  4. Test Adapter Zendure Solarflow
2.7k Beiträge 129 Kommentatoren 1.4m Aufrufe 128 Beobachtet
  • haselchenH Offline
    haselchenH Offline
    haselchen
    #2266
    Ich hätte nicht gedacht, dass es so schwer ist nen 800 Plus zu integrieren. Habe ich mich wohl geirrt.
    Nehme ich die Auswahl Lokal MQTT Server gebe ich den 800 Plus nebst Key aus der App ein.
    Kommt leider das:
    zendure-solarflow.0	2026-03-29 18:03:31.577	error	[getZenSdkProperties] IP address is not defined for device XXX
    zendure-solarflow.0	2026-03-29 18:03:31.573	error	[onReady] Could not connect to MQTT local server!
    zendure-solarflow.0	2026-03-29 18:03:31.572	error	[LocalMqttService] local MQTT url missing!
    Es gibt bei der Auswahl kein MQTT URL Feld.
    Nehme ich die andere Anmeldemöglichkeit
    zendure-solarflow.0	2026-03-29 18:09:10.558	error	Converting circular structure to JSON --> starting at object with constructor 'Agent' | property 'sockets' -> object with constructor 'Object' | property 'app.zendure:443:::::::::::::::::::::' -> object with constructor 'Array' | ... | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'agent' closes the circle
    zendure-solarflow.0	2026-03-29 18:09:10.557	error	TypeError: Converting circular structure to JSON --> starting at object with constructor 'Agent' | property 'sockets' -> object with constructor 'Object' | property 'app.zendure:443:::::::::::::::::::::' -> object with constructor 'Array' | ... | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'agent' closes the circle at JSON.stringify (<anonymous>) at /opt/iobroker/node_modules/iobroker.zendure-solarflow/build/services/zenWebService.js:87:42 at process.processTicksAndRejections (node:internal/process/task_queues:105:5) at async ZendureSolarflow.onReady (/opt/iobroker/node_modules/iobroker.zendure-solarflow/build/main.js:117:22)
    zendure-solarflow.0	2026-03-29 18:09:10.556	error	unhandled promise rejection: Converting circular structure to JSON --> starting at object with constructor 'Agent' | property 'sockets' -> object with constructor 'Object' | property 'app.zendure:443:::::::::::::::::::::' -> object with constructor 'Array' | ... | property '_httpMessage' -> object with constructor 'ClientRequest' --- property 'agent' closes the circle
    zendure-solarflow.0	2026-03-29 18:09:10.554	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    F 1 Antwort Letzte Antwort
    • haselchenH haselchen
      Kommt leider das:
      Felli
      #2267
      @haselchen warum unbedingt mit einem lokalen MQTT Server? Gehe davon aus das der SF800 ZenSDK hat? Dann einfach diesen Weg. Also per Cloud connecten und den Haken setzen bei ZenSDK im Adapter. Dann bekommt er aus der Cloud die lokale IP und verbindet sich lokal per API. Läuft bei meinem SF1600 tadellos mit der neusten Version des Adapters.
      • F Felli
        haselchenH Offline
        haselchenH Offline
        haselchen
        #2268
        @Felli
        Komme von der Hoymiles Insel :)
        Das war etwas einfacher alles.
        Ich habs mal gemacht, wie Du gesagt hast.
        Jetzt ist der verbunden.
        Wie gesagt, erstmall alles Neuland.
        Aktuell gibt es ja auch die Möglichkeit in der App einen MQTT Server einzugeben.
        Was sind die Vor -und Nachteile dabei zu dem Adapter?
        Edit : noch eine Frage hinterher. Bei Hoymiles wars ja easy mit AhoyDTU etc. die Panels und alles weitere auszulesen. Hier lese ich immer was von Skripten und Blocklys. Listet der Zendure WR keine expliziten Werte für die Panels und die erbrachten kWh?
          @Felli
          Felli
          #2269
          @haselchen der lokale MQTT Server bringt meiner Meinung nach keinen Vorteil mehr, wenn man ZenSDK nutzt. ZenSDK redet direkt mit dem Gerät via lokaler API, MQTT ist wieder nur ein Broker der zwischen Gerät und Adapter geschaltet wird. Also eine Fehlerquelle mehr. Ich habe das zwar definiert aber im Gerät deaktiviert.
          Im Objektbaum des Adapters, gibt es einen Datenpunkt der dir zeigt, auf welchem Wege dein SF800 eingebunden ist. Sollte er ZenSDK unterstützen, müsste das nun da stehen. Falls ja, bist du lokal unterwegs.
          • F Offline
            Felli
            #2270
            Da hier ja vermutlich die meisten ioBroker/Zendure User beisammen sind, wollte ich was mit euch teilen. Habe seit knapp einer Woche einen SF1600AC+ und habe mir daher was ausgedacht, diesen über Peters Adapter zu regeln. Dazu habe ich einen eigenen kleinen Adapter gebaut, der eine Nulleinspeisung inkl. Überschussladen aus bestehender PV realisiert. Dabei wird der Datenpunkt: zendure-solarflow.0.XXX.XXX.control.setDeviceAutomationInOutLimit angesprochen.
            Da mein SF1600 beim umschalten von laden zu einspeisen klackt, habe ich mir hier auch Gedanken gemacht, wie man das Relais sinnvoll schützen kann. Dazu ist ein Tick Timer eingebaut, der über das UI eingestellt werden kann. Standard ist 3 Clicks zum einspeisen und 5 Clicks zum laden. Also bei 5 sek. Tick wären das 15 oder 25 Sekunden, in denen dann ein Schwellwert (ebenfalls einstellbar) anliegen muss, bevor er schaltet. Zusätzlich, wird noch packPower gecheckt und nur dann geschaltet, wenn dieser kleiner 10W ist. Damit sollte sichergestellt sein, dass das Relais nur ohne Last umschaltet. Vermute Zendure hat daran gedacht, wollte aber auf Nummer sicher gehen :D
            Den Entladeschluss kann man auf zwei Arten definieren. Entweder klassisch via SOC oder per minVol. Dazu scannt der Adapter alle Packs in Peters Integration nach minVol und wertet hier den kleinsten aus. Dieser wird dann auch berücksichtigt fürs Notladen, sollte mal ein Pack bei schlechtem Wetter abschmieren.
            Wenn Notladen aktiv, wird bis zu einem Exit SOC geladen (Standard 20%). Danach bleibt die Reglung in einem Recovery Modus und dessen Exit SOC ist bei 30%. Damit wollte ich unnötige Loops vermeiden. All diese Schwellwerte sind bequem zu steuern per UI und im Objektbaum unter Control, kann man mit einem Schalter die Reglung einfach ausschalten, falls man händisch was machen will per App oder was weiß ich.
            Das läuft nun seit einer Woche erstaunlich gut und stabil muss ich sagen. Werde den Adapter nicht offiziell ins Repo bringen, also müsst Ihr den wenn per Custom-Link manuell direkt via Github installieren bei Interesse. Denke für die neuen Geräte ist das eine tolle Sache und die regeln wirklich traumhaft schnell und weich die Last weg.
            @nograx falls Du Interesse an dem Werk hast und wenn es nur Teile sind, lass es mich wissen. Glaube sowas wäre eine tolle Ergänzung zu Deinem genialen Adapter, den ich seit Anfang an nutze!
            Hier der Link: https://github.com/Felliglanz/ioBroker.zendure-automation
            Viel Spaß beim probieren und gebt gerne eine Rückmeldung.
            LG
            Sven
            haselchenH S 2 Antworten Letzte Antwort
            • F Felli
              LG
              Sven
              haselchenH Offline
              haselchenH Offline
              haselchen
              #2271
              @Felli
              Ich bin jetzt laut DP im zenSDK Modus.
              Es sind viele DP mit einer roten null versehen.
              Hier 2 Beispiele.
              Regeneriert sich das noch?
              Wo würde der Konflikt liegen , wenn ich den Adapter nutze und zeitgleich MQTT in der App aktiviere?
                @Felli
                Hier 2 Beispiele.
                Felli
                #2272
                @haselchen Die "nullen " habe ich ebenfalls. Vermute die DP werden vom Gerät generell nicht genutzt oder nur aktualisiert, wenn man sie verwendet. Mit welchem Server der verbunden ist, interessiert mich im Grunde im lokalen Betrieb ja auch nicht, die anderen Nullen sind auch uninteressant. Teste die lokale API mal via http://ipdeinesSF800/properties/report
                Dann siehst du was er alles liefert in der Ausgabe. Das einfach in einem Browser Fenster im LAN ausführen.
                Einen Nachteil von aktiviertem MQTT gibt es denke ich keinen aber auch keinen Mehrwert in meinen Augen. Am Ende hat er halt mehr zu tun, er liefert dann Daten an die Cloud, deinen Broker und bedient die lokale API. Was ich nicht brauche, schalte ich ab. Teste mal meinen Automations Adapter, theoretisch sollte er mit dem SF800 auch gehen, der kann doch AC Laden oder ?? Wenn ja dann sollte das Gerät damit das gleiche tun wie der SF1600 nur mit weniger Leistung.
                • F Felli
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #2273
                  @Felli
                  @nograx
                  Ich habe im Sekundentakt diese Nachrichten im Log
                  zendure-solarflow.0	2026-03-30 15:08:52.437	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:51.406	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:51.368	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:50.367	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:49.335	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:49.295	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:48.294	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:47.264	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:47.224	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:46.222	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:45.192	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:45.150	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:44.149	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:43.114	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:43.068	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:42.066	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:41.035	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:40.990	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:39.988	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:38.959	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:38.919	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:37.917	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:36.884	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                  zendure-solarflow.0	2026-03-30 15:08:36.837	info	[onReconnected] Reconnected to MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:35.835	info	[onDisconnected] Disconnected from MQTT! URL: mqtt://mqtteu.zen-iot.com:1883
                  zendure-solarflow.0	2026-03-30 15:08:34.802	info	[onConnected] Connected with MQTT! URL: mqtt://mqtteu.zen-iot.com:1883, Client ID:
                    @Felli
                    @nograx
                    Felli
                    schrieb am zuletzt editiert von Felli
                    #2274
                    @haselchen
                    Lösch doch mal den gesamten Adapter. Nicht das da noch was von dem ganzen einstellen übrig ist. Sollte nicht sein aber so ein Bild habe ich noch nie gesehen. Er verbindet und trennt ja im Sekundentakt die Cloud. Hast Du ggf. den Haken mit Cloudweiterleitung aktiviert? Nicht das daraus dieser Fehler kommt. Ich habe nur ZenSDK aktiv und keine Fehler. Vielleicht kann Peter da mehr zu sagen ...
                    Also nach löschen neu aufsetzen natürlich :D
                    • F Felli
                      @haselchen
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #2275
                      @Felli
                      Hast Du Dich im Adapter mit Key oder Lokalem MQTT angemeldet?
                      • F Offline
                        Felli
                        #2276
                        Nur mit Cloud-Key und dann im Adapter die ZenSDK Option aktiviert. Dann läuft er ja lokal. Ich habe das so verstanden, dass die Cloud dann nur initial genutzt wird um eine lokale Verbindung zu ermöglichen. @nograx kann das sicherlich näher erklären.
                        • F Felli
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #2277
                          @Felli
                          Meldungen im Log bleiben.
                          Ich hab den Adapter mal pausiert und das MQTT in der App aktiviert.
                          Die DP sind die Gleichen.
                          Wenn man die per Blockly schalten/steuern kann, bräuchte ich den Adapter ja nicht.
                          • nograxN Online
                            nograxN Online
                            nograx
                            schrieb am zuletzt editiert von nograx
                            #2278
                            Reconnect im Sekundentakt tritt auf wenn man mehrere Instanzen oder parallel z.B. Home Assistant noch laufen hat.
                            MQTT was man in der App aktivieren kann ist meiner Erfahrung nach sehr langsam und die Steuerung darüber habe ich bisher nicht ans laufen bekommen. Gibt aktuell auch keine Doku darüber wie das Payload aussehen muss.
                            • nograxN nograx
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #2279
                              @nograx
                              Kaum macht man es richtig :)
                              Das war der entscheidende Hinweis.
                              Bevor ich 114 Seite durchblättere, mein Projekt soll sein,
                              wenn die HauptPVBatterie bei 30% ist, soll die Solarflow aktiviert werden und ins Haus speisen.
                              Nun die Frage, aus Deinem Wissen raus, existiert dazu schon ein Skript oder Blockly?
                              Mein innerer Monk möchte ohne kWh Bezug durch die Nacht kommen.
                              Die HauptPVBatterie und dann die ZendureBatterie sollen im Zusammenspiel solange "halten" bis wieder morgens genug Sonne scheint.
                              @felli fürs Brainstorming :)
                              Edit: noch ein ganz wichtiger Punkt. Wieso wird der aktuelle PV Ertrag nicht abgebildet?
                              Das ist doch das A und O bei ner PV Anlage.
                              Ich meine, dieser DP wird auch nicht per MQTT per App mitgeschickt.
                              Krieg ich den irgendwie aufbereitet?
                              Der Adapter zeigt völlig wirre Kalkulationen an.
                              L 1 Antwort Letzte Antwort
                                @nograx
                                L Online
                                L Online
                                lesiflo
                                #2280
                                @haselchen sagte in Test Adapter Zendure Solarflow:
                                Lass dir das doch von einer KI erstellen. Ich erstelle fast alles nur noch mit ChatGPT oder Gemini. Warum den Kopf zerbrechen wenn's auch einfach geht.
                                • L lesiflo
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #2281
                                  @lesiflo
                                  Weil ich mir mit den Jungs&Mädels schon den Kopf zerbrochen habe :)
                                  Da kommt nur Blödsinn raus. Manchmal erst im 3. oder 4. Nachfragen kommt als Antwort: Ja, da hast Du recht, die Anleitung ist veraltet.....
                                  • F Felli
                                    LG
                                    Sven
                                    shark
                                    #2282
                                    @Felli sagte in Test Adapter Zendure Solarflow:
                                    LG
                                    Sven
                                    @felli
                                    Danke erstmal für deinen Adapter
                                    Heute mal installiert.
                                    Ich haben einen Solarflow 800 Pro.
                                    Läuft erstmal im Entlademodus, mal schauen wie der Lademodus läuft.
                                    Ich habe den Solarflow zur Zeit als reinen AC Speicher laufen, muß ich da noch irgendwas anpassen.
                                    MQTT Steuerung ist auch in der Zendure App nicht aktiviert, oder?
                                    Also funktioniert die Steuerung doch über ZenSDK ist das die schnellste Regelung?
                                    Gruß Frank
                                    • S shark
                                      LG
                                      Sven
                                      @felli
                                      Gruß Frank
                                      Felli
                                      #2283
                                      @shark
                                      Toll das es auch mit dem SF800 geht! Mein Adapter regelt nur das System, wie Du Peters Adapter an Dein System anbindest, ist dem dabei völlig egal. Lokale Anbindung ist mit 100%iger Sicherheit das sinnigste. Dabei empfinde ich die API die sie uns mittlerweile geben als am besten.
                                      Anpassen musst du an den Einstellungen nur die maximale Leistung die rein oder raus gehen soll. Selbst wenn du es auf den Default Werten lässt, wird nichts passieren, da der SF800 einfach 800 nimmt wenn du ihm was höheres gibst. Ansonsten hoffe ich das die Config intuitiv ist, ich habe es so empfunden. Danke fürs probieren und wenn was klemmt, lass es mich wissen.
                                      LG
                                      Sven
                                      Nachtrag: Da der SF1600AC+ ein reiner AC Speicher ist, ist am am Ende genau wie Deiner bzw wie du ihn nutzt. Nur eine Nummer kleiner 😁
                                        shark
                                        #2284
                                        @felli
                                        ich habe dein Adapter bei Ziel Netzleistung auf 40W gestellt, das hat gestern Abend beim reinen entladen gut funktioniert.
                                        Heute beim laden/entladen ist meine Netzleistung ab und zu vom Netzeinspeisung in den Netzbezug gesprungen, obwohl das nicht immer nötig war.
                                        Wäre es vielleicht besser für den Punkt Ziel Netzleistung zwei Werte zu haben z.B. beim entladen auf z.B. 40W und laden auf -40W zu stellen, dann hat man eine Art Hysterese.
                                          bob der 1.
                                          #2285
                                          Kurzes Feeback zum neuen AC 2400+.
                                          Also einrichten des Adapters war super simpwl wie das Gerät mal da war.Ich weiss nun nicht ob ich alle Werte sehe ,die auch ältere Produkte bringen,aber ich gehe davon aus.
                                          Aktuell steuert der EcoTracker das ganze
                                          ..leider kann ich meinen SMA Smartmeter nicht direkt einbinden.Der große BYD - Speicher und der Zendure arbeiten aber glücklicherweise extrem gut miteinander....so das beide Spwicher paralell entladen werden.
                                          Laden klar,zuerst der große dann der AC....läuft ja über die Überschuß Regel.
