  3. Off Topic
  4. Plauderecke
  5. Octoprint und Webcam
    1.0k
Geplant Angeheftet Gesperrt Verschoben Plauderecke
40 Beiträge 3 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • MichaelFM MichaelF
    Wenn die Kamera defekt wäre ging dann das hier?
    pi@OctoprintEnder:~ $ rpicam-vid -t 0 --inline --listen -o tcp://0.0.0.0:8554
    [0:25:37.894262256] [3031]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+99-bfd68f78
    [0:25:37.908162545] [3036]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:17:26)
    [0:25:37.918079664] [3036]  INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/pisp/imx219.json
    [0:25:37.932915342] [3036]  INFO Camera camera_manager.cpp:220 Adding camera '/base/axi/pcie@1000120000/rp1/i2c@80000/imx219@10' for pipeline handler rpi/pisp
    [0:25:37.932966323] [3036]  INFO RPI pisp.cpp:1179 Registered camera /base/axi/pcie@1000120000/rp1/i2c@80000/imx219@10 to CFE device /dev/media0 and ISP device /dev/media2 using PiSP variant BCM2712_C0
    Made X/EGL preview window
    Made DRM preview window
    Preview window unavailable
    Mode selection for 640:480:12:P
        SRGGB10_CSI2P,640x480/0 - Score: 1000
        SRGGB10_CSI2P,1640x1232/0 - Score: 1444.49
        SRGGB10_CSI2P,1920x1080/0 - Score: 1636.67
        SRGGB10_CSI2P,3280x2464/0 - Score: 2162.49
        SRGGB8,640x480/0 - Score: 2000
        SRGGB8,1640x1232/0 - Score: 2444.49
        SRGGB8,1920x1080/0 - Score: 2636.67
        SRGGB8,3280x2464/0 - Score: 3162.49
    Stream configuration adjusted
    [0:25:38.029040176] [3031]  INFO Camera camera.cpp:1215 configuring streams: (0) 640x480-YUV420/SMPTE170M (1) 640x480-BGGR_PISP_COMP1/RAW
    [0:25:38.029161361] [3036]  INFO RPI pisp.cpp:1483 Sensor: /base/axi/pcie@1000120000/rp1/i2c@80000/imx219@10 - Selected sensor format: 640x480-SBGGR10_1X10/RAW - Selected CFE format: 640x480-PC1B/RAW
    [libx264 @ 0x9c93b0] using cpu capabilities: ARMv6 NEON
    [libx264 @ 0x9c93b0] profile High, level 3.0, 4:2:0, 8-bit
    Output #0, h264, to 'tcp://0.0.0.0:8554?listen=1':
      Stream #0:0: Video: h264, yuv420p(tv, smpte170m/smpte170m/bt709), 640x480, q=2-31, 30 fps, 30 tbr, 1000k tbn
    #7 (0.00 fps) exp 33251.00 ag 9.85 dg 1.02
    #8 (30.00 fps) exp 33251.00 ag 9.48 dg 1.04
    #9 (30.01 fps) exp 33251.00 ag 9.48 dg 1.04
    #10 (30.00 fps) exp 33251.00 ag 9.85 dg 1.02
    #11 (30.01 fps) exp 33251.00 ag 9.85 dg 1.02
    #12 (30.01 fps) exp 33251.00 ag 8.83 dg 1.03
    #13 (30.00 fps) exp 33251.00 ag 8.83 dg 1.03
    #14 (30.01 fps) exp 33251.00 ag 8.83 dg 1.03
    #15 (30.00 fps) exp 33251.00 ag 8.83 dg 1.03
    #16 (30.00 fps) exp 33251.00 ag 8.83 dg 1.03
    #17 (30.00 fps) exp 33251.00 ag 8.83 dg 1.03
    #18 (30.01 fps) exp 33251.00 ag 8.83 dg 1.03
    #19 (30.00 fps) exp 33251.00 ag 8.83 dg 1.03
    #20 (30.00 fps) exp 33251.00 ag 8.83 dg 1.03
    #21 (30.01 fps) exp 33251.00 ag 8.83 dg 1.03
    arteckA Offline
    arteckA Offline
    arteck
    @michaelf ahh ok.. das ding liefert schon mal Bild..
    und aktiviert hast du di im octoprint ?
    MichaelFM 1 Antwort Letzte Antwort
    • arteckA arteck
      MichaelFM Offline
      MichaelFM Offline
      MichaelF
      @arteck
      Ich hoffe, oder muss ich das noch irgendwo anders aktivieren?
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        und was passiert wenn du auf den Test klickst
        • arteckA arteck
          MichaelFM Offline
          MichaelFM Offline
          MichaelF
          @arteck ist aktiviert und neu gestartet.
          Leider kein Bild:
          Thomas BraunT arteckA 2 Antworten Letzte Antwort
            Leider kein Bild:
            @michaelf
            Ist der User in der Gruppe Video drin?
            Und wie sehen die Rechte vollständig aus?
            Da liegt ja ein ACL drauf.
              @michaelf
              MichaelFM Offline
              MichaelFM Offline
              MichaelF
              Hi, da brauch ich etwas Unterstützung mein "Linux" ist nicht sooooooooo ausgeprägt.....
                Leider kein Bild:
                arteckA Offline
                arteckA Offline
                arteck
                @michaelf ein adblocker vielleicht ? in Browser .. oder pfsense oder ad blah... was weiss ich
                • arteckA arteck
                  MichaelFM Offline
                  MichaelFM Offline
                  MichaelF
                  @arteck
                  Nein, leider auch nicht.
                  Also ich habe noch ein weiteren Drucker mit der gleichen Kamera wo die Installation Problemlos ging wie in einen Howto von Octoprint beschrieben.
                  Der unterschied ein älteres OS und ein Pi3, das hier ist ein Pi5 mit neustem Image von Octoprint.
                  Das Problem gibt es anscheinend öfter wenn man in Google danach sucht.
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @michaelf irgendwo hab ich mal gelesen dass der PI5 probleme macht.. da haben wirs ja
                    • arteckA arteck
                      MichaelFM Offline
                      MichaelFM Offline
                      MichaelF
                      @arteck Ich würde auch eine andere Kaufen aber welche ist halt das Problem :-)
                        @michaelf
                        All Raspberry Pi boards with a camera connector use the same installation method, though the Raspberry Pi 5 and all Raspberry Pi Zero models require a different camera cable.
                        Und zwar dieses:
                        https://www.raspberrypi.com/products/camera-cable/
                        Quelle:
                        https://www.raspberrypi.com/documentation/accessories/camera.htm
                        Das würde auch erklären, warum es am Raspberry3 funktioniert.
                          @michaelf
                          Und zwar dieses:
                          Quelle:
                          MichaelFM Offline
                          MichaelFM Offline
                          MichaelF
                          @thomas-braun Kabel sollte passen, die Kamera bringt ja wohl auch ein Bild siehe weiter oben.
                          Das dürfte ja dann auch nicht gehen, oder ?
                            @michaelf sagte in Octoprint und Webcam:
                            Ich hab keine Kamera am Raspberry laufen, ich kann dir da also nichts aus erster Hand erzählen.
                            sudo -H -u iobroker groups
                            und
                            getfacl /pfad/zum/geraet
                            liefert jeweils?
                              und
                              liefert jeweils?
                              MichaelFM Offline
                              MichaelFM Offline
                              MichaelF
                              schrieb am zuletzt editiert von MichaelF
                              pi@OctoprintEnder:~ $ sudo -H -u iobroker groups
                              sudo: Unbekannter Benutzer iobroker
                              sudo: Audit-Plugin sudoers_audit konnte nicht initialisiert werden
                              pi@OctoprintEnder:~ $ getfacl /pfad/zum/geraet
                              getfacl: /pfad/zum/geraet: Datei oder Verzeichnis nicht gefunden
                              Zur Info, erkannt wird sie auch:
                              pi@OctoprintEnder:~ $ rpicam-still --list-cameras
                              Available cameras
                              0 : imx219 [3280x2464 10-bit RGGB] (/base/axi/pcie@1000120000/rp1/i2c@80000/imx219@10)
                                  Modes: 'SRGGB10_CSI2P' : 640x480 [103.33 fps - (1000, 752)/1280x960 crop]
                                                           1640x1232 [41.85 fps - (0, 0)/3280x2464 crop]
                                                           1920x1080 [47.57 fps - (680, 692)/1920x1080 crop]
                                                           3280x2464 [21.19 fps - (0, 0)/3280x2464 crop]
                                         'SRGGB8' : 640x480 [103.33 fps - (1000, 752)/1280x960 crop]
                                Available cameras
                                @michaelf
                                Okay, war jetzt geraten. Das hat also nur indirekt (oder garnichts?) mit dem iobroker zu tun...
                                Also verwendet der user pi die Camera? Dann halt
                                groups
                                Und den 'Pfad zum Gerät' musst du anpassen. Keine Ahnung wie der bei dir richtig lautet.
                                /dev/video*
                                oder
                                /dev/media*
                                oder ähnliches.
                                  @michaelf
                                  groups
                                  /dev/video*
                                  oder
                                  /dev/media*
                                  oder ähnliches.
                                  MichaelFM Offline
                                  MichaelFM Offline
                                  MichaelF
                                  Ich hoffe das ist richtig was ich hier gemacht habe.
                                  Ja, user ist Pi
                                  pi@OctoprintEnder:~ $ groups /dev/video*
                                  groups: „/dev/video0“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video1“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video19“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video2“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video20“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video21“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video22“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video23“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video24“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video25“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video26“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video27“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video28“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video29“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video3“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video30“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video31“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video32“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video33“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video34“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video35“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video4“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video5“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video6“: Einen solchen Benutzer gibt es nicht
                                  groups: „/dev/video7“: Einen solchen Benutzer gibt es nicht
                                    Ja, user ist Pi
                                    @michaelf
                                    Nein...
                                    Denk dir doch keine Befehle aus...
                                    Du sollst nur
                                    groups
                                    eingeben. Dann sieht man, in welchen Gruppen der User (pi in dem Fall) enthalten ist.
                                      @michaelf
                                      Nein...
                                      Du sollst nur
                                      groups
                                      MichaelFM Offline
                                      MichaelFM Offline
                                      MichaelF
                                      @thomas-braun sorry.
                                      pi adm tty dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                        @michaelf
                                        Das passt dann wohl, hatte ich aber auch nicht anders erwartet.
                                        Ich vermute da immer noch das falsche Kabel.
                                        MichaelFM 2 Antworten Letzte Antwort
                                          @michaelf
                                          MichaelFM Offline
                                          MichaelFM Offline
                                          MichaelF
                                          Bestelle dann nochmal ein anderes, im Moment ist das hier dran Link
                                          Hatte ich drauf geachtet, steht auch in den Bewertungen das meine Konstellation da funktionieren sollte.
                                          Ich stecke gleich mal das dran was bei der Kamera dabei war, mal sehen was da passiert.
