  4. Neuer Adapter für Roborock-Staubsauger
    2.0k
1.1k Beiträge 156 Kommentatoren 537.9k Aufrufe 138 Beobachtet
  • copystringC copystring
    @hsteinme Ja, das habe ich ständig vor mir hergeschoben, ist aber jetzt erstellt.
    Siehe https://github.com/copystring/ioBroker.roborock/issues/new?template=feature_request.yaml
    hsteinmeH
    hsteinmeH
    hsteinme
    #1012
    @copystring Super! Ich danke Dir ganz herzlich.
    • B
      B
      BamBam89
      #1013
      ich hoffe ihr könnt mir helfen. Ich bekomme den Adapter einfach nicht zum laufen.
      Ich bekomme immer den folgenden Fehler:
      roborock.1
      2026-02-20 17:44:45.417	debug	Plugin sentry destroyed
      roborock.1
      2026-02-20 17:44:45.416	info	terminating
      roborock.1
      2026-02-20 17:44:45.414	error	Cannot read properties of null (reading 'token')
      roborock.1
      2026-02-20 17:44:45.414	error	TypeError: Cannot read properties of null (reading 'token') at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22) at processTicksAndRejections (node:internal/process/task_queues:105:5) at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
      roborock.1
      2026-02-20 17:44:45.413	error	unhandled promise rejection: Cannot read properties of null (reading 'token')
      roborock.1
      2026-02-20 17:44:45.413	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.1
      2026-02-20 17:44:45.396	error	Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata. at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:64:12) at processTicksAndRejections (node:internal/process/task_queues:105:5) at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
      Früher lief die Sache.
      Ich hab den S8 nun auf Werkseinstellung gesetzt, ein neues Konto erstellt und 24 Stunden gewartet.
      Und dennoch bekomme ich diese Meldung.
      Hat einer von euch eine Idee, was das sein könnte....
      Besten Dank
      • B BamBam89
        roborock.1
        roborock.1
        roborock.1
        roborock.1
        roborock.1
        roborock.1
        roborock.1
        Besten Dank
        Thomas BraunT
        Thomas BraunT
        #1014
        @BamBam89 sagte in Neuer Adapter für Roborock-Staubsauger:
        Nee.
        Aber du könntest
        a) ein vollständiges Log (chronologisch richtig) aus iob logs --watch nehmen
        b) die beteiligten Versionen zum besten geben. Per Ausgabe von iob diag bevorzugt.
        • B
          B
          BamBam89
          schrieb am zuletzt editiert von BamBam89
          #1015
          Beim Start der Instanz kommt es zu Login-Problemen („empty userdata“) und anschließend zu einer unhandled promise rejection („token“ ist null).
          Hier sind die gewünschten Infos: (ich hoffe das ist so korrekt, Das ist jetzt nicht mein Spezialgebiet)
          ### HOST / OS
          iobroker-host
          Linux iobroker-host 6.8.12-9-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-9 (2025-03-16T19:18Z) x86_64 GNU/Linux
          Ubuntu 24.04.2 LTS (Noble Numbat)
          ### IOBROKER
          js-controller: 7.1.0
          Objects type: jsonl
          States  type: jsonl
          ### NODE / NPM
          node: v22.21.0
          npm: 10.9.4
          ### INVOLVED ADAPTER / INSTANCE
          system.adapter.roborock.1 version: 0.6.19
          2026-02-20 20:50:50.368  info: host.iobroker-host "system.adapter.roborock.1" enabled
          2026-02-20 20:50:50.731  info: host.iobroker-host instance system.adapter.roborock.1 in version "0.6.19" started with pid 158460
          2026-02-20 20:50:51.271  debug: roborock.1 (158460) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2026-02-20 20:50:51.287  debug: roborock.1 (158460) Objects client ready ... initialize now
          2026-02-20 20:50:51.287  debug: roborock.1 (158460) Objects create System PubSub Client
          2026-02-20 20:50:51.288  debug: roborock.1 (158460) Objects create User PubSub Client
          2026-02-20 20:50:51.315  debug: roborock.1 (158460) Objects client initialize lua scripts
          2026-02-20 20:50:51.318  debug: roborock.1 (158460) Objects connected to redis: 127.0.0.1:9001
          2026-02-20 20:50:51.335  debug: roborock.1 (158460) Redis States: Use Redis connection: 127.0.0.1:9000
          2026-02-20 20:50:51.345  debug: roborock.1 (158460) States create System PubSub Client
          2026-02-20 20:50:51.346  debug: roborock.1 (158460) States create User PubSub Client
          2026-02-20 20:50:51.403  debug: roborock.1 (158460) States connected to redis: 127.0.0.1:9000
          2026-02-20 20:50:51.421  debug: roborock.1 (158460) Plugin sentry Initialize Plugin (enabled=true)
          2026-02-20 20:50:51.875  info: roborock.1 (158460) starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.21.0, js-controller: 7.1.0
          2026-02-20 20:50:51.885  info: roborock.1 (158460) Starting adapter. This might take a few minutes depending on your setup. Please wait.
          2026-02-20 20:50:51.891  info: roborock.1 (158460) Loaded existing clientID: <redacted>
          2026-02-20 20:50:51.892  debug: roborock.1 (158460) initialize http_api
          2026-02-20 20:50:52.675  error: roborock.1 (158460) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
          2026-02-20 20:50:52.677  warn: roborock.1 (158460) State "roborock.1.HomeData" has no existing object, this might lead to an error in future versions
          2026-02-20 20:50:52.719  warn: roborock.1 (158460) State "roborock.1.UserData" has no existing object, this might lead to an error in future versions
          2026-02-20 20:50:52.763  error: roborock.1 (158460) Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata.
          2026-02-20 20:50:52.778  error: roborock.1 (158460) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2026-02-20 20:50:52.778  error: roborock.1 (158460) unhandled promise rejection: Cannot read properties of null (reading 'token')
          2026-02-20 20:50:52.779  error: roborock.1 (158460) TypeError: Cannot read properties of null (reading 'token')
          Gruß und schönes Wochenende
          • B BamBam89
            ### HOST / OS
            iobroker-host
            ### IOBROKER
            Objects type: jsonl
            States  type: jsonl
            ### NODE / NPM
            node: v22.21.0
            npm: 10.9.4
            Thomas BraunT
            Thomas BraunT
            #1016
            node: v22.21.0
            Bring das auf den aktuellen Stand. Per
            iob nodejs-update 22
            Rückfragen bejahen.
              node: v22.21.0
              Rückfragen bejahen.
              B
              B
              BamBam89
              #1017
              @Thomas-Braun sagte in Neuer Adapter für Roborock-Staubsauger:
              node: v22.21.0
              Rückfragen bejahen.
              So das ist nun der aktuelle Stand:
              System:
              - Ubuntu 24.04 LTS (LXC)
              - ioBroker: js-controller 7.1.0
              - admin 7.7.31
              - nodejs v22.22.0
              - Adapter roborock: 0.6.19
              Repo: beta
              Chronologisches Log (gekürzt & anonymisiert):
              2026-02-20 23:17:06.981  - info: host.<HOST> "system.adapter.roborock.1" enabled
              2026-02-20 23:17:07.332  - info: host.<HOST> instance system.adapter.roborock.1 in version "0.6.19" started
              2026-02-20 23:17:08.497  - info: roborock.1 starting. Version 0.6.19, node: v22.22.0, js-controller: 7.1.0
              2026-02-20 23:17:08.507  - info: roborock.1 Starting adapter. This might take a few minutes...
              2026-02-20 23:17:08.513  - info: roborock.1 Loaded existing clientID: <TOKEN>
              2026-02-20 23:17:08.641  - error: roborock.1 Error in getUserData: Login returned empty userdata..
              2026-02-20 23:17:08.688  - error: roborock.1 Failed to process ... : Error: Login returned empty userdata.
              2026-02-20 23:17:08.704  - error: roborock.1 Unhandled promise rejection ...
              2026-02-20 23:17:08.705  - error: roborock.1 TypeError: Cannot read properties of null (reading 'token')
                                                at http_api.initializeRealApi (.../lib/http_api.js:78:22)
                                                at http_api.init (.../lib/http_api.js:32:3)
                                                at Roborock.onReady (.../main.js:55:3)
              2026-02-20 23:17:08.708  - warn: roborock.1 Terminated (UNCAUGHT_EXCEPTION)
              2026-02-20 23:17:09.488  - info: host.<HOST> Restart adapter system.adapter.roborock.1 because enabled
              2026-02-20 23:17:09.488  - warn: host.<HOST> Do not restart adapter ... because restart loop detected
              2026-02-20 23:17:12.648  - info: host.<HOST> "system.adapter.roborock.1" disabled
              • B BamBam89
                node: v22.21.0
                Rückfragen bejahen.
                System:
                - admin 7.7.31
                - nodejs v22.22.0
                Repo: beta
                Thomas BraunT
                Thomas BraunT
                #1018
                @BamBam89
                Und die vollständige und ungekürzte Ausgabe von
                iob diag
                schaut nun wie aus?
                  @BamBam89
                  iob diag
                  schaut nun wie aus?
                  B
                  B
                  BamBam89
                  #1019
                  @BamBam89
                  iob diag
                  schaut nun wie aus?
                  Kurzinfo:
                  - Problem: roborock.1 crasht nach Start (UNCAUGHT_EXCEPTION) und läuft in einen Restart-Loop → wird dann deaktiviert
                  - System: Ubuntu 24.04.4 LTS in LXC (Proxmox-Kernel 6.8.12-9-pve)
                  - ioBroker: js-controller 7.1.0 / admin 7.7.31 / javascript 9.0.18
                  - NodeJS: v22.22.0
                  - Repo: beta
                  - Hinweis: "Listening Ports" und einige dmesg/var Checks konnten nicht ausgeführt werden, weil iob diag dafür sudo braucht (Terminal-Passwortabfrage nicht möglich)
                  --- iob diag (gekürzt auf relevante Stellen, ohne IPs/Secrets) ---
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                  Operating System: Ubuntu 24.04.4 LTS
                  Virtualization  : lxc
                  Kernel          : Linux 6.8.12-9-pve
                  Architecture    : x86-64
                  CPU threads     : 6
                  *** ioBroker-Installation ***
                  Hosts:
                  <HOST> (version: 7.1.0, alive)
                  Core adapters versions:
                  admin:         7.7.31
                  javascript:    9.0.18
                  NodeJS:
                  node:  v22.22.0
                  npm:   10.9.4
                  ✓ Node.js installation is correct
                  Active repo(s): beta
                  Adapter (relevant):
                  roborock: 0.6.19   (Instanz roborock.1 ist aktuell disabled)
                  *** FAILED SERVICES ***
                  (run-rpc_pipefs.mount / sys-kernel-config.mount) -> läuft im LXC erwartbar oft "failed"
                  *** DMESG / Listening Ports ***
                  sudo: a terminal is required to read the password
                  sudo: a password is required
                  => daher hier keine Ausgabe
                  --- Log File - Last 25 Lines (anonymisiert) ---
                  2026-02-20 23:18:31.433  - error: host.<HOST> instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2026-02-20 23:18:31.433  - info: host.<HOST> Restart adapter system.adapter.roborock.1 because enabled
                  2026-02-20 23:18:31.433  - warn: host.<HOST> Do not restart adapter system.adapter.roborock.1 because restart loop detected
                  2026-02-20 23:21:23.661  - info: host.<HOST> "system.adapter.roborock.1" disabled
                  (Weitere Zeilen waren nur Disconnects von iot.0, dwd.0 Termination sowie Web-UI Connects)
                  # iob logs --watch (Auszug roborock.1, anonymisiert)
                  2026-02-20 XX:XX:XX.XXX - info: host.<HOST> "system.adapter.roborock.1" enabled
                  2026-02-20 XX:XX:XX.XXX - info: host.<HOST> instance system.adapter.roborock.1 in version "0.6.19" started
                  2026-02-20 XX:XX:XX.XXX - info: roborock.1 starting... node: v22.22.0, js-controller: 7.1.0
                  2026-02-20 XX:XX:XX.XXX - error: roborock.1 ... (deine konkreten Fehlzeilen)
                  2026-02-20 XX:XX:XX.XXX - error: host.<HOST> instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2026-02-20 XX:XX:XX.XXX - warn: host.<HOST> restart loop detected
                  • B BamBam89
                    @BamBam89
                    iob diag
                    schaut nun wie aus?
                    Kurzinfo:
                    - NodeJS: v22.22.0
                    - Repo: beta
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                    CPU threads     : 6
                    Hosts:
                    admin:         7.7.31
                    javascript:    9.0.18
                    NodeJS:
                    node:  v22.22.0
                    npm:   10.9.4
                    Adapter (relevant):
                    Thomas BraunT
                    Thomas BraunT
                    #1020
                    @BamBam89
                    Du sollst das nicht kürzen.
                      @BamBam89
                      B
                      B
                      BamBam89
                      #1021
                      @BamBam89
                      ```bash
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                       Static hostname: iobroker-hausautomation
                             Icon name: computer-container
                               Chassis: container ☐
                        Virtualization: lxc
                                Kernel: Linux 6.8.12-9-pve
                          Architecture: x86-64
                      OS is similar to: debian
                      model name      : AMD Ryzen 5 4500U with Radeon Graphics
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       23:28:31 up  2:30,  0 user,  load average: 0.99, 1.04, 0.91
                      CPU threads: 6
                      *** LIFE CYCLE STATUS ***
                      Operating System is the current Ubuntu LTS release codenamed 'noble'!
                      *** TIME AND TIMEZONES ***
                                     Local time: Fri 2026-02-20 23:28:31 CET
                                 Universal time: Fri 2026-02-20 22:28:31 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video
                      iobroker
                      HOME=/home/iobroker
                      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                      A root login is not required in most Linux Distributions.
                      Run 'iobroker fix' or use the system tools to create a user.
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:
                      *** MEMORY ***
                      Mem:             16G        3.7G        7.1G        118K        5.3G         12G
                      Swap:           8.6G         61K        8.6G
                      Total:           24G        3.7G         15G
                      Active iob-Instances:   31
                              15427 M total memory
                               3572 M used memory
                               4744 M active memory
                               3385 M inactive memory
                               6786 M free memory
                                  0 M buffer memory
                               5068 M swap cache
                               8191 M total swap
                                  0 M used swap
                               8191 M free swap
                      top - 23:28:31 up  2:30,  0 user,  load average: 0.99, 1.04, 0.91
                      Tasks:  67 total,   1 running,  66 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 10.9 us,  3.1 sy,  0.0 ni, 84.4 id,  0.0 wa,  0.0 hi,  1.6 si,  0.0 st
                      MiB Mem :  15427.7 total,   6784.6 free,   3574.4 used,   5068.9 buff/cache
                      MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.  11853.3 avail Mem
                        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                              SUB    -> The low-level unit activation state, values depend on unit type.
                      2 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
                      No critical errors detected
                      *** FILESYSTEM ***
                      Filesystem                                     Type      Size  Used Avail Use% Mounted on
                      /dev/mapper/Speicher_neu_2025-vm--100--disk--0 ext4      295G   20G  260G   7% /
                      none                                           tmpfs     492K  4.0K  488K   1% /dev
                      efivarfs                                       efivarfs  128K   20K  104K  16% /sys/firmware/efi/efivars
                      none                                           tmpfs     8.0K  4.0K  4.0K  50% /dev/ttyUSB0
                      tmpfs                                          tmpfs     7.6G     0  7.6G   0% /dev/shm
                      tmpfs                                          tmpfs     3.1G  156K  3.1G   1% /run
                      tmpfs                                          tmpfs     5.0M     0  5.0M   0% /run/lock
                      Show mounted filesystems:
                      TARGET SOURCE                                         FSTYPE OPTIONS
                      /      /dev/mapper/Speicher_neu_2025-vm--100--disk--0 ext4   rw,relatime,stripe=16
                      /var:
                      Archived and active journals take up 139.8M in the file system.
                      /opt/iobroker/backups:
                      579M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      599M    /opt/iobroker/iobroker-data/
                      422M    /opt/iobroker/iobroker-data/files
                      136M    /opt/iobroker/iobroker-data/files/vis
                      129M    /opt/iobroker/iobroker-data/files/vis/widgets
                      117M    /opt/iobroker/iobroker-data/files/vis-2
                      26M     /opt/iobroker/iobroker-data/objects.jsonl
                      17M     /opt/iobroker/iobroker-data/states.jsonl.CURRENT_2026-02-20_225805
                      13M     /opt/iobroker/iobroker-data/states.jsonl
                      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                      9.1M    /opt/iobroker/iobroker-data/states.jsonl.OLD_2026-02-20_221928
                      USB-Devices by-id:
                      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                      please always prefer the links 'by-id':
                      /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_<ID>-if00-port0
                      *** ZigBee Settings ***
                      No nvbackup.json found.
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v22.22.0
                      /usr/bin/node           v22.22.0
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Installed: 22.22.0-1nodesource1
                        Candidate: 22.22.0-1nodesource1
                        Version table:
                       *** 22.22.0-1nodesource1 1001
                           22.21.0-1nodesource1 1001
                           22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           18.19.1+dfsg-6ubuntu5 500
                              500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker-hausautomation iobroker-hausautomation (version: 7.1.0, hostname: iobroker-hausautomation, alive, uptime: 1816)
                      admin:          7.7.31
                      javascript:     9.0.18
                      nodejs modules from github:     4
                      +-- iobroker.cameras@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.cameras.git#<TOKEN>)
                      +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#<TOKEN>)
                      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#<TOKEN>)
                      `-- shinobi@1.0.37 (git+ssh://git@github.com/ShinobiCCTV/Shinobi.git#<TOKEN>)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker-hausautomation                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : iobroker-hausautomation                  -  enabled
                      + system.adapter.bestway.0                : bestway               : iobroker-hausautomation                  -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker-hausautomation                  -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker-hausautomation                  -  enabled
                        system.adapter.dwd.0                    : dwd                   : iobroker-hausautomation                  -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-hausautomation                  -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : iobroker-hausautomation                  -  enabled
                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-hausautomation                  -  enabled
                      + system.adapter.followthesun.0           : followthesun          : iobroker-hausautomation                  -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker-hausautomation                  -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-hausautomation                  -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-hausautomation                  -  enabled, port: 0
                      + system.adapter.homeconnect.0            : homeconnect           : iobroker-hausautomation                  -  enabled
                      + system.adapter.hue.0                    : hue                   : iobroker-hausautomation                  -  enabled, port: 80
                      + system.adapter.hue.1                    : hue                   : iobroker-hausautomation                  -  enabled, port: 80
                        system.adapter.ical.0                   : ical                  : iobroker-hausautomation                  -  enabled
                        system.adapter.ical.1                   : ical                  : iobroker-hausautomation                  -  enabled
                        system.adapter.ical.2                   : ical                  : iobroker-hausautomation                  -  enabled
                        system.adapter.ical.3                   : ical                  : iobroker-hausautomation                  -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker-hausautomation                  -  enabled, port: 8086
                      + system.adapter.iot.0                    : iot                   : iobroker-hausautomation                  -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker-hausautomation                  -  enabled
                      + system.adapter.modbus.0                 : modbus                : iobroker-hausautomation                  -  enabled
                        system.adapter.mqtt.0                   : mqtt                  : iobroker-hausautomation                  - disabled, port: 1883, bind: 0.0.0.0
                        system.adapter.owntracks.0              : owntracks             : iobroker-hausautomation                  - disabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.procon-ip.0              : procon-ip             : iobroker-hausautomation                  -  enabled
                      + system.adapter.reolink.0                : reolink               : iobroker-hausautomation                  -  enabled
                      + system.adapter.reolink.1                : reolink               : iobroker-hausautomation                  -  enabled
                        system.adapter.robonect.0               : robonect              : iobroker-hausautomation                  - disabled
                        system.adapter.roborock.1               : roborock              : iobroker-hausautomation                  - disabled
                      + system.adapter.shelly.1                 : shelly                : iobroker-hausautomation                  -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.shelly.2                 : shelly                : iobroker-hausautomation                  -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.sma-em.0                 : sma-em                : iobroker-hausautomation                  -  enabled
                      + system.adapter.sonoff.0                 : sonoff                : iobroker-hausautomation                  -  enabled, port: 1883, bind: <IP>
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker-hausautomation                  -  enabled
                        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker-hausautomation                  -  enabled
                        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker-hausautomation                  -  enabled
                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker-hausautomation                  -  enabled
                        system.adapter.vis-2-widgets-ovarious.0 : vis-2-widgets-ovarious: iobroker-hausautomation                  -  enabled
                      + system.adapter.vis-2.0                  : vis-2                 : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-hausautomation                  -  enabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker-hausautomation                  -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-hausautomation                  -  enabled
                        system.adapter.vis.0                    : vis                   : iobroker-hausautomation                  -  enabled
                      + system.adapter.web.0                    : web                   : iobroker-hausautomation                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-hausautomation                  -  enabled
                        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker-hausautomation                  - disabled
                      + instance is alive
                      ioBroker-Repositories
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: beta
                      Adapter    "admin"        : 7.7.31   , installed 7.7.31
                      Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                      Adapter    "bestway"      : 0.0.5    , installed 0.0.5
                      Adapter    "cameras"      : 2.1.2    , installed 2.1.2
                      Adapter    "daswetter"    : 4.5.1    , installed 3.2.8  [Updatable]
                      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                      Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
                      Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                      Adapter    "followthesun" : 0.5.2    , installed 0.5.2
                      Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
                      Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
                      Adapter    "hue"          : 3.16.2   , installed 3.16.2
                      Adapter    "ical"         : 1.19.5   , installed 1.19.5
                      Adapter    "iot"          : 5.0.12   , installed 5.0.12
                      Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                      Controller "js-controller": 7.1.0    , installed 7.1.0
                      Adapter    "modbus"       : 8.0.3    , installed 7.0.6  [Updatable]
                      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                      Adapter    "owntracks"    : 1.1.0    , installed 1.1.0
                      Adapter    "procon-ip"    : 1.7.0    , installed 1.7.0
                      Adapter    "reolink"      : 1.3.0    , installed 1.3.0
                      Adapter    "robonect"     : 1.4.2    , installed 1.4.2
                      Adapter    "roborock"     : 0.6.19   , installed 0.6.19
                      Adapter    "shelly"       : 10.6.0   , installed 10.6.0
                      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                      Adapter    "sma-em"       : 1.3.0    , installed 1.3.0
                      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                      Adapter    "trashschedule": 5.2.1    , installed 5.2.1
                      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                      Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
                      Adapter    "vis-2-widgets-collection": 2.3.3, installed 2.3.3
                      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                      Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
                      Adapter    "vis-2-widgets-inventwo": 0.5.8, installed 0.5.8
                      Adapter    "vis-2-widgets-jaeger-design": 1.4.18, installed 1.4.18
                      Adapter    "vis-2-widgets-material": 1.6.0, installed 1.6.0
                      Adapter    "vis-2-widgets-ovarious": 2.0.0, installed 2.0.0
                      Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
                      Adapter    "vis-icontwo"  : 2.9.0    , installed 1.18.0 [Updatable]
                      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                      Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                      Adapter    "web"          : 8.0.0    , installed 8.0.0
                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                      Adapter    "ws"           : 4.0.0    , installed 4.0.0
                      Adapter    "yr"           : 5.3.0    , installed 5.3.0
                      Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
                      Objects and States
                      Objects:        15262
                      States:         13490
                      Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
                      Hit:2 https://apt.grafana.com stable InRelease
                      Hit:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                      Hit:4 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                      Get:5 https://repos.influxdata.com/debian stable InRelease [6913 B]
                      Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Hit:7 http://security.ubuntu.com/ubuntu noble-security InRelease
                      Fetched 6913 B in 0s (14.9 kB/s)
                      Reading package lists...
                      Pending systemupdates: 0
                      *** Listening Ports ***
                      2026-02-20 23:18:31.433  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2026-02-20 23:18:31.433  - info: host.iobroker-hausautomation Restart adapter system.adapter.roborock.1 because enabled
                      2026-02-20 23:18:31.433  - warn: host.iobroker-hausautomation Do not restart adapter system.adapter.roborock.1 because restart loop detected
                      2026-02-20 23:19:30.129  - info: iot.0 (22003) Connection changed: disconnect
                      2026-02-20 23:20:37.010  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 in version "2.8.5" started with pid 24410
                      2026-02-20 23:20:37.972  - info: dwd.0 (24410) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
                      2026-02-20 23:20:38.263  - info: dwd.0 (24410) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2026-02-20 23:20:38.780  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 having pid 24410 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2026-02-20 23:21:23.661  - info: host.iobroker-hausautomation "system.adapter.roborock.1" disabled
                      2026-02-20 23:21:38.277  - info: iot.0 (22003) Connection changed: disconnect
                      2026-02-20 23:22:51.564  - info: sonoff.0 (21734) Client [Tasmota_Kühlschrank Nebenraum] connected with secret <TOKEN>
                      2026-02-20 23:22:53.974  - info: web.0 (21957) ==> Connected system.user.admin from <IP>
                      2026-02-20 23:22:55.077  - info: web.0 (21957) ==> Connected system.user.admin from <IP>
                      2026-02-20 23:23:01.744  - info: web.0 (21957) <== Disconnect system.user.admin from <IP> energiefluss-erweitert.0
                      2026-02-20 23:23:01.765  - info: web.0 (21957) <== Disconnect system.user.admin from <IP> vis.0
                      2026-02-20 23:23:01.860  - info: web.0 (21957) ==> Connected system.user.admin from <IP>
                      2026-02-20 23:23:06.870  - info: sonoff.0 (21734) Client [Tasmota_Kühlschrank Nebenraum] connection closed: closed
                      2026-02-20 23:23:14.338  - info: web.0 (21957) <== Disconnect system.user.admin from <IP> vis.0
                      2026-02-20 23:23:46.424  - info: iot.0 (22003) Connection changed: disconnect
                      2026-02-20 23:25:37.010  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 in version "2.8.5" started with pid 24510
                      2026-02-20 23:25:37.978  - info: dwd.0 (24510) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
                      2026-02-20 23:25:38.276  - info: dwd.0 (24510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2026-02-20 23:25:38.792  - info: host.iobroker-hausautomation instance system.adapter.dwd.0 having pid 24510 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2026-02-20 23:25:54.566  - info: iot.0 (22003) Connection changed: disconnect
                      2026-02-20 23:28:07.728  - info: iot.0 (22003) Connection changed: disconnect
                      ```bash
                      root@iobroker-hausautomation:/opt/iobroker# sudo -u iobroker iob logs --watch --no-color | tee /tmp/iob_watch.log
                      2026-02-20 23:06:09.654  - debug: roborock.1 (22406) Redis Objects: Use Redis connection: <IP>:9001
                      2026-02-20 23:06:09.668  - debug: roborock.1 (22406) Objects client ready ... initialize now
                      2026-02-20 23:06:09.669  - debug: roborock.1 (22406) Objects create System PubSub Client
                      2026-02-20 23:06:09.669  - debug: roborock.1 (22406) Objects create User PubSub Client
                      2026-02-20 23:06:09.693  - debug: roborock.1 (22406) Objects client initialize lua scripts
                      2026-02-20 23:06:09.695  - debug: roborock.1 (22406) Objects connected to redis: <IP>:9001
                      2026-02-20 23:06:09.711  - debug: roborock.1 (22406) Redis States: Use Redis connection: <IP>:9000
                      2026-02-20 23:06:09.719  - debug: roborock.1 (22406) States create System PubSub Client
                      2026-02-20 23:06:09.720  - debug: roborock.1 (22406) States create User PubSub Client
                      2026-02-20 23:06:09.776  - debug: roborock.1 (22406) States connected to redis: <IP>:9000
                      2026-02-20 23:06:09.791  - debug: roborock.1 (22406) Plugin sentry Initialize Plugin (enabled=true)
                      2026-02-20 23:06:10.200  - error: roborock.1 (22406) adapter disabled
                      2026-02-20 23:06:10.244  - debug: roborock.1 (22406) Plugin sentry destroyed
                      2026-02-20 23:06:10.244  - warn: roborock.1 (22406) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                      2026-02-20 23:06:10.777  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                      2026-02-20 23:06:10.777  - info: host.iobroker-hausautomation Do not restart adapter system.adapter.roborock.1 because disabled or deleted
                      2026-02-20 23:10:16.972  - info: host.iobroker-hausautomation "system.adapter.roborock.1" enabled
                      2026-02-20 23:10:17.331  - info: host.iobroker-hausautomation instance system.adapter.roborock.1 in version "0.6.19" started with pid 22456
                      2026-02-20 23:10:17.862  - debug: roborock.1 (22456) Redis Objects: Use Redis connection: <IP>:9001
                      2026-02-20 23:10:17.878  - debug: roborock.1 (22456) Objects client ready ... initialize now
                      2026-02-20 23:10:17.879  - debug: roborock.1 (22456) Objects create System PubSub Client
                      2026-02-20 23:10:17.879  - debug: roborock.1 (22456) Objects create User PubSub Client
                      2026-02-20 23:10:17.905  - debug: roborock.1 (22456) Objects client initialize lua scripts
                      2026-02-20 23:10:17.908  - debug: roborock.1 (22456) Objects connected to redis: <IP>:9001
                      2026-02-20 23:10:17.926  - debug: roborock.1 (22456) Redis States: Use Redis connection: <IP>:9000
                      2026-02-20 23:10:17.934  - debug: roborock.1 (22456) States create System PubSub Client
                      2026-02-20 23:10:17.935  - debug: roborock.1 (22456) States create User PubSub Client
                      2026-02-20 23:10:17.990  - debug: roborock.1 (22456) States connected to redis: <IP>:9000
                      2026-02-20 23:10:18.011  - debug: roborock.1 (22456) Plugin sentry Initialize Plugin (enabled=true)
                      2026-02-20 23:10:18.454  - info: roborock.1 (22456) starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.22.0, js-controller: 7.1.0
                      2026-02-20 23:10:18.462  - info: roborock.1 (22456) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                      2026-02-20 23:10:18.467  - info: roborock.1 (22456) Loaded existing clientID: <TOKEN>
                      2026-02-20 23:10:18.469  - debug: roborock.1 (22456) initialize http_api
                      2026-02-20 23:10:18.555  - error: roborock.1 (22456) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
                      2026-02-20 23:10:18.559  - warn: roborock.1 (22456) State "roborock.1.HomeData" has no existing object, this might lead to an error in future versions
                      2026-02-20 23:10:18.600  - warn: roborock.1 (22456) State "roborock.1.UserData" has no existing object, this might lead to an error in future versions
                      2026-02-20 23:10:18.644  - error: roborock.1 (22456) Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata.
                      2026-02-20 23:10:18.659  - error: roborock.1 (22456) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2026-02-20 23:10:18.659  - error: roborock.1 (22456) unhandled promise rejection: Cannot read properties of null (reading 'token')
                      2026-02-20 23:10:18.659  - error: roborock.1 (22456) TypeError: Cannot read properties of null (reading 'token')
                      2026-02-20 23:10:18.659  - error: roborock.1 (22456) Cannot read properties of null (reading 'token')
                      2026-02-20 23:10:18.661  - info: roborock.1 (22456) terminating
                      2026-02-20 23:10:18.662  - debug: roborock.1 (22456) Plugin sentry destroyed
                      2026-02-20 23:10:18.662  - warn: roborock.1 (22456) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2026-02-20 23:10:19.163  - info: roborock.1 (22456) terminating
                      2026-02-20 23:10:19.196  - error: host.iobroker-hausautomation Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]: TypeError: Cannot read properties of null (reading 'token')
                      2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22)
                      2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at processTicksAndRejections (node:internal/process/task_queues:105:5)
                      2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3)
                      2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation Caught by controller[1]:     at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
                      2026-02-20 23:10:19.197  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2026-02-20 23:10:19.197  - info: host.iobroker-hausautomation Restart adapter system.adapter.roborock.1 because enabled
                      2026-02-20 23:10:22.094  - info: host.iobroker-hausautomation "system.adapter.roborock.1" disabled
                      ^C
                      • B BamBam89
                        @BamBam89
                        ```bash
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 6
                                         RTC time: n/a
                                  RTC in local TZ: no
                        iobroker
                        HOME=/home/iobroker
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:
                        *** MEMORY ***
                        Swap:           8.6G         61K        8.6G
                        Total:           24G        3.7G         15G
                                 3572 M used memory
                                 6786 M free memory
                                    0 M buffer memory
                                 5068 M swap cache
                                 8191 M total swap
                                    0 M used swap
                                 8191 M free swap
                        *** FILESYSTEM ***
                        /var:
                        USB-Devices by-id:
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.31
                        javascript:     9.0.18
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        15262
                        States:         13490
                        ```bash
                        ^C
                        Thomas BraunT
                        Thomas BraunT
                        #1022
                        @BamBam89
                        Zum einen: Hampel da nicht als root herum. Leg dir einen Standarduser an.
                        Siehe auch:
                        Der Text steht da nicht zum Spaß.
                        Dann würde auch der Rest mit dem sudo richtig funktionieren.
                          @BamBam89
                          Siehe auch:
                          B
                          B
                          BamBam89
                          #1023
                          @BamBam89
                          Siehe auch:
                          ```bash
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                           Static hostname: <HOSTNAME>
                                   Chassis: container
                            Virtualization: lxc
                                    Kernel: Linux <KERNEL>
                          model name      : <CPU_MODEL>
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           23:54:09 up  2:55,  0 user,  load average: 0.92, 0.85, 0.72
                          CPU threads: 6
                                         Local time: Fri 2026-02-20 23:54:09 CET
                                     Universal time: Fri 2026-02-20 22:54:09 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          iobroker
                          HOME=/home/iobroker
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:
                          *** MEMORY ***
                          Mem:             16G        3.8G        7.0G        122K        5.3G         12G
                          Swap:           8.6G         61K        8.6G
                          Total:           24G        3.8G         15G
                                   3638 M used memory
                                   4816 M active memory
                                   3381 M inactive memory
                                   6716 M free memory
                                      0 M buffer memory
                                   5073 M swap cache
                                   8191 M total swap
                                      0 M used swap
                                   8191 M free swap
                          top - 23:54:10 up  2:55,  0 user,  load average: 0.92, 0.85, 0.72
                          Tasks:  70 total,   1 running,  69 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 11.1 us,  4.8 sy,  0.0 ni, 84.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  15427.7 total,   6714.6 free,   3639.8 used,   5073.5 buff/cache
                          MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.  11787.9 avail Mem
                          [sudo] password for iobroker:
                          dmesg: read kernel buffer failed: Operation not permitted
                          *** FILESYSTEM ***
                          /dev/mapper/<DISK_MAPPER>                      ext4      295G   20G  260G   7% /
                          tmpfs                                          tmpfs     3.1G  160K  3.1G   1% /run
                          /      /dev/mapper/<DISK_MAPPER> ext4   rw,relatime,stripe=16
                          /var:
                          4.0G    /var/
                          1.8G    /var/lib
                          1.4G    /var/cache/apt
                          1.4G    /var/cache
                          1.3G    /var/cache/apt/archives
                          595M    /opt/iobroker/iobroker-data/
                          find: Failed to change directory: /home/<USER>: Permission denied
                          find: Failed to restore initial working directory: /home/<USER>: Permission denied
                          USB-Devices by-id:
                          /dev/serial/by-id/<USB_ID>
                          /usr/bin/npm            10.9.4
                          /usr/bin/npx            10.9.4
                          nodejs:
                            Version table:
                               ... (unchanged)
                          (ASCII-Banner unverändert)
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          <HOSTNAME> <HOSTNAME> (version: 7.1.0, hostname: <HOSTNAME>, alive, uptime: 3376)
                          admin:          7.7.31
                          javascript:     9.0.18
                          +-- iobroker.cameras@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.cameras.git#<GIT_HASH>)
                          +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#<GIT_HASH>)
                          +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#<GIT_HASH>)
                          `-- shinobi@1.0.37 (git+ssh://git@github.com/ShinobiCCTV/Shinobi.git#<GIT_HASH>)
                          (Adapter-Liste unverändert – keine sensiblen Daten außer Hostname/IP, daher Hostname bleibt als <HOSTNAME>.)
                          ... (restlicher Inhalt unverändert) ...
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          56128727   1/systemd
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          56381801   1/systemd
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          56131871   678/master
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       56663637   21548/iobroker.js-c
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       56664546   21548/iobroker.js-c
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       56670869   21878/io.shelly.2
                          tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      111        56129281   266/mosquitto
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        56378887   11744/systemd-resol
                          tcp        0      0 127.0.0.1:37227         0.0.0.0:*               LISTEN      0          56377267   11673/containerd
                          tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        56378889   11744/systemd-resol
                          tcp        0      0 <IP>:1883               0.0.0.0:*               LISTEN      1000       56665025   21734/io.sonoff.0
                          tcp        0      0 <IP>:2001               0.0.0.0:*               LISTEN      1000       56669368   21750/io.hm-rpc.0
                          tcp        0      0 <IP>:2010               0.0.0.0:*               LISTEN      1000       56670540   21766/io.hm-rpc.1
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          56128729   1/systemd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          56381802   1/systemd
                          tcp6       0      0 :::3000                 :::*                    LISTEN      109        56430463   15307/grafana
                          tcp6       0      0 ::1:1883                :::*                    LISTEN      111        56129282   266/mosquitto
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          56131872   678/master
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       56674802   21957/io.web.0
                          tcp6       0      0 :::8080                 :::*                    LISTEN      0          56132247   911/node
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       56665829   21567/io.admin.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      108        56131275   327/influxd
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       56667951   21713/io.shelly.1
                          udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        56378888   11744/systemd-resol
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        56378886   11744/systemd-resol
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          56128728   1/systemd
                          udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1000       56664800   21682/io.sma-em.0
                          udp6       0      0 :::111                  :::*                                0          56128730   1/systemd
                          2026-02-20 23:40:48.125  - info: web.0 (21957) ==> Connected system.user.admin from ::ffff:<IP>
                          2026-02-20 23:40:52.003  - info: web.0 (21957) ==> Connected system.user.admin from ::ffff:<IP>
                          2026-02-20 23:40:52.664  - info: web.0 (21957) ==> Connected system.user.admin from ::ffff:<IP>
                          2026-02-20 23:40:56.667  - info: iot.0 (22003) Connection changed: disconnect
                          2026-02-20 23:43:04.812  - info: iot.0 (22003) Connection changed: disconnect
                          2026-02-20 23:45:12.960  - info: iot.0 (22003) Connection changed: disconnect
                          2026-02-20 23:45:21.010  - info: host.<HOSTNAME> instance system.adapter.daswetter.0 in version "3.2.8" started with pid 27305
                          2026-02-20 23:45:22.012  - warn: daswetter.0 (27305) This instance has 6362 objects, the limit for this instance is set to 5000.
                          2026-02-20 23:45:22.014  - info: daswetter.0 (27305) starting. Version 3.2.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.22.0, js-controller: 7.1.0
                          2026-02-20 23:45:25.842  - info: daswetter.0 (27305) still wrong data structure from server received! repaired...
                          2026-02-20 23:45:26.860  - info: daswetter.0 (27305) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                          2026-02-20 23:45:27.364  - info: daswetter.0 (27305) cleaned everything up...
                          2026-02-20 23:45:27.374  - info: host.<HOSTNAME> instance system.adapter.daswetter.0 having pid 27305 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2026-02-20 23:45:37.010  - info: host.<HOSTNAME> instance system.adapter.dwd.0 in version "2.8.5" started with pid 27321
                          2026-02-20 23:45:37.958  - info: dwd.0 (27321) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
                          2026-02-20 23:45:38.246  - info: dwd.0 (27321) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2026-02-20 23:45:38.760  - info: host.<HOSTNAME> instance system.adapter.dwd.0 having pid 27321 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2026-02-20 23:47:21.228  - info: iot.0 (22003) Connection changed: disconnect
                          2026-02-20 23:49:29.493  - info: iot.0 (22003) Connection changed: disconnect
                          2026-02-20 23:50:37.009  - info: host.<HOSTNAME> instance system.adapter.dwd.0 in version "2.8.5" started with pid 27349
                          2026-02-20 23:50:37.981  - info: dwd.0 (27349) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.0, js-controller: 7.1.0
                          2026-02-20 23:50:38.318  - info: dwd.0 (27349) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2026-02-20 23:50:38.833  - info: host.<HOSTNAME> instance system.adapter.dwd.0 having pid 27349 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2026-02-20 23:51:37.641  - info: iot.0 (22003) Connection changed: disconnect
                          2026-02-20 23:53:45.785  - info: iot.0 (22003) Connection changed: disconnect
                          2026-02-21 00:04:03.169  - info: host.<HOST> "system.adapter.roborock.1" enabled
                          2026-02-21 00:04:03.456  - info: host.<HOST> instance system.adapter.roborock.1 in version "0.6.19" started with pid 29408
                          2026-02-21 00:04:04.078  - debug: roborock.1 (29408) Redis Objects: Use Redis connection: <IP_LOCAL>:9001
                          2026-02-21 00:04:04.093  - debug: roborock.1 (29408) Objects client ready ... initialize now
                          2026-02-21 00:04:04.093  - debug: roborock.1 (29408) Objects create System PubSub Client
                          2026-02-21 00:04:04.094  - debug: roborock.1 (29408) Objects create User PubSub Client
                          2026-02-21 00:04:04.119  - debug: roborock.1 (29408) Objects client initialize lua scripts
                          2026-02-21 00:04:04.121  - debug: roborock.1 (29408) Objects connected to redis: <IP_LOCAL>:9001
                          2026-02-21 00:04:04.136  - debug: roborock.1 (29408) Redis States: Use Redis connection: <IP_LOCAL>:9000
                          2026-02-21 00:04:04.144  - debug: roborock.1 (29408) States create System PubSub Client
                          2026-02-21 00:04:04.145  - debug: roborock.1 (29408) States create User PubSub Client
                          2026-02-21 00:04:04.199  - debug: roborock.1 (29408) States connected to redis: <IP_LOCAL>:9000
                          2026-02-21 00:04:04.215  - debug: roborock.1 (29408) Plugin sentry Initialize Plugin (enabled=true)
                          2026-02-21 00:04:04.666  - info: roborock.1 (29408) starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.22.0, js-controller: 7.1.0
                          2026-02-21 00:04:04.676  - info: roborock.1 (29408) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                          2026-02-21 00:04:04.685  - info: roborock.1 (29408) Loaded existing clientID: <CLIENT_ID>
                          2026-02-21 00:04:04.686  - debug: roborock.1 (29408) initialize http_api
                          2026-02-21 00:04:04.812  - error: roborock.1 (29408) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
                          2026-02-21 00:04:04.814  - warn: roborock.1 (29408) State "roborock.1.HomeData" has no existing object, this might lead to an error in future versions
                          2026-02-21 00:04:04.856  - warn: roborock.1 (29408) State "roborock.1.UserData" has no existing object, this might lead to an error in future versions
                          2026-02-21 00:04:04.900  - error: roborock.1 (29408) Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata.
                          2026-02-21 00:04:04.915  - error: roborock.1 (29408) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2026-02-21 00:04:04.915  - error: roborock.1 (29408) unhandled promise rejection: Cannot read properties of null (reading 'token')
                          2026-02-21 00:04:04.915  - error: roborock.1 (29408) TypeError: Cannot read properties of null (reading 'token')
                          2026-02-21 00:04:04.915  - error: roborock.1 (29408) Cannot read properties of null (reading 'token')
                          2026-02-21 00:04:04.917  - info: roborock.1 (29408) terminating
                          2026-02-21 00:04:04.918  - debug: roborock.1 (29408) Plugin sentry destroyed
                          2026-02-21 00:04:04.918  - warn: roborock.1 (29408) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2026-02-21 00:04:05.419  - info: roborock.1 (29408) terminating
                          2026-02-21 00:04:05.420  - info: roborock.1 (29408) terminating
                          2026-02-21 00:04:05.454  - error: host.<HOST> Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]: TypeError: Cannot read properties of null (reading 'token')
                          2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22)
                          2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at processTicksAndRejections (node:internal/process/task_queues:105:5)
                          2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3)
                          2026-02-21 00:04:05.455  - error: host.<HOST> Caught by controller[0]:     at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
                          2026-02-21 00:04:05.455  - error: host.<HOST> instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2026-02-21 00:04:05.455  - info: host.<HOST> Restart adapter system.adapter.roborock.1 because enabled
                          2026-02-21 00:04:08.914  - info: host.<HOST> "system.adapter.roborock.1" disabled
                          Thomas BraunT haselchenH 2 Antworten Letzte Antwort
                          • B BamBam89
                            @BamBam89
                            Siehe auch:
                            ```bash
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 6
                                             RTC time: n/a
                                      RTC in local TZ: no
                            iobroker
                            HOME=/home/iobroker
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:
                            *** MEMORY ***
                            Swap:           8.6G         61K        8.6G
                            Total:           24G        3.8G         15G
                                     3638 M used memory
                                     6716 M free memory
                                        0 M buffer memory
                                     5073 M swap cache
                                     8191 M total swap
                                        0 M used swap
                                     8191 M free swap
                            *** FILESYSTEM ***
                            /var:
                            4.0G    /var/
                            1.8G    /var/lib
                            1.4G    /var/cache/apt
                            1.4G    /var/cache
                            USB-Devices by-id:
                            /usr/bin/npm            10.9.4
                            /usr/bin/npx            10.9.4
                            nodejs:
                              Version table:
                                 ... (unchanged)
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.7.31
                            javascript:     9.0.18
                            Thomas BraunT
                            Thomas BraunT
                            #1024
                            Ist das jetzt nach seinen Wünschen?
                            Es geht nicht 'nach meinen Wünschen', es geht darum das System grundsätzlich richtig zu verwenden.
                            Du bist da immer noch nicht als Standarduser aktiv. Der user 'iobroker' ist als Systemuser vorgesehen.
                            Ich bin dann aus der Nummer raus...
                            • B BamBam89
                              @BamBam89
                              Siehe auch:
                              ```bash
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 6
                                               RTC time: n/a
                                        RTC in local TZ: no
                              iobroker
                              HOME=/home/iobroker
                              iobroker
                              HOME=/home/iobroker
                              Display-Manager:
                              Desktop:
                              Session:
                              *** MEMORY ***
                              Swap:           8.6G         61K        8.6G
                              Total:           24G        3.8G         15G
                                       3638 M used memory
                                       6716 M free memory
                                          0 M buffer memory
                                       5073 M swap cache
                                       8191 M total swap
                                          0 M used swap
                                       8191 M free swap
                              *** FILESYSTEM ***
                              /var:
                              4.0G    /var/
                              1.8G    /var/lib
                              1.4G    /var/cache/apt
                              1.4G    /var/cache
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.4
                              /usr/bin/npx            10.9.4
                              nodejs:
                                Version table:
                                   ... (unchanged)
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.7.31
                              javascript:     9.0.18
                              haselchenH
                              haselchenH
                              haselchen
                              #1025
                              @BamBam89
                              Zudem benutzen shelly.1 und sonoff.0 beide den Port 1883
                              Das solltest Du auch ändern.
                                B
                                B
                                BamBam89
                                #1026
                                Sorry das hatte aber nichts mit dir zu tun.
                                Ich hab hier 3 Baustellen gleichzeit. Ich bin ja froh wenn mich jemand unterstützt der mehr Ahnung vn der Materie hat. Was im übrigen nicht schwer ist.
                                Ich weiß ehrlicherweise noch nicht was ich falsch mache. Angemeldet bin ich aber als
                                BamBam89@iobroker-hausautomation:~$
                                @haselchen sagte in Neuer Adapter für Roborock-Staubsauger:
                                @BamBam89
                                Vielen Dank für den Hinweis. Das werde ich korrigieren.
                                • B BamBam89
                                  @BamBam89
                                  Thomas BraunT
                                  Thomas BraunT
                                  #1027
                                  @BamBam89
                                  Dann ruf das Skript auch als dieser user auf. Du springst warum auch immer in den iobroker:
                                  iobroker
                                  B 2 Antworten Letzte Antwort
                                    @BamBam89
                                    iobroker
                                    B
                                    B
                                    BamBam89
                                    #1028
                                    @BamBam89
                                    iobroker
                                    Ok vielen Dank
                                    Ich schau mir das morgen früh mal an und hoffe das ich dann die richtigen Daten bereitstellen kann.
                                      @BamBam89
                                      iobroker
                                      B
                                      B
                                      BamBam89
                                      #1029
                                      @BamBam89
                                      iobroker
                                      Guten Morgen,
                                      so ein neuer Versuch. Ich hoffe das passt nun.
                                      Script v.2026-01-31
                                      *** BASE SYSTEM ***
                                        Virtualization: lxc
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       08:11:46 up 11:13,  0 user,  load average: 0.81, 0.53, 0.56
                                      CPU threads: 6
                                                     Local time: Sat 2026-02-21 08:11:46 CET
                                                 Universal time: Sat 2026-02-21 07:11:46 UTC
                                                       RTC time: n/a
                                                RTC in local TZ: no
                                      BamBam89
                                      HOME=/home/BamBam89
                                      GROUPS=BamBam89 adm dialout sudo audio video plugdev users iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      Display-Manager:
                                      Desktop:
                                      Session:
                                      *** MEMORY ***
                                      Mem:             16G        4.0G        8.6G        106K        3.6G         12G
                                      Swap:           8.6G         77K        8.6G
                                      Total:           24G        4.0G         17G
                                               3804 M used memory
                                               3270 M active memory
                                               3571 M inactive memory
                                               8174 M free memory
                                                  0 M buffer memory
                                               3448 M swap cache
                                               8191 M total swap
                                                  0 M used swap
                                               8191 M free swap
                                      top - 08:11:47 up 11:13,  0 user,  load average: 0.81, 0.53, 0.56
                                      Tasks:  68 total,   1 running,  67 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s): 11.7 us,  0.0 sy,  0.0 ni, 86.7 id,  0.0 wa,  0.0 hi,  1.7 si,  0.0 st
                                      MiB Mem :  15427.7 total,   8173.1 free,   3806.1 used,   3448.6 buff/cache
                                      MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.  11621.6 avail Mem
                                      *** FILESYSTEM ***
                                      /var:
                                      4.0G    /var/
                                      1.8G    /var/lib
                                      1.4G    /var/cache/apt
                                      1.4G    /var/cache
                                      Archived and active journals take up 869.1M in the file system.
                                      541M    /opt/iobroker/backups/
                                      602M    /opt/iobroker/iobroker-data/
                                      21M     /opt/iobroker/iobroker-data/objects.jsonl
                                      20M     /opt/iobroker/iobroker-data/states.jsonl
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_327e0f98dfc2ef11aad7e6b08048b910-if00-port0
                                      /usr/bin/npm            10.9.4
                                      /usr/bin/npx            10.9.4
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker-hausautomation iobroker-hausautomation (version: 7.1.0, hostname: iobroker-hausautomation, alive, uptime: 33227)
                                      admin:          7.7.31
                                      javascript:     9.0.18
                                      +-- iobroker.cameras@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.cameras.git#939aa16d253f5365c8e6ee3280cb0aebfe6b458b)
                                      +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)
                                      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                      `-- shinobi@1.0.37 (git+ssh://git@github.com/ShinobiCCTV/Shinobi.git#984deef28caef29d36ae2b27ae6da2fd44b8a5b7)
                                      Adapter State
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker-hausautomation                  -  enabled, port: 1883, bind: 192.168.1.10
                                      + instance is alive
                                      Objects and States
                                      Objects:        15269
                                      States:         13497
                                      Hit:1 https://apt.grafana.com stable InRelease
                                      Get:2 https://repos.influxdata.com/debian stable InRelease [6913 B]
                                      Hit:3 https://deb.nodesource.com/node_22.x nodistro InRelease
                                      Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
                                      Hit:5 http://archive.ubuntu.com/ubuntu noble InRelease
                                      Hit:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                                      Hit:7 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                                      Fetched 6913 B in 1s (12.8 kB/s)
                                      tcp        0      0 192.168.1.10:1883       0.0.0.0:*               LISTEN      1000       56665025   21734/io.sonoff.0
                                      tcp        0      0 192.168.1.10:2001       0.0.0.0:*               LISTEN      1000       56669368   21750/io.hm-rpc.0
                                      tcp        0      0 192.168.1.10:2010       0.0.0.0:*               LISTEN      1000       56670540   21766/io.hm-rpc.1
                                      2026-02-21 08:11:48.408  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:49.465  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:50.562  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:51.579  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:52.635  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:53.692  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:54.747  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:55.800  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:56.858  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:57.911  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:11:58.965  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:00.102  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:01.078  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:02.134  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:03.473  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:04.245  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:05.809  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:06.360  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:07.414  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:08.491  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:09.521  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:10.579  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:11.634  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:12.690  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      2026-02-21 08:12:13.745  - info: javascript.0 (21635) script.js.common.2025_KI_.Berechnung_Speichersimulation_Dashboard_Tag_Monat_Jahr: [PV-Aggregation] Berechnung abgeschlossen (KW=8, M=2, J=2026)
                                      iob diag has finished.
                                      2026-02-21 08:22:27.297  - info: host.iobroker-hausautomation "system.adapter.roborock.1" enabled
                                      2026-02-21 08:22:27.643  - info: host.iobroker-hausautomation instance system.adapter.roborock.1 in version "0.6.19" started with pid 34380
                                      2026-02-21 08:22:28.416  - debug: roborock.1 (34380) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2026-02-21 08:22:28.433  - debug: roborock.1 (34380) Objects client ready ... initialize now
                                      2026-02-21 08:22:28.434  - debug: roborock.1 (34380) Objects create System PubSub Client
                                      2026-02-21 08:22:28.434  - debug: roborock.1 (34380) Objects create User PubSub Client
                                      2026-02-21 08:22:28.459  - debug: roborock.1 (34380) Objects client initialize lua scripts
                                      2026-02-21 08:22:28.461  - debug: roborock.1 (34380) Objects connected to redis: 127.0.0.1:9001
                                      2026-02-21 08:22:28.477  - debug: roborock.1 (34380) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2026-02-21 08:22:28.486  - debug: roborock.1 (34380) States create System PubSub Client
                                      2026-02-21 08:22:28.487  - debug: roborock.1 (34380) States create User PubSub Client
                                      2026-02-21 08:22:28.543  - debug: roborock.1 (34380) States connected to redis: 127.0.0.1:9000
                                      2026-02-21 08:22:28.561  - debug: roborock.1 (34380) Plugin sentry Initialize Plugin (enabled=true)
                                      2026-02-21 08:22:29.020  - info: roborock.1 (34380) starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.22.0, js-controller: 7.1.0
                                      2026-02-21 08:22:29.031  - info: roborock.1 (34380) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                      2026-02-21 08:22:29.036  - info: roborock.1 (34380) Loaded existing clientID: a59f15a6-b0ac-4933-ad28-5ab3bc15f837
                                      2026-02-21 08:22:29.037  - debug: roborock.1 (34380) initialize http_api
                                      2026-02-21 08:22:29.157  - error: roborock.1 (34380) Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
                                      2026-02-21 08:22:29.158  - warn: roborock.1 (34380) State "roborock.1.HomeData" has no existing object, this might lead to an error in future versions
                                      2026-02-21 08:22:29.201  - warn: roborock.1 (34380) State "roborock.1.UserData" has no existing object, this might lead to an error in future versions
                                      2026-02-21 08:22:29.245  - error: roborock.1 (34380) Failed to process undefined on robot undefined (unknown device model): Error: Login returned empty userdata.
                                      2026-02-21 08:22:29.263  - error: roborock.1 (34380) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2026-02-21 08:22:29.263  - error: roborock.1 (34380) unhandled promise rejection: Cannot read properties of null (reading 'token')
                                      2026-02-21 08:22:29.263  - error: roborock.1 (34380) TypeError: Cannot read properties of null (reading 'token')
                                      2026-02-21 08:22:29.263  - error: roborock.1 (34380) Cannot read properties of null (reading 'token')
                                      2026-02-21 08:22:29.265  - info: roborock.1 (34380) terminating
                                      2026-02-21 08:22:29.266  - debug: roborock.1 (34380) Plugin sentry destroyed
                                      2026-02-21 08:22:29.266  - warn: roborock.1 (34380) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2026-02-21 08:22:29.766  - info: roborock.1 (34380) terminating
                                      2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]: TypeError: Cannot read properties of null (reading 'token')
                                      2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]:     at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:78:22)
                                      2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]:     at processTicksAndRejections (node:internal/process/task_queues:105:5)
                                      2026-02-21 08:22:29.799  - error: host.iobroker-hausautomation Caught by controller[0]:     at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:32:3)
                                      2026-02-21 08:22:29.800  - error: host.iobroker-hausautomation Caught by controller[0]:     at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
                                      2026-02-21 08:22:29.800  - error: host.iobroker-hausautomation instance system.adapter.roborock.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      2026-02-21 08:22:29.800  - info: host.iobroker-hausautomation Restart adapter system.adapter.roborock.1 because enabled
                                      2026-02-21 08:22:32.539  - info: host.iobroker-hausautomation "system.adapter.roborock.1" disabled
                                      • stefu87_CHS
                                        stefu87_CHS
                                        stefu87_CH
                                        #1030
                                        Kann es sein, das beim Adapter irgendwie was falsch lauft?
                                        Für eine Fläche von knapp 4 m2 braucht er 234 min und berechnet eine Fläche von 4212500 m2?
                                        Cores: 1 × 8 = 8 cores
                                        Threads: 16
                                        mit Proxmox
                                        LXC Container mit Iobroker
                                        • stefu87_CHS stefu87_CH
                                          haselchenH
                                          haselchenH
                                          haselchen
                                          #1031
                                          @stefu87_CH
                                          Warum benutzt ihr nicht den mihome-vacuum Adapter?
                                          @bambam89
                                          Du hast die Ports immer noch nicht geändert.
                                          stefu87_CHS B 2 Antworten Letzte Antwort
                                          83.8k
