  4. MQTT und Shelly
    6.3k
MQTT und Shelly
146 Beiträge 11 Kommentatoren 5.7k Aufrufe 10 Beobachtet
    axel
    helly.0
    	2026-05-05 16:14:13.688	debug	[firmwareNotify] Starting firmware check on every device
    shelly.0
    	2026-05-05 16:14:03.695	debug	[MQTT Server] Started listener on 127.0.0.1:1884
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.688	info	Starting in MQTT mode. Listening on 127.0.0.1:1884 (QoS 0)
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.613	silly	States user redis pmessage shelly.0.*/shelly.0.info.connection:{"val":false,"ack":true,"ts":1777990443612,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1777908038007}
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.573	silly	redis psubscribe cfg.f.shelly.0$%$*$%$data
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.499	silly	States system redis pmessage system.adapter.shelly.0.logLevel/system.adapter.shelly.0.logLevel:{"val":"silly","ack":true,"ts":1777990443491,"q":0,"from":"system.adapter.shelly.0","lc":1777984168669}
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.471	info	starting. Version 10.6.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v22.22.2, js-controller: 7.0.7
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.291	debug	Plugin sentry Initialize Plugin (enabled=true)
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.259	silly	statesDB connected
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.258	debug	States connected to redis: 127.0.0.1:9000
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.177	debug	States create User PubSub Client
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.176	debug	States create System PubSub Client
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.127	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.125	silly	objectDB connected
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.124	silly	redis psubscribe cfg.o.enum.*
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.086	silly	redis psubscribe cfg.o.system.user.*
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.084	debug	Objects connected to redis: 127.0.0.1:9001
    shelly.0
    shelly.0
    	2026-05-05 16:14:03.080	debug	Objects client initialize lua scripts
    shelly.0
    shelly.0
    	2026-05-05 16:14:02.964	debug	Objects create User PubSub Client
    shelly.0
    shelly.0
    	2026-05-05 16:14:02.962	debug	Objects create System PubSub Client
    shelly.0
    shelly.0
    	2026-05-05 16:14:02.892	debug	Objects client ready ... initialize now
    shelly.0
    shelly.0
    	2026-05-05 16:14:02.847	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.822	info	terminating
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.366	debug	[MQTT Server] Closing listener
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.365	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.364	debug	Plugin sentry destroyed
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.363	info	terminating
    shelly.0
    	2026-05-05 16:13:58.363	debug	[MQTT Server] Destroying
    shelly.0
    	2026-05-05 16:13:58.363	debug	[BaseServer] Destroying
    shelly.0
    shelly.0
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.362	debug	[onUnload] Stopping MQTT server
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.362	debug	[onUnload] Closing adapter
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.359	silly	States user redis pmessage shelly.0.*/shelly.0.info.connection:{"val":false,"ack":true,"ts":1777990438357,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1777908038007}
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.320	info	Got terminate signal TERMINATE_YOURSELF
    shelly.0
    shelly.0
    	2026-05-05 16:13:58.319	silly	States system redis pmessage system.adapter.shelly.0.sigKill/system.adapter.shelly.0.sigKill:{"val":-1,"ack":false,"ts":1777990438318,"q":0,"from":"system.host.grafenhof","lc":1777990438318}
    shelly.0
    QNAP 677 VM 16 GB, 4 Kerne, 3,4 GHz
    29.375 Objekte
    24.247 Zustände
      @axel und auch noch auf local IP umgestellt
      Accuface
      @crunchip sagte:
      könnte es daran liegen?
      bei mir ist der Haken nicht drin.
      • A axel
        Der Wunsch nach den code-tags gehlt nicht, Formatierung wird nicht angebten
        @axel sagte:
        Wieso nicht?
        Bitte unbedingt lesen:
        • A axel
          crunchipC Abwesend
          crunchipC Abwesend
          @axel hier ist der Haken aber drin
          • A axel
            helly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            shelly.0
            crunchipC Abwesend
            crunchipC Abwesend
            @axel sagte:
            127.0.0.1
            ist falsch
              axel
              es spielt keine Rolle, nichts fumktioniert...
              Der Adapter geht nicht auf grün.
              29.375 Objekte
              24.247 Zustände
              HomoranH crunchipC 2 Antworten Letzte Antwort
              • A axel
                @axel sagte:
                Zeig bitte die Ausgabe von iob diag !
                • A axel
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @axel so lang der Shelly nicht erkannt wird, bleibt das auch so
                  Wie war denn dein alter Shelly eingerichtet?
                  • da_WoodyD Offline
                    da_WoodyD Offline
                    Die Diskussion wird mühsam.
                    Adapter deinstallieren, den Shelly auf Werkseinstellungen zurücksetzen, Adapter original mit mqtt insten, Shelly über die App neu einbinden. Richtige Daten eingeben!
                    Diverse reboots nicht vergessen.
                      Ich gehe bei diesem Satz
                      @axel sagte:
                      ich binde das Tasmota-Gerät über MQTT auf port 1883 über den MQTT-Adapter an den Sonoff-Adapter an.
                      Erst recht von port Doppelbelegungen aus
                      Leider wird dem Wunsch nach der Ausgabe von iob diag, was auch andere Probleme zeigen würde, nicht nachgekommen
                        axel
                        ich kann nicht zaubern...
                        wie bekomme ich den output in eine datei?
                        29.375 Objekte
                        24.247 Zustände
                        • A axel
                          @axel wieso Datei?
                          Einfach kopieren und hier in code-tags posten
                            axel
                            #66
                            Ich bin leider nicht durchgehend verfügbar. Hier der Output iob diag:
                            ```bash
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                            Operating System: Ubuntu 24.04.4 LTS
                             Static hostname: grafenhof
                                   Icon name: computer-vm
                                     Chassis: vm 🖴
                              Virtualization: kvm
                                      Kernel: Linux 6.8.0-111-generic
                                Architecture: x86-64
                             Hardware Vendor: qemu
                              Hardware Model: qemu
                            Firmware Version: e0d6339-dirty-20220919_024111-d528eb931742
                               Firmware Date: Tue 2014-04-01
                                Firmware Age: 12y 1month 4d
                            OS is similar to: debian
                            model name      : AMD Opteron 22xx (Gen 2 Class Opteron)
                            Docker          : false
                            Virtualization  : kvm
                            Kernel          : x86_64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             18:18:29 up 7 min,  3 users,  load average: 0.46, 0.93, 0.57
                            CPU threads: 4
                            *** LIFE CYCLE STATUS ***
                            Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
                            *** TIME AND TIMEZONES ***
                                           Local time: Tue 2026-05-05 18:18:29 CEST
                                       Universal time: Tue 2026-05-05 16:18:29 UTC
                                             RTC time: Tue 2026-05-05 16:18:29
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            axel
                            HOME=/home/axel
                            GROUPS=axel adm cdrom sudo dip plugdev lxd iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev
                            *** DISPLAY-SERVER SETUP ***
                            Display-Server:         false
                            Unit display-manager.service could not be found.
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:             16G        4.0G         12G        4.4M        902M         12G
                            Swap:           4.3G          0B        4.3G
                            Total:           21G        4.0G         16G
                            Active iob-Instances:   48
                                    15993 M total memory
                                     3812 M used memory
                                     3544 M active memory
                                      440 M inactive memory
                                    11608 M free memory
                                       80 M buffer memory
                                      780 M swap cache
                                     4095 M total swap
                                        0 M used swap
                                     4095 M free swap
                            top - 18:18:29 up 7 min,  3 users,  load average: 0.46, 0.93, 0.57
                            Tasks: 211 total,   2 running, 209 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  15993.2 total,  11608.0 free,   3812.5 used,    860.9 buff/cache
                            MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.  12180.6 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            No critical errors detected
                            *** FILESYSTEM ***
                            Filesystem                        Type   Size  Used Avail Use% Mounted on
                            tmpfs                             tmpfs  1.6G  4.2M  1.6G   1% /run
                            /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   24G   70G  25% /
                            tmpfs                             tmpfs  7.9G     0  7.9G   0% /dev/shm
                            tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                            /dev/vda2                         ext4   2.0G  200M  1.6G  11% /boot
                            tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
                            [Tue May  5 18:10:38 2026] EXT4-fs (dm-0): mounted filesystem 0752226f-a4b0-480d-bcc4-3e164dcec510 ro with ordered data mode. Quota mode: none.
                            [Tue May  5 18:10:41 2026] EXT4-fs (dm-0): re-mounted 0752226f-a4b0-480d-bcc4-3e164dcec510 r/w.
                            [Tue May  5 18:10:43 2026] EXT4-fs (vda2): mounted filesystem 638497ff-4955-4c0c-a8a3-79ea9e7c1f0f r/w with ordered data mode. Quota mode: none.
                            Show mounted filesystems:
                            TARGET                          SOURCE                            FSTYPE   OPTIONS
                            /                               /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                            |-/snap/canonical-livepatch/384 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/canonical-livepatch/406 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/core22/2411             /dev/loop4                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/core24/1499             /dev/loop3                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/core22/2339             /dev/loop2                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/speedtest/12            /dev/loop10                       squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/core24/1587             /dev/loop6                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/powershell/341          /dev/loop5                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/snapd/25935             /dev/loop8                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/powershell/351          /dev/loop7                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/speedtest/9             /dev/loop11                       squashfs ro,nodev,relatime,errors=continue,threads=single
                            |-/snap/snapd/26382             /dev/loop9                        squashfs ro,nodev,relatime,errors=continue,threads=single
                            `-/boot                         /dev/vda2                         ext4     rw,relatime
                            /var:
                            3.0G    /var/
                            881M    /var/lib
                            859M    /var/cache
                            823M    /var/cache/apt
                            735M    /var/log
                            Archived and active journals take up 716.1M in the file system.
                            /opt/iobroker/backups:
                            9.2G    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            787M    /opt/iobroker/iobroker-data/
                            569M    /opt/iobroker/iobroker-data/files
                            125M    /opt/iobroker/iobroker-data/backup-objects
                            78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                            55M     /opt/iobroker/iobroker-data/files/material
                            53M     /opt/iobroker/iobroker-data/objects.jsonl
                            42M     /opt/iobroker/iobroker-data/states.jsonl
                            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                            30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                            11M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js
                            USB-Devices by-id:
                            USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                            please always prefer the links 'by-id':
                            No Devices found 'by-id'
                            No nvbackup.json found.
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v22.22.2
                            /usr/bin/node           v22.22.2
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            ✓ Node.js installation is correct
                            nodejs:
                              Installed: 22.22.2-1nodesource1
                              Candidate: 22.22.2-1nodesource1
                              Version table:
                             *** 22.22.2-1nodesource1 1001
                                 22.22.1-1nodesource1 1001
                                 22.22.0-1nodesource1 1001
                                 22.21.0-1nodesource1 1001
                                 22.20.0-1nodesource1 1001
                                 22.19.0-1nodesource1 1001
                                 22.18.0-1nodesource1 1001
                                 22.17.1-1nodesource1 1001
                                 22.17.0-1nodesource1 1001
                                 22.16.0-1nodesource1 1001
                                 22.15.1-1nodesource1 1001
                                 22.15.0-1nodesource1 1001
                                 22.14.0-1nodesource1 1001
                                 22.13.1-1nodesource1 1001
                                 22.13.0-1nodesource1 1001
                                 22.12.0-1nodesource1 1001
                                 22.11.0-1nodesource1 1001
                                 22.10.0-1nodesource1 1001
                                 22.9.0-1nodesource1 1001
                                 22.8.0-1nodesource1 1001
                                 22.7.0-1nodesource1 1001
                                 22.6.0-1nodesource1 1001
                                 22.5.1-1nodesource1 1001
                                 22.5.0-1nodesource1 1001
                                 22.4.1-1nodesource1 1001
                                 22.4.0-1nodesource1 1001
                                 22.3.0-1nodesource1 1001
                                 22.2.0-1nodesource1 1001
                                 22.1.0-1nodesource1 1001
                                 22.0.0-1nodesource1 1001
                                 18.19.1+dfsg-6ubuntu5 500
                                    500 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                            No problems detected
                            Errors in npm tree: 0
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            grafenhof           grafenhof (version: 7.0.7, hostname: grafenhof     , alive, uptime: 460)
                            Core adapters versions
                            admin:          7.7.22
                            javascript:     9.0.18
                            nodejs modules from github:     1
                            +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : grafenhof                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alarm.0                  : alarm                 : grafenhof                                -  enabled
                            + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : grafenhof                                -  enabled
                            + system.adapter.alexa2.0                 : alexa2                : grafenhof                                -  enabled
                              system.adapter.apg-info.0               : apg-info              : grafenhof                                -  enabled
                            + system.adapter.backitup.0               : backitup              : grafenhof                                -  enabled
                            + system.adapter.chromecast.0             : chromecast            : grafenhof                                -  enabled
                              system.adapter.cloud.0                  : cloud                 : grafenhof                                - disabled
                              system.adapter.daswetter.0              : daswetter             : grafenhof                                -  enabled
                            + system.adapter.discovery.0              : discovery             : grafenhof                                -  enabled
                              system.adapter.dwd.0                    : dwd                   : grafenhof                                -  enabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : grafenhof                                - disabled
                              system.adapter.feiertage.0              : feiertage             : grafenhof                                -  enabled
                            + system.adapter.followthesun.0           : followthesun          : grafenhof                                -  enabled
                            + system.adapter.fritzbox.0               : fritzbox              : grafenhof                                -  enabled
                            + system.adapter.fritzdect.0              : fritzdect             : grafenhof                                -  enabled
                            + system.adapter.history.0                : history               : grafenhof                                -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : grafenhof                                -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : grafenhof                                -  enabled, port: 18701
                            + system.adapter.hm-rpc.1                 : hm-rpc                : grafenhof                                -  enabled, port: 12001
                            + system.adapter.hm-rpc.2                 : hm-rpc                : grafenhof                                -  enabled
                              system.adapter.ical.0                   : ical                  : grafenhof                                -  enabled
                              system.adapter.ical.1                   : ical                  : grafenhof                                -  enabled
                              system.adapter.ical.2                   : ical                  : grafenhof                                -  enabled
                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: grafenhof                                -  enabled
                              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : grafenhof                                -  enabled
                              system.adapter.icons-icons8.0           : icons-icons8          : grafenhof                                -  enabled
                              system.adapter.icons-material-png.0     : icons-material-png    : grafenhof                                -  enabled
                              system.adapter.icons-material-svg.0     : icons-material-svg    : grafenhof                                -  enabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : grafenhof                                -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : grafenhof                                -  enabled
                              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: grafenhof                                -  enabled
                              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : grafenhof                                -  enabled
                            + system.adapter.iot.0                    : iot                   : grafenhof                                -  enabled
                            + system.adapter.jarvis.0                 : jarvis                : grafenhof                                -  enabled
                            + system.adapter.javascript.0             : javascript            : grafenhof                                -  enabled
                            + system.adapter.kecontact.0              : kecontact             : grafenhof                                -  enabled
                            + system.adapter.klf200.0                 : klf200                : grafenhof                                -  enabled
                            + system.adapter.lgtv.0                   : lgtv                  : grafenhof                                -  enabled
                            + system.adapter.linkeddevices.0          : linkeddevices         : grafenhof                                -  enabled
                              system.adapter.material.0               : material              : grafenhof                                -  enabled
                            + system.adapter.modbus.0                 : modbus                : grafenhof                                -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : grafenhof                                -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.net-tools.0              : net-tools             : grafenhof                                -  enabled
                            + system.adapter.notification-manager.0   : notification-manager  : grafenhof                                -  enabled
                            + system.adapter.opendtu.0                : opendtu               : grafenhof                                -  enabled
                            + system.adapter.opendtu.1                : opendtu               : grafenhof                                -  enabled
                            + system.adapter.ping.0                   : ping                  : grafenhof                                -  enabled
                            + system.adapter.pollenflug.0             : pollenflug            : grafenhof                                -  enabled
                            + system.adapter.pushover.0               : pushover              : grafenhof                                -  enabled
                            + system.adapter.pvforecast.0             : pvforecast            : grafenhof                                -  enabled
                            + system.adapter.rest-api.0               : rest-api              : grafenhof                                -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                            + system.adapter.shelly.0                 : shelly                : grafenhof                                -  enabled, port: 1884, bind: 127.0.0.1
                            + system.adapter.shuttercontrol.0         : shuttercontrol        : grafenhof                                -  enabled
                            + system.adapter.sonoff.0                 : sonoff                : grafenhof                                -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.sql.0                    : sql                   : grafenhof                                -  enabled, port: 3306
                            + system.adapter.stiebel-isg.0            : stiebel-isg           : grafenhof                                -  enabled
                            + system.adapter.tr-064.0                 : tr-064                : grafenhof                                -  enabled
                            + system.adapter.tr-064.1                 : tr-064                : grafenhof                                -  enabled
                            + system.adapter.tr-064.3                 : tr-064                : grafenhof                                -  enabled
                            + system.adapter.tr-064.4                 : tr-064                : grafenhof                                -  enabled
                              system.adapter.unifi.0                  : unifi                 : grafenhof                                - disabled
                            + system.adapter.upnp.0                   : upnp                  : grafenhof                                -  enabled
                              system.adapter.vis-bars.0               : vis-bars              : grafenhof                                -  enabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : grafenhof                                -  enabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : grafenhof                                -  enabled
                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : grafenhof                                -  enabled
                              system.adapter.vis-google-fonts.0       : vis-google-fonts      : grafenhof                                -  enabled
                              system.adapter.vis-history.0            : vis-history           : grafenhof                                -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : grafenhof                                -  enabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : grafenhof                                -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : grafenhof                                -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : grafenhof                                -  enabled
                              system.adapter.vis-justgage.0           : vis-justgage          : grafenhof                                -  enabled
                              system.adapter.vis-map.0                : vis-map               : grafenhof                                -  enabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : grafenhof                                -  enabled
                              system.adapter.vis-material-webfont.0   : vis-material-webfont  : grafenhof                                -  enabled
                              system.adapter.vis-material.0           : vis-material          : grafenhof                                -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : grafenhof                                -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : grafenhof                                -  enabled
                              system.adapter.vis-players.0            : vis-players           : grafenhof                                -  enabled
                              system.adapter.vis-plumb.0              : vis-plumb             : grafenhof                                -  enabled
                              system.adapter.vis-rgraph.0             : vis-rgraph            : grafenhof                                -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : grafenhof                                -  enabled
                              system.adapter.vis-weather.0            : vis-weather           : grafenhof                                -  enabled
                              system.adapter.vis.0                    : vis                   : grafenhof                                -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : grafenhof                                -  enabled
                            + system.adapter.web.0                    : web                   : grafenhof                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : grafenhof                                -  enabled
                            + system.adapter.withings.0               : withings              : grafenhof                                -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            │ (index) │ name     │ url                                                      │ auto upgrade │
                            │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'         │ false        │
                            │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json ' │ false        │
                            Active repo(s): stable
                            Upgrade policy: none
                            Installed ioBroker-Adapters
                            Used repository: stable
                            Adapter    "admin"        : 7.7.22   , installed 7.7.22
                            Adapter    "alarm"        : 3.7.6    , installed 3.7.6
                            Adapter    "alexa-timer-vis": 2.2.2  , installed 2.2.2
                            Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                            Adapter    "apg-info"     : 0.1.30   , installed 0.1.30
                            Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                            Adapter    "chromecast"   : 4.1.1    , installed 4.1.1
                            Adapter    "daswetter"    : 4.5.3    , installed 3.2.8  [Updatable]
                            Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                            Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
                            Adapter    "followthesun" : 0.5.2    , installed 0.5.2
                            Adapter    "fritzbox"     : 0.7.0    , installed 0.7.0
                            Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                            Adapter    "history"      : 4.0.0    , installed 4.0.0
                            Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
                            Adapter    "homekit-controller": 0.5.11, installed 0.5.11
                            Adapter    "ical"         : 1.20.0   , installed 1.20.0
                            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                            Adapter    "iot"          : 5.0.12   , installed 5.0.12
                            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                            Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                            Controller "js-controller": 7.0.7    , installed 7.0.7
                            Adapter    "kecontact"    : 3.6.0    , installed 3.6.0
                            Adapter    "klf200"       : 1.3.5    , installed 1.3.5
                            Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                            Adapter    "material"     : 1.3.1    , installed 1.3.1
                            Adapter    "modbus"       : 8.0.3    , installed 8.0.3
                            Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
                            Adapter    "notification-manager": 1.3.0, installed 1.3.0
                            Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                            Adapter    "ping"         : 1.7.9    , installed 1.7.9
                            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                            Adapter    "pushover"     : 5.0.0    , installed 5.0.0
                            Adapter    "pvforecast"   : 5.1.0    , installed 5.1.0
                            Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
                            Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                            Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
                            Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                            Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                            Adapter    "sql"          : 3.0.1    , installed 3.0.1
                            Adapter    "stiebel-isg"  : 2.0.3    , installed 2.0.3
                            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                            Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                            Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                            Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
                            Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                            Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                            Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                            Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                            Adapter    "web"          : 8.0.0    , installed 8.0.0
                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                            Adapter    "withings"     : 0.0.13   , installed 0.0.13
                            Adapter    "ws"           : 4.0.0    , installed 4.0.0
                            Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                            Objects and States
                            Objects:        29379
                            States:         24304
                            Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
                            Hit:2 http://de.archive.ubuntu.com/ubuntu noble InRelease
                            Hit:3 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                            Hit:5 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
                            Hit:6 https://esm.ubuntu.com/apps/ubuntu noble-apps-security InRelease
                            Hit:7 https://esm.ubuntu.com/apps/ubuntu noble-apps-updates InRelease
                            Hit:8 https://esm.ubuntu.com/infra/ubuntu noble-infra-security InRelease
                            Hit:9 https://esm.ubuntu.com/infra/ubuntu noble-infra-updates InRelease
                            Hit:10 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
                            Reading package lists...
                            Pending systemupdates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       23084      2000/io.sonoff.0
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        9354       804/systemd-resolve
                            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       27920      2367/io.jarvis.0
                            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          10591      1022/smbd
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          869        1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7110       1/init
                            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          10590      1022/smbd
                            tcp        0      0 192.168.12.182:2010     0.0.0.0:*               LISTEN      1001       15620      1578/io.hm-rpc.2
                            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        9356       804/systemd-resolve
                            tcp        0      0 192.168.12.182:12001    0.0.0.0:*               LISTEN      1001       13991      1562/io.hm-rpc.1
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11375      827/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9190       827/iobroker.js-con
                            tcp        0      0 127.0.0.1:1884          0.0.0.0:*               LISTEN      1001       25073      2152/io.shelly.0
                            tcp        0      0 192.168.12.182:18701    0.0.0.0:*               LISTEN      1001       13959      1546/io.hm-rpc.0
                            tcp6       0      0 :::139                  :::*                    LISTEN      0          10589      1022/smbd
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          1402       1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          7112       1/init
                            tcp6       0      0 :::445                  :::*                    LISTEN      0          10588      1022/smbd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9998       1211/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28251      2526/io.web.0
                            tcp6       0      0 :::8093                 :::*                    LISTEN      1001       28367      2601/io.rest-api.0
                            tcp6       0      0 :::8000                 :::*                    LISTEN      1001       34261      2431/io.upnp.0
                            udp        0      0 0.0.0.0:41441           0.0.0.0:*                           1001       28033      2431/io.upnp.0
                            udp        0      0 0.0.0.0:41670           0.0.0.0:*                           1001       14360      1352/io.whatsapp-cm
                            udp        0      0 0.0.0.0:49957           0.0.0.0:*                           1001       23450      2200/io.alexa-timer
                            udp        0      0 0.0.0.0:58671           0.0.0.0:*                           1001       10910      1259/io.javascript.
                            udp        0      0 0.0.0.0:42308           0.0.0.0:*                           1001       24539      2019/io.stiebel-isg
                            udp        0      0 0.0.0.0:42625           0.0.0.0:*                           1001       23620      1750/io.kecontact.0
                            udp        0      0 0.0.0.0:34661           0.0.0.0:*                           1001       28087      2464/io.vis-inventw
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       30056      2431/io.upnp.0
                            udp        0      0 0.0.0.0:43232           0.0.0.0:*                           1001       25536      2308/io.followthesu
                            udp        0      0 0.0.0.0:35322           0.0.0.0:*                           1001       27917      2367/io.jarvis.0
                            udp        0      0 0.0.0.0:43576           0.0.0.0:*                           1001       26306      2253/io.discovery.0
                            udp        0      0 0.0.0.0:51779           0.0.0.0:*                           1001       21937      1796/io.modbus.0
                            udp        0      0 0.0.0.0:60172           0.0.0.0:*                           1001       29723      2415/io.pvforecast.
                            udp        0      0 0.0.0.0:51997           0.0.0.0:*                           1001       23082      2000/io.sonoff.0
                            udp        0      0 0.0.0.0:35717           0.0.0.0:*                           1001       13077      1530/io.hm-rega.0
                            udp        0      0 0.0.0.0:35798           0.0.0.0:*                           1001       10162      1323/io.sql.0
                            udp        0      0 0.0.0.0:35899           0.0.0.0:*                           1001       24360      1956/io.pollenflug.
                            udp        0      0 0.0.0.0:35953           0.0.0.0:*                           1001       10137      1307/io.pushover.0
                            udp        0      0 0.0.0.0:36062           0.0.0.0:*                           1001       12297      1219/io.history.0
                            udp        0      0 0.0.0.0:36299           0.0.0.0:*                           1001       22940      1933/io.ping.0
                            udp        0      0 0.0.0.0:52866           0.0.0.0:*                           1001       27055      2383/io.klf200.0
                            udp        0      0 0.0.0.0:36855           0.0.0.0:*                           1001       22711      1812/io.mqtt.0
                            udp        0      0 0.0.0.0:53295           0.0.0.0:*                           1001       27828      2345/io.iot.0
                            udp        0      0 0.0.0.0:45103           0.0.0.0:*                           1001       23238      2088/io.tr-064.3
                            udp        0      0 0.0.0.0:37027           0.0.0.0:*                           1001       24267      1917/io.opendtu.1
                            udp        0      0 0.0.0.0:37975           0.0.0.0:*                           1001       13656      1411/io.backitup.0
                            udp        0      0 0.0.0.0:38042           0.0.0.0:*                           1001       25060      2136/io.alarm.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11801      1454/io.chromecast.
                            udp        0      0 0.0.0.0:46469           0.0.0.0:*                           1001       25014      2104/io.tr-064.4
                            udp        0      0 0.0.0.0:38487           0.0.0.0:*                           1001       13712      1454/io.chromecast.
                            udp        0      0 0.0.0.0:46683           0.0.0.0:*                           1001       29800      2431/io.upnp.0
                            udp        0      0 0.0.0.0:38570           0.0.0.0:*                           1001       13956      1546/io.hm-rpc.0
                            udp        0      0 0.0.0.0:55214           0.0.0.0:*                           1001       27314      2526/io.web.0
                            udp        0      0 0.0.0.0:39148           0.0.0.0:*                           1001       24930      2048/io.tr-064.0
                            udp        0      0 0.0.0.0:39162           0.0.0.0:*                           1001       14529      1466/io.alexa2.0
                            udp        0      0 0.0.0.0:47412           0.0.0.0:*                           1001       22357      2068/io.tr-064.1
                            udp        0      0 0.0.0.0:39387           0.0.0.0:*                           1001       21872      1750/io.kecontact.0
                            udp        0      0 0.0.0.0:39622           0.0.0.0:*                           1001       9183       827/iobroker.js-con
                            udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       23625      1750/io.kecontact.0
                            udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       23626      1750/io.kecontact.0
                            udp        0      0 0.0.0.0:56464           0.0.0.0:*                           1001       27960      2399/io.linkeddevic
                            udp        0      0 0.0.0.0:40166           0.0.0.0:*                           1001       24645      1884/io.notificatio
                            udp        0      0 0.0.0.0:56682           0.0.0.0:*                           1001       15542      1562/io.hm-rpc.1
                            udp        0      0 0.0.0.0:40345           0.0.0.0:*                           1001       26005      2152/io.shelly.0
                            udp        0      0 0.0.0.0:56734           0.0.0.0:*                           1001       24685      1901/io.opendtu.0
                            udp        0      0 0.0.0.0:56881           0.0.0.0:*                           1001       24799      1977/io.shuttercont
                            udp        0      0 0.0.0.0:48822           0.0.0.0:*                           1001       29117      2566/io.withings.0
                            udp        0      0 0.0.0.0:49135           0.0.0.0:*                           1001       15052      1578/io.hm-rpc.2
                            udp        0      0 0.0.0.0:32795           0.0.0.0:*                           1001       21272      1828/io.net-tools.0
                            udp        0      0 0.0.0.0:57387           0.0.0.0:*                           1001       30238      2601/io.rest-api.0
                            udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        9355       804/systemd-resolve
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        9353       804/systemd-resolve
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          870        1/init
                            udp        0      0 192.168.12.255:137      0.0.0.0:*                           0          10541      1012/nmbd
                            udp        0      0 192.168.12.182:137      0.0.0.0:*                           0          10540      1012/nmbd
                            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          10525      1012/nmbd
                            udp        0      0 192.168.12.255:138      0.0.0.0:*                           0          10543      1012/nmbd
                            udp        0      0 192.168.12.182:138      0.0.0.0:*                           0          10542      1012/nmbd
                            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          10526      1012/nmbd
                            udp        0      0 0.0.0.0:32918           0.0.0.0:*                           1001       11432      1211/io.admin.0
                            udp        0      0 0.0.0.0:49345           0.0.0.0:*                           1001       26469      2326/io.fritzdect.0
                            udp        0      0 0.0.0.0:49460           0.0.0.0:*                           1001       13830      1510/io.fritzbox.0
                            udp        0      0 0.0.0.0:57675           0.0.0.0:*                           1001       23705      1780/io.lgtv.0
                            udp6       0      0 fe80::5054:ff:fe00::546 :::*                                998        8062       638/systemd-network
                            udp6       0      0 :::111                  :::*                                0          2373       1/init
                            2026-05-05 18:18:50.008  - warn: javascript.0 (1259)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                            2026-05-05 18:18:50.008  - warn: javascript.0 (1259)     at listOnTimeout (node:internal/timers:585:17)
                            2026-05-05 18:18:50.009  - info: javascript.0 (1259) script.js.common.Haus.KI.Energie.Energiebilanz1: Haus-Energie | pvRaw=0 gridRaw=212 | pv=0 import=210.33 export=0 balance=210.33 load=210.33 self=0 residual=0
                            2026-05-05 18:19:00.001  - warn: javascript.0 (1259) getState "shelly.0.SHEM-3#08F9E051D35A#1.Emeter2.Power" not found (3)
                            2026-05-05 18:19:00.004  - warn: javascript.0 (1259)     at num (script.js.common.Haus.KI.Energie.Energiebilanz1:237:15)
                            2026-05-05 18:19:00.007  - warn: javascript.0 (1259)     at calculate (script.js.common.Haus.KI.Energie.Energiebilanz1:344:35)
                            2026-05-05 18:19:00.008  - warn: javascript.0 (1259)     at Object.cycle (script.js.common.Haus.KI.Energie.Energiebilanz1:416:19)
                            2026-05-05 18:19:00.009  - warn: javascript.0 (1259)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2389:34)
                            2026-05-05 18:19:00.009  - warn: javascript.0 (1259)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                            2026-05-05 18:19:00.010  - warn: javascript.0 (1259)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                            2026-05-05 18:19:00.011  - warn: javascript.0 (1259)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                            2026-05-05 18:19:00.012  - warn: javascript.0 (1259)     at listOnTimeout (node:internal/timers:585:17)
                            2026-05-05 18:19:00.013  - info: javascript.0 (1259) script.js.common.Haus.KI.Energie.Energiebilanz1: Haus-Energie | pvRaw=0 gridRaw=216 | pv=0 import=211.67 export=0 balance=211.67 load=211.67 self=0 residual=0
                            2026-05-05 18:19:10.002  - warn: javascript.0 (1259) getState "shelly.0.SHEM-3#08F9E051D35A#1.Emeter2.Power" not found (3)
                            29.375 Objekte
                            24.247 Zustände
                            • A axel
                              ```bash
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                                       Chassis: vm 🖴
                                Virtualization: kvm
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                            NTP service: active
                                        RTC in local TZ: no
                              axel
                              HOME=/home/axel
                              iobroker
                              HOME=/home/iobroker
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           4.3G          0B        4.3G
                              Total:           21G        4.0G         16G
                                       3812 M used memory
                                      11608 M free memory
                                         80 M buffer memory
                                        780 M swap cache
                                       4095 M total swap
                                          0 M used swap
                                       4095 M free swap
                              *** FILESYSTEM ***
                              /var:
                              3.0G    /var/
                              881M    /var/lib
                              859M    /var/cache
                              823M    /var/cache/apt
                              735M    /var/log
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.7.22
                              javascript:     9.0.18
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        29379
                              States:         24304
                              #67
                              @axel sagte:
                              Immer noch falsch
                              • A axel
                                ```bash
                                Script v.2026-01-31
                                *** BASE SYSTEM ***
                                         Chassis: vm 🖴
                                  Virtualization: kvm
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 4
                                              NTP service: active
                                          RTC in local TZ: no
                                axel
                                HOME=/home/axel
                                iobroker
                                HOME=/home/iobroker
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Swap:           4.3G          0B        4.3G
                                Total:           21G        4.0G         16G
                                         3812 M used memory
                                        11608 M free memory
                                           80 M buffer memory
                                          780 M swap cache
                                         4095 M total swap
                                            0 M used swap
                                         4095 M free swap
                                *** FILESYSTEM ***
                                /var:
                                3.0G    /var/
                                881M    /var/lib
                                859M    /var/cache
                                823M    /var/cache/apt
                                735M    /var/log
                                USB-Devices by-id:
                                /usr/bin/npm            10.9.7
                                /usr/bin/npx            10.9.7
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.7.22
                                javascript:     9.0.18
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        29379
                                States:         24304
                                #68
                                @axel sagte:
                                • system.adapter.admin.0 : admin : grafenhof - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                • system.adapter.hm-rpc.0 : hm-rpc : grafenhof - enabled, port: 18701
                                • system.adapter.hm-rpc.1 : hm-rpc : grafenhof - enabled, port: 12001
                                • system.adapter.mqtt.0 : mqtt : grafenhof - enabled, port: 1883, bind: 0.0.0.0
                                • system.adapter.rest-api.0 : rest-api : grafenhof - enabled, port: 8093, bind: 0.0.0.0, run as: admin
                                • system.adapter.shelly.0 : shelly : grafenhof - enabled, port: 1884, bind: 127.0.0.1
                                • system.adapter.sonoff.0 : sonoff : grafenhof - enabled, port: 1883, bind: 0.0.0.0
                                • system.adapter.sql.0 : sql : grafenhof - enabled, port: 3306
                                • system.adapter.web.0 : web : grafenhof - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Und wie vermutet
                                2x port 1883
                                  axel
                                  #69
                                  Hab den Shelly umgestellt
                                  tcp        0      0 192.168.12.182:18701    0.0.0.0:*               LISTEN      1001       13688      1527/io.hm-rpc.0
                                  tcp        0      0 192.168.12.182:12001    0.0.0.0:*               LISTEN      1001       14661      1543/io.hm-rpc.1
                                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        9306       768/systemd-resolve
                                  tcp        0      0 192.168.12.182:2010     0.0.0.0:*               LISTEN      1001       16672      1559/io.hm-rpc.2
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9658       811/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10774      811/iobroker.js-con
                                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       30369      2204/io.shelly.0
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       26567      2056/io.sonoff.0
                                  tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          9000       1013/smbd
                                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       31446      2419/io.jarvis.0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7066       1/init
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2536       1/init
                                  tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          8999       1013/smbd
                                  tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        9308       768/systemd-resolve
                                  29.375 Objekte
                                  24.247 Zustände
                                  • A axel
                                    #70
                                    @axel sagte:
                                    Und wo ist jetzt der mqtt hin?
                                      @axel sagte:
                                      Und wie vermutet
                                      2x port 1883
                                      axel
                                      #71
                                      @Homoran Der Port 1883 ist für den Tasmota Leser zuständig. Der ist über mqtt an sonoff angebunden. darüber läuft dann die Kommunikation. Das tut auch. Der Port 1884 soll dann für den Shelly relevant sein. Der ist direkt an den Shelly-Adapter angebunden.
                                      So habe ich das Kommuniokationssystem verstanden.
                                      Ich habe eine Shelly Gen1 ersetzt. Der lief aber nicht über mqtt. Das hat auch funktioniert. Nun der Shelly Gen2, der nur noch mqtt versteht, mit dem es irgendwie nicht geht.
                                      29.375 Objekte
                                      24.247 Zustände
                                        axel
                                        #72
                                        Ist natürlich da
                                        + system.adapter.shelly.0                 : shelly                : grafenhof                                -  enabled, port: 1884, bind: 0.0.0.0
                                        29.375 Objekte
                                        24.247 Zustände
                                        • A axel
                                          Ist natürlich da
                                          #73
                                          @axel sagte:
                                          Ist natürlich da
                                          Und immer noch auf dem selben Port 1883 wie der Sonoff
