypi5:/home/iobroker $ sudo -H -u "$(whoami)" npx is-my-node-vulnerable
        node:fs:2414
          errno: -13,
          code: 'EACCES',
          syscall: 'open',
        Node.js v24.15.0
          node:fs:2414
            errno: -13,
            code: 'EACCES',
            syscall: 'open',
          Node.js v24.15.0
          #843
          @teletapi
          Keine Ahnung was da bei dir krumm ist. Hat aber nichts mit dem Skript an sich zu tun.
          • teletapiT Online
            teletapiT Online
            teletapi
            #844
            das bisher genutzte iob diag gibt auch keinerlei Probleme aus
            ```bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
             00:45:11 up  1:14,  1 user,  load average: 0.58, 0.57, 0.62
            CPU threads: 4
            Current issues:
                           Local time: Wed 2026-05-20 00:45:11 CEST
                       Universal time: Tue 2026-05-19 22:45:11 UTC
                             RTC time: Tue 2026-05-19 22:45:11
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            SUDO_HOME=/home/pi
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:             17G        5.8G        6.7G         26M        4.6G         11G
            Swap:           209M          0B        209M
            Total:           17G        5.8G        6.9G
                     5576 M used memory
                     5570 M active memory
                     3676 M inactive memory
                     6397 M free memory
                      227 M buffer memory
                     4161 M swap cache
                      199 M total swap
                        0 M used swap
                      199 M free swap
            top - 00:45:11 up  1:14,  1 user,  load average: 0.58, 0.57, 0.62
            Tasks: 219 total,   1 running, 218 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  2.3 us,  2.3 sy,  0.0 ni, 95.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  16218.4 total,   6396.4 free,   5577.8 used,   4388.8 buff/cache
            MiB Swap:    200.0 total,    200.0 free,      0.0 used.  10640.5 avail Mem
            *** FILESYSTEM ***
            /var:
            2.9G    /var/
            1.9G    /var/lib
            5.0G    /opt/iobroker/backups/
            664M    /opt/iobroker/iobroker-data/
            30M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            Raspberrypi5        Raspberrypi5 (version: 7.1.2, hostname: Raspberrypi5  , alive, uptime: 4458)
            admin:          7.8.25
            javascript:     9.2.2
            Adapter State
            + instance is alive
            Objects and States
            Objects:        18706
            States:         18825
            Fetched 6922 B in 0s (37.9 kB/s)
            tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       14374      2232/io.simple-api.
            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       10226      1836/io.sonoff.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        8466       989/mosquitto
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6947       1249/exim4
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7004       1301/iobroker.js-co
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9604       1301/iobroker.js-co
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8361       963/sshd: /usr/sbin
            tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       9914       1617/io.hm-rpc.0
            tcp        0      0 192.168.178.82:18702    0.0.0.0:*               LISTEN      1001       9019       1635/io.hm-rpc.1
            tcp        0      0 192.168.178.82:9292     0.0.0.0:*               LISTEN      1001       12743      1994/io.hm-rpc.2
            tcp6       0      0 :::1883                 :::*                    LISTEN      106        8467       989/mosquitto
            tcp6       0      0 :::8400                 :::*                    LISTEN      1001       12914      2141/io.jarvis.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          8363       963/sshd: /usr/sbin
            tcp6       0      0 :::3000                 :::*                    LISTEN      107        7017       1300/grafana
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6948       1249/exim4
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       13979      2262/io.socketio.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        6957       980/influxd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9662       1361/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14044      2283/io.web.0
            udp        0      0 0.0.0.0:45342           0.0.0.0:*                           1001       14583      2165/io.matter.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14417      2165/io.matter.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13127      2165/io.matter.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6020       716/avahi-daemon: r
            udp        0      0 0.0.0.0:5541            0.0.0.0:*                           1001       13126      2165/io.matter.0
            udp        0      0 0.0.0.0:57417           0.0.0.0:*                           104        6022       716/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                1001       14418      2165/io.matter.0
            udp6       0      0 :::5353                 :::*                                1001       13130      2165/io.matter.0
            udp6       0      0 :::5353                 :::*                                104        6021       716/avahi-daemon: r
            udp6       0      0 :::5541                 :::*                                1001       13125      2165/io.matter.0
            udp6       0      0 :::57272                :::*                                104        6023       716/avahi-daemon: r
            udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          10438      869/NetworkManager
            udp6       0      0 fe80::b78f:a4e0:488:546 :::*                                0          8586       869/NetworkManager
            udp6       0      0 :::51306                :::*                                1001       14582      2165/io.matter.0
            2026-05-20 00:43:10.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=1W | Battery=314W | Bedarf=315W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:43:20.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=29W | Battery=288W | Bedarf=317W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:43:24.231  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-20 00:43:30.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=12W | Battery=314W | Bedarf=326W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:43:40.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=10W | Battery=314W | Bedarf=324W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:43:44.449  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-20 00:43:50.761  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=10W | Battery=314W | Bedarf=324W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:43:56.001  - info: javascript.0 (1431) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-2W | PV_total:-1W | Batt:288W | Haus:309W | Tag:0.257kWh
            2026-05-20 00:44:00.761  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=10W | Battery=314W | Bedarf=324W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:44:05.987  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-20 00:44:10.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-12W | Battery=314W | Bedarf=314W | Überschuss=12W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:44:20.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-12W | Battery=314W | Bedarf=314W | Überschuss=12W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:44:27.135  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-20 00:44:30.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=14W | Battery=314W | Bedarf=328W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:44:40.761  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=13W | Battery=314W | Bedarf=327W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:44:47.900  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-20 00:44:50.761  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-7W | Battery=314W | Bedarf=314W | Überschuss=7W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:44:58.000  - info: javascript.0 (1431) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-5W | PV_total:-1W | Batt:314W | Haus:324W | Tag:0.262kWh
            2026-05-20 00:45:00.761  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=10W | Battery=314W | Bedarf=324W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:45:08.400  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-20 00:45:10.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-11W | Battery=340W | Bedarf=340W | Überschuss=11W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:45:20.761  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-11W | Battery=340W | Bedarf=340W | Überschuss=11W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:45:28.771  - info: tr-064.0 (1865) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-20 00:45:30.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=11W | Battery=314W | Bedarf=325W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
            2026-05-20 00:45:40.760  - info: javascript.0 (1431) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=2W | Battery=314W | Bedarf=316W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
              ```bash
              Script v.2026-01-31
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              SUDO_HOME=/home/pi
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:           209M          0B        209M
                       5576 M used memory
                       6397 M free memory
                        227 M buffer memory
                       4161 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              *** FILESYSTEM ***
              /var:
              2.9G    /var/
              1.9G    /var/lib
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.8.25
              javascript:     9.2.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        18706
              States:         18825
              #845
              @teletapi
              Führ mal den
              iob fix
              aus.
              • teletapiT Online
                teletapiT Online
                teletapi
                #846
                Error bleibt der gleiche
                node:fs:2414
                  errno: -13,
                  code: 'EACCES',
                  syscall: 'open',
                Node.js v24.15.0
                  node:fs:2414
                    errno: -13,
                    code: 'EACCES',
                    syscall: 'open',
                  Node.js v24.15.0
                  #847
                  @teletapi
                  Zieh das Skript jetzt nochmal neu.
                  • teletapiT Online
                    teletapiT Online
                    teletapi
                    #848
                    Das sieht gut aus
                    ```bash
                    Script v.2026-05-19
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Unknown
                    Kernel          : aarch64
                    Userland        : 64bit
                     01:16:36 up 16 min,  1 user,  load average: 1.22, 0.82, 0.58
                    CPU threads     : 4
                    Current issues:
                                   Local time: Wed 2026-05-20 01:16:36 CEST
                               Universal time: Tue 2026-05-19 23:16:36 UTC
                                     RTC time: Tue 2026-05-19 23:16:36
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:             17G        5.2G         10G         26M        1.7G         11G
                    Swap:           209M          0B        209M
                    Total:           17G        5.2G         10G
                             4994 M used memory
                             4861 M active memory
                              986 M inactive memory
                             9730 M free memory
                              199 M buffer memory
                             1439 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    top - 01:16:36 up 16 min,  1 user,  load average: 1.22, 0.82, 0.58
                    Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  16218.4 total,   9727.4 free,   4996.9 used,   1638.5 buff/cache
                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.  11221.4 avail Mem
                    *** FILESYSTEM ***
                    /dev/nvme0n1p2 ext4      117G   17G   95G  16% /
                    tmpfs          tmpfs     8.0G  8.7M  8.0G   1% /tmp
                    [Wed May 20 00:59:57 2026] EXT4-fs (nvme0n1p2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
                    [Wed May 20 00:59:58 2026] EXT4-fs (nvme0n1p2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
                    /var:
                    2.9G    /var/
                    1.9G    /var/lib
                    643M    /opt/iobroker/iobroker-data/
                    31M     /opt/iobroker/iobroker-data/objects.jsonl
                    18M     /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    nodejs:
                      Version table:
                    No known Vulnerabilities detected!
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    Raspberrypi5        Raspberrypi5 (version: 7.1.2, hostname: Raspberrypi5  , alive, uptime: 993)
                    admin:          7.8.25
                    javascript:     9.2.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        18712
                    States:         18858
                    Fetched 6922 B in 0s (35.0 kB/s)
                    udp                     UNCONN                    0                         0        0.0.0.0:33196                                                    0.0.0.0:*                       users:(("avahi-daemon",pid=716,fd=14))
                    udp                     UNCONN                    0                         0        0.0.0.0:43688                                                    0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=42))
                    udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=39))
                    udp                     UNCONN                    0                         0        0.0.0.0:mdns                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=37))
                    udp                     UNCONN                    0                         0        0.0.0.0:5541                                                     0.0.0.0:*                       users:(("io.matter.0",pid=2209,fd=36))
                    udp                     UNCONN                    0                         0        *:40920                                                          *:*                       users:(("io.matter.0",pid=2209,fd=41))
                    udp                     UNCONN                    0                         0                                            [fe80::b78f:a4e0:4880:4be4]:dhcpv6-client                                                  *:*                       users:(("NetworkManager",pid=834,fd=38))
                    udp                     UNCONN                    0                         0                                            [fe80::f05b:9255:16fc:d8b2]:dhcpv6-client                                                  *:*                       users:(("NetworkManager",pid=834,fd=35))
                    udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("io.matter.0",pid=2209,fd=40))
                    udp                     UNCONN                    0                         0        *:mdns                                                           *:*                       users:(("io.matter.0",pid=2209,fd=38))
                    udp                     UNCONN                    0                         0        *:5541                                                           *:*                       users:(("io.matter.0",pid=2209,fd=35))
                    udp                     UNCONN                    0                         0        *:56246                                                          *:*                       users:(("avahi-daemon",pid=716,fd=15))
                    tcp                     LISTEN                    0                         511                                                       192.168.178.82:8087                                                     0.0.0.0:*                       users:(("io.simple-api.0",pid=2273,fd=35))
                    tcp                     LISTEN                    0                         128                                                              0.0.0.0:ssh                                                      0.0.0.0:*                       users:(("sshd",pid=965,fd=6))
                    tcp                     LISTEN                    0                         100                                                              0.0.0.0:1883                                                     0.0.0.0:*                       users:(("mosquitto",pid=991,fd=5))
                    tcp                     LISTEN                    0                         511                                                              0.0.0.0:1886                                                     0.0.0.0:*                       users:(("io.sonoff.0",pid=1892,fd=40))
                    tcp                     LISTEN                    0                         20                                                             127.0.0.1:smtp                                                     0.0.0.0:*                       users:(("exim4",pid=1250,fd=5))
                    tcp                     LISTEN                    0                         511                                                            127.0.0.1:9000                                                     0.0.0.0:*                       users:(("iobroker.js-con",pid=1300,fd=29))
                    tcp                     LISTEN                    0                         511                                                            127.0.0.1:9001                                                     0.0.0.0:*                       users:(("iobroker.js-con",pid=1300,fd=23))
                    tcp                     LISTEN                    0                         511                                                       192.168.178.82:9292                                                     0.0.0.0:*                       users:(("io.hm-rpc.2",pid=2054,fd=35))
                    tcp                     LISTEN                    0                         511                                                       192.168.178.82:18701                                                    0.0.0.0:*                       users:(("io.hm-rpc.0",pid=1660,fd=35))
                    tcp                     LISTEN                    0                         511                                                       192.168.178.82:18702                                                    0.0.0.0:*                       users:(("io.hm-rpc.1",pid=1677,fd=35))
                    tcp                     LISTEN                    0                         4096        *:3000                                                           *:*                       users:(("grafana",pid=1299,fd=18))
                    tcp                     LISTEN                    0                         128        [::]:ssh                                                         [::]:*                       users:(("sshd",pid=965,fd=7))
                    tcp                     LISTEN                    0                         511        *:8400                                                           *:*                       users:(("io.jarvis.0",pid=2184,fd=36))
                    tcp                     LISTEN                    0                         100        [::]:1883                                                        [::]:*                       users:(("mosquitto",pid=991,fd=6))
                    tcp                     LISTEN                    0                         20        [::1]:smtp                                                        [::]:*                       users:(("exim4",pid=1250,fd=6))
                    tcp                     LISTEN                    0                         511        *:tproxy                                                         *:*                       users:(("io.admin.0",pid=1357,fd=39))
                    tcp                     LISTEN                    0                         511        *:8082                                                           *:*                       users:(("io.web.0",pid=2327,fd=35))
                    tcp                     LISTEN                    0                         511        *:8084                                                           *:*                       users:(("io.socketio.0",pid=2305,fd=34))
                    tcp                     LISTEN                    0                         4096        *:8086                                                           *:*                       users:(("influxd",pid=979,fd=1547))
                    2026-05-20 01:15:48.873  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-4W | Battery=366W | Bedarf=366W | Überschuss=4W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:15:50.000  - info: javascript.0 (1435) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-4W | PV_total:-1W | Batt:366W | Haus:369W | Tag:0.418kWh
                    2026-05-20 01:15:54.612  - info: hm-rpc.2 (2054) xmlrpc <- listDevices ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c"]
                    2026-05-20 01:15:54.650  - info: hm-rpc.2 (2054) xmlrpc -> 48 devices
                    2026-05-20 01:15:54.713  - info: hm-rpc.2 (2054) xmlrpc <- newDevices 48
                    2026-05-20 01:15:54.753  - info: hm-rpc.2 (2054) new virtual-devices devices/channels after filter: 0
                    2026-05-20 01:15:54.756  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000004"]
                    2026-05-20 01:15:54.759  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000005"]
                    2026-05-20 01:15:54.763  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000006"]
                    2026-05-20 01:15:54.766  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000007"]
                    2026-05-20 01:15:54.769  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000010"]
                    2026-05-20 01:15:54.772  - info: hm-rpc.2 (2054) xmlrpc <- setReadyConfig ["Raspberrypi5:hm-rpc.2:44c75c7e8f1f92114ee5001718ae3c3c","INT0000014"]
                    2026-05-20 01:15:58.873  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-11W | Battery=366W | Bedarf=366W | Überschuss=11W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:16:06.755  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2026-05-20 01:16:08.874  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-7W | Battery=366W | Bedarf=366W | Überschuss=7W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:16:18.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=0W | Battery=366W | Bedarf=366W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:16:27.110  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2026-05-20 01:16:28.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=6W | Battery=366W | Bedarf=372W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:16:38.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=11W | Battery=340W | Bedarf=351W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:16:48.263  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2026-05-20 01:16:48.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-4W | Battery=366W | Bedarf=366W | Überschuss=4W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:16:50.000  - info: javascript.0 (1435) script.js.AlphaESS.PV6_Hauslast_neu_Monats_Gesamtsumme_tagesaktuell: DIAG: Netz:-7W | PV_total:-1W | Batt:366W | Haus:366W | Tag:0.424kWh
                    2026-05-20 01:16:58.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=-6W | Battery=366W | Bedarf=366W | Überschuss=6W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:17:08.875  - info: javascript.0 (1435) script.js.Marstek_Venus_E.Marstek_1: [MarstekRegelung] Grid=12W | Battery=339W | Bedarf=351W | Überschuss=0W | Ziel=0W | Status=Kein Bedarf
                    2026-05-20 01:17:09.154  - info: tr-064.0 (1916) forEachConfiguredDevice: in GetSpecificHostEntry 39(Stromzaehler-LG-E320-Wlan/08:F9:E0:A8:33:5F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                      Das sieht gut aus
                      ```bash
                      Script v.2026-05-19
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Unknown
                      Kernel          : aarch64
                      Userland        : 64bit
                      CPU threads     : 4
                      Current issues:
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           209M          0B        209M
                      Total:           17G        5.2G         10G
                               4994 M used memory
                               9730 M free memory
                                199 M buffer memory
                               1439 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.9G    /var/
                      1.9G    /var/lib
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.8.25
                      javascript:     9.2.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        18712
                      States:         18858
                      #849
                      @teletapi
                      Ich hab mit den Rechten noch was herumgespielt. Aber so ganz erklären kann ich mir das Verhalten auf deiner Kiste nicht.
                      teletapiT 1 Antwort Letzte Antwort
                        @teletapi
                        teletapiT Online
                        teletapiT Online
                        teletapi
                        #850
                        System läuft aber auch top und ich kann keinerlei Fehler sehen oder bemerken. Vielleicht fällt ja irgendwann noch was auf. herzlichen dank für die Hilfe dazu
                          @skvarel sagte:
                          Ubuntu 24.04.4 ist aber doch LTS, oder?
                          Ja, es ist zwar noch supportet, aber perspektivisch sollte das auf 26.04 'Resolute Raccoon' gehievt werden. Und genau das steht da. Wenn es EOL wäre würde das auch da stehen.
                          Hab jetzt noch mal was geändert. Magst du noch mal testen?
                          skvarelS Offline
                          skvarelS Offline
                          skvarel
                          #851
                          @Thomas-Braun sagte:
                          Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
                          *** LEBENSZYKLUS STATUS ***
                          Die Unterstützung für das Betriebssystem mit dem Codenamen 'noble' läuft aus. Es sollte in nächster Zeit auf die aktuelle Version 'resolute' mit Langzeitunterstützung gebracht werden.
                          #TeamInventwo
                          Unsere Adapter:
                          • BananaJoeB BananaJoe
                            @skvarel und damit warten wir mindestens bis zur Version 26.04.1 - wenn diese erschienen ist, wird dich dein 24.04.x auch darauf Hinweisen das nun ein Inplace-Upgrade möglich wäre.
                            Ob dann Inplace oder Neuinstallation dann der richtige Weg ist wäre eine andere Diskussion
                            skvarelS Offline
                            skvarelS Offline
                            skvarel
                            #852
                            @BananaJoe sagte:
                            Ich bin nicht gut im Erkennen von Ironie/Sarkasmus und schon gar nicht was Linux angeht ... ist das Warten ernst gemeint oder jetzt updaten?
                            #TeamInventwo
                            Unsere Adapter:
                            • skvarelS skvarel
                              @BananaJoe sagte:
                              #853
                              @skvarel sagte:
                              Upgrades aus einer Bestandsversion sind offiziell erst nach der Veröffentlichung des ersten Point releases vorgesehen. Wer das vorzeitig machen will muss das ausdrücklich dem Upgrade mitgeben.
                              sudo do-release-upgrade -d
                              ist das. Später geht es dann ohne -d.
                              Das Abwarten des ersten Point releases ist auch für Debian eine übliche Praxis. Dafür gibt es ja die einjährige Übergangsphase z.B.
                              • skvarelS skvarel
                                #854
                                @skvarel sagte:
                                Genau so soll es aussehen. Danke für's testen!
                                skvarelS 1 Antwort Letzte Antwort
                                  @skvarel sagte:
                                  skvarelS Offline
                                  skvarelS Offline
                                  skvarel
                                  #855
                                  @Thomas-Braun .. sehr gerne und vielen Dank für den Fix 👍
                                  Ich kann leider nicht mehr Voten
                                  #TeamInventwo
                                  Unsere Adapter:
                                  • M MCU
                                    @Thomas-Braun Gibt es die diag auch für Windows?
                                    S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    #856
                                    @Thomas-Braun
                                    Ist es nicht möglich mit KI ein Windows iob_diag bauen zu lassen?
                                    Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                    ioBroker Backup Analyzer
                                    • S Shadowhunter23
                                      @Thomas-Braun
                                      #857
                                      @Shadowhunter23 sagte:
                                      Da fragst du den richtigen...
                                      Ich hab von Windows keine Ahnung, will ich auch nicht.
                                      Und mit KIs und deren wiedersprüchlichen Ansinnen schlage ich mich schon genug herum.
                                      Und dann wird doch auch immer erzählt, Windows ist viel 'einfacher' als dieses dämliche 'Linuggs-Geraffel', kann auch meine Oma beklicken. Wozu dann ein solches Diag-Skript? ;-)
                                      • Thomas BraunT Online
                                        #858
                                        @skvarel @teletapi
                                        Könnten die fleißigen Tester nochmal checken?
                                        Ich hab gestern noch ein paar Dinge im Kampf mit zwei KIs umgestellt.
                                        Optisch ändert sich nix gravierendes, nur bitte mal schauen ob die Ausgaben noch bzw. wieder plausibel sind.
                                        Danke schön!
                                        Super wäre auch mal ein komplexeres ZigBee-Konstrukt mit mehreren Koordinatoren und/oder mehreren Anschlüssen (per TCP oder USB) zu sehen. Aber die Konstellation ist wohl nicht gar so häufig in freier Wildbahn anzutreffen.
                                        • skvarelS Offline
                                          skvarelS Offline
                                          skvarel
                                          schrieb am zuletzt editiert von skvarel
                                          #859
                                          ./iob_diag.sh
                                          ```bash
                                          Script v.2026-05-20
                                          *** BASE SYSTEM ***
                                          Operating System: Ubuntu 24.04.4 LTS
                                           Static hostname: ioBroker
                                                 Icon name: computer-desktop
                                                   Chassis: desktop 🖥️
                                                    Kernel: Linux 6.8.0-117-generic
                                              Architecture: x86-64
                                           Hardware Vendor: Dell Inc.
                                            Hardware Model: OptiPlex 3050
                                          Firmware Version: 1.6.5
                                             Firmware Date: Sat 2017-09-09
                                              Firmware Age: 8y 8month 1w 3d
                                          OS is similar to: debian
                                          model name      : Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
                                          Docker          : false
                                          Unknown
                                          Kernel          : x86_64
                                          Userland        : 64bit
                                          System was installed 243 days ago (on 2025-09-19).
                                           11:17:00 up 3 days,  4:15,  1 user,  load average: 0.54, 0.66, 0.76
                                          CPU threads     : 4
                                                         Local time: Thu 2026-05-21 11:17:00 CEST
                                                     Universal time: Thu 2026-05-21 09:17:00 UTC
                                                           RTC time: Thu 2026-05-21 09:17:00
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          HOME=/home/pi
                                          GROUPS=pi adm cdrom sudo dip plugdev lxd iobroker
                                          iobroker[sudo] password for pi:
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev redis
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Mem:             16G        9.7G        2.9G        5.0M        4.5G        7.0G
                                          Swap:           4.3G          0B        4.3G
                                          Total:           20G        9.7G        7.2G
                                          Active iob-Instances:   53
                                                  15877 M total memory
                                                   9220 M used memory
                                                   9344 M active memory
                                                   2736 M inactive memory
                                                   2735 M free memory
                                                    800 M buffer memory
                                                   3461 M swap cache
                                                   4095 M total swap
                                                      0 M used swap
                                                   4095 M free swap
                                          top - 11:17:11 up 3 days,  4:15,  1 user,  load average: 0.68, 0.68, 0.76
                                          Tasks: 233 total,   1 running, 232 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  9.8 us,  5.9 sy,  0.0 ni, 82.4 id,  0.0 wa,  0.0 hi,  2.0 si,  0.0 st
                                          MiB Mem :  15877.7 total,   2734.3 free,   9222.2 used,   4262.3 buff/cache
                                          MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6655.5 avail Mem
                                          *** FILESYSTEM ***
                                          Filesystem                        Type   Size  Used Avail Use% Mounted on
                                          tmpfs                             tmpfs  1.6G  4.6M  1.6G   1% /run
                                          /dev/mapper/ubuntu--vg-ubuntu--lv ext4   467G   20G  428G   5% /
                                          tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
                                          tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                                          /dev/nvme0n1p2                    ext4   2.0G  200M  1.6G  11% /boot
                                          tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
                                          [Mon May 18 07:01:29 2026] Btrfs loaded, zoned=yes, fsverity=yes
                                          [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): mounted filesystem a547182b-43b5-440e-b6fe-09323774b05c ro with ordered data mode. Quota mode: none.
                                          [Mon May 18 07:01:29 2026] EXT4-fs (dm-0): re-mounted a547182b-43b5-440e-b6fe-09323774b05c r/w.
                                          [Mon May 18 07:01:30 2026] EXT4-fs (nvme0n1p2): mounted filesystem 7a71a3d0-fb5e-4ed0-8d6d-dc24002c0eef r/w with ordered data mode. Quota mode: none.
                                          /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
                                          `-/boot /dev/nvme0n1p2                    ext4   rw,relatime
                                          /var:
                                          5.3G    /var/
                                          4.4G    /var/log
                                          4.2G    /var/log/journal/b521ee0ca8cb46db87113e33c1d11d82
                                          760M    /var/lib
                                          Archived and active journals take up 4.1G in the file system.
                                          190M    /opt/iobroker/backups/
                                          502M    /opt/iobroker/iobroker-data/
                                          329M    /opt/iobroker/iobroker-data/files
                                          132M    /opt/iobroker/iobroker-data/backup-objects
                                          56M     /opt/iobroker/iobroker-data/files/vis-2
                                          47M     /opt/iobroker/iobroker-data/files/admin.admin
                                          38M     /opt/iobroker/iobroker-data/objects.jsonl
                                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                          9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                                          9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          No nvbackup.json found.
                                          /usr/bin/nodejs         v22.22.2
                                          /usr/bin/node           v22.22.2
                                          /usr/bin/npm            10.9.7
                                          /usr/bin/npx            10.9.7
                                          nodejs:
                                            Installed: 22.22.2-1nodesource1
                                            Candidate: 22.22.2-1nodesource1
                                            Version table:
                                           *** 22.22.2-1nodesource1 1001
                                               22.22.1-1nodesource1 1001
                                               22.22.0-1nodesource1 1001
                                               22.21.0-1nodesource1 1001
                                               22.20.0-1nodesource1 1001
                                               22.19.0-1nodesource1 1001
                                               22.18.0-1nodesource1 1001
                                               22.17.1-1nodesource1 1001
                                               22.17.0-1nodesource1 1001
                                               22.16.0-1nodesource1 1001
                                               22.15.1-1nodesource1 1001
                                               22.15.0-1nodesource1 1001
                                               22.14.0-1nodesource1 1001
                                               22.13.1-1nodesource1 1001
                                               22.13.0-1nodesource1 1001
                                               22.12.0-1nodesource1 1001
                                               22.11.0-1nodesource1 1001
                                               22.10.0-1nodesource1 1001
                                               22.9.0-1nodesource1 1001
                                               22.8.0-1nodesource1 1001
                                               22.7.0-1nodesource1 1001
                                               22.6.0-1nodesource1 1001
                                               22.5.1-1nodesource1 1001
                                               22.5.0-1nodesource1 1001
                                               22.4.1-1nodesource1 1001
                                               22.4.0-1nodesource1 1001
                                               22.3.0-1nodesource1 1001
                                               22.2.0-1nodesource1 1001
                                               22.1.0-1nodesource1 1001
                                               22.0.0-1nodesource1 1001
                                               18.19.1+dfsg-6ubuntu5 500
                                                  500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: redis
                                          Hosts:
                                          ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152296)
                                          admin:          7.8.25
                                          javascript:     9.2.2
                                          nodejs modules from github:     3
                                          +-- iobroker.energiefluss-erweitert@0.8.2 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#89dbb71bf0fc70044249fd6453c25194130d9971)
                                          +-- iobroker.foxesscloud@0.4.0 (git+ssh://git@github.com/inventwo/ioBroker.foxesscloud.git#9c22623f35cd02277a4a3dcc145ada655b4e9080)
                                          +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                                          + system.adapter.autodarts.0              : autodarts             : ioBroker                                 -  enabled, port: 3180
                                          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                          + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
                                            system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                                          + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
                                          + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                                          + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                                          + system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
                                          + system.adapter.discovergy.0             : discovergy            : ioBroker                                 -  enabled
                                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                                          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
                                          + system.adapter.enpal.0                  : enpal                 : ioBroker                                 -  enabled
                                            system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                                            system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                                            system.adapter.foxesscloud.0            : foxesscloud           : ioBroker                                 - disabled
                                          + system.adapter.foxesscloud.1            : foxesscloud           : ioBroker                                 -  enabled
                                          + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
                                          + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
                                            system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                                            system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                                            system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
                                            system.adapter.ical.4                   : ical                  : ioBroker                                 -  enabled
                                          + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                          + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                          + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
                                          + system.adapter.javascript.2             : javascript            : ioBroker                                 -  enabled
                                          + system.adapter.javascript.3             : javascript            : ioBroker                                 -  enabled
                                          + system.adapter.javascript.5             : javascript            : ioBroker                                 -  enabled
                                          + system.adapter.life360ng.0              : life360ng             : ioBroker                                 -  enabled
                                          + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                                          + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                                          + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ioBroker                                 - disabled, port: 16021
                                          + system.adapter.operating-hours.0        : operating-hours       : ioBroker                                 -  enabled
                                          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                                          + system.adapter.reolink.5                : reolink               : ioBroker                                 -  enabled
                                          + system.adapter.reolink.6                : reolink               : ioBroker                                 -  enabled
                                          + system.adapter.reolink.7                : reolink               : ioBroker                                 -  enabled
                                          + system.adapter.reolink.8                : reolink               : ioBroker                                 -  enabled
                                            system.adapter.reolink.9                : reolink               : ioBroker                                 - disabled
                                            system.adapter.seq.0                    : seq                   : ioBroker                                 - disabled, port: 443
                                          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            system.adapter.snmp.0                   : snmp                  : ioBroker                                 - disabled
                                          + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                                            system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
                                          + system.adapter.sureflap.0               : sureflap              : ioBroker                                 -  enabled
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                                          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.tidy.0                   : tidy                  : ioBroker                                 -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                                            system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
                                          + system.adapter.trashschedule.1          : trashschedule         : ioBroker                                 -  enabled
                                          + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                                            system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
                                            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
                                          + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                                            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                                          + system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 -  enabled
                                          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 -  enabled, port: 5000
                                          + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                                          + system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
                                          + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
                                          + instance is alive
                                          │ 0       │ 'Beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                          │ 1       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                          Active repo(s): Beta
                                          │ 2       │ 'system.adapter.autodarts'              │ 'autodarts'              │ '1.0.8'   │ 'none'         │
                                          │ 3       │ 'system.adapter.backitup'               │ 'backitup'               │ '3.3.17'  │ 'none'         │
                                          │ 4       │ 'system.adapter.bambulab'               │ 'bambulab'               │ '0.4.3'   │ 'none'         │
                                          │ 5       │ 'system.adapter.birthdays'              │ 'birthdays'              │ '6.0.1'   │ 'none'         │
                                          │ 6       │ 'system.adapter.brightsky'              │ 'brightsky'              │ '1.1.0'   │ 'none'         │
                                          │ 7       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'   │ 'none'         │
                                          │ 8       │ 'system.adapter.device-watcher'         │ 'device-watcher'         │ '2.15.15' │ 'none'         │
                                          │ 9       │ 'system.adapter.devices'                │ 'devices'                │ '2.1.1'   │ 'none'         │
                                          │ 10      │ 'system.adapter.discovergy'             │ 'discovergy'             │ '0.7.0'   │ 'none'         │
                                          │ 11      │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.2'   │ 'none'         │
                                          │ 12      │ 'system.adapter.enpal'                  │ 'enpal'                  │ '0.2.0'   │ 'none'         │
                                          │ 13      │ 'system.adapter.fb-checkpresence'       │ 'fb-checkpresence'       │ '1.4.2'   │ 'none'         │
                                          │ 14      │ 'system.adapter.feiertage'              │ 'feiertage'              │ '1.4.0'   │ 'none'         │
                                          │ 15      │ 'system.adapter.foxesscloud'            │ 'foxesscloud'            │ '0.4.0'   │ 'none'         │
                                          │ 16      │ 'system.adapter.harmony'                │ 'harmony'                │ '2.1.0'   │ 'none'         │
                                          │ 17      │ 'system.adapter.hmip'                   │ 'hmip'                   │ '1.27.0'  │ 'none'         │
                                          │ 18      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.20.1'  │ 'none'         │
                                          │ 19      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '4.0.2'   │ 'none'         │
                                          │ 21      │ 'system.adapter.life360ng'              │ 'life360ng'              │ '1.9.1'   │ 'none'         │
                                          │ 22      │ 'system.adapter.linux-control'          │ 'linux-control'          │ '1.1.6'   │ 'none'         │
                                          │ 23      │ 'system.adapter.matter'                 │ 'matter'                 │ '1.0.0'   │ 'none'         │
                                          │ 24      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'   │ 'none'         │
                                          │ 25      │ 'system.adapter.nanoleaf-lightpanels'   │ 'nanoleaf-lightpanels'   │ '1.6.0'   │ 'none'         │
                                          │ 26      │ 'system.adapter.operating-hours'        │ 'operating-hours'        │ '1.5.1'   │ 'none'         │
                                          │ 27      │ 'system.adapter.ping'                   │ 'ping'                   │ '2.2.4'   │ 'none'         │
                                          │ 28      │ 'system.adapter.reolink'                │ 'reolink'                │ '1.4.2'   │ 'none'         │
                                          │ 29      │ 'system.adapter.seq'                    │ 'seq'                    │ '1.0.2'   │ 'none'         │
                                          │ 30      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '10.6.1'  │ 'none'         │
                                          │ 31      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'   │ 'none'         │
                                          │ 32      │ 'system.adapter.snmp'                   │ 'snmp'                   │ '3.4.0'   │ 'none'         │
                                          │ 33      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'   │ 'none'         │
                                          │ 34      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14'  │ 'none'         │
                                          │ 35      │ 'system.adapter.spotify-premium'        │ 'spotify-premium'        │ '2.0.3'   │ 'none'         │
                                          │ 36      │ 'system.adapter.sureflap'               │ 'sureflap'               │ '3.4.2'   │ 'none'         │
                                          │ 37      │ 'system.adapter.tankerkoenig'           │ 'tankerkoenig'           │ '3.4.0'   │ 'none'         │
                                          │ 38      │ 'system.adapter.telegram'               │ 'telegram'               │ '4.1.0'   │ 'none'         │
                                          │ 39      │ 'system.adapter.tidy'                   │ 'tidy'                   │ '0.1.1'   │ 'none'         │
                                          │ 40      │ 'system.adapter.tr-064'                 │ 'tr-064'                 │ '4.3.0'   │ 'none'         │
                                          │ 41      │ 'system.adapter.trashschedule'          │ 'trashschedule'          │ '5.3.0'   │ 'none'         │
                                          │ 42      │ 'system.adapter.tuya'                   │ 'tuya'                   │ '3.17.0'  │ 'none'         │
                                          │ 43      │ 'system.adapter.vis-2'                  │ 'vis-2'                  │ '2.13.19' │ 'none'         │
                                          │ 44      │ 'system.adapter.vis-2-widgets-icontwo'  │ 'vis-2-widgets-icontwo'  │ '1.40.0'  │ 'none'         │
                                          │ 45      │ 'system.adapter.vis-2-widgets-inventwo' │ 'vis-2-widgets-inventwo' │ '1.0.0'   │ 'none'         │
                                          │ 46      │ 'system.adapter.vis-icontwo'            │ 'vis-icontwo'            │ '2.11.3'  │ 'none'         │
                                          │ 47      │ 'system.adapter.wallpanel'              │ 'wallpanel'              │ '0.3.11'  │ 'none'         │
                                          │ 48      │ 'system.adapter.web'                    │ 'web'                    │ '8.1.0'   │ 'none'         │
                                          │ 49      │ 'system.adapter.wiobrowser'             │ 'wiobrowser'             │ '2.0.2'   │ 'none'         │
                                          │ 50      │ 'system.adapter.wled'                   │ 'wled'                   │ '0.9.2'   │ 'none'         │
                                          │ 51      │ 'system.adapter.worx'                   │ 'worx'                   │ '3.3.0'   │ 'none'         │
                                          │ 52      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'   │ 'none'         │
                                          │ 53      │ 'system.adapter.zigbee2mqtt'            │ 'zigbee2mqtt'            │ '3.2.1'   │ 'none'         │
                                          Used repository: Beta
                                          Adapter    "autodarts"    : 1.0.8    , installed 1.0.8
                                          Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
                                          Adapter    "birthdays"    : 6.0.1    , installed 6.0.1
                                          Adapter    "brightsky"    : 1.1.0    , installed 1.1.0
                                          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                          Adapter    "device-watcher": 2.15.15 , installed 2.15.15
                                          Adapter    "devices"      : 2.1.1    , installed 2.1.1
                                          Adapter    "discovergy"   : 0.7.0    , installed 0.7.0
                                          Adapter    "enpal"        : 0.2.0    , installed 0.2.0
                                          Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                                          Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
                                          Adapter    "foxesscloud"  : 0.4.0    , installed 0.4.0
                                          Adapter    "harmony"      : 2.1.0    , installed 2.1.0
                                          Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                                          Adapter    "life360ng"    : 1.9.1    , installed 1.9.1
                                          Adapter    "linux-control": 1.1.5    , installed 1.1.6
                                          Adapter    "nanoleaf-lightpanels": 1.6.0, installed 1.6.0
                                          Adapter    "operating-hours": 1.5.1  , installed 1.5.1
                                          Adapter    "seq"          : 1.0.2    , installed 1.0.2
                                          Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                                          Adapter    "snmp"         : 3.4.0    , installed 3.4.0
                                          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                          Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
                                          Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
                                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                          Adapter    "trashschedule": 5.3.0    , installed 5.3.0
                                          Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                                          Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
                                          Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
                                          Adapter    "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
                                          Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                                          Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                                          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                          Adapter    "worx"         : 3.3.0    , installed 3.3.0
                                          Adapter    "zigbee2mqtt"  : 3.2.1    , installed 3.2.1
                                          Objects and States
                                          Objects:        22292
                                          States:         22954
                                          Hit:1 https://apt.grafana.com stable InRelease
                                          Get:2 https://repos.influxdata.com/debian stable InRelease [6922 B]
                                          Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
                                          Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
                                          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                          Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                                          Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                                          Hit:8 https://packages.redis.io/deb noble InRelease
                                          Fetched 6922 B in 1s (7313 B/s)
                                          Pending systemupdates: 2
                                          udp       UNCONN     0          0                                         0.0.0.0:61991                      0.0.0.0:*        users:(("io.harmony.0",pid=612834,fd=30))
                                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=42))
                                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=40))
                                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.wled.0",pid=614951,fd=22))
                                          udp       UNCONN     0          0                                         0.0.0.0:mdns                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=38))
                                          udp       UNCONN     0          0                                         0.0.0.0:5540                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=46))
                                          udp       UNCONN     0          0                                         0.0.0.0:5541                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=37))
                                          udp       UNCONN     0          0                                         0.0.0.0:5542                       0.0.0.0:*        users:(("io.matter.0",pid=614373,fd=47))
                                          udp       UNCONN     0          0                                         0.0.0.0:6666                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=53))
                                          udp       UNCONN     0          0                                         0.0.0.0:6667                       0.0.0.0:*        users:(("io.tuya.0",pid=614059,fd=54))
                                          udp       UNCONN     0          0                                      127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=16))
                                          udp       UNCONN     0          0                                   127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=14))
                                          udp       UNCONN     0          0                          192.168.130.130%enp2s0:bootpc                     0.0.0.0:*        users:(("systemd-network",pid=512,fd=24))
                                          udp       UNCONN     0          0                                         0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=5),("systemd",pid=1,fd=270))
                                          udp       UNCONN     0          0                                  172.18.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=25))
                                          udp       UNCONN     0          0                                      172.18.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=24))
                                          udp       UNCONN     0          0                                  172.17.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=21))
                                          udp       UNCONN     0          0                                      172.17.0.1:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=20))
                                          udp       UNCONN     0          0                                 192.168.255.255:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=16))
                                          udp       UNCONN     0          0                                 192.168.130.130:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=15))
                                          udp       UNCONN     0          0                                         0.0.0.0:netbios-ns                 0.0.0.0:*        users:(("nmbd",pid=991,fd=13))
                                          udp       UNCONN     0          0                                  172.18.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=27))
                                          udp       UNCONN     0          0                                      172.18.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=26))
                                          udp       UNCONN     0          0                                  172.17.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=23))
                                          udp       UNCONN     0          0                                      172.17.0.1:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=22))
                                          udp       UNCONN     0          0                                 192.168.255.255:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=18))
                                          udp       UNCONN     0          0                                 192.168.130.130:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=17))
                                          udp       UNCONN     0          0                                         0.0.0.0:netbios-dgm                0.0.0.0:*        users:(("nmbd",pid=991,fd=14))
                                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=44))
                                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=43))
                                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=41))
                                          udp       UNCONN     0          0                                            [::]:mdns                          [::]:*        users:(("io.matter.0",pid=614373,fd=39))
                                          udp       UNCONN     0          0                                            [::]:5540                          [::]:*        users:(("io.matter.0",pid=614373,fd=45))
                                          udp       UNCONN     0          0                                            [::]:5541                          [::]:*        users:(("io.matter.0",pid=614373,fd=36))
                                          udp       UNCONN     0          0                                            [::]:5542                          [::]:*        users:(("io.matter.0",pid=614373,fd=35))
                                          udp       UNCONN     0          0                                            [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=7),("systemd",pid=1,fd=272))
                                          udp       UNCONN     0          0              [fe80::da9e:f3ff:fe78:3132]%enp2s0:dhcpv6-client                 [::]:*        users:(("systemd-network",pid=512,fd=22))
                                          tcp       LISTEN     0          50                                        0.0.0.0:netbios-ssn                0.0.0.0:*        users:(("smbd",pid=1007,fd=31))
                                          tcp       LISTEN     0          4096                                      0.0.0.0:ssh                        0.0.0.0:*        users:(("sshd",pid=2422,fd=3),("systemd",pid=1,fd=101))
                                          tcp       LISTEN     0          4096                                      0.0.0.0:sunrpc                     0.0.0.0:*        users:(("rpcbind",pid=647,fd=4),("systemd",pid=1,fd=269))
                                          tcp       LISTEN     0          4096                                   127.0.0.54:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=17))
                                          tcp       LISTEN     0          4096                                      0.0.0.0:http                       0.0.0.0:*        users:(("docker-proxy",pid=1323,fd=7))
                                          tcp       LISTEN     0          50                                        0.0.0.0:microsoft-ds               0.0.0.0:*        users:(("smbd",pid=1007,fd=30))
                                          tcp       LISTEN     0          511                                       0.0.0.0:1885                       0.0.0.0:*        users:(("io.mqtt.0",pid=613007,fd=34))
                                          tcp       LISTEN     0          511                                       0.0.0.0:1883                       0.0.0.0:*        users:(("io.sonoff.0",pid=613163,fd=40))
                                          tcp       LISTEN     0          511                                       0.0.0.0:1882                       0.0.0.0:*        users:(("io.shelly.0",pid=614225,fd=36))
                                          tcp       LISTEN     0          511                                     127.0.0.1:9001                       0.0.0.0:*        users:(("iobroker.js-con",pid=612180,fd=23))
                                          tcp       LISTEN     0          4096                                    127.0.0.1:34169                      0.0.0.0:*        users:(("containerd",pid=764,fd=15))
                                          tcp       LISTEN     0          511                                     127.0.0.1:redis                      0.0.0.0:*        users:(("redis-server",pid=720,fd=20))
                                          tcp       LISTEN     0          4096                                127.0.0.53%lo:domain                     0.0.0.0:*        users:(("systemd-resolve",pid=696,fd=15))
                                          tcp       LISTEN     0          50                                           [::]:netbios-ssn                   [::]:*        users:(("smbd",pid=1007,fd=29))
                                          tcp       LISTEN     0          4096                                         [::]:ssh                           [::]:*        users:(("sshd",pid=2422,fd=4),("systemd",pid=1,fd=102))
                                          tcp       LISTEN     0          4096                                         [::]:sunrpc                        [::]:*        users:(("rpcbind",pid=647,fd=6),("systemd",pid=1,fd=271))
                                          tcp       LISTEN     0          4096                                         [::]:http                          [::]:*        users:(("docker-proxy",pid=1330,fd=7))
                                          tcp       LISTEN     0          50                                           [::]:microsoft-ds                  [::]:*        users:(("smbd",pid=1007,fd=28))
                                          tcp       LISTEN     0          4096                                            *:3000                             *:*        users:(("grafana",pid=1463,fd=26))
                                          tcp       LISTEN     0          511                                             *:61991                            *:*        users:(("io.harmony.0",pid=612834,fd=29))
                                          tcp       LISTEN     0          511                                         [::1]:redis                         [::]:*        users:(("redis-server",pid=720,fd=21))
                                          tcp       LISTEN     0          511                                             *:8087                             *:*        users:(("io.simple-api.0",pid=614626,fd=35))
                                          tcp       LISTEN     0          4096                                            *:8086                             *:*        users:(("influxd",pid=946,fd=358))
                                          tcp       LISTEN     0          511                                             *:8084                             *:*        users:(("io.ws.0",pid=614776,fd=34))
                                          tcp       LISTEN     0          511                                             *:8082                             *:*        users:(("io.web.0",pid=612361,fd=35))
                                          tcp       LISTEN     0          511                                             *:tproxy                           *:*        users:(("io.admin.0",pid=612200,fd=39))
                                          2026-05-21 11:00:07.069  - info: ical.1 (1343691) processing URL: xxx
                                          2026-05-21 11:00:08.171  - info: host.ioBroker instance system.adapter.ical.3 in version "1.20.1" started with pid 1343725
                                          2026-05-21 11:00:08.497  - info: ical.0 (1343653) Terminated (NO_ERROR): Without reason
                                          2026-05-21 11:00:09.021  - info: host.ioBroker instance system.adapter.ical.0 having pid 1343653 terminated with code 0 (NO_ERROR)
                                          2026-05-21 11:00:10.036  - info: ical.3 (1343725) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                                          2026-05-21 11:00:10.837  - info: ical.3 (1343725) processing URL: Jannis https://calendar.google.com/calendar/ical/0815%40group.calendar.google.com/private-0815/basic.ics
                                          2026-05-21 11:00:12.326  - info: ical.1 (1343691) Terminated (NO_ERROR): Without reason
                                          2026-05-21 11:00:12.852  - info: host.ioBroker instance system.adapter.ical.1 having pid 1343691 terminated with code 0 (NO_ERROR)
                                          2026-05-21 11:00:16.030  - info: ical.3 (1343725) Terminated (NO_ERROR): Without reason
                                          2026-05-21 11:00:16.592  - info: host.ioBroker instance system.adapter.ical.3 having pid 1343725 terminated with code 0 (NO_ERROR)
                                          2026-05-21 11:00:31.696  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
                                          2026-05-21 11:00:57.303  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Home → in der Ladestation
                                          2026-05-21 11:04:57.953  - info: javascript.3 (612306) script.js.Innenhof_&_Garten.Roberta.Status_RAW: Rasenmäher-Status geändert: Mowing → mäht
                                          2026-05-21 11:10:13.946  - info: alexa2.0 (869734) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
                                          2026-05-21 11:10:15.455  - info: alexa2.0 (869734) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                          2026-05-21 11:15:00.094  - info: host.ioBroker instance system.adapter.ical.1 in version "1.20.1" started with pid 1347962
                                          2026-05-21 11:15:01.965  - info: ical.1 (1347962) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                                          2026-05-21 11:15:02.781  - info: ical.1 (1347962) processing URL: xxx
                                          2026-05-21 11:15:04.113  - info: host.ioBroker instance system.adapter.ical.0 in version "1.20.1" started with pid 1348018
                                          2026-05-21 11:15:05.832  - info: ical.0 (1348018) starting. Version 1.20.1 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.1.2
                                          2026-05-21 11:15:06.610  - info: ical.0 (1348018) processing URL: xxx
                                          2026-05-21 11:15:08.103  - info: ical.1 (1347962) Terminated (NO_ERROR): Without reason
                                          2026-05-21 11:15:08.658  - info: host.ioBroker instance system.adapter.ical.1 having pid 1347962 terminated with code 0 (NO_ERROR)
                                          2026-05-21 11:15:11.941  - info: ical.0 (1348018) Terminated (NO_ERROR): Without reason
                                          2026-05-21 11:15:12.502  - info: host.ioBroker instance system.adapter.ical.0 having pid 1348018 terminated with code 0 (NO_ERROR)
                                          ./iob_diag.sh --de
                                          ```bash
                                          Script v.2026-05-20
                                          *** GRUNDSYSTEM ***
                                                   Chassis: desktop 🖥️
                                          Docker          : false
                                          Virtualization  : none
                                          Unknown
                                          Kernel          : x86_64
                                          Userland        : 64bit
                                          Das System wurde vor 243 Tagen installiert (am 19.09.2025).
                                          Systemuptime and Load:
                                           11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
                                          CPU threads     : 4
                                          *** ZEIT UND ZEITZONEN ***
                                                         Local time: Thu 2026-05-21 11:21:33 CEST
                                                     Universal time: Thu 2026-05-21 09:21:33 UTC
                                                           RTC time: Thu 2026-05-21 09:21:33
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** User und Gruppen ***
                                          User der 'iob diag' aufgerufen hat:
                                          pi
                                          HOME=/home/pi
                                          User der den 'js-controller' ausführt:
                                          iobrokerHOME=/home/iobroker
                                          *** DISPLAY-SERVER SETUP ***
                                          Display-Server:         Unknown
                                          Display-Manager:        Not found
                                          Desktop:
                                          Session:                tty
                                          Boot Target:            multi-user.target
                                          *** MEMORY ***
                                          Swap:           4.3G          0B        4.3G
                                                   9221 M used memory
                                                   9345 M active memory
                                                   2737 M inactive memory
                                                   2733 M free memory
                                                    801 M buffer memory
                                                   3462 M swap cache
                                                   4095 M total swap
                                                      0 M used swap
                                                   4095 M free swap
                                          top - 11:21:33 up 3 days,  4:20,  1 user,  load average: 1.44, 1.15, 0.94
                                          Tasks: 235 total,   2 running, 233 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 18.6 us,  9.3 sy,  0.0 ni, 72.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :  15877.7 total,   2737.4 free,   9218.2 used,   4263.2 buff/cache
                                          MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6659.5 avail Mem
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** DMESG CRITICAL ERRORS ***
                                          Es wurden keine kritischen Fehler gefunden
                                          *** FILESYSTEM ***
                                          Messages concerning filesystems in dmesg:
                                          Show mounted filesystems:
                                          TARGET  SOURCE                            FSTYPE OPTIONS
                                          /var:
                                          5.3G    /var/
                                          4.4G    /var/log
                                          760M    /var/lib
                                          /opt/iobroker/backups:
                                          /opt/iobroker/iobroker-data:
                                          19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
                                          USB-Devices by-id:
                                          USB-Sticks - Vermeide direkte Links zu /dev/tty* in deinen Adapter-Einstellungen,
                                          bevorzuge immer die Links 'by-id':
                                          Keine Geräte gefunden 'by-id'
                                          *** NodeJS-Installation ***
                                          /usr/bin/npm            10.9.7
                                          /usr/bin/npx            10.9.7
                                          ✓ Node.js ist korrekt installiert
                                          nodejs:
                                            Version table:
                                          No problems detected
                                          Errors in npm tree: 0
                                          Keine bekannten Sicherheitslücken in der Node.js-Version erkannt!
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: redis
                                          Hosts:
                                          ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 152566)
                                          Core adapters versions
                                          admin:          7.8.25
                                          javascript:     9.2.2
                                          Adapter State
                                          + instance is alive
                                          ioBroker-Repositories
                                          Upgrade policy: none
                                          Installed ioBroker-Adapters
                                          │ (index) │ id                                      │ name                     │ version   │ upgrade policy │
                                          │ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '7.8.25'  │ 'none'         │
                                          │ 1       │ 'system.adapter.alexa2'                 │ 'alexa2'                 │ '3.27.4'  │ 'none'         │
                                          │ 20      │ 'system.adapter.javascript'             │ 'javascript'             │ '9.2.2'   │ 'none'         │
                                          ioBroker-Adapter Versions and update status
                                          Adapter    "admin"        : 7.8.25   , installed 7.8.25
                                          Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                                          Adapter    "backitup"     : 3.3.17   , installed 3.3.17
                                          Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
                                          Adapter    "ical"         : 1.20.1   , installed 1.20.1
                                          Adapter    "javascript"   : 9.2.2    , installed 9.2.2
                                          Controller "js-controller": 7.1.2    , installed 7.1.2
                                          Adapter    "matter"       : 1.0.0    , installed 1.0.0
                                          Adapter    "ping"         : 2.2.4    , installed 2.2.4
                                          Adapter    "reolink"      : 1.4.2    , installed 1.4.2
                                          Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                                          Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                                          Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                                          Adapter    "web"          : 8.1.0    , installed 8.1.0
                                          Adapter    "wled"         : 0.9.2    , installed 0.9.2
                                          Adapter    "ws"           : 4.1.0    , installed 4.1.0
                                          Objects and States
                                          Objects:        22292
                                          States:         22954
                                          Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
                                          Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
                                          Get:4 https://repos.influxdata.com/debian stable InRelease [6922 B]
                                          Fetched 6922 B in 1s (7184 B/s)
                                          Reading package lists... Done
                                          Offene Systemupdates: 2
                                          *** Listening Ports ***
                                          Netid     State      Recv-Q     Send-Q                              Local Address:Port                  Peer Address:Port    Process
                                          EDIT:
                                          Mit internem Zigbee kann ich nicht dienen. Ich nutze Zigbee2mqqt auf einer separaten Hardware
                                          #TeamInventwo
                                          Unsere Adapter:
