  4. JavaScript
  5. E3DC Hauskraftwerk steuern
3.6k Beiträge 73 Kommentatoren 2.2m Aufrufe 64 Beobachtet
  • D Dave69-CH
    17.2.2026, 18:40:25.459	[info ]: javascript.0 (95480) script.js.common.Charge_Control: start JavaScript (Javascript/js)
    17.2.2026, 18:40:25.472	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Charge-Control Version 1.6.8 ====-"}##
    17.2.2026, 18:40:25.505	[info ]: javascript.0 (95480) script.js.common.Charge_Control: registered 0 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
    17.2.2026, 18:40:25.768	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== alle Objekt ID's angelegt ====-"}##
    17.2.2026, 18:40:25.855	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== alle Objekte ID's überprüft ====-"}##
    17.2.2026, 18:40:26.045	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Speichergroesse_kWh=52 ====-"}##
    17.2.2026, 18:40:26.048	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" ****************************** Es wird Solcast Dach 2 abgerufen ****************************** "}##
    17.2.2026, 18:40:27.444	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
    17.2.2026, 18:40:27.446	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" ****************************** Es wird Solcast Dach 1 abgerufen ****************************** "}##
    17.2.2026, 18:40:28.350	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
    17.2.2026, 18:40:28.350	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-17 pv_estimate= 0 pv_estimate90= 0"}##
    17.2.2026, 18:40:28.350	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-18 pv_estimate= 18.34 pv_estimate90= 28.42"}##
    17.2.2026, 18:40:28.354	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-19 pv_estimate= 36.51 pv_estimate90= 56"}##
    17.2.2026, 18:40:28.356	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-20 pv_estimate= 29.08 pv_estimate90= 44.9"}##
    17.2.2026, 18:40:28.358	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-21 pv_estimate= 36.81 pv_estimate90= 64.74"}##
    17.2.2026, 18:40:28.361	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-22 pv_estimate= 35.21 pv_estimate90= 71.4"}##
    17.2.2026, 18:40:28.363	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-23 pv_estimate= 52.16 pv_estimate90= 72.01"}##
    17.2.2026, 18:40:28.596	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" ******************* Es wird die Globalstrahlung ab Tag 0 von Proplanta abgerufen ******************* "}##
    17.2.2026, 18:40:29.333	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"Rueckmeldung InterrogateProplanta response.status = 200"}##
    17.2.2026, 18:40:29.363	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Globalstrahlung Tag0 =0.1  Globalstrahlung Tag1 =0.3  Globalstrahlung Tag2 =0.5  Globalstrahlung Tag3 =0.1"}##
    17.2.2026, 18:40:29.456	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Näste Aktualisierung Wetterdaten =ja Uhr "}##
    17.2.2026, 18:40:29.460	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" ******************* Es wird die Globalstrahlung ab Tag 4 von Proplanta abgerufen ******************* "}##
    17.2.2026, 18:40:30.049	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"Rueckmeldung InterrogateProplanta response.status = 200"}##
    17.2.2026, 18:40:30.064	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" Globalstrahlung Tag4 =0.9  Globalstrahlung Tag5 =0.9  Globalstrahlung Tag6 =0.5"}##
    17.2.2026, 18:40:30.154	[error]: javascript.0 (95480) script.js.common.Charge_Control: schedule(cron={"hour":"NaN","minute":"NaN"}): cannot create schedule
    17.2.2026, 18:40:30.158	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== ScriptStart() erfolgreich abgeschlossen ====-"}##
    17.2.2026, 18:40:31.216	[warn ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"⚠️ Ungültige State-ID: 11 ⚠️"}##
    17.2.2026, 18:40:31.412	[info ]: javascript.0 (95480) script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"📊 Durchschnitt Hausverbrauch aktualisiert: 1405 W"}##
    ArnoD
    #3579
    @Dave69-CH
    Ich vermute das es bei dir an den Wetterdaten von Proplanta liegt.
    Dort wird ein Timer für den nächsten Abruf der Wetterdaten gesetzt und bei dir stimmt da anscheinend was mit dem Zeitformat nicht.
    Kannst du mal bitte prüfen, was bei dir unter
    -0_userdata.0.Charge_Control.Proplanta.NaesteAktualisierung eingetragen ist.
    Dort sollte eine Zeit stehen in dem Format hh:mm
      ArnoD
      #3580
      Neue Version Charge-Control auf GitHub hochgeladen.
      Version: 1.6.9
      Änderungen:
      • Prüfung, ob die Zeitangaben (hour, minute) aus dem State .NaesteAktualisierung gültige Zahlen sind, bevor ein neuer Timer mit schedule() gesetzt wird.
        Bei ungültigen Werten (z.B. "NaN", null, leer) wird ein Fallback-Timer auf 3:00 Uhr gesetzt und ein Warnhinweis ins Log geschrieben.
      • Einführung einer Timer-Variable (TimerSolcast) für Solcast, um vor jedem neuen Schedule den alten Timer zu löschen.
      @Dave69-CH: Kannst du mal testen, ob mit dieser Version der Fehler zumindest abgefangen wird.
      D 2 Antworten Letzte Antwort
      • azzkikrboyA azzkikrboy
        Hallo @arnod ,
        ich habe seit einigen Tagen einen Fehler bei der Solcast abfrage. Es sieht so aus, als ob das Script 6 mal hintereinander abfragt, bis dann der Fehler 429 (zu viele Versuche) kommt.
        Log siehe unten:
        2026-02-18 04:05:01.689 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:05:02.750 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:05:02.750 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-18 pv_estimate= 23.68 pv_estimate90= 33.2"}##
        2026-02-18 04:05:02.758 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-19 pv_estimate= 13.91 pv_estimate90= 20.11"}##
        2026-02-18 04:05:02.765 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-20 pv_estimate= 20.32 pv_estimate90= 39.33"}##
        2026-02-18 04:05:02.771 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-21 pv_estimate= 18.01 pv_estimate90= 27.21"}##
        2026-02-18 04:05:02.776 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-22 pv_estimate= 19.2 pv_estimate90= 23.86"}##
        2026-02-18 04:05:02.779 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-23 pv_estimate= 21.46 pv_estimate90= 36.15"}##
        2026-02-18 04:05:02.781 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-24 pv_estimate= 33.19 pv_estimate90= 47.29"}##
        2026-02-18 04:06:00.930 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:06:01.677 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:06:01.677 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-18 pv_estimate= 23.68 pv_estimate90= 33.2"}##
        2026-02-18 04:06:01.684 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-19 pv_estimate= 13.91 pv_estimate90= 20.11"}##
        2026-02-18 04:06:01.687 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-20 pv_estimate= 20.32 pv_estimate90= 39.33"}##
        2026-02-18 04:06:01.689 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-21 pv_estimate= 18.01 pv_estimate90= 27.21"}##
        2026-02-18 04:06:01.692 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-22 pv_estimate= 19.2 pv_estimate90= 23.86"}##
        2026-02-18 04:06:01.694 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-23 pv_estimate= 21.46 pv_estimate90= 36.15"}##
        2026-02-18 04:06:01.696 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-24 pv_estimate= 33.19 pv_estimate90= 47.29"}##
        2026-02-18 04:07:00.910 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:07:01.697 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:07:01.697 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-18 pv_estimate= 23.68 pv_estimate90= 33.2"}##
        2026-02-18 04:07:01.700 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-19 pv_estimate= 13.91 pv_estimate90= 20.11"}##
        2026-02-18 04:07:01.702 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-20 pv_estimate= 20.32 pv_estimate90= 39.33"}##
        2026-02-18 04:07:01.704 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-21 pv_estimate= 18.01 pv_estimate90= 27.21"}##
        2026-02-18 04:07:01.707 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-22 pv_estimate= 19.2 pv_estimate90= 23.86"}##
        2026-02-18 04:07:01.709 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-23 pv_estimate= 21.46 pv_estimate90= 36.15"}##
        2026-02-18 04:07:01.711 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-24 pv_estimate= 33.19 pv_estimate90= 47.29"}##
        2026-02-18 04:10:00.927 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:10:02.316 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:10:02.317 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-18 pv_estimate= 23.68 pv_estimate90= 33.2"}##
        2026-02-18 04:10:02.325 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-19 pv_estimate= 13.91 pv_estimate90= 20.11"}##
        2026-02-18 04:10:02.330 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-20 pv_estimate= 20.32 pv_estimate90= 39.33"}##
        2026-02-18 04:10:02.333 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-21 pv_estimate= 18.01 pv_estimate90= 27.21"}##
        2026-02-18 04:10:02.336 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-22 pv_estimate= 19.2 pv_estimate90= 23.86"}##
        2026-02-18 04:10:02.338 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-23 pv_estimate= 21.46 pv_estimate90= 36.15"}##
        2026-02-18 04:10:02.340 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-24 pv_estimate= 33.19 pv_estimate90= 47.29"}##
        2026-02-18 04:22:01.759 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:22:02.982 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
        2026-02-18 04:22:02.982 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-18 pv_estimate= 25.04 pv_estimate90= 34.15"}##
        2026-02-18 04:22:02.991 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-19 pv_estimate= 17.88 pv_estimate90= 24.6"}##
        2026-02-18 04:22:02.997 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-20 pv_estimate= 21.05 pv_estimate90= 40.11"}##
        2026-02-18 04:22:03.079 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-21 pv_estimate= 16.61 pv_estimate90= 25.75"}##
        2026-02-18 04:22:03.164 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-22 pv_estimate= 18.38 pv_estimate90= 23.04"}##
        2026-02-18 04:22:03.172 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-23 pv_estimate= 19.74 pv_estimate90= 32.75"}##
        2026-02-18 04:22:03.179 - info: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-24 pv_estimate= 36.91 pv_estimate90= 47.31"}##
        2026-02-18 04:23:00.376 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:23:00.900 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:25:00.620 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:25:01.151 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:39:00.444 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:39:00.727 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:49:00.722 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:49:01.006 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:51:00.424 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:51:00.780 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:52:00.645 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:52:00.924 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:59:00.470 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:59:00.476 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:59:00.751 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        2026-02-18 04:59:00.754 - warn: javascript.0 (591) script.js.Charge_Control_1_6_8: ##{"from":"Charge-Control", "message":"-==== Error in der function InterrogateSolcast. Fehler = Error: Error fetching data: Request failed with status code 429 ====-"}##
        Kann das an der neuen Version liegen? Vorher hatte ich dieses Verhalten nicht.
        ArnoD
        #3581
        @azzkikrboy
        Ich denke eher das in deinem Fall aus irgendeinem Grund der Timer mehrfach gesetzt wurde.
        Das kann durch häufige Neustarts z. B., Passieren, dass Timer nicht sauber gelöscht werden.
        Ich schaue mal wie ich das absichern kann, wenn du das Skript stoppst und etwas wartest bevor du es wieder startest, sollte das Problem erstmal gelöst sein.
          Hallo @arnod ,
          Log siehe unten:
          ArnoD
          #3582
          @azzkikrboy
          Habe den Timer Aufruf Solcast in der Version 1.6.9 noch mal abgesichert.
          • A ArnoD
            Version: 1.6.9
            Änderungen:
            Dave69-CH
            #3583
            @ArnoD
            Werde ich machen, komme aber erst Sammstag dazu.
            Und ja bei -0_userdata.0.Charge_Control.Proplanta.NaesteAktualisierung
            steht Ja oder nein keine Zeit. Wie kann Ich Das korrigieren?
            vielen dank für Deine tolle hilfe!
            • D Dave69-CH
              @ArnoD
              ArnoD
              #3584
              @Dave69-CH
              Kannst du mir mal deinen Link zu der Proplanta Seite schicken.
              Ich denke das die Schweizer Version anders aufgebaut ist und deswegen die Zeit für die nächste Aktualisierung mit meinem Filter nicht gefunden wird.
              Auf der Seite werden diese Zeilen gesucht:
              Entweder gibt es die in der Schweizer Version nicht, oder sind anders beschrieben.
              • A ArnoD
                Version: 1.6.9
                Änderungen:
                Dave69-CH
                #3585
                @ArnoD Habe auf Version 1.6.9 Aktualisiert.
                Und hier die neuen Meldungen.
                javascript.0	12:56:56.809	info
                Stopping script
                javascript.0	12:57:05.354	info
                javascript.0	12:57:05.366	info
                ##{"from":"Charge-Control", "message":"-==== Charge-Control Version 1.6.9 ====-"}##
                javascript.0	12:57:05.370	info
                javascript.0	12:57:05.700	info
                javascript.0	12:57:05.783	info
                javascript.0	12:57:05.933	info
                javascript.0	12:57:09.221	info
                javascript.0	12:57:10.689	info
                javascript.0	12:57:10.690	info
                ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-21 pv_estimate= 8.98 pv_estimate90= 13.6"}##
                ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-22 pv_estimate= 44.55 pv_estimate90= 66.42"}##
                javascript.0	12:57:10.695	info
                ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-23 pv_estimate= 31.88 pv_estimate90= 57.63"}##
                javascript.0	12:57:10.698	info
                ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-24 pv_estimate= 55.25 pv_estimate90= 69.78"}##
                javascript.0	12:57:10.701	info
                ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-25 pv_estimate= 64 pv_estimate90= 73.18"}##
                javascript.0	12:57:10.704	info
                ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-26 pv_estimate= 70.39 pv_estimate90= 71.52"}##
                javascript.0	12:57:10.707	info
                ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2026-02-27 pv_estimate= 59.7 pv_estimate90= 74.19"}##
                javascript.0	12:57:12.377	warn
                ##{"from":"Charge-Control", "message":"-==== Ungültige Zeit für Wetterdaten, Fallback auf 3:00 Uhr ====-"}##
                javascript.0	12:57:12.380	info
                javascript.0	12:57:14.280	warn
                • A ArnoD
                  @Dave69-CH
                  Dave69-CH
                  schrieb am zuletzt editiert von Dave69-CH
                  #3586
                  @ArnoD Wo finde ich den Link?
                  Unter Obiekte Proplanta steht im "NäechsteAktualisierung" Ja oder Nein.
                  Wenn ich da eine Zeit eingebe wird der wert wieder in Ja / Nein geändert.
                  So Sieht es diereckt auf der Proplanta Homepage aus:
                  4933 Rütschelen Schweiz
                  • D Dave69-CH
                    ArnoD
                    #3587
                    @Dave69-CH
                    Ok, dann funktioniert erstmal alles bei dir so weit.
                    Ich teste es gerade mit den Wetterdaten von Basel und konnte den Fehler noch nicht reproduzieren.
                    Ich muss mir meinen Filter noch mal genau ansehen, ob ich den etwas sicherer machen kann.
                    • A ArnoD
                      @Dave69-CH
                      Dave69-CH
                      #3588
                      @ArnoD super Danke viel mals.
                      Habe mal den wert bei -0_userdata.0.Charge_Control.Proplanta.NaesteAktualisierung von hand auf 04:00
                      geändert. Er ändert sich danach wider in Ja oder Nein nach einer zeit. ??
                      Kann es sein das ich was falsch eingegeben habe in den User Anpassungen?
                        Dave69-CH
                        #3589
                        @arnod Schon wieder ich.
                        Diesen Datenpunkt habe ich nicht, wurde der ersetzt?
                        0_userdata.0.Charge_Control.Allgemein.EigenverbrauchDurchschnitt_kWh
                        Siehe Bild
                        Oder was hast Du da reingemacht?
                        Vieeeelen DANK.
                          ArnoD
                          #3590
                          Version: 1.6.10
                          Änderungen:
                          • Fehler bei der Speicherung der Zeit behoben durch Optimierung der Filterfunktion HTML_CleanUp()
                          @dave69-ch mit dieser Version sollte es bei dir wieder funktionieren.
                          • D Dave69-CH
                            Siehe Bild
                            Vieeeelen DANK.
                            ArnoD
                            #3591
                            @Dave69-CH sagte in E3DC Hauskraftwerk steuern:
                            Die Objekt iDs haben sich geändert. Ist aber bereits länger her, weiß schon gar nicht mehr, mit welcher Version :-)
                            Das sollte jetzt so aussehen:
                            Im Editor den Text und die Objekt-ID 0_userdata.0.Charge_Control.Allgemein.EigenverbrauchDurchschnitt eintragen, dann sollte es wieder stimmen.
                            Prüfe auch die Objekt-ID "aktuell erzeugte Energie" dort sollte die Objekt-ID 0_userdata.0.Charge_Control.Allgemein.IstPvErtragLM0_kWh eingetragen sein.
                            • A ArnoD
                              Dave69-CH
                              #3592
                              Danke habe ich so angepasst!
                              • A ArnoD
                                Version: 1.6.10
                                Änderungen:
                                Dave69-CH
                                #3593
                                @ArnoD Super, jetzt habe icheine Zeitangabe und keinen fehler mehr.
                                Danke viel mals.
                                • A ArnoD
                                  Dave69-CH
                                  #3594
                                  Danke habe ich gemacht. ( 1punkt)
                                  Die Objekt-ID "aktuell erzeugte Energie" wäre bei mir:
                                  Objekt-ID: 0_userdata.0.Charge_Control.Allgemein.IstPvErtragLM0_kWh plus Objekt-ID: 0_userdata.0.Charge_Control.Allgemein.IstPvErtragLM1_kWh
                                  (zusatz WR)
                                  wie kann ich das bewerkstelligen?
                                  • D Dave69-CH
                                    (zusatz WR)
                                    ArnoD
                                    #3595
                                    @Dave69-CH
                                    Binding ist das Zauberwort :-)
                                    Ersetze das basic-Number Widget durch ein basic-HTML Widget und füge bei HTML folgende Zeile ein:
                                    {v1:0_userdata.0.Charge_Control.Allgemein.IstPvErtragLM0_kWh;v2:0_userdata.0.Charge_Control.Allgemein.IstPvErtragLM1_kWh;(Math.round(v1*1+v2*1))} kWh
                                    • A ArnoD
                                      @Dave69-CH
                                      Dave69-CH
                                      #3596
                                      @ArnoD Vielen Dank werde ich morgen machen!
                                      Super es funktioniert. Vielen dank!!! ;)
                                      • azzkikrboyA Offline
                                        azzkikrboyA Offline
                                        azzkikrboy
                                        #3597
                                        Hallo @arnod,
                                        ich habe auch gerade bemerkt, dass der Durchschnitt Tag / Nacht bei mir nicht richtig angezeigt wird.
                                        ich habe die Objekt ID geprüft, die ist auch korrekt, aber es wird nur der erste Teil angezeigt.
                                        Woran könnte das liegen?
                                          Hallo @arnod,
                                          ArnoD
                                          #3598
                                          @azzkikrboy
                                          Verwendest du die Objekt-ID 0_userdata.0.Charge_Control.Allgemein.EigenverbrauchDurchschnitt ?
                                          Da sollten immer beide Werte angezeigt werden.
                                          azzkikrboyA 1 Antwort Letzte Antwort
