  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.4k Aufrufe 8 Beobachtet
  • S SpeedyBlade
    copy-paste...;)
    hab gerade auf 8.20 upgedated von 8.02
    FRITZ!OS: 8.20
    hat leider auch keine besserung gebracht
    15:23:30.416INFOguiBackup gestartet ...
    15:23:40.536DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
    15:23:40.589DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
    15:23:40.592DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
    15:23:40.648DEBUGmountError: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups
    mount error(2): No such file or directory
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    15:23:44.769DEBUGiobrokerhost.RaspberryPi4 2376 objects saved
    15:23:45.068DEBUGiobrokerhost.RaspberryPi4 1727 states saved
    15:23:45.084DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
    host.RaspberryPi4 "config.json" is valid
    15:23:45.097DEBUGiobrokerhost.RaspberryPi4 "objects.jsonl" exists
    host.RaspberryPi4 "states.jsonl" exists
    15:23:45.490DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
    15:23:45.548DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
    15:23:46.265DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-15_23_41_backupiobroker.tar.gz
    15:23:46.272DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
    15:23:47.308DEBUGiobrokerdone
    15:23:49.429DEBUGnoderedCreated nodered tmp directory
    15:23:49.547DEBUGnoderedNode-Red tmp copy finish
    15:23:49.669DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-15_23_49_backupiobroker.tar.gz
    15:23:49.684DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
    15:23:49.690DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
    15:23:49.692DEBUGnoderedfound node-red database: node-red.0
    15:23:49.730DEBUGnodereddone
    15:23:50.283DEBUGcifsused copy path: /fritz.nas/nas#/files/iobroker_backup
    15:23:50.286DEBUGcifsdone
    15:23:50.891ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
    15:23:50.931DEBUGcleandone
    15:23:51.053DEBUGhistoryHTMLnew history html values created
    15:23:51.066DEBUGhistoryHTMLdone
    15:23:51.231DEBUGhistoryJSONnew history json values created
    15:23:51.274DEBUGhistoryJSONdone
    #176
    @SpeedyBlade sagte in Iobroker backitup error.. Wo liegt das problem:
    Ist falsch. Der Pfad muss
    //192.168.1.1/fritz.nas/iobroker_backup
    lauten.
      lauten.
      HomoranH Offline
      HomoranH Offline
      #177
      @Thomas-Braun sagte in Iobroker backitup error.. Wo liegt das problem:
      der wird aber doch zusammengesetzt!
      nach den Informationen von @speedyblade hier: https://forum.iobroker.net/post/1329835
      müsste es richtig sein.
      existiert noch ein separater mount?
      Thomas BraunT S 2 Antworten Letzte Antwort
        #178
        @Homoran sagte in Iobroker backitup error.. Wo liegt das problem:
        Jein. Aber nicht so.
        //192.168.178.1/fritz.nas/iobroker /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
        Der FritzNas-interne Bereich wird mit //192.168.178.1/fritz.nas/iobroker definiert. Hier ist noch ein Verzeichnis namens 'iobroker' angelegt, wo die Backups dann abgelegt werden.
          SpeedyBlade
          #179
          egal wie ich es schreibe, es kommt immer der gleiche Fehler
            SpeedyBlade
            #180
            es wird noch mit einer Gegensprechanlage, aber dafür nutze ich einen anderen User, auf ein anderes Verzeichnis auf der Fritzbox zugegriffen.
              SpeedyBlade
              #181
              @Thomas-Braun
              der Ordner, wo die backups abgelegt werden sollen heißt "iobroker_backup"
              • S SpeedyBlade
                HomoranH Offline
                HomoranH Offline
                #182
                der Fehler ist nicht wo du die roten Linien zusammenlaufen lässt, sondern in der 2.und 3. Zeile
                • S SpeedyBlade
                  @Thomas-Braun
                  #183
                  @SpeedyBlade
                  Hier übrigens ein Screenshot meiner alten Einstellungen (bevor es die Experten-Option gab):
                  https://user-images.githubusercontent.com/39792461/224364096-c39691b6-0d4d-41fd-b627-00002ea2695e.png
                    #184
                    Und die Zeilen sind abgeschnitten. Man sieht die Pfade nicht.
                      HomoranH Offline
                      HomoranH Offline
                      #185
                      so ist es!
                      ich bin vereinfacht davon ausgegangen
                      15
                      weil es ja hiess, er bliebe gleich
                        @SpeedyBlade
                        SpeedyBlade
                        #186
                        @Thomas-Braun
                        kann es sein, dass es einen Fehler verursacht, weil ich den internen Speicher der Fritzbox nutze und nicht eine USB Festplatte?
                        • S SpeedyBlade
                          @Thomas-Braun
                          HomoranH Offline
                          HomoranH Offline
                          #187
                          @SpeedyBlade nöö, außerdem hat Thomas es ja auch intern gemacht
                          • S SpeedyBlade
                            @Thomas-Braun
                            #188
                            Nein. Mein Backup in Posting #171 ging auf den internen Speicher.
                              SpeedyBlade
                              schrieb am zuletzt editiert von SpeedyBlade
                              #189
                              @Thomas-Braun
                              und welchen pfad hast du dort im iobroker-backup hinterlegt?
                              kannst den link mal sharen bitte
                              • S SpeedyBlade
                                @Thomas-Braun
                                HomoranH Offline
                                HomoranH Offline
                                #190
                                wie geschrieben
                                Das nutzt dir nix, ich verwende die Experten-Optionen an der Stelle.
                                  SpeedyBlade
                                  #191
                                  Die Dinge sind korrekt hinterlegt, bei anderen systemen funktioniert das einwandfrei, nur nicht bei dem backup von iobroker
                                  //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups
                                  sucht der hier lokal nach dem ordrner
                                  • S SpeedyBlade
                                    HomoranH Offline
                                    HomoranH Offline
                                    #192
                                    heisst was?
                                    wer sucht?
                                    nach welchem Ordner?
                                    Der mount wird lokal in /opt/iobroker/backups gesetzt und zeigt extern auf die Fritzbox.
                                    Wohin genau wird wie gezeigt in Zeile 2 des logs angezeigt.
                                    Daher diese Zeile bitte immer vollständig und als Text in code-tags zeigen
                                    • S SpeedyBlade
                                      @Thomas-Braun
                                      #193
                                      Ich habe einen Eintrag in der /etc/fstab und verwende daher die Experten-Optionen im Adapter. Die fstab sieht aber so aus:
                                      echad@chet:~ $ cat /etc/fstab
                                      proc            /proc           proc    defaults          0       0
                                      PARTUUID=68a5cb8b-01  /boot/firmware  vfat    defaults          0       2
                                      PARTUUID=68a5cb8b-02  /               ext4    defaults,noatime  0       1
                                      # //192.168.178.1/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                                      # a swapfile is not a swap partition, no line here
                                      #   use  dphys-swapfile swap[on|off]  for that
                                      echad@chet:~ $
                                      Die erste Zeile mit der Freigabe (hier auskommentiert) ist für die USB-Festplatte, die zweite Zeile hängt den internen Speicher der FritzBox auf /opt/iobroker/backups ein..
                                      • S SpeedyBlade
                                        #194
                                        @SpeedyBlade
                                        Ich hab es jetzt mal auf Standard umgestellt.
                                        17:35:37.093 INFO gui Backup gestartet ...
                                        17:35:37.210 DEBUG mount mount activ... umount is started before mount!!
                                        17:35:37.250 DEBUG mount umount successfully completed
                                        17:35:47.304 DEBUG mount mount successfully completed
                                        17:35:47.307 DEBUG mount done
                                        17:35:55.188 DEBUG iobroker host.chet 10514 objects saved
                                        17:35:56.046 DEBUG iobroker host.chet 8566 states saved
                                        17:35:56.064 DEBUG iobroker host.chet Validating backup ...
                                        17:35:56.070 DEBUG iobroker host.chet "config.json" is valid
                                        17:35:56.115 DEBUG iobroker host.chet "objects.jsonl" exists host.chet "states.jsonl" exists
                                        17:35:57.106 DEBUG iobroker host.chet JSONL lines are valid
                                        17:35:57.155 DEBUG iobroker host.chet The backup is valid!
                                        17:35:58.722 DEBUG iobroker Backup created: /opt/iobroker/backups/iobroker_2026_03_15-17_35_47_chet_backupiobroker.tar.gz
                                        17:35:58.727 DEBUG iobroker This backup can only be restored with js-controller version 7.0 or higher
                                        17:35:59.806 DEBUG iobroker done
                                        17:36:00.747 DEBUG historyDB compress from historyDB started ...
                                        17:36:10.735 DEBUG historyDB Packed 18MB so far...
                                        17:36:13.418 DEBUG historyDB done
                                        17:36:13.724 DEBUG zigbee done
                                        17:36:14.462 DEBUG javascripts Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                        17:36:16.077 DEBUG javascripts found Script: awtrix
                                        17:36:16.385 DEBUG javascripts found Script: frostwarner
                                        17:36:16.496 DEBUG javascripts found Script: lautstaerke_bad
                                        17:36:16.609 DEBUG javascripts found Script: lautstaerke_kueche
                                        17:36:16.775 DEBUG javascripts found Script: nuki_ext_wohnungstuer_entriegelt
                                        17:36:16.929 DEBUG javascripts found Script: paketlieferungen
                                        17:36:17.067 DEBUG javascripts found Script: pakettruhe_offen
                                        17:36:17.238 DEBUG javascripts found Script: ps4_waker
                                        17:36:17.362 DEBUG javascripts found Script: sonnenaufgang
                                        17:36:17.614 DEBUG javascripts found Script: sonnenuntergang
                                        17:36:17.668 DEBUG javascripts found Script: speedtest
                                        17:36:17.920 DEBUG javascripts found Script: telefon_klingelt
                                        17:36:17.969 DEBUG javascripts found Script: treppenhaus_licht_ble
                                        17:36:18.229 DEBUG javascripts found Script: treppenhaus_licht_hub
                                        17:36:18.274 DEBUG javascripts found Script: tuerklingel_laeutet
                                        17:36:18.432 DEBUG javascripts found Script: usv_warner
                                        17:36:18.574 DEBUG javascripts found Script: wohnung_verlassen
                                        17:36:18.740 DEBUG javascripts found Script: zuhause_verlassen
                                        17:36:18.875 DEBUG javascripts found Script: nuki_extended_restart_fix
                                        17:36:19.028 DEBUG javascripts found Script: solix2mqtt
                                        17:36:19.251 DEBUG javascripts found Script: stromzaehler2
                                        17:36:19.457 DEBUG javascripts Backup created: /opt/iobroker/backups/javascripts_2026_03_15-17_36_14_chet_backupiobroker.tar.gz
                                        17:36:19.461 DEBUG javascripts done
                                        17:36:20.378 DEBUG cifs done
                                        17:36:22.018 DEBUG googledrive Google Drive: Copy iobroker_2026_03_15-17_35_47_chet_backupiobroker.tar.gz...
                                        17:36:25.704 DEBUG googledrive Google Drive: Copy historyDB_2026_03_15-17_36_00_chet_backupiobroker.tar.gz...
                                        17:36:32.154 DEBUG googledrive Google Drive: Copy zigbee.0_2026_03_15-17_36_13_chet_backupiobroker.tar.gz...
                                        17:36:34.551 DEBUG googledrive Google Drive: Copy javascripts_2026_03_15-17_36_14_chet_backupiobroker.tar.gz...
                                        17:36:36.359 DEBUG googledrive done
                                        17:36:36.538 WARN clean No older backup files are deleted, because this backup was started manually
                                        17:36:36.559 DEBUG clean done
                                        17:36:36.676 DEBUG historyHTML new history html values created
                                        17:36:36.768 DEBUG historyHTML done
                                        17:36:36.968 DEBUG historyJSON done
                                        17:36:37.110 DEBUG umount mount active, umount is started ...
                                        17:36:42.292 DEBUG umount umount successfully completed
                                        17:36:42.295 DEBUG umount done
                                        17:36:48.441 DEBUG whatsapp done
                                        17:36:49.670 DEBUG notification done
                                        17:36:49.717 INFO gui Das Backup wurde erfolgreich erstellt!
                                          SpeedyBlade
                                          #195
                                          neuen user in der fritzbox angelegt, mit neuem passwort, alles neu hinterlegt im iobroker
                                          Leider alles ohne Erfolg .
                                          Gibt es eine Möglichkeit über die Konsole das ganze mal manuell zu sichern auf die Fritzbox?
