  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.4k Aufrufe 8 Beobachtet
    @SpeedyBlade
    Klar:
    Liegt jetzt im internen Bereich des FritzNas.
    Was läuft da bei dir? Also welche FritzBox mit welchem FritzOS?
    SpeedyBlade
    #173
    @Thomas-Braun
    FRITZ!Box 5590 Fiber
    FRITZ!OS: 8.02
    Thomas BraunT S 2 Antworten Letzte Antwort
    • S SpeedyBlade
      @Thomas-Braun
      FRITZ!OS: 8.02
      #174
      @SpeedyBlade sagte in Iobroker backitup error.. Wo liegt das problem:
      FRITZ!OS: 8.02
      Typo? 8.20 ist aktuell.
      • S SpeedyBlade
        @Thomas-Braun
        FRITZ!OS: 8.02
        SpeedyBlade
        #175
        copy-paste...;)
        hab gerade auf 8.20 upgedated von 8.02
        FRITZ!OS: 8.20
        hat leider auch keine besserung gebracht
        15:23:30.416INFOguiBackup gestartet ...
        15:23:40.536DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
        15:23:40.589DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
        15:23:40.592DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
        15:23:40.648DEBUGmountError: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups
        mount error(2): No such file or directory
        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
        15:23:44.769DEBUGiobrokerhost.RaspberryPi4 2376 objects saved
        15:23:45.068DEBUGiobrokerhost.RaspberryPi4 1727 states saved
        15:23:45.084DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
        host.RaspberryPi4 "config.json" is valid
        15:23:45.097DEBUGiobrokerhost.RaspberryPi4 "objects.jsonl" exists
        host.RaspberryPi4 "states.jsonl" exists
        15:23:45.490DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
        15:23:45.548DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
        15:23:46.265DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-15_23_41_backupiobroker.tar.gz
        15:23:46.272DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
        15:23:47.308DEBUGiobrokerdone
        15:23:49.429DEBUGnoderedCreated nodered tmp directory
        15:23:49.547DEBUGnoderedNode-Red tmp copy finish
        15:23:49.669DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-15_23_49_backupiobroker.tar.gz
        15:23:49.684DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
        15:23:49.690DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
        15:23:49.692DEBUGnoderedfound node-red database: node-red.0
        15:23:49.730DEBUGnodereddone
        15:23:50.283DEBUGcifsused copy path: /fritz.nas/nas#/files/iobroker_backup
        15:23:50.286DEBUGcifsdone
        15:23:50.891ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
        15:23:50.931DEBUGcleandone
        15:23:51.053DEBUGhistoryHTMLnew history html values created
        15:23:51.066DEBUGhistoryHTMLdone
        15:23:51.231DEBUGhistoryJSONnew history json values created
        15:23:51.274DEBUGhistoryJSONdone
        • S SpeedyBlade
          copy-paste...;)
          FRITZ!OS: 8.20
          #176
          Ist falsch. Der Pfad muss
          //192.168.1.1/fritz.nas/iobroker_backup
          lauten.
            lauten.
            HomoranH Offline
            HomoranH Offline
            #177
            @Thomas-Braun sagte in Iobroker backitup error.. Wo liegt das problem:
            der wird aber doch zusammengesetzt!
            nach den Informationen von @speedyblade hier: https://forum.iobroker.net/post/1329835
            müsste es richtig sein.
            existiert noch ein separater mount?
              #178
              @Homoran sagte in Iobroker backitup error.. Wo liegt das problem:
              Jein. Aber nicht so.
              //192.168.178.1/fritz.nas/iobroker /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
              Der FritzNas-interne Bereich wird mit //192.168.178.1/fritz.nas/iobroker definiert. Hier ist noch ein Verzeichnis namens 'iobroker' angelegt, wo die Backups dann abgelegt werden.
                SpeedyBlade
                #179
                egal wie ich es schreibe, es kommt immer der gleiche Fehler
                  SpeedyBlade
                  #180
                  es wird noch mit einer Gegensprechanlage, aber dafür nutze ich einen anderen User, auf ein anderes Verzeichnis auf der Fritzbox zugegriffen.
                    SpeedyBlade
                    #181
                    @Thomas-Braun
                    der Ordner, wo die backups abgelegt werden sollen heißt "iobroker_backup"
                    • S SpeedyBlade
                      HomoranH Offline
                      HomoranH Offline
                      #182
                      der Fehler ist nicht wo du die roten Linien zusammenlaufen lässt, sondern in der 2.und 3. Zeile
                      • S SpeedyBlade
                        @Thomas-Braun
                        #183
                        @SpeedyBlade
                        Hier übrigens ein Screenshot meiner alten Einstellungen (bevor es die Experten-Option gab):
                        https://user-images.githubusercontent.com/39792461/224364096-c39691b6-0d4d-41fd-b627-00002ea2695e.png
                          #184
                          Und die Zeilen sind abgeschnitten. Man sieht die Pfade nicht.
                            HomoranH Offline
                            HomoranH Offline
                            #185
                            so ist es!
                            ich bin vereinfacht davon ausgegangen
                            15
                            weil es ja hiess, er bliebe gleich
                              @SpeedyBlade
                              SpeedyBlade
                              #186
                              @Thomas-Braun
                              kann es sein, dass es einen Fehler verursacht, weil ich den internen Speicher der Fritzbox nutze und nicht eine USB Festplatte?
                              • S SpeedyBlade
                                @Thomas-Braun
                                HomoranH Offline
                                HomoranH Offline
                                #187
                                @SpeedyBlade nöö, außerdem hat Thomas es ja auch intern gemacht
                                • S SpeedyBlade
                                  @Thomas-Braun
                                  #188
                                  Nein. Mein Backup in Posting #171 ging auf den internen Speicher.
                                    SpeedyBlade
                                    schrieb am zuletzt editiert von SpeedyBlade
                                    #189
                                    @Thomas-Braun
                                    und welchen pfad hast du dort im iobroker-backup hinterlegt?
                                    kannst den link mal sharen bitte
                                    • S SpeedyBlade
                                      @Thomas-Braun
                                      HomoranH Offline
                                      HomoranH Offline
                                      #190
                                      wie geschrieben
                                      Das nutzt dir nix, ich verwende die Experten-Optionen an der Stelle.
                                        SpeedyBlade
                                        #191
                                        Die Dinge sind korrekt hinterlegt, bei anderen systemen funktioniert das einwandfrei, nur nicht bei dem backup von iobroker
                                        //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups
                                        sucht der hier lokal nach dem ordrner
                                        • S SpeedyBlade
                                          HomoranH Offline
                                          HomoranH Offline
                                          #192
                                          heisst was?
                                          wer sucht?
                                          nach welchem Ordner?
                                          Der mount wird lokal in /opt/iobroker/backups gesetzt und zeigt extern auf die Fritzbox.
                                          Wohin genau wird wie gezeigt in Zeile 2 des logs angezeigt.
                                          Daher diese Zeile bitte immer vollständig und als Text in code-tags zeigen
