  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    5.9k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • E Offline
    earl80
    schrieb am zuletzt editiert von earl80
    #2336
    Am Ende kommt failed
    INFO: Kia/Hyundai OAuth2 Token Fetcher
    INFO: Select your brand:
    INFO:   1. Kia
    INFO:   2. Hyundai
    Enter choice (1 or 2): 2
    INFO: Selected: Hyundai
    INFO: Checking prerequisites
    INFO: Checking browser installation
    INFO: Browser found
    INFO: Checking dependencies
    INFO: Dependencies installed
    Remove virtual environment and dependencies after script finishes? (Y/n): y
    INFO: Setup complete. Restarting script
    INFO:   1. Kia
    INFO:   2. Hyundai
    INFO: Browser found
    INFO: Hyundai OAuth2 Token Fetcher
    INFO: Manual login with Chrome Remote Debugging
    INFO: Previous session data cleared
    INFO: Launching browser
    INFO:    OS: Windows
    INFO:    Browser: C:\Program Files\Google\Chrome\Application\chrome.exe
    INFO:    Remote debugging: Port 9222
    INFO: Chrome launched
    INFO:    Profile: C:\Users\peter\AppData\Local\Temp\chrome-kia-profile
    INFO:    Opening: https://idpconnect-eu.hyundai.com/auth/api/v2/user/oauth2/authorize?ui_locales=en&scope=openid%20profile%20email%20phone&response_type=code&client_id=peuhyundaiidm-ctb&redirect_uri=https://ctbapi.hyundai-europe.com/api/auth&state=&captcha=1&lang=en
    INFO: MANUAL LOGIN REQUIRED
    INFO: Action required in Chrome:
    INFO:   1. Log in with Hyundai credentials
    INFO:   2. Complete CAPTCHA
    INFO:   3. Wait for successful login
    Have you completed the login? (Y/n): y
    INFO: Continuing OAuth flow
    INFO: Step 2: Navigating to OAuth URL
    INFO: Navigating to OAuth redirect URL
    INFO:    URL: https://idpconnect-eu.hyundai.com/auth/api/v2/user/oauth2/authorize?response_type=code&client_id=6d477c38-XXXXXXXXX-2a1929a94654&redirect_uri=https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token&lang=en&state=ccsp
    INFO: Connecting to browser WebSocket
    INFO: Target created: 383CB706BE5425126BE6D71869215262
    INFO: Navigation command sent
    INFO: Waiting for OAuth redirect
    INFO:    Expecting automatic redirect
    INFO: Waiting for authorization code
    INFO: Authorization code extracted: 719a9b7d-XXXXXXXXXXX-b0aa-60778f...
    INFO: Final URL: https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token?code=719a9b7d-XXXXXXXXX-b0aa-60778f91...
    INFO: Step 3: Exchange code for tokens
    WARN: Token exchange failed (attempt 1/3): 400
    INFO: Retrying in 2 seconds...
    WARN: Token exchange failed (attempt 2/3): 400
    INFO: Retrying in 4 seconds...
    • arteckA Offline
      arteckA Offline
      arteck
      #2337
      schick mir mal dein login
      • arteckA Offline
        arteckA Offline
        arteck
        #2338
        es scheint als ob die hyundai Leute wieder am Server basteln.. der login geht zur zeit nicht..
        • Steven HardingS Offline
          Steven Harding
          #2339
          Moin - Jahrelang hat der Adapter problemlos funktioniert, seit ein paar Tagen bekomme ich die Fehlermeldung:
          ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"eae35b41-3859-4a5e-be3d-9ba83bb29386","errCode":"4003","errMsg":"Invalid values"}
          Die Login-Daten habe ich überprüft, der Zugang ist aktiv und der Zugriff über die App funktioniert immernoch problemlos. Hat jamend ähnliche Probleme aktuell, hat Hyundai/Kia etwas an dem Zugriff des Dienstes geändert bzw. hat jmd einen heißen Tipp für mich?
          Die Android App ist am 3.11.25 aktuallisiert worden, daher vermute ich dort eine Änderung des Dienstes und Zugriffs.
          Merci, ein weiterer Äy-Du
          • arteckA Offline
            arteckA Offline
            arteck
            #2340
            Lesen kannst du aber .. ja.. ??
            • arteckA arteck
              probier mal nach dem hier
              https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/issues/959
              und sag bescheid obs geht
              THELOH
              schrieb am zuletzt editiert von THELOH
              #2341
              @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
              Ich habe das Skript eben ausgeführt und leider auch Fehler bekommen. Hast du eine Idee oder spinnen die Server noch?
              Man merkt erst wie blöde das ist wenn man mal Manuel laden muss und die Preise beobachten muss 😂
              • E Elektronikwelt
                ist ein Hyundai Ioniq 5. Vor dem Update auf 3.1.23 und der Neuregistrierung mit dem Hyundai Account waren die Datenpunkte vorhanden.
                Entweder werden diese nicht automatisch angelegt oder sie werden nicht mehr abgerufen.
                Auch im Vehicle Status Raw finde ich die Datenpunkte nicht mehr.
                Vor dem Update waren hier die Datenpunkte vorhanden:
                bluelink.0.[meinFahrzeug].vehicleStatus.battery.soc
                Elektronikwelt
                #2342
                ich komme nochmals zurück zu dem Ordner vehicleStatus
                Hier waren früher die Werte für die Restkilometer vorhanden, die ich in der App von Bluelink sehe.
                Ebenfalls fehlt mir die Restladezeit.
                Ich habe in den Raw Datenpunkte geschaut aber nichts passendes gefunden.
                Wie komme ich wieder auf die Werte?
                • F Offline
                  fichte_112
                  #2343
                  So ist es bei mir. Hyundai Tucson PHEV.
                  Restladezeitzeit: vehicleStatusRaw.Green.ChargingInformation.Charging.RemainTime
                  Reichweite elektrisch: vehicleStatusRaw.Drivetrain.FuelSystem.DTE.EV
                  Reichweite Benzin: vehicleStatusRaw.Drivetrain.FuelSystem.DTE.ICE
                  Reichweite gesamt: vehicleStatusRaw.Drivetrain.FuelSystem.DTE.Total
                  • E Elektronikwelt
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #2344
                    @Elektronikwelt sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                    es ist ALLES aber wirklich ALLES unter RAW vorhanden.. die anderen Datenpunkte werden aus diesem Ordner IMMER befüllt..
                    also es ist ALLES dadrunter zu finden..wenns geliefert wurde
                      tilly001
                      #2345
                      @fichte_112 : Ich bekomme zum Ende des Scripts immer diese Fehlermeldung:
                      An unexpected error occurred: 'NoneType' object has no attribute 'group'
                      Cleaning up and closing the browser.
                      Hat jemand eine Idee was falsch läuft?
                      Gruß Stefan
                      • T tilly001
                        Gruß Stefan
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #2346
                        probier mal den hier
                        https://github.com/RustyDust/bluelink_refresh_token
                        damit geht es...
                        so geht der aufruf
                        python bluelinktoken.py --brand hyundai
                        • F Offline
                          fichte_112
                          schrieb am zuletzt editiert von fichte_112
                          #2347
                          @arteck
                          ich habe die Anleitung angepasst. Jetzt ist es aber wieder kein script von Dir. Sag bescheid, wenn Du das ändern möchtest.
                          Anleitung zur Erstellung eines Tokens für Hyundai oder KIA mit Windows
                          arteckA E 2 Antworten Letzte Antwort
                          • F fichte_112
                            @arteck
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #2348
                            @fichte_112 ich hab auf ein fremd script verlinkt in der doku.. hab da kein bock ständig anpssungen hinterher zu machen.. weil kia oder hyundai mal was rum fummeln....
                            • F Offline
                              fichte_112
                              #2349
                              @arteck Ich wollte dir nur bescheid geben, weil die Anleitung auf deiner github Seite verlinkt ist.
                              • F fichte_112
                                @arteck
                                earl80
                                #2350
                                @fichte_112 sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                @arteck
                                ohne `
                                iwr -UseBasicParsing -OutFile ApiToken.py https://raw.githubusercontent.com/RustyDust/bluelink_refresh_token/refs/heads/main/bluelinktoken.py
                                • F Offline
                                  fichte_112
                                  #2351
                                  Ich schau mir das morgen nochmal genauer an. Dann wird es korrigiert.
                                  • F Offline
                                    fichte_112
                                    #2352
                                    ich habe die Anleitung angepasst. Das Script ist jetzt in der Anleitung integriert und muss nicht extern geladen werden. Es kann nun kein Code von "bösen Menschen" eingefügt werden.
                                    • L Offline
                                      Liladi
                                      #2353
                                      Hallo zusammen, hoffe jemand kann mir helfen. Möchte gerne den Token auslesen um unseren KIA in den Iobroker zu integrieren. Bin der Anleitung gefolgt um Refresh Token und ein Access Token auszulesen. Wenn ich den Code ausführe und dann die Chrome Webseite öffnet, gebe ich die KIA Log in Daten ein und erhalte dann aber nach einigerzeit die Rückmeldung "ERROR Timeout - Login nicht abgeschlossen oder Erolgsmeldung Element nicht gefunden" Habe dies jetzt schon mehrmals versucht, keine Ahnung was ich falsch mache. Kann mir jemand helfen, wäre super.
                                      arteckA T 2 Antworten Letzte Antwort
                                      • L Liladi
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #2354
                                        @Liladi schick mir die login Daten mal..
                                        • L Liladi
                                          THELOH
                                          #2355
                                          @Liladi
                                          ich habe heute eine Seite gefunden, die mir den Token ausgeworfen hat.
                                          Damit und mit der Adapter Version 3.1.23 hat das nun endlich bei mir wieder funktioniert.
