  3. Off Topic
  4. Proxmox
  5. an alle Proxmox Nutzer
    6.8k
Geplant Angeheftet Gesperrt Verschoben Proxmox
53 Beiträge 18 Kommentatoren 3.4k Aufrufe 12 Beobachtet
  • MartinPM Online
    MartinPM Online
    MartinP
    Den habe ich mir selber erstellt - den Proxmox-Adapter habe ich nicht installiert.
    Hier der Userdata-Tree
    Das Bash-Script ist etwas länglich...
     #!/usr/bin/bash
    # to make script ready for cron
    PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
    SimpleApiUrl="http://192.168.2.201:8087/set/0_userdata.0."
    echo "test_hdd_data.sh drive health check started" > /root/scripte/Proxmox_Skripte/last_run.log
    # parameter §1 is subpath (no leading dot but a trailing dot
    function write_userdata_hdd()
      # normalized read error rate
      # use simple api to write to iobroker
      # example: http://192.168.1.:8087/set/javascript.0.test?value=1
      # ReadErrorRate and ReadErrorRateWorst should be ABOVE ReadErrorRateLimit
      # decreasing distance to limit is an indicator for hdd getting worse
      curl $SimpleApiUrl$1"NormalizedReadErrorRate?value="$(awk '/Raw_Read_Error_Rate/{print $4}' /root/scripte/Proxmox_Skripte/Testdata.txt);
      curl $SimpleApiUrl$1"NormalizedReadErrorRateWorst?value="$(awk '/Raw_Read_Error_Rate/{print $5}' /root/scripte/Proxmox_Skripte/Testdata.txt);
      curl $SimpleApiUrl$1"NormalizedReadErrorRateLimit?value="$(awk '/Raw_Read_Error_Rate/{print $6}' /root/scripte/Proxmox_Skripte/Testdata.txt);
      # SeekErrorRate and SeekErrorRateWorst should be ABOVE SeekErrorRateLimit
      curl $SimpleApiUrl$1"SeekErrorRate?value="$(awk '/Seek_Error_Rate/{print $4}' /root/scripte/Proxmox_Skripte/Testdata.txt);
      curl $SimpleApiUrl$1"SeekErrorRateWorst?value="$(awk '/Seek_Error_Rate/{print $5}' /root/scripte/Proxmox_Skripte/Testdata.txt);
      curl $SimpleApiUrl$1"SeekErrorRateLimit?value="$(awk '/Seek_Error_Rate/{print $6}' /root/scripte/Proxmox_Skripte/Testdata.txt);
      curl $SimpleApiUrl$1"LastSmartResult?value="$2
    function write_userdata_ssd()
      curl $SimpleApiUrl$1"PercentLifetimeRemain?value="$(awk '/Percent_Lifetime_Remain/{print $4}' /root/scripte/Proxmox_Skripte/Testdata.txt);
    # write smartctl of hdds of interest to file and analyze results
    # for test purpose comment out smartctl invocations and invoke write_userdata_... functions with off script got Testdata.txt
    # even possible on different linux machine
    # Intenso USB hdd read parameter "sat,12" from https://raw.githubusercontent.com/mirror/smartmontools/master/drivedb.h
    smartctl -a -d sat,12 /dev/sdb >/root/scripte/Proxmox_Skripte/Testdata.txt
    result=$?
    echo " test_hdd_data.sh drive health check data of usb hdd retrieved result="$result >> /root/scripte/Proxmox_Skripte/last_run.log
    write_userdata_hdd "Proxmox_N3000.HDD_Intenso1." $result
    # system SSD
    smartctl -a /dev/sda >/root/scripte/Proxmox_Skripte/Testdata.txt
    result=$?
    echo " test_hdd_data.sh drive health check data of system ssd retrieved result="$result >> /root/scripte/Proxmox_Skripte/last_run.log
    write_userdata_ssd "Proxmox_N3000.System_SSD." $result
    echo " test_hdd_data.sh drive health check finished" >> /root/scripte/Proxmox_Skripte/last_run.log
    • T Nicht stören
      T Nicht stören
      ticaki
      nicht das es eine gute platte war - aber das hab ich gerade gefunden (hab was anders geguckt)
      Wert Status
      SMART Health FAILED
      Critical Warning 0x04 — Reliability degraded
      Percentage Used 131% — SSD hat TBW-Limit um 31% überschritten
      Daten geschrieben 221 TB auf einer 512 GB SSD
      Power On Hours 24.754 h (~2,8 Jahre)
      Spare Blocks 100% (noch gut)
      Media Errors 0 (noch keine Datenfehler)
      Spenden
      • MartinPM Online
        MartinPM Online
        MartinP
        Hmm - nur ~500 Zyklen pro Zelle, und die Platte gibt Alarm?
        Meine Platte (480 GB) hat inzwischen 43562302801 LBAs geschrieben.
        Bei 512 Bytes pro LBA wären das 22 TB, bei 4096 Bytes pro LBA etwa 180 TB
        Der Abnutzungsgrad von 11% spricht dafür, dass etwa 22 TB bisher geschrieben worden sind...
        Scheint also üblich zu sein, dass man das 500 - fache der Kapazität an Schreibzyklen als Verschleißgrenze annimmt ...
        • ChaotC Offline
          ChaotC Offline
          Chaot
          Die Anzeige zeigt also den Verschleiß der Platte in % an. Das kann bei mir irgendwie nicht stimmen:
          • arteckA Offline
            arteckA Offline
            arteck
            -50% ist auch interessant
            • ChaotC Offline
              ChaotC Offline
              Chaot
              Kommt so aus den SMART Werten
              • ChaotC Offline
                ChaotC Offline
                Chaot
                • ilovegymI Offline
                  ilovegymI Offline
                  ilovegym
                  100% ist neu, 0% ist verschlissen. Bei -50 biste halt schon drüber, aber wennse noch geht.. schonmal Reserve nebendran legen.. :)
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    nein 0% in proxmox ist neu.. im Adapter währe die verschlissen bei 0% da ist 100% neu
                    eben umgekehrt, die api liefert das so..
                    ilovegymI 1 Antwort Letzte Antwort
                    • ChaotC Offline
                      ChaotC Offline
                      Chaot
                      Sorry für den Doppelpost. Irgendwie spinnt mein Internet.
                      @ilovegym Laut den Bildern der anderen Nutzer hier scheint es aber anders zu sein 0% ist Neu 100% ist Tot
                      • ilovegymI Offline
                        ilovegymI Offline
                        ilovegym
                        Ah ja sorry, Recht haste.. 100% ist Kaputt, 0% ist neu, das ist das, was Proxmox aus den Smartwerten rechnet..
                        • arteckA arteck
                          ilovegymI Offline
                          ilovegymI Offline
                          ilovegym
                          @arteck ahhh.. daher hab ich mein Durcheinenander.. danke, die Api zeigts anders als die Gui.. na das ist ja mal interessant.. :)
                          • ChaotC Chaot
                            MartinPM Online
                            MartinPM Online
                            MartinP
                            @Chaot sagte:
                            Percent_lifetime_remain über 100% sind schon sehr merkwürdig, und erklären die negativen Werte, die die Proxmox-Umrechnung ergibt....
                            Vielleicht hat die SSD ja Katzen-Gene
                            Katzen haben ja bekanntlich sieben Leben.
                            Bei einer neugeborenen Katze würde also bei Percent Lifetime Remain 700 gemeldet.....
                            • ChaotC Offline
                              ChaotC Offline
                              Chaot
                              Ich muss ehrlicherweise sagen, dass ich da nie darauf geachtet habe. Aber die ganze Anzeige ist irgendwie Käse.
                              percent Lifetime 206 Schwellwert 150 hat doch beides nichts mit irgendwelchen Prozentwerten zu tun finde ich.
                              Ok, dauernde Backups mache ich sowieso und eine Reserveplatte (die ich eigentlich schon vor 12 Monaten einbauen wollte) liegt auch bereit. Mal im Auge behalten wo hier die Reise hingeht.
                              • Master67M Offline
                                Master67M Offline
                                Master67
                                Ein sehr interessantes Thema über das ich mir nie Gedanken gemacht hatte.
                                Die Aktuelle Nvme ist seit November 2024 im System Verbaut, ebenso die SSD.
                                Und so sehen die Werte aus
                                Keine Ahnung warum dir beiden Platten nur zu 2% belastet sind.....
                                Gruß Master67
                                • MartinPM Online
                                  MartinPM Online
                                  MartinP
                                  Interessant finde ich die hohe Anzahl an "Unsafe Shutdowns". Muss Linux bei SSDs beim Herunterfahren besondere Prozeduren einhalten, und tut es in Deinem Fall nicht korrekt?
                                  Master67M 1 Antwort Letzte Antwort
                                  • MartinPM MartinP
                                    Master67M Offline
                                    Master67M Offline
                                    Master67
                                    schrieb am zuletzt editiert von Master67
                                    @MartinP sagte:
                                    Mich nicht.... das System ist öfter mal "Hart" Abgeschaltet worden, weil bei mir die Server über PV laufen, es hängt zwar eine USV dazwischen aber bis alle Automationen aufeinander Abgestimmt
                                    waren hat es sicher 20 mal "geknallt" der Rest wird von sonstigen Hart-Resets sein, aber nach 1,5 Jahren kann ich nicht alles Aufzählen, es wird sicher auch mal ein LXC mit schuld sein, vermute ich mal :-)
                                    Edit:
                                    So sieht der zweite Server aus, da wird die SSD bald ausfallen, die ist aber auch älter, war beim Einbau sicher schon 2-3 Jahre alt.
                                    Gruß Master67
                                    • Master67M Master67
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      @Master67
                                      Die 2% betrifft wahrscheinlich den TBA Total bytes written wert.
                                      Da musst mal schauen wieviel der Hersteller vorgibt. Bis dahin garantiert er. Manchmal auch noch zusätzlich die Betriebsstunden.
                                      Meine Adapter und Widgets
                                      Links im Profil
                                      • David G.D Online
                                        David G.D Online
                                        David G.
                                        Ich rufe mir die Werte mit Linux Control ab.
                                        Befehl
                                        smartctl --scan | awk '{print $1}' | while read dev; do name=$(basename $dev); json=$(smartctl -A -j $dev); if echo "$json" | jq -e '.ata_smart_attributes' > /dev/null 2>&1; then echo "$json" | jq --arg d "$name" '{($d): (.ata_smart_attributes.table | map({(.name): (if .name == "Temperature_Celsius" then .value else .raw.value end)}) | add // {})}'; else echo "$json" | jq --arg d "$name" '{($d): (.nvme_smart_health_information_log // {} | del(.nsid, .temperature_sensors))}'; fi; done | jq -s 'add'
                                        Ergebnis
                                          "sda": {
                                            "Reallocated_Sector_Ct": 0,
                                            "Power_On_Hours": 23050,
                                            "Power_Cycle_Count": 46,
                                            "Wear_Leveling_Count": 286,
                                            "Used_Rsvd_Blk_Cnt_Tot": 0,
                                            "Unused_Rsvd_Blk_Cnt_Tot": 437,
                                            "Program_Fail_Cnt_Total": 0,
                                            "Erase_Fail_Count_Total": 0,
                                            "Runtime_Bad_Block": 0,
                                            "End-to-End_Error": 0,
                                            "Uncorrectable_Error_Cnt": 0,
                                            "Airflow_Temperature_Cel": 53,
                                            "Temperature_Celsius": 47,
                                            "ECC_Error_Rate": 0,
                                            "Current_Pending_Sector": 0,
                                            "CRC_Error_Count": 0,
                                            "Exception_Mode_Status": 0,
                                            "POR_Recovery_Count": 14,
                                            "Total_LBAs_Written": 52455340537,
                                            "Total_LBAs_Read": 40595535623,
                                            "SATA_Downshift_Ct": 0,
                                            "Thermal_Throttle_St": 0,
                                            "Timed_Workld_Media_Wear": 65535,
                                            "Timed_Workld_RdWr_Ratio": 65535,
                                            "Timed_Workld_Timer": 65535,
                                            "NAND_Writes": 67942600384
                                          "nvme0": {
                                            "critical_warning": 0,
                                            "temperature": 55,
                                            "available_spare": 100,
                                            "available_spare_threshold": 10,
                                            "percentage_used": 13,
                                            "data_units_read": 1622206761,
                                            "data_units_written": 295401619,
                                            "host_reads": 11974915901,
                                            "host_writes": 4429907015,
                                            "controller_busy_time": 27892,
                                            "power_cycles": 45,
                                            "power_on_hours": 3891,
                                            "unsafe_shutdowns": 11,
                                            "media_errors": 0,
                                            "num_err_log_entries": 0,
                                            "warning_temp_time": 17,
                                            "critical_comp_time": 0
                                        • BananaJoeB Online
                                          BananaJoeB Online
                                          BananaJoe
                                          Ich hatte auch mal einen Anlauf genommen, die S.M.A.R.T.-Werte unter Windows zu überwachen. Grund war das ich eine Festplatte hatte die dann schon massive Schreibfehler produziert hatte. Unter Windows produziert das einen EventLog-Eintrag mit der Ereignis-ID 7, dann ist höchster Alarm angesagt. CrystalDiskInfo hat immerhin Vorsicht bei der Festplatte gemeldet bei C5, das war der Current Pending Sector Count. Aber 3 andere Festplatten die exakt den gleichen Wert bei C5 hatten (200) waren grün?!?!?
                                          Ich habe dann geschaut was über WMI, PowerShell (nicht WMI) und den Smartmontools geht.
                                          Bei den Tools die auch für eine Hintergrundüberwachung geeignet wäre, kein einziges, der Gesamtzustand war trotzdem Heathly (PowerShell), OK (WMI) bzw. PredictFailure = False (auch WMI) und bei den SmartmonTools kam nur die Werte raus, aber ohne Bewertung.
                                          Hier meine Forschungen von damals: https://znil.net/index.php?title=Zabbix:Template_Windows_SMART-Werte_Festplatten
                                          Mein Fazit war, das ich nur auf das Eventlog vertraue.
                                          Was wäre das Pendant in Linux?
