  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    5.9k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    #2335
    probier mal nach dem hier
    https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/issues/959
    und sag bescheid obs geht
    • E Offline
      earl80
      schrieb am zuletzt editiert von earl80
      #2336
      Am Ende kommt failed
      INFO: Kia/Hyundai OAuth2 Token Fetcher
      INFO: Select your brand:
      INFO:   1. Kia
      INFO:   2. Hyundai
      Enter choice (1 or 2): 2
      INFO: Selected: Hyundai
      INFO: Checking prerequisites
      INFO: Checking browser installation
      INFO: Browser found
      INFO: Checking dependencies
      INFO: Dependencies installed
      Remove virtual environment and dependencies after script finishes? (Y/n): y
      INFO: Setup complete. Restarting script
      INFO:   1. Kia
      INFO:   2. Hyundai
      INFO: Browser found
      INFO: Hyundai OAuth2 Token Fetcher
      INFO: Manual login with Chrome Remote Debugging
      INFO: Previous session data cleared
      INFO: Launching browser
      INFO:    OS: Windows
      INFO:    Browser: C:\Program Files\Google\Chrome\Application\chrome.exe
      INFO:    Remote debugging: Port 9222
      INFO: Chrome launched
      INFO:    Profile: C:\Users\peter\AppData\Local\Temp\chrome-kia-profile
      INFO:    Opening: https://idpconnect-eu.hyundai.com/auth/api/v2/user/oauth2/authorize?ui_locales=en&scope=openid%20profile%20email%20phone&response_type=code&client_id=peuhyundaiidm-ctb&redirect_uri=https://ctbapi.hyundai-europe.com/api/auth&state=&captcha=1&lang=en
      INFO: MANUAL LOGIN REQUIRED
      INFO: Action required in Chrome:
      INFO:   1. Log in with Hyundai credentials
      INFO:   2. Complete CAPTCHA
      INFO:   3. Wait for successful login
      Have you completed the login? (Y/n): y
      INFO: Continuing OAuth flow
      INFO: Step 2: Navigating to OAuth URL
      INFO: Navigating to OAuth redirect URL
      INFO:    URL: https://idpconnect-eu.hyundai.com/auth/api/v2/user/oauth2/authorize?response_type=code&client_id=6d477c38-XXXXXXXXX-2a1929a94654&redirect_uri=https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token&lang=en&state=ccsp
      INFO: Connecting to browser WebSocket
      INFO: Target created: 383CB706BE5425126BE6D71869215262
      INFO: Navigation command sent
      INFO: Waiting for OAuth redirect
      INFO:    Expecting automatic redirect
      INFO: Waiting for authorization code
      INFO: Authorization code extracted: 719a9b7d-XXXXXXXXXXX-b0aa-60778f...
      INFO: Final URL: https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token?code=719a9b7d-XXXXXXXXX-b0aa-60778f91...
      INFO: Step 3: Exchange code for tokens
      WARN: Token exchange failed (attempt 1/3): 400
      INFO: Retrying in 2 seconds...
      WARN: Token exchange failed (attempt 2/3): 400
      INFO: Retrying in 4 seconds...
      • arteckA Offline
        arteckA Offline
        arteck
        #2337
        schick mir mal dein login
        • arteckA Offline
          arteckA Offline
          arteck
          #2338
          es scheint als ob die hyundai Leute wieder am Server basteln.. der login geht zur zeit nicht..
          • Steven HardingS Offline
            Steven Harding
            #2339
            Moin - Jahrelang hat der Adapter problemlos funktioniert, seit ein paar Tagen bekomme ich die Fehlermeldung:
            ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"eae35b41-3859-4a5e-be3d-9ba83bb29386","errCode":"4003","errMsg":"Invalid values"}
            Die Login-Daten habe ich überprüft, der Zugang ist aktiv und der Zugriff über die App funktioniert immernoch problemlos. Hat jamend ähnliche Probleme aktuell, hat Hyundai/Kia etwas an dem Zugriff des Dienstes geändert bzw. hat jmd einen heißen Tipp für mich?
            Die Android App ist am 3.11.25 aktuallisiert worden, daher vermute ich dort eine Änderung des Dienstes und Zugriffs.
            Merci, ein weiterer Äy-Du
            • arteckA Offline
              arteckA Offline
              arteck
              #2340
              Lesen kannst du aber .. ja.. ??
              • arteckA arteck
                THELOH
                schrieb am zuletzt editiert von THELOH
                #2341
                @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                Ich habe das Skript eben ausgeführt und leider auch Fehler bekommen. Hast du eine Idee oder spinnen die Server noch?
                Man merkt erst wie blöde das ist wenn man mal Manuel laden muss und die Preise beobachten muss 😂
                • E Elektronikwelt
                  ist ein Hyundai Ioniq 5. Vor dem Update auf 3.1.23 und der Neuregistrierung mit dem Hyundai Account waren die Datenpunkte vorhanden.
                  Entweder werden diese nicht automatisch angelegt oder sie werden nicht mehr abgerufen.
                  Auch im Vehicle Status Raw finde ich die Datenpunkte nicht mehr.
                  Vor dem Update waren hier die Datenpunkte vorhanden:
                  bluelink.0.[meinFahrzeug].vehicleStatus.battery.soc
                  Elektronikwelt
                  #2342
                  ich komme nochmals zurück zu dem Ordner vehicleStatus
                  Hier waren früher die Werte für die Restkilometer vorhanden, die ich in der App von Bluelink sehe.
                  Ebenfalls fehlt mir die Restladezeit.
                  Ich habe in den Raw Datenpunkte geschaut aber nichts passendes gefunden.
                  Wie komme ich wieder auf die Werte?
                  • F Offline
                    fichte_112
                    #2343
                    So ist es bei mir. Hyundai Tucson PHEV.
                    Restladezeitzeit: vehicleStatusRaw.Green.ChargingInformation.Charging.RemainTime
                    Reichweite elektrisch: vehicleStatusRaw.Drivetrain.FuelSystem.DTE.EV
                    Reichweite Benzin: vehicleStatusRaw.Drivetrain.FuelSystem.DTE.ICE
                    Reichweite gesamt: vehicleStatusRaw.Drivetrain.FuelSystem.DTE.Total
                    • E Elektronikwelt
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #2344
                      @Elektronikwelt sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                      es ist ALLES aber wirklich ALLES unter RAW vorhanden.. die anderen Datenpunkte werden aus diesem Ordner IMMER befüllt..
                      also es ist ALLES dadrunter zu finden..wenns geliefert wurde
                        tilly001
                        #2345
                        @fichte_112 : Ich bekomme zum Ende des Scripts immer diese Fehlermeldung:
                        An unexpected error occurred: 'NoneType' object has no attribute 'group'
                        Cleaning up and closing the browser.
                        Hat jemand eine Idee was falsch läuft?
                        Gruß Stefan
                        • T tilly001
                          Gruß Stefan
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #2346
                          probier mal den hier
                          https://github.com/RustyDust/bluelink_refresh_token
                          damit geht es...
                          so geht der aufruf
                          python bluelinktoken.py --brand hyundai
                          • F Offline
                            fichte_112
                            schrieb am zuletzt editiert von fichte_112
                            #2347
                            @arteck
                            ich habe die Anleitung angepasst. Jetzt ist es aber wieder kein script von Dir. Sag bescheid, wenn Du das ändern möchtest.
                            Anleitung zur Erstellung eines Tokens für Hyundai oder KIA mit Windows
                            arteckA E 2 Antworten Letzte Antwort
                            • F fichte_112
                              @arteck
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #2348
                              @fichte_112 ich hab auf ein fremd script verlinkt in der doku.. hab da kein bock ständig anpssungen hinterher zu machen.. weil kia oder hyundai mal was rum fummeln....
                              • F Offline
                                fichte_112
                                #2349
                                @arteck Ich wollte dir nur bescheid geben, weil die Anleitung auf deiner github Seite verlinkt ist.
                                • F fichte_112
                                  @arteck
                                  earl80
                                  #2350
                                  @fichte_112 sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  @arteck
                                  ohne `
                                  iwr -UseBasicParsing -OutFile ApiToken.py https://raw.githubusercontent.com/RustyDust/bluelink_refresh_token/refs/heads/main/bluelinktoken.py
                                  • F Offline
                                    fichte_112
                                    #2351
                                    Ich schau mir das morgen nochmal genauer an. Dann wird es korrigiert.
                                    • F Offline
                                      fichte_112
                                      #2352
                                      ich habe die Anleitung angepasst. Das Script ist jetzt in der Anleitung integriert und muss nicht extern geladen werden. Es kann nun kein Code von "bösen Menschen" eingefügt werden.
                                      • L Offline
                                        Liladi
                                        #2353
                                        Hallo zusammen, hoffe jemand kann mir helfen. Möchte gerne den Token auslesen um unseren KIA in den Iobroker zu integrieren. Bin der Anleitung gefolgt um Refresh Token und ein Access Token auszulesen. Wenn ich den Code ausführe und dann die Chrome Webseite öffnet, gebe ich die KIA Log in Daten ein und erhalte dann aber nach einigerzeit die Rückmeldung "ERROR Timeout - Login nicht abgeschlossen oder Erolgsmeldung Element nicht gefunden" Habe dies jetzt schon mehrmals versucht, keine Ahnung was ich falsch mache. Kann mir jemand helfen, wäre super.
                                        arteckA T 2 Antworten Letzte Antwort
                                        • L Liladi
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #2354
                                          @Liladi schick mir die login Daten mal..
