  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.4k Aufrufe 8 Beobachtet
  • S SpeedyBlade
    hier der screenshot von beiden systemen
    #163
    @SpeedyBlade sagte in Iobroker backitup error.. Wo liegt das problem:
    wo steht da der Freigabename der Fritzbox?
    ich sehe nur das Verzeichnis
      SpeedyBlade
      #164
      Du musst also als root mounten...=> habe ich gemacht, jedoch bleibt die Fehlermeldung
      hier steht alles, von beiden Systemen
      https://forum.iobroker.net/post/1329832
      14:08:47.142INFOguiBackup gestartet ...
      14:08:57.287DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups"
      14:08:57.340DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
      14:08:57.345DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups"
      14:08:57.411DEBUGmountError: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups
      mount error(2): No such file or directory
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      14:09:01.738DEBUGiobrokerhost.RaspberryPi4 2376 objects saved
      14:09:02.028DEBUGiobrokerhost.RaspberryPi4 1727 states saved
      14:09:02.034DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
      14:09:02.040DEBUGiobrokerhost.RaspberryPi4 "config.json" is valid
      14:09:02.046DEBUGiobrokerhost.RaspberryPi4 "objects.jsonl" exists
      host.RaspberryPi4 "states.jsonl" exists
      14:09:02.466DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
      14:09:02.490DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
      14:09:03.243DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-14_08_57_backupiobroker.tar.gz
      14:09:03.252DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
      14:09:04.294DEBUGiobrokerdone
      14:09:06.434DEBUGnoderedCreated nodered tmp directory
      14:09:06.543DEBUGnoderedNode-Red tmp copy finish
      14:09:06.648DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-14_09_06_backupiobroker.tar.gz
      14:09:06.663DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
      14:09:06.668DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
      14:09:06.709DEBUGnoderedfound node-red database: node-red.0
      14:09:06.711DEBUGnodereddone
      14:09:07.262DEBUGcifsused copy path: /fritz.nas/iobroker_backup
      14:09:07.264DEBUGcifsdone
      14:09:07.872ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      14:09:07.874DEBUGcleandone
      14:09:08.033DEBUGhistoryHTMLnew history html values created
      14:09:08.126DEBUGhistoryHTMLdone
      14:09:08.296DEBUGhistoryJSONnew history json values created
      14:09:08.337DEBUGhistoryJSONdone
      • S SpeedyBlade
        #165
        Da muss was falsch sein. Ist die IP richtig? Üblicherweise ist 192.168.178.1 die IP einer FritzBox. Jedenfalls, wenn man das nicht bewusst umstellt.
          SpeedyBlade
          #166
          die IP ist richtig von der fritzbox...192.168.1.1 => wurde bewusst geändert ;)
            SpeedyBlade
            #167
            das macht mich ein wenig stutzig
            • malorossM Offline
              malorossM Offline
              maloross
              #168
              Ich schreib mal ganz naiv: müsste der Pfad nicht mit "/" beginnen?
              Denn so sieht das bei mir aus:
              Auch Frauen können sich für Technik begeistern! ;)
              Equipment:
              diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
              • S SpeedyBlade
                #169
                @SpeedyBlade
                Ganz normal:
                  @SpeedyBlade
                  Ganz normal:
                  SpeedyBlade
                  schrieb am zuletzt editiert von SpeedyBlade
                  #170
                  @Thomas-Braun
                  kannst du das mit backup vom iobroker testen?
                  Und kannst mal deine Einstellungen im backup-iobroker senden sharen bitte.
                  • S SpeedyBlade
                    @Thomas-Braun
                    #171
                    @SpeedyBlade
                    Klar:
                    Liegt jetzt im internen Bereich des FritzNas.
                    Was läuft da bei dir? Also welche FritzBox mit welchem FritzOS?
                    • S SpeedyBlade
                      @Thomas-Braun
                      #172
                      Das nutzt dir nix, ich verwende die Experten-Optionen an der Stelle.
                        @SpeedyBlade
                        Klar:
                        SpeedyBlade
                        #173
                        @Thomas-Braun
                        FRITZ!Box 5590 Fiber
                        FRITZ!OS: 8.02
                        Thomas BraunT S 2 Antworten Letzte Antwort
                        • S SpeedyBlade
                          @Thomas-Braun
                          FRITZ!OS: 8.02
                          #174
                          FRITZ!OS: 8.02
                          Typo? 8.20 ist aktuell.
                          • S SpeedyBlade
                            @Thomas-Braun
                            FRITZ!OS: 8.02
                            SpeedyBlade
                            #175
                            copy-paste...;)
                            hab gerade auf 8.20 upgedated von 8.02
                            FRITZ!OS: 8.20
                            hat leider auch keine besserung gebracht
                            15:23:30.416INFOguiBackup gestartet ...
                            15:23:40.536DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
                            15:23:40.589DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
                            15:23:40.592DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
                            15:23:40.648DEBUGmountError: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups
                            15:23:44.769DEBUGiobrokerhost.RaspberryPi4 2376 objects saved
                            15:23:45.068DEBUGiobrokerhost.RaspberryPi4 1727 states saved
                            15:23:45.084DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
                            15:23:45.097DEBUGiobrokerhost.RaspberryPi4 "objects.jsonl" exists
                            15:23:45.490DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
                            15:23:45.548DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
                            15:23:46.265DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-15_23_41_backupiobroker.tar.gz
                            15:23:46.272DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                            15:23:47.308DEBUGiobrokerdone
                            15:23:49.429DEBUGnoderedCreated nodered tmp directory
                            15:23:49.547DEBUGnoderedNode-Red tmp copy finish
                            15:23:49.669DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-15_23_49_backupiobroker.tar.gz
                            15:23:49.684DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
                            15:23:49.690DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
                            15:23:49.692DEBUGnoderedfound node-red database: node-red.0
                            15:23:49.730DEBUGnodereddone
                            15:23:50.283DEBUGcifsused copy path: /fritz.nas/nas#/files/iobroker_backup
                            15:23:50.286DEBUGcifsdone
                            15:23:50.891ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                            15:23:50.931DEBUGcleandone
                            15:23:51.053DEBUGhistoryHTMLnew history html values created
                            15:23:51.066DEBUGhistoryHTMLdone
                            15:23:51.231DEBUGhistoryJSONnew history json values created
                            15:23:51.274DEBUGhistoryJSONdone
                            • S SpeedyBlade
                              copy-paste...;)
                              FRITZ!OS: 8.20
                              #176
                              Ist falsch. Der Pfad muss
                              lauten.
                                lauten.
                                #177
                                @Thomas-Braun sagte in Iobroker backitup error.. Wo liegt das problem:
                                der wird aber doch zusammengesetzt!
                                nach den Informationen von @speedyblade hier: https://forum.iobroker.net/post/1329835
                                müsste es richtig sein.
                                existiert noch ein separater mount?
                                  #178
                                  @Homoran sagte in Iobroker backitup error.. Wo liegt das problem:
                                  Jein. Aber nicht so.
                                  //192.168.178.1/fritz.nas/iobroker /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                                  Der FritzNas-interne Bereich wird mit //192.168.178.1/fritz.nas/iobroker definiert. Hier ist noch ein Verzeichnis namens 'iobroker' angelegt, wo die Backups dann abgelegt werden.
                                    SpeedyBlade
                                    #179
                                    egal wie ich es schreibe, es kommt immer der gleiche Fehler
                                      SpeedyBlade
                                      #180
                                      es wird noch mit einer Gegensprechanlage, aber dafür nutze ich einen anderen User, auf ein anderes Verzeichnis auf der Fritzbox zugegriffen.
                                        SpeedyBlade
                                        #181
                                        @Thomas-Braun
                                        der Ordner, wo die backups abgelegt werden sollen heißt "iobroker_backup"
                                        • S SpeedyBlade
                                          #182
                                          der Fehler ist nicht wo du die roten Linien zusammenlaufen lässt, sondern in der 2.und 3. Zeile
