  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 157 Kommentatoren 546.6k Aufrufe 139 Beobachtet
    @BamBam89
    Du sollst das nicht kürzen.
    B
    B
    BamBam89
    #1021
    @Thomas-Braun sagte in Neuer Adapter für Roborock-Staubsauger:
    @BamBam89
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Ubuntu 24.04.4 LTS
     Static hostname: iobroker-hausautomation
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-9-pve
        Architecture: x86-64
    OS is similar to: debian
    model name      : AMD Ryzen 5 4500U with Radeon Graphics
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     23:28:31 up  2:30,  0 user,  load average: 0.99, 1.04, 0.91
    CPU threads: 6
    *** LIFE CYCLE STATUS ***
    Operating System is the current Ubuntu LTS release codenamed 'noble'!
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-02-20 23:28:31 CET
               Universal time: Fri 2026-02-20 22:28:31 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:             16G        3.7G        7.1G        118K        5.3G         12G
    Swap:           8.6G         61K        8.6G
    Total:           24G        3.7G         15G
    Active iob-Instances:   31
            15427 M total memory
             3572 M used memory
             4744 M active memory
             3385 M inactive memory
             6786 M free memory
                0 M buffer memory
             5068 M swap cache
             8191 M total swap
                0 M used swap
             8191 M free swap
    top - 23:28:31 up  2:30,  0 user,  load average: 0.99, 1.04, 0.91
    Tasks:  67 total,   1 running,  66 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 10.9 us,  3.1 sy,  0.0 ni, 84.4 id,  0.0 wa,  0.0 hi,  1.6 si,  0.0 st
    MiB Mem :  15427.7 total,   6784.6 free,   3574.4 used,   5068.9 buff/cache
    MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.  11853.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
    sudo: a password is required
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                                     Type      Size  Used Avail Use% Mounted on
    /dev/mapper/Speicher_neu_2025-vm--100--disk--0 ext4      295G   20G  260G   7% /
    none                                           tmpfs     492K  4.0K  488K   1% /dev
    efivarfs                                       efivarfs  128K   20K  104K  16% /sys/firmware/efi/efivars
    none                                           tmpfs     8.0K  4.0K  4.0K  50% /dev/ttyUSB0
    tmpfs                                          tmpfs     7.6G     0  7.6G   0% /dev/shm
    tmpfs                                          tmpfs     3.1G  156K  3.1G   1% /run
    tmpfs                                          tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                                         FSTYPE OPTIONS
    /      /dev/mapper/Speicher_neu_2025-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    Archived and active journals take up 139.8M in the file system.
    /opt/iobroker/backups:
    579M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    599M    /opt/iobroker/iobroker-data/
    422M    /opt/iobroker/iobroker-data/files
    136M    /opt/iobroker/iobroker-data/files/vis
    129M    /opt/iobroker/iobroker-data/files/vis/widgets
    117M    /opt/iobroker/iobroker-data/files/vis-2
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    17M     /opt/iobroker/iobroker-data/states.jsonl.CURRENT_2026-02-20_225805
    13M     /opt/iobroker/iobroker-data/states.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    9.1M    /opt/iobroker/iobroker-data/states.jsonl.OLD_2026-02-20_221928
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_<ID>-if00-port0
    *** ZigBee Settings ***
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.19.1+dfsg-6ubuntu5 500
            500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-hausautomation iobroker-hausautomation (version: 7.1.0, hostname: iobroker-hausautomation, alive, uptime: 1816)
    Core adapters versions
    js-controller:  7.1.0
    admin:          7.7.31
    javascript:     9.0.18
    nodejs modules from github:     4
    +-- iobroker.cameras@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.cameras.git#<TOKEN>)
    +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#<TOKEN>)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#<TOKEN>)
    `-- shinobi@1.0.37 (git+ssh://git@github.com/ShinobiCCTV/Shinobi.git#<TOKEN>)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-hausautomation                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-hausautomation                  -  enabled
    + system.adapter.bestway.0                : bestway               : iobroker-hausautomation                  -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker-hausautomation                  -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-hausautomation                  -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker-hausautomation                  -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-hausautomation                  -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker-hausautomation                  -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-hausautomation                  -  enabled
    + system.adapter.followthesun.0           : followthesun          : iobroker-hausautomation                  -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-hausautomation                  -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-hausautomation                  -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-hausautomation                  -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : iobroker-hausautomation                  -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker-hausautomation                  -  enabled, port: 80
    + system.adapter.hue.1                    : hue                   : iobroker-hausautomation                  -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iobroker-hausautomation                  -  enabled
      system.adapter.ical.1                   : ical                  : iobroker-hausautomation                  -  enabled
      system.adapter.ical.2                   : ical                  : iobroker-hausautomation                  -  enabled
      system.adapter.ical.3                   : ical                  : iobroker-hausautomation                  -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker-hausautomation                  -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker-hausautomation                  -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-hausautomation                  -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker-hausautomation                  -  enabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker-hausautomation                  - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.owntracks.0              : owntracks             : iobroker-hausautomation                  - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.procon-ip.0              : procon-ip             : iobroker-hausautomation                  -  enabled
    + system.adapter.reolink.0                : reolink               : iobroker-hausautomation                  -  enabled
    + system.adapter.reolink.1                : reolink               : iobroker-hausautomation                  -  enabled
      system.adapter.robonect.0               : robonect              : iobroker-hausautomation                  - disabled
      system.adapter.roborock.1               : roborock              : iobroker-hausautomation                  - disabled
    + system.adapter.shelly.1                 : shelly                : iobroker-hausautomation                  -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : iobroker-hausautomation                  -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sma-em.0                 : sma-em                : iobroker-hausautomation                  -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker-hausautomation                  -  enabled, port: 1883, bind: <IP>
    + system.adapter.trashschedule.0          : trashschedule         : iobroker-hausautomation                  -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker-hausautomation                  -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker-hausautomation                  -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker-hausautomation                  -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker-hausautomation                  -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker-hausautomation                  -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker-hausautomation                  -  enabled
      system.adapter.vis-2-widgets-ovarious.0 : vis-2-widgets-ovarious: iobroker-hausautomation                  -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker-hausautomation                  -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-hausautomation                  -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-hausautomation                  -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-hausautomation                  -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-hausautomation                  -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-hausautomation                  -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker-hausautomation                  -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-hausautomation                  -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-hausautomation                  -  enabled
    + system.adapter.web.0                    : web                   : iobroker-hausautomation                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-hausautomation                  -  enabled
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker-hausautomation                  - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.7.31   , installed 7.7.31
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "bestway"      : 0.0.5    , installed 0.0.5
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "daswetter"    : 4.5.1    , installed 3.2.8  [Updatable]
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "followthesun" : 0.5.2    , installed 0.5.2
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.19.5   , installed 1.19.5
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.1.0    , installed 7.1.0
    Adapter    "modbus"       : 8.0.3    , installed 7.0.6  [Updatable]
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "owntracks"    : 1.1.0    , installed 1.1.0
    Adapter    "procon-ip"    : 1.7.0    , installed 1.7.0
    Adapter    "reolink"      : 1.3.0    , installed 1.3.0
    Adapter    "robonect"     : 1.4.2    , installed 1.4.2
    Adapter    "roborock"     : 0.6.19   , installed 0.6.19
    Adapter    "shelly"       : 10.6.0   , installed 10.6.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "sma-em"       : 1.3.0    , installed 1.3.0
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "trashschedule": 5.2.1    , installed 5.2.1
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
    Adapter    "vis-2-widgets-collection": 2.3.3, installed 2.3.3
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
    Adapter    "vis-2-widgets-inventwo": 0.5.8, installed 0.5.8
    Adapter    "vis-2-widgets-jaeger-design": 1.4.18, installed 1.4.18
    Adapter    "vis-2-widgets-material": 1.6.0, installed 1.6.0
    Adapter    "vis-2-widgets-ovarious": 2.0.0, installed 2.0.0
    Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
    Adapter    "vis-icontwo"  : 2.9.0    , installed 1.18.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
    Objects and States
    Objects:        15262
    States:         13490
    Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
    Hit:2 https://apt.grafana.com stable InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu noble-backports InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [6913 B]
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:7 http://security.ubuntu.com/ubuntu noble-security InRelease
    Fetched 6913 B in 0s (14.9 kB/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    2026-02-20 23:18:31.433  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2026-02-20 23:18:31.433  - info: host.iobroker-hausautomation Restart adapter system.adapter.roborock.1 because enabled
    2026-02-20 23:18:31.433  - warn: host.iobroker-hausautomation Do not restart adapter system.adapter.roborock.1 because restart loop detected
    2026-02-20 23:19:30.129  - info: iot.0 (22003) Connection changed: disconnect
    2026-02-20 23:20:37.010  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 in version "2.8.5" started with pid 24410
    2026-02-20 23:20:37.972  - info: dwd.0 (24410) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
    2026-02-20 23:20:38.263  - info: dwd.0 (24410) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-02-20 23:20:38.780  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 having pid 24410 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-02-20 23:21:23.661  - info: host.iobroker-hausautomation "system.adapter.roborock.1" disabled
    2026-02-20 23:21:38.277  - info: iot.0 (22003) Connection changed: disconnect
    2026-02-20 23:22:51.564  - info: sonoff.0 (21734) Client [Tasmota_Kühlschrank Nebenraum] connected with secret <TOKEN>
    2026-02-20 23:22:53.974  - info: web.0 (21957) ==> Connected system.user.admin from <IP>
    2026-02-20 23:22:55.077  - info: web.0 (21957) ==> Connected system.user.admin from <IP>
    2026-02-20 23:23:01.744  - info: web.0 (21957) <== Disconnect system.user.admin from <IP> energiefluss-erweitert.0
    2026-02-20 23:23:01.765  - info: web.0 (21957) <== Disconnect system.user.admin from <IP> vis.0
    2026-02-20 23:23:01.860  - info: web.0 (21957) ==> Connected system.user.admin from <IP>
    2026-02-20 23:23:06.870  - info: sonoff.0 (21734) Client [Tasmota_Kühlschrank Nebenraum] connection closed: closed
    2026-02-20 23:23:14.338  - info: web.0 (21957) <== Disconnect system.user.admin from <IP> vis.0
    2026-02-20 23:23:46.424  - info: iot.0 (22003) Connection changed: disconnect
    2026-02-20 23:25:37.010  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 in version "2.8.5" started with pid 24510
    2026-02-20 23:25:37.978  - info: dwd.0 (24510) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
    2026-02-20 23:25:38.276  - info: dwd.0 (24510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-02-20 23:25:38.792  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 having pid 24510 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-02-20 23:25:54.566  - info: iot.0 (22003) Connection changed: disconnect
    2026-02-20 23:28:07.728  - info: iot.0 (22003) Connection changed: disconnect
    ```bash
    root@iobroker-hausautomation:/opt/iobroker# sudo -u iobroker iob logs --watch --no-color | tee /tmp/iob_watch.log
    2026-02-20 23:06:09.654  - debug: roborock.1 (22406) Redis Objects: Use Redis connection: <IP>:9001
    2026-02-20 23:06:09.668  - debug: roborock.1 (22406) Objects client ready ... initialize now
    2026-02-20 23:06:09.669  - debug: roborock.1 (22406) Objects create System PubSub Client
    2026-02-20 23:06:09.669  - debug: roborock.1 (22406) Objects create User PubSub Client
    2026-02-20 23:06:09.693  - debug: roborock.1 (22406) Objects client initialize lua scripts
    2026-02-20 23:06:09.695  - debug: roborock.1 (22406) Objects connected to redis: <IP>:9001
    2026-02-20 23:06:09.711  - debug: roborock.1 (22406) Redis States: Use Redis connection: <IP>:9000
    2026-02-20 23:06:09.719  - debug: roborock.1 (22406) States create System PubSub Client
    2026-02-20 23:06:09.720  - debug: roborock.1 (22406) States create User PubSub Client
    2026-02-20 23:06:09.776  - debug: roborock.1 (22406) States connected to redis: <IP>:9000
    2026-02-20 23:06:09.791  - debug: roborock.1 (22406) Plugin sentry Initialize Plugin (enabled=true)
    2026-02-20 23:06:10.200  - error: roborock.1 (22406) adapter disabled
    2026-02-20 23:06:10.244  - debug: roborock.1 (22406) Plugin sentry destroyed
    2026-02-20 23:06:10.244  - warn: roborock.1 (22406) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2026-02-20 23:06:10.777  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2026-02-20 23:06:10.777  - info: host.iobroker-hausautomation Do not restart adapter system.adapter.roborock.1 because disabled or deleted
    2026-02-20 23:10:16.972  - info: host.iobroker-hausautomation "system.adapter.roborock.1" enabled
    2026-02-20 23:10:17.331  - info: host.iobroker-hausautomation instance system.adapter.roborock.1 in version "0.6.19" started with pid 22456
    2026-02-20 23:10:17.862  - debug: roborock.1 (22456) Redis Objects: Use Redis connection: <IP>:9001
    2026-02-20 23:10:17.878  - debug: roborock.1 (22456) Objects client ready ... initialize now
    2026-02-20 23:10:17.879  - debug: roborock.1 (22456) Objects create System PubSub Client
    2026-02-20 23:10:17.879  - debug: roborock.1 (22456) Objects create User PubSub Client
    2026-02-20 23:10:17.905  - debug: roborock.1 (22456) Objects client initialize lua scripts
    2026-02-20 23:10:17.908  - debug: roborock.1 (22456) Objects connected to redis: <IP>:9001
    2026-02-20 23:10:17.926  - debug: roborock.1 (22456) Redis States: Use Redis connection: <IP>:9000
    2026-02-20 23:10:17.934  - debug: roborock.1 (22456) States create System PubSub Client
    2026-02-20 23:10:17.935  - debug: roborock.1 (22456) States create User PubSub Client
    2026-02-20 23:10:17.990  - debug: roborock.1 (22456) States connected to redis: <IP>:9000
    2026-02-20 23:10:18.011  - debug: roborock.1 (22456) Plugin sentry Initialize Plugin (enabled=true)
    2026-02-20 23:10:18.454  - info: roborock.1 (22456) starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.22.0, js-controller: 7.1.0
    2026-02-20 23:10:18.462  - info: roborock.1 (22456) Starting adapter. This might take a few minutes depending on your setup. Please wait.
    2026-02-20 23:10:18.467  - info: roborock.1 (22456) Loaded existing clientID: <TOKEN>
    2026-02-20 23:10:18.469  - debug: roborock.1 (22456) initialize http_api
    2026-02-20 23:10:18.555  - error: roborock.1 (22456) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
    2026-02-20 23:10:18.559  - warn: roborock.1 (22456) State "roborock.1.HomeData" has no existing object, this might lead to an error in future versions
    2026-02-20 23:10:18.600  - warn: roborock.1 (22456) State "roborock.1.UserData" has no existing object, this might lead to an error in future versions
    2026-02-20 23:10:18.644  - error: roborock.1 (22456) Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata.
        at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:64:12)
        at processTicksAndRejections (node:internal/process/task_queues:105:5)
        at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3)
        at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
    2026-02-20 23:10:18.659  - error: roborock.1 (22456) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2026-02-20 23:10:18.659  - error: roborock.1 (22456) unhandled promise rejection: Cannot read properties of null (reading 'token')
    2026-02-20 23:10:18.659  - error: roborock.1 (22456) TypeError: Cannot read properties of null (reading 'token')
        at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22)
    2026-02-20 23:10:18.659  - error: roborock.1 (22456) Cannot read properties of null (reading 'token')
    2026-02-20 23:10:18.661  - info: roborock.1 (22456) terminating
    2026-02-20 23:10:18.662  - debug: roborock.1 (22456) Plugin sentry destroyed
    2026-02-20 23:10:18.662  - warn: roborock.1 (22456) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2026-02-20 23:10:19.163  - info: roborock.1 (22456) terminating
    2026-02-20 23:10:19.196  - error: host.iobroker-hausautomation Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]: TypeError: Cannot read properties of null (reading 'token')
    2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22)
    2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at processTicksAndRejections (node:internal/process/task_queues:105:5)
    2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3)
    2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
    2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2026-02-20 23:10:19.197  - info: host.iobroker-hausautomation Restart adapter system.adapter.roborock.1 because enabled
    2026-02-20 23:10:22.094  - info: host.iobroker-hausautomation "system.adapter.roborock.1" disabled
    ^C
    • B BamBam89
      @BamBam89
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 6
                       RTC time: n/a
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Swap:           8.6G         61K        8.6G
      Total:           24G        3.7G         15G
               3572 M used memory
               6786 M free memory
                  0 M buffer memory
               5068 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      *** FILESYSTEM ***
      /var:
      USB-Devices by-id:
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.31
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        15262
      States:         13490
      ```bash
      ^C
      Thomas BraunT
      Thomas BraunT
      #1022
      @BamBam89
      Zum einen: Hampel da nicht als root herum. Leg dir einen Standarduser an.
      Siehe auch:
      Der Text steht da nicht zum Spaß.
      Dann würde auch der Rest mit dem sudo richtig funktionieren.
        @BamBam89
        Siehe auch:
        B
        B
        BamBam89
        schrieb am zuletzt editiert von BamBam89
        #1023
        @BamBam89
        Siehe auch:
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
         Static hostname: <HOSTNAME>
                 Chassis: container
          Virtualization: lxc
                  Kernel: Linux <KERNEL>
        model name      : <CPU_MODEL>
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
         23:54:09 up  2:55,  0 user,  load average: 0.92, 0.85, 0.72
        CPU threads: 6
                       Local time: Fri 2026-02-20 23:54:09 CET
                   Universal time: Fri 2026-02-20 22:54:09 UTC
                         RTC time: n/a
                  RTC in local TZ: no
        iobroker
        HOME=/home/iobroker
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:
        *** MEMORY ***
        Mem:             16G        3.8G        7.0G        122K        5.3G         12G
        Swap:           8.6G         61K        8.6G
        Total:           24G        3.8G         15G
                 3638 M used memory
                 4816 M active memory
                 3381 M inactive memory
                 6716 M free memory
                    0 M buffer memory
                 5073 M swap cache
                 8191 M total swap
                    0 M used swap
                 8191 M free swap
        top - 23:54:10 up  2:55,  0 user,  load average: 0.92, 0.85, 0.72
        Tasks:  70 total,   1 running,  69 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 11.1 us,  4.8 sy,  0.0 ni, 84.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15427.7 total,   6714.6 free,   3639.8 used,   5073.5 buff/cache
        MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.  11787.9 avail Mem
        [sudo] password for iobroker:
        dmesg: read kernel buffer failed: Operation not permitted
        *** FILESYSTEM ***
        /dev/mapper/<DISK_MAPPER>                      ext4      295G   20G  260G   7% /
        tmpfs                                          tmpfs     3.1G  160K  3.1G   1% /run
        /      /dev/mapper/<DISK_MAPPER> ext4   rw,relatime,stripe=16
        /var:
        4.0G    /var/
        1.8G    /var/lib
        1.4G    /var/cache/apt
        1.4G    /var/cache
        1.3G    /var/cache/apt/archives
        595M    /opt/iobroker/iobroker-data/
        find: Failed to change directory: /home/<USER>: Permission denied
        find: Failed to restore initial working directory: /home/<USER>: Permission denied
        USB-Devices by-id:
        /dev/serial/by-id/<USB_ID>
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
             ... (unchanged)
        (ASCII-Banner unverändert)
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        <HOSTNAME> <HOSTNAME> (version: 7.1.0, hostname: <HOSTNAME>, alive, uptime: 3376)
        admin:          7.7.31
        javascript:     9.0.18
        +-- iobroker.cameras@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.cameras.git#<GIT_HASH>)
        +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#<GIT_HASH>)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#<GIT_HASH>)
        `-- shinobi@1.0.37 (git+ssh://git@github.com/ShinobiCCTV/Shinobi.git#<GIT_HASH>)
        (Adapter-Liste unverändert – keine sensiblen Daten außer Hostname/IP, daher Hostname bleibt als <HOSTNAME>.)
        ... (restlicher Inhalt unverändert) ...
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          56128727   1/systemd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          56381801   1/systemd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          56131871   678/master
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       56663637   21548/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       56664546   21548/iobroker.js-c
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       56670869   21878/io.shelly.2
        tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      111        56129281   266/mosquitto
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        56378887   11744/systemd-resol
        tcp        0      0 127.0.0.1:37227         0.0.0.0:*               LISTEN      0          56377267   11673/containerd
        tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        56378889   11744/systemd-resol
        tcp        0      0 <IP>:1883               0.0.0.0:*               LISTEN      1000       56665025   21734/io.sonoff.0
        tcp        0      0 <IP>:2001               0.0.0.0:*               LISTEN      1000       56669368   21750/io.hm-rpc.0
        tcp        0      0 <IP>:2010               0.0.0.0:*               LISTEN      1000       56670540   21766/io.hm-rpc.1
        tcp6       0      0 :::111                  :::*                    LISTEN      0          56128729   1/systemd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          56381802   1/systemd
        tcp6       0      0 :::3000                 :::*                    LISTEN      109        56430463   15307/grafana
        tcp6       0      0 ::1:1883                :::*                    LISTEN      111        56129282   266/mosquitto
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          56131872   678/master
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       56674802   21957/io.web.0
        tcp6       0      0 :::8080                 :::*                    LISTEN      0          56132247   911/node
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       56665829   21567/io.admin.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      108        56131275   327/influxd
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       56667951   21713/io.shelly.1
        udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        56378888   11744/systemd-resol
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        56378886   11744/systemd-resol
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          56128728   1/systemd
        udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1000       56664800   21682/io.sma-em.0
        udp6       0      0 :::111                  :::*                                0          56128730   1/systemd
        2026-02-20 23:40:48.125  - info: web.0 (21957) ==> Connected system.user.admin from ::ffff:<IP>
        2026-02-20 23:40:52.003  - info: web.0 (21957) ==> Connected system.user.admin from ::ffff:<IP>
        2026-02-20 23:40:52.664  - info: web.0 (21957) ==> Connected system.user.admin from ::ffff:<IP>
        2026-02-20 23:40:56.667  - info: iot.0 (22003) Connection changed: disconnect
        2026-02-20 23:43:04.812  - info: iot.0 (22003) Connection changed: disconnect
        2026-02-20 23:45:12.960  - info: iot.0 (22003) Connection changed: disconnect
        2026-02-20 23:45:21.010  - info: host.<HOSTNAME> instance system.adapter.daswetter.0 in version "3.2.8" started with pid 27305
        2026-02-20 23:45:22.012  - warn: daswetter.0 (27305) This instance has 6362 objects, the limit for this instance is set to 5000.
        2026-02-20 23:45:22.014  - info: daswetter.0 (27305) starting. Version 3.2.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.22.0, js-controller: 7.1.0
        2026-02-20 23:45:25.842  - info: daswetter.0 (27305) still wrong data structure from server received! repaired...
        2026-02-20 23:45:26.860  - info: daswetter.0 (27305) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2026-02-20 23:45:27.364  - info: daswetter.0 (27305) cleaned everything up...
        2026-02-20 23:45:27.374  - info: host.<HOSTNAME> instance system.adapter.daswetter.0 having pid 27305 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-02-20 23:45:37.010  - info: host.<HOSTNAME> instance system.adapter.dwd.0 in version "2.8.5" started with pid 27321
        2026-02-20 23:45:37.958  - info: dwd.0 (27321) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
        2026-02-20 23:45:38.246  - info: dwd.0 (27321) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2026-02-20 23:45:38.760  - info: host.<HOSTNAME> instance system.adapter.dwd.0 having pid 27321 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-02-20 23:47:21.228  - info: iot.0 (22003) Connection changed: disconnect
        2026-02-20 23:49:29.493  - info: iot.0 (22003) Connection changed: disconnect
        2026-02-20 23:50:37.009  - info: host.<HOSTNAME> instance system.adapter.dwd.0 in version "2.8.5" started with pid 27349
        2026-02-20 23:50:37.981  - info: dwd.0 (27349) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
        2026-02-20 23:50:38.318  - info: dwd.0 (27349) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2026-02-20 23:50:38.833  - info: host.<HOSTNAME> instance system.adapter.dwd.0 having pid 27349 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-02-20 23:51:37.641  - info: iot.0 (22003) Connection changed: disconnect
        2026-02-20 23:53:45.785  - info: iot.0 (22003) Connection changed: disconnect
        2026-02-21 00:04:03.169  - info: host.<HOST> "system.adapter.roborock.1" enabled
        2026-02-21 00:04:03.456  - info: host.<HOST> instance system.adapter.roborock.1 in version "0.6.19" started with pid 29408
        2026-02-21 00:04:04.078  - debug: roborock.1 (29408) Redis Objects: Use Redis connection: <IP_LOCAL>:9001
        2026-02-21 00:04:04.093  - debug: roborock.1 (29408) Objects client ready ... initialize now
        2026-02-21 00:04:04.093  - debug: roborock.1 (29408) Objects create System PubSub Client
        2026-02-21 00:04:04.094  - debug: roborock.1 (29408) Objects create User PubSub Client
        2026-02-21 00:04:04.119  - debug: roborock.1 (29408) Objects client initialize lua scripts
        2026-02-21 00:04:04.121  - debug: roborock.1 (29408) Objects connected to redis: <IP_LOCAL>:9001
        2026-02-21 00:04:04.136  - debug: roborock.1 (29408) Redis States: Use Redis connection: <IP_LOCAL>:9000
        2026-02-21 00:04:04.144  - debug: roborock.1 (29408) States create System PubSub Client
        2026-02-21 00:04:04.145  - debug: roborock.1 (29408) States create User PubSub Client
        2026-02-21 00:04:04.199  - debug: roborock.1 (29408) States connected to redis: <IP_LOCAL>:9000
        2026-02-21 00:04:04.215  - debug: roborock.1 (29408) Plugin sentry Initialize Plugin (enabled=true)
        2026-02-21 00:04:04.666  - info: roborock.1 (29408) starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.22.0, js-controller: 7.1.0
        2026-02-21 00:04:04.676  - info: roborock.1 (29408) Starting adapter. This might take a few minutes depending on your setup. Please wait.
        2026-02-21 00:04:04.685  - info: roborock.1 (29408) Loaded existing clientID: <CLIENT_ID>
        2026-02-21 00:04:04.686  - debug: roborock.1 (29408) initialize http_api
        2026-02-21 00:04:04.812  - error: roborock.1 (29408) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
        2026-02-21 00:04:04.814  - warn: roborock.1 (29408) State "roborock.1.HomeData" has no existing object, this might lead to an error in future versions
        2026-02-21 00:04:04.856  - warn: roborock.1 (29408) State "roborock.1.UserData" has no existing object, this might lead to an error in future versions
        2026-02-21 00:04:04.900  - error: roborock.1 (29408) Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata.
        2026-02-21 00:04:04.915  - error: roborock.1 (29408) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2026-02-21 00:04:04.915  - error: roborock.1 (29408) unhandled promise rejection: Cannot read properties of null (reading 'token')
        2026-02-21 00:04:04.915  - error: roborock.1 (29408) TypeError: Cannot read properties of null (reading 'token')
        2026-02-21 00:04:04.915  - error: roborock.1 (29408) Cannot read properties of null (reading 'token')
        2026-02-21 00:04:04.917  - info: roborock.1 (29408) terminating
        2026-02-21 00:04:04.918  - debug: roborock.1 (29408) Plugin sentry destroyed
        2026-02-21 00:04:04.918  - warn: roborock.1 (29408) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2026-02-21 00:04:05.419  - info: roborock.1 (29408) terminating
        2026-02-21 00:04:05.420  - info: roborock.1 (29408) terminating
        2026-02-21 00:04:05.454  - error: host.<HOST> Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]: TypeError: Cannot read properties of null (reading 'token')
        2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22)
        2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at processTicksAndRejections (node:internal/process/task_queues:105:5)
        2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3)
        2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
        2026-02-21 00:04:05.455  - error: host.<HOST> instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2026-02-21 00:04:05.455  - info: host.<HOST> Restart adapter system.adapter.roborock.1 because enabled
        2026-02-21 00:04:08.914  - info: host.<HOST> "system.adapter.roborock.1" disabled
        Thomas BraunT haselchenH 2 Antworten Letzte Antwort
        • B BamBam89
          @BamBam89
          Siehe auch:
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
                   Chassis: container
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 6
                           RTC time: n/a
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Swap:           8.6G         61K        8.6G
          Total:           24G        3.8G         15G
                   3638 M used memory
                   6716 M free memory
                      0 M buffer memory
                   5073 M swap cache
                   8191 M total swap
                      0 M used swap
                   8191 M free swap
          *** FILESYSTEM ***
          /var:
          4.0G    /var/
          1.8G    /var/lib
          1.4G    /var/cache/apt
          1.4G    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
               ... (unchanged)
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.31
          javascript:     9.0.18
          Thomas BraunT
          Thomas BraunT
          #1024
          @BamBam89 sagte in Neuer Adapter für Roborock-Staubsauger:
          Ist das jetzt nach seinen Wünschen?
          Es geht nicht 'nach meinen Wünschen', es geht darum das System grundsätzlich richtig zu verwenden.
          Du bist da immer noch nicht als Standarduser aktiv. Der user 'iobroker' ist als Systemuser vorgesehen.
          Ich bin dann aus der Nummer raus...
          • B BamBam89
            @BamBam89
            Siehe auch:
            ```bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 6
                             RTC time: n/a
                      RTC in local TZ: no
            iobroker
            HOME=/home/iobroker
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Swap:           8.6G         61K        8.6G
            Total:           24G        3.8G         15G
                     3638 M used memory
                     6716 M free memory
                        0 M buffer memory
                     5073 M swap cache
                     8191 M total swap
                        0 M used swap
                     8191 M free swap
            *** FILESYSTEM ***
            /var:
            4.0G    /var/
            1.8G    /var/lib
            1.4G    /var/cache/apt
            1.4G    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
                 ... (unchanged)
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.31
            javascript:     9.0.18
            haselchenH
            haselchenH
            haselchen
            #1025
            @BamBam89
            Zudem benutzen shelly.1 und sonoff.0 beide den Port 1883
            Das solltest Du auch ändern.
              B
              B
              BamBam89
              #1026
              Sorry das hatte aber nichts mit dir zu tun.
              Ich hab hier 3 Baustellen gleichzeit. Ich bin ja froh wenn mich jemand unterstützt der mehr Ahnung vn der Materie hat. Was im übrigen nicht schwer ist.
              Ich weiß ehrlicherweise noch nicht was ich falsch mache. Angemeldet bin ich aber als
              BamBam89@iobroker-hausautomation:~$
              @haselchen sagte in Neuer Adapter für Roborock-Staubsauger:
              @BamBam89
              Vielen Dank für den Hinweis. Das werde ich korrigieren.
              • B BamBam89
                @BamBam89
                Thomas BraunT
                Thomas BraunT
                #1027
                @BamBam89
                Dann ruf das Skript auch als dieser user auf. Du springst warum auch immer in den iobroker:
                iobroker
                B 2 Antworten Letzte Antwort
                  @BamBam89
                  iobroker
                  B
                  B
                  BamBam89
                  #1028
                  @BamBam89
                  iobroker
                  Ok vielen Dank
                  Ich schau mir das morgen früh mal an und hoffe das ich dann die richtigen Daten bereitstellen kann.
                    @BamBam89
                    iobroker
                    B
                    B
                    BamBam89
                    #1029
                    @BamBam89
                    iobroker
                    Guten Morgen,
                    so ein neuer Versuch. Ich hoffe das passt nun.
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                     08:11:46 up 11:13,  0 user,  load average: 0.81, 0.53, 0.56
                    CPU threads: 6
                                   Local time: Sat 2026-02-21 08:11:46 CET
                               Universal time: Sat 2026-02-21 07:11:46 UTC
                                     RTC time: n/a
                              RTC in local TZ: no
                    BamBam89
                    HOME=/home/BamBam89
                    GROUPS=BamBam89 adm dialout sudo audio video plugdev users iobroker
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:
                    *** MEMORY ***
                    Mem:             16G        4.0G        8.6G        106K        3.6G         12G
                    Swap:           8.6G         77K        8.6G
                    Total:           24G        4.0G         17G
                             3804 M used memory
                             3270 M active memory
                             3571 M inactive memory
                             8174 M free memory
                                0 M buffer memory
                             3448 M swap cache
                             8191 M total swap
                                0 M used swap
                             8191 M free swap
                    top - 08:11:47 up 11:13,  0 user,  load average: 0.81, 0.53, 0.56
                    Tasks:  68 total,   1 running,  67 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 11.7 us,  0.0 sy,  0.0 ni, 86.7 id,  0.0 wa,  0.0 hi,  1.7 si,  0.0 st
                    MiB Mem :  15427.7 total,   8173.1 free,   3806.1 used,   3448.6 buff/cache
                    MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.  11621.6 avail Mem
                    *** FILESYSTEM ***
                    /var:
                    4.0G    /var/
                    1.8G    /var/lib
                    1.4G    /var/cache/apt
                    1.4G    /var/cache
                    Archived and active journals take up 869.1M in the file system.
                    541M    /opt/iobroker/backups/
                    602M    /opt/iobroker/iobroker-data/
                    21M     /opt/iobroker/iobroker-data/objects.jsonl
                    20M     /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_327e0f98dfc2ef11aad7e6b08048b910-if00-port0
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    iobroker-hausautomation iobroker-hausautomation (version: 7.1.0, hostname: iobroker-hausautomation, alive, uptime: 33227)
                    admin:          7.7.31
                    javascript:     9.0.18
                    +-- iobroker.cameras@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.cameras.git#939aa16d253f5365c8e6ee3280cb0aebfe6b458b)
                    +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)
                    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                    `-- shinobi@1.0.37 (git+ssh://git@github.com/ShinobiCCTV/Shinobi.git#984deef28caef29d36ae2b27ae6da2fd44b8a5b7)
                    Adapter State
                    + system.adapter.sonoff.0                 : sonoff                : iobroker-hausautomation                  -  enabled, port: 1883, bind: 192.168.1.10
                    + instance is alive
                    Objects and States
                    Objects:        15269
                    States:         13497
                    Hit:1 https://apt.grafana.com stable InRelease
                    Get:2 https://repos.influxdata.com/debian stable InRelease [6913 B]
                    Hit:3 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
                    Hit:5 http://archive.ubuntu.com/ubuntu noble InRelease
                    Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                    Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                    Fetched 6913 B in 1s (12.8 kB/s)
                    tcp        0      0 192.168.1.10:1883       0.0.0.0:*               LISTEN      1000       56665025   21734/io.sonoff.0
                    tcp        0      0 192.168.1.10:2001       0.0.0.0:*               LISTEN      1000       56669368   21750/io.hm-rpc.0
                    tcp        0      0 192.168.1.10:2010       0.0.0.0:*               LISTEN      1000       56670540   21766/io.hm-rpc.1
                    2026-02-21 08:11:48.408  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:49.465  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:50.562  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:51.579  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:52.635  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:53.692  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:54.747  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:55.800  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:56.858  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:57.911  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:11:58.965  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:00.102  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:01.078  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:02.134  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:03.473  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:04.245  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:05.809  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:06.360  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:07.414  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:08.491  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:09.521  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:10.579  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:11.634  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:12.690  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    2026-02-21 08:12:13.745  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                    iob diag has finished.
                    2026-02-21 08:22:27.297  - info: host.iobroker-hausautomation "system.adapter.roborock.1" enabled
                    2026-02-21 08:22:27.643  - info: host.iobroker-hausautomation instance system.adapter.roborock.1 in version "0.6.19" started with pid 34380
                    2026-02-21 08:22:28.416  - debug: roborock.1 (34380) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2026-02-21 08:22:28.433  - debug: roborock.1 (34380) Objects client ready ... initialize now
                    2026-02-21 08:22:28.434  - debug: roborock.1 (34380) Objects create System PubSub Client
                    2026-02-21 08:22:28.434  - debug: roborock.1 (34380) Objects create User PubSub Client
                    2026-02-21 08:22:28.459  - debug: roborock.1 (34380) Objects client initialize lua scripts
                    2026-02-21 08:22:28.461  - debug: roborock.1 (34380) Objects connected to redis: 127.0.0.1:9001
                    2026-02-21 08:22:28.477  - debug: roborock.1 (34380) Redis States: Use Redis connection: 127.0.0.1:9000
                    2026-02-21 08:22:28.486  - debug: roborock.1 (34380) States create System PubSub Client
                    2026-02-21 08:22:28.487  - debug: roborock.1 (34380) States create User PubSub Client
                    2026-02-21 08:22:28.543  - debug: roborock.1 (34380) States connected to redis: 127.0.0.1:9000
                    2026-02-21 08:22:28.561  - debug: roborock.1 (34380) Plugin sentry Initialize Plugin (enabled=true)
                    2026-02-21 08:22:29.020  - info: roborock.1 (34380) starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.22.0, js-controller: 7.1.0
                    2026-02-21 08:22:29.031  - info: roborock.1 (34380) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                    2026-02-21 08:22:29.036  - info: roborock.1 (34380) Loaded existing clientID: a59f15a6-b0ac-4933-ad28-5ab3bc15f837
                    2026-02-21 08:22:29.037  - debug: roborock.1 (34380) initialize http_api
                    2026-02-21 08:22:29.157  - error: roborock.1 (34380) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
                    2026-02-21 08:22:29.158  - warn: roborock.1 (34380) State "roborock.1.HomeData" has no existing object, this might lead to an error in future versions
                    2026-02-21 08:22:29.201  - warn: roborock.1 (34380) State "roborock.1.UserData" has no existing object, this might lead to an error in future versions
                    2026-02-21 08:22:29.245  - error: roborock.1 (34380) Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata.
                    2026-02-21 08:22:29.263  - error: roborock.1 (34380) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2026-02-21 08:22:29.263  - error: roborock.1 (34380) unhandled promise rejection: Cannot read properties of null (reading 'token')
                    2026-02-21 08:22:29.263  - error: roborock.1 (34380) TypeError: Cannot read properties of null (reading 'token')
                    2026-02-21 08:22:29.263  - error: roborock.1 (34380) Cannot read properties of null (reading 'token')
                    2026-02-21 08:22:29.265  - info: roborock.1 (34380) terminating
                    2026-02-21 08:22:29.266  - debug: roborock.1 (34380) Plugin sentry destroyed
                    2026-02-21 08:22:29.266  - warn: roborock.1 (34380) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2026-02-21 08:22:29.766  - info: roborock.1 (34380) terminating
                    2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]: TypeError: Cannot read properties of null (reading 'token')
                    2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]:     at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22)
                    2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]:     at processTicksAndRejections (node:internal/process/task_queues:105:5)
                    2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]:     at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3)
                    2026-02-21 08:22:29.800  - error: host.iobroker-hausautomation Caught by controller[0]:     at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
                    2026-02-21 08:22:29.800  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2026-02-21 08:22:29.800  - info: host.iobroker-hausautomation Restart adapter system.adapter.roborock.1 because enabled
                    2026-02-21 08:22:32.539  - info: host.iobroker-hausautomation "system.adapter.roborock.1" disabled
                    • stefu87_CHS
                      stefu87_CHS
                      stefu87_CH
                      #1030
                      Kann es sein, das beim Adapter irgendwie was falsch lauft?
                      Für eine Fläche von knapp 4 m2 braucht er 234 min und berechnet eine Fläche von 4212500 m2?
                      Cores: 1 × 8 = 8 cores
                      Threads: 16
                      mit Proxmox
                      LXC Container mit Iobroker
                      • stefu87_CHS stefu87_CH
                        haselchenH
                        haselchenH
                        haselchen
                        #1031
                        @stefu87_CH
                        Warum benutzt ihr nicht den mihome-vacuum Adapter?
                        @bambam89
                        Du hast die Ports immer noch nicht geändert.
                        stefu87_CHS B 2 Antworten Letzte Antwort
                        • haselchenH haselchen
                          @stefu87_CH
                          @bambam89
                          stefu87_CHS
                          stefu87_CHS
                          stefu87_CH
                          schrieb am zuletzt editiert von stefu87_CH
                          #1032
                          Weil der mihome Adapter seit Anfang Jahr bei mir nicht mehr verbunden hat, und weil laut Forumsbeiträgen da was an der Anmeldung verändert wurde, somit konnte die Verbindung nicht mehr hergestellt werden.
                          Und das er jetzt so komische Werte anzeigt ist erst seit dem 14. Februar
                          Threads: 16
                          mit Proxmox
                            haselchenH
                            haselchenH
                            haselchen
                            #1033
                            @stefu87_CH
                            Keine Ahnung wo Du das gelesen hast. Anmeldung klappt.
                            Eventuell gibt es Probleme mit der Karte.
                            Aber ich meine in den letzten Tagen eine Lösung hier gelesen zu haben (vom Entwickler?)
                            Also ich bin seit Jahren zufrieden mit dem Adapter.
                            Funktioniert auch mit Valetudo.
                              @stefu87_CH
                              @bambam89
                              B
                              B
                              BamBam89
                              #1034
                              Ja ich weis... kommt noch.
                                @stefu87_CH
                                stefu87_CHS
                                stefu87_CHS
                                stefu87_CH
                                #1035
                                Ja ich bin jetzt auf Roborock und ändere nur wegen den 2 Sachen den ganzen Adapter. Ist ja auch mit Aufwand verbunden, alles in der Vis anzupassen.
                                Threads: 16
                                mit Proxmox
                                • M
                                  M
                                  mrMuppet
                                  schrieb am zuletzt editiert von mrMuppet
                                  #1036
                                  ich habe herausgefunden, warum die allerneuesten Modelle im Adapter aktuell komplett ignoriert werden und localDevices: {} zurückliefern.
                                  Roborock hat die API-Struktur für neue Modelle geändert! > Die neuen Geräte tauchen im JSON nicht mehr unter "devices": [] auf (dieses Array ist bei mir komplett leer). Stattdessen liegen sie jetzt unter "products": und nutzen ein neues RPC-Schema für die Datenpunkte. Da der Adapter nur in devices sucht, übersieht er den Sauger, anstatt ein 'unknown model' zu melden.
                                  Mein Modell: roborock.vacuum.ss09 (Roborock Q10 Series)
                                  Hier ist der komplette HomeData-String:
                                  {"id":1234567,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"XXXXXXXXXXXXXXXXXXXXXX","name":"Roborock Q10 Series","model":"roborock.vacuum.ss09","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":101,"name":"RPC Request","code":"rpc_request","mode":"rw","type":"RAW","property":"null"},{"id":102,"name":"RPC Response","code":"rpc_response","mode":"rw","type":"RAW","property":"null"},{"id":120,"name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"null"},{"id":121,"name":"设备状态","code":"state","mode":"ro","type":"VALUE","property":"null"},{"id":122,"name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"null"},{"id":123,"name":"吸力档位","code":"fan_power","mode":"rw","type":"ENUM","property":"null"},{"id":124,"name":"拖地档位","code":"water_box_mode","mode":"rw","type":"RAW","property":"null"},{"id":125,"name":"主刷寿命","code":"main_brush_life","mode":"ro","type":"ENUM","property":"null"},{"id":126,"name":"边刷寿命","code":"side_brush_life","mode":"ro","type":"ENUM","property":"null"},{"id":127,"name":"滤网寿命","code":"filter_life","mode":"ro","type":"ENUM","property":"null"},{"id":135,"name":"离线原因","code":"offline_status","mode":"ro","type":"ENUM","property":"null"},{"id":136,"name":"清洁次数","code":"clean_times","mode":"rw","type":"ENUM","property":"null"},{"id":137,"name":"扫拖模式","code":"cleaning_preference","mode":"rw","type":"ENUM","property":"null"},{"id":138,"name":"清洁任务类型","code":"clean_task_type","mode":"ro","type":"ENUM","property":"null"},{"id":139,"name":"返回基站类型","code":"back_type","mode":"ro","type":"ENUM","property":"null"},{"id":140,"name":"基站任务类型","code":"dock_task_type","mode":"ro","type":"ENUM","property":"null"},{"id":141,"name":"清洁进度","code":"cleaning_progress","mode":"ro","type":"ENUM","property":"null"},{"id":142,"name":"窜货信息","code":"fc_state","mode":"ro","type":"RAW","property":"null"},{"id":201,"name":"启动清洁任务","code":"start_clean_task","mode":"wo","type":"ENUM","property":"null"},{"id":202,"name":"返回基站任务","code":"start_back_dock_task","mode":"wo","type":"ENUM","property":"null"},{"id":203,"name":"启动基站任务","code":"start_dock_task","mode":"wo","type":"ENUM","property":"null"},{"id":204,"name":"暂停任务","code":"pause","mode":"wo","type":"RAW","property":"null"},{"id":205,"name":"继续任务","code":"resume","mode":"wo","type":"RAW","property":"null"},{"id":206,"name":"结束任务","code":"stop","mode":"wo","type":"RAW","property":"null"},{"id":207,"name":"用户改善计划","code":"ceip","mode":"rw","type":"ENUM","property":"{\"range\": [\"0,1\"]}"}]}],"devices":[],"receivedDevices":[],"rooms":[]}
                                  ioBroker auf NUC (Celeron mit Ubuntu-Server)
                                  Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
                                  • M
                                    M
                                    mrMuppet
                                    #1037
                                    Sollte ich hierzu noch einen Issue bei Github einreichen oder reicht das so?
                                    • M mrMuppet
                                      Thomas BraunT
                                      Thomas BraunT
                                      #1038
                                      @mrMuppet
                                      GitHub ist der richtige Platz dafür. Hier im Forum geht das unter.
                                      • S
                                        S
                                        samsungfreak
                                        #1039
                                        Hat jemand einen Tipp? Ich bekommen den Adapter leider nicht zum laufen:
                                        System läuft mit Node.js: v22.22.0.
                                        • H
                                          H
                                          horgihorgsen
                                          #1040
                                          Hallo zusammen - ich habe einen Roborock Q10 S5+ und es kommen folgende Fehlermeldungen zurück. Hab die Dokumentation vom Adapter gelesen, finde aber nichts wie ich den verbunden bekomme.
                                          roborock.0
                                          3280 2026-03-02 00:59:14.306 error Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
                                          roborock.0
                                          3280 2026-03-02 00:59:14.308 error Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (C:\ioBroker\node_modules\iobroker.roborock\main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:105:5) at Roborock.initializeRoborockApi (C:\ioBroker\node_modules\iobroker.roborock\main.js:103:21) at C:\ioBroker\node_modules\iobroker.roborock\main.js:75:35
                                          roborock.0
                                          3280 2026-03-02 00:59:14.487 error Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (C:\ioBroker\node_modules\iobroker.roborock\main.js:144:25) at C:\ioBroker\node_modules\iobroker.roborock\main.js:77:15
                                          83.8k
