  4. mihome-vacuum Karten werden nicht geladen
    6.0k
29 Beiträge 6 Kommentatoren 2.1k Aufrufe 5 Beobachtet
  • M matte300
    @thomas-braun :
    Hier ist das komplette iob-diag:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.11-4-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:16:56 up 22 min,  1 user,  load average: 0.84, 0.50, 0.37
    CPU threads: 1
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-11-11 09:16:56 CET
               Universal time: Tue 2025-11-11 08:16:56 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    matte
    HOME=/home/matte
    GROUPS=matte sudo iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.3G        260M        3.1G        8.8M        980M        4.0G
    Swap:           4.3G          0B        4.3G
    Total:          8.6G        260M        7.4G
    Active iob-Instances:   0
             4096 M total memory
              248 M used memory
              600 M active memory
              423 M inactive memory
             2920 M free memory
                0 M buffer memory
              935 M swap cache
             4096 M total swap
                0 M used swap
             4096 M free swap
    top - 09:16:56 up 22 min,  1 user,  load average: 0.84, 0.50, 0.37
    Tasks:  32 total,   1 running,  31 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,   2918.6 free,    250.2 used,    935.5 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   3845.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       12G  9.8G  1.4G  88% /
    none                             tmpfs     492K  8.0K  484K   2% /dev
    /dev/mapper/pve-root             ext4       94G  4.8G   85G   6% /dev/ttyACM0
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G  144K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     7.8G  8.3M  7.8G   1% /tmp
    tmpfs                            tmpfs     1.6G  8.0K  1.6G   1% /run/user/1001
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
    |-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    |-/dev/ttyUSB0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyUSB0] ext4   rw,relatime,errors=remount-ro
    `-/dev/ttyUSB1 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyUSB1] ext4   rw,relatime,errors=remount-ro
    /var:
    3.1G    /var/
    2.3G    /var/cache/apt
    2.3G    /var/cache
    2.2G    /var/cache/apt/archives
    409M    /var/log
    Archived and active journals take up 56.8M in the file system.
    /opt/iobroker/backups:
    61M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    377M    /opt/iobroker/iobroker-data/
    285M    /opt/iobroker/iobroker-data/files
    80M     /opt/iobroker/iobroker-data/files/vis-2
    66M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_9273e15ec119ec1194c57fe5f01c6278-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI04NT4L-if00-port0
    /dev/serial/by-id/usb-0658_0200-if00
    *** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
    import tar from 'tar';
    SyntaxError: The requested module 'tar' does not provide an export named 'default'
        at ModuleJob._instantiate (node:internal/modules/esm/module_job:226:21)
        at async ModuleJob.run (node:internal/modules/esm/module_job:335:5)
        at async onImport.tracePromise.__proto__ (node:internal/modules/esm/loader:665:26)
    Node.js v22.21.0
    Hosts:
    Node.js v22.21.0
    Core adapters versions
    Node.js v22.21.0
    js-controller:
    Node.js v22.21.0
    admin:
    Node.js v22.21.0
    javascript:
    nodejs modules from github:     2
    +-- iobroker.mihome-vacuum@5.3.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git#140b7dec6648ad51692821690114fc87a343a3fb)
    +-- iobroker.openwrt@0.0.4 (git+ssh://git@github.com/Schnup89/ioBroker.openwrt.git#607c57da251a30e3bed4adcf666d6e48354d0082)
    Adapter State
    ioBroker-Repositories
    Node.js v22.21.0
    Installed ioBroker-Adapters
    Node.js v22.21.0
    Objects and States
    Objects:        0
    States:         0
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://phoscon.de/apt/deconz generic InRelease
    Hit:4 https://download.docker.com/linux/debian trixie InRelease
    Hit:5 http://security.debian.org trixie-security InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          863866     367/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          862210     1/init
    tcp        0      0 0.0.0.0:3551            0.0.0.0:*               LISTEN      0          863572     256/apcupsd
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      104        863802     231/mariadbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          862877     1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          862212     1/init
    tcp6       0      0 :::3000                 :::*                    LISTEN      103        864361     379/grafana
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          863867     367/master
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          862211     1/init
    udp6       0      0 :::111                  :::*                                0          862213     1/init
    2025-11-11 08:48:12.659  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:12.659  - info: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:12.695  - info: host.iobroker instance system.adapter.jeelink.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:12.695  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:12.696  - info: host.iobroker instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:12.696  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:12.897  - info: host.iobroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:12.919  - warn: host.iobroker instance system.adapter.pushover.0 terminated due to SIGKILL
    2025-11-11 08:48:12.920  - info: host.iobroker instance system.adapter.pushover.0 terminated with code null ()
    2025-11-11 08:48:12.920  - warn: host.iobroker instance system.adapter.mielecloudservice.0 terminated due to SIGKILL
    2025-11-11 08:48:12.920  - info: host.iobroker instance system.adapter.mielecloudservice.0 terminated with code null ()
    2025-11-11 08:48:12.920  - warn: host.iobroker instance system.adapter.eusec.0 terminated due to SIGKILL
    2025-11-11 08:48:12.920  - info: host.iobroker instance system.adapter.eusec.0 terminated with code null ()
    2025-11-11 08:48:12.952  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
    2025-11-11 08:48:12.952  - info: host.iobroker instance system.adapter.iot.0 terminated with code null ()
    2025-11-11 08:48:12.952  - warn: host.iobroker instance system.adapter.parser.0 terminated due to SIGKILL
    2025-11-11 08:48:12.952  - info: host.iobroker instance system.adapter.parser.0 terminated with code null ()
    2025-11-11 08:48:12.952  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
    2025-11-11 08:48:12.952  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
    2025-11-11 08:48:12.952  - warn: host.iobroker instance system.adapter.zwave2.0 terminated due to SIGKILL
    2025-11-11 08:48:12.952  - info: host.iobroker instance system.adapter.zwave2.0 terminated with code null ()
    2025-11-11 08:48:13.018  - info: host.iobroker instance system.adapter.zigbee2mqtt.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:13.121  - info: host.iobroker instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
    2025-11-11 08:48:13.122  - info: host.iobroker All instances are stopped.
    2025-11-11 08:48:13.313  - info: host.iobroker terminated
    @matte300
    cd /opt/iobroker
    npm install iobroker.js-controller@7.0.7 --omit=dev
    iob restart
      @matte300
      cd /opt/iobroker
      iob restart
      matte300
      schrieb am zuletzt editiert von matte300
      @thomas-braun said in mihome-vacuum Karten werden nicht geladen:
      matte@iobroker:/opt/iobroker$ npm install iobroker.js-controller@7.0.7 --omit=dev
      up to date in 4s
      260 packages are looking for funding
        run `npm fund` for details
      matte@iobroker:/opt/iobroker$ iob restart
      Aber startet leider trotzdem nicht.
      Eduard77E 1 Antwort Letzte Antwort
      • M matte300
        up to date in 4s
        Eduard77E Offline
        Eduard77E Offline
        Eduard77
        @matte300
        Das Problem mit den Karten ist dem Entwikler von Adapter @dirkhe bekannt und hängt mit Xiaomi neuen Loging Authentifizierung zusammen.
        https://forum.iobroker.net/topic/81620/mihome-vacuum-login-failed
        haselchenH M 2 Antworten Letzte Antwort
        • Eduard77E Eduard77
          @matte300
          haselchenH Offline
          haselchenH Offline
          haselchen
          @eduard77
          Warum funktioniert es bei mir? 🤔
          1x mit Valetudo , 1x ohne
            @matte300
            matte300
            @eduard77 Aber in Deinem zitierten Post geht es doch um die Cloud, oder? Ich nutze Valetudo und bekomme hier keine Login Fehler (trotzdem bekomme ich keine Daten ;-) ).
            • haselchenH haselchen
              @eduard77
              Eduard77E Offline
              Eduard77E Offline
              Eduard77
              @haselchen
              Da hast du noch Glück gehabt und dich bei Xiaomi nicht neu einlogen musstes.
              • M matte300
                Eduard77E Offline
                Eduard77E Offline
                Eduard77
                @matte300
                Da hst du recht, habe ich übersehen.
                In meisten Fällen liegt es an Canvas.
                Versuch Mal das.
                cd /opt/iobroker/node_modules/canvas/
                sudo -u iobroker npm install --omit=dev
                  @haselchen
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @eduard77
                  Technik ist kein Glück ;)
                  In meinem Account habe ich mich natürlich schon x mal ausgeloggt und wieder eingeloggt.
                  Ich hab schon nen paar Mal hier andere Setups mit meinem verglichen.
                  So grosse Unterschiede habe ich nicht gesehen.
                  Ich update auch brav den Adapter, so dass es da auch keine Unterschiede zu anderen Usern gibt.
                  Meine Einstellungen oben haste ja gesehen.
                    matte300
                    @eduard77 Danke auch für Deine Tipps!
                    Deinen Befehl hab ich ausgeführt, aber es hat nichts gebracht.
                    Mich wundert, dass in den Logs nach dem LoadMap Befehl keine sinnvolle Antwort kommt, nach allen anderen Befehlen kommen die Ergebnisse vom Sauger.
                    • M matte300
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @matte300
                      Was steht denn im cleanmap Datenpunkt ?
                        matte300
                        @haselchen Leider nichts (null):
                        • M matte300
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @matte300
                          Und wenn du den "loadmap" Button mal "drückst?
                          Hast du im Adapter auch den richtiger Sauger eingetragen?
                          Ich meine, da stand was von Auto.
                          Model und Manager sind bei dir nicht , in meinen Augen, richtig ausgefüllt.
                            @matte300
                            matte300
                            @haselchen
                            Ja, da hab ich "auto" drin. In den Logs fragt er ja das Modell ab und bekommt eine Antwort.
                            Was soll ich unter Modell eintragen? "S5" und unter Manager "Roborock"?
                            • M matte300
                              @haselchen
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @matte300
                              Das Modell was da in deinem Screenshot steht
                              Wie bei mir im Screenshot
                                @matte300
                                matte300
                                @haselchen Ich habe das eingetragen und zur Sicherheit meinen zweiten Sauger auch noch in eine Instanz gesetzt und dort auch das Modell (roborock.vacuum.s5) mit dem Own Port 53422 manuell eingetragen, aber auch dort werden leider keine Werte vom Sauger empfangen und in das Mapobjekt eingetragen.
                                  @eduard77
                                  Eduard77E Offline
                                  Eduard77E Offline
                                  Eduard77
                                  @haselchen
                                  bist du sicher, dass es bei dir funktioniert.
                                  Prüfe wann dein DP zu letzt aktualiesiert wurde.
                                  Meine Karte wird in VIS angezeigt. Nur wurde sie zu letzt am 15.08 aktualiesiert.
                                  Und hätte ich die Aktualisierung Zeit im Vis nicht angezeigt gehabt, hätte ich es nicht mitbekommen.
                                  • haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @eduard77
                                    @bahnuhr
                                    Durch die Probiererei habe ich meine Adapter Konfig zerschossen grmpf
                                    Nun geht bei mir logischerweise die Karte auch gerade nicht.
                                    Ich muss das erstmal neu aufsetzen.
                                    Edit:
                                    Nach der Neukonfiguration geht auch bei mir die Karte nicht mehr.
                                    Neugierigskeitshalber habe ich es mit HA versucht und da klappt es.
                                    Bei der Installation wird ein Captcha abgefragt. So wie es der Adapter hier machen soll laut Log.
                                    Gibt es eine softwareübergreifende Helpbase?
                                    Ich stelle mir das wahrscheinlich zu romantisch vor.
                                    So in der Art, dass man sich mit HA Leuten mal austauscht?!
                                    @dirkhe
                                      @eduard77
                                      @bahnuhr
                                      Edit:
                                      @dirkhe
                                      matte300
                                      @haselchen Oh, sorry, das tut mir leid. Ja, der Datenpunkt wird erneuert. die "null" oder "0" werden regelmäßig kurz grün, also werden dort Werte aktualisiert (auch wenn es nichts ist.
                                      Aber vielen Dank für Euren Einsatz @haselchen, @Thomas-Braun, @Eduard77
                                        dirkhe
                                        @haselchen das mit dem captcha ist schon drin, funktionierte auch am anfang, jetzt aber nicht mehr. Ich hatte hinterher auch keine muse mehr, da weiter zu forschen.
                                        • D dirkhe
                                          Eduard77E Offline
                                          Eduard77E Offline
                                          Eduard77
                                          @dirkhe
                                          könntest du bitte den Adapter nochmals anschauen.
                                          Der Entwikler von Mihome-cloud Adapter hat eine möglichkeit gefunden, wie man sich bei Xiaomi wieder verifiziert.
                                          Sehe Beitrag von Thomas.
                                          https://forum.iobroker.net/post/1325899
