  4. Iobroker backitup error.. Wo liegt das problem
    6.4k
283 Beiträge 14 Kommentatoren 39.4k Aufrufe 8 Beobachtet
    SpeedyBlade
    #164
    Du musst also als root mounten...=> habe ich gemacht, jedoch bleibt die Fehlermeldung
    hier steht alles, von beiden Systemen
    https://forum.iobroker.net/post/1329832
    14:08:47.142INFOguiBackup gestartet ...
    14:08:57.287DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups"
    14:08:57.340DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
    14:08:57.345DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups"
    14:08:57.411DEBUGmountError: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/iobroker_backup /opt/iobroker/backups
    mount error(2): No such file or directory
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    14:09:01.738DEBUGiobrokerhost.RaspberryPi4 2376 objects saved
    14:09:02.028DEBUGiobrokerhost.RaspberryPi4 1727 states saved
    14:09:02.034DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
    14:09:02.040DEBUGiobrokerhost.RaspberryPi4 "config.json" is valid
    14:09:02.046DEBUGiobrokerhost.RaspberryPi4 "objects.jsonl" exists
    host.RaspberryPi4 "states.jsonl" exists
    14:09:02.466DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
    14:09:02.490DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
    14:09:03.243DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-14_08_57_backupiobroker.tar.gz
    14:09:03.252DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
    14:09:04.294DEBUGiobrokerdone
    14:09:06.434DEBUGnoderedCreated nodered tmp directory
    14:09:06.543DEBUGnoderedNode-Red tmp copy finish
    14:09:06.648DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-14_09_06_backupiobroker.tar.gz
    14:09:06.663DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
    14:09:06.668DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
    14:09:06.709DEBUGnoderedfound node-red database: node-red.0
    14:09:06.711DEBUGnodereddone
    14:09:07.262DEBUGcifsused copy path: /fritz.nas/iobroker_backup
    14:09:07.264DEBUGcifsdone
    14:09:07.872ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
    14:09:07.874DEBUGcleandone
    14:09:08.033DEBUGhistoryHTMLnew history html values created
    14:09:08.126DEBUGhistoryHTMLdone
    14:09:08.296DEBUGhistoryJSONnew history json values created
    14:09:08.337DEBUGhistoryJSONdone
    • S SpeedyBlade
      #165
      @SpeedyBlade sagte in Iobroker backitup error.. Wo liegt das problem:
      Da muss was falsch sein. Ist die IP richtig? Üblicherweise ist 192.168.178.1 die IP einer FritzBox. Jedenfalls, wenn man das nicht bewusst umstellt.
        SpeedyBlade
        #166
        die IP ist richtig von der fritzbox...192.168.1.1 => wurde bewusst geändert ;)
          SpeedyBlade
          #167
          das macht mich ein wenig stutzig
          • malorossM Offline
            malorossM Offline
            maloross
            #168
            Ich schreib mal ganz naiv: müsste der Pfad nicht mit "/" beginnen?
            Denn so sieht das bei mir aus:
            Auch Frauen können sich für Technik begeistern! ;)
            Equipment:
            diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
            • S SpeedyBlade
              #169
              @SpeedyBlade
              Ganz normal:
                @SpeedyBlade
                Ganz normal:
                SpeedyBlade
                schrieb am zuletzt editiert von SpeedyBlade
                #170
                @Thomas-Braun
                kannst du das mit backup vom iobroker testen?
                Und kannst mal deine Einstellungen im backup-iobroker senden sharen bitte.
                • S SpeedyBlade
                  @Thomas-Braun
                  #171
                  @SpeedyBlade
                  Klar:
                  Liegt jetzt im internen Bereich des FritzNas.
                  Was läuft da bei dir? Also welche FritzBox mit welchem FritzOS?
                  • S SpeedyBlade
                    @Thomas-Braun
                    #172
                    Das nutzt dir nix, ich verwende die Experten-Optionen an der Stelle.
                      @SpeedyBlade
                      Klar:
                      SpeedyBlade
                      #173
                      @Thomas-Braun
                      FRITZ!Box 5590 Fiber
                      FRITZ!OS: 8.02
                      Thomas BraunT S 2 Antworten Letzte Antwort
                      • S SpeedyBlade
                        @Thomas-Braun
                        FRITZ!OS: 8.02
                        #174
                        FRITZ!OS: 8.02
                        Typo? 8.20 ist aktuell.
                        • S SpeedyBlade
                          @Thomas-Braun
                          FRITZ!OS: 8.02
                          SpeedyBlade
                          #175
                          copy-paste...;)
                          hab gerade auf 8.20 upgedated von 8.02
                          FRITZ!OS: 8.20
                          hat leider auch keine besserung gebracht
                          15:23:30.416INFOguiBackup gestartet ...
                          15:23:40.536DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
                          15:23:40.589DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
                          15:23:40.592DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups"
                          15:23:40.648DEBUGmountError: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.1.1/fritz.nas/nas#/files/iobroker_backup /opt/iobroker/backups
                          15:23:44.769DEBUGiobrokerhost.RaspberryPi4 2376 objects saved
                          15:23:45.068DEBUGiobrokerhost.RaspberryPi4 1727 states saved
                          15:23:45.084DEBUGiobrokerhost.RaspberryPi4 Validating backup ...
                          15:23:45.097DEBUGiobrokerhost.RaspberryPi4 "objects.jsonl" exists
                          15:23:45.490DEBUGiobrokerhost.RaspberryPi4 JSONL lines are valid
                          15:23:45.548DEBUGiobrokerhost.RaspberryPi4 The backup is valid!
                          15:23:46.265DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2026_03_15-15_23_41_backupiobroker.tar.gz
                          15:23:46.272DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                          15:23:47.308DEBUGiobrokerdone
                          15:23:49.429DEBUGnoderedCreated nodered tmp directory
                          15:23:49.547DEBUGnoderedNode-Red tmp copy finish
                          15:23:49.669DEBUGnoderedBackup created: /opt/iobroker/backups/nodered.0_2026_03_15-15_23_49_backupiobroker.tar.gz
                          15:23:49.684DEBUGnoderedTry deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
                          15:23:49.690DEBUGnoderednode-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
                          15:23:49.692DEBUGnoderedfound node-red database: node-red.0
                          15:23:49.730DEBUGnodereddone
                          15:23:50.283DEBUGcifsused copy path: /fritz.nas/nas#/files/iobroker_backup
                          15:23:50.286DEBUGcifsdone
                          15:23:50.891ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                          15:23:50.931DEBUGcleandone
                          15:23:51.053DEBUGhistoryHTMLnew history html values created
                          15:23:51.066DEBUGhistoryHTMLdone
                          15:23:51.231DEBUGhistoryJSONnew history json values created
                          15:23:51.274DEBUGhistoryJSONdone
                          • S SpeedyBlade
                            copy-paste...;)
                            FRITZ!OS: 8.20
                            #176
                            Ist falsch. Der Pfad muss
                            lauten.
                              lauten.
                              #177
                              @Thomas-Braun sagte in Iobroker backitup error.. Wo liegt das problem:
                              der wird aber doch zusammengesetzt!
                              nach den Informationen von @speedyblade hier: https://forum.iobroker.net/post/1329835
                              müsste es richtig sein.
                              existiert noch ein separater mount?
                                #178
                                @Homoran sagte in Iobroker backitup error.. Wo liegt das problem:
                                Jein. Aber nicht so.
                                //192.168.178.1/fritz.nas/iobroker /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                                Der FritzNas-interne Bereich wird mit //192.168.178.1/fritz.nas/iobroker definiert. Hier ist noch ein Verzeichnis namens 'iobroker' angelegt, wo die Backups dann abgelegt werden.
                                  SpeedyBlade
                                  #179
                                  egal wie ich es schreibe, es kommt immer der gleiche Fehler
                                    SpeedyBlade
                                    #180
                                    es wird noch mit einer Gegensprechanlage, aber dafür nutze ich einen anderen User, auf ein anderes Verzeichnis auf der Fritzbox zugegriffen.
                                      SpeedyBlade
                                      #181
                                      @Thomas-Braun
                                      der Ordner, wo die backups abgelegt werden sollen heißt "iobroker_backup"
                                      • S SpeedyBlade
                                        #182
                                        der Fehler ist nicht wo du die roten Linien zusammenlaufen lässt, sondern in der 2.und 3. Zeile
                                        • S SpeedyBlade
                                          @Thomas-Braun
                                          #183
                                          @SpeedyBlade
                                          Hier übrigens ein Screenshot meiner alten Einstellungen (bevor es die Experten-Option gab):
                                          https://user-images.githubusercontent.com/39792461/224364096-c39691b6-0d4d-41fd-b627-00002ea2695e.png
